11-ACL and QoS
HomeSupportReference GuidesMIB CompanionH3C MSR1000[2600][3600] Routers MIB Reference(V9)-R9141-6W10011-ACL and QoS
02-HH3C-CBQOS2-MIB
02-HH3C-CBQOS2-MIB 359.38 KB
HH3C-CBQOS2-MIB
About this MIB
Use this MIB to configure class-based QoS (CBQoS).
CBQoS applies different service quality levels to different classes of packets, enabling multiple service support on the network.
MIB file name
hh3c-cbqos2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cQos2(65)
Scalar objects
hh3cCBQoSClassifierIndexNext
Object (OID)
Access
Value range
Implementation
hh3cCBQoSClassifierIndexNext (1.3.6.1.4.1.25506.2.65.2.1.1.1)
read-only
Integer32
Standard MIB values.
Index of the next available traffic class.
As per the MIB.
hh3cCBQoSBehaviorIndexNext
Object (OID)
Access
Value range
Implementation
hh3cCBQoSBehaviorIndexNext (1.3.6.1.4.1.25506.2.65.2.1.2.1)
read-only
Integer32
Index of the next available traffic behavior.
As per the MIB.
hh3cCBQoSPolicyIndexNext
Object (OID)
Access
Value range
Implementation
hh3cCBQoSPolicyIndexNext (1.3.6.1.4.1.25506.2.65.2.1.3.1)
read-only
Integer32
Index of the next available QoS policy.
As per the MIB.
hh3cCBQoSApplyingStatus
Object (OID)
Access
Value range
Implementation
hh3cCBQoSApplyingStatus (1.3.6.1.4.1.25506.2.65.2.1.6.1)
read-only
INTEGER
·     idle(1)
·     busy(2)
QoS policy application status.
As per the MIB.
Tabular objects
hh3cCBQoSClassifierCfgInfoTable
About this table
This table configures a traffic class.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is hh3cCBQoSClassifierIndex.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSClassifierIndex (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.1)
not-accessible
Integer32
Traffic class index.
As per the MIB.
hh3cCBQoSClassifierName (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.2)
read-create
OCTET STRING
SIZE (1..31)
Traffic class name.
As per the MIB.
hh3cCBQoSClassifierRuleCount (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.3)
read-only
Integer32
Number of match criteria.
As per the MIB.
hh3cCBQoSClassifierOperator (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.4)
read-create
INTEGER
·     and(1)
·     or(2)
Relationship among match criteria.
As per the MIB.
hh3cCBQoSClassifierType (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.6)
read-only
INTEGER
·     systemDefined(1)
·     userDefined(2)
Traffic class type.
Implementation varies by product.
hh3cCBQosClassifierMatchRuleNextIndex (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.7)
read-only
Integer32
Index used to create a match criterion.
If the value is 2147483647, the a match criterion cannot be created.
hh3cCBQoSClassifierRowStatus (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.8)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSMatchRuleCfgInfoTable
About this table
This table configures match criteria for a traffic class.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cCBQoSClassifierIndex and hh3cCBQoSMatchRuleIndex.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSMatchRuleIndex (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.1)
not-accessible
Integer32
Match criterion index.
As per the MIB.
hh3cCBQoSMatchRuleIfNot (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.2)
read-create
INTEGER
·     match(1)
·     notMatch (2)
Match attribute.
hh3cCBQoSMatchRuleType (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.3)
read-create
MatchRuleType
Match criterion type.
Supports only matchRuleAny(1), matchRuleIpv4Acl(2), matchRuleIpv6Acl(3), matchRuleIpv4Protocol(4), matchRuleIpv6Protocol(5), matchRuleDscp(7), matchIpPre(8), matchRuleVlan8021p(9), matchRuleMplsExp(10), matchSourceMac(13), matchDestinationMac(14), matchQosLocalId(15), matchRuleClassifier(16), matchInboundInterface(17), matchRtpPort(18), matchVlanID(20),matchRuleLocalPrecedence(22), matchRulePacketLentch(29).
hh3cCBQoSMatchRuleStringValue (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.4)
read-create
OCTET STRING
SIZE (1..255)
Match criterion type string value. The corresponding match criterion types include:
·     IPv4acl
·     MACACL
·     UserACL
·     IPv6acl
·     Source-MAC
·     Destination-MAC
·     Classifier
·     Inbound-interface
·     VlanID
·     SourceIp
·     MplsLabel
·     SecondMplsLabel
As per the MIB.
