03-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath F1000[F5000] Firewalls Series Command Reference(V7)-6W90203-Security Command Reference
16-SSH commands
16-SSH commands 476.04 KB
SSH commands
SSH server commands
display ssh server
Use display ssh server on an SSH server to display the SSH server status or sessions.
display ssh server { session [ slot slot-number ] | status }
context-admin
context-operator
session: Specifies the SSH server sessions.
status: Specifies the SSH server status.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays SSH server session information for the master device.
# Display the SSH server status.
<Sysname> display ssh server status
 Stelnet server: Disable
 SSH version : 2.0
 SSH authentication-timeout : 60 second(s)
 SSH server key generating interval : 0 hour(s)
 SSH authentication retries : 3 time(s)
 SFTP server: Disable
 SFTP server Idle-Timeout: 10 minute(s)
 NETCONF server: Disable
 SCP server: Disable
 SSH Server PKI domain name: aaa
Stelnet server
Whether the Stelnet server is enabled.
SSH version
SSH protocol version.
When the SSH server supports SSH1, the protocol version is 1.99. Otherwise, the protocol version is 2.
Authentication timeout timer.
Minimum interval for updating the RSA server key pair.
Maximum number of authentication attempts for SSH users.
SFTP server
Whether the SFTP server is enabled.
SFTP connection idle timeout timer.
NETCONF server
Whether NETCONF over SSH is enabled.
SCP server
Whether the SCP server is enabled.
Name of the PKI domain specified for the SSH server.
# Display the SSH server sessions.
<Sysname> display ssh server session
UserPid   SessID Ver   Encrypt    State          Retries  Serv     Username   Idx
 184      0      2.0   aes128-cbc Established    1        Stelnet  abc@123
UserPid
User process ID.
SessID
Session ID.
Ver
Protocol version of the SSH client.
Encrypt
Encryption algorithm used on the SSH server.
Session state:
·     Init—Initialization.
·     Ver-exchange—Version negotiation.
·     Keys-exchange—Key exchange.
·     Auth-request—Authentication request.
·     Serv-request—Session service request.
·     Established—The session is established.
·     Disconnected—The session is terminated.
Retries
Number of authentication failures.
Serv
Service type:
·     SCP.
·     SFTP.
·     Stelnet.
·     NETCONF.
Username
Username that the client uses to log in to the server.
Idx
Absolute number of the user line. The value for this field is empty if the SSH connection for the user is not redirected.
display ssh user-information
Use display ssh user-information to display information about SSH users on an SSH server.
context-admin
context-operator
username: Specifies an SSH username, a case-sensitive string of 1 to 80 characters. If you do not specify an SSH user, this command displays information about all SSH users.
This command displays information only about SSH users that are configured by using the ssh user command on the SSH server.
# Display information about all SSH users.
<Sysname> display ssh user-information
 Total ssh users:2
 Username            Authentication-type  User-public-key-name  Service-type
 yemx                password                                   Stelnet
 test                publickey            pubkey                SFTP
Total ssh users
Total number of SSH users.
Authentication-type
Authentication methods:
·     Password authentication.
·     Publickey authentication.
·     Password-publickey authentication.
·     Any authentication.
Public key name of the user.
This field is empty if the authentication method is password authentication.
Service-type
Service types:
·     all.
·     Stelnet.
·     SFTP.
·     SCP.
·     NETCONF.
ssh user
scp server enable
Use scp server enable to enable the SCP server.
Use undo scp server enable to disable the SCP server.
scp server enable
The SCP server is disabled.
context-admin
# Enable the SCP server.
[Sysname] scp server enable
display ssh server
sftp server enable
Use sftp server enable to enable the SFTP server.
Use undo sftp server enable to disable the SFTP server.
sftp server enable
The SFTP server is disabled.
context-admin
# Enable the SFTP server.
[Sysname] sftp server enable
display ssh server
sftp server idle-timeout
Use sftp server idle-timeout to set the idle timeout timer for SFTP connections on an SFTP server.
Use undo sftp server idle-timeout to restore the default.
The idle timeout timer is 10 minutes for SFTP connections.
context-admin
time-out-value: Specifies an idle timeout timer in the range of 1 to 35791 minutes.
If an SFTP connection is idle when the idle timeout timer expires, the system automatically terminates the connection. To promptly release connection resources, set the idle timeout timer to a small value when many SFTP connections concurrently exist.
# Set the idle timeout timer to 500 minutes for SFTP connections.
[Sysname] sftp server idle-timeout 500
display ssh server
ssh server acl
Use ssh server acl to specify an ACL to control IPv4 SSH connections to the server.
Use undo ssh server acl to restore the default.
undo ssh server acl
No ACLs are specified and all IPv4 SSH clients can initiate SSH connections to the server.
context-admin
advanced-acl-number: Specifies an IPv4 advanced ACL number in the range of 3000 to 3999.
basic-acl-number: Specifies an IPv4 basic ACL number in the range of 2000 to 2999.
mac mac-acl-number: Specifies a Layer 2 ACL by its number in the range of 4000 to 4999.
The ACL specified in this command filters IPv4 SSH clients' connection requests. Only the IPv4 SSH clients that the ACL permits can access the device. If the specified ACL does not exist or contains no rules, IPv4 SSH clients are not allowed to access the device.
If the vpn-instance keyword is specified in an ACL rule, the rule applies only to VPN packets. If the vpn-instance keyword is not specified in an ACL rule, the rule applies only to public network packets.
This command takes effect only on SSH connections that are initiated after the configuration of this command.
This command does not take effect on NETCONF-over-SSH connections initiated by IPv4 SSH clients. To control IPv4 clients to establish NETCONF-over-SSH connections to the server, use the netconf ssh acl command. For more information about the netconf ssh acl command, see NETCONF commands in Network Management and Monitoring Command Reference.
# Configure ACL 2001 and permit only the users at 1.1.1.1 to initiate SSH connections to the server.
[Sysname] acl basic 2001
[Sysname] ssh server acl 2001
display ssh server
Use ssh server acl-deny-log enable to enable logging for SSH login attempts that are denied by the SSH login control ACL.
Use undo ssh server acl-deny-log enable to disable logging for SSH login attempts that are denied by the SSH login control ACL.
Logging is disabled for SSH login attempts that are denied by the SSH login control ACL.
context-admin
Only SSH clients permitted by the SSH login control ACL can access the SSH server. The logging feature generates log messages for SSH login attempts that are denied by the SSH login control ACL, and sends the messages to the information center.
For information about log message output, see the information center in Network Management and Monitoring Configuration Guide. For information about configuring an SSH login control ACL, see the ssh server acl or ssh server ipv6 acl command.
# Enable logging for SSH login attempts that are denied by the SSH login control ACL.
[Sysname] ssh server acl-deny-log enable
ssh server acl
ssh server ipv6 acl
ssh server authentication-retries
Use ssh server authentication-retries to set the maximum number of authentication attempts for SSH users.
Use undo ssh server authentication-retries to restore the default.
ssh server authentication-retries retries
The maximum number of authentication attempts is 3 for SSH users.
context-admin
retries: Specifies the maximum number of authentication attempts for SSH users, in the range of 1 to 5.
Setting the maximum number of authentication attempts prevents malicious hacking of usernames and passwords.
If the total number of authentication attempts exceeds the upper limit specified in this command, further authentication is not allowed.
·     For any authentication, an authentication attempt is a publickey or password authentication process.
·     For password-publickey authentication, an authentication attempt contains both a publickey authentication process and a password authentication process. The server first uses publickey authentication, and then uses password authentication to authenticate the SSH user.
This configuration does not affect logged-in users. It affects only users that attempt to log in after the configuration.
# Set the maximum number of authentication attempts to 4 for SSH users.
[Sysname] ssh server authentication-retries 4
display ssh server
ssh server authentication-timeout
Use ssh server authentication-timeout to set the SSH user authentication timeout timer on the SSH server.
