05-HH3C-NETSTREAM4-MIB | 54.41 KB |
HH3C-NETSTREAM4-MIB
About this MIB
Use this MIB to export alarm information of the NETSTREAM4 module.
MIB file name
hh3c-netstream4.mib
Notifications
hh3cNetstream4TrapEntryTHAlarm
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.256.1.0.1 |
The number of IPv4 Netstream entries reaches the alarm threshold of the device, card, or member device. |
Informational |
Warning |
1.3.6.1.4.1.25506.2.256.1.0.2 (hh3cNetstream4TrapEntryTHResume) |
ON |
Notification triggers
This notification is generated when the number of IPv4 NetStream entries reaches 80% of the upper limit of the device, card, or member device.
System impact
Too many IPv4 NetStream entries will use a large amount of the memory. When the number of the entries reaches the upper limit, the system might not be able to collect statistics for some of the entries.
Status control
ON
CLI: Use the snmp-agent trap enable ip netstream [ entry-limit ] command.
OFF
CLI: Use the undo snmp-agent trap enable ip netstream [ entry-limit ] command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.256.1.1.1 (hh3cNetstream4TrapEntrySpec) |
Flow table specification |
N/A |
Unsigned32 |
Standard MIB values. |
1.3.6.1.4.1.25506.2.256.1.1.2 (hh3cNetstream4TrapEntryChassis) |
Chassis number |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.256.1.1.3 (hh3cNetstream4TrapEntrySlot) |
Slot number |
N/A |
Unsigned32 |
Recommended action
1.If the device has enough memory, use the ip netstream max-entry command to expand the upper limit for IPv4 NetStream entries.
2.If the device has good performance, use the ip netstream max-entry aging command to age out some entries when the upper limit is reached. This can resolve the issue that some entry statistics cannot be collected.
3.Adjust the incoming interface or add new cards to sort flows.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.256.1.0.2 |
The number of IPv4 Netstream entries reaches the recovery threshold of the device, card, or member device. |
Recovery |
Warning |
N/A (N/A) |
ON |
This notification is generated when the number of IPv4 NetStream entries drops below 70% of the upper limit of the device, card, or member device.
System impact
No impact on the system.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Flow table specification. |
N/A |
Unsigned32 |
Chassis number. |
N/A |
Unsigned32 |
Slot number. |
N/A |
Unsigned32 |
Recommended action
No action is required.
