12-ACL and QoS
HomeSupportRoutersCR16000-F SeriesDiagnose & MaintainAlarms ReferencesH3C CR16000-F Routers Alarm Reference-R8530Pxx-6W10012-ACL and QoS
03-HH3C-IFQOS2-MIB
03-HH3C-IFQOS2-MIB 313.30 KB
HH3C-IFQOS2-MIB
About this MIB
Use this MIB to configure or obtain settings for the following modules:
   Hardware queuing.
   Software queuing.
   Rate limit.
   CAR.
   GTS.
   WRED.
   Port priority and priority trust mode.
   Priority map.
CAR includes aggregate CAR and three-color CAR. WRED includes table-based WRED and interface WRED.
WRED
WRED avoids global TCP synchronization by randomly dropping packets before a queue is full. WRED sets an upper threshold and lower threshold for each queue, and processes the packets in a queue as follows:
When the queue size is shorter than the lower threshold, no packet is dropped.
When the queue size reaches the upper threshold, all subsequent packets are dropped.
When the queue size is between the lower threshold and the upper threshold, the received packets are dropped at random. The drop probability in a queue increases along with the queue size under the maximum drop probability.
WRED can discard packets based on the IP precedence, DSCP, or MPLS EXP value and selectively discard low-priority packets.
Through combining WRED with WFQ, the flow-based WRED can be realized.
WRED has the following types:
Port-based WRED: Applies WRED to all packets on a port.
Queue-based WRED: Applies WRED to only packets on WRED-enabled queues.
Drop level-based WRED: Applies different WRED parameters to packets with different WRED parameters.
ACL-based WRED: Applies different WRED parameters to packets matching different ACLs.
802.1p-based WRED: Applies different WRED parameters to packets with different 802.1p priorities.
EXP-based WRED: Applies different WRED parameters to packets with different EXP priorities.
ATM CLP-based WRED: Applies different WRED parameters to packets with different CLP priorities.
DSCP-based WRED: Applies different WRED parameters to packets with different DSCP values.
IP precedence-based WRED: Applies different WRED parameters to packets with different IP precedences.
FR DE-based WRED: Applies different WRED parameters to packets with different DE bit settings.
ComwareV500R002 supports two WRED configuration approaches:
Interface configurationConfigure WRED parameters on an interface or PVC and enable WRED.
WRED table configurationConfigure a WRED table in system view and then apply the WRED table to an interface. A maximum number of 64 WRED tables is supported.
Aggregate CAR
Some switch models support aggregate CAR.
An aggregate CAR action is created globally. It can be directly applied to interfaces or used in the traffic behaviors associated with different traffic classes to police multiple traffic flows as a whole. The total rate of the traffic flows must conform to the traffic policing specifications set in the aggregate CAR action.
MIB file name
hh3c-ifqos2.mib
Notifications
hh3cIfQoS8QueueResouceOverAlarm
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.1
The downlink resources of an 8-queue scheduling profile are insufficient.
Error
Major
hh3cIfQoS8QueueResouceOverRecover (hh3cIfQoS8QueueResouceOverRecover)
OFF
Notification triggers
The notification is generated when the downlink (network side to user side) resources of an 8-queue scheduling profile are insufficient.
System impact
The qos user-queue command might not take effect.
Status control
ON
CLI: Use the snmp-agent trap enable qos command.
OFF
CLI: Use the undo snmp-agent trap enable qos command.
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
 (1.3.6.1.4.1.25506.2.65.1.15.1)
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
 (1.3.6.1.4.1.25506.2.65.1.15.2)
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
 (1.3.6.1.4.1.25506.2.65.1.15.3)
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSChip
 (1.3.6.1.4.1.25506.2.65.1.15.4)
Chip number
N/A
Integer32
0 to 65534
hh3cIfQoSDirection (1.3.6.1.4.1.25506.2.65.1.15.6)
Direction
N/A
Direction
As per the MIB
Recommended action
To resolve the issue:
1.Delete or optimized related configuration.
2.If you cannot identify the configuration to be deleted or optimized, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.2
The resources of an 8-queue user-queue profile are sufficient.
Recovery
Major
N/A (N/A)
OFF
The notification is generated when the resources of an 8-queue user-queue profile are sufficient.
System impact
No negative impact on the system.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSChip
Chip number
N/A
Integer32
0 to 65534
Direction
N/A
Direction
As per the MIB
Recommended action
No action is required.
hh3cIfQoS8QueueResoucePreAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.3
The resource usage of an 8-queue scheduling profile exceeds 90%.
Error
Minor
hh3cIfQoS8QueueResoucePreRecover (hh3cIfQoS8QueueResoucePreRecover)
OFF
The notification is generated when the resource usage of an 8-queue scheduling profile exceeds 90%.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSChip
Chip number
N/A
Integer32
0 to 65534
Direction
N/A
Direction
As per the MIB
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.4
The resource usage of an 8-queue scheduling profile fell below 90%.