Use undo ssh server authentication-timeout to restore the default.
The SSH user authentication timeout timer is 60 seconds.
context-admin
time-out-value: Specifies an authentication timeout timer in the range of 1 to 120 seconds.
If a user does not finish the authentication when the timeout timer expires, the connection cannot be established.
To prevent malicious occupation of TCP connections, set the authentication timeout timer to a small value.
# Set the authentication timeout timer to 10 seconds for SSH users.
[Sysname] ssh server authentication-timeout 10
display ssh server
ssh server compatible-ssh1x enable
Use ssh server compatible-ssh1x enable to enable the SSH server to support SSH1 clients.
Use undo ssh server compatible-ssh1x [ enable ] to restore the default.
The SSH server does not support SSH1 clients.
context-admin
context-operator
The undo form of this command restores the default setting whether you specify the enable keyword or not.
# Enable the SSH server to support SSH1 clients.
[Sysname] ssh server compatible-ssh1x enable
display ssh server
ssh server dscp
Use ssh server dscp to set the DSCP value in the IPv4 SSH packets that the SSH server sends to SSH clients.
Use undo ssh server dscp to restore the default.
ssh server dscp dscp-value
The DSCP value is 48 in IPv4 SSH packets.
context-admin
dscp-value: Specifies the DSCP value in the IPv4 SSH packets, in the range of 0 to 63. A bigger DSCP value represents a higher priority.
The DSCP value of a packet specifies the priority of the packet and affects the transmission priority of the packet.
# Set the DSCP value to 30 for IPv4 SSH packets.
[Sysname] ssh server dscp 30
ssh server enable
Use ssh server enable to enable the Stelnet server.
Use undo ssh server enable to disable the Stelnet server.
ssh server enable
The Stelnet server is disabled.
context-admin
# Enable the Stelnet server.
[Sysname] ssh server enable
display ssh server
ssh server ipv6 acl
Use ssh server ipv6 acl to specify an ACL to control IPv6 SSH connections to the server.
Use undo ssh server ipv6 acl to restore the default.
No ACLs are specified and all IPv6 SSH clients can initiate SSH connections to the server.
context-admin
ipv6: Specifies the IPv6 ACL type.
advanced-acl-number: Specifies an IPv6 advanced ACL number in the range of 3000 to 3999.
basic-acl-number: Specifies an IPv6 basic ACL number in the range of 2000 to 2999.
The ACL specified in this command filters IPv6 SSH clients' connection requests. Only the IPv6 SSH clients that the ACL permits can access the device. If the specified ACL does not exist or contains no rules, IPv6 SSH clients are not allowed to access the device.
This command does not take effect on NETCONF-over-SSH connections initiated by IPv6 SSH clients.
# Configure ACL 2001 and permit only the users on the subnet 1::1/64 to initiate SSH connections to the server.
[Sysname] acl ipv6 basic 2001
[Sysname-acl-ipv6-basic-2001] rule permit source 1::1 64
[Sysname] ssh server ipv6 acl ipv6 2001
display ssh server
ssh server ipv6 dscp
Use ssh server ipv6 dscp to set the DSCP value in the IPv6 SSH packets that the SSH server sends to SSH clients.
Use undo ssh server ipv6 dscp to restore the default.
The DSCP value is 48 in IPv6 SSH packets.
context-admin
dscp-value: Specifies the DSCP value in the IPv6 SSH packets, in the range of 0 to 63. A bigger DSCP value represents a higher priority.
The DSCP value of an IPv6 packet specifies the priority of the packet and affects the transmission priority of the packet.
# Set the DSCP value to 30 for IPv6 SSH packets.
[Sysname] ssh server ipv6 dscp 30
ssh server key-re-exchange enable
Use ssh server key-re-exchange enable to enable SSH algorithm renegotiation and key re-exchange.
Use undo ssh server key-re-exchange enable to disable SSH algorithm renegotiation and key re-exchange.
ssh server key-re-exchange enable [ interval interval ]
SSH algorithm renegotiation and key re-exchange are disabled.
context-admin
interval interval: Specifies an interval for SSH algorithm renegotiation and key re-exchange, in the range of 1 to 24 hours. If you do not specify this option, the SSH server initiates SSH algorithm renegotiation and key re-exchange at intervals of 1 hour.
This command enables the SSH server to renegotiate algorithms and re-exchange keys at regular intervals after the first algorithm negotiation and key exchange with SSH clients.
This command takes effect only on new SSH connections that are established after the command is configured, and it does not affect existing SSH connections.
# Enable SSH algorithm renegotiation and key re-exchange.
<Sysname> sysname
[Sysname] ssh server key-re-exchange enable
ssh server pki-domain
Use ssh server pki-domain to specify a PKI domain for an SSH server.
Use undo ssh server pki-domain to restore the default.
ssh server pki-domain domain-name
No PKI domain is specified for an SSH server.
context-admin
domain-name: Specifies the name of the PKI domain used to verify the SSH server. The PKI domain name is a case-insensitive string of 1 to 31 characters. Invalid characters are tildes (~), asterisks (*), backslashes (\), vertical bars (|), colons (:), dots (.), angle brackets (< >), quotation marks ("), and apostrophes (').
# Specify PKI domain serverpkidomain for the SSH server.
[Sysname] ssh server pki-domain serverpkidomain
ssh server port
Use ssh server port to specify the SSH service port.
Use undo ssh server port to restore the default.
ssh server port port-number
The SSH service port is 22.
context-admin
port-number: Specifies a port number in the range of 1 to 65535.
CAUTION
CAUTION:
·     If you modify the SSH port number when the SSH server is enabled, the SSH service is restarted and all SSH connections are terminated after the modification. SSH users must reconnect to the SSH server to access the server.
·     If you set the SSH port to a well-known port number, the service that uses the well-known port number might fail to start. Well-known port numbers are in the range of 1 to 1024.
When the device acts as an SSH redirect server, modifying the SSH service port on the device affects existing SSH redirect connections as follows:
·     If an SSH user accesses the destination device by specifying the SSH redirect listening port, modifying the SSH service port does not affect the existing SSH redirect connection.
·     If an SSH user accesses the destination device by specifying the absolute number of the user line, modifying the SSH service port terminates the SSH redirect connection. The SSH user must reconnect to the SSH redirect server to access the destination device.
# Set the SSH service port to 1025.
[Sysname] ssh server port 1025
ssh server rekey-interval
Use ssh server rekey-interval to set the minimum interval for updating the RSA server key pair.
Use undo ssh server rekey-interval to restore the default.
ssh server rekey-interval interval
The minimum interval for updating the RSA server key pair is 0 hours. The system does not update the RSA server key pair.
context-admin
interval: Specifies the minimum interval for updating the RSA server key pair, in the range of 1 to 24 hours.
Periodically updating the RSA server key pair prevents malicious hacking to the key pair and enhances security of the SSH connections.
The system starts to count down the configured minimum update interval after the first SSH1 user logs in to the server. If a new SSH1 user logs in to the server after the interval, the system performs the following operations:
1.     Updates the RSA server key pair.
2.     Uses the updated RSA server key pair for key pair negotiation with the new user.
3.     Resets the interval and starts to count down the interval again.
This command takes effect only on SSH1 clients.
# Set the minimum interval to 3 hours for updating the RSA server key pair.
[Sysname] ssh server rekey-interval 3
display ssh server
ssh user
Use ssh user to create an SSH user and specify the service type and authentication method.
