- 03-Security Command Reference
- 01-Security zone commands
- 02-Security policy commands
- 03-ASPF commands
- 04-Session management commands
- 05-Object group commands
- 06-IP source guard commands
- 07-AAA commands
- 08-User identification commands
- 09-Password control commands
- 10-Portal commands
- 11-MAC authentication commands
- 12-SMS commands
- 13-802.1X commands
- 14-Public key management commands
- 15-PKI commands
- 16-SSH commands
- 17-SSL commands
- 18-Connection limit commands
- 19-Attack detection and prevention commands
- 20-Deception commands
- 21-Server connection detection commands
- 22-ARP attack protection commands
- 23-ND attack defense commands
- 24-uRPF commands
- 25-IP-MAC binding commands
- 26-Keychain commands
- 27-MAC learning through a Layer 3 device commands
- 28-APR commands
- 29-IPoE commands
- 30-Crypto engine commands
- 31-Location identification commands
- 32-Terminal identification commands
| 20-Deception commands | 128.12 KB |
Deception commands
The following compatibility matrix shows the support of hardware platforms for the deception feature:
Series |
Models |
Deception compatibility |
F5000 series |
F5000-AI360, F5000-AI160, F5000-AI120, F5000-AI-40, F5000-AI-20, F5000-AI-15, F5000-CN-G85, F5000-CN-G65, F5000-CN60, F5000-CN-G55, F5000-CN30 |
Yes |
F5000-CN160 |
No |
F1000 series |
F1000-AI-90, F1000-AI-80, F1000-AI-75, F1000-AI-70, F1000-AI-65, F1000-AI-60, F1000-AI-25, F1000-CN-G35 |
Yes |
allowlist
Use allowlist to configure a deception allowlist entry.
Use undo allowlist to delete a deception allowlist entry.
allowlist [ id id-number ] { destination | source } ip-address [ mask | mask-length ] [ vpn-instance vpn-instance-name ]
undo allowlist [ id id-number ]
Deception allowlist entries do not exist.
Deception view
context-admin
id id-number: Specifies a deception allowlist entry ID in the value range of 1 to 50. If you do not specify an ID, the device automatically assigns an ID for the entry.
destination: Configure a destination address allowlist entry.
source: Configure a source address allowlist entry.
ip-address: IP address in the allowlist entry.
mask: Mask for the IP address.
mask-length: Mask length for the IP address, in the range of 1 to 32.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the deception allowlist entry belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the allowlisted IP address is on the public network, do not specify this option.
The deception allowlist specifies the deception exceptions. It can contain source address allowlist entries and destination address allowlist entries.
· For the IP addresses in the destination address allowlist entries, the device will not decoy the traffic accessing these IP addresses.
· For the IP addresses in the source address allowlist entries, the device will not decoy the traffic initiated by these IP addresses.
For devices that do not respond to ARP requests (some legacy printers for example), you can add their IP addresses to the destination address allowlist to prevent normal access traffic from being decoyed.
For devices that will periodically send probe packets (some NMS devices for example), you can add their IP addresses to the source address allowlist to prevent their traffic from being decoyed as intrusion traffic.
The deception allowlist cannot contain IP address 0.0.0.0 or 255.255.255.255.
If you do not specify an ID in the undo allowlist command, the device will delete all deception allowlist entries.
# Configure a deception allowlist entry: set the entry ID to 1 and destination address as 1.1.1.1.
[Sysname] deception
[Sysname-deception] allowlist id 1 destination 1.1.1.1
deception enable
arp-scan threshold
Use arp-scan threshold to set the ARP request sending rate that triggers deception, hereinafter referred to as the deception threshold.
Use undo arp-scan threshold to restore the default.
arp-scan threshold threshold-value
By default, the deception threshold is 10 ARP requests per 10 seconds.
Deception view
context-admin
threshold-value: Specifies the deception threshold, in the range of 1 to 20000. This value represents the number of ARP requests sent per 10 seconds.
After deception is enabled (by using the deception enable command) and strict deception mode is used, the device enters deception state when it detects that the following conditions are met:
· The ARP request sending rate to a detection network (configured by using the detect-network command) reaches the deception threshold.
· A scanned IP address in a detection network is in offline state.
If you execute the arp-scan threshold command multiple times, the most recent configuration takes effect.
# Configure the ARP request sending rate that triggers deception as 500 ARP requests per 10 seconds.
[Sysname] deception
[Sysname-deception] arp-scan threshold 500
deception enable
decoy
detect-network
deception
Use deception to enter deception view.
Use undo deception to delete all deception configuration.
deception
undo deception
Enter system view.
context-admin
Enter deception view to configure deception settings.
Executing the undo deception command deletes all deception settings. Use caution when you perform this operation.
