H3C Wi-Fi 7 Access Points Cloud Mode Web-Based Configuration Guide(R2610P06)-6W100
HomeSupportConfigure & DeployUser ManualsH3C Wi-Fi 7 Access Points Cloud Mode Web-Based Configuration Guide(R2610P06)-6W100
01-Login
01-Login 59.20 KB
Logging in to the Web interface
Log in to the Web interface through HTTP or HTTPS.
To ensure a successful login, verify that your operating system and Web browser meet the requirements, and follow the guidelines in this section.
Web browser requirements
As a best practice, use the following Web browsers:
·     Internet Explorer 10 or higher.
·     Mozilla Firefox 30.0.0.5269 or higher
·     Google Chrome 35.0.1916.114 or higher.
·     Safari 6.0 or higher.
To access the Web interface, you must use the following browser settings:
·     Accept the first-party cookies (cookies from the site you are accessing).
·     To ensure correct display of webpage contents after software upgrade or downgrade, clear data cached by the browser before you log in.
·     Enable active scripting or JavaScript, depending on the Web browser.
·     If you are using a Microsoft Internet Explorer browser, you must enable the following security settings:
¡     Run ActiveX controls and plug-ins.
¡     Script ActiveX controls marked safe for scripting.
Make sure the display resolution of the PC, laptop, or tablet that you use to access the Web interface is 1024 × 768 or higher.
Default login settings
Use settings in Table 1 for the first login.
Table 1 Default login settings
Item
Setting
Username
admin
Password
h3capadmin
User role
Logging in to the Web interface for the first time
You can log in to the device through HTTP or HTTPS. By default, HTTP and HTTPS are enabled.
To log in to the Web interface for the first time:
1.     Connect the device to the WLAN with SSID H3C_xxxxxx, where xxxxxx represents the last six characters of the device's MAC address.
2.     Visit http://10.40.94.1 through a browser.
3.     On the login page, enter the default username (admin) and the default password (h3capadmin).
4.     Click Login.
You can change the login password as prompted to enhance security.
Logging out of the Web interface
IMPORTANT
IMPORTANT:
·     For security purposes, log out of the Web interface immediately after you finish your tasks.
·     The device does not automatically save the configuration when you log out of the Web interface. To prevent the loss of configuration when the device reboots, you must save the configuration.
To log out of the Web interface:
1.     Use one of the following methods to save the current configuration:
Method 1:
Click the Save icon in the upper right corner of the Web interface.
Method 2:
a.     From the navigation pane, select System > Management > Configuration.
b.     Click Save Running Configuration.
2.     Click the admin icon in the upper right corner of the page, and then click Logout.
