03-Interface Configuration Guide
HomeSupportRoutersCR16000-F SeriesConfigure & DeployConfiguration GuidesH3C CR16000-F Routers Configuration Guides-R8530Pxx-6W10103-Interface Configuration Guide
06-ATM interface configuration
06-ATM interface configuration 130.25 KB
Configuring ATM interfaces
This chapter covers the physical configurations of ATM interfaces. For information about configuring ATM services, see Layer 2—WAN Configuration Guide.
About ATM interfaces
ATM
Asynchronous Transfer Mode (ATM) is a technology based on packet transmission mode and incorporates the high-speed of circuit transmission mode. It is a backbone network technology for transmission of audio, video, and data. Because of its flexibility and support for multimedia services, ATM is regarded as a core technology for implementing broadband communications.
The ATM physical layer is at the bottom of the ATM reference model. It primarily delivers valid cells and the associated timing signals between the upper layer and transmission medium. The speeds of physical access media are defined in international standards such as ATM OC-3c/STM-1 and ATM OC-12c/STM-4.
ATM interface types
The device supports the following ATM interface types:
·     ATM OC-3c/STM-1 based on SONET/SDH—Operates in 155 Mbps.
·     ATM OC-12c/STM-4 based on SONET/SDH—Operates in 622 Mbps.
ATM interface applications
An ATM interface supports IPoA.
ATM interface features
ATM interfaces support the following features:
·     Constant Bit Rate (CBR).
·     Unspecified Bit Rate (UBR).
·     Variable Bit Rate-Real Time (VBR-RT).
·     Variable Bit Rate-Non Real Time (VBR-NRT).
·     Permanent Virtual Circuit (PVC).
·     Traffic Shaping based on Virtual Circuit (VC).
·     User-to-Network Interface (UNI).
·     RFC1483, Multiprotocol Encapsulation over ATM Adaptation Layer 5.
·     RFC 2225, Classical IP and ARP over ATM.
·     RFC 2390, Inverse Address Resolution Protocol.
·     F5 End to End Loopback OAM.
·     ATM Adaptation Layer 5 (AAL5).
Configuring the operating mode of an interface subcard
The MIC-SP4L interface subcards can operate in different modes to provide different types of interfaces. To change the operating mode for such an interface card, execute the card-mode command. You must make sure an ATM interface card is operating in the desired mode before you configure the interfaces on it.
For more information about interface subcard operating mode configuration, see device management in Fundamentals Configuration Guide.
Configuring an ATM OC-3c/STM-1 or ATM OC-12c/STM-4 interface
Configuring basic settings of an ATM OC-3c/STM-1 or ATM OC-12c/STM-4 interface
2.     Enter ATM OC-3c/STM-1 or ATM OC-12c/STM-4 interface view.
interface atm interface-number
3.     (Optional.) Configure the interface description.
By default, the description is interface-name Interface.
4.     Configure the clock mode for the interface.
clock { master | slave }
By default, the clock mode is slave.
When the ATM interfaces on two devices are connected directly through a fiber-optic cable, set the clock mode to master at one end and to slave at the other end. The clock of the SONET/SDH network is more precise than the internal clock of ATM interfaces. When an ATM interface is connected to a SONET/SDH device, set the clock mode of the ATM interface to slave.
5.     Configure the frame format for the interface.
frame-format { sdh | sonet }
By default, the frame format is SDH.
6.     (Optional.) Configure the expected bandwidth for the interface.
bandwidth bandwidth-value
By default, the expected bandwidth (in kbps) is calculated by using the following formula: Interface baud rate/1000.
7.     Bring up the interface.
By default, the interface is up.
Configuring physical state change suppression interval on an ATM OC-3c/STM-1 or ATM OC-12c/STM-4 interface
The physical link state of an interface is either up or down. Each time the physical link of an interface comes up or goes down, the system then performs the following operations:
·     Notifies the upper-layer protocol modules (such as routing and forwarding modules) of the change immediately for guiding packet forwarding.
·     Automatically generates traps and logs to inform users to take the correct actions.
To prevent frequent physical link flapping from affecting system performance, configure physical state change suppression. You can configure this feature to suppress only link-down events, only link-up events, or both. If an event of the specified type still exists when the suppression interval expires, the system reports the event.
3.     Set the physical state change suppression interval on the interface.
link-delay seconds
By default, the physical state change suppression interval is one second.
Configuring alarm actions for an interface
Signal degrade (SD) and signal fail (SF) alarms are used to indicate the current line performance. When a small number of bit errors occur, the interface sends an SD alarm. When a large number of bit errors occur, the line performance degrades seriously and the interface sends an SF alarm.
When the device receives multiplexer section remote defect indication (MS-RDI) signals from the remote end, an RDI alarm occurs.
You can configure the ATM OC-3c/STM-1 or ATM OC-12c/STM-4 interface to go down automatically when an RDI, SD, or SF alarm is detected on the interface.
3.     Configure the action to take when an RDI, SD, or SF alarm occurs on the ATM OC-3c/STM-1 or ATM OC-12c/STM-4 interface.
alarm-detect { rdi | sd | sf } action link-down
By default, the device does not take any actions on the interface when an RDI, SD, or SF alarm occurs.
Enabling payload scrambling on an ATM OC-3c/STM-1 or ATM OC-12c/STM-4 interface
Payload scrambling enables an interface to scramble outgoing data and descramble incoming data. By preventing the presence of long strings of all 1s or all 0s, payload scrambling enables the receiving end to extract the line clock signal correctly.
