- 08-Layer 3 - IP Services
- 01-HH3C-ARP-RATELIMIT-MIB
- 02-HH3C-ARP-SUPPRESSION-MIB
- 03-HH3C-ARP-TRAP-MIB
- 04-HH3C-BPA-MIB
- 05-HH3C-DHCP-SNOOP2-MIB
- 06-HH3C-DHCP4-CLIENT-MIB
- 07-HH3C-DHCP4-MIB
- 08-HH3C-DHCP6-MIB
- 09-HH3C-FIB-MIB
- 10-HH3C-IP-ADDRESS-MIB
- 11-HH3C-IPFW-MIB
- 12-HH3C-IPV6-ADDRESS-MIB
- 13-HH3C-NAT-MIB
- 14-HH3C-ND-TRAP-MIB
- 15-HH3C-SESSION-MIB
- 16-HH3C-TCP-MIB
- 17-HH3C-DNS-MIB
- 18-IP-MIB
- 19-IPV6-ICMP-MIB
- 20-IPV6-MIB
- 21-IPV6-TCP-MIB
- 22-IPV6-UDP-MIB
- 23-TCP-MIB
- 24-UDP-MIB
19-IPV6-ICMP-MIB | 87.80 KB |
IPV6-ICMP-MIB
About this MIB
Use this MIB to manage ICMPv6.
MIB file name
rfc2466-ipv6-icmp.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).ipv6IcmpMIB(56)
Tabular objects
ipv6IfIcmpTable
About this table
Use this table to obtain IPv6 ICMP statistics.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
This table does not contain indexes.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipv6IfIcmpInMsgs (1.3.6.1.2.1.56.1.1.1.1) |
read-only |
Counter32 |
Standard MIB values. |
Total number of ICMP messages received by the interface, including those counted by ipv6IfIcmpInErrors. |
As per the MIB. |
ipv6IfIcmpInErrors (1.3.6.1.2.1.56.1.1.1.2) |
read-only |
Counter32 |
Number of ICMP messages that the interface received and determined as having ICMP-specific errors. |
As per the MIB. |
ipv6IfIcmpInDestUnreachs (1.3.6.1.2.1.56.1.1.1.3) |
read-only |
Counter32 |
Number of ICMP Destination Unreachable messages received by the interface. |
As per the MIB. |
ipv6IfIcmpInAdminProhibs (1.3.6.1.2.1.56.1.1.1.4) |
read-only |
Counter32 |
Number of ICMP destination unreachable/communication administratively prohibited messages received by the interface. |
The value is fixed at 0. |
ipv6IfIcmpInTimeExcds (1.3.6.1.2.1.56.1.1.1.5) |
read-only |
Counter32 |
Number of ICMP Time Exceeded messages received by the interface. |
As per the MIB. |
ipv6IfIcmpInParmProblems (1.3.6.1.2.1.56.1.1.1.6) |
read-only |
Counter32 |
Number of ICMP Parameter Problem messages received by the interface. |
As per the MIB. |
ipv6IfIcmpInPktTooBigs (1.3.6.1.2.1.56.1.1.1.7) |
read-only |
Counter32 |
Number of ICMP Packet Too Big messages received by the interface. |
As per the MIB. |
ipv6IfIcmpInEchos (1.3.6.1.2.1.56.1.1.1.8) |
read-only |
Counter32 |
Number of ICMP Echo (request) messages received by the interface. |
As per the MIB. |
ipv6IfIcmpInEchoReplies (1.3.6.1.2.1.56.1.1.1.9) |
read-only |
Counter32 |
Number of ICMP Echo Reply messages received by the interface. |
As per the MIB. |
ipv6IfIcmpInRouterSolicits (1.3.6.1.2.1.56.1.1.1.10) |
read-only |
Counter32 |
Number of ICMP Router Solicit messages received by the interface. |
As per the MIB. |
ipv6IfIcmpInRouterAdvertisements (1.3.6.1.2.1.56.1.1.1.11) |
read-only |
Counter32 |
Number of ICMP Router Advertisement messages received by the interface. |
As per the MIB. |
ipv6IfIcmpInNeighborSolicits (1.3.6.1.2.1.56.1.1.1.12) |
read-only |
Counter32 |
Number of ICMP Neighbor Solicit messages received by the interface. |
As per the MIB. |
ipv6IfIcmpInNeighborAdvertisements (1.3.6.1.2.1.56.1.1.1.13) |
read-only |
Counter32 |
Number of ICMP Neighbor Advertisement messages received by the interface. |
As per the MIB. |
ipv6IfIcmpInRedirects (1.3.6.1.2.1.56.1.1.1.14) |
read-only |
Counter32 |
Number of Redirect messages received by the interface. |
As per the MIB. |
