09-MPLS
HomeSupportRoutersSR6602-I[IE] SeriesReference GuidesMIB CompanionH3C SR6602-I[IE] AI-Powered ICT Converged Gateways MIB Reference(V9)-R9141-6W10009-MPLS
07-MPLS-LSR-STD-MIB
07-MPLS-LSR-STD-MIB 205.04 KB
MPLS-LSR-STD-MIB
About this MIB
A label switching router (LSR) is a router that performs MPLS forwarding. Based on the traditional routing table, LSRs establish label switching paths through a label distribution protocol to perform fast label switching.
MPLS-LSR-STD-MIB is a standard MIB based on RFC 3813.
MIB file name
rfc3813-mpls-lsr-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).mplsStdMIB(166)
Scalar objects
mplsInSegmentIndexNext (1.3.6.1.2.1.10.166.2.1.3)
Object (OID)
Access
Value range
Implementation
read-only
Octet string
Octet string (0..65535)
Next available index value for LSR incoming labels.
As per the MIB.
mplsOutSegmentIndexNext (1.3.6.1.2.1.10.166.2.1.6)
Object (OID)
Access
Value range
Implementation
read-only
Octet string
Next available index value for LSR outgoing labels.
As per the MIB.
mplsXCIndexNext (1.3.6.1.2.1.10.166.2.1.9)
Object (OID)
Access
Value range
Implementation
read-only
Octet string
Next available index value for cross-connect tables.
As per the MIB.
mplsMaxLabelStackDepth (1.3.6.1.2.1.10.166.2.1.11)
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Unsigned32
(0..2147483647)
Maximum allowed label stack depth.
As per the MIB.
mplsXCNotificationsEnable (1.3.6.1.2.1.10.166.2.1.15)
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
true(1), false(2)
Whether the notification feature is enabled.
Supports read and write operations.
Default: false(2).
Tabular objects
mplsInterfaceTable
About this table
This table contains MPLS capability information about interfaces.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is mplsInterfaceIndex.
Object (OID)
Access
Value range
Implementation
mplsInterfaceIndex (1.3.6.1.2.1.10.166.2.1.1.1.1)
not-accessible
Interger32
Interger32
(0..2147483647)
Interface index.
0 represents the per-platform label space.
mplsInterfaceLabelMinIn (1.3.6.1.2.1.10.166.2.1.1.1.2)
read-only
Unsigned32
Unsigned32
(0.. 4294967295)
Minimum incoming label of the interface.
Default: 16.
mplsInterfaceLabelMaxIn (1.3.6.1.2.1.10.166.2.1.1.1.3)
read-only
Unsigned32
Unsigned32
(0.. 4294967295)
Maximum incoming label of the interface.
The actually supported value is 1048575.
The default value varies by device models.
mplsInterfaceLabelMinOut (1.3.6.1.2.1.10.166.2.1.1.1.4)
read-only
Unsigned32
Unsigned32
(0.. 4294967295)
Minimum outgoing label of the interface.
Default: 0.
mplsInterfaceLabelMaxOut (1.3.6.1.2.1.10.166.2.1.1.1.5)
read-only
Unsigned32
Unsigned32
(0.. 4294967295)
Maximum outgoing label of the interface.
Default: 1048575.
mplsInterfaceTotalBandwidth (1.3.6.1.2.1.10.166.2.1.1.1.6)
read-only
Unsigned32
Unsigned32
(0 | 1.. 4294967295)
Total amount of usable bandwidth on this interface in Kbps.
Applies only to TE.
mplsInterfaceAvailableBandwidth (1.3.6.1.2.1.10.166.2.1.1.1.7)
read-only
Unsigned32
Unsigned32
Total amount of available bandwidth on this interface in Kbps.
Applies only to TE.
mplsInterfaceLabelParticipationType (1.3.6.1.2.1.10.166.2.1.1.1.8)
read-only
BITS
perPlatform(0), perInterface(1)
Label space type.
Supports only perPlatform.
mplsInterfacePerfTable
About this table
This table contains MPLS performance information about interfaces.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
This table does not contain indexes.
Object (OID)
Access
Value range
Implementation
mplsInterfacePerfInLabelsInUse (1.3.6.1.2.1.10.166.2.1.2.1.1)
read-only
Gauge32
Gauge32
(0..4294967295)
Number of used incoming labels on the interface.
