03-Device Management
HomeSupportRoutersSR8800-X SeriesReference GuidesMIB CompanionH3C SR8800-X Routers MIB Reference-R8530Pxx-6W10003-Device Management
08-HH3C-LswTRAP-MIB
08-HH3C-LswTRAP-MIB 770.87 KB
HH3C-LswTRAP-MIB· 1
About this MIB· 1
MIB file name· 1
Root object 1
Scalar objects· 1
hh3csLswTrapCpuCoreInfo (1.3.6.1.4.1.25506.8.35.12.2.1) 1
hh3csLswTrapProcessMemoryInfo (1.3.6.1.4.1.25506.8.35.12.2.3) 1
hh3csLswTrapSlubInfo (1.3.6.1.4.1.25506.8.35.12.2.4) 1
hh3cLswTrapCpuUsage (1.3.6.1.4.1.25506.8.35.12.2.5) 2
hh3cLswTrapCoreProcessInfo (1.3.6.1.4.1.25506.8.35.12.2.6) 2
hh3cBoardAvailablePower (1.3.6.1.4.1.25506.8.35.12.2.8) 2
hh3cBoardRequiredPower (1.3.6.1.4.1.25506.8.35.12.2.9) 2
hh3cLswAlarmInPortInNum (1.3.6.1.4.1.25506.8.35.12.2.10) 2
hh3cDevTrapSrcChassis(1.3.6.1.4.1.25506.8.35.12.2.20) 3
hh3cDevTrapSrcSlot(1.3.6.1.4.1.25506.8.35.12.2.21) 3
hh3cDevTrapSrcCpu(1.3.6.1.4.1.25506.8.35.12.2.22) 3
hh3cDevTrapDestChassis(1.3.6.1.4.1.25506.8.35.12.2.23) 3
hh3cDevTrapDestSlot(1.3.6.1.4.1.25506.8.35.12.2.24) 3
hh3cDevTrapDestCpu(1.3.6.1.4.1.25506.8.35.12.2.25) 3
hh3cDevTrapRebootReason(1.3.6.1.4.1.25506.8.35.12.2.26) 4
hh3cDevTrapSlaveSwitchFailReason(1.3.6.1.4.1.25506.8.35.12.2.27) 4
hh3cDevTrapFanFailureErrcode(1.3.6.1.4.1.25506.8.35.12.2.28) 4
hh3cDMAMemoryTotal(1.3.6.1.4.1.25506.8.35.12.2.11) 4
hh3cDMAMemoryUsed(1.3.6.1.4.1.25506.8.35.12.2.12) 4
hh3cDMAMemoryFree(1.3.6.1.4.1.25506.8.35.12.2.13) 5
hh3cDMAMemoryCurrentState(1.3.6.1.4.1.25506.8.35.12.2.17) 5
hh3cDMAMemoryFreeRatio(1.3.6.1.4.1.25506.8.35.12.2.14) 5
hh3cDMAMemoryCriticalThreshold(1.3.6.1.4.1.25506.8.35.12.2.15) 5
hh3cDMAMemoryRecoverThreshold(1.3.6.1.4.1.25506.8.35.12.2.16) 5
hh3cDevTrapSliceIndex(1.3.6.1.4.1.25506.8.35.12.2.29) 5
Notifications· 6
hh3cpowerfailure· 6
hh3cPowerNormal 7
hh3cPowerRemoved· 7
hh3cfanfailure· 8
hh3cFanNormal 9
hh3cBoardRemoved· 10
hh3cBoardInserted· 10
hh3cBoardFailure· 11
hh3cBoardNormal 12
hh3cSubcardRemove· 13
hh3cSubcardInsert 14
hh3cPowerInserted· 14
hh3cCpuRemoved· 15
hh3cCpuFailure· 16
hh3cCpuNormal 17
hh3cPowerIncompatible· 18
hh3cCpuUsageSevereNotification· 18
hh3cCpuUsageSevereRecoverNotification· 20
hh3cCpuUsageMinorNotification· 22
hh3cCpuUsageMinorRecoverNotification· 25
hh3cMemoryUsageEarlyWarningNotification· 27
hh3cMemoryUsageEarlyWarningRecoverNotification· 30
hh3cMemoryUsageMinorNotification· 33
hh3cMemoryUsageMinorRecoverNotification· 36
hh3cMemoryUsageSevereNotification· 39
hh3cMemoryUsageSevereRecoverNotification· 42
hh3cMemoryUsageCriticalNotification· 45
hh3cMemoryUsageCriticalRecoverNotification· 48
hh3cCoreUsageNotification· 51
hh3cBoardPowerNotEnough· 52
hh3cCoreUsageSevereRecoveryNotification· 53
hh3cCoreUsageMinorNotification· 55
hh3cCoreUsageMinorRecoveryNotification· 57
hh3cDMAMemoryUsageCriticalNotification· 58
hh3cDMAMemoryUsageRecoverNotification· 60
hh3cLoadFinished· 61
hh3cBootImageUpdated· 62
hh3cRequestLoading· 62
hh3cBoardHeartbeatTimeout 63
hh3cBoardHeartbeatResume· 64
hh3cCommunicateError 65
hh3cCommunicateResume· 66
hh3cBoardRebooted· 67
hh3cAllBoardHeartbeatTimeout 68
hh3cAllBoardHeartbeatResume· 68
hh3cBladeNotInsertedNotCleared· 69
hh3cBladeInsertedCleared· 70
hh3cOutputPowerStatusNotification· 71
hh3cDevTrapSliceStarting· 72
hh3cDevTrapSliceOnline· 73
hh3cDevTrapSliceOffline· 73
hh3cBoardReceiveWrongPackets· 74
HH3C-LswTRAP-MIB
About this MIB
This MIB contains information about notifications for state change of cards and resources on the device.
