17-User Access and Authentication
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesMIB CompanionH3C SR8800-X Routers MIB Reference-R8530Pxx-6W10017-User Access and Authentication
11-IEEE8021X-PAE-MIB
11-IEEE8021X-PAE-MIB 94.93 KB
IEEE8021X-PAE-MIB
About this MIB
This MIB manages the Port Access Entity (PAE) functions of IEEE 802.1X.
MIB file name
ieee8021x-pae.mib
Root object
iso(1).std(0).iso8802(8802).ieee802dot1(1).ieee802dot1mibs(1).ieee8021XPaeMIB(15)
Tabular objects
ieee8021XPaePortTable
About this table
Use this table to configure or obtain system level information about each port supported by 802.1X PAE.
Support for operations
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table index is ieee8021XPaePortNumber.
Object (OID)
Access
Value range
Implementation
ieee8021XPaePortNumber  (1.3.111.2.802.1.1.15.1.1.5.1.1)
not-accessible
InterfaceIndex
Integer32 (1..2147483647)
Port number.
As per the MIB.
ieee8021XPaePortCapabilities (1.3.111.2.802.1.1.15.1.1.5.1.7)
read-only
BITS
suppImplemented(0),
authImplemented(1),
mkaImplemented(2),
macsecImplemented(3),
announcementsImplemented(4),
listenerImplemented(5),
virtualPortsImplemented(6)
Capabilities of the PAE port.
As per the MIB.
ieee8021XKayMkaTable
About this table
Use this table to manage or obtain information about each port supported by the Key Agreement Entity (KaY), a PAE entity responsible for MKA.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
ieee8021XKayMkaActive  (1.3.111.2.802.1.1.15.1.6.1.1.1)
read-only
TruthValue
true(1),
false(2)
Whether an MKA active actor exists to transmit MKPDUs.
As per the MIB.
ieee8021XKayMkaAuthenticated   (1.3.111.2.802.1.1.15.1.6.1.1.2)
read-only
TruthValue
true(1),
false(2)
Whether the principal actor has determined that Controlled Port communication should proceed with MACsec.
As per the MIB.
ieee8021XKayMkaSecured (1.3.111.2.802.1.1.15.1.6.1.1.3)
read-only
TruthValue
true(1),
false(2)
Whether the principal actor has determined that communication should use MACsec.
As per the MIB.
ieee8021XKayMkaFailed  (1.3.111.2.802.1.1.15.1.6.1.1.4)
read-only
TruthValue
true(1),
false(2)
Whether the MKA lifetime has elapsed.
As per the MIB.
ieee8021XKayMkaActorSCI (1.3.111.2.802.1.1.15.1.6.1.1.5)
read-only
SecySCI
OCTET STRING (0..65535)
Secure channel identifier (SCI) assigned by the system to the port.
As per the MIB.
ieee8021XKayMkaActorsPriority  (1.3.111.2.802.1.1.15.1.6.1.1.6)
read-write
Ieee8021XMkaKeyServerPriority
OCTET STRING (SIZE (1))
Key server priority for all MKA actors on the port.
As per the MIB.
ieee8021XKayMkaKeyServerPriority (1.3.111.2.802.1.1.15.1.6.1.1.7)
read-only
Priority of the elected key server.
Not supported.
ieee8021XKayMkaKeyServerSCI (1.3.111.2.802.1.1.15.1.6.1.1.8)
read-only
SecySCI
Key server SCI for the MKA principal actor.
As per the MIB.
ieee8021XKayAllowedJoinGroup (1.3.111.2.802.1.1.15.1.6.1.1.9)
read-only
TruthValue
true(1),
false(2)
Whether the KaY accepts group connectivity association keys (CAKs) distributed by the MKA protocol.
Not supported.
ieee8021XKayAllowedFormGroup (1.3.111.2.802.1.1.15.1.6.1.1.10)
read-only
TruthValue
true(1),
false(2)
Whether the KaY attempts to use point-to-point connectivity associations (CAs) to distribute a group CAK if the KaY's MKA principal actor is the key server for all the point-to-point CAs.