# Enter deception view.
[Sysname] deception
[Sysname-deception]
deception enable
Use deception enable to enable the deception feature.
Use undo deception enable to disable the deception feature.
deception enable
The deception feature is disabled.
Deception view
context-admin
After attackers intrude into an internal network, typically they will perform multiple scans to obtain the internal IP address status. Deception technology detects scanning behaviors on the intranet to find out intrusion threats. Besides, it forges the responses of the victims to entice the attackers into deep interactions with the decoy server. In this way, it can misdirect the attackers from their true targets, analyze and traceback the attacks, so as to protect the intranet security.
After deception is enabled, the device lures suspicious traffic to the decoy server for in-depth analysis. Incorrect deception settings might misdirect normal network traffic to the decoy server. Before enabling deception, use the display this command in deception view to verify the deception settings.
# Enable deception.
[Sysname] deception
[Sysname-deception] deception enable
arp-scan threshold
deception mode strict
decoy
decoy-network
ip-state detect rate
allowlist
Use deception mode strict to enable the strict deception mode.
Use undo deception mode to restore the default.
undo deception mode
The strict deception mode is disabled. The non-strict mode is used for deception.
Deception view
context-admin
Use the strict deception mode on a network where devices use static ARP entries instead of sending ARP requests. In strict mode, when the device detects an ARP request for an offline IP address on a detection network (see the detect-network command), it immediately lures the attacker's subsequent traffic destined for the IP address to the decoy server.
Use the non-strict deception mode on networks where ARP entries can be aged. In non-strict mode, the device periodically detects the rate of ARP requests sent to a detection network. When the rate reaches the deception threshold, the subsequent traffic sent from the attackers to the offline IP addresses in the detection network will be lured to the decoy server for further analysis.
# Enable the strict mode for deception.
[Sysname] deception
[Sysname-deception] deception mode strict
decoy
Use decoy to configure the IP address of the decoy server.
Use undo decoy to restore the default.
decoy destination destination-ip [ source source-ip ] [ dest-port destination-port ] [ vpn-instance vpn-instance-name ]
undo decoy
No decoy server IP address is configured.
Deception view
context-admin
destination destination-ip: Specifies the IP address of the decoy server.
source source-ip: Specifies the source IP address used by the device to connect to the decoy server. If you do not specify this option, the device randomly uses the IP address of an up interface as the source IP address. Do not configure this option in an RBM network.
dest-port destination-port: Specifies the service port number of the decoy server. The value range is 1 to 65535, and the default value is 5555.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the decoy server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the decoy server is on the public network, do not specify this option.
A decoy server is a threat perception and traceability system, which can decoy attackers to interact with it deeply in the well-constructed simulation environment, analyze and trace the attack behaviors, and protect the real network from attacks.
After deception is enabled (see the deception enable command), the device acts as the proxy of the decoy server to interact the attacker. It lures the attack traffic to the decoy server for analysis, and forwards the response traffic from the decoy server to the attacker.
The value for the destination-ip or source-ip argument cannot be 0.0.0.0 or 255.255.255.255.
If you execute the decoy command multiple times, the most recent configuration takes effect.
# Configure the IP address of the decoy server as 1.1.1.2, and the source IP address used by the device to connect to the decoy server as 1.1.1.1.
[Sysname] deception
[Sysname-deception] decoy destination 1.1.1.2 source 1.1.1.1
· deception enable
decoy-network
Use decoy-network to configure a decoy network.
Use undo decoy-network to delete decoy networks.
decoy-network [ id id-number ] destination ip-address [ mask | mask-length ] [ vpn-instance vpn-instance-name ]
undo decoy-network [ id id-number ]
No decoy networks exist.
Deception view
context-admin
id id-number: Specifies a decoy network ID in the value range of 1 to 50. If you do not specify an ID, the device automatically assigns an ID for the decoy network.
destination ip-address: Specifies the decoy network address.
mask: Specifies the mask of the decoy network.
mask-length: Specifies the mask length for the decoy network, in the range of 1 to 32.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the decoy network belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the decoy network belongs to the public network.
Decoy networks are used for static deception. When the device detects that an attacker initiates scanning or any form of access to an IP address in a decoy network, no matter whether the IP address is online or not, the device will immediately enter the deception state and lure the attacker's subsequent traffic to the decoy server for in-depth analysis.
If a decoy network overlaps with the addresses in the deception allowlist (see the allowlist command), the device will treat the overlapping IP addresses as allowlisted IP addresses. If a decoy network overlaps with a detection network, the device will treat the overlapping IP addresses as the IP addresses in the decoy network.
A decoy network cannot contain IP address 0.0.0.0 or 255.255.255.255.
If you do not specify an ID in the undo decoy-network command, the device will delete all decoy networks.
