08-Layer 3 - IP Routing
HomeSupportRoutersH3C SR8800-F Router SeriesDiagnose & MaintainAlarms ReferencesH3C SR8800-F Routers Alarm Reference-R8530Pxx-6W10008-Layer 3 - IP Routing
04-HH3C-IPRAN-DCN-MIB
04-HH3C-IPRAN-DCN-MIB 84.37 KB
HH3C-IPRAN-DCN-MIB
About this MIB
HH3C-IPRAN-DCN-MIB is used for the Network Management System (NMS) to perform remote management and control of network elements in the Data Communication Network (DCN), and obtain the running status and receive association and disassociation notifications.
MIB file name
hh3c-ipran-dcn.mib
Notifications
hh3cIpRanDcnNeOnline
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.152.1.3.0.1
A network element comes online.
Recovery
Warning
N/A (N/A)
OFF
Notification triggers
This notification is sent when a network element comes online from the DCN network.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the auto-report command.
OFF
CLI: Use the undo auto-report command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.152.1.1.2.1.1 (hh3cIpRanDcnNeInfoNeId)
ID of the network element.
Hh3cIpRanNeId
OCTET STRING (4)
1.3.6.1.4.1.25506.2.152.1.1.2.1.2 (hh3cIpRanDcnNeInfoNeIpType)
IP address type of the network element.
InetAddressType
ipv4(1)
1.3.6.1.4.1.25506.2.152.1.1.2.1.3 (hh3cIpRanDcnNeInfoNeIp)
IP address of the network element.
InetAddress
OCTET STRING (0..255)
1.3.6.1.4.1.25506.2.152.1.2.3 (hh3cIpRanDcnCompanyName)
Device vendor name.
N/A
DisplayString
1.3.6.1.4.1.25506.2.152.1.2.4 (hh3cIpRanDcnDeviceType)
Device type.
N/A
DisplayString
1.3.6.1.4.1.25506.2.152.1.2.5 (hh3cIpRanDcnDeviceMac)
Bridge MAC of the device.
N/A
MacAddress
OCTET STRING (6)
Recommended action
No action is required.
hh3cIpRanDcnNeOffline
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.152.1.3.0.2
A network element goes offline.
Error
Warning
1.3.6.1.4.1.25506.2.152.1.3.0.1 (hh3cIpRanDcnNeOnline)
OFF
This notification is sent when a network element goes offline from the DCN network.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Network element ID.
Hh3cIpRanNeId
OCTET STRING (4)
InetAddressType
ipv4(1)
InetAddress
Recommended action
hh3cIpRanDcnNeIdConflict
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.152.1.3.0.3
A network element ID conflict occurs.
Error
Warning
1.3.6.1.4.1.25506.2.152.1.3.0.4 (hh3cIpRanDcnNeIdConflictClear)
ON
This notification is sent when two or more devices have the same NE ID in the DCN network.
System impact
After this notification is generated, NMS cannot manage the device correctly, configuration cannot be deployed to the device, and errors might occur on newly added services.
Status control
ON
CLI: Use the snmp-agent trap enable dcn neid-conflict command
OFF
CLI: Use the undo snmp-agent trap enable dcn neid-conflict command
Object
OID (object name)
Index
Value range
Network element ID.
Hh3cIpRanNeId
OCTET STRING (4)
Recommended action
1.Modify the ID of the alarming network element to a unique value in the DCN network, and wait for the NE ID conflict notification to be removed.
2.If the issue persists, collect alarm information and configuration information, and contact H3C Support.
Basic information
OID
Event
Severity
Default status
The network element ID conflict is cleared.
Recovery
Warning
N/A (N/A)
ON
This notification is sent when the network element ID conflict is removed in the DCN network.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable dcn neid-conflict-clear command.
OFF
CLI: Use the undo snmp-agent trap enable dcn neid-conflict-clear command.
Object
OID (object name)
Index
Value range
Network element ID.
Hh3cIpRanNeId
OCTET STRING (4)
Recommended action
hh3cIpRanDcnNeIpConflict
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.152.1.3.0.5
A network element IP address conflict occurs.
Error
Warning
1.3.6.1.4.1.25506.2.152.1.3.0.6 (hh3cIpRanDcnNeIpConflictClear)
ON
This notification is sent when two or more devices have the same NE IP address in the DCN network.
System impact
The conflicting network element may be placed under management, resulting in NMS being unable to manage the device correctly.
Status control
ON
CLI: Use the snmp-agent trap enable dcn neip-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable dcn neip-conflict command.
Object
OID (object name)
Index
Value range
Network element IP address.
InetAddress
Recommended action
1.Modify the IP address of the alarming network element to a unique value in the DCN network, and wait for the NE IP conflict notification to be removed.
Basic information
OID
Event
Severity
Default status
The network element IP address conflict is cleared.
Recovery
Warning
N/A (N/A)
ON
This notification is sent when the network element IP address conflict is removed in the DCN network.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable dcn neip-conflict-clear command.
OFF
CLI: Use the undo snmp-agent trap enable dcn neip-conflict-clear command.
Object
OID (object name)
Index
Value range
InetAddress
Recommended action