Supports only the read operation.
mplsInterfacePerfInLabelLookupFailures (1.3.6.1.2.1.10.166.2.1.2.1.2)
read-only
Counter32
Counter32
(0..4294967295)
Number of labeled packets that have been received on this interface but were discarded because there was no matching cross-connect entry.
mplsInterfacePerfOutLabelsInUse (1.3.6.1.2.1.10.166.2.1.2.1.3)
read-only
Gauge32
Gauge32 (0..4294967295)
Number of top-most labels in the outgoing label stacks that are in use on this interface.
mplsInterfacePerfOutFragmentedPkts (1.3.6.1.2.1.10.166.2.1.2.1.4)
read-only
Counter32
Counter32 (0..4294967295)
Number of outgoing packets that required fragmentation before transmission on this interface.
mplsInSegmentTable
About this table
This table contains incoming label configuration information.
Create
Edit/Modify
Delete
Read
To create an incoming label, the mplsInSegmentLabel and mplsInSegmentRowStatus objects must be configured together. To create a static CRLSP, set mplsInSegmentTrafficParamPtr to 1.3.6.1.2.1.10.166.3.2.6.1.2.0.
Adding and deletion must be performed on a row basis. Editing is not allowed.
To delete an incoming label used by a cross-connect, first delete the cross-connect.
Supported
Columns
The table index is mplsInSegmentIndex.
Object (OID)
Access
Value range
Implementation
mplsInSegmentIndex (1.3.6.1.2.1.10.166.2.1.4.1.1)
not-accessible
Octet string
Octet string
(1..24)
Incoming label index.
0x00 is invalid.
mplsInSegmentInterface (1.3.6.1.2.1.10.166.2.1.4.1.2)
read-create
Integer32
Integer32
(0..2147483647)
Interface bound to the incoming label.
mplsInSegmentLabel  (1.3.6.1.2.1.10.166.2.1.4.1.3)
read-create
Unsigned32
Unsigned32
(0.. 4294967295)
Incoming label.
mplsInSegmentLabelPtr (1.3.6.1.2.1.10.166.2.1.4.1.4)
read-create
RowPointer
RowPointer
Incoming label extension pointer.
If the incoming label cannot be represented fully within the mplsInSegmentLabel object, this object points to an extended table.
The default value is 0.0, which indicates that this object does not point to any extended tables.
mplsInSegmentNPop (1.3.6.1.2.1.10.166.2.1.4.1.5)
read-create
Integer32
Integer32
(1..2147483647)
Number of labels to pop from the incoming packet.
Default: 1.
mplsInSegmentAddrFamily (1.3.6.1.2.1.10.166.2.1.4.1.6)
read-create
Integer
other(0),
ipV4(1),
ipV6(2),
nsap(3),
hdlc(4),
bbn1822(5),
all802(6),
e163(7),
e164(8),
f69(9),
x121(10),
ipx(11),
appleTalk(12),
decnetIV(13),
banyanVines(14),
e164withNsap(15),
dns(16),
distinguishedName(17),
asNumber(18),
xtpOverIpv4(19),
xtpOverIpv6(20),
xtpNativeModeXTP(21),
fibreChannelWWPN(22),
fibreChannelWWNN(23),
gwid(24),
reserved(65535)
Address family.
Supports only IPv4(1) and IPv6(2).
Default: nonvolatile(3).
mplsInSegmentXCIndex (1.3.6.1.2.1.10.166.2.1.4.1.7)
read-only
Octet string
Octet string
(1..24)
Cross-connect index.
0x00 indicates that no corresponding entry exists in the cross-connect table.
mplsInSegmentOwner (1.3.6.1.2.1.10.166.2.1.4.1.8)
read-only
Integer
unknown(1),
other(2),
snmp(3),
ldp(4),
crldp(5),
rsvpTe(6),
policyAgent(7)
Owner of the incoming label.
mplsInSegmentTrafficParamPtr (1.3.6.1.2.1.10.166.2.1.4.1.9)
read-create
RowPointer
RowPointer
Pointer to the traffic parameter.
The default value is 0.0, which indicates that the incoming label does not point to any table. Valid value represents static CRLSP.
mplsInSegmentRowStatus (1.3.6.1.2.1.10.166.2.1.4.1.10)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
Supports only active(1), createAndGo(4), and destroy(6).
This object returns active(1).
mplsInSegmentStorageType (1.3.6.1.2.1.10.166.2.1.4.1.11)
read-create
StorageType
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Storage type.
mplsInSegmentPerfTable
About this table
This table contains LDP entity information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are mplsLdpEntityLdpId and mplsLdpEntityIndex.
