17-User Access and Authentication
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R8530Pxx-6W10017-User Access and Authentication
05-HH3C-PORT-SECURITY-MIB
05-HH3C-PORT-SECURITY-MIB 212.32 KB
About this MIB
Use this MIB to configure port security feature settings, obtain user information, and report trap notifications.
MIB file name
hh3c-port-security.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cPortSecurity(26).hh3cPortSecurityMIB(1)
Scalar objects
hh3cSecurePortSecurityControl (1.3.6.1.4.1.25506.2.26.1.1.1)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
enabled(1),
disabled(2)
Enabling status of port security.
As per the MIB.
hh3cSecurePortVlanMembershipList (1.3.6.1.4.1.25506.2.26.1.1.2)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
DisplayString
OCTET STRING (0..255)
VLANs assigned to each port.
As per the MIB.
hh3cSecureRalmDefaultSessionTime (1.3.6.1.4.1.25506.2.26.1.1.4.1)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
Integer32 (1..1000000)
Periodic MAC reauthentication interval.
Not supported.
hh3cSecureRalmHoldoffTime (1.3.6.1.4.1.25506.2.26.1.1.4.2)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
Quiet timer before a blocked (denied) MAC address can be reauthenticated.
Value range: 1 to 3600.
hh3cSecureRalmReauthenticate (1.3.6.1.4.1.25506.2.26.1.1.4.3)
Object (OID)
Access
Value range
Implementation
read-write
MacAddress
OCTET STRING (6)
An immediate reauthentication is performed on the MAC authentication users.
Not supported.
hh3cSecureRalmAuthMode (1.3.6.1.4.1.25506.2.26.1.1.4.4)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
papUsernameAsMacAddress(1),
papUsernameFixed(2)
MAC authentication user account format.
If the value is set to papUsernameAsMacAddress(1), the MAC address of each user is used as both the username and password.
If the value is set to papUsernameFixed(2), the username and password are from the h3cSecureRalmAuthUsername and h3cSecureRalmAuthPassword objects. In this mode, the MAC address of each user can be carried in the Calling-Station-Id attribute of RADIUS packets.
hh3cSecureRalmAuthUsername (1.3.6.1.4.1.25506.2.26.1.1.4.5)
Object (OID)
Access
Value range
Implementation
read-write
DisplayString
OCTET STRING (1..80)
Username.
Length: 1 to 55 characters.
The username cannot contain an at sign (@).
hh3cSecureRalmAuthPassword (1.3.6.1.4.1.25506.2.26.1.1.4.6)
Object (OID)
Access
Value range
Implementation
read-write
DisplayString
OCTET STRING (1..63)
Password.
Supports only the plaintext form.
hh3cSecureRalmAuthDomain (1.3.6.1.4.1.25506.2.26.1.1.4.7)
Object (OID)
Access
Value range
Implementation
read-write
DisplayString
OCTET STRING (1..255)
Domain used for MAC authentication.
As per the MIB.
hh3cSecureRalmAuthOfflineTime (1.3.6.1.4.1.25506.2.26.1.1.4.8)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
Integer32 (60..2147483647)
Authentication offline detection timer.
As per the MIB.
hh3cSecureRalmAuthServerTimeoutTime (1.3.6.1.4.1.25506.2.26.1.1.4.9)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
Integer32 (1..65535)
Timeout timer for the device to wait for a response from the server.
Value range: 100 to 300 seconds.
hh3cSecureMacControl (1.3.6.1.4.1.25506.2.26.1.1.4.10)
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
enabled(1),
disabled(2)
Enabling status of MAC authentication globally.
As per the MIB.
Tabular objects
hh3cSecurePortTable
About this table
Use this table to configure or obtain security attributes on ports.
Support for operations
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cSecurePortMode (1.3.6.1.4.1.25506.2.26.1.2.1.1.1)
read-write
INTEGER
noRestrictions(1),
continuousLearning(2),
autoLearn(3),
secure(4),
userLogin(5),
userLoginSecure(6),
userLoginWithOUI(7),
macAddressWithRadius(8),
macAddressOrUserLoginSecure(9),
macAddressElseUserLoginSecure(10),
userLoginSecureExt(11),
macAddressOrUserLoginSecureExt(12),
macAddressElseUserLoginSecureExt(13),
macAddressAndUserLoginSecure(14),
macAddressAndUserLoginSecureExt(15)
Port security mode.
