17-User Access and Authentication
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesMIB CompanionH3C SR8800-X Routers MIB Reference-R8530Pxx-6W10017-User Access and Authentication
09-IEEE8021-PAE-MIB
09-IEEE8021-PAE-MIB 111.43 KB
IEEE8021-PAE-MIB
About this MIB
Use this MIB to manage 802.1X basic settings.
MIB file name
ieee8021-pae.mib
Root object
iso(1).std(0).iso8802(8802).ieee802dot1(1).ieee802dot1mibs(1).ieee8021paeMIB(1)
Scalar objects
dot1xPaeSystemAuthControl (1.0.8802.1.1.1.1.1.1)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
enabled(1),
disabled(2)
Enabling status of 802.1X
As per the MIB.
Tabular objects
dot1xPaePortTable
About this table
Use this table to configure or obtain information about 802.1X parameters on ports.
Support for operations
CreateSupported
Edit/ModifySupported
DeleteSupported
ReadSupported
Columns
The table index is dot1xPaePortNumber.
Object (OID)
Access
Value range
Implementation
dot1xPaePortNumber (1.0.8802.1.1.1.1.1.2.1.1)
not-accessible
InterfaceIndex
Integer32 (1..2147483647)
Port number.
As per the MIB.
dot1xPaePortProtocolVersion (1.0.8802.1.1.1.1.1.2.1.2)
read-only
Unsigned32
Standard MIB values.
Protocol version.
As per the MIB.
dot1xPaePortCapabilities (1.0.8802.1.1.1.1.1.2.1.3)
read-only
BITS
dot1xPaePortAuthCapable(0),
dot1xPaePortSuppCapable(1)
PAE capabilities supported by the port.
As per the MIB.
dot1xPaePortInitialize (1.0.8802.1.1.1.1.1.2.1.4)
read-write
TruthValue
true(1),
false(2)
Port initialization control.
Not supported
dot1xPaePortReauthenticate (1.0.8802.1.1.1.1.1.2.1.5)
read-write
TruthValue
true(1),
false(2)
Port reauthentication control.
As per the MIB.
dot1xAuthConfigTable
About this table
Use this table to configure or obtain information about 802.1X authentication parameters.
CreateNot supported
DeleteSupported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
dot1xAuthPaeState (1.0.8802.1.1.1.1.2.1.1.1)
read-only
INTEGER
initialize(1),
disconnected(2),
connecting(3),
authenticating(4),
authenticated(5),
aborting(6),
held(7),
forceAuth(8),
forceUnauth(9)
Current value of the Authenticator PAE state machine.
Supports only initialize(1), forceAuth(8), and forceUnauth(9).
dot1xAuthBackendAuthState (1.0.8802.1.1.1.1.2.1.1.2)
read-only
INTEGER
request(1),
response(2),
success(3),
fail(4),
timeout(5) ,
idle(6),
initialize(7)
Current state of the Backend Authentication state machine.
As per the MIB.
dot1xAuthAdminControlledDirections (1.0.8802.1.1.1.1.2.1.1.3)
read-write
INTEGER
both(0),
in(1)
Current value of the administrative controlled directions parameter for the port.
Supports only the read operation.
dot1xAuthOperControlledDirections (1.0.8802.1.1.1.1.2.1.1.4)
read-only
INTEGER
both(0),
in(1)
Current value of the operational controlled directions parameter for the port.
As per the MIB.
dot1xAuthAuthControlledPortStatus (1.0.8802.1.1.1.1.2.1.1.5)
read-only
INTEGER
authorized(1),
unauthorized(2)
Current value of the controlled port status parameter for the port.
Supports only for port-based access control.
dot1xAuthAuthControlledPortControl (1.0.8802.1.1.1.1.2.1.1.6)
read-write
INTEGER
unauthforce(1),
auto(2),
authforce(3)
Current value of the controlled port control parameter for the port.
As per the MIB.
dot1xAuthQuietPeriod (1.0.8802.1.1.1.1.2.1.1.7)
read-write
Unsigned32
Quiet period.
The value is fixed at 0.
To modify the quiet period, use the private MIB of 802.1X.
dot1xAuthTxPeriod (1.0.8802.1.1.1.1.2.1.1.8)
read-write
Unsigned32
Username request timeout timer.
To modify the username request timeout timer, use the private MIB of 802.1X.
dot1xAuthSuppTimeout (1.0.8802.1.1.1.1.2.1.1.9)
read-write
Unsigned32
Client timeout timer.
To modify the client timeout timer, use the private MIB of 802.1X.
dot1xAuthServerTimeout (1.0.8802.1.1.1.1.2.1.1.10)
read-write
Unsigned32
Server timeout timer.
To modify the server timeout timer, use the private MIB of 802.1X.
dot1xAuthMaxReq (1.0.8802.1.1.1.1.2.1.1.11)
read-write
Unsigned32
Maximum number of attempts for sending an authentication request to a client.