hh3cCBQoSMatchRuleIntValue1 (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.5)
read-create
Unsigned32
Match criterion type integer value. The corresponding match criterion types include:
·     IPv4acl
·     MACACL
·     UserACL
·     IPv6acl
·     Software QoS
·     Hardware Qos
·     RtpPort
·     IpPrec
·     Dscp
·     Vlan8021p
·     Mplsexp
·     SourceIp
·     QosLocalID
·     AtmClp
·     FrDe
·     LocalPrecedence
·     DropPriority
·     ServiceDot1p
·     SecondMplsExp
·     PacketLength
·     ForwardingLayer
As per the MIB.
hh3cCBQoSMatchRuleIntValue2 (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.6)
read-create
Unsigned32
·     RTP-PORT
·     DSCP
·     PacketLength
As per the MIB.
hh3cCBQoSMatchRuleRowStatus (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.9)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSMatchCpProtoCfgTable
About this table
Use this table to configure a match criterion to match protocol traffic to a control plane.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSMatchCpProtoIfNot (1.3.6.1.4.1.25506.2.65.2.1.1.4.1.1)
read-create
INTEGER
·     match(1)
·     matchNot(2)
Match attribute.
hh3cCBQoSMatchCpProtoValue (1.3.6.1.4.1.25506.2.65.2.1.1.4.1.2)
read-create
OCTET STRING
SIZE (0..255)
Control plane protocol.
hh3cCBQoSMatchCpProtoRowStatus (1.3.6.1.4.1.25506.2.65.2.1.1.4.1.3)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSMatchCpGroupCfgTable
About this table
Use this MIB to configure a match criterion to match protocol group traffic to a control plane.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSMatchCpGroupIfNot (1.3.6.1.4.1.25506.2.65.2.1.1.5.1.1)
read-create
INTEGER
·     match(1)
·     matchNot(2)
Match attribute.
hh3cCBQoSMatchCpGroupValue (1.3.6.1.4.1.25506.2.65.2.1.1.5.1.2)
read-create
INTEGER
·     critical(1)
·     important(2)
·     management(3)
·     normal(4)
·     redirect(5)
·     monitor(6)
·     exception(7)
Control plane protocol group.
hh3cCBQoSMatchCpGroupRowStatus (1.3.6.1.4.1.25506.2.65.2.1.1.5.1.3)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSBehaviorCfgInfoTable
About this table
This table configures match criteria for a traffic behavior.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is hh3cCBQoSBehaviorIndex.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSBehaviorIndex (1.3.6.1.4.1.25506.2.65.2.1.2.2.1.1)
not-accessible
Integer32
Traffic behavior index.
As per the MIB.
hh3cCBQoSBehaviorName (1.3.6.1.4.1.25506.2.65.2.1.2.2.1.2)
read-create
OCTET STRING
SIZE (1..31)
Traffic behavior name.
As per the MIB.
hh3cCBQoSBehaviorType (1.3.6.1.4.1.25506.2.65.2.1.2.2.1.3)
read-only
INTEGER
·     systemDefined(1)
·     userDefined(2)
Traffic behavior type.
hh3cCBQoSBehaviorRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.2.1.4)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSCarCfgInfoTable
About this table
This table configures a CAR action for a traffic behavior.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSCarCir (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.1)
read-create
Unsigned32
CIR.
Supports the range 8 to 10000000.
hh3cCBQoSCarCbs (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.2)
read-create
Unsigned32
CBS.
Supports the range 1000 to 1000000000.
hh3cCBQoSCarEbs (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.3)
read-create
Unsigned32
EBS.
Supports the range 0 to 1000000000.
hh3cCBQoSCarPir (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.4)
read-create
Unsigned32
PIR.
hh3cCBQoSCarGreenAction (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.6)
read-create
CarAction
Action to take on green packets.
Supports only pass(1), discard(3), remark-ip-pass(6), remark-mplsexp-pass(8), remark-dscp-pass(10), and remark-dot1p-pass(12).
hh3cCBQoSCarGreenRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.7)
read-create
Integer32
·     0..63
·     255
Value to mark for green packets.
