03-Device Management
HomeSupportRoutersSR8800-X SeriesReference GuidesMIB CompanionH3C SR8800-X Routers MIB Reference-R8530Pxx-6W10003-Device Management
07-HH3C-LswDEVM-MIB
07-HH3C-LswDEVM-MIB 97.18 KB
HH3C-LswDEVM-MIB
About this MIB
Use this MIB to obtain information the resources on the device. For example, access this MIB to obtain power supply or fan information, including their number or status.
MIB file name
hh3c-splat-devm.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswdevMMib(9)
Tabular objects
hh3cdevMFanStatusTable
About this table
This table contains basic fan information.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDevMFanNum.
Object (OID)
Access
Value range
Implementation
hh3cDevMFanNum (1.3.6.1.4.1.25506.8.35.9.1.1.1.1)
read-only
Integer32
Standard MIB values.
Fan index.
Implementation varies by product.
hh3cDevMFanStatus (1.3.6.1.4.1.25506.8.35.9.1.1.1.2)
read-only
INTEGER
active(1),
deactive(2),
not-install(3),
unsupport(4)
Fan status.
hh3cDevMFanPosFrame
(1.3.6.1.4.1.25506.8.35.9.1.1.1.3)
read-only
Integer32
ID of the chassis where the fan resides.
Not supported
hh3cDevMFanMaxSpeed
(1.3.6.1.4.1.25506.8.35.9.1.1.1.6)
read-only
Integer32
Maximum fan speed.
Not supported
hh3cDevMFanCurrentSpeed
(1.3.6.1.4.1.25506.8.35.9.1.1.1.7)
read-only
Integer32
Current fan speed.
Not supported
hh3cdevMPowerStatusTable
About this table
This table contains basic power supply information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDevMPowerNum.
Object (OID)
Access
Value range
Implementation
hh3cDevMPowerNum (1.3.6.1.4.1.25506.8.35.9.1.2.1.1)
read-only
Integer32
Power supply index.
hh3cDevMPowerStatus (1.3.6.1.4.1.25506.8.35.9.1.2.1.2)
read-only
INTEGER
active(1),
deactive(2),
not-install(3),
unsupport(4)
Power supply status.
hh3cDevMPowerEntIndex (1.3.6.1.4.1.25506.8.35.9.1.2.1.3)
read-only
Integer32
Entity index of the power supply.
hh3cDevMPowerRatedVoltage (1.3.6.1.4.1.25506.8.35.9.1.2.1.4)
read-only
Integer32
Rated voltage of the power supply, in mV.
hh3cDevMPowerRatedCurrent (1.3.6.1.4.1.25506.8.35.9.1.2.1.5)
read-only
Integer32
Rated current of the power supply, in mA.
hh3cDevMPowerLoadFactor (1.3.6.1.4.1.25506.8.35.9.1.2.1.6)
read-only
Integer32
Load factor of the power supply.
hh3cDevMPowerUsedPower
(1.3.6.1.4.1.25506.8.35.9.1.2.1.7)
read-only
Integer32
Used power of the power supply, in mW.
hh3cDevMPowerRemainingPower (1.3.6.1.4.1.25506.8.35.9.1.2.1.8)
read-only
Integer32
Remaining power of the power supply, in mW.
hh3cDevMPowerSupplyType
(1.3.6.1.4.1.25506.8.35.9.1.2.1.9)
read-only
Integer32
AC(1),
DC (2),
HVDC(3)
Power supply type.
hh3cDevMPowerOutputVoltage(1.3.6.1.4.1.25506.8.35.9.1.2.1.10)
read-only
Integer32
Output voltage of the power module, in V.
hh3cDevMPowerInputPower (1.3.6.1.4.1.25506.8.35.9.1.2.1.13)
read-only
Integer32
Input power of the power module, in mW.
hh3cDevMPowerInputVoltage(1.3.6.1.4.1.25506.8.35.9.1.2.1.14)
read-only
Integer32
Input voltage of the power module, in V.
hh3cdevMSlotEnvironmentTable
About this table
This table contains environment information for a card.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cdevMSlotEnvironmentType.
Object (OID)
Access
Value range
Implementation
hh3cdevMSlotEnvironmentType (1.3.6.1.4.1.25506.8.35.9.1.3.1.1)
not-accessible
INTEGER
temperature(1),
humidity(2),
fog(3)
Type of the environment elements.
hh3cDevMSlotEnvironmentStatus (1.3.6.1.4.1.25506.8.35.9.1.3.1.2)
read-only
INTEGER
normal(1),
upper(2),
lower(3)
Status of the environment where the card resides.
Not supported.
hh3cDevMSlotEnvironmentValue (1.3.6.1.4.1.25506.8.35.9.1.3.1.3)
read-only
Integer32
Environment data for the card.
hh3cDevMSlotEnvironmentUpperLimit (1.3.6.1.4.1.25506.8.35.9.1.3.1.4)
read-write
Integer32
Upper limit for the environment requirements.
Not supported.
hh3cDevMSlotEnvironmentLowerLimit (1.3.6.1.4.1.25506.8.35.9.1.3.1.5)
read-write
Integer32
Lower limit for the environment requirements.
Not supported.
hh3cMemTable
About this table
This table contains memory information.
CreateNo
Edit/ModifyNo
DeleteNo
ReadYes
Columns
The table index is hh3cMemModuleIndex.
Object (OID)
Access
Value range
Implementation
hh3cMemModuleIndex (1.3.6.1.4.1.25506.8.8.2.1.1.1)
not-accessible
Integer32
Table index.
As per the MIB.
hh3cMemSize (1.3.6.1.4.1.25506.8.8.2.1.1.2)
read-only
Gauge32
Total size of memory modules on the hosted object.
As per the MIB.
hh3cMemFree (1.3.6.1.4.1.25506.8.8.2.1.1.3)
read-only
Gauge32
Free memory size.
As per the MIB.
hh3cMemRawSliceUsed (1.3.6.1.4.1.25506.8.8.2.1.1.4)
read-only
Gauge32
Size of the raw memory that has been used.
As per the MIB.
hh3cMemLgFree (1.3.6.1.4.1.25506.8.8.2.1.1.5)
read-only
Gauge32
Maximum available size of a contiguous region in memory, in bytes.
As per the MIB.
hh3cMemFail (1.3.6.1.4.1.25506.8.8.2.1.1.6)
read-only
Gauge32
Number of memory allocation failures.
As per the MIB.
hh3cMemFailNoMem (1.3.6.1.4.1.25506.8.8.2.1.1.7)
read-only
Gauge32
Low memory limit for the card.
As per the MIB.
