- 15-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-iNQA commands
- 04-iFIT commands
- 05-SRPM commands
- 06-NTP commands
- 07-PTP commands
- 08-Network synchronization commands
- 09-SNMP commands
- 10-RMON commands
- 11-NETCONF commands
- 12-CWMP commands
- 13-EAA commands
- 14-Process monitoring and maintenance commands
- 15-Sampler commands
- 16-Mirroring commands
- 17-NetStream commands
- 18-IPv6 NetStream commands
- 19-TCP connection trace commands
- 20-Performance management commands
- 21-Fast log output commands
- 22-Flow log commands
- 23-Information center commands
- 24-Packet capture commands
- 25-Flow monitor commands
17-NetStream commands | 277.59 KB |
display ip netstream cache archive
ip netstream cache archive enable
ip netstream export host (NetStream aggregation mode view)
ip netstream export host (system view)
ip netstream export template refresh-rate
ip netstream outbound sampler srv6-policy
ip netstream outbound srv6-policy
NetStream commands
Use display ip netstream cache to display NetStream entry information.
In standalone mode:
display ip netstream cache [ verbose ] [ type { ip | ipl2 | l2 | mpls [ label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] ] } ] [ destination destination-ip | destination-port destination-port | interface interface-type interface-number | protocol protocol | source source-ip | source-port source-port ] * [ arrived-time start-date start-time end-date end-time ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display ip netstream cache [ verbose ] [ type { ip | ipl2 | l2 | mpls [ label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] ] } ] [ destination destination-ip | destination-port destination-port | interface interface-type interface-number | protocol protocol | source source-ip | source-port source-port ] * [ arrived-time start-date start-time end-date end-time ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
verbose: Displays detailed information about NetStream entries. If you do not specify this keyword, this command displays brief information about NetStream entries.
type: Specifies the NetStream entry type. If you do not specify this keyword, this commands displays information about all types of NetStream entries.
ip: Specifies Layer 3 NetStream entries.
ipl2: Specifies Layer 2 and Layer 3 NetStream entries.
l2: Specifies Layer 2 NetStream entries.
mpls: Specifies MPLS NetStream entries.
label-position1 label-value1: Specifies a label by its position and value. The value range for the label-position1 argument is 1 to 10, representing labels from the outermost to the innermost. The value range for the label-value1 argument is 0 to 1048575.
label-position2 label-value2: Specifies a label by its position and value. The value range for the label-position2 argument is 1 to 10 except for specified values, representing labels from the outermost to the innermost. The value range for the label-value2 argument is 0 to 1048575.
label-position3 label-value3: Specifies a label by its position and value. The value range for the label-position3 argument is 1 to 10 except for specified values, representing labels from the outermost to the innermost. The value range for the label-value3 argument is 0 to 1048575.
destination destination-ip: Specifies a destination IP address in dotted-decimal notation. If you specify this option, this command does not display Layer 2 NetStream entries.
destination-port destination-port: Specifies a destination port number in the range of 0 to 65535. If you specify this option, this command does not display Layer 2 NetStream entries.
protocol protocol: Specifies a protocol by its number in the range of 0 to 255 or by its name such as GRE, OSPF, TCP, or UDP. If you specify this option, this command does not display Layer 2 NetStream entries.
source source-ip: Specifies a source IP address in dotted-decimal notation. If you specify this option, this command does not display Layer 2 NetStream entries.
source-port source-port: Specifies a source port number in the range of 0 to 65535. If you specify this option, this command does not display Layer 2 NetStream entries.
arrived-time: Specifies an arrived time range to display NetStream entries. If you do not specify this keyword, the arrived time is not used as a criterion for filtering the NetStream entries to be displayed.
start-date: Specifies the start date in the format of MM/DD/YYYY or YYYY/MM/DD, where MM is in the range of 1 to 12 and YYYY is in the range of 2000 to 2035. The value range for DD varies by the value of MM.
start-time: Specifies the start time in the format of HH:MM:SS, where HH is in the range of 0 to 23, MM and SS are in the range of 0 to 59. The SS element can be omitted if its value is 00. Both the SS and MM elements can be omitted if their values are 0. For example, the start time of 0 indicates 00:00:00.