Recovery
Minor
N/A (N/A)
OFF
The notification is generated when the resource usage of an 8-queue scheduling profile falls below 90%.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSChip
Chip number
N/A
Integer32
0 to 65534
Direction
N/A
Direction
As per the MIB
Recommended action
hh3cIfQoSBufferOverAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.5
Queue buffer usage alarm.
Error
Minor
hh3cIfQoSBufferOverRecover (hh3cIfQoSBufferOverRecover)
OFF
An alarm is generated when the queue buffer usage reaches or exceeds 90%.
System impact
Packet loss occurs on high-priority queues.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSChip
Chip number
N/A
Integer32
0 to 65534
Direction
N/A
Direction
As per the MIB
Recommended action
1.Reduce deployed services.
2.If the issue persists, collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.6
Queue buffer usage alarm recovery.
Recovery
Minor
N/A (N/A)
OFF
The notification is generated when the queue buffer usage alarm recovers.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSChip (1.3.6.1.4.1.25506.2.65.1.15.4)
Chip number
N/A
Integer32
0 to 65534
Recommended action
hh3cIfQoSModeChannelOverPortShapAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.7
The channelized bandwidth exceeds the interface rate limit.
Error
Major
hh3cIfQoSModeChannelOverPortShapRecover (hh3cIfQoSModeChannelOverPortShapRecover)
OFF
The notification is generated when the channelized bandwidth exceeds the interface rate limit.
System impact
The channelized bandwidth does not take effect.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSIfName (1.3.6.1.4.1.25506.2.65.1.15.5)
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
Recommended action
1.Use the mode channel-bandwidth command to set a smaller channelized bandwidth.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.8
The channelized bandwidth is smaller than the interface rate limit.
Recovery
Major
N/A (N/A)
OFF
The notification is generated when the channelized bandwidth is smaller than the interface rate limit.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
Recommended action
hh3cIfQoSExclusiveBandApplyFailAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.9
Exclusive bandwidth application failure alarm.
Error
Major
hh3cIfQoSExclusiveBandApplyFailRecover (hh3cIfQoSExclusiveBandApplyFailRecover)
OFF
The notification is generated when the exclusive bandwidth fails to be applied.
System impact
The exclusive bandwidth does not take effect.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
Recommended action
Collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.10
Exclusive bandwidth application failure alarm recovery.
Recovery
Major
N/A (N/A)
OFF
The notification is generated when the exclusive bandwidth application failure alarm recovers.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
Recommended action
None.
hh3cIfQoSExclusiveBandOverAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.11
Exclusive bandwidth exceeding maximum interface bandwidth.
Error
Major
hh3cIfQoSExclusiveBandOverRecover (hh3cIfQoSExclusiveBandOverRecover)
OFF
The notification is generated when the exclusive bandwidth value exceeds the maximum interface bandwidth. The configuration will also become ineffective.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
Recommended action
Configure an exclusive bandwidth value that is smaller than the maximum interface bandwidth.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.12
Exclusive bandwidth exceeding maximum interface bandwidth alarm recovery.
Recovery
Major
N/A (N/A)
OFF
The notification is generated when the alarm that the configured exclusive bandwidth value exceeds the maximum interface bandwidth recovers.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
Recommended action
hh3cIfQoSLRDiscardAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.13
The outgoing traffic of an interface exceeds the configured CIR
Error
Major
hh3cIfQoSLRDiscardAlarmRecover (hh3cIfQoSLRDiscardAlarmRecover)
OFF
The notification is generated when the outgoing traffic of an interface exceeds the configured CIR.
System impact
The outgoing traffic of an interface might be dropped.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
hh3cIfQoSLRCir (1.3.6.1.4.1.25506.2.65.1.3.1.1.2)
CIR
N/A
Unsigned32
Standard MIB values.
hh3cIfQoSPassPacketRate (1.3.6.1.4.1.25506.2.65.1.15.7)
Outgoing traffic rate of the interface
N/A
Unsigned32
Recommended action
Increase the CIR on the interface.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.14
The outgoing traffic rate of an interface drops below the configured CIR
Recovery
Major
N/A (N/A)
OFF
The notification is generated when the outgoing traffic rate of an interface drops below the configured CIR.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
CIR
N/A
Unsigned32
N/A
Unsigned32
Recommended action
hh3cIfQoSCarDiscardAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.15
Packets are dropped by CAR on an interface
Error
Major
hh3cIfQoSCarDiscardAlarmRecover (hh3cIfQoSCarDiscardAlarmRecover)
OFF
The notification is generated when packets are dropped by CAR on an interface.
