02-HH3C-CBQOS2-MIB | 71.63 KB |
HH3C-CBQOS2-MIB
About this MIB
Use this MIB to configure class-based QoS (CBQoS).
CBQoS applies different service quality levels to different classes of packets, enabling multiple service support on the network.
MIB file name
hh3c-cbqos2.mib
Notifications
hh3cCBQoSGlobalAclNotSupport
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.65.2.1.7.0.3 |
The global ACL is not supported. |
Informational |
Warning |
N/A (N/A) |
OFF |
Notification triggers
The notification is generated when you apply a QoS policy globally and a card does not support the ACL used in the QoS policy.
System impact
The QoS policy applied globally does not take effect on the card.
Status control
ON
CLI: Use the snmp-agent trap enable qos command.
OFF
CLI: Use the undo snmp-agent trap enable qos command.
Object
OID (object name) |
Index |
Type |
Value range |
hh3cCBQoSChassis (1.3.6.1.4.1.25506.2.65.2.1.8.1) |
Chassis number |
N/A |
Integer32 |
0..65534 |
hh3cCBQoSSlot (1.3.6.1.4.1.25506.2.65.2.1.8.2) |
Slot number |
N/A |
Integer32 |
0..65534 |
hh3cCBQoSCPU (1.3.6.1.4.1.25506.2.65.2.1.8.3) |
CPU number |
N/A |
Integer32 |
0..65534 |
hh3cCBQoSDirection (1.3.6.1.4.1.25506.2.65.2.1.8.4) |
Application direction |
N/A |
DirectionTyp |
Standard MIB values. |
Recommended action
No action is required.
hh3cCBQoSGlobalQPPBNotSupport
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.2.1.7.0.4 |
QPPB is not supported. |
Informational |
Warning |
N/A (N/A) |
OFF |
The notification is generated when you apply a QoS policy globally in QPPB mode and a card does not support QPPB.
System impact
The QoS policy applied globally in QPPB mode does not take effect on the card.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Chassis number |
N/A |
Integer32 |
0..65534 |
Slot number |
N/A |
Integer32 |
0..65534 |
CPU number |
N/A |
Integer32 |
0..65534 |
N/A |
DirectionType |
Recommended action
Apply a QoS policy in QPPB mode to the interfaces on the card that support the QPPB mode.
hh3cCBQoSRedirectInvalidAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.2.1.7.0.5 |
The redirection next hop is unreachable. |
Error |
Major |
hh3cCBQoSRedirectInvalidAlarmRecover (hh3cCBQoSRedirectInvalidAlarmRecover) |
OFF |
The notification is generated when the redirection next hop is unreachable.
System impact
The QoS policy containing the redirection action does not take effect.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.65.2.1.8.5 (hh3cCBQoSRedirectAlarmBehaviorName) |
Traffic behavior name |
N/A |
OCTET STRING |
SIZE (1..31) |
1.3.6.1.4.1.25506.2.65.2.1.8.6 (hh3cCBQoSRedirectAlarmProtoFamily) |
Protocol family of the next-hop address |
N/A |
InetAddressType |
1.3.6.1.4.1.25506.2.65.2.1.8.7 (hh3cCBQoSRedirectAlarmNextHop) |
Next-hop address |
N/A |
InetAddress |
Recommended action
To resolve the issue, identify whether the next hop exists in the routing table. If the next hop does not exist in the routing table, configure a routing protocol for the next hop to be learned to the routing table.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.65.2.1.7.0.6 |
The redirection next hop is reachable. |
Recovery |
Major |
N/A (N/A) |
OFF |
The notification is generated when the redirection next hop is reachable.
System impact
No negative impact on the system.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
OCTET STRING |
SIZE (1..31) |
N/A |
InetAddressType |
Next-hop address |
N/A |
InetAddress |
Recommended action