# Configure decoy network 1 as 1.1.1.0/24.
[Sysname] deception
[Sysname-deception] decoy-network id 1 destination 1.1.1.0 24
· deception enable
· allowlist
detect-network
Use detect-network to configure a detection network.
Use undo detect-network to delete detection networks.
detect-network [ id id-number ] ip-address [ mask | mask-length ] [ vpn-instance vpn-instance-name ]
undo detect-network [ id id-number ]
No detection networks exist.
Deception view
context-admin
id id-number: Specifies a detection network ID in the value range of 1 to 50. If you do not specify an ID, the device automatically assigns an ID for the detection network.
ip-address: Specifies the detection network address.
mask: Specifies the mask of the detection network.
mask-length: Specifies the mask length for the detection network, in the range of 1 to 32.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the detection network belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the allowlisted IP address is on the public network, do not specify this option.
Detection networks are used for offline IP deception. Make sure the device can reach the detection networks.
If detection networks are configured and deception is enabled, the device constantly monitors the ARP requests sent to the detection networks. The device processes deception differently in different deception modes.
· In strict mode, when the device detects an ARP request for an offline IP address on a detection network, it immediately lures the attacker's subsequent traffic destined for the IP address to the decoy server for in-depth analysis.
· In non-strict mode, the device periodically detects the rate of the ARP requests sent by attackers to the detection networks. When the rate reaches the deception threshold and the scanned IP address is offline, the subsequent traffic sent from the attackers to the offline IP address will be lured to the decoy server for further analysis.
If a detection network overlaps with a decoy network, the device will treat the overlapping IP addresses as the IP addresses in the decoy network. If a detection network overlaps with the addresses in the deception allowlist, the device will treat the overlapping IP addresses as allowlisted IP addresses.
The total number of IP addresses in all detection networks cannot exceed 10240.
A detection network cannot contain IP address 0.0.0.0 or 255.255.255.255.
If you do not specify an ID in the undo detect-network command, the device will delete all detection networks.
# Configure detection network 1 as 1.1.1.0/24.
[Sysname] deception
[Sysname-deception] detect-network id 1 1.1.1.0 24
arp-scan threshold
deception enable
decoy-network
allowlist
display deception arp-scan statistics
Use display deception arp-scan statistics to display ARP scanning statistics.
display deception arp-scan [ source ip-address ] statistics [ slot slot-number ]
context-admin
context-operator
source ip-address: Specifies the IP address that initiates the ARP scanning.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays ARP scanning statistics on all member devices.
# Display ARP scanning statistics.
<Sysname> display deception arp-scan statistics
Slot 1:
Source IP Rate(packets/10s) Count VPN instance
1.1.1.1 300 2310 --
1.1.1.2 100 2800 --
Total IPs: 2
Slot 2:
1.1.1.1 300 2310 --
1.1.1.2 100 2800 --
Total IPs: 2
Source IP |
IP address that initiates ARP scanning. |
Rate(num/10s) |
ARP scanning rate, which represents the number of ARP requests sent per 10 seconds. |
Count |
Total number of ARP requests sent for scanning. |
VPN instance |
VPN instance to which the scanning source IP address belongs. If the address belongs to the public network, this field displays two hyphens (--). |
Total IPs |
Number of IP addresses that initiate ARP scanning. |
arp-scan threshold
display deception decoy status
Use display deception decoy status to display the decoy server status.
context-admin
context-operator
The registration status of the device on the decoy server can be init or alive.
· init—The device has not registered to the decoy server.
· alive—The device has registered to the decoy server successfully.
The device connects to the decoy server every 5 minutes and updates the port list. If it fails consecutively twice to connect to the decoy server, it changes the decoy server status from alive to init. When the connection succeeds again, the device sets the decoy server status back to alive. The device drops the decoyed traffic if the decoy server status is init. The normal deception process resumes when the decoy server status becomes alive.
# Display the decoy server status.
<Sysname> display deception decoy status
Decoy register status information:
Register status : alive
Online duration : 25510(s)
Available decoy service ports:
21 22 80 443 3306
4855 15554
Decoy register status information |
Decoy server status information. |
Register status |
Registration status of the device on the decoy server. · init—Unregistered. · alive—Registered. |
Online duration |
Period of time that the device has connected to the decoy server. |
Available decoy service ports |
Destination port numbers that support deception. |
deception enable
decoy
display deception ip-state
Use display deception ip-state to display the online status of the IP addresses in detection networks.
display deception ip-state [ ip-address ] [ slot slot-number ]
context-admin
context-operator
ip-address: Specifies an IP address. If you do not specify an IP address, this command displays the online status of all IP addresses in detection networks.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IP status information on all member devices.
After deception is enabled, the deception device initiates IP address scanning on the detection networks at intervals of 30 minutes to obtain the IP address online status. You can execute this command to display the real-time online status of the IP addresses in detection networks.