The continuousLearning(2) and macAddressAndUserLoginSecure(14) modes are not supported.
hh3cSecureNeedToKnowMode (1.3.6.1.4.1.25506.2.26.1.2.1.1.2)
read-write
INTEGER
notAvailable(1),
disabled(2),
needToKnowOnly(3),
needToKnowWithBroadcastsAllowed(4),
needToKnowWithMulticastsAllowed(5),
permanentNeedToKnowOnly(6),
permanentNeedToKnowWithBroadcastsAllowed(7),
permanentNeedToKnowWithMulticastsAllowed(8)
needToKnowAuto(9)
This object specifies the NTK mode for checking outbound frames of a port.
As per the MIB.
hh3cSecureIntrusionAction (1.3.6.1.4.1.25506.2.26.1.2.1.1.3)
read-write
INTEGER
notAvailable(1),
noAction(2),
disablePort(3),
disablePortTemporarily(4),
allowDefaultAccess(5),
blockMacAddress(6)
Intrusion protection action to take when intrusion protection detects illegal frames.
The allowDefaultAccess action is not supported.
hh3cSecureNumberAddresses (1.3.6.1.4.1.25506.2.26.1.2.1.1.4)
read-write
Integer32
Standard MIB values.
Maximum number of secure MAC addresses that the port can learn.
As per the MIB.
hh3cSecureNumberAddressesStored (1.3.6.1.4.1.25506.2.26.1.2.1.1.5)
read-only
INTEGER
Number of MAC addresses that the port has learned.
As per the MIB.
hh3cSecureMaximumAddresses (1.3.6.1.4.1.25506.2.26.1.2.1.1.6)
read-only
INTEGER
Maximum value you can specify as the number of secure MAC addresses.
As per the MIB.
hh3cSecureAddressTable
About this table
Use this table to configure or obtain information about secure MAC addresses.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ifIndex, hh3cSecureAddrMAC, and hh3cSecureAddrVlanID.
Object (OID)
Access
Value range
Implementation
hh3cSecureAddrMAC (1.3.6.1.4.1.25506.2.26.1.2.2.1.1)
MacAddress
MAC address on a port.
Not supported.
hh3cSecureAddrVlanID (1.3.6.1.4.1.25506.2.26.1.2.2.1.2)
read-create
Integer32
Authorization VLAN.
Not supported.
hh3cSecureAddrMACStatus (1.3.6.1.4.1.25506.2.26.1.2.2.1.3)
read-create
INTEGER
addressBlackhole(1),
addressUserConfig(2),
addressDot1xAuth(3),
addressRALM(4)
MAC address attribute.
Not supported.
hh3cSecureAddrRowStatus (1.3.6.1.4.1.25506.2.26.1.2.2.1.4)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
As per the MIB.
hh3cSecureOUITable
About this table
Use this table to configure or obtain Organizationally Unique Identifier (OUI) information.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table index is hh3cSecureOUIIndex.
Object (OID)
Access
Value range
Implementation
hh3cSecureOUIIndex (1.3.6.1.4.1.25506.2.26.1.2.3.1.1)
not-accessible
Integer32
Integer32 (1..1024)
OUI index
1..16
hh3cSecureOUI (1.3.6.1.4.1.25506.2.26.1.2.3.1.2)
read-create
OCTET STRING
OCTET STRING (3)
OUI value.
As per the MIB.
hh3cSecureOUIRowStatus
(1.3.6.1.4.1.25506.2.26.1.2.3.1.3)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
OUI row status.
As per the MIB.
hh3cSecureBindingTable
About this table
Use this table to configure or obtain information about port, IP address, and MAC address binding entries.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table index is hh3cSecureBindingIndex.
Object (OID)
Access
Value range
Implementation
hh3cSecureBindingIndex (1.3.6.1.4.1.25506.2.26.1.2.4.1.1)
not-accessible
Integer32
Index of a binding entry.
Not supported.
hh3cSecureBindingPort (1.3.6.1.4.1.25506.2.26.1.2.4.1.2)
read-create
Integer32
Port index in the binding entry.
Not supported.
hh3cSecureBindingAddrMAC (1.3.6.1.4.1.25506.2.26.1.2.4.1.3)
read-create
MacAddress
MAC address in the binding entry.