Use undo ssh user to delete an SSH user.
ssh user username service-type { all | netconf | scp | sftp | stelnet } authentication-type { password | { any | password-publickey | publickey } [ assign { pki-domain domain-name | publickey keyname } ] }
undo ssh user username
No SSH users exist.
context-admin
username: Specifies an SSH username, a case-sensitive string of 1 to 80 characters. The username cannot be a, al, or all. In addition, the username cannot include vertical bars (|), colons (:), asterisks (*), question marks (?), or angle brackets (< >). The at sign (@), slash (/), and backslash (\) can only be used to append ISP domain names to usernames in the pureusername@domain, pureusername/domain, and domain\pureusername format. Do not include hyphens (-) in the username of an SCP user. Otherwise, SCP logins using that username will fail.
service-type: Specifies a service type for the SSH user.
·     all: Specifies service types Stelnet, SFTP, SCP, and NETCONF.
·     scp: Specifies the service type SCP.
·     sftp: Specifies the service type SFTP.
·     stelnet: Specifies the service type Stelnet.
·     netconf: Specifies the service type NETCONF.
authentication-type: Specifies an authentication method for the SSH user.
·     password: Specifies password authentication. This authentication method provides easy and fast encryption, but it is vulnerable. It can work with AAA to implement user authentication, authorization, and accounting.
·     any: Specifies either password authentication or publickey authentication.
·     password-publickey: Specifies both password authentication and publickey authentication for SSH2 clients. In SSH2, the password-publickey authentication method provides higher security. If the client runs SSH1, this keyword specifies either password authentication or publickey authentication.
·     publickey: Specifies publickey authentication. This authentication method has complicated and slow encryption, but it provides strong authentication that can defend against brute-force attacks. This authentication method is easy to use. If this method is configured, the authentication process completes automatically without entering any password.
assign: Specifies parameters used for client verification.
·     pki-domain domain-name: Specifies the PKI domain that verifies the client's digital certificate. The domain-name argument is a case-insensitive string of 1 to 31 characters. Invalid characters are tildes (~), asterisks (*), backslashes (\), vertical bars (|), colons (:), dots (.), angle brackets (< >), quotation marks ("), and apostrophes ('). The server uses the CA certificate that is saved in the PKI domain to verify the client's digital certificate. In this scenario, the server does not need to save clients' public keys in advance.
·     publickey keyname: Specifies the public key of the SSH client. The keyname argument represents the name of the SSH client's public key configured on the server. It is a case-insensitive string of 1 to 64 characters. The server uses the client's public key to check the validity of the client. If the public key file of the client is changed, you must update the client's public key on the server promptly.
Use this command to configure an SSH user depending on the authentication method.
·     If the authentication method is publickey, you must create an SSH user and a local user on the SSH server. The two users must have the same username, so that the SSH user can be assigned the correct working directory and user role.
·     If the authentication method is password, you must perform one of the following tasks:
¡     For local authentication, configure a local user on the SSH server.
¡     For remote authentication, configure an SSH user on a remote authentication server, for example, a RADIUS server.
You do not need to create an SSH user by using the ssh user command. However, if you want to display all SSH users, including the password-only SSH users, for centralized management, you can use this command to create them. If such an SSH user has been created, make sure you have specified the correct service type and authentication method.
·     If the authentication method is password-publickey or any, you must create an SSH user on the SSH server and perform one of the following tasks:
In either case, the local user or the SSH user configured on the remote authentication server must have the same username as the SSH user.
For an SFTP or SCP user, the working directory depends on the authentication method.
·     If the authentication method is publickey or password-publickey, the working directory is specified by the authorization-attribute command in the associated local user view.
·     If the authentication method is password, the working directory is authorized by AAA.
For an SSH user, the user role also depends on the authentication method.
·     If the authentication method is publickey or password-publickey, the user role is specified by the authorization-attribute command in the associated local user view.
·     If the authentication method is password, the user role is authorized by AAA.
If you use this command to specify a host public key or a PKI domain for a user multiple times, the most recent configuration takes effect. If neither a host public key nor a PKI domain is specified for the user, the user uses certificate authentication for login. The server uses the PKI domain of its own certificate to verify the client's certificate.
The command configuration does not affect logged-in users. It affects only users that attempt to log in after the configuration.
# Create an SSH user named user1. Specify the service type as sftp and the authentication method as password-publickey for the user. Assign the host public key key1 to the user.
[Sysname] ssh user user1 service-type sftp authentication-type password-publickey assign publickey key1
# Create a local device management user named user1. Specify the password as 123456TESTplat&! in plain text and the service type as ssh for the user. Assign the working directory flash: and the network-admin user role to the user.
[Sysname-luser-manage-user1] service-type ssh
[Sysname-luser-manage-user1] authorization-attribute work-directory flash: user-role network-admin
local-user
pki domain
SSH client commands
bye
Use bye to terminate the connection with the SFTP server and return to user view.
bye
SFTP client view
context-admin
This command has the same function as the exit and quit commands.
# Terminate the connection with the SFTP server.
sftp> bye
<Sysname>
cd
Use cd to change the working directory on the SFTP server.
cd [ remote-path ]
SFTP client view
context-admin
remote-path: Specifies the name of a directory on the server.
You can use the cd .. command to return to the upper-level directory.
You can use the cd / command to return to the root directory of the system.
# Change the working directory to new1.
sftp> cd new1
Current Directory is:/new1
sftp> pwd
Remote working directory: /new1
sftp>
cdup
Use cdup to return to the upper-level directory.
cdup
SFTP client view
context-admin
Example
# Return to the upper-level directory from the current working directory /test1.
sftp> cd test1
Current Directory is:/test1
sftp> pwd
Remote working directory: /test1
sftp> cdup
sftp> pwd
sftp>
delete
Use delete to delete a file from the SFTP server.
delete remote-file
SFTP client view
context-admin
remote-file: Specifies a file by its name.
This command has the same function as the remove command.
# Delete file temp.c from the SFTP server.
sftp> delete temp.c
Removing /temp.c
dir
Use dir to display information about the files and subdirectories under a directory.
SFTP client view
context-admin
-a: Displays detailed information about files and subdirectories under a directory in a list, including the files and subdirectories with names starting with dots (.).
-l: Displays detailed information about the files and subdirectories under a directory in a list, excluding the files and subdirectories with names starting with dots (.).
remote-path: Specifies the name of the directory to be queried. If you do not specify this argument, the command displays information about the files and subdirectories under the current working directory.
If you do not specify both of the –a and –l keywords, this command displays the names of the files and subdirectories under a directory.
This command has the same function as the ls command.
# Display detailed information about the files and subdirectories under the current directory, including the files and subdirectories with names starting with dots (.).
sftp> dir -a
drwxrwxrwx    2 1        1               512 Dec 18 14:12 .
drwxrwxrwx    2 1        1               512 Dec 18 14:12 ..
-rwxrwxrwx    1 1        1               301 Dec 18 14:11 010.pub
-rwxrwxrwx    1 1        1               301 Dec 18 14:12 011.pub
-rwxrwxrwx    1 1        1               301 Dec 18 14:12 012.pub
# Display detailed information about the files and subdirectories under the current directory, excluding the files and subdirectories with names starting with dots (.).
sftp> dir -l
display sftp client source
Use display sftp client source to display the source IP address configuration of the SFTP client.
context-admin
context-operator
# Display the source IP address configuration of the SFTP client.
<Sysname> display sftp client source
The source IP address of the SFTP client is 192.168.0.1
The source IPv6 address of the SFTP client is 2:2::2:2.
sftp client ipv6 source
sftp client source
display ssh client source
Use display ssh client source to display the source IP address configuration of the Stelnet client.
context-admin
context-operator
# Display the source IP address configuration of the Stelnet client.
<Sysname> display ssh client source
The source IP address of the SSH client is 192.168.0.1
The source IPv6 address of the SSH client is 2:2::2:2.
ssh client ipv6 source
ssh client source
exit
Use exit to terminate the SFTP connection and return to user view.
exit
SFTP client view
context-admin
context-operator
This command has the same function as the bye and quit commands.