For the decoy IP addresses (packets destined for the IP addresses will be lured to the decoy server), the IP scanning interval can be decreased to 10 seconds, depending on the decoy IP addresses quantity, to improve the scanning efficiency.
# Display the online status of the IP addresses in detection networks.
<Sysname> display deception ip-state
Slot 1:
IP address State VPN instance
1.1.1.1 Online --
1.1.1.2 Offline --
1.1.1.3 Offline --
1.1.1.255 Online --
Total IPs: 4
Slot 2:
1.1.1.1 Online --
1.1.1.2 Offline --
1.1.1.3 Offline --
1.1.1.255 Online --
Total IPs: 4
State |
IP address status: · Online · Offline |
VPN instance |
VPN instance to which the IP address belongs. If the address belongs to the public network, this field displays two hyphens (--). |
Total IPs |
Total number of IP addresses in the detection networks. |
deception enable
detect-network
reset deception ip-state
display deception redirect
Use display deception redirect to display deception redirect entries.
display deception redirect [ source-ip ip-address ] [ destination-ip ip-address ] [ destination-port port ] [ slot slot-number ]
context-admin
context-operator
source-ip ip-address: Specifies the source IP address of the decoyed traffic.
destination - ip-address: Specifies the destination address of the decoyed traffic.
destination-port port: Specifies the destination port number of the decoyed traffic, in the range of 1 to 65535.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays deception redirect entries on all member devices.
The device creates a deception redirect entry when it lures traffic to the decoy server. Before the entry ages, all the traffic that matches the entry will be redirected to the decoy server.
# Display deception redirect entries.
<Sysname> display deception redirect
Slot 1:
SrcIP SrcPort DstIP DstPort VPN instance Type Aging Count
1.1.1.1 1123 1.1.1.2 80 -- Decoy 12 100
1.1.1.3 1223 1.1.1.4 80 -- Off-IP 12 100
Total entries: 2
Slot 2:
Total entries: 2
SrcIP |
Source IP address of the decoyed traffic |
SrcPort |
Source port number of the decoyed traffic |
DstIP |
Destination IP address of the decoyed traffic |
Dstport |
Destination port number of the decoyed traffic |
VPN instance |
VPN instance to which the decoyed traffic belongs. If the traffic belongs to the public network, this field displays two hyphens (--). |
Type |
Deception type: · Decoy—Static deception. · Off-IP—Offline IP deception. |
Aging(s) |
Remaining lifetime of the entry, in seconds. The initial value is 120 seconds. The aging timer of an entry will be reset each time the entry is hit by traffic. |
Count |
Total number of packets of the decoyed traffic. |
Total entries |
Total number of deception redirect entries. |
reset deception redirect
Use ip-state detect rate to configure the IP scanning rate for deception.
Use undo ip-state detect rate to restore the default.
ip-state detect rate rate-number
The deception device performs IP scanning at a rate of 30 ARP requests per second.
Deception view
context-admin
rate-number: Specifies the IP scanning rate, in the range of 10 to 200 (number of ARP requests sent per second).
The device needs to maintain the online status of all the IP addresses in the detection networks for offline IP deception.
After deception is enabled, the device initiates IP address scanning on the detection networks at intervals of 30 minutes.
Within an interval, the device sends ARP requests to the IP addresses on the detection networks at the specified rate (set by the rate-number argument), and then updates the IP address online status according to the responses. If the IP scanning rate is too big, the scanning might affect the internal network. If the IP scanning rate is too small, the device might take a long time to obtain the online status of the IP addresses in the detection networks. Please set a proper IP scanning rate according to your network conditions.
# Configure the deception device to perform IP scanning at a rate of 100 ARP requests per second.
[Sysname] deception
[Sysname-deception] ip-state detect rate 100
· deception enable
· detect-network
Use reset deception ip-state to reset the online status information of the IP addresses in detection networks.
context-admin
context-operator
This command clears the online status information for the IP addresses not in decoy state in the detection networks and re-detects the online status of these addresses. An IP address in not in decoy state if the traffic destined for the IP address is not lured to the decoy server.
# Reset the online status information for the IP addresses in detection networks.
<Sysname> reset deception ip-state
Use reset deception redirect to clear the specified deception redirect entries.
reset deception redirect [ source-ip ip-address ] [ destination-ip ip-address ] [ destination-port port ]
context-admin
context-operator
After this command is executed, the device does not redirect the traffic matching the deleted entries any longer but monitors and decoys the traffic again.
If you do not specify any parameters, this command clears all deception redirect entries.
# Clear the specified deception redirect entry to terminate the deception on the matching traffic.
<Sysname> reset deception redirect source-ip 1.1.1.1 destination-ip 1.1.1.2 port 80
