03-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath F1000[F5000] Firewalls Series Command Reference(V7)-6W90203-Security Command Reference
30-Crypto engine commands
30-Crypto engine commands 54.45 KB
display crypto-engine
Use display crypto-engine to display crypto engine information.
context-admin
context-operator
If the device does not have hardware crypto engines, this command displays information only about software crypto engines.
# Display crypto engine information.
<Sysname> display crypto-engine
  Crypto engine name: cavium crypto driver
  Crypto engine state: Enabled
  Crypto engine type: Hardware
  Slot ID: 1
  CPU ID:0
  Crypto engine ID: 0
  Crypto device name: cavium crypto
  Crypto device serial number:
  Symmetric algorithms: des-ecb 3des-cbc 3des-ecb aes-cbc aes-ecb aes-ctr camellia_cbc sha1 sha2-256 sha2-384 sha2-512 md5-hmac sha1hmac sha2-256-hmac sha2-384-hmac sha2-512-hmac
  Asymmetric algorithms: dh-group1 dh-group2 dh-group5 dh-group14 dh-group24
  Random number generation function: Supported
  Crypto engine name: Software crypto engine
  Crypto engine type: Software
  Slot ID: 1
  CPU ID:0
  Crypto engine ID: 1
  Crypto device name: Software
  Symmetric algorithms: des-cbc des-ecb 3des-cbc aes-cbc aes-ecb aes-ctr camellia_cbc md5 sha1 sha2-256 sha2-384 sha2-512 md5-hmac sha1-hmac sha2-256-hmac sha2-384-hmac sha2-512-hmac aes-xcbc aes-xcbc-hmac
  Crypto engine name: inhandxdrv
  Slot ID: 2
  CPU ID: 0
  Crypto engine ID: 2
  Crypto device name: inhandxcard2/8
  Crypto device serial number: 2016091400125014
  Symmetric algorithms: sm1-cbc-128
  Asymmetric algorithms: sm2
  Random number generation function: Not Supported
Crypto engine state
Hardware crypto engine state:
·     Enabled.
·     Disabled.
This field always displays Enabled for software crypto engines.
Crypto engine type
Crypto engine type:
·     Hardware.
·     Software.
Crypto device name
Name of the crypto device.
This field displays Software for software crypto engines.
Serial number of the crypto device.
This field is always empty for software crypto engines.
Supported symmetric algorithms.
Supported asymmetric algorithms.
Whether random number generation function is supported:
·     Supported.
·     Not supported.
display crypto-engine statistics
Use display crypto-engine statistics to display crypto engine statistics.
display crypto-engine statistics [ engine-id engine-id slot slot-number ]
context-admin
context-operator
engine-id engine-id: Specifies a crypto engine by its ID. The value range for the engine-id argument is 0 to 4294967295.
slot slot-number: Specifies an IRF member device by its member ID.
If hardware crypto engines are not enabled or the device does not have hardware crypto engines, this command displays statistics only for software crypto engines.
If you do not specify any parameters, this command displays crypto engine statistics for all member devices.
# Display all crypto engine statistics.
<Sysname> display crypto-engine statistics
  Slot ID: 1
  CPU ID: 0
  Crypto engine ID: 0
  Submitted sessions: 0
  Failed sessions: 0
  Symmetric operations: 0
  Symmetric errors: 0
  Asymmetric operations: 0
  Asymmetric errors: 0
  Get-random operations: 0
  Get-random errors: 0
# Display statistics for crypto engine 1 on the specified slot.
<Sysname> display crypto-engine statistics engine-id 1 slot 1
  Failed sessions: 0
  Symmetric errors: 0
Submitted sessions
Number of established sessions.
Failed sessions
Number of failed sessions.
Number of operations using symmetric algorithms.
Symmetric errors
Number of failed operations using symmetric algorithms.
Number of operations using asymmetric algorithms.
Asymmetric errors
Number of failed operations using asymmetric algorithms.
Number of operations for obtaining random numbers.
Get-random errors
Number of failed operations for obtaining random numbers.
reset crypto-engine statistics
Use reset crypto-engine statistics to clear crypto engine statistics.
reset crypto-engine statistics [ engine-id engine-id slot slot-number ]
context-admin
If you do not specify any parameters, this command clears crypto engine statistics for all member devices.
# Clear statistics for all crypto engines.
<Sysname> reset crypto-engine statistics
# Clear statistics for crypto engine 1 on the specified slot.
<Sysname> reset crypto-engine statistics engine-id 1 slot 1