# Terminate the SFTP connection.
sftp> exit
<Sysname>
get
Use get to download a file from the SFTP server and save it locally.
SFTP client view
context-admin
remote-file: Specifies the name of a file on the SFTP server.
local-file: Specifies the name for the local file. If you do not specify this argument, the file will be saved locally with the same name as the file on the SFTP server.
# Download file temp1.c and save it as temp.c locally.
sftp> get temp1.c temp.c
Fetching /temp1.c to temp.c
/temp.c                                                 100% 1424     1.4KB/s   00:00
help
Use help to display help information on the SFTP client.
help
SFTP client view
context-admin
This command has the same function as entering the question mark (?).
# Display help information on the SFTP client.
sftp> help
Available commands:
  bye                          Quit sftp
  cd [path]                    Change remote directory to 'path'
  cdup                         Change remote directory to the parent directory
  delete path                  Delete remote file
  dir [-a|-l][path]            Display remote directory listing
       -a                        List all filenames
       -l                        List filename including the specific
                                 information of the file
  exit                         Quit sftp
  get remote-path [local-path] Download file
  help                         Display this help text
  ls [-a|-l][path]             Display remote directory
  mkdir path                   Create remote directory
  put local-path [remote-path] Upload file
  pwd                          Display remote working directory
  quit                         Quit sftp
  rename oldpath newpath       Rename remote file
  remove path                  Delete remote file
  rmdir path                   Delete remote empty directory
  ?                            Synonym for help
ls
Use ls to display information about the files and subdirectories under a directory.
SFTP client view
context-admin
This command has the same function as the dir command.
sftp> ls -a
# Display detailed information about the files and subdirectories under the current working directory, excluding the files and subdirectories with names starting with dots (.).
sftp> ls -l
mkdir
Use mkdir to create a directory on the SFTP server.
mkdir remote-path
SFTP client view
context-admin
remote-path: Specifies the name of a directory.
# Create a directory named test on the SFTP server.
sftp> mkdir test
put
Use put to upload a local file to the SFTP server.
SFTP client view
context-admin
local-file: Specifies the name of a local file.
remote-file: Specifies the name of a file on an SFTP server. If you do not specify this argument, the file will be remotely saved with the same name as the local file.
# Upload the local file startup.bak to the SFTP server and save it as startup01.bak.
sftp> put startup.bak startup01.bak
Uploading startup.bak to /startup01.bak
startup01.bak                                   100% 1424     1.4KB/s   00:00
pwd
Use pwd to display the current working directory of the SFTP server.
pwd
SFTP client view
context-admin
# Display the current working directory of the SFTP server.
sftp> pwd
The output shows that the current working directory is the root directory.
Use quit to terminate the SFTP connection and return to user view.
SFTP client view
context-admin
This command has the same function as the bye and exit commands.
sftp> quit
<Sysname>
remove
Use remove to delete a file from the SFTP server.
remove remote-file
SFTP client view
context-admin
This command has the same function as the delete command.
sftp> remove temp.c
Removing /temp.c
rename
Use rename to change the name of a file or directory on the SFTP server.
rename old-name new-name
SFTP client view
context-admin
oldname: Specifies the name of an existing file or directory.
newname: Specifies a new name for the existing file or directory.
# Change the name of a file on the SFTP server from temp1.c to temp2.c.
sftp> dir
aa.pub  temp1.c
sftp> rename temp1.c temp2.c
sftp> dir
aa.pub  temp2.c
rmdir
Use rmdir to delete a directory from the SFTP server.
rmdir remote-path
SFTP client view
context-admin
remote-path: Specifies a directory.
# Delete subdirectory temp1 under the current directory on the SFTP server.
sftp> rmdir temp1
scp
Use scp to establish a connection to an IPv4 SCP server and transfer files with the server.
scp server [ port-number ] [ vpn-instance vpn-instance-name ] { get | put } source-file-name [ destination-file-name ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ip ip-address } ] *
context-admin
server: Specifies a server by its IPv4 address or host name, a case-insensitive string of 1 to 253 characters.
port-number: Specifies the port number of the server, in the range of 1 to 65535. The default is 22.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the server belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters.
get: Downloads the file.
put: Uploads the file.
source-file-name: Specifies the name of the source file, a case-sensitive string of 1 to 255 characters.
destination-file-name: Specifies the name of the target file, a case-sensitive string of 1 to 255 characters. If you do not specify this argument, the target file uses the same file name as the source file.
identity-key: Specifies a public key algorithm for publickey authentication of the client. The default is DSA. If the server uses publickey authentication, you must specify this keyword. The client generates the digital signature or certificate by using the local private key that is associated with the specified algorithm.
·     dsa: Specifies public key algorithm DSA.
·     ecdsa-sha2-nistp256: Specifies the ECDSA algorithm with 256-bit key strength.
·     ecdsa-sha2-nistp384: Specifies the ECDSA algorithm with 384-bit key strength.
·     rsa: Specifies public key algorithm RSA.
·     x509v3-ecdsa-sha2-nistp256: Specifies public key algorithm x509v3-ecdsa-sha2-nistp256.
·     x509v3-ecdsa-sha2-nistp384: Specifies public key algorithm x509v3-ecdsa-sha2-nistp384.
·     pki-domain domain-name: Specifies the PKI domain of the client's certificate. The domain-name argument is a case-insensitive string of 1 to 31 characters. When the x509v3 public key algorithm is used, you must specify this option for the client to get the correct local certificate.
prefer-compress: Specifies the preferred compression algorithm for data compression between the server and the client. By default, compression is not supported.
zlib: Specifies compression algorithm zlib.
prefer-ctos-cipher: Specifies the preferred client-to-server encryption algorithm. The default is AES128-CTR. Supported algorithms are DES-CBC, 3DES-CBC, AES128-CBC, AES128-CTR, AES128-GCM, AES192-CTR, AES256-CBC, AES256-CTR, and AES256-GCM, in ascending order of security strength and computation time.
·     3des-cbc: Specifies encryption algorithm 3DES-CBC.
·     aes128-cbc: Specifies encryption algorithm AES128-CBC.
·     aes128-ctr: Specifies encryption algorithm AES128-CTR.
·     aes128-gcm: Specifies encryption algorithm AES128-GCM.
·     aes192-ctr: Specifies encryption algorithm AES192-CTR.
·     aes256-cbc: Specifies encryption algorithm AES256-CBC.
·     aes256-ctr: Specifies encryption algorithm AES256-CTR.
·     aes256-gcm: Specifies encryption algorithm AES256-GCM.
·     des-cbc: Specifies encryption algorithm DES-CBC.
prefer-ctos-hmac: Specifies the preferred client-to-server HMAC algorithm. The default is SHA2-256. Supported algorithms are MD5, MD5-96, SHA1, SHA1-96, SHA2-256, and SHA2-512, in ascending order of security strength and computation time.
·     md5: Specifies HMAC algorithm HMAC-MD5.
·     md5-96: Specifies HMAC algorithm HMAC-MD5-96.
·     sha1: Specifies HMAC algorithm HMAC-SHA1.
·     sha1-96: Specifies HMAC algorithm HMAC-SHA1-96.
·     sha2-256: Specifies HMAC algorithm HMAC-SHA2-256.
·     sha2-512: Specifies HMAC algorithm HMAC-SHA2-512.
prefer-kex: Specifies the preferred key exchange algorithm. The default is ecdh-sha2-nistp256. Supported algorithms are diffie-hellman-group-exchange-sha1, diffie-hellman-group1-sha1, diffie-hellman-group14-sha1, ecdh-sha2-nistp256, and ecdh-sha2-nistp384, in ascending order of security strength and computation time.
·     dh-group-exchange-sha1: Specifies key exchange algorithm diffie-hellman-group-exchange-sha1.
·     dh-group1-sha1: Specifies key exchange algorithm diffie-hellman-group1-sha1.