As per the MIB.
hh3cCBQoSCarYellowAction (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.8)
read-create
CarAction
Action to take on yellow packets.
hh3cCBQoSCarYellowRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.9)
read-create
Integer32
·     0..63
·     255
Value to mark for yellow packets.
As per the MIB.
hh3cCBQoSCarRedAction (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.10)
read-create
CarAction
·     For VRP: Action to take on packets exceeding the CIR.
·     For 10G: Action to take on packets exceeding the PIR.
hh3cCBQoSCarRedRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.11)
read-create
Integer32
·     0..63
·     255
Value to mark for red packets.
As per the MIB.
hh3cCBQoSCarRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.13)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSGtsCfgInfoTable
About this table
This table contains GTS configuration information.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSGtsCir (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.1)
read-create
Unsigned32
CIR.
hh3cCBQoSGtsCbs (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.2)
read-create
Unsigned32
CBS.
hh3cCBQoSGtsEbs (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.3)
read-create
Unsigned32
EBS.
hh3cCBQoSGtsQueueLength (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.4)
read-create
Integer32
1..1024
Queue length.
As per the MIB.
hh3cCBQoSGtsRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.5)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSGtsPir (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.6)
read-create
Unsigned32
PIR.
hh3cCBQoSRemarkCfgInfoTable
About this table
This table contains marking configuration information.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cCBQoSBehaviorIndex and hh3cCBQoSRemarkType.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSRemarkType (1.3.6.1.4.1.25506.2.65.2.1.2.6.1.1)
not-accessible
RemarkType
Marking type.
Supports only IpPrecedence(1), Dscp(2), MplsExp(3), Vlan8021p(4), QosLocalID(8), DropPrecedence(9), and LocalPrecedence(10).
hh3cCBQoSRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.6.1.2)
read-create
Integer32
0..4095
As per the MIB.
hh3cCBQoSRemarkRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.6.1.3)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSQueueCfgInfoTable
About this table
This table contains queuing configuration information.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSQueueType (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.1)
read-create
QueueType
Queuing type.
hh3cCBQoSQueueLength (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.3)
read-create
Integer32
1..2147483647
Queue length.
Supports the range 1 to 1024.
hh3cCBQoSQueueBandwidthUnit (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.4)
read-create
QueueBandwidthUnit
Bandwidth unit.
hh3cCBQoSQueueBandwidthValue (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.5)
read-create
Integer32
·     1..100000000
·     2147483647
Bandwidth value.
Supports the range 1 to 10000000.
hh3cCBQoSQueueCbs (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.6)
read-create
Integer32
·     32..1000000000
·     2147483647
CBS.
Supports the range 32 to 1000000000.
hh3cCBQoSQueueQueueNumber (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.7)
read-create
INTEGER
·     unavailable(0)
·     a16(16)
·     a32(32)
·     a64(64)
·     a128(128)
·     a256(256)
·     a512(512)
·     a1024(1024)
·     a2048(2048)
·     a4096(4096)
Maximum number of queues.
Supports the range 16 to 4096.
hh3cCBQoSQueueCbsRatio (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.8)
read-create
Integer32
·     25..500
·     2147483647
Allowed burst ratio.
Supports the range 25 to 500.
hh3cCBQoSQueueRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.9)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSFirewallCfgInfoTable
About this table
This table contains firewall configuration information.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSFirewallAction (1.3.6.1.4.1.25506.2.65.2.1.2.12.1.1)
read-create
INTEGER
·     permit(1)
·     deny(2)
Firewall behavior.
As per the MIB.
hh3cCBQoSFirewallRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.12.1.2)
read-create
RowStatus
Row status.
As per the MIB.
hh3cCBQoSAccountCfgInfoTable
About this table
This table contains accounting configuration information.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSAccountRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.14.1.2)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSAccountingMode (1.3.6.1.4.1.25506.2.65.2.1.2.14.1.3)
read-create
INTEGER
·     auto(1)
·     packet(2)
·     byte(3)
·     both(4)
Accounting mode.
hh3cCBQoSRedirectCfgInfoTable
About this table
This table configures a redirecting action for a traffic behavior.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSRedirectType (1.3.6.1.4.1.25506.2.65.2.1.2.15.1.1)
read-create
INTEGER
·     cpu(1)
·     interface(2)
·     nextHop(3)
Redirecting destination.
hh3cCBQoSRedirectIfIndex (1.3.6.1.4.1.25506.2.65.2.1.2.15.1.2)
read-create
Integer32
Interface index.
