05-Interface Command Reference
HomeSupportRoutersSR6602-I[IE] SeriesReference GuidesCommand ReferencesH3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References(V9)-R9141-6W10005-Interface Command Reference
01-Common interface commands
01-Common interface commands 208.59 KB
bandwidth
Use bandwidth to set the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth is not configured.
Interface view
# Set the expected bandwidth of Ten-GigabitEthernet 0/0/6 to 1000 kbps.
[Sysname] interface ten-gigabitethernet 0/0/6
[Sysname-Ten-GigabitEthernet0/0/6] bandwidth 1000
speed
default
Use default to restore the default settings for an interface.
default
Interface view
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you use it in a live network.
This command might fail to restore the default settings for some commands because of command dependencies or system restrictions. You can use the display this command in interface view to identify these commands, and use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to solve the problem.
# Restore the default settings for Ten-GigabitEthernet 0/0/6.
[Sysname-Ten-GigabitEthernet0/0/6] default
description
The description of an interface is the interface name plus Interface (for example, Ten-GigabitEthernet0/0/6 Interface).
Interface view
text: Specifies the interface description, a case-sensitive string of 1 to 255 characters.
# Set the description of Ten-GigabitEthernet 0/0/6 to lan-interface.
[Sysname-Ten-GigabitEthernet0/0/6] description lan-interface
display counters
Use display counters to display interface traffic statistics.
display counters { inbound | outbound } interface [ interface-type [ interface-number ] ]
inbound: Displays inbound traffic statistics.
outbound: Displays outbound traffic statistics.
To clear the interface traffic statistics, use the reset counters interface command.
If you do not specify an interface type, this command displays traffic statistics for all interfaces that have traffic counters.
If you specify an interface type but do not specify an interface number, this command displays traffic statistics for all interfaces of the specified type.
If you specify an interface type and number, this command displays traffic statistics for the specified interface.
# Display inbound traffic statistics for all interfaces.
<Sysname> display counters inbound interface
Interface            Total (pkts)    Broadcast (pkts)    Multicast (pkts)  Err (pkts)
GE1/0/1                       100                 100                   0           0
GE1/0/2                  Overflow            Overflow            Overflow    Overflow
 Overflow: More than 14 digits (7 digits for column "Err").
       --: Not supported.
Abbreviated interface name.
Total (pkts)
Total number of packets received or sent through the interface.
Broadcast (pkts)
Total number of broadcast packets received or sent through the interface.
Multicast (pkts)
Total number of multicast packets received or sent through the interface.
Err (pkts)
Total number of error packets received or sent through the interface.
The command displays Overflow when any of the following conditions exist:
·     The data length of an Err field value is greater than 7 decimal digits.
·     The data length of a non-Err field value is greater than 14 decimal digits.
--: Not supported
The statistical item is not supported.
display counters rate
Use display counters rate to display traffic rate statistics for interfaces in up state for the most recent statistics polling interval.
display counters rate { inbound | outbound } interface [ interface-type [ interface-number ] ]
inbound: Displays inbound traffic rate statistics.
outbound: Displays outbound traffic rate statistics.
If you do not specify an interface type, this command displays traffic rate statistics for all up interfaces that have traffic counters.
If you specify an interface type but do not specify an interface number, this command displays traffic rate statistics for all up interfaces of the specified type.
If you specify an interface type and an interface, this command displays traffic rate statistics for the specified interface.
If an interface that you specify is always down for the most recent statistics polling interval, the system prompts that the interface does not support the command.
You can use the flow-interval command to set the statistics polling interval.
# Display the inbound traffic rate statistics for all interfaces.
<Sysname> display counters rate inbound interface
Usage: Bandwidth utilization in percentage
Interface            Usage (%)   Total (pps)   Broadcast (pps)   Multicast (pps)
GE1/0/1                     0             0                --               --
 Overflow: More than 14 digits.
       --: Not supported.
Usage (%)
Bandwidth usage (in percentage) of the interface for the last statistics polling interval.
Total (pkts/sec)
Average receiving or sending rate (in pps) for unicast packets for the last statistics polling interval.
Broadcast (pkts/sec)
Average receiving or sending rate (in pps) for broadcast packets for the last statistics polling interval.
Multicast (pkts/sec)
Average receiving or sending rate (in pps) for multicast packets for the last statistics polling interval.