·     dh-group14-sha1: Specifies key exchange algorithm diffie-hellman-group14-sha1.
·     ecdh-sha2-nistp256: Specifies key exchange algorithm ecdh-sha2-nistp256.
·     ecdh-sha2-nistp384: Specifies key exchange algorithm ecdh-sha2-nistp384.
prefer-stoc-cipher: Specifies the preferred server-to-client encryption algorithm. The default is AES128-CTR. Supported algorithms are the same as the client-to-server encryption algorithms (see the prefer-ctos-cipher keyword).
prefer-stoc-hmac: Specifies the preferred server-to-client HMAC algorithm. The default is SHA2-256. Supported algorithms are the same as the client-to-server HMAC algorithms (see the prefer-ctos-hmac keyword).
public-key keyname: Specifies the server's host public key that the client uses to authenticate the server. The keyname argument is a case-insensitive string of 1 to 64 characters.
server-pki-domain domain-name: Specifies the PKI domain for verifying the server's certificate. The domain-name argument represents the PKI domain name, a case-insensitive string of 1 to 31 characters. Invalid characters are tildes (~), asterisks (*), backslashes (\), vertical bars (|), colons (:), dots (.), angle brackets (< >), quotation marks ("), and apostrophes (').
source: Specifies a source IPv4 address or source interface for SCP packets. By default, the device uses the primary IPv4 address of the output interface in the routing entry as the source address of SCP packets. As a best practice to ensure successful SCP connections, specify a loopback interface as the source interface or specify the IPv4 address of a loopback or dialer interface as the source address.
·     interface interface-type interface-number: Specifies a source interface by its type and number. The IPv4 address of this interface is the source IPv4 address of the SCP packets.
·     ip ip-address: Specifies a source IPv4 address.
If the client uses certificate authentication, the client must verify the server's certificate. For the client to correctly get the server's certificate, use the server-pki-domain domain-name option to specify the server's PKI domain on the client. The client uses the CA certificate stored in the specified PKI domain to verify the server's certificate and does not need to save the server's public key before authentication. If you do not specify the server's PKI domain, the client uses the PKI domain of its own certificate to verify the server's certificate.
If the SCP server is an H3C device, you can specify the target file name with or without the file path by using the destination-file-name argument on the SCP client.
·     Specify the target file name without the file path—The SCP client will download the source file from the server to the current working directory of the SCP client or upload the source file to the current working directory of the server, and then rename the file as the target file name. For example, to download file remote.bin from the server to the current working directory of the client and rename it as local.bin, you can specify the destination-file-name argument as local.bin.
·     Specify the target file name with the file path—The SCP client will download the source file from the server to the specified file path of the SCP client or upload the source file to the specified file path of the server, and then rename the file as the target file name. For example, to download file remote.bin from the server to path flash:/logfile of the client and rename it as local.bin, you can specify the destination-file-name argument as flash:/logfile/local.bin or logfile/local.bin.
# Connect the SCP client to SCP server 200.1.1.1. Specify the public key of the server as svkey, and download file abc.txt from the server. The SCP client uses publickey authentication. Use the following algorithms:
·     Preferred key exchange algorithm: dh-group14-sha1.
·     Preferred server-to-client encryption algorithm: aes128-cbc.
·     Preferred client-to-server HMAC algorithm: sha1.
·     Preferred server-to-client HMAC algorithm: sha1-96.
·     Preferred compression algorithm: zlib.
<Sysname> scp 200.1.1.1 get abc.txt prefer-kex dh-group14-sha1 prefer-stoc-cipher aes128-cbc prefer-ctos-hmac sha1 prefer-stoc-hmac sha1-96 prefer-compress zlib public-key svkey
Username:
scp ipv6
Use scp ipv6 to establish a connection to an IPv6 SCP server and transfer files with the server.
scp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] { get | put } source-file-name [ destination-file-name ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
context-admin
server: Specifies a server by its IPv6 address or host name, a case-insensitive string of 1 to 253 characters.
-i interface-type interface-number: Specifies an output interface by its type and number for SCP packets. This option is used only when the server uses a link-local address to provide the SCP service for the client. The specified output interface on the SCP client must have a link-local address.
prefer-ctos-hmac: Specifies the preferred client-to-server HMAC algorithm. The default is SHA2-256. Supported algorithms are MD5, MD5-96, SHA1, SHA1-96, SHA2-256, and SHA2-512 in ascending order of security strength and computation time.
source: Specifies a source IPv6 address or source interface for IPv6 SCP packets. By default, the device automatically selects a source address for IPv6 SCP packets in compliance with RFC 3484. As a best practice to ensure successful SCP connections, specify a loopback interface as the source interface or specify the IPv6 address of a loopback or dialer interface as the source address.
·     interface interface-type interface-number: Specifies a source interface by its type and number. The IPv6 address of this interface is the source IPv6 address of the IPv6 SCP packets.
·     ipv6 ipv6-address: Specifies a source IPv6 address.
# Connect an SCP client to SCP server 2000::1. Specify the public key of the server as svkey, and download file abc.txt from the server. The SCP client uses publickey authentication. Use the following algorithms:
<Sysname> scp ipv6 2000::1 get abc.txt prefer-kex dh-group14-sha1 prefer-stoc-cipher aes128-cbc prefer-ctos-hmac sha1 prefer-stoc-hmac sha1-96 prefer-compress zlib public-key svkey
Username:
scp ipv6 suite-b
Use scp ipv6 suite-b to establish a connection to an IPv6 SCP server based on Suite B algorithms and transfer files with the server.
scp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] { get | put } source-file-name [ destination-file-name ] suite-b [ 128-bit | 192-bit ] pki-domain domain-name [ server-pki-domain domain-name ] [ prefer-compress zlib ] [ source { interface interface-type interface-number | ipv6 ipv6-address } ]
context-admin
-i interface-type interface-number: Specifies an output interface by its type and number for SCP packets. Specify this option when the server uses a link-local address to provide the SCP service for the client. The specified output interface on the SCP client must have a link-local address.
suite-b: Specifies the Suite B algorithms. If neither the 128-bit keyword nor the 192-bit keyword is specified, all algorithms in Suite B are used. For more information about the Suite B algorithms, see Table 4.
128-bit: Specifies the 128-bit Suite B security level.
192-bit: Specifies the 192-bit Suite B security level.
pki-domain domain-name: Specifies the PKI domain of the client's certificate. The domain-name argument represents the PKI domain name, a case-insensitive string of 1 to 31 characters. Invalid characters are tildes (~), asterisks (*), backslashes (\), vertical bars (|), colons (:), dots (.), angle brackets (< >), quotation marks ("), and apostrophes (').
server-pki-domain domain-name: Specifies the PKI domain for verifying the server's certificate. The domain-name argument represents the PKI domain name, a case-insensitive string of 1 to 31 characters. Invalid characters are tildes (~), asterisks (*), backslashes (\), vertical bars (|), colons (:), dots (.), angle brackets (< >), quotation marks ("), and apostrophes ('). If you do not specify the server's PKI domain, the client uses the PKI domain of its own certificate to verify the server's certificate.
Table 4 Suite B algorithms
Security level
Key exchange algorithm
Encryption algorithm and HMAC algorithm
Public key algorithm
128-bit
ecdh-sha2-nistp256
AES128-GCM
192-bit
ecdh-sha2-nistp384
AES256-GCM
Both
ecdh-sha2-nistp256
ecdh-sha2-nistp384
AES128-GCM
AES256-GCM
# Use the 192-bit Suite B algorithms to establish a connection to SCP server 2000::1 and download the file abc.txt from the server. Specify the client's PKI domain and the server's PKI domain as clientpkidomain and serverpkidomain, respectively.
