07-IP Multicast Command Reference
HomeSupportRoutersCR16000-M SeriesReference GuidesCommand ReferencesH3C CR16000-M Routers Command Reference-R8530Pxx-6W10107-IP Multicast Command Reference
02-PIM snooping commands
02-PIM snooping commands 104.44 KB
display pim-snooping neighbor
Use display pim-snooping neighbor to display PIM snooping neighbor information.
display pim-snooping neighbor [ vlan vlan-id | vsi vsi-name ] [ verbose ] [ slot slot-number ]
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays PIM snooping neighbor information for all VLANs.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays PIM snooping neighbor information for all VSIs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays PIM snooping neighbor information on the active MPU.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# Display detailed information about PIM snooping neighbors for VLAN 2.
<Sysname> display pim-snooping neighbor vlan 2 verbose
Total 2 neighbors.
VLAN 2: Total 2 neighbors.
  10.1.1.2
    Slots (0 in total):
    Ports (1 in total):
      XGE3/0/1                              (02:02:23)    LAN Prune Delay(T)
  10.1.1.3
    Slots (0 in total):
    Ports (1 in total):
      XGE3/0/2                              (02:02:25)
# Display PIM snooping neighbor information for VSI aaa.
<Sysname> display pim-snooping neighbor vsi aaa
Total 2 neighbors.
VSI aaa: Total 2 neighbors.
  10.0.0.1
    Slots (0 in total):
    Ports (1 in total):
      AC (VSI index 0 Link ID 2)          (00:01:32)
  10.0.0.4
    Slots (0 in total):
    Ports (1 in total):
      AC (VSI index 0 Link ID 1)          (00:01:41)
Total 2 neighbors
Total number of PIM snooping neighbors.
Total number of PIM snooping neighbors in VLAN 2.
Total number of PIM snooping neighbors in VSI aaa.
10.1.1.2
IP address of the PIM snooping neighbor.
Slots (0 in total)
Slot numbers and total number of the cards that have the neighbor, except for the specified card or the MPU when no card is specified.
Ports (1 in total)
Ports where the PIM snooping neighbors reside, and the total number of the ports.
(02:02:23)
Remaining aging timer for a PIM snooping neighbor on the port.
This field is always displayed for global ports (such as Layer 2 aggregate interfaces, ACs, N-PWs, and U-PWs).
For a non-global port, this field is displayed when one of the following conditions exists:
·     The port is on the specified card.
·     The port is on the MPU and no card is specified.
LAN Prune Delay
The PIM hello message sent by the PIM snooping neighbor has the LAN_Prune_Delay option.
(T)
The join message suppression feature has been disabled for the PIM snooping neighbor.
AC interface, and its VSI index and link ID.
NPW (VSI index 0 Link ID 1)
N-PW interface, and its VSI index and link ID.
UPW (VSI index 0 Link ID 1)
U-PW interface, and its VSI index and link ID.
display pim-snooping router-port
Use display pim-snooping router-port to display PIM snooping router port information.
display pim-snooping router-port [ vlan vlan-id | vsi vsi-name ] [ slot slot-number ]
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays PIM snooping router port information for all VLANs.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays PIM snooping router port information for all VSIs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays PIM snooping router port information on the active MPU.
PIM snooping router port information is available only when the device receives fragmented PIM Join messages from PIM snooping neighbor ports.
# Display PIM snooping router port information for VLAN 2.
<Sysname> display pim-snooping router-port vlan 2
VLAN 2:
  Router slots (0 in total):
  Router ports (2 in total):
    XGE3/0/1                              (00:01:30)
    XGE3/0/2                              (00:01:32)
# Display PIM snooping router port information for VSI aaa.
<Sysname> display pim-snooping router-port vsi aaa
VSI aaa:
    AC (VSI index 0 Link ID 0)          (00:02:50)
    AC (VSI index 0 Link ID 1)          (00:02:59)
VLAN 2
VLAN ID.
VSI aaa
VSI name.
Slot numbers and total number of the cards that have router ports, except for the specified card or the MPU when no card is specified.
Router ports and total number of router ports.
(00:01:30)
Remaining aging time for the router port.
For a global port, this field is always displayed.
display pim-snooping routing-table
Use display pim-snooping routing-table to display PIM snooping routing entries.
display pim-snooping routing-table [ vlan vlan-id | vsi vsi-name ] [ verbose ] [ slot slot-number ]
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays PIM snooping routing entries for all VLANs.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays PIM snooping routing entries for all VSIs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays PIM snooping routing entries on the active MPU.
verbose: Displays detailed information. If you do not specify the keyword, this command displays brief information.
# Display detailed information about PIM snooping routing entries for VLAN 2.
<Sysname> display pim-snooping routing-table vlan 2 verbose
Total 1 entries.
FSM Flag: NI-no info, J-join, PP-prune pending
VLAN 2: Total 1 entries.
  (172.10.10.1, 225.1.1.1)
    FSM information: normal
    Upstream neighbor: 20.1.1.1
      Upstream Slots (0 in total):
      Upstream Ports (1 in total):
        XGE3/0/1
      Downstream Slots (0 in total):
      Downstream Ports (2 in total):
        XGE3/0/2
          Expires: 00:03:01, FSM: J
          Downstream Neighbors (2 in total):
            7.1.1.1
              Expires: 00:59:19, FSM: J
            7.1.1.11
              Expires: 00:59:20, FSM: J
        XGE3/0/3
          Expires: 00:02:21, FSM: PP
# Display PIM snooping routing entries for VSI aaa.
<Sysname> display pim-snooping routing-table vsi aaa
Total 1 entries.