MIB file name
hh3c-splat-trap.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswTrapMib(12)
Scalar objects
Object (OID)
Access
Value range
Implementation
accessible-for-notify
SnmpAdminString
OCTET STRING (0..255)
CPU core information in CPU notifications.
As per the MIB.
Object (OID)
Access
Value range
Implementation
SnmpAdminString
Memory information in CPU notifications.
As per the MIB.
Object (OID)
Access
Value range
Implementation
SnmpAdminString
Slub information in CPU notifications.
As per the MIB.
Object (OID)
Access
Value range
Implementation
SnmpAdminString
CPU usage information in CPU notifications.
As per the MIB.
Object (OID)
Access
Value range
Implementation
SnmpAdminString
Core process information in CPU notifications.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Integer32
Standard MIB values.
Available power.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Integer32
Required power.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Unsigned32
Number of alarm in ports.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Integer32
Source chassis ID.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Integer32
Source slot ID.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Integer32
Source CPU ID.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Integer32
Destination chassis ID.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Integer32
Destination slot ID.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Integer32
Destination CPU ID.
As per the MIB.
Object (OID)
Access
Value range
Implementation
SnmpAdminString
OCTET STRING(0..255)
Reason for card or member device reboot failure
As per the MIB.
Object (OID)
Access
Value range
Implementation
INTEGER
other(0)
systemRestarting(1)
standbyAbsent(2)
standbyNoReady(3)
Reason for active/standby or master/subordinate switchover failure.
As per the MIB.
Object (OID)
Access
Value range
Implementation
INTEGER
remove(0)
failed(1)
Reason for the fan tray failure.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Counter64
Total DMA memory space.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Counter64
Used DMA memory space.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Counter64
Free DMA memory space.
As per the MIB.
Object (OID)
Access
Value range
Implementation
INTEGER
normal(1),
critical(2)
Current DMA memory usage status.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Unsigned32
Unsigned32(0..100)
Free DMA memory ratio.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Unsigned32
DMA memory usage alarm threshold.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Unsigned32
DMA memory usage alarm clearance threshold.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Unsigned32
Slice index.
As per the MIB.
Notifications
hh3cpowerfailure
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.8.35.12.1.1
Failure of a power supply
Error
Major
1.3.6.1.4.1.25506.8.35.12.1.2 (hh3cPowerNormal)
ON
Notification triggers
This notification is generated when a power supply fails or a new power supply is inserted into the device.
System impact
A power supply failure might affect power supply to the device.
Status control
The notification cannot be disabled.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.8.35.9.1.2.1.1 (hh3cDevMPowerNum)
Power supply ID.
hh3cDevMPowerNum
Integer32
1.3.6.1.4.1.25506.8.35.9.1.13 (hh3cDevMFirstTrapTime)
Timestamp of the notification.
N/A
TimeTicks
Recommended action
To resolve the issue:
1.Verify that the power supply is installed correctly.
2.If the issue persists, contact H3C Support.
hh3cPowerNormal
Basic information
OID
Event
Severity
Default status
Recovery of a power supply from a fault
Recovery
Warning
N/A (N/A)
ON
This notification is generated when a power supply recovers from an abnormal state.
System impact
No negative impact on the system
Status control
Object
OID (object name)
Index
Value range
Power supply ID.
hh3cDevMPowerNum
Integer32
N/A
TimeTicks
Recommended action
No action is required.
hh3cPowerRemoved
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.5
Removal of a power supply
Error
Minor
1.3.6.1.4.1.25506.8.35.12.1.23 (hh3cPowerInserted)
ON
This notification is generated when a power supply is removed from the device.
System impact
Power supply to the system might be affected.
Status control
Object
OID (object name)
Index
Value range
Power supply ID.
hh3cDevMPowerNum
Integer32
Recommended action
1.Verify that a power supply is removed from the device.
  - If the power supply is removed from the device, no action is required.
  - If the power supply is not removed from the device, verify that the power supply is installed correctly.
hh3cfanfailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.6
Failure of a fan tray
Error
Major
1.3.6.1.4.1.25506.8.35.12.1.7 (hh3cFanNormal)
ON
This notification is generated when a fan tray fails.
