17-Network Management and Monitoring
HomeSupportRoutersH3C SR8800-F Router SeriesDiagnose & MaintainAlarms ReferencesH3C SR8800-F Routers Alarm Reference-R8530Pxx-6W10017-Network Management and Monitoring
10-HH3C-SNMP-EXT-MIB
10-HH3C-SNMP-EXT-MIB 57.46 KB
HH3C-SNMP-EXT-MIB
About this MIB
This MIB adds objects to extend SNMP management.
MIB file name
hh3c-snmp-ext.mib
Notifications
hh3cSnmpExtTargetHostDel
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.104.3.0.1
An SNMP notification target host configuration was cancelled.
Informational
Warning
N/A (N/A)
ON
Notification triggers
This notification is generated when the undo snmp-agent target-host command is executed to cancel an SNMP notification target host configuration. This notification is sent only to the canceled target host.
System impact
No negative impact on the system.
Status control
This notification cannot be disabled.
Object
OID (object name)
Index
Value range
hh3cSnmpExtTargetAddress (1.3.6.1.4.1.25506.2.104.1.12)
Address of the target host that receives SNMP notifications.
N/A
OCTET STRING
Standard MIB values.
Recommended action
No action is required.
hh3cSnmpExtLockThreshold
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.104.3.0.2
The number of users in the SNMPv3 user denylist exceeded the rising threshold.
Informational
Warning
hh3cSnmpExtLockThresholdResume (hh3cSnmpExtLockThresholdResume)
ON
This notification is generated when the number of users in the SNMPv3 user denylist exceeds the rising threshold (40% of the maximum number of users in the SNMPv3 user denylist).
System impact
The device is subject to many authorized user access attacks, which can result in network management connection failure in worst cases.
Status control
ON
CLI: Use the snmp-agent trap enable command.
OFF
CLI: Use the undo snmp-agent trap enable command.
Object
OID (object name)
Index
Value range
hh3cSnmpExtRisingThreshold (1.3.6.1.4.1.25506.2.104.1.14)
Rising threshold for the number of users in the SNMPv3 user denylist.
N/A
Integer32
Recommended action
Check the users in the denylist for attack sources and filter attack sources through firewall or other means.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.104.3.0.3
The number of users in the SNMPv3 denylist fell below the falling threshold.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the number of users in the SNMPv3 user denylist falls below the falling threshold (10% of the maximum number of users in the SNMPv3 user denylist).
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cSnmpExtFallingThreshold (1.3.6.1.4.1.25506.2.104.1.13)
Falling threshold for the number of users in the SNMPv3 user denylist.
N/A
Integer32
Recommended action
