                        - 15-Network Management and Monitoring Configuration Guide
- 02-NQA configuration
- 03-iNQA configuration
- 04-iFIT configuration
- 05-SRPM configuration
- 06-NTP configuration
- 07-PTP configuration
- 08-Network synchronization configuration
- 09-SNMP configuration
- 10-RMON configuration
- 11-NETCONF configuration
- 12-CWMP configuration
- 13-EAA configuration
- 14-Process monitoring and maintenance configuration
- 15-Sampler configuration
- 16-Mirroring configuration
- 17-NetStream configuration
- 18-IPv6 NetStream configuration
- 19-TCP connection trace configuration
- 20-Performance management configuration
- 21-Fast log output configuration
- 22-Flow log configuration
- 23-Information center configuration
- 24-Packet capture configuration
- 25-Flow monitor configuration
| 00-Preface | 110.62 KB |
Preface
This configuration guide describes features that help you manage and monitor your network, for example, manage system events, collect traffic statistics, sample packets, assess network performance, and test network connectivity.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the routers.
Conventions
Command conventions
| Convention | Description |
| Boldface | Bold text represents commands and keywords that you enter literally as shown. |
| Italic | Italic text represents arguments that you replace with actual values. |
| [ ] | Square brackets enclose syntax choices (keywords or arguments) that are optional. |
| { x | y | ... } | Braces enclose a set of required syntax choices separated by vertical bars, from which you select one. |
| [ x | y | ... ] | Square brackets enclose a set of optional syntax choices separated by vertical bars, from which you select one or none. |
| { x | y | ... } * | Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select a minimum of one. |
| [ x | y | ... ] * | Asterisk marked square brackets enclose optional syntax choices separated by vertical bars, from which you select one choice, multiple choices, or none. |
| &<1-n> | The argument or keyword and argument combination before the ampersand (&) sign can be entered 1 to n times. |
| # | A line that starts with a pound (#) sign is comments. |
GUI conventions
| Boldface | Window names, button names, field names, and menu items are in Boldface. For example, the New User window opens; click OK. |
| > | Multi-level menus are separated by angle brackets. For example, File > Create > Folder. |
Symbols
| An alert that calls attention to important information that if not understood or followed can result in personal injury. | |
| An alert that calls attention to important information that if not understood or followed can result in data loss, data corruption, or damage to hardware or software. | |
| An alert that calls attention to essential information. | |
| NOTE: | An alert that contains additional or supplementary information. |
| An alert that provides helpful information. |
Network topology icons
| Represents a generic network device, such as a router, switch, or firewall. | |
| Represents a routing-capable device, such as a router or Layer 3 switch. | |
| Represents a generic switch, such as a Layer 2 or Layer 3 switch, or a router that supports Layer 2 forwarding and other Layer 2 features. | |
| Represents an access controller, a unified wired-WLAN module, or the access controller engine on a unified wired-WLAN switch. | |
| Represents an access point. | |
| Represents a wireless terminator unit. | |
| Represents a wireless terminator. | |
| Represents a mesh access point. | |
| Represents omnidirectional signals. | |
| Represents directional signals. | |
| Represents a security product, such as a firewall, UTM, multiservice security gateway, or load balancing device. | |
| Represents a security module, such as a firewall, load balancing, NetStream, SSL VPN, IPS, or ACG module. |
Documentation feedback
We appreciate your comments.
 Login
Login