<Sysname> scp ipv6 2000::1 get abc.txt suite-b 192-bit pki-domain clientpkidomain server-pki-domain serverpkidomain
Username:
scp suite-b
Use scp suite-b to establish a connection to an SCP server based on Suite B algorithms and transfer files with the server.
scp server [ port-number ] [ vpn-instance vpn-instance-name ] { get | put } source-file-name [ destination-file-name ] suite-b [ 128-bit | 192-bit ] pki-domain domain-name [ server-pki-domain domain-name ] [ prefer-compress zlib ] [ source { interface interface-type interface-number | ip ip-address } ]
context-admin
suite-b: Specifies the Suite B algorithms. If neither the 128-bit keyword nor the 192-bit keyword is specified, all algorithms in Suite B are used. For more information about the Suite B algorithms, see Table 5.
source: Specifies a source IP address or source interface for SCP packets. By default, the device uses the primary IPv4 address of the output interface in the routing entry as the source address of SCP packets. As a best practice to ensure successful SCP connections, specify a loopback interface as the source interface or specify the IPv4 address of a loopback or dialer interface as the source address.
Table 5 Suite B algorithms
Security level
128-bit
ecdh-sha2-nistp256
AES128-GCM
192-bit
ecdh-sha2-nistp384
AES256-GCM
Both
ecdh-sha2-nistp256
ecdh-sha2-nistp384
AES128-GCM
AES256-GCM
# Use the 128-bit Suite B algorithms to establish a connection to SCP server 200.1.1.1 and download the file abc.txt from the server. Specify the client's PKI domain and the server's PKI domain as clientpkidomain and serverpkidomain, respectively.
<Sysname> scp 200.1.1.1 get abc.txt suite-b 128-bit pki-domain clientpkidomain server-pki-domain serverpkidomain
Username
sftp
Use sftp to establish a connection to an IPv4 SFTP server and enter SFTP client view.
sftp server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ dscp dscp-value | { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ip ip-address } ] *
context-admin
dscp dscp-value: Specifies the DSCP value in the IPv4 SFTP packets. The value range for the dscp-value argument is 0 to 63, and the default value is 48. The DSCP value determines the transmission priority of the packet.
source: Specifies a source IPv4 address or source interface for the SFTP packets. By default, the device uses the primary IPv4 address of the output interface in the routing entry as the source address of SFTP packets. As a best practice to ensure successful SFTP connections, specify a loopback interface as the source interface or specify the IPv4 address of a loopback or dialer interface as the source address.
·     interface interface-type interface-number: Specifies a source interface by its type and number. The primary IPv4 address of this interface is the source IPv4 address of the SFTP packets.
# Connect an SFTP client to SFTP server 10.1.1.2 and specify the public key of the server as svkey. The SFTP client uses publickey authentication. Use the following algorithms:
<Sysname> sftp 10.1.1.2 prefer-kex dh-group14-sha1 prefer-stoc-cipher aes128-cbc prefer-ctos-hmac sha1 prefer-stoc-hmac sha1-96 prefer-compress zlib public-key svkey
Use sftp client ipv6 source to configure the source IPv6 address for SFTP packets that are sent by the SFTP client.
Use undo sftp client ipv6 source to restore the default.
sftp client ipv6 source { interface interface-type interface-number | ipv6 ipv6-address }
The source IPv6 address for outgoing SFTP packets is not configured. The SFTP client automatically selects an IPv6 address for outgoing SFTP packets in compliance with RFC 3484.
context-admin
interface interface-type interface-number: Specifies a source interface by its type and number. The SFTP client selects the interface's address that most specifically matches the destination address of outgoing SFTP packets as the source address of the SFTP packets.
This command takes effect on all IPv6 SFTP connections. The source IPv6 address specified in the sftp ipv6 command takes effect only on the current IPv6 SFTP connection. If you specify the source IPv6 address both in this command and the sftp ipv6 command, the source IPv6 address specified in the sftp ipv6 command takes effect.
# Specify 2:2::2:2 as the source IPv6 address for SFTP packets.
[Sysname] sftp client ipv6 source ipv6 2:2::2:2
sftp client source
Use sftp client source to configure the source IPv4 address for SFTP packets that are sent by the SFTP client.
Use undo sftp client source to restore the default.
sftp client source { interface interface-type interface-number | ip ip-address }
The source IPv4 address for outgoing SFTP packets is not configured. The SFTP client uses the primary IPv4 address of the output interface in the matching route as the source IPv4 address of outgoing SFTP packets.
context-admin
interface interface-type interface-number: Specifies a source interface by its type and number. The SFTP client uses the primary IPv4 address of the interface as the source address of outgoing SFTP packets.
This command takes effect on all SFTP connections. The source IPv4 address specified in the sftp command takes effect only on the current SFTP connection. If you specify the source IPv4 address both in this command and the sftp command, the source IPv4 address specified in the sftp command takes effect.
# Specify 192.168.0.1 as the source IPv4 address for SFTP packets.
[Sysname] sftp client source ip 192.168.0.1
sftp ipv6
Use sftp ipv6 to connect an SFTP client to an IPv6 SFTP server and enter SFTP client view.
sftp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ dscp dscp-value | { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
context-admin
-i interface-type interface-number: Specifies an output interface by its type and number for IPv6 SFTP packets. This option is used only when the server uses a link-local address to provide the SFTP service for the client. The specified output interface on the SFTP client must have a link-local address.
dscp dscp-value: Specifies the DSCP value in the IPv6 SFTP packets. The value range for the dscp-value argument is 0 to 63, and the default value is 48. The DSCP value determines the transmission priority of the packet.
public-key keyname: Specifies the host public key of the server that the client uses to authenticate the server. The keyname argument is a case-insensitive string of 1 to 64 characters.
source: Specifies a source IPv6 address or source interface for IPv6 SFTP packets. By default, the device automatically selects a source address for IPv6 SFTP packets in compliance with RFC 3484. As a best practice to ensure successful SFTP connections, specify a loopback interface as the source interface or specify the IPv6 address of a loopback or dialer interface as the source address.
·     interface interface-type interface-number: Specifies a source interface by its type and number. The IPv6 address of this interface is the source IPv6 address of the IPv6 SFTP packets.
# Connect an SFTP client to SFTP server 2000::1 and specify the public key of the server as svkey. The SFTP client uses publickey authentication. Use the following algorithms:
<Sysname> sftp ipv6 2000::1 prefer-kex dh-group14-sha1 prefer-stoc-cipher aes128-cbc prefer-ctos-hmac sha1 prefer-stoc-hmac sha1-96 prefer-compress zlib public-key svkey
Username:
sftp ipv6 suite-b
Use sftp ipv6 suite-b to establish a connection to an IPv6 SFTP server based on Suite B algorithms and enter SFTP client view.
sftp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] suite-b [ 128-bit | 192-bit ] pki-domain domain-name [ server-pki-domain domain-name ] [ prefer-compress zlib ] [ dscp dscp-value | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
context-admin
-i interface-type interface-number: Specifies an output interface by its type and number for IPv6 SFTP packets. The specified outgoing interface must have a link-local address. This option is used only when the server uses a link-local address to provide the SFTP service for the client.
suite-b: Specifies the Suite B algorithms. If neither the 128-bit keyword nor the 192-bit keyword is specified, all algorithms in Suite B are used. For more information about the Suite B algorithms, see Table 6.
source: Specifies a source IP address or source interface for IPv6 SFTP packets. By default, the device automatically selects a source address for IPv6 SFTP packets in compliance with RFC 3484. As a best practice to ensure successful SFTP connections, specify a loopback interface as the source interface or specify the IPv6 address of a loopback or dialer interface as the source address.
·     interface interface-type interface-number: Specifies a source interface by its type and number. The IPv6 address of this interface is the source IP address of the IPv6 SFTP packets.
