17-Network Management and Monitoring
HomeSupportRoutersH3C SR8800-F Router SeriesDiagnose & MaintainAlarms ReferencesH3C SR8800-F Routers Alarm Reference-R8530Pxx-6W10017-Network Management and Monitoring
01-HH3C-NTP-MIB
01-HH3C-NTP-MIB 113.14 KB
HH3C-NTP-MIB
About this MIB
Use this MIB to configure NTP of the device.
MIB file name
hh3c-ntp.mib
Notifications
hh3cNTPSysStateChangeTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.1
NTP local time synchronization status changed.
Informational
Warning
N/A (N/A)
ON
Notification triggers
This notification is generated when the NTP local time synchronization status changes.
Possible reasons for change of the NTP time status from synchronized to unsynchronized include:
Reason 1: The specified time server is deleted.
Reason 2: The specified time server fails authentication.
Reason 3: The clock of the specified time server is not synchronized.
Reason 4: The specified time server is not reachable.
Reason 5: The stratum level of the clock source is larger than that of the local clock.
Reason 6: The clock source is lost.
System impact
The local time is inaccurate.
Status control
The notification cannot be disabled.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.8.22.1.1.10
 (hh3cNTPSysState)
Local clock status.
N/A
INTEGER
noUpdateClock(0), getfreqInfo(1), clockBySet(2), clockBySetAndNoFreq(3), clockBySyns(4), findError(5)
1.3.6.1.4.1.25506.8.22.1.1.19
 (hh3cNTPServerIP)
IP address of the NTP server.
N/A
IpAddress
OCTET STRING (4)
1.3.6.1.4.1.25506.8.22.1.1.22 (hh3cNTPSysSrcVpnName)
VPN instance to which the NTP server belongs.
N/A
DisplayString
OCTET STRING(0..255)
Recommended action
hh3cNTPSysPeerChangeTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.2
Change of the NTP time server.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the NTP time server changes.
System impact
No negative impact on the system.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.8.22.1.1.21 (hh3cNTPSysOldServerIP)
IP address of last NTP server.
N/A
IpAddress
Standard MIB values.
1.3.6.1.4.1.25506.8.22.1.1.23 (hh3cNTPSysOldSrcVpnName)
VPN instance to which the last NTP server belongs.
N/A
DisplayString
OCTET STRING (0..255)
1.3.6.1.4.1.25506.8.22.1.1.19 (hh3cNTPServerIP)
IP address of the current NTP server.
N/A
IpAddress
VPN instance to which the current NTP server belongs.
N/A
DisplayString
Recommended action
If the clock source is changed because another clock source is specified, no action is required.
If the clock source is changed because of a change in clock source properties, execute the display ntp-service sessions verbos command to view the clock source properties and conduct further investigation. You can see the recommended actions for the hh3cNTPSysStateChangeTrap.
hh3cNTPDynSessionLimit
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.3
The number of dynamic NTP sessions reached the threshold.
Error
Major
1.3.6.1.4.1.25506.8.22.1.2.0.4 (hh3cNTPDynSessionLimitResume)
ON
This notification is generated when the number of dynamic NTP sessions reaches the threshold.
System impact
New dynamic NTP sessions cannot be established.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.8.22.1.1.24 (hh3cNTPSysMaxDynamicSessions)
Maximum number of dynamic NTP sessions.
N/A
Unsigned32
Unsigned32 (0..4294967295)
Recommended action
Execute the ntp-service max-dynamic-sessions command to set the maximum number of dynamic sessions to a value large enough.
Basic information
OID
Event
Severity
Default status
The number of dynamic NTP sessions dropped below the threshold.
Recovery
Major
N/A (N/A)
ON
This notification is generated when the number of dynamic NTP sessions drops below the threshold.
System impact
Status control
Object
OID (object name)
Index
Value range
N/A
Unsigned32
Recommended action
No action is required.
hh3cNTPSessionLimit
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.5
Number of NTP sessions reached the threshold.
Error
Major
1.3.6.1.4.1.25506.8.22.1.2.0.6 (hh3cNTPSessionLimitResume)
ON
This notification is generated when the number of NTP sessions reaches the threshold.
System impact
New NTP sessions cannot be established.
Status control
Object
OID (object name)
Index
Value range
hh3cNTPSysMaxSessions (1.3.6.1.4.1.25506.8.22.1.1.25)
Maximum number of NTP sessions.
N/A
Unsigned32
Unsigned32 (0..65535)
Recommended action
Delete unused static NTP sessions.
Basic information
OID
Event
Severity
Default status
Number of NTP sessions fell below the threshold.
Recovery
Major
N/A (N/A)
ON
This notification is generated when the number of NTP sessions falls below the threshold.
System impact
Status control
Object
OID (object name)
Index
Value range
N/A
Unsigned32
Recommended action
hh3cNTPSynchronizationResume
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.8
The local NTP clock resumed time synchronization.
Recovery
Major
N/A (N/A)
ON
This notification is generated when the local NTP clock resumes time synchronization.
System impact
Status control
Object
OID (object name)
Index
Value range
 (hh3cNTPSysState)
Local clock status.
N/A
INTEGER
N/A
IpAddress
OCTET STRING (4)
Recommended action
hh3cNTPSysStratumChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.9
The stratum level of the local clock changed.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the stratum level of the local clock changes.
System impact
The downstream NTP clock might become unsynchronized.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.8.22.1.1.2 (hh3cNTPSysStratum)
Current stratum level of the local system clock.
N/A
Integer32
Integer32 (1..16)
1.3.6.1.4.1.25506.8.22.1.1.26 (hh3cNTPSysOldStratum)
Old stratum level of the local system clock.
N/A
Integer32
Integer32 (1..16)
Recommended action
hh3cNTPTimeOffsetThresExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.10
NTP clock offset reached the threshold.
Error
Major
1.3.6.1.4.1.25506.8.22.1.2.0.11 (hh3cNTPTimeOffsetThresResume)
OFF
This notification is generated when the time offset between the local NTP clock and the NTP time server reaches or exceeds the threshold.
System impact
The clock precision might be affected.
Status control
ON
CLI: Use the ntp-service time-offset-threshold trap trap-threshold command.
OFF
CLI: Use the undo ntp-service time-offset-threshold command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.8.22.1.1.11 (hh3cNTPSysOffset)
NTP time offset.
N/A
OCTET STRING
OCTET STRING (1..128)
1.3.6.1.4.1.25506.8.22.1.1.27 (hh3cNTPSysTimeOffsetThres)
NTP time offset threshold.
N/A
OCTET STRING
Recommended action
1.Execute the display ntp-service sessions verbose command to view detailed information about the NTP session.
  - If the session meets the requirements, execute the ntp-service time-offset-threshold command to correct the alarm threshold.
  - If the session does not meet the requirements, specify another clock source.
2.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
The NTP clock offset fell below the threshold to the normal range.
Recovery
Major
N/A (N/A)
OFF
This notification is generated when the NTP clock offset falls below the threshold to the normal range.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
NTP time offset.
N/A
OCTET STRING
N/A
OCTET STRING
Recommended action