System impact
Heat dissipation might be affected.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.8.35.9.1.1.1.1 (hh3cDevMFanNum)
Fan tray ID.
hh3cDevMFanNum
Integer32
1.3.6.1.4.1.25506.8.35.12.2.28 (hh3cDevTrapFanFailureErrcode)
N/A
INTEGER
Recommended action
1.Verify that the fan tray is installed correctly.
hh3cFanNormal
Basic information
OID
Event
Severity
Default status
Recovery of a fan tray from a fault.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when a fan tray recovers from a fault.
System impact
No negative impact on the system.
Status control
Object
OID (object name)
Index
Value range
Fan tray ID.
hh3cDevMFanNum
Integer32
Recommended action
hh3cBoardRemoved
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.8
Removal of a card
Error
Minor
1.3.6.1.4.1.25506.8.35.12.1.9 (hh3cBoardInserted)
ON
This notification is generated when a card is removed from the device.
System impact
Service processing capabilities of the system will degrade.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.8.35.18.4.2.1.1 (hh3cLswFrameIndex)
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer32
1.3.6.1.4.1.25506.8.35.18.4.3.1.1 (hh3cLswSlotIndex)
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer32
Recommended action
1.Verify that the card is removed from the device.
  - If the card is removed from the device, no action is required.
  - If the card is not removed from the device, verify that the card is installed correctly.
hh3cBoardInserted
Basic information
OID
Event
Severity
Default status
Insertion of a card
Recovery
Warning
N/A (N/A)
ON
This notification is generated when a card is inserted into the device.
System impact
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer32
Recommended action
hh3cBoardFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.10
Failure or startup of a card
Error
Major
1.3.6.1.4.1.25506.8.35.12.1.11 (hh3cBoardNormal)
ON
This notification is generated when a card is starting up or a fault occurs on the card.
System impact
A card failure can cause degradation of system processing capabilities.
Status control
Object
OID (object name)
Index
Value range
Member ID of the device
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer32
Slot ID
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer32
Recommended action
1.Verify that the card is installed correctly.
2.If the issue persists after 24 hours, contact H3C Support.
hh3cBoardNormal
Basic information
OID
Event
Severity
Default status
Initialization completion of a card
Recovery
Warning
N/A (N/A)
ON
This notification is generated when a card completes initialization.
System impact
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer32
Recommended action
hh3cSubcardRemove
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.12
Removal of a subcard
Error
Minor
1.3.6.1.4.1.25506.8.35.12.1.13 (hh3cSubcardInsert)
ON
This notification is generated when a subcard is removed from the device.
System impact
System processing capabilities will degrade.
Status control
Object
OID (object name)
Index
Value range
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswSubslotIndex
Integer32
Slot ID
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswSubslotIndex
Integer32
1.3.6.1.4.1.25506.8.35.18.4.4.1.1 (hh3cLswSubslotIndex)
Subslot ID
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswSubslotIndex
Integer32
Recommended action
1.Verify that the subcard is removed from the device.
  - If the subcard is removed from the device, no action is required.
  - If the subcard is not removed from the device, verify that the subcard is installed correctly.
hh3cSubcardInsert
Basic information
OID
Event
Severity
Default status
Insertion of a subcard
Recovery
Warning
N/A (N/A)
ON
This notification is generated when a subcard is inserted into the device.
System impact
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswSubslotIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswSubslotIndex
Integer32
Subslot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswSubslotIndex
Integer32
Recommended action
hh3cPowerInserted
Basic information
OID
Event
Severity
Default status
Insertion of a power supply
Recovery
Warning
N/A (N/A)
ON
This notification is generated when a power supply is inserted into the device.
System impact
Status control
Object
OID (object name)
Index
Value range
Power supply ID.
hh3cDevMPowerNum
Integer32
Recommended action
hh3cCpuRemoved
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.25
Removal of a non-default CPU
Error
Minor
N/A (N/A)
ON
This notification is generated when a non-default CPU subcard is removed from the device.
System impact
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
1.3.6.1.4.1.25506.8.35.18.4.10.1.1 (hh3cLswCpuIndex)
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
Recommended action
1.Verify that the non-default CPU is removed from the device.
  - If the non-default CPU is removed from the device, no action is required.
  - If the non-default CPU is not removed from the device, verify that the non-default CPU is installed correctly.
hh3cCpuFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.26
Failure or startup of a non-default CPU
Error
Major
1.3.6.1.4.1.25506.8.35.12.1.27 (hh3cCpuNormal)
ON
This notification is generated when a non-default CPU is starting up or a fault occurs on it.
System impact
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
Recommended action
1.Verify that the non-default CPU is installed correctly.
hh3cCpuNormal
Basic information
OID
Event
Severity
Default status
Initialization completion of a non-default CPU
Recovery
Warning
N/A (N/A)
ON
This notification is generated when a non-default CPU completes initialization.
System impact
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.28
Incompatibility of a power supply with the device
Error
Major
ON
This notification is generated when a power supply is not compatible with the device.