Table 6 Suite B algorithms
Security level
128-bit
ecdh-sha2-nistp256
AES128-GCM
192-bit
ecdh-sha2-nistp384
AES256-GCM
Both
ecdh-sha2-nistp256
ecdh-sha2-nistp384
AES128-GCM
AES256-GCM
# Use the 192-bit Suite B algorithms to establish a connection to SFTP server 2000::1. Specify the client's PKI domain and the server's PKI domain as clientpkidomain and serverpkidomain, respectively.
<Sysname> sftp ipv6 2000::1 suite-b 192-bit pki-domain clientpkidomain server-pki-domain serverpkidomain
Username:
sftp suite-b
Use sftp suite-b to establish a connection to an IPv4 SFTP server based on Suite B algorithms and enter SFTP client view.
sftp server [ port-number ] [ vpn-instance vpn-instance-name ] suite-b [ 128-bit | 192-bit ] pki-domain domain-name [ server-pki-domain domain-name ] [ prefer-compress zlib ] [ dscp dscp-value | source { interface interface-type interface-number | ip ip-address } ] *
context-admin
suite-b: Specifies the Suite B algorithms. If neither the 128-bit keyword nor the 192-bit keyword is specified, all algorithms in Suite B are used. For more information about the Suite B algorithms, see Table 7.
source: Specifies a source IP address or source interface for the SFTP packets. By default, the device uses the primary IPv4 address of the output interface in the routing entry as the source address of SFTP packets. As a best practice to ensure successful SFTP connections, specify a loopback interface as the source interface or specify the IPv4 address of a loopback or dialer interface as the source address.
Table 7 Suite B algorithms
Security level
128-bit
ecdh-sha2-nistp256
AES128-GCM
192-bit
ecdh-sha2-nistp384
AES256-GCM
Both
ecdh-sha2-nistp256
ecdh-sha2-nistp384
AES128-GCM
AES256-GCM
# Use the 128-bit Suite B algorithms to establish a connection to SFTP server 10.1.1.2. Specify the client's PKI domain and the server's PKI domain as clientpkidomain and serverpkidomain, respectively.
<Sysname> sftp 10.1.1.2 suite-b 128-bit pki-domain clientpkidomain server-pki-domain serverpkidomain
Username
Use ssh client ipv6 source to configure the source IPv6 address for SSH packets that are sent by the Stelnet client.
Use undo ssh client ipv6 source to restore the default.
The source IPv6 address for outgoing SSH packets is not configured. The Stelnet client automatically selects an IPv6 address for outgoing SSH packets in compliance with RFC 3484.
context-admin
interface interface-type interface-number: Specifies a source interface by its type and number. The Stelnet client selects the interface's address that most specifically matches the destination address of outgoing SSH packets as the source address of the SSH packets.
This command takes effect on all IPv6 Stelnet connections. The source IPv6 address specified in the ssh2 ipv6 command takes effect only on the current IPv6 Stelnet connection. If you specify the source IPv6 address both in this command and the ssh2 ipv6 command, the source IPv6 address specified in the ssh2 ipv6 command takes effect.
# Specify 2:2::2:2 as the source IPv6 address for SSH packets that are sent by the Stelnet client.
[Sysname] ssh client ipv6 source ipv6 2:2::2:2
ssh client source
Use ssh client source to configure the source IPv4 address for SSH packets that are sent by the Stelnet client.
Use undo ssh client source to restore the default.
The source IPv4 address for outgoing SSH packets is not configured. The Stelnet client uses the primary IPv4 address of the output interface in the matching route as the source address of outgoing SSH packets.
context-admin
interface interface-type interface-number: Specifies a source interface by its type and number. The Stelnet client uses the primary IPv4 address of the interface as the source address of outgoing SSH packets.
This command takes effect on all Stelnet connections. The source IPv4 address specified in the ssh2 command takes effect only on the current Stelnet connection. If you specify the source IPv4 address both in this command and the ssh2 command, the source IPv4 address specified in the ssh2 command takes effect.
# Specify 192.168.0.1 as the source IPv4 address for SSH packets.
[Sysname] ssh client source ip 192.168.0.1
ssh2
Use ssh2 to establish a connection to an IPv4 Stelnet server.
ssh2 server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ dscp dscp-value | escape character | { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ip ip-address } ] *
context-admin
port-number: Specifies the port number of the server, in the range 1 to 65535. The default is 22.
dscp dscp-value: Specifies the DSCP value in the IPv4 SSH packets. The value range for the dscp-value argument is 0 to 63, and the default value is 48. The DSCP value determines the transmission priority of the packet.
escape character: Specifies a case-sensitive escape character. By default, the escape character is a tilde (~).
source: Specifies a source IPv4 address or source interface for SSH packets. By default, the device uses the primary IPv4 address of the output interface in the routing entry as the source address of SSH packets. As a best practice to ensure successful Stelnet connections, specify a loopback interface as the source interface or specify the IPv4 address of a loopback or dialer interface as the source address.
·     interface interface-type interface-number: Specifies a source interface by its type and number. The primary IPv4 address of this interface is the source IPv4 address of the SSH packets.
The combination of an escape character and a dot (.) works as an escape sequence. This escape sequence is typically used to quickly terminate an SSH connection when the server reboots or malfunctions.
For the escape sequence to take effect, you must enter it at the very beginning of a line. If you have entered other characters or performed operations in a line, enter the escape sequence in the next line.
As a best practice, use the default escape character (~). Do not use any character in SSH usernames as the escape character.
# Establish a connection to Stelnet server 3.3.3.3 and specify the public key of the server as svkey. The Stelnet client uses publickey authentication. Specify the dollar sign ($) as the escape character. Use the following algorithms:
<Sysname> ssh2 3.3.3.3 prefer-kex dh-group14-sha1 prefer-stoc-cipher aes128-cbc prefer-ctos-hmac sha1 prefer-stoc-hmac sha1-96 prefer-compress zlib public-key svkey escape $
ssh2 ipv6
Use ssh2 ipv6 to establish a connection to an IPv6 Stelnet server.
ssh2 ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } ] * [ dscp dscp-value | escape character | { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
context-admin
-i interface-type interface-number: Specifies an output interface by its type and number for IPv6 SSH packets. This option is used only when the server uses a link-local address to provide the Stelnet service for the client. The specified output interface on the Stelnet client must have a link-local address.
dscp dscp-value: Specifies the DSCP value in the IPv6 SSH packets. The value range for the dscp-value argument is 0 to 63, and the default value is 48. The DSCP value determines the transmission priority of the packet.
public-key keyname: Specifies the server by its host public key that the client uses to authenticate the server. The keyname argument is a case-insensitive string of 1 to 64 characters.
source: Specifies a source IPv6 address or source interface for IPv6 SSH packets. By default, the device automatically selects a source address for IPv6 SSH packets in compliance with RFC 3484. As a best practice to ensure successful Stelnet connections, specify a loopback interface as the source interface or specify the IPv6 address of a loopback or dialer interface as the source address.
·     interface interface-type interface-number: Specifies a source interface by its type and number. The IPv6 address of this interface is the source IPv6 address of the IPv6 SSH packets.
As a best practice, use the default escape character (~). Do not use any characters in SSH usernames as the escape character.