The payload scrambling setting must be the same at both ends of a link to ensure correct communication.
3.     Enable payload scrambling.
scramble
By default, payload scrambling is enabled.
Configuring overhead byte on an ATM OC-3c/STM-1 or ATM OC-12c/STM-4 interface
J0 byte is a section overhead byte. SDH and SONET use this byte to test continuity of the connection between two interfaces at the section level.
J1 byte is a higher-order path overhead byte. SDH and SONET use this byte to test continuity of the connection between two interfaces at the path level.
The C2 byte is a higher-order path overhead byte. It indicates the multiplex structure of virtual container (VC) frames and the property of payload.
When the C2 byte of one end is set to 1, the C2 byte of the other end can be set to any character in hexadecimal notation. If the C2 byte of either ends of a link is not set to 1, the C2 byte must be the same at both ends.
The J1 settings on the sending and receiving ends must be the same.
The J0 byte can be any character in the network of the same carrier. On networks of two carriers, the sending and receiving devices at network borders must use the same J0 byte.
3.     Configure the C2 path signal label byte.
flag c2 flag-value
By default, the C2 byte is 13 in hexadecimal notation.
4.     Configure the J0 regenerator section trace byte.
flag j0 { sdh | sonet } flag-value
By default, the system uses the SDH framing format, and the J0 byte is CR16000 in SDH frames.
5.     Configure the J1 path trace byte.
flag j1 { sdh | sonet } flag-value
By default, the system uses the SDH framing format, and the J1 byte is CR16000 in SDH frames.
Configuring the MTU for an ATM OC-3c/STM-1 or ATM OC-12c/STM-4 interface
The MTU setting affects the assembly and fragmentation of IP packets.
3.     Set the MTU.
mtu size
The default setting is 1500 bytes.
Enabling loopback on an ATM OC-3c/STM-1 or ATM OC-12c/STM-4 interface
Perform this task to determine whether an ATM OC-3c/STM-1 or ATM OC-12c/STM-4 link works correctly.
Loopback includes the following types:
·     Internal cell loopback—Checks physical chips on the local end.
·     Internal loopback—Checks service chips on the local end.
·     External line loopback—Checks the remote end.
Loopback is intended for testing only. Disable loopback when the interface is operating correctly.
After you enable this feature on an ATM OC-3c/STM-1 or ATM OC-12c/STM-4 interface, the interface does not forward data traffic.
3.     Enable loopback.
loopback { cell | local | remote }
By default, loopback is disabled.
Restoring the default settings for an ATM OC-3c/STM-1 or ATM OC-12c/STM-4 interface
This feature might interrupt ongoing network services. Make sure you are fully aware of the impact of this feature when you use it on a live network.
This feature might fail to restore the default settings for some commands because of command dependencies or system restrictions. You can use the display this command in interface view to check for these commands and perform their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message to resolve the problem.
3.     Restore the default settings for the interface.
default
Configuring an ATM subinterface
About ATM subinterfaces
An ATM subinterface supports the same network layer functions as an ATM interface. The network layers of different ATM subinterfaces are independent of each other. You can configure different Layer 3 services for ATM subinterfaces, such as IP services and MPLS services. To enable an ATM interface to support multiple Layer 3 services, create multiple subinterfaces for the interface.
The rate of an ATM subinterface depends on the rates of the PVCs configured on the subinterfaces.
Configuring basic settings of an ATM subinterface
2.     Create an ATM subinterface and enter its view.
interface atm interface-number.subnumber [ p2mp | p2p ]
3.     (Optional.) Configure the subinterface description.
4.     (Optional.) Configure the expected bandwidth for the subinterface.
5.     Bring up the subinterface.
By default, the subinterface is up.
Configuring the MTU for an ATM subinterface
2.     Enter ATM subinterface view.
3.     Set the MTU.
mtu size
Restoring the default settings for an ATM subinterface
CAUTION
CAUTION:
default
Display and maintenance commands for ATM interfaces
Display ATM interface information.
display interface [ atm [ interface-number ] ] [ brief [ description | down ] ]
Display the physical attributes of an interface.
display interface [ interface-type [ interface-number ] ] phy-option
Display the operating status and information of an interface.
display this interface
Display interface traffic statistics.
display counters { inbound | outbound } interface [ atm [ interface-number ] ]
Display traffic rate statistics for interfaces in up state for the most recent statistics interval.
display counters rate { inbound | outbound } interface [ atm [ interface-number ] ]
Clear the statistics for an interface.
reset counters interface [ atm [ interface-number ] ]
Troubleshooting ATM interfaces
Interface state error
Symptom
The ATM interface state is down.
Solution
To resolve the problem:
1.     Verify that the Rx and Tx ends of the optical fiber are correctly connected.
2.     If the two devices are connected back-to-back, verify that the clock mode is set to master on one interface, and to slave on the other interface. The default clock mode is slave. To set the clock mode to master, use the clock master command.
3.     If the problem persists, contact H3C Support.
Frequent packet dropping, CRC check errors, and interface state errors
Symptom
Two devices connecting back-to-back can ping each other successfully. Frequent packet dropping and CRC errors occur, and the interface state flaps between up and down.
Solution
1.     Verify that the ATM interfaces of the two sides are of the same type, for example, multimode fiber interfaces or single-mode fiber interfaces.
If a multimode fiber interface and a single-mode fiber interface are directly connected, they can communicate in most cases. However, frequent packet dropping, CRC errors, and interface state errors might occur.
2.     If the problem persists, contact H3C Support.
