| 05-HH3C-INFOCENTER-MIB | 148.80 KB |
hh3cICMaxLogbufferSize (1.3.6.1.4.1.25506.2.119.1.1.1)
hh3cICLogbufferSize (1.3.6.1.4.1.25506.2.119.1.1.2)
hh3cICLogbufferCurrentMessages (1.3.6.1.4.1.25506.2.119.1.1.3)
hh3cICLogbufferOverwrittenMessages (1.3.6.1.4.1.25506.2.119.1.1.4)
hh3cICLogbufferDroppedMessages (1.3.6.1.4.1.25506.2.119.1.1.5)
hh3cICMaxLoghost (1.3.6.1.4.1.25506.2.119.2.1.1)
hh3cICLoghostSourceInterface (1.3.6.1.4.1.25506.2.119.2.1.2)
hh3cICLoghostTimestampType (1.3.6.1.4.1.25506.2.119.2.1.3)
hh3cICLogGlobalState (1.3.6.1.4.1.25506.2.119.5.1.1)
hh3cICLogTimestampType (1.3.6.1.4.1.25506.2.119.5.1.2)
hh3cICLogType (1.3.6.1.4.1.25506.2.119.5.4.1)
hh3cICFailReason (1.3.6.1.4.1.25506.2.119.5.4.2)
hh3cICLogFileName (1.3.6.1.4.1.25506.2.119.5.4.3)
HH3C-INFOCENTER-MIB
About this MIB
Use this MIB to configure information center settings, including enabling the information center or configuring log buffers and log hosts. You can access this MIB to obtain information about log entries in the log buffer.
MIB file name
hh3c-infocenter.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cInfoCenter(119)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICMaxLogbufferSize (1.3.6.1.4.1.25506.2.119.1.1.1) |
read-only |
Unsigned32 |
Standard MIB values. |
Maximum number of log entries that can be buffered. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogbufferSize (1.3.6.1.4.1.25506.2.119.1.1.2) |
read-write |
Unsigned32 |
Current buffer size. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogbufferCurrentMessages (1.3.6.1.4.1.25506.2.119.1.1.3) |
read-only |
Unsigned32 |
Number of messages stored in the log buffer. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogbufferOverwrittenMessages (1.3.6.1.4.1.25506.2.119.1.1.4) |
read-only |
Counter32 |
Number of overwritten messages in the log buffer. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogbufferDroppedMessages (1.3.6.1.4.1.25506.2.119.1.1.5) |
read-only |
Counter32 |
Number of dropped messages in the log buffer. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICMaxLoghost (1.3.6.1.4.1.25506.2.119.2.1.1) |
read-only |
Unsigned32 |
Maximum number of log hosts supported by the information center. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLoghostSourceInterface (1.3.6.1.4.1.25506.2.119.2.1.2) |
read-write |
InterfaceIndexOrZero |
Source interface through which log messages are sent to log hosts. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLoghostTimestampType (1.3.6.1.4.1.25506.2.119.2.1.3) |
read-write |
ICTimeStampType |
date(0), boot(1), iso(2), dateWithoutYear(3), none(4), isoWithTimezone(5), dataWithMilliseconds(6), isoWithMilliseconds(7), isoWithMillisecondsAndTimezone(8) |
Timestamp format for logs sent to log hosts. |
Does not support boot(1). isoWithTimezone(5), dataWithMilliseconds(6), isoWithMilliseconds(7), or isoWithMillisecondsAndTimezone(8). |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogGlobalState (1.3.6.1.4.1.25506.2.119.5.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Selects whether to enable the information center globally. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogTimestampType (1.3.6.1.4.1.25506.2.119.5.1.2) |
read-write |
ICTimeStampType |
date(0), |
Timestamp format for log messages. |
Supports only boot, date, and none. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogType (1.3.6.1.4.1.25506.2.119.5.4.1) |
accessible-for-notify |
INTEGER |
logfile(1), diagfile(2), secfile(3), tracefile(4) |
Log type. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICFailReason (1.3.6.1.4.1.25506.2.119.5.4.2) |
DisplayString |
Reason for write failure. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogFileName (1.3.6.1.4.1.25506.2.119.5.4.3) |
DisplayString |
Name of the deleted log file. |
As per the MIB. |
Tabular objects
hh3cICLogbufferContTable
About this table
This table contains log buffer information.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table index is hh3cICLogbufferContIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogbufferContIndex (1.3.6.1.4.1.25506.2.119.1.2.1.1) |
not-accessible |
Integer32 |
Integer32 (1..2147483647) |
Table index. |
As per the MIB. |
hh3cICLogbufferContDescription (1.3.6.1.4.1.25506.2.119.1.2.1.2) |
read-only |
DisplayString |
OCTET STRING (0..1600) |
Content of the log buffer. |
As per the MIB. |
hh3cICLoghostTable
About this table
This table specifies a log host and configures output parameters, including IP address of the log host, VPN instance, logging facility, port number of the log host, and log output destination. You can also access this table to obtain log host-related information.