Object (OID)
Access
Value range
Implementation
mplsInSegmentPerfOctets (1.3.6.1.2.1.10.166.2.1.5.1.1)
read-only
Counter32
Counter32
(0..4294967295)
Total number of bytes received on this incoming label.
As per the MIB.
mplsInSegmentPerfPackets (1.3.6.1.2.1.10.166.2.1.5.1.2)
read-only
Counter32
Counter32
(0..4294967295)
Total number of packets received on this incoming label.
As per the MIB.
mplsInSegmentPerfErrors (1.3.6.1.2.1.10.166.2.1.5.1.3)
read-only
Counter32
Counter32
(0..4294967295)
Number of error packets received on this incoming label.
As per the MIB.
mplsInSegmentPerfDiscards (1.3.6.1.2.1.10.166.2.1.5.1.4)
read-only
Counter32
Counter32
(0..4294967295)
Number of packets received on this incoming label but were discarded.
As per the MIB.
mplsInSegmentPerfHCOctets (1.3.6.1.2.1.10.166.2.1.5.1.5)
read-only
Counter64
Counter64
(0..18446744073709551615)
As per the MIB.
mplsInSegmentPerfDiscontinuityTime (1.3.6.1.2.1.10.166.2.1.5.1.6)
read-only
TimeStamp
Standard MIB values.
System time when any one or more of this label's Counter32 or Counter64 suffered a discontinuity most recently.
As per the MIB.
mplsOutSegmentTable
About this table
This table contains outgoing label configuration information.
Create
Edit/Modify
Delete
Read
To create an outgoing label, the mplsOutSegmentInterface, mplsOutSegmentLabel, and mplsOutSegmentRowStatus objects must be configured together.
For the next hop mode, mplsOutSegmentLabel, mplsOutSegmentNextHopAddr, and mplsOutSegmentRowStatus must be configured.
To create a static CRLSP, set mplsOutSegmentTrafficParamPtr to the combination of the OID of mplsTunnelResourceMaxRateand the value of mplsOutSegmentIndex. For example, if the value of mplsOutSegmentIndex is 2048, set mplsOutSegmentTrafficParamPtr to 1.3.6.1.2.1.10.166.3.2.6.1.2.2048.
To delete an outgoing label used by a cross-connect, first delete the cross-connect.
Supported
Columns
The table index is mplsOutSegmentIndex.
Object (OID)
Access
Value range
Implementation
mplsOutSegmentIndex (1.3.6.1.2.1.10.166.2.1.7.1.1)
not-accessible
Octet string
Octet string
(1..24)
Outgoing label index.
0x00 is invalid.
mplsOutSegmentInterface (1.3.6.1.2.1.10.166.2.1.7.1.2)
read-create
Integer32
Integer32 (0..2147483647)
Interface bound to the outgoing label.
mplsOutSegmentPushTopLabel (1.3.6.1.2.1.10.166.2.1.7.1.3)
read-create
TruthValue
true(1),
false(2)
Whether or not a top label is pushed onto the outgoing packet's label stack.
mplsOutSegmentTopLabel (1.3.6.1.2.1.10.166.2.1.7.1.4)
read-create
Unsigned32
Unsigned32
(0..4294967295)
Top-most label.
This object is valid when the value of mplsOutSegmentPushTopLabel is true.
mplsOutSegmentTopLabelPtr (1.3.6.1.2.1.10.166.2.1.7.1.5)
read-create
RowPointer
RowPointer
If the label for this segment cannot be represented fully within the mplsOutSegmentLabel object, this object must point to the first accessible column of a conceptual row in an external table containing the label.
The default value is 0.0, which indicates that the outgoing label does not point to any extended table.
mplsOutSegmentNextHopAddrType (1.3.6.1.2.1.10.166.2.1.7.1.6)
read-create
Integer:unknown(0),ipv4(1),ipv6(2)
unknown(0),
ipv4(1),
ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
Next hop address type.
mplsOutSegmentNextHopAddr (1.3.6.1.2.1.10.166.2.1.7.1.7)
read-create
Octet string
Octet string
(0..255)
Next hop address.
mplsOutSegmentXCIndex (1.3.6.1.2.1.10.166.2.1.7.1.8)
read-only
Octet string
Octet string
(1..24)
mplsOutSegmentOwner (1.3.6.1.2.1.10.166.2.1.7.1.9)
read-only
Integer
unknown(1),
other(2),
snmp(3),
ldp(4),
crldp(5),
rsvpTe(6),
policyAgent(7)
Owner of the outgoing label.