Overflow: more than 14 decimal digits
The command displays Overflow if the data length of a statistical item is greater than 14 decimal digits.
--: not supported
flow-interval
display interface link-info
Use display interface link-info to display the status and packet statistics of interfaces.
display interface link-info [ main ]
main: Specifies all interfaces except subinterfaces. If you do not specify this keyword, this command displays status and packet statistics of all interfaces.
# Display status and statistics of all interfaces.
<Sysname> display interface link-info
Protocol: (s) - spoofing
Interface        Link Protocol  InUsage OutUsage         InErrs        OutErrs
XGE0/0/6          UP   UP            10%       0%              0              0
NULL0            UP   UP(s)          0%       0%              0              0
 Overflow: More than 7 digits.
       --: Not supported.
Physical link state of the interface:
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command.
Protocol: (s) – spoofing
The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces, loopback interfaces, and InLoopback interfaces.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces, loopback interfaces, and InLoopback interfaces.
InUsage
Inbound bandwidth usage within the most recent statistics polling interval. It is calculated by this formula: Average inbound speed of the interface within the most recent statistics polling interval/interface bandwidth. To set the statistics polling interval, use the flow-interval command.
OutUsage
Outbound bandwidth usage within the most recent statistics polling interval. It is calculated by this formula: Average outbound speed of the interface within the most recent statistics polling interval/interface bandwidth. To set the statistics polling interval, use the flow-interval command.
InErrs
Number of error packets received.
OutErrs
Number of error packets sent.
The data length of a statistical item value is greater than 7 decimal digits.
--: Not supported.
A hyphen (-) indicates that the corresponding statistical item is not supported.
flow-interval
display interface main
Use display interface main to display operating status and information of all interfaces except subinterfaces.
display interface [ interface-type ] [ brief [ description | down ] ] main
interface-type: Specifies an interface type. If you do not specify this argument, the command displays information about interfaces of all types.
down: Displays information about interfaces in down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
# Display operating status and information of all interfaces except subinterfaces.
<Sysname> display interface main
Line protocol state: DOWN
IP packet frame type: Ethernet II, hardware address: 4005-6538-0100
Description: Ten-GigabitEthernet0/0/6 Interface
Bandwidth: 1000000 kbps
Loopback is not set
Flow-control is not enabled
Maximum frame length: 9216
Allow jumbo frames to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
PVID: 1
MDI type: Automdix
Port link-type: Access
 Tagged VLANs:   None
 Untagged VLANs: 1
Port priority: 2
Last link flapping: Never
Current system time:2018-04-11 10:20:24
Last time when physical state changed to up:-
Last time when physical state changed to down:2018-04-11 09:11:09
 Peak input rate: 0 bytes/sec, at 00-00-00 00:00:00
 Peak output rate: 0 bytes/sec, at 00-00-00 00:00:00
 Last 300 seconds input: 0 packets/sec 0 bytes/sec -%
 Last 300 seconds output: 0 packets/sec 0 bytes/sec -%
 Input (total):  0 packets, 0 bytes
 Input (normal):  0 packets, 0 bytes
         0 CRC, 0 frame, 0 overruns, 0 aborts
         0 ignored, 0 parity errors
 Output (normal): 0 packets, 0 bytes
 Output: 0 output errors, 0 underruns, 0 buffer failures
         0 lost carrier, 0 no carrier
IPv4 traffic statistics:
 Last 300 seconds input rate: 0 packets/sec, 0 bytes/sec
 Last 300 seconds output rate: 0 packets/sec, 0 bytes/sec
 Input: 0 packets, 0 bytes
 Output: 0 packets, 0 bytes
IPv6 traffic statistics:
Ten-GigabitEthernet0/0/7
Description: Ten-GigabitEthernet0/0/7 Interface
IP packet frame type: Ethernet II, hardware address: 4005-6538-0107
IPv6 packet frame type: Ethernet II, hardware address: 4005-6538-0107
Last time when physical state changed to down:2018-04-11 09:33:52
Current state
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     DOWN ( Link-Aggregation interface down )—The aggregate interface to which the interface belongs has been shut down by using the shutdown command.
·     Link-Flap DOWN—The interface has been shut down by the link flapping protection feature.