System impact
The power supply cannot supply power to the device.
Status control
Object
OID (object name)
Index
Value range
Power supply ID.
hh3cDevMPowerNum
Integer32
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.29
Severe CPU usage alarm
Error
Major
1.3.6.1.4.1.25506.8.35.12.1.30 (hh3cCpuUsageSevereRecoverNotification)
ON
This notification is generated when the CPU usage increases to or above the hh3cLswCpuUsageSevereThreshold.  This notification is sent at intervals of 60 seconds until the alarm is cleared.
System impact
The system service processing capabilities will be degraded.
Status control
This notification cannot be disabled.
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
1.3.6.1.4.1.25506.8.35.18.4.10.1.3
 (hh3cLswCpuRatio)
CPU usage.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
1.3.6.1.4.1.25506.8.35.18.4.10.1.11
 (hh3cLswCpuUsageMinorThreshold)
Minor CPU usage threshold.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
1.3.6.1.4.1.25506.8.35.18.4.10.1.12
 (hh3cLswCpuUsageSevereThreshold)
Severe CPU usage threshold.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
1.3.6.1.4.1.25506.8.35.18.4.10.1.13
 (hh3cLswCpuUsageRecoverThreshold)
CPU usage recovery threshold.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
 (hh3csLswTrapCpuCoreInfo)
CPU core usage (top1).
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
Standard MIB values., (hh3cLswCpuCoreUsage-top1)
CPU core usage (top2).
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
Standard MIB values., (hh3cLswCpuCoreUsage-top2)
CPU core usage (top3).
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
Standard MIB values., (hh3cLswCpuCoreUsage-top3)
CPU core usage (top4).
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
Standard MIB values., (hh3cLswCpuCoreUsage-top4)
CPU core usage (top5).
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
Standard MIB values., (hh3cLswCpuCoreUsage-top5)
 (hh3csLswTrapProcessCpuInfo)
Process usage (top1).
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
Standard MIB values., (hh3cLswProcessCpuRatio -top1)
Process usage (top2).
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
Standard MIB values., (hh3cLswProcessCpuRatio -top2)
Process usage (top3).
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
Standard MIB values., (hh3cLswProcessCpuRatio-top3)
Process usage (top4).
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
Standard MIB values., (hh3cLswProcessCpuRatio -top4)
1.3.6.1.4.1.25506.8.35.12.2.2 (hh3csLswTrapProcessCpuInfo)
Process usage (top5).
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
Standard MIB values., (hh3cLswProcessCpuRatio -top5)
Recommended action
If the alarm remains over 10 minutes, contact H3C Support.
Basic information
OID
Event
Severity
Default status
Clearance of a severe CPU usage alarm
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the CPU usage decreases to or below the hh3cLswCpuUsageSevereThreshold.
System impact
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
 (hh3cLswCpuRatio)
CPU usage.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.31
Minor CPU usage alarm
Error
Warning
1.3.6.1.4.1.25506.8.35.12.1.32 (hh3cCpuUsageMinorRecoverNotification)
ON
This notification is generated when the CPU usage increases to or above the hh3cLswCpuUsageMinorThreshold. This notification is sent at intervals of 300 seconds until the alarm is cleared.
System impact
No impact on the system at present. Observer whether the CPU usage continues to increase.
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
 (hh3cLswCpuRatio)
CPU usage.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
Recommended action
Potential risks exist. It is necessary to assess whether to take appropriate measures.
Basic information
OID
Event
Severity
Default status
Minor CPU usage alarm clearance
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the CPU usage decreases to or below the hh3cLswCpuUsageMinorThreshold.
System impact
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
 (hh3cLswCpuRatio)
CPU usage.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
SnmpAdminString
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.33
Memory usage early warning alarm
Error
Warning
1.3.6.1.4.1.25506.8.35.12.1.34 (hh3cMemoryUsageEarlyWarningRecoverNotification)
ON
This notification is generated when the amount of free memory decreases to or below the hh3cMemoryUsageEarlyWarningThreshold. This notification is sent at intervals of 1 hours until the alarm is cleared or a higher severity alarm is generated.
System impact
No negative impact on the system. Observe whether the amount of free memory continues to decrease.
