11-ACL and QoS
HomeSupportReference GuidesMIB CompanionH3C MSR1000[2600][3600] Routers MIB Reference(V9)-R9141-6W10011-ACL and QoS
04-HH3C-QOS-CAPABILITY-MIB
04-HH3C-QOS-CAPABILITY-MIB 50.20 KB
About this MIB
Use this MIB to obtain QoS capabilities.
MIB file name
hh3c-qos-capability.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).huawei(2011).h3c(10).h3cSNMPAgCpb(7).h3cQosCapability(1)
Tabular objects
hh3cQoSSysCapabilityTable
About this table
This table obtains global QoS feature values.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table indexes are h3cQoSSysCapModuleIndex and h3cQoSSysCapCharacteristicsIndex.
Object (OID)
Access
Value range
Implementation
hh3cQoSSysCapModuleIndex (1.3.6.1.4.1.25506.7.1.1.1.2.1.1)
not-accessible
Integer32
1..2147483647
QoS module index.
As per the MIB.
hh3cQoSSysCapCharacteristicsIndex (1.3.6.1.4.1.25506.7.1.1.1.2.1.2)
not-accessible
Integer32
1..2147483647
QoS system feature index.
As per the MIB.
hh3cQoSSysCapCharacteristicsValue (1.3.6.1.4.1.25506.7.1.1.1.2.1.3)
read-only
Unsigned32
Standard MIB values.
QoS feature value.
As per the MIB.
hh3cQoSIfCapabilityTable
About this table
This table obtains interface QoS feature values.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table indexes are h3cQoSIfCapIfIndex, h3cQoSIfCapModuleIndex, and h3cQoSIfCapCharacteristicsIndex.
Object (OID)
Access
Value range
Implementation
hh3cQoSIfCapIfIndex (1.3.6.1.4.1.25506.7.1.1.1.3.1.1)
not-accessible
Integer32
0..2147483647
Interface index.
As per the MIB.
hh3cQoSIfCapModuleIndex (1.3.6.1.4.1.25506.7.1.1.1.3.1.2)
not-accessible
Integer32
0..2147483647
QoS module index.
As per the MIB.
hh3cQoSIfCapCharacteristicsIndex (1.3.6.1.4.1.25506.7.1.1.1.3.1.3)
not-accessible
Integer32
0..2147483647
QoS interface feature index.
As per the MIB.
hh3cQoSIfCapCharacteristicsValue (1.3.6.1.4.1.25506.7.1.1.1.3.1.4)
read-only
Unsigned32
QoS feature value.
As per the MIB.