end-date: Specifies the end date in the format of MM/DD/YYYY or YYYY/MM/DD, where MM is in the range of 1 to 12 and YYYY is in the range of 2000 to 2035. The value range for DD varies by the value of MM.
end-time: Specifies the end time in the format of HH:MM:SS, where HH is in the range of 0 to 23, MM and SS are in the range of 0 to 59. The SS element can be omitted if its value is 00. Both the SS and MM elements can be omitted if their values are 0. For example, the end time of 0 indicates 00:00:00.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information about NetStream entries on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information about NetStream entries on all cards. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. This option is available only if multiple CPUs are available on the specified slot.
# Display detailed information about NetStream entries.
<Sysname> display ip netstream cache verbose
IP NetStream cache information:
Active flow timeout : 60 min
Inactive flow timeout : 10 sec
Max number of entries : 1000
IP active flow entries : 1
MPLS active flow entries : 1
L2 active flow entries : 0
IPL2 active flow entries : 0
IP flow entries counted : 10
MPLS flow entries counted : 20
L2 flow entries counted : 10
IPL2 flow entries counted : 20
Last statistics resetting time : 01/01/2000 at 00:01:02
IP packet size distribution (1103746 packets in total):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.249 .694 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608 >4608
.000 .000 .027 .000 .027 .000 .000 .000 .000 .000 .000 .000
Protocol Total Packets Flows Packets Active(sec) Idle(sec)
Flows /sec /sec /flow /flow /flow
TCP-Telnet 2656855 372 4 86 49 27
TCP-FTP 5900082 86 9 9 11 33
TCP-FTPD 3200453 1006 5 193 45 33
TCP-WWW 546778274 11170 887 12 8 32
TCP-other 49148540 3752 79 47 30 32
UDP-DNS 117240379 570 190 3 7 34
UDP-other 45502422 2272 73 30 8 37
ICMP 14837957 125 24 5 12 34
IP-other 77406 5 0 47 52 27
Type DstIP(Port) SrcIP(Port) Pro ToS VNI If(Direct) Pkts
DstMAC(VLAN) SrcMAC(VLAN)
TopLblType(IP/Mask) Lbl-Exp-S-List
IP 11.1.1.1(1024) 11.1.1.2(21) 6 128 10 XGE3/1/1(I) 42996
TCPFlag: 27 TTL: 64
DstMask: 24 SrcMask: 24 NextHop: 0.0.0.0
DstAS: 0 SrcAS: 0 BGPNextHop: 0.0.0.0
InVRF: mvpn
Bgp-community1: 0
Bgp-community2: 0
Bgp-community3: 0
Bgp-community4: 0
SamplerMode:Random SamplerInt: 256
Active: 5.600 Bytes/Pkt: 152
First packet arrived: 10/28/2013, 14:10:03
Last packet arrived: 10/28/2013, 14:21:03
SRv6 policy NID: 2150629378
IP& 172.16.1.1(68) 172.16.2.1(67) 17 64 N/A XGE3/1/3(I) 1848
MPLS LDP(4.4.4.4/24) 1:55-6-0
2:16-6-1
TCPFlag: 0
DstMask: 24 SrcMask: 24 NextHop: 172.16.2.10
InVRF: vpn1
Bgp-community1: 0
Bgp-community2: 0
Bgp-community3: 0
Bgp-community4: 0
SamplerMode:N/A SamplerInt: 0
Active: 5.542 Bytes/Pkt: 1426
First packet arrived: 10/28/2013, 14:12:03
Last packet arrived: 10/28/2013, 14:23:03
Active flow timeout |
Aging timer for active flows, in minutes. |
Inactive flow timeout |
Aging timer for inactive flows, in seconds. |
Max number of entries |
Maximum number of flows allowed in the cache. |
IP active flow entries |
Number of active IP flows in the cache. |
MPLS active flow entries |
Number of active MPLS flows in the cache. |
L2 active flow entries |
Number of active Layer 2 flows in the cache. |
IPL2 active flow entries |
Number of active Layer 2 and Layer 3 flows in the cache. |
IP flow entries counted |
Number of IP flows that have been counted. |
MPLS flow entries counted |
Number of MPLS flows that have been counted. |
L2 flow entries counted |
Number of Layer 2 flows that have been counted. |
IPL2 flow entries counted |
Number of Layer 2 and Layer 3 flows that have been counted. |
Last statistics resetting time |
Last time the reset ip netstream statistics command was executed. This field displays Never if you have never executed this command. |
IP packet size distribution (1103746 packets in total) |
