09-HH3C-RIB-MIB | 57.69 KB |
HH3C-RIB-MIB
About this MIB
Use the HH3C-RIB-MIB to obtain device RIB information and collect alarm information.
MIB file name
hh3c-rib.mib
Notifications
hh3cRibCyclicIterateRestrain
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.219.2.0.1 |
The recursion loop for routes in the VPN instance is suppressed. |
Error |
Warning |
1.3.6.1.4.1.25506.2.219. 2.0.2 (hh3cRibCyclicIterateRestrainClr) |
ON |
Notification triggers
This notification is generated when the recursion loop for routes in the VPN instance is suppressed.
System impact
The CPU usage might remain high.
Status control
ON
CLI: Use the snmp-agent trap enable [ ipv6 ] rib cyclic-iterate-restrain command.
OFF
CLI: Use the undo snmp-agent trap enable [ ipv6 ] rib cyclic-iterate-restrain command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.219.1.1 (hh3cRibVrfRestrainType) |
Address family type of the VPN route. |
N/A |
OCTET STRING |
OCTET STRING(1..31) |
1.3.6.1.4.1.25506.2.219.1.2 (hh3cRibVrfName) |
VPN instance name. |
N/A |
OCTET STRING |
OCTET STRING(0..31) |
1.3.6.1.4.1.25506.2.219.1.3 (hh3cRibVrfIndex) |
VPN instance index. |
N/A |
Gauge32 |
INTEGER(0..65535) |
1.3.6.1.4.1.25506.2.219.1.4 (hh3cRibVrfRtNexthopAddress) |
Next hop address of the VPN route. |
N/A |
OCTET STRING |
OCTET STRING(1..46) |
1.3.6.1.4.1.25506.2.219.1.5 (hh3cRibVrfRtProtocol) |
Protocol type of the VPN route. |
N/A |
OCTET STRING |
Recommended action
To resolve the issue:
1.If the value for 1.3.6.1.4.1.25506.2.219.1.1 (hh3cRibVrfRestrainType) is IPv4, and the value for 1.3.6.1.4.1.25506.2.219.1.3 (hh3cRibVrfIndex) is 0, execute the display ip routing-table command to obtain the route related to 1.3.6.1.4.1.25506.2.219.1.4 (hh3cRibVrfRtNexthopAddress) and identify whether a recursion loop exists.
If yes, proceed to step 5.
If not, proceed to step 6.
2.If the value for 1.3.6.1.4.1.25506.2.219.1.1 (hh3cRibVrfRestrainType) is IPv4, and the value for 1.3.6.1.4.1.25506.2.219.1.3 (hh3cRibVrfIndex) is not 0, execute the display ip routing-table vpn-instance vpn-instance-name command to obtain the route related to 1.3.6.1.4.1.25506.2.219.1.4 (hh3cRibVrfRtNexthopAddress) in VPN routing table hh3cRibVrfName and identify whether a recursion loop exists.
3.If the value for 1.3.6.1.4.1.25506.2.219.1.1 (hh3cRibVrfRestrainType) is IPv6, and the value for 1.3.6.1.4.1.25506.2.219.1.3 (hh3cRibVrfIndex) is 0, execute the display ipv6 routing-table command to obtain the route related to 1.3.6.1.4.1.25506.2.219.1.4 (hh3cRibVrfRtNexthopAddress) and identify whether a recursion loop exists.
4.If the value for 1.3.6.1.4.1.25506.2.219.1.1 (hh3cRibVrfRestrainType) is IPv6, and the value for 1.3.6.1.4.1.25506.2.219.1.3 (hh3cRibVrfIndex) is not 0, execute the display ipv6 routing-table vpn-instance vpn-instance-name command to obtain the route related to 1.3.6.1.4.1.25506.2.219.1.4 (hh3cRibVrfRtNexthopAddress) in VPN routing table hh3cRibVrfName and identify whether a recursion loop exists.
5.Delete the route with recursion loop (for more information, see the configuration guide of the associated routing protocol). Wait for 10 minutes, and identify whether the hh3cRibCyclicIterateRestrainClr alarm occurs and whether the hh3cRibCyclicIterateRestrain alarm does not occur any more.
6.If the issue persists, collect configuration data, log information, and alarm information, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.219. 2.0.2 |
The recursion loop suppression for routes in the VPN instance is disabled. |
Recovery |
Warning |
N/A (N/A) |
ON |
This notification is generated when the recursion loop suppression for routes in the VPN instance is disabled.
System impact
No impact on services.
Status control
ON
CLI: Use the snmp-agent trap enable [ ipv6 ] rib cyclic-iterate-restrain-clear command.
OFF
CLI: Use the undo snmp-agent trap enable [ ipv6 ] rib cyclic-iterate-restrain-clear command.
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
N/A |
Gauge32 |
INTEGER(0..65535) |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
Recommended action
No action is required.
