12-Network Management and Monitoring Configuration Guide
HomeSupportRouters5G IPRAN Access RoutersConfigure & DeployConfiguration GuidesH3C RA5300[5300-X][5300-AC] Routers Configuration Guides-R7752-6W10012-Network Management and Monitoring Configuration Guide
11-Network synchronization configuration
11-Network synchronization configuration 152.17 KB
Configuring network synchronization
About network synchronization
The network clock monitoring module provides network clock synchronization for all interface cards in the system. It ensures that all ports on the interface cards operate at the same clock rates for network synchronization.
The network clock monitoring module provides the following functions:
·     Provides highly precise, reliable timing signal to all interface cards.
·     Constantly monitors the signaling status on the interface cards.
·     Selects a clock reference from available clock sources, and then distributes its timing signal to all interface cards.
·     Performs phase lock to maintain a deterministic relationship between the input and output signals in frequency and phase.
Clock sources
A clock source provides timing signals for the device. Clock sources are classified into the following four types in descending order of precision.
·     BITS—Building integrated timing supply (BITS) clock. The MPU has BITS ports to receive and send timing signals.
·     Line clock—Timing signal extracted from the signal received on a port from a higher-level device. The port is called a line processing unit (LPU) port.
·     Local clock source—38.88 MHz timing signal generated by a crystal oscillator on the clock daughter card. The local clock signal has the lowest precision.
Clock source attributes
When the device receives timing signals from multiple clock sources, it will select an optimal one from the clock sources as its reference clock (reference source). In automatic clock reference selection, the clock reference is selected based on the SSM quality level and priority.
SSM quality levels
The synchronization status message (SSM) is transmitted in a synchronization distribution trail to indicate the quality of the clock source. The following are the SSM quality levels supported by the device, from the highest to the lowest:
·     PRC—G.811 primary reference clock.
·     SSU-A—G.812 primary-level SSU.
·     SSU-B—G.812 second-level SSU.
·     SEC—SDH equipment clock.
·     Unknown—Synchronization quality unknown.
·     DNU—Do not use for synchronization.
Priority
For a clock source to be selected as the clock reference, assign it a lower priority value than other clock sources. The lower the priority value, the better the clock source. For example, the clock source with a priority of 1 is better than the clock source with a priority of 3.
Clock reference selection
The network clock monitoring module supports automatic and manual clock reference selection.
Automatic reference selection
In an automatic reference selection process, the network clock monitoring module uses the SSM quality level, clock source priority, and clock source number to make a selection decision. The use of SSM in the automatic reference selection process is user configurable.
The selection process is as follows:
1.     If SSM is enabled for automatic reference selection, the module selects the clock source with the highest SSM quality level.
2.     If SSM is disabled for automatic reference selection, or clock sources have the same SSM quality level, the module selects the clock source with the lowest priority value. (A lower priority value indicates a better clock source.)
3.     If the clock sources have the same priority, the module selects the clock source that has the lowest slot-number/subslot-number/port-number sequence.
After selecting the best reference, the network clock monitoring module distributes the selected timing signal to all interface cards, and locks the timing to the reference signal. When the traced timing signal is lost, the network clock monitoring module selects the next optimal clock reference. When the signal of the best clock source can be traced again, the module selects the best clock source to replace the less optimal clock source as the reference.
A clock source will not compete in automatic reference selection if the clock source is in one of the following conditions:
·     The timing signal cannot be detected.
The clock source priority is 255 and SSM levels are ignored in automatic reference selection.
·     The SSM quality level is DNU.
Manual reference selection
In manual reference selection mode, you specify a clock source as the reference. If the specified clock reference is invalid, the module uses the local clock timing signal. After using the specified clock reference, the network clock monitoring module does not change the clock reference automatically. When the signal of the specified clock reference is lost, the module changes to the holdover state. In this state, the module continues to distribute the signal of the clock reference to the interface cards.
Clock mode on a port
IMPORTANT
IMPORTANT:
Set the clock mode to slave on the port connected to a SONET/SDH device, because the SONET/SDH clock is more precise.
A port can operate in one of the following clock modes:
·     Master—The port provides timing to the peer end. The timing signal is derived from the network clock monitoring module.
¡     If automatic reference selection is used, the timing signal is derived from the reference clock selected by the network clock monitoring module.
¡     If manual reference selection is used, the timing signal is derived from the manually specified clock reference.
¡     If the manually specified clock reference is not available, the port outputs the timing signal generated by the local clock.
·     Slave—The port uses the timing signal received from the peer end. For the network clock monitoring module to extract timing signal from a port, you must place the port in slave clock mode. If the port is in master clock mode, the module does not extract the timing signal from the incoming traffic on the port.