VSI aaa: Total 1 entries.
      Downstream Ports (1 in total):
           Expires: 00:03:23, FSM: J
Total 1 entries
Total number of (S, G) entries and (*, G) entries.
State machine flag of the downstream port:
·     NI—Initial state.
·     J—Join.
·     PP—Prune pending.
Total number of (S, G) entries and (*, G) entries in VLAN 2.
Total number of (S, G) entries and (*, G) entries in VSI aaa.
(S, G) entry.
FSM information
Finite state machine information of the entry:
·     delete—The entry attributes have been deleted.
·     dummy—The entry is a new temporary entry.
·     no info—The entry does not exist.
·     normal—The entry is a correct entry.
Upstream neighbor
Upstream neighbor of the (S, G) or (*, G) entry.
Slot numbers and total number of the cards that have the upstream neighbor, except for the specified card or the MPU when no card is specified.
Upstream ports, and the total number of upstream ports.
This field is displayed when one of the following conditions exists:
Slot numbers and total number of the cards that have downstream ports, except for the specified card or the MPU when no card is specified.
Downstream ports of the upstream neighbor, and the total number of the downstream ports.
Downstream neighbors of the downstream port, and the total number of the downstream neighbors.
Remaining aging time for the downstream port or downstream neighbor, and the finite state machine information.
display pim-snooping statistics
Use display pim-snooping statistics to display statistics for the PIM messages learned through PIM snooping.
# Display statistics for the PIM messages learned through PIM snooping.
<Sysname> display pim-snooping statistics
Received PIMv2 hello:  100
Received PIMv2 join/prune:  100
Received PIMv2 error:  0
Received PIMv2 messages in total:  200
Received PIMv1 messages in total:  0
Number of received PIMv2 hello messages.
Number of received PIMv2 join/prune messages.
Number of received PIMv2 messages with errors.
Total number of received PIMv2 messages.
Total number of received PIMv1 messages.
reset pim-snooping statistics
pim-snooping enable
Use pim-snooping enable to enable PIM snooping for a VLAN or VSI.
Use undo pim-snooping enable to disable PIM snooping for a VLAN or VSI.
pim-snooping enable
PIM snooping is disabled for a VLAN or VSI.
VLAN view
VSI view
You must enable IGMP snooping feature and enable IGMP snooping for a VLAN or VSI before you enable PIM snooping for the VLAN or VSI.
PIM snooping does not take effect on sub-VLANs of a multicast VLAN.
# Enable IGMP snooping globally, and enable IGMP snooping and PIM snooping for VLAN 2.
[Sysname] igmp-snooping
[Sysname-igmp-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping enable
[Sysname-vlan2] pim-snooping enable
# Enable IGMP snooping globally, and enable IGMP snooping and PIM snooping for VSI aaa.
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping enable
[Sysname-vsi-aaa] pim-snooping enable
igmp-snooping
pim-snooping graceful-restart join-aging-time
Use pim-snooping graceful-restart join-aging-time to set the aging time for global downstream ports and global router ports after an active/standby switchover.
Use undo pim-snooping graceful-restart join-aging-time to restore the default.
pim-snooping graceful-restart join-aging-time seconds
The aging time is 210 seconds for global neighbor ports after an active/standby switchover.
VLAN view
VSI view
seconds: Specifies an aging time in the range of 210 to 18000 seconds.
You must enable PIM snooping for a VLAN or VSI before you execute this command.
For a global router port or global downstream port, the set aging time does not take effect when the port receives a PIM join message after an active/standby switchover. The aging time for the port is determined by the aging time in the PIM join message.
# In VLAN 2, set the aging time to 600 seconds for global downstream ports and global router ports after an active/standby switchover.
[Sysname] vlan 2
[Sysname-vlan2] pim-snooping graceful-restart join-aging-time 600
# In VSI aaa, set the aging time to 600 seconds for global downstream ports and global router ports after an active/standby switchover.
[Sysname] vsi aaa
[Sysname-vsi-aaa] pim-snooping graceful-restart join-aging-time 600
pim-snooping enable
pim-snooping graceful-restart neighbor-aging-time
Use pim-snooping graceful-restart neighbor-aging-time to set the aging time for global neighbor ports after an active/standby switchover.
Use undo pim-snooping graceful-restart neighbor-aging-time to restore the default.
pim-snooping graceful-restart neighbor-aging-time seconds
The aging time is 105 seconds for global neighbor ports after an active/standby switchover.
VLAN view
VSI view
seconds: Specifies an aging time in the range of 105 to 18000 seconds.
You must enable PIM snooping in a VLAN or VSI before you execute this command.
For a global neighbor port, the set aging time does not take effect when the global neighbor port receives a PIM hello message after an active/standby switchover. The aging time for the global port is determined by the aging time in the PIM hello message.
# In VLAN 2, set the aging time to 300 seconds for global neighbor ports after an active/standby switchover.
[Sysname] vlan 2
[Sysname-vlan2] pim-snooping graceful-restart neighbor-aging-time 300
# In VSI aaa, set the aging time to 300 seconds for global neighbor ports after an active/standby switchover.
[Sysname] vsi aaa
[Sysname-vsi-aaa] pim-snooping graceful-restart neighbor-aging-time 300
pim-snooping enable
Use reset pim-snooping statistics to clear statistics for the PIM messages learned through PIM snooping.
# Clear statistics for the PIM messages learned through PIM snooping.
<Sysname> reset pim-snooping statistics