Not supported.
hh3cSecureBindingAddrIp (1.3.6.1.4.1.25506.2.26.1.2.4.1.4)
read-create
IpAddress
IP address in the binding entry.
Not supported.
hh3cSecureBindingRowStatus (1.3.6.1.4.1.25506.2.26.1.2.4.1.5)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
Not supported.
hh3cSecureAssignTable
About this table
Use this table to apply or obtain authorization information assigned by the server.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cSecureAssignEnable (1.3.6.1.4.1.25506.2.26.1.2.5.1.1)
read-write
TruthValue
true(1),
false(2)
Whether to apply the authorization attributes received from the server to a port.
As per the MIB.
hh3cSecureVlanAssignment (1.3.6.1.4.1.25506.2.26.1.2.5.1.2)
read-only
OCTET STRING
Authorization VLANs and tag information assigned by the server to the port.
As per the MIB.
Notifications
hh3cSecureAddressLearned
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506. 2.26.1.3.1
A new secure MAC address was learned.
Informational
Warning
N/A (N/A)
OFF
Notification triggers
This notification is generated when a new secure MAC address is learned.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable port-security address-learned command.
OFF
CLI: Use the undo snmp-agent trap enable port-security address-learned command.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.2.2.1.1 (ifIndex)
Port index.
ifIndex
INTEGER
INTEGER (1.. 2147483647)
1.3.6.1.4.1.25506.2.26.1.2.2.1.1 (hh3cSecureAddrMAC)
Learned MAC address on a port.
ifIndex
hh3cSecureAddrMAC
MacAddress
Recommended action
No action is required.
hh3cSecureViolation
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.26.1.3.2
Intrusion protection event occurred.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when a port receives illegal frames whose source MAC address has not been learned by the port or that fail to pass authentication after you enable intrusion protection.
System impact
The system might be attacked by illegal frames if too many intrusion protection events occur.
Status control
ON
CLI: Use the snmp-agent trap enable port-security intrusion command.
OFF
CLI: Use the undo snmp-agent trap enable port-security intrusion command.
Object
OID (object name)
Index
Value range
Port index.
ifIndex
Integer32
Integer32 (1.. 2147483647)
User MAC address.
ifIndex
hh3cSecureAddrMAC
MacAddress
1.3.6.1.2.1.2.2.1.7 (ifAdminStatus)
Link layer status.
ifIndex
INTEGER
up(1) , down(2) , testing(3)
Recommended action
To resolve this issue:
1.Verify that 802.1X authentication, MAC authentication, and secure MAC addresses are configured correctly.
2.Execute the display dot1x, display mac-authentication, and display port-security mac-address security commands in any view to identify whether the number of online users or secure MAC addresses on the port has reached the upper limit.
  - If the number of online users or learned secure MAC addresses on the port has reached the upper limit and the upper limit is too small, change the upper limit.
  - If the numbers of online users and learned secure MAC addresses on the port hasn't reached the upper limit and intrusion protections events occur only occasionally, no action is required.
3.If many intrusion protection events occur, the system might be attacked. In this case, contact Technical Support.
hh3cSecureLoginFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.26.1.3.3
An 802.1X user failed authentication.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when an 802.1X user fails authentication.
System impact
The system might be attacked by many authentication packets if too many notifications are generated.
Status control
ON
CLI: Use the snmp-agent trap enable port-security dot1x-failure command.
OFF
CLI: Use the undo snmp-agent trap enable port-security dot1x-failure command.
Object
OID (object name)
Index
Value range
Port index.
ifIndex
InterfaceIndex
Integer32 (1..2147483647)
User MAC address.
ifIndex
hh3cSecureAddrMAC
MacAddress
1.0.8802.1.1.1.1.2.4.1.9 (dot1xAuthSessionUserName)
Username of an 802.1X authentication user.
SnmpAdminString
OCTET STRING (SIZE (0..255))
Recommended action
1.Verify that 802.1X authentication settings are correct.
2.Execute the dot1x access-user log enable failed-login command to enable logging 802.1X user login failures to identify authentication failure cause. Edit the device or server configuration as needed if an authentication failure is caused by device or server configuration errors, for example:
  - The authentication methods configured for the device and the server are different.
  - The username is not added to the server.
  - The username or password is incorrect.