Network synchronization tasks at a glance
To configure network synchronization, perform the following tasks:
1.     Configuring clock reference selection
¡     Enabling automatic clock reference selection
¡     Specifying a clock reference manually
2.     (Optional.) Configuring BITS clocks
a.     Setting an Sa bit for the SSM of BITS clocks
b.     Setting the frequency of a BITS clock
3.     (Optional.) Configuring automatic reference selection parameters
¡     Configuring the method for setting the SSM quality level of a clock source
¡     Specifying an SSM quality level for a clock source
¡     Controlling the use of SSM in automatic reference selection
¡     Setting a priority for a clock source
2.     Enable automatic clock reference selection
network-clock work-mode auto
By default, clock reference is selected automatically.
If manual reference selection is used, the SSM levels and priorities configured for the clock sources do not take effect.
2.     Specify a clock reference manually.
network-clock work-mode manual source { bits0 | lpuport interface-type interface-number }
By default, the clock reference is selected automatically.
Sa bits from Sa4 through Sa8 can be used to transmit the SSM quality level of BITS timing signal. Select one Sa bit as required by the network.
2.     Specify an Sa bit for the SSM of a BITS clock.
network-clock source bits0 sa-bit { sa4 | sa5 | sa6 | sa7 | sa8 }
You can set the frequency of a BITS clock to 2 Mbps or 2 MHz.
2.     Set the frequency of a BITS clock.
network-clock source bits0 frequency { bps-2m | hz-2m }
By default, the frequency of a BITS clock is 2 Mbps.
The network clock monitoring module can use one of the following methods to assign an SSM quality level to the timing signal from a clock source:
·     Uses the SSM quality level extracted from the received timing signal.
·     Uses the SSM quality level manually assigned as described in "Specifying an SSM quality level for a clock source."
2.     Configure the method for setting the SSM quality level of a clock source.
network-clock source { bits0 | lpuport interface-type interface-number } forcessm { off | on }
By default, the quality level of a clock source is a user-defined value. The network clock monitoring module does not extract the quality level from the SSM sent by the clock source.
To extract the SSM quality level from the received timing signal, specify the off keyword. To use the manually assigned SSM quality level, specify the on keyword.
The SSM quality level you specify for a clock source takes effect only when manual SSM quality level assignment is enabled.
2.     Assign an SSM quality level to a clock source.
network-clock source { bits0 | lpuport interface-type interface-number } ssm { dnu | prc | sec | ssua | ssub | unknown }
By default, all clock sources use the unknown SSM quality level.
DNU clock sources are excluded from automatic reference selection.
3.     (Optional.) Verify that the configuration is effective.
display network-clock source
It takes time for the SSM quality level change to take effect. To verify the effectiveness of the change, you can also check the logs.
2.     Configure the use of SSM quality level in automatic reference selection.
network-clock ssmcontrol { off | on }
To ignore the SSM quality level in clock reference selection, specify the off keyword. To use the SSM quality level in clock reference selection, specify the on keyword.
In an automatic reference selection process, the network clock monitoring module selects the optimal clock as a reference from all available clock sources.
A clock source with a priority value of 255 will not take part in automatic clock reference election.
2.     Set a priority for a clock source.
network-clock source { bits0 | lpuport interface-type interface-number } priority priority
By default, all clock sources have a priority of 255. None of the clock sources can be used in automatic clock reference selection.
Display and maintenance commands for network clock monitoring module
Display information about the clock sources.
Display the operating state of the network clock monitoring module.
display network-clock status
Configuring synchronous Ethernet (SyncE)
About synchronous Ethernet
Synchronous Ethernet (SyncE) provides high-quality frequency synchronization on Ethernet at the physical layer. It can provide the same level of clock precision as SONET/SDH.
Transferring frequency signals at the physical layer, SyncE functions regardless of the network conditions such as congestion, packet loss, and delay.
Quality levels of clocks
SyncE devices use an Ethernet synchronization messaging channel (ESMC) to transmit the quality level (QL) of their system clocks. A SyncE device uses QL information to select the optimal clock reference from all available timing sources for its system clock.
The following are the QLs supported by the device, from the highest to the lowest:
·     UNK—Synchronization quality unknown.
DNU clock sources cannot participate in clock reference selection.
The system clock uses the clock reference selected with the highest QL from the following sources. If these sources have the same QL, the system clock selects the clock reference by priority, from the highest to the lowest:
·     External clock sources.
·     Line clock sources input from interfaces.
·     Internal clock sources.
The system clock uses the QL of the selected reference. Clock reference selection process starts each time the QL of a source is updated.
If QLs are the same on two interfaces, the clock source input from the lower-numbered interface has priority.
System clock QL distribution and SyncE port input QL updating
Distribution of the system clock QL
When distributing the QL of the system clock, the system uses the following rules:
·     If the clock reference is not from a SyncE port, the system distributes the QL out of all SyncE ports.