Not supported.
ieee8021XKayCreateNewGroup (1.3.111.2.802.1.1.15.1.6.1.1.11)
read-write
TruthValue
true(1),
false(2)
Whether the KaY will distribute a new group CAK if the KaY's MKA principal actor is the key server for all the point-to-point CAs.
Not supported.
ieee8021XKayMacSecCapability (1.3.111.2.802.1.1.15.1.6.1.1.12)
read-only
INTEGER
noMACsec(0),
macSecCapability1(1),
macSecCapability2(2),
macSecCapability3(3)
Whether to implement MACsec and the MACsec capabilities.
As per the MIB.
ieee8021XKayMacSecDesired  (1.3.111.2.802.1.1.15.1.6.1.1.13)
read-write
TruthValue
true(1),
false(2)
Whether the MKA participants desire the use of MACsec to protect frames with this KaY.
As per the MIB.
ieee8021XKayMacSecProtect (1.3.111.2.802.1.1.15.1.6.1.1.14)
read-only
TruthValue
true(1),
false(2)
Status of the MACsec protection function for this KaY.
Not supported.
ieee8021XKayMacSecReplayProtect (1.3.111.2.802.1.1.15.1.6.1.1.15)
read-only
TruthValue
true(1),
false(2)
Status of the MACsec replay protection function for this KaY.
Not supported.
ieee8021XKayMacSecValidate  (1.3.111.2.802.1.1.15.1.6.1.1.16)
read-only
TruthValue
true(1),
false(2)
Status of the MACsec validation function for this KaY.
Not supported.
ieee8021XKayMacSecConfidentialityOffset (1.3.111.2.802.1.1.15.1.6.1.1.17)
read-write
Integer32
Integer32 (0 | 30 | 50)
Confidentiality protection offset options for the selected cipher suite in the MACsec.
Not supported.
ieee8021XKayMkaTxKN  (1.3.111.2.802.1.1.15.1.6.1.1.18)
read-only
Ieee8021XMkaKN
Unsigned32 (1..2147483648)
Key number assigned by the key server to the SAK currently being used for transmission.
Not supported.
ieee8021XKayMkaTxAN  (1.3.111.2.802.1.1.15.1.6.1.1.19)
read-only
RowPointer
Standard MIB values.
SC AN assigned by the key server for use with the key number for transmission.
Not supported.
ieee8021XKayMkaRxKN  (1.3.111.2.802.1.1.15.1.6.1.1.20)
read-only
Ieee8021XMkaKN
Key number assigned by the key server to the oldest secure association key (SAK) currently being used for reception.
Not supported.
ieee8021XKayMkaRxAN   (1.3.111.2.802.1.1.15.1.6.1.1.21)
read-only
RowPointer
Secure channel (SC) SA number (AN) assigned by the key server for use with the key number for reception.
Not supported.
ieee8021XKayMkaPeerListTable
About this table
Use this table to obtain information about the MKA peer list for a KaY.
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
ieee8021XKayMkaPeerListMI (1.3.111.2.802.1.1.15.1.6.3.1.1)
not-accessible
Ieee8021XMkaMI
OCTET STRING (SIZE (12))
MI information of a peer entry in the peer list of this active participant in the MKA protocol.
As per the MIB.
ieee8021XKayMkaPeerListMN    (1.3.111.2.802.1.1.15.1.6.3.1.2)
read-only
Ieee8021XMkaMN
Latest MN information of the peer entry in the peer list of this active participant in the MKA protocol.
As per the MIB.
ieee8021XKayMkaPeerListType    (1.3.111.2.802.1.1.15.1.6.3.1.3)
read-only
INTEGER
livePeerList(1),
potentialPeerList(2)
Type of the peer entry in the peer list of this active participant in MKA protocol.
As per the MIB.
ieee8021XKayMkaPeerListSCI      (1.3.111.2.802.1.1.15.1.6.3.1.4)
read-only
SecySCI
SCI information of the peer entry in the peer list of this active participant in the MKA protocol.
As per the MIB.