·     mac-address moving down—The interface has been shut down by the MAC address move suppression feature.
·     OFP DOWN—The interface has been shut down by OpenFlow.
·     STP DOWN—The interface has been shut down by the BPDU guard feature.
·     DOWN (No MEC license)—The interface has been shut down because the device does not have an MEC license.
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer.
·     UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces.
·     DOWN (protocols)—The data link layer has been shut down by protocols included in the parentheses. Available protocols include:
¡     DLDP—Shuts down the data link layer when it detects that the link is unidirectional.
¡     LAGG—Shuts down the data link layer when it detects that the aggregate interface does not have Selected ports.
¡     BFD—Shuts down the data link layer when it detects a link failure.
Bandwidth
Expected bandwidth of the interface.
MTU of the interface.
IP packet processing capability of the interface when the interface is not assigned an IP address:
·     Disabled—The interface cannot process IP packets.
·     Enabled—The interface can process IP packets.
IP address of the interface and type of the address in parentheses.
Possible IP address types include:
·     Primary—Manually configured primary IP address.
·     Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed.
·     DHCP-allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3IP Services Configuration Guide.
·     BOOTP-allocatedBOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3IP Services Configuration Guide.
·     PPP-negotiated—IP address assigned by a PPP server during PPP negotiation. For more information, see PPP configuration in Layer 2WAN Access Configuration Guide.
·     Unnumbered—IP address borrowed from another interface.
·     MTunnel—IP address of the multicast tunnel interface (MTI), which is the same as the IP address of the MVPN source interface. For more information, see multicast VPN configuration in Multicast Configuration Guide.
IPv4 packet framing format.
hardware address
MAC address of the interface.
IPv6 packet framing format.
Port priority
Port priority of the interface.
Loopback is set internal
An internal loopback test is running on the interface. This field depends on your configuration.
Loopback is set external
An external loopback test is running on the interface. This field depends on your configuration.
Loopback is not set
No loopback test is running on the interface. This field depends on your configuration.
10Mbps-speed mode
The interface is operating at 10 Mbps. This field depends on your configuration and the link parameter negotiation result.
100Mbps-speed mode
The interface is operating at 100 Mbps. This field depends on your configuration and the link parameter negotiation result.
1000Mbps-speed mode
The interface is operating at 1000 Mbps. This field depends on your configuration and the link parameter negotiation result.
10Gbps-speed mode
The interface is operating at 10 Gbps. This field depends on your configuration and the link parameter negotiation result.
Unknown-speed mode
The speed of the interface is unknown because the speed negotiation fails or the interface is physically disconnected.
half-duplex mode
The interface is operating in half duplex mode. This field depends on your configuration and the link parameter negotiation result.
full-duplex mode
The interface is operating in full duplex mode. This field depends on your configuration and the link parameter negotiation result.
unknown-duplex mode
The duplex mode of the interface is unknown because the duplex mode negotiation fails or the interface is physically disconnected.
The interface is configured with the speed auto command.
Link speed type is force link
The interface is manually configured with a speed (for example, 1000 Mbps) by using the speed command.
The interface is configured with the duplex auto command.
link duplex type is force link
The interface is manually configured with a duplex mode (for example, half or full) by using the duplex command.
Generic flow control is disabled on the interface. This field depends on your configuration and the link parameter negotiation result.
Maximum length of Ethernet frames allowed to pass through the interface.
Allow jumbo frame to pass
The interface allows jumbo frames to pass through.
Broadcast max-
Broadcast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
Multicast max-
Multicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
Unicast max-
Unknown unicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
PVID
Port VLAN ID (PVID) of the interface.
MDI type
MDIX mode of the interface:
·     automdix.
·     mdi.
·     mdix.
Port link-type
Link type of the interface:
·     access.
·     trunk.
·     hybrid.
Tagged VLANs
VLANs for which the interface sends packets without removing VLAN tags.
Untagged VLANs
VLANs for which the interface sends packets after removing VLAN tags.
VLAN Passing
VLANs whose packets can be forwarded by the port. The VLANs must have been created.
VLAN permitted
VLANs whose packets are permitted by the port.
Trunk port encapsulation
Encapsulation protocol type for the trunk port.
Last link flapping
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup.
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup.
Current system time
Current system date and time, which is displayed in the YYYY/MM/DD hh:mm:ss format by default.