To modify the value, use the private MIB of 802.1X.
dot1xAuthReAuthPeriod (1.0.8802.1.1.1.1.2.1.1.12)
read-write
Unsigned32
Reauthentication interval.
Value range: 0 and 60 to 7200, in seconds.
Default: 0 seconds.
dot1xAuthReAuthEnabled (1.0.8802.1.1.1.1.2.1.1.13)
read-write
TruthValue
true(1),
false(2)
Enabling status of periodic reauthentication.
As per the MIB.
dot1xAuthKeyTxEnabled (1.0.8802.1.1.1.1.2.1.1.14)
read-write
TruthValue
true(1),
false(2)
Enabling status of key transmission.
dot1xAuthStatsTable
About this table
This table contains 802.1X authentication statistics.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
dot1xAuthEapolFramesRx (1.0.8802.1.1.1.1.2.2.1.1)
read-only
Counter32
Number of received EAPOL frames.
As per the MIB.
dot1xAuthEapolFramesTx (1.0.8802.1.1.1.1.2.2.1.2)
read-only
Counter32
Number of sent EAPOL frames.
As per the MIB.
dot1xAuthEapolStartFramesRx (1.0.8802.1.1.1.1.2.2.1.3)
read-only
Counter32
Number of received EAPOL-Start frames.
As per the MIB.
dot1xAuthEapolLogoffFramesRx (1.0.8802.1.1.1.1.2.2.1.4)
read-only
Counter32
Number of received EAPOL-LogOff frames.
As per the MIB.
dot1xAuthEapolRespIdFramesRx (1.0.8802.1.1.1.1.2.2.1.5)
read-only
Counter32
Number of received EAP-Response/Identity frames.
As per the MIB.
dot1xAuthEapolRespFramesRx (1.0.8802.1.1.1.1.2.2.1.6)
read-only
Counter32
Number of received EAPOL-Response frames.
As per the MIB.
dot1xAuthEapolReqIdFramesTx (1.0.8802.1.1.1.1.2.2.1.7)
read-only
Counter32
Number of sent EAP-Request/Identity frames.
As per the MIB.
dot1xAuthEapolReqFramesTx (1.0.8802.1.1.1.1.2.2.1.8)
read-only
Counter32
Number of sent EAPOL-Request frames.
As per the MIB.
dot1xAuthInvalidEapolFramesRx (1.0.8802.1.1.1.1.2.2.1.9)
read-only
Counter32
Number of received invalid EAPOL frames.
As per the MIB.
dot1xAuthEapLengthErrorFramesRx (1.0.8802.1.1.1.1.2.2.1.10)
read-only
Counter32
Number of received frames with invalid length.
Not supported.
dot1xAuthLastEapolFrameVersion (1.0.8802.1.1.1.1.2.2.1.11)
read-only
Unsigned32
Protocol version number carried in the most recently received EAPOL frame.
As per the MIB.
dot1xAuthLastEapolFrameSource (1.0.8802.1.1.1.1.2.2.1.12)
read-only
MacAddress
OCTET STRING (6)
Source MAC address carried in the most recently received EAPOL frame.
Not supported.
dot1xAuthSessionStatsTable
About this table
Use this table to obtain 802.1X authentication session statistics.
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is dot1xAuthSessionUserName.
Object (OID)
Access
Value range
Implementation
dot1xAuthSessionOctetsRx (1.0.8802.1.1.1.1.2.4.1.1)
read-only
Counter64
Number of received octets.
As per the MIB.
dot1xAuthSessionOctetsTx (1.0.8802.1.1.1.1.2.4.1.2)
read-only
Counter64
Number of sent octets.
As per the MIB.
dot1xAuthSessionFramesRx (1.0.8802.1.1.1.1.2.4.1.3)
read-only
Counter64
Number of received frames.
As per the MIB.
dot1xAuthSessionFramesTx (1.0.8802.1.1.1.1.2.4.1.4)
read-only
Counter64
Number of sent frames.
As per the MIB.
dot1xAuthSessionId (1.0.8802.1.1.1.1.2.4.1.5)
read-only
SnmpAdminString
OCTET STRING (0..65535)
Session ID.
As per the MIB.
dot1xAuthSessionAuthenticMethod (1.0.8802.1.1.1.1.2.4.1.6)
read-only
INTEGER
remoteAuthServer(1),
localAuthServer(2)
Authentication method.
Not supported
dot1xAuthSessionTime (1.0.8802.1.1.1.1.2.4.1.7)
read-only
TimeTicks
Session duration.
As per the MIB.
dot1xAuthSessionTerminateCause (1.0.8802.1.1.1.1.2.4.1.8)
read-only
INTEGER
supplicantLogoff(1),
portFailure(2),
supplicantRestart(3),
reauthFailed(4),
authControlForceUnauth(5),
portReInit(6),
portAdminDisabled(7),
notTerminatedYet(999)
Session termination cause.
Not supported
dot1xAuthSessionUserName (1.0.8802.1.1.1.1.2.4.1.9)
read-only
SnmpAdminString
Session user name.
As per the MIB.