As per the MIB.
mplsOutSegmentTrafficParamPtr (1.3.6.1.2.1.10.166.2.1.7.1.10)
read-create
RowPointer
RowPointer
Traffic parameter pointer.
The default value is 0.0, which indicates that the outgoing label does not point to any table. The valid value represents static CRLSP and points to mplsTunnelResourceTable
mplsOutSegmentRowStatus (1.3.6.1.2.1.10.166.2.1.7.1.11)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
mplsOutSegmentStorageType (1.3.6.1.2.1.10.166.2.1.7.1.12)
read-create
StorageType
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Storage type.
mplsOutSegmentPerfTable
About this table
This table contains outgoing label performance table information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
mplsOutSegmentPerfOctets (1.3.6.1.2.1.10.166.2.1.8.1.1)
read-only
Counter32
Counter32
 (0..4294967295)
Total number of bytes sent on this outgoing label.
As per the MIB.
mplsOutSegmentPerfPackets (1.3.6.1.2.1.10.166.2.1.8.1.2)
read-only
Counter32
Counter32
(0..4294967295)
Total number of packets sent on this outgoing label.
As per the MIB.
mplsOutSegmentPerfErrors (1.3.6.1.2.1.10.166.2.1.8.1.3)
read-only
Counter32
Counter32
 (0..4294967295)
Number of packets failed to be sent because of outgoing label error.
As per the MIB.
mplsOutSegmentPerfDiscards (1.3.6.1.2.1.10.166.2.1.8.1.4)
read-only
Counter32
Counter32
 (0..4294967295)
Number of packets sent on this outgoing label but were discarded.
As per the MIB.
mplsOutSegmentPerfHCOctets (1.3.6.1.2.1.10.166.2.1.8.1.5)
read-only
Counter64
Counter64
As per the MIB.
mplsOutSegmentPerfDiscontinuityTime (1.3.6.1.2.1.10.166.2.1.8.1.6)
read-only
TimeStamp
Value of sysUpTime on the most recent occasion at which any one or more of this outgoing label's Counter32 or Counter64 suffered a discontinuity.
As per the MIB.
mplsXCTable
About this table
This table contains cross-connect table information.
Create
Edit/Modify
Delete
Read
To create a static CRLSP, first create an mplsTunnelResourceTable object. The object index is the same as the value of mplsXCOutSegmentIndex.
To create an ingress LSP or transit LSP, mplsXCIndex must be consistent with mplsXCOutSegmentIndex.
Supported
Supported
Supported
Columns
The table indexes are mplsXCIndex, mplsXCInSegmentIndex, and mplsXCOutSegmentIndex.
Object (OID)
Access
Value range
Implementation
mplsXCIndex (1.3.6.1.2.1.10.166.2.1.10.1.1)
not-accessible
Octet string
Octet string
(1..24)
0x00 is invalid.
mplsXCInSegmentIndex (1.3.6.1.2.1.10.166.2.1.10.1.2)
not-accessible
Octet string
Octet string
(1..24)
0x00 indicates that no corresponding incoming label exists and the LSR is an ingress LSR.
mplsXCOutSegmentIndex (1.3.6.1.2.1.10.166.2.1.10.1.3)
not-accessible
Octet string
Octet string
(1..24)
0x00 indicates that no corresponding outgoing label exists and the LSR is an egress LSR.
mplsXCLspId (1.3.6.1.2.1.10.166.2.1.10.1.4)
read-create
Octet string
Octet string
(2 | 6)
LSP ID.
mplsXCOwner (1.3.6.1.2.1.10.166.2.1.10.1.6)
read-only
Integer
unknown(1),
other(2),
snmp(3),
ldp(4),
crldp(5),
rsvpTe(6),
policyAgent(7)
Owner.
As per the MIB.
mplsXCRowStatus (1.3.6.1.2.1.10.166.2.1.10.1.7)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
mplsXCStorageType (1.3.6.1.2.1.10.166.2.1.10.1.8)
read-create
StorageType
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Storage type.
mplsXCAdminStatus (1.3.6.1.2.1.10.166.2.1.10.1.9)
read-create
Integer:
up(1),
down(2),
testing(3)
Administrative state.
mplsXCOperStatus (1.3.6.1.2.1.10.166.2.1.10.1.10)
read-only
Integer
up(1),down(2),testing(3),unknown(4),dormant(5),notPresent(6),lowerLayerDown(7)
Operational state.
As per the MIB.
mplsInSegmentMapTable
About this table
This table contains incoming label mapping table information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are mplsInSegmentMapInterface, mplsInSegmentMapLabel, and mplsInSegmentMapLabelPtrIndex.
