07-Layer 2 - WAN Access
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R8530Pxx-6W10007-Layer 2 - WAN Access
01-HH3C-BRAS-ACCESS-MIB
01-HH3C-BRAS-ACCESS-MIB 206.66 KB
About this MIB
Use HH3C-BRAS-ACCESS-MIB to obtain the BRAS access user information and detect the online user count alarms through traps.
MIB file name
hh3c-bras-access.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cBrasAcc(200)
Scalar objects
hh3cBrasAccTotalUserNum
(1.3.6.1.4.1.25506.2.200.1.1)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Standard MIB values.
Total number of BRAS users accessing the device.
As per the MIB.
hh3cBrasAccTotalPPPoEUserNum
(1.3.6.1.4.1.25506.2.200.1.2)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Total number of PPPoE users accessing the device.
As per the MIB.
hh3cBrasAccTotalIPoEUserNum
(1.3.6.1.4.1.25506.2.200.1.3)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Total number of IPoE users accessing the device.
As per the MIB.
hh3cBrasAccTotalLNSUserNum
 (1.3.6.1.4.1.25506.2.200.1.4)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Total number of LNS users accessing the device.
As per the MIB.
hh3cBrasAccTotalLACUserNum
 (1.3.6.1.4.1.25506.2.200.1.5)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Total number of LAC users accessing the device.
As per the MIB.
hh3cBrasAccTotalIPv4UserNum
(1.3.6.1.4.1.25506.2.200.1.6)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Total number of single-stack IPv4 BRAS users accessing the device.
As per the MIB.
hh3cBrasAccTotalIPv6UserNum
(1.3.6.1.4.1.25506.2.200.1.7)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Total number of single-stack IPv6 BRAS users accessing the device.
As per the MIB.
hh3cBrasAccTotalDSUserNum
(1.3.6.1.4.1.25506.2.200.1.8)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Total number of dual-stack BRAS users accessing the device.
As per the MIB.
hh3cBrasAccCUTrapUPID
(1.3.6.1.4.1.25506.2.200.5.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
Integer32
Integer32(1024..2047)
UP ID value.
As per the MIB.
hh3cBrasAccCUTrapSlotID
(1.3.6.1.4.1.25506.2.200.5.2)
Object (OID)
Access
Value range
Implementation
Integer32
Integer32(1..255)
Slot number of a card.
As per the MIB.
hh3cBrasAccCUTrapThreshold
(1.3.6.1.4.1.25506.2.200.5.3)
Object (OID)
Access
Value range
Implementation
Integer32
Integer32 (0..100)
User count alarm threshold.
As per the MIB.
hh3cBrasAccOnlineTrapType
(1.3.6.1.4.1.25506.2.200.7.1)
Object (OID)
Access
Value range
Implementation
Integer32
all(1)
ipoe(2)
ppp(3)
l2tpv2(4)
User type.
As per the MIB.
hh3cBrasAccOnlineTrapSlot
(1.3.6.1.4.1.25506.2.200.7.2)
Object (OID)
Access
Value range
Implementation
Integer32
Slot number of the BRAS-VM.
As per the MIB.
hh3cBrasAccOnlineTrapThreshold
(1.3.6.1.4.1.25506.2.200.7.3)
Object (OID)
Access
Value range
Implementation
Integer32
Integer32 (0..100)
As per the MIB.
Tabular objects
hh3cBrasAccUPStatTable
About this table
Use this table to obtain the number of BRAS access users on a UP on a CUPS network.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cBrasAccUPID.
Object (OID)
Access
Value range
Implementation
hh3cBrasAccUPID (1.3.6.1.4.1.25506.2.200.2.1.1)
not-accessible
Integer32
UP ID.
As per the MIB.
hh3cBrasAccUPUserNum (1.3.6.1.4.1.25506.2.200.2.1.2)
read-only
Integer32
Total number of BRAS users accessing the UP.
As per the MIB.
hh3cBrasAccUPPPPoEUserNum (1.3.6.1.4.1.25506.2.200.2.1.3)
read-only
Integer32
Total number of PPPoE users on the UP.
As per the MIB.
hh3cBrasAccUPIPoEUserNum (1.3.6.1.4.1.25506.2.200.2.1.4)
read-only
Integer32
Total number of IPoE users on the UP.
As per the MIB.
hh3cBrasAccUPLNSUserNum (1.3.6.1.4.1.25506.2.200.2.1.5)
read-only
Integer32
Total number of LNS users on the UP.
As per the MIB.
hh3cBrasAccUPLACUserNum (1.3.6.1.4.1.25506.2.200.2.1.6)
read-only
Integer32
Total number of LAC users on the UP.
As per the MIB.
hh3cBrasAccUPIPv4UserNum (1.3.6.1.4.1.25506.2.200.2.1.7)
read-only
Integer32
Total number of single-stack IPv4 BRAS users on the UP.