Distribution of IP packets by packet size, and the bracketed number is the total number of IP packets. The value is displayed in the proportion of the number of IP packets of the specified sizes to the total number of IP packets, and the value is displayed with 3 decimal places. |
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480 512 544 576 1024 1536 2048 2560 3072 3584 4096 4608 |
Range of IP packet length (excluding data link layer header) in bytes. · For the values in the range of 1 to 576, the range increases in the step of 32. For example, 1-32 shows the number of packets with the size of 1 to 32 bytes. 64 shows the number of packets with the size of 33 to 64 bytes. · For the values greater than 1024, the range increases in the step of 512. For example, 1536 shows the number of packets with the size of 1025 to 1536 bytes. · Packets with the size of 577 to 1024 bytes are recorded in the 1024 entry. |
Protocol Total Flows Packets /sec Flows/sec Packets/flow Active(sec)/flow Idle(sec)/flow |
Statistics of packets by protocol type: · Protocol type. · Total number of flows. · Number of packets per second. · Number of flows per second. · Number of packets per flow. · Active time (in seconds) of each flow. · Inactive time (in seconds) of each flow. |
Type DstIP(Port) SrcIP(Port) Pro ToS VNI If(Direct) Pkts |
Statistics of the active flows in the current cache: · Flow type. Flows are classified into the following types: ¡ Layer 3 flows. ¡ Layer 2 flows. ¡ Layer 2 and Layer 3 flows. ¡ MPLS flows without IP options. ¡ MPLS flows with IP options. · Destination IP address (destination port). · Source IP address (source port). · Protocol number. · ToS. · VXLAN ID. The VNI field displays N/A for non-VXLAN packets and on VXLAN-incapable devices. · Interface name (direction). · Number of packets. ICMP packets do not contain port number fields, so the type and code fields are captured. The value for the destination port represents these two fields: · The highest 8 bits represent the type field. · The lowest 8 bits represent the code field. The value for the source port is set to 0 and does not indicate any statistics. NetStream sampling based on an SRv6 TE policy collects the destination IP address (destination port), source IP address (source port), protocol number, ToS, and VXLAN ID in the inner header of packets. |
DstMAC(VLAN) SrcMAC(VLAN) |
Layer 2 information of the active flows in the current cache: · Destination MAC address, followed by the destination VLAN ID in parenthesis. · Source MAC address, followed by the source VLAN ID in parenthesis. |
TopLblType(IP/Mask) Lbl-Exp-S-List |
Information about the active MPLS flows in the current cache: · TopLblType—Type of the labels at the top of the label stack. · IP/Mask—IP address and mask associated with the label. · Lbl—20-bit label value. · EXP—3-bit field for implementing QoS. · S—1-bit bottom of stack flag. The S field is set to 1 if the label is the bottom label and set to 0 if not. · List—Label list. Up to three labels can be listed in one label list. Use the mpls-position argument to specify the label position. |
TCPFlag: TTL: DstMask: SrcMask: NextHop: DstAS: SrcAS: BGPNextHop: OutVRF: InVRF: Bgp-community1: Bgp-community2: Bgp-community3: Bgp-community4: SamplerMode: SamplerInt: Active: Bytes/Pkt: First packet arrived: Last packet arrived: SRv6 policy NID: |
Other information about the active flows in the cache: · TCPFlag—TCP tag. · TTL. · DstMask—Destination mask. · SrcMask—Source mask. · NextHop—Routing next hop. · DstAS—Destination AS. · SrcAS—Source AS. · BGPNextHop—BGP next hop. · OutVRF—VPN instance to which the outbound packets belong. · InVRF—VPN instance to which the inbound packets belong. · SamplerMode—Sampling mode. NetStream supports the following sampling modes: ¡ N/A—No sampling. ¡ Fixed—Fixed sampling. ¡ Random—Random sampling. · Bgp-community—BGP community number. · SamplerInt—Sampling interval. · Active—Flow's active time. · Bytes/Pkt—Number of bytes per packet. · First packet arrived—Arrival time of the first packet of the flow. · Last packet arrived—Arrival time of the last packet of