Object (OID)
Access
Value range
Implementation
mplsInSegmentMapInterface (1.3.6.1.2.1.10.166.2.1.14.1.1)
not-accessible
Integer32
Integer32
(0..2147483647)
Ingress interface.
As per the MIB.
mplsInSegmentMapLabel (1.3.6.1.2.1.10.166.2.1.14.1.2)
not-accessible
Unsigned32
Unsigned32
(0..4294967295)
Incoming label.
As per the MIB.
mplsInSegmentMapLabelPtrIndex (1.3.6.1.2.1.10.166.2.1.14.1.3)
not-accessible
RowPointer
RowPointer
If the incoming label cannot be represented fully within the mplsInSegmentMapLabel object, this object points to an extended table.
0.0 indicates that this object does not point any extended tables.
mplsInSegmentMapIndex (1.3.6.1.2.1.10.166.2.1.14.1.4)
read-only
Octet string
Octet string
(1..24)
As per the MIB.
Notifications
mplsXCUp
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.10.166.2.0.1
mplsXCup
Informational
Warning
N/A
ON
Notification triggers
This notification is generated when the MPLSXC state (mplsXCOperStatus) of a tunnel (such as LDP tunnel or MPLS TE tunnel) changes to UP.
System impact
No negative impact on services.
Status control
ON
CLI: Use the snmp-agent trap enable te command.
OFF
CLI: Use the undo snmp-agent trap enable te command.
Objects
OID (object name)
Index
Value range
1.3.6.1.2.1.10.166.2.1.10.1.9 (mplsXCAdminStatus)
Operational status of the label.
mplsXCIndex
INTEGER
up(1), down(2), testing(3)
(mplsXCOperStatus)
Actual operational status of the cross-connect.
mplsXCIndex
INTEGER
up(1), down(2),  testing(3), unknown(4), dormant(5), notPresent(6), lowerLayerDown(7)
Recommended action
No action is required.
mplsXCDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.10.166.2.0.2
A cross-connect enters down state.
Error
Major
1.3.6.1.2.1.10.166.2.0.1(mplsXCUp)
ON
This notification is generated when the MPLSXC state (mplsXCOperStatus) of a tunnel (such as LDP tunnel or MPLS TE tunnel) changes to down.
Possible causes:
1.     MPLS is disabled on the interfaces that the tunnel passes through.
2.     A protocol fault occurs on the tunnel. For example, LDP is disabled globally or on the interfaces that the tunnel passes through.
3.     A fault occurs on the path that the tunnel passes through.
4.     Dependent routes of the tunnel have been withdrawn.
5.     The tunnel is switched to a new path and the new path has problem 1 or 2.
System impact
Service traffic carried on the tunnel will be interrupted.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
mplsXCIndex
INTEGER
(mplsXCOperStatus)
mplsXCIndex
INTEGER
Recommended action
According to the protocol, tunnel destination address, outgoing interface/next hop and outgoing label information in the mplsXCDown notification message, execute the following steps to resolve this issue:
1.     Check routes: Execute the display ip routing-table command or the display ipv6 routing-table command to view whether the route corresponding to the tunnel destination address exists.
¡     If the route does not exist, configure a proper routing protocol to generate a route to the tunnel destination address. Check whether an mplsXCUp notification is generated. If yes, the issue is resolved. If not, go to step 2.
¡     If the route exists, go to step 2.
2.     According to the outgoing interface/next hop information, execute the display mpls interface command to identify whether the outgoing interface is enabled with MPLS.
¡     If the interface is not enabled with MPLS, execute the mpls enable command on the interface. Check whether an mplsXCUp notification is generated. If yes, the issue is resolved. If not, go to step 3.
¡     If the interface is enabled with MPLS, go to step 3.
3.     According to the tunnel protocol information, check the protocol capabilities on the interface. Take an LDP tunnel as an example. Execute the display mpls ldp interface command to check whether LDP is enabled on the outgoing interface.
¡     If LDP is not enabled, execute the mpls ldp command in system view to enable LDP globally and the mpls ldp enable command in interface view to enable LDP on the interface. Check whether an mplsXCUp notification is generated. If yes, the issue is resolved. If not, go to step 4.
¡     If LDP is enabled globally and on the outgoing interface, go to step 4.
4.     According to the route in step 1, find the next hop. Execute step 1 through step 3 on the next hop device. Repeat this step to troubleshoot all the nodes that the tunnel passes until the issue is resolved.
5.     If the issue persists, contact Technical Support.
