01-HH3C-MPLSEXT-MIB | 125.48 KB |
HH3C-MPLSEXT-MIB
About this MIB
Use this MIB to manage MPLS and LDP capabilities and MPLS BFD sessions.
MIB file name
rfc3812-mplsext.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).mplsStdMIB(166).mplsTeStdMIB(3)
Scalar objects
hh3cMplsExtLsrID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtLsrID (1.3.6.1.4.1.25506.2.142.1.1.1) |
read-write |
OCTET STRING |
OCTET STRING (0..255) |
Global LSR ID. |
As per the MIB. |
hh3cMplsExtLdpStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtLdpStatus (1.3.6.1.4.1.25506.2.142.1.1.2) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of global LDP. |
As per the MIB. |
Tabular objects
hh3cMplsExtTable
About this table
Use this table to configure the MPLS capability for interfaces.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
You cannot set an MTU for a tunnel interface. By default, the MPLS MTU depends on the interface MTU. Different types of interfaces have different MTU values. |
The MTU of a tunnel interface cannot be modified. |
Supported |
Supported |
Columns
The table index is hh3cMplsExtIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtIndex (1.3.6.1.4.1.25506.2.142.1.2.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (1..4294967295) |
Index of an interface. |
As per the MIB. |
hh3cMplsExtCapability (1.3.6.1.4.1.25506.2.142.1.2.1.2) |
read-create |
TruthValue |
true(1), false(2) |
MPLS capability of the interface. |
As per the MIB. |
hh3cMplsExtMtu (1.3.6.1.4.1.25506.2.142.1.2.1.3) |
read-create |
Unsigned32 |
Unsigned32 (46..65535) |
MPLS MTU of the interface. |
As per the MIB. |
hh3cMplsExtRowStatus (1.3.6.1.4.1.25506.2.142.1.2.1.4) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
Supports only active(1), createAndGo(4), and destroy(6). |
hh3cMplsExtLdpTable
About this table
Use this table to configure the LDP capability for interfaces.
Create |
Edit/Modify |
Delete |
Read |
When create, the value of hh3cMplsExtLdpCapability must be true(1). |
Supported |
Supported |
Supported |
Columns
The table index is hh3cMplsExtLdpIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtLdpIndex (1.3.6.1.4.1.25506.2.142.1.3.1.1) |
not-accessible |
Unsigned32 |
As per the MIB. |
hh3cMplsExtLdpCapability (1.3.6.1.4.1.25506.2.142.1.3.1.2) |
read-create |
TruthValue |
true(0) false(1) |
LDP capability of the interface. |
As per the MIB. |
hh3cMplsExtLdpRowStatus (1.3.6.1.4.1.25506.2.142.1.3.1.3) |
read-create |
RowStatus |
active(1),
Row status. |
hh3cMplsExtBfdTable
About this table
This table contains information about MPLS BFD sessions.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cMplsExtBfdLocalDiscr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtBfdLocalDiscr (1.3.6.1.4.1.25506.2.142.1.4.1.1) |
not-accessible |
Unsigned32 |
Local discriminator of a BFD session. |
As per the MIB. |
hh3cMplsExtBfdType (1.3.6.1.4.1.25506.2.142.1.4.1.2) |
read-only |
INTEGER |
1: unknown 4: BFD for VPLS PW 5: BFD for TE |
Type of the BFD session. |
As per the MIB. |
hh3cMplsExtBfdBindIfIndex (1.3.6.1.4.1.25506.2.142.1.4.1.3) |
read-only |
InterfaceIndexOrZero |
This object displays a tunnel interface index when the value of hh3cMplsExtBfdType is 5 (BFD for TE) and displays the index of an AC interface bound to a PW when the value of hh3cMplsExtBfdType is 3 (BFD for VPWS PW). This object is invalid and displays 0 when the value of hh3cMplsExtBfdType is not 5 (BFD for TE) or 3 (BFD for VPWS PW). |
Index of the bound local interface. |
As per the MIB. |
hh3cMplsExtBfdBindIfName (1.3.6.1.4.1.25506.2.142.1.4.1.4) |
read-only |
DisplayString |
DisplayString (0..255) |
Name of the bound local interface. |
As per the MIB. |
hh3cMplsExtBfdXcIndex (1.3.6.1.4.1.25506.2.142.1.4.1.5) |
read-only |
OCTET STRING |
OCTET STRING (0..24) |
MplsOutSegmentEntry index for an LSP entry. |
As per the MIB. |
hh3cMplsExtBfdPwBackupFlag (1.3.6.1.4.1.25506.2.142.1.4.1.6) |
read-only |
INTEGER |
1: Non-PW |
Primary or backup flag of a PW. |
As per the MIB. |
hh3cMplsExtBfdPwId (1.3.6.1.4.1.25506.2.142.1.4.1.7) |
read-only |
Unsigned32 |
Unsigned32 (0..4294967295) |
PW identifier. |
As per the MIB. |
hh3cMplsExtBfdVsiIndex (1.3.6.1.4.1.25506.2.142.1.4.1.8) |
read-only |
Unsigned32 |
VSI index + 1. |
As per the MIB. |
hh3cMplsExtBfdPwPeerIpType (1.3.6.1.4.1.25506.2.142.1.4.1.9) |
read-only |
InetAddressType |
IPv4 or IPv6. The value of this object is 0 if the BFD session is not for a PW. |
Type of the PW peer address. |
As per the MIB. |
hh3cMplsExtBfdPwPeerIp (1.3.6.1.4.1.25506.2.142.1.4.1.10) |
read-only |
InetAddress |
Peer address of the PW. |
As per the MIB. |
hh3cMplsExtBfdPwSPE (1.3.6.1.4.1.25506.2.142.1.4.1.11) |
read-only |
INTEGER |
1: Non-VPWS PW |
Node information of the VPWS PW. |
As per the MIB. |
hh3cMplsExtBfdPwEncapType (1.3.6.1.4.1.25506.2.142.1.4.1.12) |
read-only |
INTEGER |
1: unknown 2: fr-dlci-martini 3: atm-aal5-sdu 4: atm-trans-cell 5: vlan 6: ethernet 7: hdlc 8: ppp 9: cesom 10: atm-nto1-vcc 11: atm-nto1-vpc 12: ip-interworking 13: atm-1to1-vcc 14: atm-1to1-vpc 15: atm-aal5-pdu 16: fr-port 17: cep 18: satop-e1 19: satop-t1 20: satop-e3 21: satop-t3 22: esopsn-basic 23: tdmoip-aal1-mode 24: tdm-cesopsn-with-cas 25: tdmoip-aal2-mode 26: fr-dlci |
Encapsulation type of the PW. |
As per the MIB. |
hh3cMplsExtVpnStatsTable
About this table
This table contains statistical information about packets received and sent by VPNs.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cMplsExtVpnStatsVrfIndex .