As per the MIB.
hh3cCBQoSRedirectRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.15.1.6)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSRedirectIfVlanID (1.3.6.1.4.1.25506.2.65.2.1.2.15.1.9)
read-create
Integer32
0..4094|65535
VLAN ID.
hh3cCBQoSMirrorCfgInfoTable
About this table
This table contains flow mirroring configuration information.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSMirrorType (1.3.6.1.4.1.25506.2.65.2.1.2.17.1.1)
read-create
INTEGER
·     interface(1)
·     cpu(2)
·     vlan(3)
Mirroring destination.
hh3cCBQoSMirrorVlanID (1.3.6.1.4.1.25506.2.65.2.1.2.17.1.3)
read-create
Integer32
0..4094
Destination VLAN ID.
hh3cCBQoSMirrorRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.17.1.4)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSNestPolicyCfgInfoTable
About this table
This table nests a QoS policy.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSNestPolicyName (1.3.6.1.4.1.25506.2.65.2.1.2.19.1.1)
read-create
OCTET STRING
SIZE (1..31)
Nested policy name.
As per the MIB.
hh3cCBQoSNestPolicyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.19.1.2)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSMirrorIfCfgInfoTable
About this table
This table contains information about flow mirroring to an interface.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSMirrorIfMainIfIndex (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.1)
not-accessible
Integer32
Destination interface index.
As per the MIB.
hh3cCBQoSMirrorIfMainIfStatus (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.2)
read-only
INTEGER
·     inactive(1)
·     active(2)
Destination interface status.
As per the MIB.
hh3cCBQoSMirrorIfBackupIfIndex (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.3)
read-create
Integer32
Backup destination interface index.
hh3cCBQoSMirrorIfBackupIfStatus (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.4)
read-only
INTEGER
·     inactive(1)
·     active(2)
Backup destination interface status.
As per the MIB.
hh3cCBQoSMirrorIfRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.5)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSColoredRemarkCfgTable
About this table
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cCBQoSBehaviorIndex, hh3cCBQoSColoredRemarkType, and hh3cCBQoSColoredRemarkColor.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.65.2.1.2.21.1.1)
not-accessible
RemarkType
Marking type.
hh3cCBQoSColoredRemarkColor (1.3.6.1.4.1.25506.2.65.2.1.2.21.1.2)
not-accessible
INTEGER
·     green(1)
·     yellow(2)
·     red(3)
Marking color.
hh3cCBQoSColoredRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.21.1.3)
read-create
Integer32
0..4095
Value to mark for packets.
As per the MIB.
hh3cCBQoSColoredRemarkRowStatus
(1.3.6.1.4.1.25506.2.65.2.1.2.21.1.4)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSPrimapCfgInfoTable
About this table
This table contains information about predefined priority maps. The system modifies the priority of matching packets according to the predefined priority map.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSPrimapColorType (1.3.6.1.4.1.25506.2.65.2.1.2.22.1.1)
not-accessible
INTEGER
·     noColorMap(1)
·     colorMap(2)
Predefined priority map color attribute.
hh3cCBQoSPrePriMapTableType(1.3.6.1.4.1.25506.2.65.2.1.2.22.1.2)
not-accessible
INTEGER
·     invalid(0)
·     dot1pToLp(1)
·     dot1pToDp(2)
·     expToLp(3)
·     dscpToLp(4)
·     expToDp(5)
·     dscpToDp(6)
·     dscpToDot1p(7)
·     dot1pToDscp(8)
·     dscpToDscp(9)
·     dscpToExp(10)
·     expToDscp(11)
·     expToDot1p(12)
·     expToExp(13)
·     lpToDot1p(14)
·     dot1pToRpr(15)
·     dscpToRpr(16)
·     expToRpr(17)
·     ippreToRpr(18)
·     upToDot1p(19)
·     upToDscp(20)
·     upToExp(21)
·     upToDp(22)
·     upToLp(23)
·     upToRpr(24)
·     upToFc(25)
·     lpTodscp(26)
·     dot11eToLp(27)
·     lpToDot11e(28)
·     lpToLp(29)
·     dot1pToExp(30)
·     lpToExp(31)
·     lpToDp(32)
·     upToUp(33)
·     dot1pToDot1p(34)
Predefined priority map type.