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
1.3.6.1.4.1.25506.8.35.18.4.10.1.8
 (hh3cLswCpuMemory)
Total memory size.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
1.3.6.1.4.1.25506.8.35.18.4.10.1.14
 (hh3cLswCpuMemoryFree)
Free memory size.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
1.3.6.1.4.1.25506.8.35.18.4.10.1.15
 (hh3cLswCpuMemoryFreeRatio)
Free memory ratio.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
1.3.6.1.4.1.25506.8.35.18.4.10.1.16
 (hh3cLswCpuMemoryHighTotal)
Total high memory size
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
1.3.6.1.4.1.25506.8.35.18.4.10.1.17
 (hh3cLswCpuMemoryHighFree)
Free high memory size.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
1.3.6.1.4.1.25506.8.35.18.4.10.1.18
 (hh3cLswCpuMemoryLowTotal)
Total low memory size.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
1.3.6.1.4.1.25506.8.35.18.4.10.1.19
 (hh3cLswCpuMemoryLowFree)
Free low memory size.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
1.3.6.1.4.1.25506.8.35.18.4.10.1.26
 (hh3cLswCpuMemorySecureThreshold)
Sufficient memory threshold.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
1 to 100, in percentage
1.3.6.1.4.1.25506.8.35.18.4.10.1.27
 (hh3cLswCpuMemoryEarlyWarningThreshold)
Early-warning memory threshold.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
1.3.6.1.4.1.25506.8.35.18.4.10.1.28
 (hh3cLswCpuMemoryNormalThreshold)
Normal state memory threshold.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
1.3.6.1.4.1.25506.8.35.18.4.10.1.29
 (hh3cLswCpuMemoryMinorThreshold)
Minor memory threshold.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
1.3.6.1.4.1.25506.8.35.18.4.10.1.30
 (hh3cLswCpuMemorySevereThreshold)
Severe memory threshold.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
1.3.6.1.4.1.25506.8.35.18.4.10.1.31
 (hh3cLswCpuMemoryCriticalThreshold)
Critical memory threshold.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
1.3.6.1.4.1.25506.8.35.18.4.10.1.32
 (hh3cLswCpuMemoryCurrentState)
Current memory state.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
INTEGER
secure(1), earlywarning(2),, normal(3), minor(4), severe(5), critical(6)
 (hh3csLswTrapProcessMemoryInfo)
N/A
SnmpAdminString
Standard MIB values., (hh3cLswProcessMemoryUsed-top1)
N/A
SnmpAdminString
Standard MIB values., (hh3cLswProcessMemoryUsed-top2)
N/A
SnmpAdminString
Standard MIB values., (hh3cLswProcessMemoryUsed-top3)
N/A
SnmpAdminString
Standard MIB values., (hh3cLswProcessMemoryUsed-top4)
N/A
SnmpAdminString
Standard MIB values., (hh3cLswProcessMemoryUsed-top5)
 (hh3csLswTrapSlubInfo)
Slub information (top 1).
N/A
SnmpAdminString
Standard MIB values., (hh3cLswSlubInfoUsed-top1)
Slub information (top 2).
N/A
SnmpAdminString
Standard MIB values., (hh3cLswSlubInfoUsed-top2)
Slub information (top 3).
N/A
SnmpAdminString
Standard MIB values., (hh3cLswSlubInfoUsed-top3)
Slub information (top 4).
N/A
SnmpAdminString
Standard MIB values., (hh3cLswSlubInfoUsed-top4)
1.3.6.1.4.1.25506.8.35.12.2.4 (hh3csLswTrapSlubInfo)
Slub information (top 5).
N/A
SnmpAdminString
Standard MIB values., (hh3cLswSlubInfoUsed-top5)
Recommended action
Potential risks might exist. It is necessary to assess whether to take appropriate measures.
Basic information
OID
Event
Severity
Default status
Memory usage early warning alarm clearance
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the amount of free memory usage increases to or above the hh3cMemoryUsageSecureThreshold.
System impact
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
 (hh3cLswCpuMemory)
Total memory size.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
Free memory size.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
Free memory ratio.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
Total high memory size.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
INTEGER
secure(1), earlywarning(2), normal(3), minor(4), severe(5), critical(6)
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.35
Minor memory usage alarm
Error
Minor
1.3.6.1.4.1.25506.8.35.12.1.36 (hh3cMemoryUsageMinorRecoverNotification)
ON
This notification is generated when the amount of free memory decreases to or below the hh3cLswCpuMemoryMinorThreshold.  The notification is sent at intervals of 12 hours until the alarm condition is cleared or a higher severity alarm is generated.
System impact
No negative impact on the system at present.
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
 (hh3cLswCpuMemory)
Total memory size.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
Free memory size.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
Free memory ratio.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
INTEGER
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
Recommended action
The issue needs to be reviewed to determine whether action is necessary.
Basic information
OID
Event
Severity
Default status
Minor memory usage notification clearance
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the amount of free memory usage increases to or above the hh3cLswCpuMemoryNormalThreshold.
System impact
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
 (hh3cLswCpuMemory)
Total memory size.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
Free memory size.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
Free memory ratio.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
INTEGER
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.37
Severe memory usage alarm
Error
Major
1.3.6.1.4.1.25506.8.35.12.1.38 (hh3cMemoryUsageSevereRecoverNotification)
ON
This notification is generated when the amount of free memory decreases to or below the hh3cMemoryUsageSevereThreshold.  This notification is sent at intervals of 3 hours until the alarm is cleared or a higher severity alarm is generated.
System impact
Some services are affected.
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
 (hh3cLswCpuMemory)
Total memory size.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
Free memory size.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
Free memory ratio.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
INTEGER
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
Recommended action
The issue has significant impact on services. Immediate action is required.
