20-Network Management and Monitoring
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesMIB CompanionH3C SR8800-F Routers MIB Reference-R8530Pxx-6W10020-Network Management and Monitoring
09-HH3C-NETSTREAM6-MIB
09-HH3C-NETSTREAM6-MIB 63.66 KB
HH3C-NETSTREAM6-MIB
About this MIB
Use this MIB to export alarm information of the NETSTREAM6 module.
MIB file name
hh3c-netstream6.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cNetstream6(257)
Scalar objects
hh3cNetstream6TrapEntrySpec (1.3.6.1.4.1.25506.2.257.1.1.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
Unsigned32
Standard MIB values.
Flow table specification.
As per the MIB.
hh3cNetstream6TrapEntryChassis (1.3.6.1.4.1.25506.2.257.1.1.2)
Object (OID)
Access
Value range
Implementation
Unsigned32
Alarmed chassis number.
As per the MIB.
hh3cNetstream6TrapEntrySlot (1.3.6.1.4.1.25506.2.257.1.1.3)
Object (OID)
Access
Value range
Implementation
Unsigned32
Alarmed slot number.
As per the MIB.
Notifications
hh3cNetstream6TrapEntryTHAlarm
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.257.1.0.1
The number of IPv6 Netstream entries reaches the alarm threshold of the device, module, or member device.
Informational
Warning
1.3.6.1.4.1.25506.2.257.1.0.2 (hh3cNetstream6TrapEntryTHResume)
ON
Notification triggers
This notification is generated when the number of IPv6 NetStream entries reaches 80% of the upper limit of the module.
System impact
Too many IPv6 NetStream entries will increase the memory usage. When the number of the entries reaches the upper limit, the system might not be able to collect statistics for some of the entries.
Status control
ON
CLI: Use the snmp-agent trap enable ipv6 netstream [ entry-limit ] command.
OFF
CLI: Use the undo snmp-agent trap enable ipv6 netstream [ entry-limit ] command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.257.1.1.1 (hh3cNetstream6TrapEntrySpec)
N/A
Unsigned32
 (hh3cNetstream6TrapEntryChassis)
Chassis number
N/A
Unsigned32
1.3.6.1.4.1.25506.2.257.1.1.3 (hh3cNetstream6TrapEntrySlot)
Slot number
N/A
Unsigned32
Recommended action
1.If the device has enough memory, use the ipv6 netstream max-entry command to expand the upper limit for IPv6 NetStream entries.
2.If the device has good performance, use the ipv6 netstream max-entry aging command to age out some entries when the upper limit is reached. This can resolve the issue that some entry statistics cannot be collected.
3.Adjust the incoming interface or add new modules to sort flows.
Basic information
OID
Event
Severity
Default status
The number of IPv6 Netstream entries reaches the recovery threshold of the card.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the number of IPv6 NetStream entries drops below 70% of the upper limit of the device, module, or member device.
System impact
No negative impact on the system.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
Unsigned32
Chassis number.
N/A
Unsigned32
Slot number.
N/A
Unsigned32
Recommended action
No action is required.