hh3cCBQoSPrimapRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.22.1.3)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSColorMapDpCfgInfoTable
About this table
This table contains information about packet color-to-drop priority mappings. The system assigns drop priority to packets according to the packet color.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSColorMapDpEnable (1.3.6.1.4.1.25506.2.65.2.1.2.23.1.1)
read-create
INTEGER
·     true(1)
·     false(2)
Color-to-drop priority mapping enable status.
As per the MIB.
hh3cCBQoSColorMapDpRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.23.1.2)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSPolicyCfgInfoTable
About this table
This table configures a QoS policy.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSPolicyIndex (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.1)
not-accessible
Integer32
Policy index.
As per the MIB.
hh3cCBQoSPolicyName (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.2)
read-create
OCTET STRING
SIZE (1..31)
Policy name.
As per the MIB.
hh3cCBQoSPolicyClassCount (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.3)
read-only
Integer32
Number of traffic classes in the QoS policy.
As per the MIB.
hh3cCBQoSPolicyType (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.5)
read-only
INTEGER
·     systemDefined(1)
·     userDefined(2)
Policy type.
hh3cCBQoSPolicyClassNextIndex (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.6)
read-only
Integer32
Traffic class index used to create a traffic class.
If the value is 2147483647, no traffic class can be created for hh3cCBQoSPolicyClassCfgInfoTable.
hh3cCBQoSPolicyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.7)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table describes CB association information for a QoS policy.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cCBQoSPolicyIndex and hh3cCBQoSPolicyClassIndex.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSPolicyClassIndex (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.1)
not-accessible
Integer32
As per the MIB.
hh3cCBQoSPolicyClassClassifierIndex (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.2)
read-create
Integer32
As per the MIB.
hh3cCBQoSPolicyClassClassifierName (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.3)
read-only
OCTET STRING
SIZE (1..31)
Traffic class name.
As per the MIB.
hh3cCBQoSPolicyClassBehaviorIndex (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.4)
read-create
Integer32
As per the MIB.
hh3cCBQoSPolicyClassBehaviorName (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.5)
read-only
OCTET STRING
SIZE (1..31)
As per the MIB.
hh3cCBQoSPolicyClassRowStatus (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.7)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSIfApplyPolicyTable
About this table
.This table applies a QoS policy to an interface.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cCBQoSIfApplyPolicyIfIndex and hh3cCBQoSIfApplyPolicyDirection.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSIfApplyPolicyIfIndex (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.1)
accessible-for-notify
Integer32
Index of the interface to which a QoS policy is applied.
As per the MIB.
hh3cCBQoSIfApplyPolicyDirection (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.2)
DirectionType
Application direction.
As per the MIB.
hh3cCBQoSIfApplyPolicyName (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.3)
read-create
OCTET STRING
SIZE (1..31)
Policy name.
As per the MIB.
hh3cCBQoSIfApplyPolicyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.5)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSIfApplyPolicyStatus (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.6)
read-only
INTEGER
·     processing (0)
·     success (1)
·     partialItemFailed (2)
Application status.
As per the MIB.
hh3cCBQoSGlobalApplyTable
About this table
This table applies a QoS policy globally.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is hh3cCBQoSGlobalApplyDirection.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSGlobalApplyDirection (1.3.6.1.4.1.25506.2.65.2.1.4.6.1.1)
not-accessible
DirectionType
As per the MIB.
hh3cCBQoSGlobalApplyName (1.3.6.1.4.1.25506.2.65.2.1.4.6.1.2)
read-create
OCTET STRING
SIZE (1..31)
Policy name.
As per the MIB.
hh3cCBQoSGlobalApplyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.4.6.1.3)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSGlobalApplyStatus (1.3.6.1.4.1.25506.2.65.2.1.4.6.1.4)
read-only
INTEGER
·     processing (1)
·     success (2)
·     partialItemFailed (3)
Application status.