# Establish a connection to Stelnet server 2000::1 and specify the public key of the server as svkey. The SSH client uses publickey authentication. Specify the dollar sign ($) as the escape character. Use the following algorithms:
<Sysname> ssh2 ipv6 2000::1 prefer-kex dh-group14-sha1 prefer-stoc-cipher aes128-cbc prefer-ctos-hmac sha1 prefer-stoc-hmac sha1-96 prefer-compress zlib public-key svkey escape $
ssh2 ipv6 suite-b
Use ssh2 ipv6 suite-b to establish a connection to an IPv6 Stelnet server based on Suite B algorithms.
ssh2 ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] suite-b [ 128-bit | 192-bit ] pki-domain domain-name [ server-pki-domain domain-name ] [ prefer-compress zlib ] [ dscp dscp-value | escape character | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
context-admin
-i interface-type interface-number: Specifies an output interface by its type and number for IPv6 SSH packets. Specify this option when the server uses a link-local address to provide the Stelnet service for the client. The specified output interface on the Stelnet client must have a link-local address.
suite-b: Specifies the Suite B algorithms. If neither the 128-bit keyword nor the 192-bit keyword is specified, all algorithms in Suite B are used. For more information about the Suite B algorithms, see Table 8.
source: Specifies a source IP address or source interface for IPv6 SSH packets. By default, the device automatically selects a source address for IPv6 SSH packets in compliance with RFC 3484. As a best practice to ensure successful Stelnet connections, specify a loopback interface as the source interface or specify the IPv6 address of a loopback or dialer interface as the source address.
·     interface interface-type interface-number: Specifies a source interface by its type and number. The IPv6 address of this interface is the source IP address of the IPv6 SSH packets.
Table 8 Suite B algorithms
Security level
128-bit
ecdh-sha2-nistp256
AES128-GCM
192-bit
ecdh-sha2-nistp384
AES256-GCM
Both
ecdh-sha2-nistp256
ecdh-sha2-nistp384
AES128-GCM
AES256-GCM
For the escape sequence to take effect, you must enter it at the very beginning of a line. If you have entered other characters or performed operations in a line, enter the escape sequence in the next line. As a best practice, use the default escape character (~). Do not use any character in SSH usernames as the escape character.
# Use the 192-bit Suite B algorithms to establish a connection to Stelnet server 2000::1. Specify the client's PKI domain and the server's PKI domain as clientpkidomain and serverpkidomain, respectively.
<Sysname> ssh2 ipv6 2000::1 suite-b 192-bit pki-domain clientpkidomain server-pki-domain serverpkidomain
Username
ssh2 suite-b
Use ssh2 suite-b to establish a connection to an IPv4 Stelnet server based on Suite B algorithms.
ssh2 server [ port-number ] [ vpn-instance vpn-instance-name ] suite-b [ 128-bit | 192-bit ] pki-domain domain-name [ server-pki-domain domain-name ] [ prefer-compress zlib ] [ dscp dscp-value | escape character | source { interface interface-type interface-number | ip ip-address } ] *
context-admin
suite-b: Specifies the Suite B algorithms. If neither the 128-bit keyword nor the 192-bit keyword is specified, all algorithms in Suite B are used. For more information about the Suite B algorithms, see Table 9.
source: Specifies a source IP address or source interface for SSH packets. By default, the device uses the primary IPv4 address of the output interface in the routing entry as the source address of SSH packets. As a best practice to ensure successful Stelnet connections, specify a loopback interface as the source interface or specify the IPv4 address of a loopback or dialer interface as the source address.
Table 9 Suite B algorithms
Security level
128-bit
ecdh-sha2-nistp256
AES128-GCM
192-bit
ecdh-sha2-nistp384
AES256-GCM
Both
ecdh-sha2-nistp256
ecdh-sha2-nistp384
AES128-GCM
AES256-GCM
# Use the 128-bit Suite B algorithms to establish a connection to Stelnet server 3.3.3.3. Specify the client's PKI domain and the server's PKI domain as clientpkidomain and serverpkidomain, respectively.
<Sysname> ssh2 3.3.3.3 suite-b 128-bit pki-domain clientpkidomain server-pki-domain serverpkidomain
Username
SSH2 commands
display ssh2 algorithm
Use display ssh2 algorithm to display algorithms used by SSH2 in the algorithm negotiation stage.
context-admin
context-operator
# Display algorithms used by SSH2 in the algorithm negotiation stage.
<Sysname> display ssh2 algorithm
 Key exchange algorithms: ecdh-sha2-nistp256 ecdh-sha2-nistp384 dh-group-exchange-sha1 dh-group14-sha1 dh-group1-sha1
 Public key algorithms: x509v3-ecdsa-sha2-nistp256 x509v3-ecdsa-sha2-nistp384 ecdsa-sha2-nistp256 ecdsa-sha2-nistp384 rsa dsa
 Encryption algorithms: aes128-ctr aes192-ctr aes256-ctr aes128-gcm aes256-gcm aes128-cbc 3des-cbc aes256-cbc des-cbc
 MAC algorithms: sha2-256 sha2-512 sha1 md5 sha1-96 md5-96
Table 10 Command output
Key exchange algorithms in descending order of priority for algorithm negotiation.
Public key algorithms in descending order of priority for algorithm negotiation.
Encryption algorithms in descending order of priority for algorithm negotiation.
MAC algorithms
HMAC algorithms in descending order of priority for algorithm negotiation.
ssh2 algorithm cipher
ssh2 algorithm key-exchange
ssh2 algorithm mac
ssh2 algorithm public-key
Use ssh2 algorithm cipher to specify encryption algorithms for SSH2.
Use undo ssh2 algorithm cipher to restore the default.
ssh2 algorithm cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } *
SSH2 uses encryption algorithms AES128-CTR, AES192-CTR, AES256-CTR, AES128-GCM, AES256-GCM, AES128-CBC, 3DES-CBC, AES256-CBC, and DES-CBC in descending order of priority for algorithm negotiation.
context-admin
If you specify the encryption algorithms, SSH2 uses only the specified algorithms for algorithm negotiation. The algorithm specified earlier has a higher priority during negotiation.
# Specify algorithm aes256-cbc as the encryption algorithm for SSH2.
[Sysname] ssh2 algorithm cipher aes256-cbc
ssh2 algorithm mac
Use ssh2 algorithm key-exchange to specify key exchange algorithms for SSH2.
Use undo ssh2 algorithm key-exchange to restore the default.
ssh2 algorithm key-exchange { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } *
SSH2 uses key exchange algorithms ecdh-sha2-nistp256, ecdh-sha2-nistp384, diffie-hellman-group-exchange-sha1, diffie-hellman-group14-sha1, and diffie-hellman-group1-sha1 in descending order of priority for algorithm negotiation.
context-admin
If you specify the key exchange algorithms, SSH2 uses only the specified algorithms for algorithm negotiation. The algorithm specified earlier has a higher priority during negotiation.
# Specify algorithm dh-group1-sha1 as the key exchange algorithm for SSH2.
[Sysname] ssh2 algorithm key-exchange dh-group1-sha1
ssh2 algorithm mac
ssh2 algorithm mac
Use ssh2 algorithm mac to specify HMAC algorithms for SSH2.
Use undo ssh2 algorithm mac to restore the default.
ssh2 algorithm mac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 } *
SSH2 uses HMAC algorithms SHA2-256, SHA2-512, SHA1, MD5, SHA1-96, and MD5-96 in descending order of priority for algorithm negotiation.
context-admin
If you specify the HMAC algorithms, SSH2 uses only the specified algorithms for algorithm negotiation. The algorithm specified earlier has a higher priority during negotiation.
# Specify algorithm md5 as the HMAC algorithm for SSH2.
[Sysname] ssh2 algorithm mac md5
Use ssh2 algorithm public-key to specify public key algorithms for SSH2.
Use undo ssh2 algorithm public-key to restore the default.
ssh2 algorithm public-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } *
SSH2 uses public key algorithms x509v3-ecdsa-sha2-nistp256, x509v3-ecdsa-sha2-nistp384, ecdsa-sha2-nistp256, ecdsa-sha2-nistp384, RSA, and DSA in descending order of priority for algorithm negotiation.
context-admin
If you specify the public key algorithms, SSH2 uses only the specified algorithms for algorithm negotiation. The algorithm specified earlier has a higher priority during negotiation.
# Specify algorithm dsa as the public key algorithm for SSH2.
[Sysname] ssh2 algorithm public-key dsa
ssh2 algorithm mac
