- 17-User Access and Authentication
- 01-HH3C-8021X-EXT2-MIB
- 02-HH3C-AAA-MIB
- 03-HH3C-DOMAIN-MIB
- 04-HH3C-LOCAL-AAA-SERVER-MIB
- 05-HH3C-PORT-SECURITY-MIB
- 06-HH3C-PORTAL-MIB
- 07-HH3C-RADIUS-MIB
- 08-HH3C-USER-MIB
- 09-IEEE8021-PAE-MIB
- 10-IEEE8021-SECY-MIB
- 11-IEEE8021X-PAE-MIB
- 12-RADIUS-ACC-CLIENT-MIB
- 13-RADIUS-AUTH-CLIENT-MIB
06-HH3C-PORTAL-MIB | 105.11 KB |
HH3C-PORTAL-MIB
About this MIB
Use this MIB to configure portal authentication and obtain portal authentication information.
MIB file name
hh3c-portal.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cPortal(99)
Scalar objects
hh3cPortalFirstTrapTime
(1.3.6.1.4.1.25506.2.99.3.1.1)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPortalFirstTrapTime (1.3.6.1.4.1.25506.2.99.3.1.1) |
accessible-for-notify |
Timeticks |
Standard MIB values. |
Time when this notification is triggered. |
As per the MIB. |
hh3cPortalServerIP
(1.3.6.1.4.1.25506.2.99.3.1.2)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPortalServerIP (1.3.6.1.4.1.25506.2.99.3.1.2) |
InetAddress |
OCTET STRING (0..255) |
As per the MIB. |
Tabular objects
hh3cPortalServerTable
About this table
Use this table to obtain information about the portal authentication server and portal Web server.
Support for operations
Create:Not supported
Edit/Modify:Supported
Delete:Not supported
Read:Supported
Columns
The table index is hh3cPortalServerName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPortalServerName (1.3.6.1.4.1.25506.2.99.2.1.1.1) |
OCTET STRING |
OCTET STRING (SIZE (1..32)) |
Name of the portal authentication server. |
As per the MIB. |
hh3cPortalServerUrl (1.3.6.1.4.1.25506.2.99.2.1.1.2) |
read-write |
OCTET STRING |
OCTET STRING (SIZE (1..127)) |
URL of the portal Web server. |
As per the MIB. |
hh3cPortalServerPort (1.3.6.1.4.1.25506.2.99.2.1.1.3) |
read-write |
Integer32 |
Integer32 (1..65534) |
Port number of the portal authentication server. |
As per the MIB. |
hh3cPortalExtSrvTable
About this table
Use this table to configure a portal authentication server and obtain portal configuration and portal running state information.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table index is hh3cPortalExtSrvName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPortalExtSrvName (1.3.6.1.4.1.25506.2.99.7.1.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING (1..32) |
As per the MIB. |
hh3cPortalExtSrvIPAddrType (1.3.6.1.4.1.25506.2.99.7.1.1.2) |
read-create |
InetAddressType |
IP address type of the portal authentication server. |
You must specify hh3cPortalExtSrvIPAddrType and hh3cPortalExtSrvIP in pairs. |
hh3cPortalExtSrvIP (1.3.6.1.4.1.25506.2.99.7.1.1.3) |
read-create |
InetAddress |
IP address of the portal authentication server. |
hh3cPortalExtSrvPort (1.3.6.1.4.1.25506.2.99.7.1.1.4) |
read-write |
Integer32 |
As per the MIB. |
hh3cPortalExtSrvRowStatus (1.3.6.1.4.1.25506.2.99.7.1.1.5) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
As per the MIB. |
hh3cPortalExtSrvVpnName (1.3.6.1.4.1.25506.2.99.7.1.1.6) |
read-create |
OCTET STRING |
OCTET STRING (SIZE (0..31)) |
VPN instance name. |
You must specify hh3cPortalExtSrvVpnName together with hh3cPortalExtSrvIPAddrType and hh3cPortalExtSrvIP. |
hh3cPortalExtSrvKey (1.3.6.1.4.1.25506.2.99.7.1.1.7) |
read-create |
OCTET STRING |
OCTET STRING (SIZE (0..64)) |
Shared key for communication with the portal authentication server. |
You must specify hh3cPortalExtSrvKey together with hh3cPortalExtSrvIPAddrType and hh3cPortalExtSrvIP. A string of 0 to 64 characters. When read, this object returns a zero-length string. |
Notifications
hh3cPortalServerLost
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.99.3.0.1 |
Portal authentication server is unreachable. |
Error |
Major |
1.3.6.1.4.1.25506.2.99.3.0.2 (hh3cPortalServerGet) |
OFF |
Notification triggers
This notification is generated when the device receives no portal packets sent by the portal authentication server within the specified detection period.
This notification might be generated when the following events occur:
The device and the portal authentication server cannot reach each other.
The server heartbeat feature is disabled on the portal authentication server.
System impact
Portal users cannot log in.
Status control
ON
CLI: Use the server-detect trap command in portal authentication server view.
OFF
CLI: Use the undo server-detect command in portal authentication server view.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.99.2.1.1.1 (hh3cPortalServerName) |
hh3cPortalExtSrvName |
OCTET STRING |
1.3.6.1.4.1.25506.2.99.3.1.1 (hh3cPortalFirstTrapTime) |
N/A |
Timeticks |
1.3.6.1.4.1.25506.2.99.3.1.2 (hh3cPortalServerIP) |
InetAddress |
1.3.6.1.4.1.25506.2.99.2.1.1.3 (hh3cPortalServerPort) |
Integer32 |
Recommended action
To resolve this issue:
1.Use the ping or ping ipv6 command to check whether the portal authentication server is reachable:
- If no, troubleshoot the reachability between the device and the portal authentication server.
- If yes, go to step 2.
2.Check whether the server heartbeat feature is enabled on the portal authentication server. If the heartbeat feature is enabled, make sure the server heartbeat interval configured on the portal authentication server is smaller than the detection timeout configured on the device.
- If no, enable the server heartbeat feature on the portal authentication server and configure the server heartbeat interval as required.
- If yes, go to step 3.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cPortalServerGet
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.99.3.0.2 |
Portal authentication server is reachable. |
Recovery |
Major |
N/A (N/A) |
OFF |
This notification is generated when the device receives portal packets sent by the portal authentication server within the specified detection period.
The device receives portal packets sent by the portal authentication server within the specified detection period.
The server detection feature is disabled for the portal authentication server.
System impact
No negative impact on services.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
OCTET STRING |
N/A |
Timeticks |
InetAddress |
Integer32 |
Recommended action
No action is required.