As per the MIB.
hh3cCBQoSCpApplyPolicyTable
About this table
This table describes application information for a QoS policy applied to a control plane.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cCBQoSCpApplyPolicyChassis, hh3cCBQoSCpApplyPolicySlot, and hh3cCBQoSCpApplyPolicyDirection.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSCpApplyPolicyChassis (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.1)
not-accessible
Unsigned32
Chassis number for the control plane.
As per the MIB.
(1.3.6.1.4.1.25506.2.65.2.1.4.7.1.2)
not-accessible
Unsigned32
Slot number for the control plane.
As per the MIB.
hh3cCBQoSCpApplyPolicyDirection (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.3)
not-accessible
DirectionType
As per the MIB.
hh3cCBQoSCpApplyPolicyName (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.4)
read-create
OCTET STRING
SIZE (1..31)
Policy name.
As per the MIB.
hh3cCBQoSCpApplyPolicyStatus
(1.3.6.1.4.1.25506.2.65.2.1.4.7.1.5)
read-only
INTEGER
·     processing (0)
·     success (1)
Application status.
As per the MIB.
hh3cCBQoSCpApplyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.6)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSApplyObjectTable
About this table
This table obtains the application entity information for a QoS policy.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is hh3cCBQoSApplyObjectIndex.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.1)
not-accessible
Unsigned32
Application entity index.
As per the MIB.
hh3cCBQoSApplyObjectType (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.2)
read-only
ApplyObjectType
Application entity type.
·     interface(1)
·     vlan(2)
·     controlPlane(5)
hh3cCBQoSApplyObjectDirection (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.3)
read-only
DirectionType
Application entity direction.
As per the MIB.
hh3cCBQoSApplyObjectMainSite (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.4)
read-only
Unsigned32
Main index of the application entity.
As per the MIB.
hh3cCBQoSApplyObjectSubChannel (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.5)
read-only
Unsigned32
Subchannel ID of the application entity.
As per the MIB.
hh3cCBQoSApplyObjectSubClass (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.6)
read-only
Unsigned32
Level-1 subclass number for level-2 nesting.
As per the MIB.
hh3cCBQoSApplyObjectSubClassSec (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.7)
read-only
Unsigned32
Level-2 subclass number for level-3 nesting.
As per the MIB.
hh3cCBQoSIntApplyObjectTable
About this table
This table obtains the application entity index for a QoS policy applied to an interface.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cCBQoSIntApplyObjectIfIndex and hh3cCBQoSApplyObjectDirection.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSIntApplyObjectIfIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.2.1.1)
not-accessible
Unsigned32
As per the MIB.
hh3cCBQoSIntApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.2.1.2)
read-only
Unsigned32
As per the MIB.
hh3cCBQoSNestPolicyApplyObjectTable
About this table
This table obtains the application entity index for a child QoS policy.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cCBQoSApplyObjectIndex and hh3cCBQoSNestPolicyClassIndex.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSNestPolicyClassIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.5.1.1)
not-accessible
Unsigned32
Policy class index.
As per the MIB.
hh3cCBQoSNestPolicyApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.5.1.2)
read-only
Unsigned32
As per the MIB.
hh3cCBQoSCpApplyObjectTable
About this table
This table obtains QoS policy application information for a control plane.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cCBQoSCpApplyObjectChassis, hh3cCBQoSCpApplyObjectSlot, and hh3cCBQoSApplyObjectDirection.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSCpApplyObjectChassis (1.3.6.1.4.1.25506.2.65.2.1.5.5.6.1.1)
not-accessible
Unsigned32
As per the MIB.
hh3cCBQoSCpApplyObjectSlot (1.3.6.1.4.1.25506.2.65.2.1.5.5.6.1.2)
not-accessible
Unsigned32
As per the MIB.
hh3cCBQoSCpApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.6.1.3)
read-only
Unsigned32
As per the MIB.
hh3cCBQoSCbqRunInfoTable
About this table
This table obtains CBQ queue statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSCbqQueueSize (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.1)
read-only
Integer32
Current CBQ queue size.
As per the MIB.
hh3cCBQoSCbqDiscard (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.2)
read-only
Counter64
Number of packets dropped by the CBQ queue.