Basic information
OID
Event
Severity
Default status
Severe memory usage alarm clearance
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the amount of free memory usage increases to or above the hh3cMemoryUsageMinorThreshold.
System impact
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
 (hh3cLswCpuMemory)
Total memory size.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
Free memory size.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
Free memory ratio.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
INTEGER
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.39
Critical memory usage alarm
Error
Critical
1.3.6.1.4.1.25506.8.35.12.1.40 (hh3cMemoryUsageCriticalRecoverNotification)
ON
This notification is generated when the amount of free memory decreases to or below the hh3cMemoryUsageCriticalThreshold. This notification is sent at intervals of 1 hour until the alarm is cleared.
System impact
The amount of free memory is severely insufficient. System communication will be affected.
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
 (hh3cLswCpuMemory)
Total memory size.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
Free memory size.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
Free memory ratio.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
INTEGER
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
Recommended action
The issue puts the system assets and services at risk. Immediate action is required.
Basic information
OID
Event
Severity
Default status
Critical memory usage alarm clearance
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the amount of free memory usage increases to or above the hh3cMemoryUsageSevereThreshold.
System impact
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
 (hh3cLswCpuMemory)
Total memory size.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
Free memory size.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
Free memory ratio.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
INTEGER
1.3.6.1.4.1.25506.8.35.18.4.10.1.33
 (hh3cLswCpuMemoryUsageThreshold)
Memory usage threshold.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
CounterBasedGauge64
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.3.0.1
CPU core usage alarm
Error
Warning
1.3.6.1.4.1.25506.8.35.12.3.0.10 (hh3cCoreUsageSevereRecoveryNotification)
ON
This notification is generated when the CPU core usage exceeds the hh3cLswCoreThreshold.
System impact
Degradation of the service processing capabilities by the CPU core.
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Integer32
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Integer32
1.3.6.1.4.1.25506.8.35.18.4.15.1.1 (hh3cLswCoreIndex)
CPU core ID.
N/A
Integer32
1.3.6.1.4.1.25506.8.35.12.2.7
 (hh3cLswCoreTrapUsage)
CPU core usage in the most recent 30 minutes.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Unsigned32
1.3.6.1.4.1.25506.8.35.18.4.15.1.5 (hh3cLswCoreThreshold)
CPU core usage threshold.
N/A
Unsigned32
1.3.6.1.4.1.25506.8.35.12.2.5 (hh3cLswTrapCpuUsage)
CPU usage during the most recent 5 seconds, 1 minute, 5 minutes.
N/A
SnmpAdminString
1.3.6.1.4.1.25506.8.35.12.2.6 (hh3cLswTrapCoreProcessInfo)
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
1.3.6.1.4.1.25506.8.35.18.4.15.1.7 (hh3cLswCoreMinorThreshold)
Minor CPU core usage threshold.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Unsigned32
1.3.6.1.4.1.25506.8.35.18.4.15.1.8 (hh3cLswCoreRecoveryThreshold)
CPU core normal state threshold.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Unsigned32
Recommended action
If the issue persists after 10 minutes, contact H3C Support.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.3.0.2
Power insufficiency for a card
Error
Major
N/A (N/A)
ON
This notification is generated when the power provided for a card is not enough.
System impact
The card cannot operate correctly.
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer32
 (hh3cBoardAvailablePower)
Available power.
N/A
Integer32
1.3.6.1.4.1.25506.8.35.12.2.9 (hh3cBoardRequiredPower)
Required power.
N/A
Integer32
Recommended action
Replace the power supplies with high-power ones.
Basic information
OID
Event
Severity
Default status
Clearance of severe CPU core usage alarm
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the core usage decreases to or below the hh3cLswCoreThreshold.
System impact
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Integer32
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Integer32
CPU core ID
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Integer32
CPU core usage in last 30 minutes.
N
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Unsigned32
CPU usage during the most recent 5-second, 1-minute, and 5-minute intervals.
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Unsigned32
CPU core normal state.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Unsigned32
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.3.0.11
Minor CPU core usage alarm
Error
N/A
1.3.6.1.4.1.25506.8.35.12.3.0.12 (hh3cCoreUsageMinorRecoveryNotification)
ON
This notification is generated when the core usage increases to or above the hh3cLswCoreMinorThreshold.
System impact
No impact on the system at present. Observer whether the core usage continues to increase.
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Integer32
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Integer32
CPU core ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Integer32
CPU core usage in the last 30 minutes.
N/A
Unsigned32
N/A
Unsigned32
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Unsigned32
Recommended action
Potential errors might exist. It is necessary to evaluate whether corresponding measures should be taken.
Basic information
OID
Event
Severity
Default status
Minor CPU core usage alarm clearance
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the core usage decreases to or below the hh3cLswCoreMinorThreshold.
System impact
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Integer32
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Integer32
CPU core ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Integer32
N/A
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Unsigned32
CPU usage in the most recent 5 seconds, 1 minute, and 5 minutes.