ipv6IfIcmpInGroupMembQueries (1.3.6.1.2.1.56.1.1.1.15) |
read-only |
Counter32 |
Number of ICMPv6 Group Membership Query messages received by the interface. |
As per the MIB. |
ipv6IfIcmpInGroupMembResponses (1.3.6.1.2.1.56.1.1.1.16) |
read-only |
Counter32 |
Number of ICMPv6 Group Membership Response messages received by the interface. |
As per the MIB. |
ipv6IfIcmpInGroupMembReductions (1.3.6.1.2.1.56.1.1.1.17) |
read-only |
Counter32 |
Number of ICMPv6 Group Membership Reduction messages received by the interface. |
As per the MIB. |
ipv6IfIcmpOutMsgs (1.3.6.1.2.1.56.1.1.1.18) |
read-only |
Counter32 |
Total number of ICMP messages that interface attempted to send. |
As per the MIB. |
ipv6IfIcmpOutErrors (1.3.6.1.2.1.56.1.1.1.19) |
read-only |
Counter32 |
Number of ICMP messages the interface did not send due to problems discovered within ICMP. |
ipv6IfIcmpOutDestUnreachs (1.3.6.1.2.1.56.1.1.1.20) |
read-only |
Counter32 |
Number of ICMP Destination Unreachable messages sent by the interface. |
As per the MIB. |
ipv6IfIcmpOutAdminProhibs (1.3.6.1.2.1.56.1.1.1.21) |
read-only |
Counter32 |
Number of ICMP destination unreachable/communication administratively prohibited messages sent by the interface. |
ipv6IfIcmpOutTimeExcds (1.3.6.1.2.1.56.1.1.1.22) |
read-only |
Counter32 |
Number of ICMP Time Exceeded messages sent by the interface. |
As per the MIB. |
ipv6IfIcmpOutParmProblems (1.3.6.1.2.1.56.1.1.1.23) |
read-only |
Counter32 |
Number of ICMP Parameter Problem messages sent by the interface. |
As per the MIB. |
ipv6IfIcmpOutPktTooBigs (1.3.6.1.2.1.56.1.1.1.24) |
read-only |
Counter32 |
Number of ICMP Packet Too Big messages sent by the interface. |
As per the MIB. |
ipv6IfIcmpOutEchos (1.3.6.1.2.1.56.1.1.1.25) |
read-only |
Counter32 |
Number of ICMP Echo (request) messages sent by the interface. |
As per the MIB. |
ipv6IfIcmpOutEchoReplies (1.3.6.1.2.1.56.1.1.1.26) |
read-only |
Counter32 |
Number of ICMP Echo Reply messages sent by the interface. |
As per the MIB. |
ipv6IfIcmpOutRouterSolicits (1.3.6.1.2.1.56.1.1.1.27) |
read-only |
Counter32 |
Number of ICMP Router Solicitation messages sent by the interface. |
As per the MIB. |
ipv6IfIcmpOutRouterAdvertisements (1.3.6.1.2.1.56.1.1.1.28) |
read-only |
Counter32 |
Number of ICMP Router Advertisement messages sent by the interface. |
As per the MIB. |
ipv6IfIcmpOutNeighborSolicits (1.3.6.1.2.1.56.1.1.1.29) |
read-only |
Counter32 |
Number of ICMP Neighbor Solicitation messages sent by the interface. |
As per the MIB. |
ipv6IfIcmpOutNeighborAdvertisements (1.3.6.1.2.1.56.1.1.1.30) |
read-only |
Counter32 |
Number of ICMP Neighbor Advertisement messages sent by the interface. |
As per the MIB. |
ipv6IfIcmpOutRedirects (1.3.6.1.2.1.56.1.1.1.31) |
read-only |
Counter32 |
Number of Redirect messages sent by the interface. |
As per the MIB. |
ipv6IfIcmpOutGroupMembQueries (1.3.6.1.2.1.56.1.1.1.32) |
read-only |
Counter32 |
Number of ICMPv6 Group Membership Query messages sent by the interface. |
As per the MIB. |
ipv6IfIcmpOutGroupMembResponses (1.3.6.1.2.1.56.1.1.1.33) |
read-only |
Counter32 |
Number of ICMPv6 Group Membership Response messages sent by the interface. |
As per the MIB. |
ipv6IfIcmpOutGroupMembReductions (1.3.6.1.2.1.56.1.1.1.34) |
read-only |
Counter32 |
Number of ICMPv6 Group Membership Reduction messages sent by the interface. |
As per the MIB. |
