07-Layer 2 - WAN Access
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R8530Pxx-6W10007-Layer 2 - WAN Access
04-HH3C-MP-V2-MIB
04-HH3C-MP-V2-MIB 98.60 KB
HH3C-MP-V2-MIB
About this MIB
Use this MIB to configure MP.
MIB file name
hh3c-mp-v2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMultilinkPPPV2(140)
Tabular objects
hh3cMpMultilinkV2Table
About this table
Use this table to obtain the MP link information.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cMpMultilinkDescrV2
(1.3.6.1.4.1.25506.2.140.1.1.1.1)
read-only
DisplayString
OCTET STRING (0..255)
Interface name of the father interface on which child channels are bundled.
As per the MIB.
hh3cMpBundleNameV2
(1.3.6.1.4.1.25506.2.140.1.1.1.2)
read-only
DisplayString
Bundle name of the MP link.
For an MP-group interface, the value is Multilink.
hh3cMpBundledSlotV2
(1.3.6.1.4.1.25506.2.140.1.1.1.3)
read-only
Integer32
Standard MIB values.
Slot on which child channels are bundled.
As per the MIB.
hh3cMpBundledMemberCntV2
(1.3.6.1.4.1.25506.2.140.1.1.1.4)
read-only
Integer32
Number of child channels of the MP link.
As per the MIB.
hh3cMpLostFragmentsV2
(1.3.6.1.4.1.25506.2.140.1.1.1.5)
read-only
Counter32
Number of fragments of the MP link discarded.
As per the MIB.
hh3cMpReorderedPktsV2
(1.3.6.1.4.1.25506.2.140.1.1.1.6)
read-only
Counter32
Number of reordered incoming packets of the MP link
As per the MIB.
hh3cMpUnassignedPktsV2
(1.3.6.1.4.1.25506.2.140.1.1.1.7)
read-only
Counter32
Number of received packets of the MP link waiting for reordering.
As per the MIB.
hh3cMpInterleavedPktsV2
(1.3.6.1.4.1.25506.2.140.1.1.1.8)
read-only
Counter32
Number of received interleaved packets of the MP link.
As per the MIB.
hh3cMpRcvdSequenceV2
(1.3.6.1.4.1.25506.2.140.1.1.1.9)
read-only
Integer32
Sequence number for the MP link to receive.
As per the MIB.
hh3cMpSentSequenceV2
(1.3.6.1.4.1.25506.2.140.1.1.1.10)
read-only
Integer32
Sequence number for the MP link to send.
As per the MIB.
hh3cMpMemberlinkV2Table
About this table
Use this table to configure the child channels of an MP link.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ifIndex and hh3cMpMemberlinkSeqNumberV2.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.140.1.2.1.1)
read-only
Integer32
Sequence number of a child channel of the MP link.
As per the MIB.
hh3cMpMemberlinkIfIndexV2
(1.3.6.1.4.1.25506.2.140.1.2.1.2)
read-only
Integer32
Interface index of a child channel of the MP link.
As per the MIB.
hh3cMpMemberlinkDescrV2
(1.3.6.1.4.1.25506.2.140.1.2.1.3)
read-only
DisplayString
Interface name of a child channel of the MP link.
As per the MIB.
hh3cMpMemberlinkMpStatusV2
(1.3.6.1.4.1.25506.2.140.1.2.1.4)
read-only
INTEGER
active(1)
inactive(2)
State of a child channel of the MP link.
As per the MIB.
Notifications
hh3cMpRxLossPktAlarm
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.140.1.4.0.1
Incoming packet loss rate exceeding alarm
Error
Warning
1.3.6.1.4.1.25506.2.140.1.4.0.2 (hh3cMpRxLossPktAlarmResume)
OFF
Notification triggers
The notification is generated when the incoming packet loss rate on an MP group exceeds the user-configured threshold.
Possible reasons are:
Signal quality degrades on members in the MP group.
Both large packets and small packets exist on the MP group, and fragmentation is disabled on the MP group.
System impact
Packet loss occurs on the MP group, and the service performance is affected.
Status control
ON
CLI: snmp-agent trap enable ppp mp
OFF
CLI: undo snmp-agent trap enable ppp mp
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.140.1.3.1 (hh3cMpRxLossAlarmIfName)
Name of the interface where packet loss occurs.
N/A
DisplayString
SIZE(1..31)
1.3.6.1.4.1.25506.2.140.1.3.2 (hh3cMpRxLossCurValueString)
Current packet loss rate.
N/A
DisplayString
SIZE(1..31)
1.3.6.1.4.1.25506.2.140.1.3.3 (hh3cMpRxLossAlarmValueString)
Alarm threshold.
N/A
DisplayString
SIZE(1..31)
1.3.6.1.4.1.25506.2.140.1.3.4 (hh3cMpRxLossResumeValueString)
Alarm recovery threshold.
N/A
DisplayString
SIZE(1..31)
Recommended action
1.Verify that the configuration is correct.
2.Add sublinks.
Basic information
OID
Event
Severity
Default status
Incoming packet loss rate alarm recovery
Recovery
Warning
N/A (N/A)
OFF
The notification is generated when the incoming packet loss rate on the MP group exceeds the user-configured threshold and then drops below the threshold.
The incoming packet loss rate on the MP group drops below the user-configured threshold.
System impact
The incoming packet loss rate on the MP group drops below the user-configured threshold, and then the performance improves.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
DisplayString
SIZE(1..31)
N/A
DisplayString
SIZE(1..31)
Alarm threshold.
N/A
DisplayString
SIZE(1..31)
N/A
DisplayString
SIZE(1..31)
Recommended action
No action is required.