the flow. · SRv6 policy NID—NHLFE entry index for the SRv6 TE policy. NetStream sampling based on an SRv6 TE policy displays the following information in L3VPN service packets: · TCPFlag—TCP tag in the inner header. · TTL—TTL in the outer header. · DstMask—Destination mask in the outer header. · SrcMask—Source mask in the outer header. · NextHop—Routing next hop, fixed at 0.0.0.0. · DstAS—Destination AS in the outer header. · SrcAS—Source AS in the outer header. · BGPNextHop—BGP next hop, fixed at 0.0.0.0. · Bgp-community—BGP community number, fixed at 0. · Bytes/Pkt—Number of bytes per original packet. NetStream based on an SRv6 TE policy displays only the TTL for L2VPN service packets. Interface-specific NetStream displays the following information for packets that match an SRv6 TE policy: · TCPFlag—TCP tag in the inner header. · TTL—TTL in the outer header. · DstMask—Destination mask in the outer header, fixed at 0.0.0.0. · SrcMask—Source mask in the outer header, fixed at 0.0.0.0. · NextHop—Routing next hop, fixed at 0.0.0.0. · DstAS—Destination AS in the outer header. · SrcAS—Source AS in the outer header. · BGPNextHop—BGP next hop, fixed at 0.0.0.0. · Bytes/Pkt—Number of bytes per original packet. |
Use display ip netstream cache archive to display the locally archived NetStream entries.
In standalone mode:
display ip netstream cache archive [ verbose ] [ type { ip | ipl2 | l2 | mpls [ label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] ] } ] [ destination destination-ip | destination-port destination-port | interface interface-type interface-number | protocol protocol | source source-ip | source-port source-port ] * [ arrived-time start-date start-time end-date end-time ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display ip netstream cache archive [ verbose ] [ type { ip | ipl2 | l2 | mpls [ label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] ] } ] [ destination destination-ip | destination-port destination-port | interface interface-type interface-number | protocol protocol | source source-ip | source-port source-port ] * [ arrived-time start-date start-time end-date end-time ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
verbose: Displays detailed NetStream entry information.
label-position2 label-value2: Specifies a label by its position and value. The value range for the label-position2 argument is 1 to 10, representing labels from the outermost to the innermost. The value range for the label-value2 argument is 0 to 1048575.
label-position3 label-value3: Specifies a label by its position and value. The value range for the label-position3 argument is 1 to 10, representing labels from the outermost to the innermost. The value range for the label-value3 argument is 0 to 1048575.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information about locally archived NetStream entries on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information about locally archived NetStream entries on all cards. (In IRF mode.)
# Display information about the NetStream entries archived between 14:10:03 and 14:23:03 on July 28, 2017.
<Sysname> display ip netstream cache archive arrived-time 7/28/2017 14:10:03 7/28/2017 14:23:03
Type DstIP(Port) SrcIP(Port) Pro ToS VNI APPID If(Direct) Pkts
IP 11.1.1.1(1024) 11.1.1.2(21) 6 128 10 0xe XGE3/1/1(I) 42996
First packet arrived: 7/28/2017, 14:20:03
Last packet arrived: 7/28/2017, 14:21:03
display ip netstream export
Use display ip netstream export to display information about the NetStream data export.
In standalone mode:
display ip netstream export [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display ip netstream export [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays NetStream data export information on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays NetStream data export information on all cards. (In IRF mode.)
IP NetStream export information varies by aggregation mode. This command displays IP NetStream export information for all the configured aggregation modes.