3.If the system repeatedly generates this notification and the authentication failure log shows that one or multiple 802.1X users continuously failed to pass authentication, the system might be attacked by authentication packets. In this case, contact Technical Support.
hh3cSecureLogon
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.26.1.3.4
An 802.1X user logged on.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when an 802.1X user logs on.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable port-security dot1x-logon command.
OFF
CLI: Use the undo snmp-agent trap enable port-security dot1x-logon command.
Object
OID (object name)
Index
Value range
Port index.
ifIndex
Integer32
User MAC address.
ifIndex
hh3cSecureAddrMAC
MacAddress
SnmpAdminString
OCTET STRING(SIZE (0..255))
1.0.8802.1.1.1.1.2.4.1.6 (dot1xAuthSessionAuthenticMethod)
Authentication method.
INTEGER
remoteAuthServer(1) , localAuthServer(2)
1.3.6.1.4.1.25506.2.26.1.1.2 (hh3cSecurePortVlanMembershipList)
VLAN membership assigned to the port on session activation.
N/A
DisplayString
Recommended action
hh3cSecureLogoff
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.26.1.3.5
An 802.1X user logged off.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when an 802.1X user logs off.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable port-security dot1x-logoff command.
OFF
CLI: Use the undo snmp-agent trap enable port-security dot1x-logoff command.
Object
OID (object name)
Index
Value range
Port index
ifIndex
Integer32
User MAC address.
ifIndex
hh3cSecureAddrMAC
MacAddress
SnmpAdminString
OCTET STRING(SIZE (0.. 255))
1.0.8802.1.1.1.1.2.4.1.8 (dot1xAuthSessionTerminateCause)
802.1X session termination cause.
INTEGER
supplicantLogoff(1) , portFailure(2) , supplicantRestart(3) , reauthFailed(4) , authControlForceUnauth(5)  portReInit(6) , portAdminDisabled(7) , notTerminatedYet(999)
VLAN membership assigned to the port on session termination.
N/A
DisplayString
Recommended action
hh3cSecureRalmLoginFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.26.1.3.6
A MAC authentication user failed authentication.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when a MAC authentication user fails authentication.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable port-security mac-auth-failure command.
OFF
CLI: Use the undo snmp-agent trap enable port-security mac-auth-failure command.
Object
OID (object name)
Index
Value range
Port index.
ifIndex
Integer32
User MAC address.
ifIndex
hh3cSecureAddrMAC
MacAddress
1.3.6.1.4.1.25506.2.26.1.1.4.4 (hh3cSecureRalmAuthMode)
N/A
INTEGER
papUsernameAsMacAddress(1) , papUsernameFixed(2)
1.3.6.1.4.1.25506.2.26.1.1.4.5 (hh3cSecureRalmAuthUsername)
Username of a MAC authentication user.
N/A
DisplayString
Recommended action
1.Verify that MAC authentication settings are correct.
2.Execute the mac-authentication access-user log enable failed-login command to enable logging MAC authentication user login failures to identify authentication failure cause. Edit the device or server configuration as needed if an authentication failure is caused by device or server configuration errors, for example:
3.If the system repeatedly generates this notification and the authentication failure log shows that users from different MAC addresses continuously failed to pass authentication, the system might be attacked by authentication packets. In this case, contact Technical Support.
hh3cSecureRalmLogon
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.26.1.3.7
A MAC authentication user logged on.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when a MAC authentication user logs on.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable port-security mac-auth-logon command.
OFF
CLI: Use the undo snmp-agent trap enable port-security mac-auth-logon command.
Object
OID (object name)
Index
Value range
Port index.
ifIndex
Integer32
User MAC address.
ifIndex
hh3cSecureAddrMAC
MacAddress
N/A
INTEGER
papUsernameAsMacAddress(1)  papUsernameFixed(2)
N/A
DisplayString
N/A
DisplayString
Recommended action
hh3cSecureRalmLogoff
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.26.1.3.8
A MAC authentication user logged off.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when a MAC authentication user logs off.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable port-security mac-auth-logoff command.
OFF
CLI: Use the undo snmp-agent trap enable port-security mac-auth-logoff command.
Object
OID (object name)
Index
Value range
Port index.
ifIndex
Integer32
Integer32 (0..2147483647)
User MAC address.
ifIndex
hh3cSecureAddrMAC
MacAddress
N/A
INTEGER
Username of an MAC authentication user.
N/A
DisplayString
N/A
DisplayString
Recommended action