If the time zone is configured, this field is in the YYYY/MM/DD hh:mm:ss zone-name±hh:mm:ss format, where the zone-name argument is the local time zone name.
Last date and time when the physical state of the interface changed to up, which is displayed in the YYYY/MM/DD hh:mm:ss format by default.
If the physical state of the interface has never changed to up, this field displays a hyphen (-).
Last date and time when the physical state of the interface changed to down, which is displayed in the YYYY/MM/DD hh:mm:ss format by default.
If the physical state of the interface has never changed to down, this field displays a hyphen (-).
Last 300 seconds input:  0 packets/sec 0 bytes/sec 0%
Last 300 seconds output:  0 packets/sec 0 bytes/sec 0%
Average inbound or outbound traffic rate (in pps and Bps) in the last 300 seconds, and the ratio of the actual rate to the interface bandwidth.
A hyphen (-) indicates that the statistical item is not supported.
Input(total):  0 packets, 0 bytes
The two fields on the first line represent the inbound traffic statistics (in packets and bytes) for the interface. All inbound normal packets, abnormal packets, and normal pause frames were counted.
The four fields on the second line represent:
·     Number of inbound unicast packets.
·     Number of inbound broadcasts.
·     Number of inbound multicasts.
·     Number of inbound pause frames.
Input(normal):  0 packets, 0 bytes
The two fields on the first line represent the inbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
·     Number of inbound normal unicast packets.
·     Number of inbound normal broadcasts.
·     Number of inbound normal multicasts.
·     Number of inbound normal pause frames.
input errors
Statistics of incoming error packets.
runts
Number of inbound frames meeting the following conditions:
·     Shorter than 64 bytes.
·     In correct format.
·     Containing valid CRCs.
giants
Number of inbound giants. Giants refer to frames larger than the maximum frame length supported on the interface.
For an Ethernet interface that does not permit jumbo frames, the maximum frame length is as follows:
·     1518 bytes (without VLAN tags).
·     1522 bytes (with VLAN tags).
For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface.
throttles
Number of inbound frames that had a non-integer number of bytes.
CRC
Total number of inbound frames that had a normal length, but contained CRC errors.
frame
Total number of inbound frames that contained CRC errors and a non-integer number of bytes.
overruns
Number of packets dropped because the input rate of the port exceeded the queuing capability.
aborts
Total number of illegal inbound packets:
·     Fragment frames—CRC error frames shorter than 64 bytes. The length (in bytes) can be an integral or non-integral value.
·     Jabber frames—CRC error frames greater than the maximum frame length supported on the Ethernet interface (with an integral or non-integral length).
¡     For an Ethernet interface that does not permit jumbo frames, the maximum frame length is 1518 bytes (without VLAN tags) or 1522 bytes (with VLAN tags).
¡     For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface.
·     Symbol error frames—Frames that contained a minimum of one undefined symbol.
·     Unknown operation code frames—Non-pause MAC control frames.
·     Length error frames—Frames whose 802.3 length fields did not match the actual frame length (46 to 1500 bytes).
ignored
Number of inbound frames dropped because the receiving buffer of the port ran low.
parity errors
Total number of frames with parity errors.
Output(total): 0 packets, 0 bytes
The two fields on the first line represent the outbound traffic statistics (in packets and bytes) for the interface. All outbound normal packets, abnormal packets, and normal pause frames were counted.
·     Number of outbound unicast packets.
·     Number of outbound broadcasts.
·     Number of outbound multicasts.
·     Number of outbound pause frames.
Output(normal): 0 packets, 0 bytes
The two fields on the first line represent the outbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
·     Number of outbound normal unicast packets.
·     Number of outbound normal broadcasts.
·     Number of outbound normal multicasts.
·     Number of outbound normal pause frames.
output errors
Number of outbound packets with errors.
underruns
Number of packets dropped because the output rate of the interface exceeded the output queuing capability. This is a low-probability hardware anomaly.
buffer failures
Number of packets dropped because the transmitting buffer of the interface ran low.
aborts
Number of packets that failed to be transmitted, for example, because of Ethernet collisions.
deferred
Number of frames that the interface deferred to transmit because of detected collisions.
collisions
Number of frames that the interface stopped transmitting because Ethernet collisions were detected during transmission.
late collisions
Number of frames that the interface deferred to transmit after transmitting their first 512 bits because of detected collisions.
lost carrier
Number of carrier losses during transmission. This counter increases by one when a carrier is lost, and applies to serial WAN interfaces.
no carrier
Number of times that the port failed to detect the carrier when attempting to send frames. This counter increases by one when a port failed to detect the carrier, and applies to serial WAN interfaces.