# Display information about the NetStream data export.
<Sysname> display ip netstream export
IP export information:
Flow source interface : Ten-GigabitEthernet3/1/1
Flow destination VPN instance : VPN1
Flow destination IP address (UDP) : 10.10.0.10 (30000)
Version 5 exported flow number : 0
Version 5 exported UDP datagram number (failed) : 0 (0)
Version 9 exported flow number : 20
Version 9 exported UDP datagram number (failed) : 2 (0)
Version 10 exported flow number : 0
Version 10 exported UDP datagram number (failed) : 0 (0)
IPL2 export information:
type export information |
NetStream data export information for a specific traffic type. |
Flow source interface |
Source interface from which the NetStream data is exported. |
Flow destination VPN instance |
VPN to which the destination address of the NetStream data export belongs. |
Flow destination IP address (UDP) |
Destination IPv4 address and UDP port number of the NetStream data export. |
Flow destination IPv6 address (UDP) |
Destination IPv6 address and UDP port number of the NetStream data export. |
Version 5 exported flow number |
Number of flows that are exported in version 5 format. |
Version 5 exported UDP datagram number (failed) |
Number of UDP packets that are sent in version 5 format. The field in the parentheses indicates the number of UDP packets that failed to be sent. |
Version 9 exported flow number |
Number of flows that are exported in version 9 format. |
Version 9 exported UDP datagram number (failed) |
Number of UDP packets that are sent in version 9 format. The field in the parentheses indicates the number of UDP packets that failed to be sent. |
protocol-port aggregation export information |
Statistics of NetStream protocol-port aggregation in version 8 format. |
Version 8 exported flow number |
Number of flows that are exported in version 8 format. |
Version 8 exported UDP datagram number (failed) |
Number of UDP packets that are sent in version 8 format. The field in the parentheses indicates the number of UDP packets that failed to be sent. |
Version 10 exported flow number |
Number of flows that are exported in version 10 format. |
Version 10 exported UDP datagram number (failed) |
Number of UDP packets that are sent in version 10 format. The field in the parentheses indicates the number of UDP packets that failed to be sent. |
display ip netstream template
Use display ip netstream template to display NetStream template information.
In standalone mode:
display ip netstream template [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display ip netstream template [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays NetStream template information on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays NetStream template information on the global active MPU. (In IRF mode.)
IP NetStream templates vary by aggregation mode. This command displays IP NetStream template information for all the configured aggregation modes.
# Display NetStream template information. The template is in the version 10 format and the ip netstream template rfc7011 command is not executed.
<Sysname> display ip netstream template
Flow template refresh frequency : 20
Flow template refresh interval : 30 min
Active flow templates : 4
Created flow templates : 4
L2L3 outbound template:
Template ID : 3286
Packets : 0
Last template export time : Never
Field count : 25
Field type Field length (bytes)
Out packets 8
Out bytes 8
First forwarded 4
Last forwarded 4
Input interface index 4
Output interface index 4
Source IPv4 address 4
Destination IPv4 address 4
Source VLAN 2
Destination VLAN 2
L4 source port 2
L4 destination port 2
IP protocol version 1
TCP flags 1
Protocol 1
Source ToS 1
Direction 1
Sampling algorithm 1
PAD 1
PAD 1
Sampling interval 4
Bgp-community1 4
Bgp-community2 4
Bgp-community3 4
Bgp-community4 4
L2L3 inbound template:
Template ID : 3285
Packets : 0
Field count : 25
In packets 8
In bytes 8
First forwarded 4
Last forwarded 4
Source VLAN 2
Destination VLAN 2
L4 source port 2
TCP flags 1
Protocol 1
Source ToS 1
Direction 1
PAD 1
PAD 1
Sampling interval 4
Bgp-community1 4
Bgp-community2 4
Bgp-community3 4
Bgp-community4 4
Template ID : 3282
Packets : 0
Last template export time : 12/18/2017 at 14:51:15
Field count : 29
Out packets 8
Out bytes 8
First forwarded 4
Last forwarded 4
Next hop IPv4 address 4
Source AS 4
Destination AS 4
L4 source port 2
TCP flags 1
Protocol 1
Source ToS 1
Source address mask 1
Destination address mask 1
Direction 1
Forwarding status 1
Out VPN ID 2
PAD 1
Sampling interval 4
VXLAN ID 4
App ID 4
Bgp-community1 4
Bgp-community2 4
Bgp-community3 4
Bgp-community4 4
VPN instance name 65535
Serial number 65535
Template ID : 3281
Packets : 0
Field count : 29
In packets 8
In bytes 8
First forwarded 4
Last forwarded 4
Source AS 4
Destination AS 4
L4 source port 2
TCP flags 1
Protocol 1
Source ToS 1
Direction 1
Forwarding status 1
In VPN ID 2
PAD 1
Sampling interval 4
VXLAN ID 4
App ID 4
Bgp-community1 4
Bgp-community2 4
Bgp-community3 4
Bgp-community4 4
Serial number 65535
# Display NetStream template information. The template is in the version 10 format and is compliant with the RFC 7011 template format.