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
N/A
SnmpAdminString
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Unsigned32
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
hh3cLswCoreIndex
Unsigned32
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.3.0.41
Error
Critical
1.3.6.1.4.1.25506.8.35.12.3.0.42 (hh3cDMAMemoryUsageRecoverNotification)
ON
This notification is generated when the free DMA memory space decreases to or below the critical alarm threshold.   The notification is sent at intervals of 60 seconds until the alarm condition is cleared.
System impact
System performance might be affected.
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
1.3.6.1.4.1.25506.8.35.12.2.11 (hh3cDMAMemoryTotal)
N/A
Counter64
1.3.6.1.4.1.25506.8.35.12.2.12 (hh3cDMAMemoryUsed)
N/A
Counter64
1.3.6.1.4.1.25506.8.35.12.2.13 (hh3cDMAMemoryFree)
N/A
Counter64
1.3.6.1.4.1.25506.8.35.12.2.17 (hh3cDMAMemoryCurrentState)
Current status of the free DMA memory.
N/A
INTEGER
normal(1),, critical(2)
1.3.6.1.4.1.25506.8.35.12.2.14 (hh3cDMAMemoryFreeRatio)
Percentage of the free DMA memory space.
N/A
Unsigned32
Unsigned32(0..100)
1.3.6.1.4.1.25506.8.35.12.2.15 (hh3cDMAMemoryCriticalThreshold)
Critical alarm threshold for free DMA memory.
N/A
Unsigned32
Recommended action
The issue puts system assets and services at risk. Immediate action is required.
Basic information
OID
Event
Severity
Default status
DMA memory alarm clearance
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the free DMA memory increases to or above the normal state threshold.
System impact
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer32
N/A
Counter64
N/A
Counter64
N/A
Counter64
Current status of free DMA memory.
N/A
INTEGER
normal(1), critical(2)
Percentage of free DMA memory space.
N/A
Unsigned32
Unsigned32(0..100)
1.3.6.1.4.1.25506.8.35.12.2.16 (hh3cDMAMemoryRecoverThreshold)
Normal state threshold for free DMA memory.
N/A
Unsigned32
Recommended action
hh3cLoadFinished
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.20
A card finished loading of the image file.
Informational
Warning
N/A (N/A)
ON
This notification is generated when a card finishes loading of the image file.
System impact
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.24
Startup software images updated.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the startup software images are updated.
System impact
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer
Recommended action
hh3cRequestLoading
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.18
Image loading request received.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the loading service end receives an image loading request.
System impact
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.3.0.46
Heartbeat between the MPU and a card timed out.
Error
Warning
1.3.6.1.4.1.25506.8.35.12.3.0.47 (hh3cBoardHeartbeatResume)
ON
This notification is generated when the heartbeat between the MPU and a card times out.
System impact
A communication exception might occur between the MPU and other cards.
Status control
Object
OID (object name)
Index
Value range
 (hh3cLswFrameIndex)
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer
1.3.6.1.4.1.25506.8.35.18.4.3.1.1 (hh3cHeartbeatTimeoutSeconds)
Heartbeat timeout, in seconds.
N/A
Integer
Recommended action
Check the connection between the MPU and the card.
Basic information
OID
Event
Severity
Default status
Heartbeat between the MPU and a card resumed.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the heartbeat between the MPU and a card resumes.
System impact
Status control
Object
OID (object name)
Index
Value range
 (hh3cLswFrameIndex)
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.3.0.48
LIPC communication timed out.
Error
Warning
1.3.6.1.4.1.25506.8.35.12.3.0.49 (hh3cCommunicateResume)
ON
This notification is generated when communication between LIPC nodes times out.
System impact
A LIPC communication exception might occur.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.8.35.12.2.20 (hh3cDevTrapSrcChassis)
Source chassis ID.
N/A
Integer32
1.3.6.1.4.1.25506.8.35.12.2.21 (hh3cDevTrapSrcSlot)
Source slot ID.
N/A
Integer32
1.3.6.1.4.1.25506.8.35.12.2.22 (hh3cDevTrapSrcCpu)
Source CPU ID.
N/A
Integer32
1.3.6.1.4.1.25506.8.35.12.2.23 (hh3cDevTrapDestChassis)
N/A
Integer32
1.3.6.1.4.1.25506.8.35.12.2.24 (hh3cDevTrapDestSlot)
N/A
Integer32
1.3.6.1.4.1.25506.8.35.12.2.25 (hh3cDevTrapDestCpu)
Destination CPU ID.
N/A
Integer32
Recommended action
Basic information
OID
Event
Severity
Default status
LIPC communication recovered.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when LIPC communication recovers after a timeout.
System impact
Status control
Object
OID (object name)
Index
Value range
Source chassis ID.
N/A
Integer32
Source slot ID.
N/A
Integer32
Source CPU ID.
N/A
Integer32
N/A
Integer32
N/A
Integer32
Destination CPU ID.
N/A
Integer32
Recommended action
hh3cBoardRebooted
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.3.0.51
An active/standby or master/subordinate switchover failed.