Create:Supported
Edit/Modify:Supported
Delete:Supported
Read:Supported
Columns
The table index is hh3cICLoghostIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLoghostIndex (1.3.6.1.4.1.25506.2.119.2.2.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (1..64) |
Table index. |
As per the MIB. |
hh3cICLoghostIpaddressType (1.3.6.1.4.1.25506.2.119.2.2.1.2) |
read-create |
InetAddressType |
unknown(0), ipv4(1), ipv6(2), ipv4z(3), ipv6z(4), dns(16) |
Address type for the log host. |
As per the MIB. |
hh3cICLoghostIpaddress (1.3.6.1.4.1.25506.2.119.2.2.1.3) |
read-create |
InetAddress |
OCTET STRING (0..255) |
IP address of the log host. |
As per the MIB. |
hh3cICLoghostVPNName (1.3.6.1.4.1.25506.2.119.2.2.1.4) |
read-create |
DisplayString |
Name of the VPN instance to which the log host belongs. |
As per the MIB. |
hh3cICLoghostFacility (1.3.6.1.4.1.25506.2.119.2.2.1.5) |
read-create |
ICFacilityType |
kernel(0), userLevel(1), mailSystem(2), systemDaemons(3), securityAuthorization(4), internallyMessages(5), linePrinter(6), networkNews(7), uucp(8), clockDaemon(9), securityAuthorization2(10), ftpDaemon(11), ntp(12), logAudit(13), logAlert(14), clockDaemon2(15), local0(16), local1(17), local2(18), local3(19), local4(20), local5(21), local6(22), local7(23) |
Logging facility for marking different logging sources, and querying and filtering log messages. |
Supports only local0(0), local1(1), local2(2), local3(3), local4(4), local5(5), local6(6), and local7(7). |
hh3cICLoghostOperateRowStatus (1.3.6.1.4.1.25506.2.119.2.2.1.6) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
As per the MIB. |
hh3cICLoghostIpaddressPort (1.3.6.1.4.1.25506.2.119.2.2.1.7) |
read-create |
Unsigned32 |
Unsigned32 (1..65535) |
Port number of the log host. |
As per the MIB. |
hh3cICLoghostTAddress (1.3.6.1.4.1.25506.2.119.2.2.1.8) |
read-create |
TAddress |
OCTET STRING (1..255) |
Supports only IPv4 addresses. |
hh3cICDirectionTable
About this table
This table contains information about syslog output directions and specifies the enablement status of output directions.
Read:Supported
Columns
The table index is hh3cICDirectionIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICDirectionIndex (1.3.6.1.4.1.25506.2.119.3.1.1.1) |
not-accessible |
Unsigned32 |
Table index. |
As per the MIB. |
hh3cICDirectionName (1.3.6.1.4.1.25506.2.119.3.1.1.2) |
read-only |
DisplayString |
OCTET STRING (1..30) |
Name of a log output destination. |
As per the MIB. |
hh3cICDirectionState (1.3.6.1.4.1.25506.2.119.3.1.1.3) |
read-write |
TruthValue |
true(1), false(2) |
Status of the log output destination. |
Specifies whether to enable log output to the log buffer, log file, security log file, or diagnostic log file. Log output to other destinations than the above destinations are all enabled. |
hh3cICModuleTable
About this table
This table contains available source modules.
Read:Supported
Columns
The table index is hh3cICModuleName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICModuleName (1.3.6.1.4.1.25506.2.119.4.1.1.1) |
read-only |
DisplayString |
OCTET STRING (1..8) |
Name of a source module. |
As per the MIB. |
hh3cICLogTable
About this table
This table specifies the log level of log messages generated by a specific module to a specific output destination, and contains the log buffer information.
Create:The module name in a row cannot contain lowercase letters and cannot be default
Edit/Modify:A row with the source module named default cannot be deleted
Delete:Supported
Read:Supported
Columns
The table indexes are hh3cICDirectionIndex and hh3cICModuleName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogLevel (1.3.6.1.4.1.25506.2.119.5.2.1.1) |
read-create |
ICMessageLevelType |
emergency(0), |
Severity level of a log message. |
As per the MIB. |
hh3cICLogRowStatus (1.3.6.1.4.1.25506.2.119.5.2.1.2) |
read-create |
RowStatus |
active(1), |
Row status. |
As per the MIB. |
Notifications
hh3cICLogWriteFail
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.119.5.3.0.1 |
Failed to write buffered logs to the log file. |
Error |
Major |
N/A (N/A) |
ON |
Notification triggers
This notification is generated when the device fails to write logs in the buffer to the log file.
System impact
The latest log cannot be saved to the log file.
Status control
This notification cannot be disabled.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.119.5.4.1 (hh3cICLogType) |
Log type. |
N/A |
INTEGER |
1.3.6.1.4.1.25506.2.119.5.4.2 (hh3cICFailReason) |
N/A |
DisplayString |
Recommended action
Troubleshoot according to the failure reason carried in the trap. For example:
1.Execute the dir command in user view to display the current available space of the storage medium. If the storage space is not enough, use the delete /unreserved command to delete unused files permanently to release storage space.
2.If the storage medium becomes read-only due to a malfunction, please back up the files in the storage medium first, and then try to repair it using the fixdisk command.
3.If the write protection function is enabled, new logs cannot be written to the log file after the file is written to full capacity. At this time, you can disable write protection by using the undo info-center logfile overwrite-protection command.
4.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cICLogFileAging
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.119.5.3.0.2 |
Deleted the oldest compressed log file. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the device deletes the oldest compressed log file after all log files are full, and generates a new log file to save new logs. This notification is available for devices that support multiple log files.
System impact
The logs in the deleted log file are lost if the log file has no backup.
Status control
Object
OID (object name) |
Index |
Type |
Value range |
(1.3.6.1.4.1.25506.2.119.5.4.3 hh3cICLogFileName) |
N/A |
DisplayString |
Recommended action
1.As a best practice, back up the log files generated by the system periodically.
2.Execute the display logfile summary command and then identify the maximum storage space reserved for a single log file (the value of the Log file size quota field). To change the file size to a proper value, use the info-center logfile size-quota command.
