20-Network Management and Monitoring
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesMIB CompanionH3C SR8800-F Routers MIB Reference-R8530Pxx-6W10020-Network Management and Monitoring
16-RMON2-MIB
16-RMON2-MIB 45.71 KB
RMON2-MIB
About this MIB
Use this MIB to monitor the data traffic on a network segment or the entire network. RMON2-MIB is an extended version of RMON to support multi-dimensional monitoring and statistics.
MIB file name
rfc4502-rmon2.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).rmon(16)
Scalar objects
probeCapabilities (1.3.6.1.2.1.16.19.1)
Object (OID)
Access
Value range
Implementation
read-only
BITS
BITS { etherStats(0), historyControl(1), etherHistory(2), alarm(3), hosts(4), hostTopN(5), matrix(6), filter(7), capture(8), event(9), tokenRingMLStats(10), tokenRingPStats(11), tokenRingMLHistory(12), tokenRingPHistory(13), ringStation(14), ringStationOrder(15), ringStationConfig(16), sourceRouting(17), protocolDirectory(18), protocolDistribution(19), addressMapping(20), nlHost(21), nlMatrix(22), alHost(23), alMatrix(24), usrHistory(25), probeConfig(26) }
An indication of the RMON MIB groups supported on a minimum of one interface by this probe.
As per the MIB.
probeSoftwareRev (1.3.6.1.2.1.16.19.2)
Object (OID)
Access
Value range
Implementation
read-only
OCTET STRING
OCTET STRING (0..15)
Software revision of this device.
As per the MIB.
probeHardwareRev (1.3.6.1.2.1.16.19.3)
Object (OID)
Access
Value range
Implementation
read-only
DisplayString
OCTET STRING (0..31)
Hardware revision of this device.
Not supported.