·     If the clock reference is from a SyncE port, the system distributes the QL out of all SyncE ports except for the reference input port. To prevent timing loops, the sent QL is DNU on the timing reference input port.
Input QL updating on SyncE ports
The default input QL is Unknown on a SyncE port. The port updates its input QL when it receives a quality level higher than Unknown. The Unknown level will be restored if the port does not receive ESMC packets within 5 seconds after the update.
Protocols and standards
·     ITU-T G.781, Synchronization Layer Functions
·     ITU-T G.813, Timing characteristics of SDH equipment slave clocks (SEC)
·     ITU-T G.823, The control of jitter and wander within digital networks which are based on the 2048 kbit/s hierarchy
·     ITU-T G.8261, Timing and Synchronization Aspects in Packet Networks
·     ITU-T G.8262, Timing Characteristics of a Synchronous Ethernet Equipment Slave Clock (EEC)
·     ITU-T G.8264/Y.1364, Distribution of Timing Information through Packet Networks
Configuring SyncE on an Ethernet interface
2.     Enter Ethernet interface view or FlexE physical interface view.
3.     Enable the synchronous mode.
synchronous mode
By default, Ethernet interfaces are in the non-synchronous mode. An interface can participate in the clock reference selection only when it is in the synchronous mode.
4.     (Optional.) Assign the interface to an ESMC bundle.
esmc bundle bundle-number
By default, an interface is not assigned to an ESMC bundle.
5.     Enable ESMC to transmit QL information.
esmc enable
By default, ESMC is disabled on Ethernet interfaces.
Setting the clock mode on a copper SyncE GE port
Configure the clock mode for a copper SyncE GE port based on its time synchronization direction.
By default, a copper SyncE GE port automatically negotiates its clock mode with the remote end. To avoid a negotiation result that conflicts with your clock synchronization trail design, manually set the clock mode.
·     To derive timing from the upstream clock, set the clock mode to slave.
·     To provide timing for the downstream clock, set the clock mode to master.
2.     Enter Ethernet interface view.
3.     Set the clock mode.
synce state { master | slave }
By default, the clock mode of a copper SyncE GE port is automatically negotiated.
Display and maintenance commands for SyncE
Display ESMC information.
display esmc [ interface interface-type interface-number ]
Synchronous Ethernet configuration examples
Example: Configuring SyncE
As shown in Figure 1, configure SyncE on the devices for high-precision frequency synchronization.
Figure 1 Network diagram
# On Device A, enable the synchronous mode and ESMC on Ten-GigabitEthernet 2/0/0.
[DeviceA] interface ten-gigabitethernet 2/0/0
[DeviceA-Ten-GigabitEthernet2/0/0] synchronous mode
[DeviceA-Ten-GigabitEthernet2/0/0] esmc enable
[DeviceA-Ten-GigabitEthernet2/0/0] quit
# On Device B, enable the synchronous mode and ESMC on Ten-GigabitEthernet 2/0/0.
[DeviceB] interface ten-gigabitethernet 2/0/0
[DeviceB-Ten-GigabitEthernet2/0/0] synchronous mode
[DeviceB-Ten-GigabitEthernet2/0/0] esmc enable
[DeviceB-Ten-GigabitEthernet2/0/0] quit
# Verify that ESMC is enabled on both Device A and Device B when they are connected to their respective clock references. The clock QLs of Device A and Device B are QL-PRC and QL-SEC, respectively. Device A provides more precise timing than Device B.
[DeviceA] display esmc
Interface   : Ten-GigabitEthernet2/0/0
Mode        : Synchronous
ESMC status : Enable
ESMC bundle : N/A
Port status : Up
Duplex mode : Full
QL received : QL-SEC
QL sent     : QL-PRC
ESMC information packets received : 2195
ESMC information packets sent     : 6034
ESMC event packets received       : 1
ESMC event packets sent           : 1
ESMC information rate             : 1 packets/sec
ESMC expiration                   : 5 seconds
[DeviceB] display esmc
Mode        : Synchronous
ESMC bundle : N/A
Port status : Up
Duplex mode : Full
QL received : QL-PRC
QL sent     : QL-SEC
ESMC information packets received : 6034
ESMC information packets sent     : 2195
# Verify that QL information is exchanged correctly after synchronization between Device A and Device B. Ten-GigabitEthernet2/0/0 on Device B becomes a reference input port. The clock QL sent from Device B to Device A changes to QL-DNU.
Mode        : Synchronous
ESMC bundle : N/A
Port status : Up
Duplex mode : Full
QL received : QL-DNU
QL sent     : QL-PRC
ESMC information packets received : 2573
ESMC information packets sent     : 6412
Mode        : Synchronous
ESMC bundle : N/A
Port status : Up
Duplex mode : Full
QL sent     : QL-DNU
ESMC information packets received : 6412
ESMC information packets sent     : 2573