Peak input rate
Peak rate of inbound traffic in Bps, and the time when the peak inbound traffic rate occurred.
Peak output rate
Peak rate of outbound traffic in Bps, and the time when the peak outbound traffic rate occurred.
IPv4 packet statistics.
IPv6 packet statistics.
Average inbound traffic rate (in pps and Bps) in the last 300 seconds.
Average outbound traffic rate (in pps and Bps) in the last 300 seconds.
Inbound traffic statistics (in packets and bytes) for the interface.
Outbound traffic statistics (in packets and bytes) for the interface.
# Display brief information of all interfaces except subinterfaces.
<Sysname> display interface brief main
Interface            Link Protocol Primary IP      Description
XGE0/0/6              DOWN DOWN     --
Loop0                UP   UP(s)    2.2.2.9
NULL0                UP   UP(s)    --
Vlan1                UP   DOWN     --
Vlan999              UP   UP       192.168.1.42
Speed: (a) - auto
XGE0/0/7              DOWN auto    A      A    1
# Display brief information about all interfaces except subinterfaces, including the complete interface descriptions.
<Sysname> display interface  brief description main
Speed: (a) - auto
XGE0/0/8              UP   auto    F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display information about interfaces except subinterfaces in DOWN state and the link-down causes.
<Sysname> display interface brief down main
XGE0/0/6              DOWN Not connected
Vlan2                DOWN Not connected
XGE0/0/7              DOWN Not connected
Table 5 Command output
Brief information about Layer 3 interfaces.
Interface name.
Link
Protocol
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Description of the interface.
Brief information of interfaces in bridge mode:
Brief information about Layer 2 interfaces.
Type: A - access; T - trunk; H – hybrid
Link type options for interfaces.
Speed
Speed of the interface, in bps.
This field displays the (a) flag next to the speed if the speed is automatically negotiated.
This field displays auto if the interface is configured to autonegotiate its speed but the autonegotiation has not started.
Duplex
Duplex mode of the interface:
·     A—Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started.
·     F—Full duplex.
·     F(a)—Autonegotiated full duplex.
·     H—Half duplex.
·     H(a)—Autonegotiated half duplex.
·     A—Access.
·     H—Hybrid.
·     T—Trunk.
PVID
Port VLAN ID.
Cause
Cause for the physical link state of an interface to be DOWN:
·     Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     DOWN ( Link-Aggregation interface down )—The interface is a member port of an aggregate interface, and the aggregate interface is down.
·     DOWN (Loopback detection down)—The loopback detection module has detected loops.
·     Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty).
·     Standby—The interface is a backup interface in standby state.
Use reset counters interface to clear the interface statistics.
reset counters interface [ interface-type [ interface-number | interface-number.subnumber ] ]
interface-number.subnumber: Specifies a subinterface number. The interface-number argument is an interface number. The subnumber argument is the number of a subinterface created under the interface. The value range for the subnumber argument is 1 to 4094.
Use this command to clear history statistics if you want to collect traffic statistics for a specific time period.
If you do not specify an interface type, this command clears statistics for all interfaces.
If you specify an interface type but do not specify an interface number, this command clears statistics for all interfaces of the specified type.
# Clear the statistics for Ten-GigabitEthernet 0/0/6.
<Sysname> reset counters interface ten-gigabitethernet 0/0/6
display counters interface
shutdown
Use shutdown to shut down an interface.
Use undo shutdown to bring up an interface.
shutdown
An Ethernet interface is up.
Interface view
CAUTION
CAUTION:
Executing the shutdown command on an interface will disconnect the link of the interface and interrupt communication. Use this command with caution.
Some interface configurations might require an interface restart before taking effect.
# Shut down and then bring up Ten-GigabitEthernet 0/0/6.
[Sysname-Ten-GigabitEthernet0/0/6] shutdown
[Sysname-Ten-GigabitEthernet0/0/6] undo shutdown