System impact
Traffic might be dropped.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis (1.3.6.1.4.1.25506.2.65.1.15.1)
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot (1.3.6.1.4.1.25506.2.65.1.15.2)
Slot number
N/A
Integer32
0 to 65534
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
Direction
N/A
Direction
Recommended action
Cancel the CAR settings or increase the CIR.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.16
Packets dropped by CAR on an interface have been recovered
Recovery
Major
N/A (N/A)
OFF
The notification is generated when packets dropped by CAR on an interface have been recovered.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
Direction
N/A
Direction
Recommended action
hh3cIfQoSCoppDropPktAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.17
Packets are dropped by CAR on the control plane
Error
Major
hh3cIfQoSCoppDropPktAlarmRecover (hh3cIfQoSCoppDropPktAlarmRecover)
OFF
The notification is generated when packets are dropped by CAR on the control plane.
System impact
Packets are dropped by CAR on the control plane, and services or internal control information might not be able to be processed.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCoppProtocol (1.3.6.1.4.1.25506.2.65.1.15.8)
Protocol type
N/A
OCTET STRING
SIZE (1 to 31)
hh3cIfQoSBandwidth (1.3.6.1.4.1.25506.2.65.1.15.9)
Bandwidth
N/A
Unsigned32
1.3.6.1.4.1.25506.2.65.1.15.13 (hh3cIfQoSBandwidthUnit)
Bandwidth unit
N/A
INTEGER
unitUnavailable (0), unitAbsolute (1), unitAbsolutePPS (4)
Recommended action
Cancel the CAR settings for the control plane.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.18
Packets dropped by CAR on the control plane have been recovered
Recovery
Major
N/A (N/A)
OFF
The notification is generated when packets dropped by CAR on the control plane have been recovered.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Protocol type
N/A
OCTET STRING
SIZE (1 to 31)
Bandwidth
N/A
Unsigned32
Bandwidth unit
N/A
INTEGER
Recommended action
hh3cIfQoSQueExcpAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.19
Packets fail to be forwarded due to queue exceptions.
Error
Major
hh3cIfQoSQueExcpAlarmRecover (hh3cIfQoSQueExcpAlarmRecover)
OFF
The notification is generated when packets fail to be forwarded due to queue exceptions.
System impact
Packets cannot be forwarded.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Protocol type
N/A
OCTET STRING
SIZE (1 to 31)
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.20
Packets failing to be forwarded due to queue exceptions have been recovered.
Recovery
Major
N/A (N/A)
OFF
The notification is generated when packets failing to be forwarded due to queue exceptions have been recovered.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Protocol type
N/A
OCTET STRING
SIZE (1 to 31)
Recommended action
hh3cIfQoSBoardL3AclResLack
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.21
Layer 3 ACL resources are insufficient.
Error
Major
N/A (N/A)
OFF
The notification is generated when Layer 3 ACL resources are insufficient.
System impact
ACL rules do not take effect or fail to be matched.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSServiceName (1.3.6.1.4.1.25506.2.65.1.15.10)
Service name
N/A
OCTET STRING
SIZE (1 to 63)
hh3cIfQoSFailReason (1.3.6.1.4.1.25506.2.65.1.15.12)
Failure reason
N/A
OCTET STRING
SIZE (1 to 127)
Recommended action
hh3cIfQoSAclResAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.22
Error
Major
hh3cIfQoSAclResAlarmRecover (hh3cIfQoSAclResAlarmRecover)
OFF
The notification is generated when ACL resources are insufficient.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Service name
N/A
OCTET STRING
SIZE (1 to 63)
hh3cIfQoSApplyObject (1.3.6.1.4.1.25506.2.65.1.15.11)
Application object
N/A
OCTET STRING
SIZE (1 to 127)
Direction
N/A
Direction
Failure reason
N/A
OCTET STRING
SIZE (1 to 127)
Recommended action
Basic information
OID
Event
Severity
Default status
The ACL resource alarm is cleared.
Recovery
Major
N/A (N/A)
OFF
The notification is generated when the ACL resource alarm is cleared.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Service name
N/A
OCTET STRING
SIZE (1 to 63)
Application object
N/A
OCTET STRING
SIZE (1 to 127)
Direction
N/A
Direction
Failure reason
N/A
OCTET STRING
SIZE (1 to 127)
Recommended action
hh3cIfQoSAclMemFullAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.24
The ACL forwarding engine memory is exhausted.
Error
Major
hh3cIfQoSAclMemFullAlarmRecover (hh3cIfQoSAclMemFullAlarmRecover)
OFF
The notification is generated when the ACL forwarding engine memory is exhausted.
System impact
ACL rules fail to be matched.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.25
The ACL forwarding engine memory is recovered.
Recovery
Major
N/A (N/A)
OFF
The notification is generated when the ACL forwarding engine memory is recovered.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Recommended action