As per the MIB.
hh3cBrasAccUPIPv6UserNum (1.3.6.1.4.1.25506.2.200.2.1.8)
read-only
Integer32
Total number of single-stack IPv6 BRAS users on the UP.
As per the MIB.
hh3cBrasAccUPDSUserNum (1.3.6.1.4.1.25506.2.200.2.1.9)
read-only
Integer32
Total number of dual-stack BRAS users on the UP.
As per the MIB.
hh3cBrasAccIfStatTable
About this table
Use this table to obtain the number of BRAS access users on an interface.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cBrasAccIfName.
Object (OID)
Access
Value range
Implementation
hh3cBrasAccIfName
(1.3.6.1.4.1.25506.2.200.4.1.1)
read-only
DisplayString (1..31)
For the Get operation, you must specify a valid interface name.
For the GetNext operation, if you specify an interface name, make sure the interface name is invalid.
UP ID.
As per the MIB.
hh3cBrasAccIfUserNum
(1.3.6.1.4.1.25506.2.200. 4.1.2)
read-only
Integer32
Total number of BRAS access users on the UP.
As per the MIB.
hh3cBrasAccIfPPPoEUserNum
(1.3.6.1.4.1.25506.2.200. 4.1.3)
read-only
Integer32
As per the MIB.
hh3cBrasAccIfIPoEUserNum
(1.3.6.1.4.1.25506.2.200. 4.1.4)
read-only
Integer32
As per the MIB.
hh3cBrasAccIfLNSUserNum
(1.3.6.1.4.1.25506.2.200. 4.1.5)
read-only
Integer32
As per the MIB.
hh3cBrasAccIfLACUserNum
(1.3.6.1.4.1.25506.2.200. 4.1.6)
read-only
Integer32
As per the MIB.
hh3cBrasAccIfIPv4UserNum
(1.3.6.1.4.1.25506.2.200. 4.1.7)
read-only
Integer32
As per the MIB.
hh3cBrasAccIfIPv6UserNum
(1.3.6.1.4.1.25506.2.200. 4.1.8)
read-only
Integer32
As per the MIB.
hh3cBrasAccIfDSUserNum
(1.3.6.1.4.1.25506.2.200. 4.1.9)
read-only
Integer32
As per the MIB.
Notifications
hh3cBrasAccCUUPWarning
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.200.6.0.1
UP user count exceeding threshold alarm
Error
Warning
1.3.6.1.4.1.25506.2.200.6.0.2 (hh3cBrasAccCUUPWarningResume)
ON
Notification triggers
The notification is generated when the total number of BRAS access users on a UP exceeds the user-configured threshold.
Possible reasons are:
The upper threshold configured is too small.
Users come online, and the number of users on the UP exceeds the maximum number of user resources supported by the UP.
System impact
The performance pressure on the UP might increase, and the services for online BRAS users might be affected.
The number of online BRAS users on the UP might exceed the device capability, and the subsequent BRAS users might fail to come online.
Status control
ON
CLI: snmp-agent trap enable up-session-threshold
OFF
CLI: undo snmp-agent trap enable up-session-threshold
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.200.5.1 (hh3cBrasAccCUTrapUPID)
UP ID
None
Integer32
1.3.6.1.4.1.25506.2.200.5.3 (hh3cBrasAccCUTrapThreshold)
None
Integer32
Integer32 (0..100)
Recommended action
To resolve this issue:
1.Execute the display current-configuration command in any view on the CP to check the access-user up-session-threshold command, and identify whether the upper threshold configured is proper.
  - If the upper threshold configured is too small, proceed with step 2.
  - If the upper threshold configured is proper, proceed with step 3.
2.Use the access-user up-session-threshold command in system view on the CP to modify the upper threshold for the user resources.
3.Execute the display access-user up-id command in any view to view the number of users on the UP.
  - If the number of users reaches or approaches the upper threshold configured, add interface modules.
  - If the number of users does not approach the upper threshold configured, proceed with step 4.
4.Collect alarm information, log information, and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
UP user count recovery alarm
Recovery
Warning
ON
The notification is generated when the total number of BRAS access users on a UP drops below the user-configured threshold.
Users go offline, and the number of users on the UP drops below the upper threshold.
System impact
The performance pressure on the UP recovers, and the subsequent BRAS users can normally come online.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
UP ID
None
Integer32
None
Integer32
Integer32 (0..100)
Recommended action
No action is required.
hh3cBrasAccCUSlotWarning
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.200.6.0.3
UP card user count exceeding threshold alarm
Error
Major
1.3.6.1.4.1.25506.2.200.6.0.4 (hh3cBrasAccCUSlotWarningResume)
ON
The notification is generated when the total number of BRAS access users on a card in a UP exceeds the user-configured threshold.
Users come online, and the number of users on a card in the UP exceeds the maximum number of user resources supported by the UP card.
System impact
The performance pressure on the card in the UP might increase, and the services for online BRAS users might be affected.