Informational
Major
N/A (N/A)
ON
This notification is generated when an active/standby or master/subordinate switchover fails. The following are the possible causes:
No standby/subordinate exists.
Startup of the standby/subordinate has not finished.
The system is restarting.
Other reasons.
System impact
Active/standby or master/subordinate switchover failure.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.8.35.12.2.27 (hh3cDevTrapSlaveSwitchFailReason)
N/A
INTEGER
Standard MIB values
Recommended action
Take actions according to the reason displayed by the system:
An active/standby or master/subordinate switchover cannot be performed.
Wait for the standby/subordinate to finish startup.
Contact H3C Support.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.3.0.52
The active MPU or master device was disconnected from all cards or member devices.
Error
Major
1.3.6.1.4.1.25506.8.35.12.3.0.53 (hh3cAllBoardHeartbeatResume)
ON
This notification is generated when the active MPU or master device is disconnected from all cards or member devices.
System impact
MPU exception.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.8.35.12.2.19 (hh3cHeartbeatTimeoutSeconds)
Heartbeat timeout value.
N
Unsigned32
Standard MIB values
Recommended action
Basic information
OID
Event
Severity
Default status
Recovery
Warning
N/A (N/A)
ON
This notification is generated when heartbeat between the MPU and a card times out.
System impact
Status control
Object
OID (object name)
Index
Value range
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.3.0.54
After a security engine was removed, no security engine was inserted for a long time and information for the absent security engine was not cleared.
Error
Warning
1.3.6.1.4.1.25506.8.35.12.3.0.55 (hh3cBladeInsertedCleared)
ON
This notification is generated if a security engine is removed, no security engine is inserted for a long time, and information for the absent security engine was not cleared.
System impact
Degradation of service processing capabilities of the system.
Status control
Object
OID (object name)
Index
Value range
 (hh3cLswFrameIndex)
Chassis ID
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer
Standard MIB values
Slot ID
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer
Standard MIB values
CPU ID
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer
Standard MIB values
Recommended action
Execute the reset blade-controller-team command to clear information for an absent security engine in a security engine group or insert a security engine.
Basic information
OID
Event
Severity
Default status
A security engine was inserted or information for an absent security engine has been cleared.
Recovery
Warning
N/A (N/A)
ON
This notification is generated if a security engine was inserted or information for an absent security engine has been cleared.
System impact
Status control
Object
OID (object name)
Index
Value range
 (hh3cLswFrameIndex)
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer
Standard MIB values
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer
Standard MIB values
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer
Standard MIB values
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.3.0.45
Power interface exception
Error
Warning
N/A (N/A)
ON
This notification is generated if a power interface exception is detected.
System impact
Power supply will be affected.
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswOutputPowerPortID
Integer32
Standard MIB values
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer32
Standard MIB values
1.3.6.1.4.1.25506.8.35.18.4.16.1.1 (hh3cLswOutputPowerPortID)
Power interface ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer32
Integer32(1..2147483647)
1.3.6.1.4.1.25506.8.35.18.4.16.1.2 (hh3cLswOutputPowerStatus)
Power interface state.
hh3cLswFrameIndex
hh3cLswSlotIndex
INTEGER
INTEGER(1-7)
Recommended action
If the issue cannot be resolved, contact H3C Support.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.3.0.56
A slice module started to power on.
Informational
Warning
1.3.6.1.4.1.25506.8.35.12.3.0.57 (1.3.6.1.4.1.25506.8.35.12.3.0.57)
ON
This notification is generated when the following events occur after slice energy saving is enabled.
A hidden command is executed to power on a slice module.
A service triggers power on of a slice module.
System impact
The slice module cannot provide services when this notification is triggered.
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer32
1.3.6.1.4.1.25506.8.35.12.2.29 (hh3cDevTrapSliceIndex)
Slice module ID.
N/A
Integer32
Recommended action
Basic information
OID
Event
Severity
Default status
A slice module completed power on.
Informational
Warning
1.3.6.1.4.1.25506.8.35.12.3.0.58 (1.3.6.1.4.1.25506.8.35.12.3.0.58)
ON
This notification is generated when a slice module completes power on after slice energy saving is enabled.
System impact
The slice module that has completed power on can process services.
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer32
Slice module ID.
N/A
Integer32
Recommended action
Basic information
OID
Event
Severity
Default status
A slice module powered off.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the following event occur after slice energy saving is enabled.
A hidden command is executed to power off a slice module.
A service triggers power off of a slice module.
System impact
A slice module that has powered off cannot provide the forwarding service.
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer32
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
Integer32
Slice module ID.
N/A
Integer32
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.3.0.59
A card received error packets.
Informational
Warning
ON
This notification is triggered when a card receives error packets.
System impact
Service anomaly or card reboot might occur.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.8.4.2.1.1
 (hh3cLswFrameIndex)
Chassis ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer type.
Slot ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer type.
CPU ID.
hh3cLswFrameIndex
hh3cLswSlotIndex
hh3cLswCpuIndex
Integer type.
Recommended action