As per the MIB.
hh3cCBQoSCbqEfQueueSize (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.3)
read-only
Integer32
EF queue size.
As per the MIB.
hh3cCBQoSCbqAfQueueSize (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.4)
read-only
Integer32
AF queue size.
As per the MIB.
hh3cCBQoSCbqBeQueueSize (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.5)
read-only
Integer32
BE queue size.
As per the MIB.
hh3cCBQoSCbqBeActiveQueueNum (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.6)
read-only
Integer32
Number of active BE queues.
As per the MIB.
hh3cCBQoSCbqBeMaxActiveQueueNum (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.7)
read-only
Integer32
Maximum number of active BE queues that have existed.
As per the MIB.
hh3cCBQoSCbqBeTotalQueueNum (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.8)
read-only
Integer32
Total number of BE queues.
As per the MIB.
hh3cCBQoSCbqAfAllocatedQueueNum (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.9)
read-only
Integer32
Number of AF queues that have been allocated.
As per the MIB.
hh3cCBQoSClassMatchRunInfoTable
About this table
This table obtains matching statistics about a traffic class.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cCBQoSApplyObjectIndex and hh3cCBQoSPolicyClassIndex.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSClassMatchedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.1)
read-only
Counter64
Number of matching packets.
As per the MIB.
hh3cCBQoSClassMatchedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.2)
read-only
Counter64
Number of matching bytes.
As per the MIB.
hh3cCBQoSClassBehaviorStatus (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.8)
read-only
INTEGER
·     success(1)
·     failure(2)
·     partialSuccess(3)
CB association application status.
As per the MIB.
hh3cCBQoSCarRunInfoTable
About this table
This table obtains CAR statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSCarGreenPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.1)
read-only
Counter64
Number of packets matching the CAR configuration
As per the MIB.
hh3cCBQoSCarGreenBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.2)
read-only
Counter64
Number of bytes matching the CAR configuration
As per the MIB.
hh3cCBQoSCarRedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.3)
read-only
Counter64
Number of red packets.
As per the MIB.
hh3cCBQoSCarRedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.4)
read-only
Counter64
Number of red bytes.
As per the MIB.
hh3cCBQoSCarYellowPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.5)
read-only
Counter64
Number of yellow packets.
As per the MIB.
hh3cCBQoSCarYellowBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.6)
read-only
Counter64
Number of yellow bytes.
As per the MIB.
hh3cCBQoSRemarkRunInfoTable
About this table
This table obtains marking statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSRemarkedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.5.1.1)
read-only
Counter64
Number of packets marked.
As per the MIB.
hh3cCBQoSQueueRunInfoTable
About this table
.This table obtains queue-related traffic statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSQueueMatchedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.1)
read-only
Counter64
Number of packets matching a queue.
As per the MIB.
hh3cCBQoSQueueMatchedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.2)
read-only
Counter64
Number of bytes matching the queue.
As per the MIB.
hh3cCBQoSQueueEnqueuedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.3)
read-only
Counter64
Number of packets enqueued.
As per the MIB.
hh3cCBQoSQueueEnqueuedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.4)
read-only
Counter64
Number of bytes enqueued.
As per the MIB.
hh3cCBQoSQueueDiscardedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.5)
read-only
Counter64
Number of packets dropped by the queue.
As per the MIB.
hh3cCBQoSQueueDiscardedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.6)
read-only
Counter64
Number of bytes dropped by the queue.
As per the MIB.
hh3cCBQoSAccountingRunInfoTable
About this table
This table obtains traffic statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSAccountingPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1.1)
read-only
Counter64
Number of packets.
As per the MIB.
hh3cCBQoSAccountingBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1.2)
read-only
Counter64
Number of bytes.
As per the MIB.
hh3cCBQoSAccountingPktpps (1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1.3)
read-only
Counter64
Traffic rate in pps.
As per the MIB.
hh3cCBQoSAccountingPktbps (1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1.4)
read-only
Counter64
Traffic rate in bps.
As per the MIB.
hh3cCBQoSPolicyAccRunInfoTable
About this table
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSPolicyAccPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.9.1.1)
read-only
Counter64
Number of packets.
As per the MIB.
hh3cCBQoSPolicyAccBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.9.1.2)
read-only
Counter64
Number of bytes.
As per the MIB.