The number of online BRAS users on the card in the UP might exceed the device capability, and the subsequent BRAS users might fail to come online.
Status control
ON
CLI: snmp-agent trap enable slot-user-warning-threshold
OFF
CLI: undo snmp-agent trap enable slot-user-warning-threshold
Object
OID (object name)
Index
Value range
UP ID
None
Integer32
1.3.6.1.4.1.25506.2.200.5.2 (hh3cBrasAccCUTrapSlotID)
None
Integer32
Integer32(1..255)
None
Integer32
Integer32 (0..100)
Recommended action
1.Execute the display current-configuration command in any view on the CP to check the slot-user-warning-threshold command, and identify whether the upper threshold configured is proper.
2.Execute the slot-user-warning-threshold command in system view on the CP to modify the upper threshold for the user resources.
3.Execute the display access-user user-plane command in any view on the UP to view the number of users on the specified interface module in the UP.
  - If the number of users reaches or approaches the upper threshold configured, add subcards.
Basic information
OID
Event
Severity
Default status
UP card user count recovery alarm
Recovery
Major
ON
Users go offline, and the number of users on the card in the UP drops below the upper threshold.
System impact
The performance pressure on the card in a UP recovers, and the subsequent BRAS users can normally come online.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
UP ID
None
Integer32
1.3.6.1.4.1.25506.2.200.5. 2 (hh3cBrasAccCUTrapSlotID)
None
Integer32
Integer32(1..255)
None
Integer32
Integer32 (0..100)
Recommended action
hh3cBrasAccOnlineULimitResume
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.200.8.0.2
User count recovery from upper threshold alarm
Recovery
Major
ON
The notification is generated when the total number of BRAS access users drops below the user-configured upper threshold.
Users go offline, and the number of users drops below the device-level upper threshold for the number of access users.
System impact
The number of online BRAS users decreases and does not exceed the device capability. The subsequent BRAS users can come online successfully.
Status control
ON
CLI: snmp-agent trap enable user-warning-threshold
OFF
CLI: undo snmp-agent trap enable user-warning-threshold
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.200.7.1 (hh3cBrasAccOnlineTrapType)
User type
None
Integer32
all(1), ipoe(2), ppp(3), l2tpv2(4)
1.3.6.1.4.1.25506.2.200.7.2 (hh3cBrasAccOnlineTrapSlot)
Slot number of a BRAS-VM
None
Integer32
1.3.6.1.4.1.25506.2.200.7.3 (hh3cBrasAccOnlineTrapThreshold)
None
Integer32
Integer32 (0..100)
Recommended action
hh3cBrasAccOnlineLLimitAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.200.8.0.3
User count dropping below lower threshold alarm
Error
Warning
1.3.6.1.4.1.25506.2.200.8.0.4 (hh3cBrasAccOnlineLLimitResume)
ON
The notification is generated when the total number of BRAS access users drops below the lower threshold.
The device-level lower threshold for the number of users is too small.
Users go offline, and the number of users on the device reaches the lower threshold.
System impact
A large number of users might go offline because of abnormal reasons. Identify whether a large number of users go offline abnormally.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
User type
None
Integer32
None
Integer32
None
Integer32
Integer32 (0..100)
Recommended action
1.Execute the display access-user command to view the total number of access users.
2.Identify whether a large number of access users go offline abnormally.
Basic information
OID
Event
Severity
Default status
User count recovery from lower threshold alarm
Recovery
Warning
ON
The notification is generated when the total number of BRAS access users exceeds the user-configured lower threshold.
Users come online, and the number of users on the device exceeds the lower threshold.
System impact
The number of BRAS access users on the device meets the expectation.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
User type.
None
Integer32
Slot number of a BRAS-VM.
None
Integer32
None
Integer32
Integer32 (0..100)
Recommended action
hh3cBrasAccOnlineFailEvent
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.200.8.0.5
User online failure count within certain period exceeding threshold alarm
Informational
Warning
ON
This notification is generated when the number of user online failures within a certain period exceeds the threshold.
The threshold for the number of user online failures within a certain period is too small.
The number of user online failures within a certain period reaches the alarm threshold.
System impact
Check the user online failure reasons. Identify whether the users failing to come online are normal users or abnormal users.
Identify whether there are abnormal attacks.
Identify whether normal users fail to come online multiple times, and resolve the issue in advance.
Status control
ON
CLI: access-user online-fail-warning
OFF
CLI: undo access-user online-fail-warning
Object
OID (object name)
Index
Value range
None
Integer32
User online failure ratio alarm threshold
None
Integer32
Integer32 (0..100)
Recommended action
1.Execute the display aaa online-fail-record command in any view on the device to view user online failure records. Analyze the user online failure reasons according to the user online failure records, and resolve the issue in advance.
2.If you cannot obtain the user online failure reasons according to the user online failure records, contact H3C Support.