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtVpnStatsVrfIndex (1.3.6.1.4.1.25506.2.142.1.5.1.1) |
not-accessible |
Unsigned32 |
Index of a VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsVpnName (1.3.6.1.4.1.25506.2.142.1.5.1.2) |
read-only |
OCTET STRING |
OCTET STRING (1..31 ) |
Name of the VPN instance. |
As per the MIB. This object is invalid if VPN statistics is not enabled. When read, this object returns a zero-length string. |
hh3cMplsExtVpnStatsInOctets (1.3.6.1.4.1.25506.2.142.1.5.1.3) |
read-only |
Counter64 |
Counter64 (0..18446744073709551615) |
Number of octets received by the VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsInPackets (1.3.6.1.4.1.25506.2.142.1.5.1.4) |
read-only |
Counter64 |
Number of packets received by the VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsInErrors (1.3.6.1.4.1.25506.2.142.1.5.1.5) |
read-only |
Counter64 |
Number of error packets received by the VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsInDiscards (1.3.6.1.4.1.25506.2.142.1.5.1.6) |
read-only |
Counter64 |
Number of incoming packets discarded by the VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsOutOctets (1.3.6.1.4.1.25506.2.142.1.5.1.7) |
read-only |
Counter64 |
Number of octets sent by the VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsOutPackets (1.3.6.1.4.1.25506.2.142.1.5.1.8) |
read-only |
Counter64 |
Number of packets sent by the VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsOutErrors (1.3.6.1.4.1.25506.2.142.1.5.1.9) |
read-only |
Counter64 |
Number of error packets sent by the VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsOutDiscards (1.3.6.1.4.1.25506.2.142.1.5.1.10) |
read-only |
Counter64 |
Number of outgoing packets discarded by the VPN instance. |
As per the MIB. |
hh3cMplsExtVpnTable
About this table
This table contains MPLS L3VPN information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cMplsExtVpnName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtVpnName (1.3.6.1.4.1.25506.2.142.1.6.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING (1..31) |
Name of a VPN instance. |
As per the MIB. |
hh3cMplsExtVrfIndex (1.3.6.1.4.1.25506.2.142.1.6.1.2) |
read-only |
Unsigned32 |
Index of the VPN instance. |
As per the MIB. |
hh3cMplsExtStaticLspTable
About this table
This table contains information about MPLS static LSPs.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cMplsExtStaticLspName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtStaticLspName (1.3.6.1.4.1.25506.2.142.1.7.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING (1..15) |
Name of a static LSP. |
As per the MIB. |
hh3cMplsExtStaticLspType (1.3.6.1.4.1.25506.2.142.1.7.1.2) |
read-only |
Enumeration |
1—Ingress 2—Transit 3—Egress |
Type of the static LSP. |
As per the MIB. |
hh3cMplsExtStaticLspInLabel (1.3.6.1.4.1.25506.2.142.1.7.1.3) |
read-only |
Unsigned integer. |
Unsigned integer. (16..4294967295) |
Incoming label for the static LSP. |
As per the MIB. |
hh3cMplsExtStaticLspOutLabel (1.3.6.1.4.1.25506.2.142.1.7.1.4) |
read-only |
Unsigned integer |
Unsigned integer. (0,3,16..4294967295) |
Outgoing label for the static LSP. |
As per the MIB. |
hh3cMplsExtStaticLspDestAddr (1.3.6.1.4.1.25506.2.142.1.7.1.5) |
read-only |
String, dotted decimal notation. |
Destination address of the static LSP. |
As per the MIB. |
hh3cMplsExtStaticLspDestAddrMaskLen (1.3.6.1.4.1.25506.2.142.1.7.1.6) |
read-only |
Unsigned integer. |
Unsigned integer. (0..32) |
Mask length of the destination address. |
As per the MIB. |
hh3cMplsExtStaticLspNextHopAddr (1.3.6.1.4.1.25506.2.142.1.7.1.7) |
read-only |
Nexthop address of the static LSP. |
As per the MIB. |
hh3cMplsExtStaticLspOutIfIndex (1.3.6.1.4.1.25506.2.142.1.7.1.8) |
read-only |
Unsigned integer. |
Unsigned integer. (0..4294967295) |
Index of the outgoing interface for this static LSP. |
As per the MIB. |