Template ID : 3286
Packets : 0
Field count : 22
Out packets 8
Out bytes 8
First forwarded 4
Last forwarded 4
Source VLAN 2
Destination VLAN 2
L4 source port 2
TCP flags 1
Protocol 1
Source ToS 1
Direction 1
PAD 1
PAD 1
Sampling interval 4
Bgp-community 65535
Template ID : 3285
Packets : 0
Field count : 22
In packets 8
In bytes 8
First forwarded 4
Last forwarded 4
Source VLAN 2
Destination VLAN 2
L4 source port 2
TCP flags 1
Protocol 1
Source ToS 1
Direction 1
PAD 1
PAD 1
Sampling interval 4
Bgp-community 65535
Template ID : 3282
Packets : 0
Field count : 29
Out packets 8
Out bytes 8
First forwarded 4
Last forwarded 4
Source AS 4
Destination AS 4
L4 source port 2
TCP flags 1
Protocol 1
Source ToS 1
Direction 1
Forwarding status 1
Out VPN ID 2
PAD 1
Sampling interval 4
VXLAN ID 4
App ID 4
Bgp-community 65535
Template ID : 3281
Packets : 0
Field count : 29
In packets 8
In bytes 8
First forwarded 4
Last forwarded 4
Source AS 4
Destination AS 4
L4 source port 2
TCP flags 1
Protocol 1
Source ToS 1
Direction 1
Forwarding status 1
In VPN ID 2
PAD 1
Sampling interval 4
VXLAN ID 4
App ID 4
Bgp-community 65535
Flow template refresh frequency |
Refresh frequency at which the templates are sent, in packets. |
Flow template refresh interval |
Refresh interval at which the templates are sent, in minutes. |
Active flow templates |
Number of active NetStream templates. |
Created flow templates |
Number of templates that have been created. |
MPLS outbound template |
Information of MPLS templates in the outbound direction. This field is displayed only when NetStream is enabled for MPLS by using the ip netstream mpls command. |
MPLS inbound template |
Information of MPLS templates in the inbound direction. This field is displayed only when NetStream is enabled for MPLS by using the ip netstream mpls command. |
L2L3 outbound template |
Information of the Layer 2 and Layer 3 templates in the outbound direction. |
L2L3 inbound template |
Information of the Layer 2 and Layer 3 templates in the inbound direction. |
Information of the Layer 3 template in the outbound direction. |
Information of the Layer 3 template in the inbound direction. |
Packets |
Number of packets sent by using the template. |
Last template export time |
Time when the template was last exported. |
Field count |
Total number of fields in the template. |
Field type |
Type of a field in the template. |
Field length (bytes) |
Length of the field, in bytes. |
Out packets |
Number of sent packets. |
In packets |
Number of received packets. |
Out bytes |
Size of sent packets, in bytes. |
In bytes |
Size of received packets, in bytes. |
First forwarded |
System time when the first packet was forwarded, accurate to milliseconds. |
Last forwarded |
System time when the last packet was forwarded, accurate to milliseconds. |
BGP next hop IPv4 address |
BGP next hop IPv4 address. If the traffic is not forwarded based on the BGP routing table, the system cannot identify the BGP next hop IPv4 address, and the field is not displayed. |
Source VLAN |
Source VLAN |
Destination VLAN |
Destination VLAN |
TCP flags |
TCP flag of the flow. |
Protocol |
Layer 4 protocol type. |
Out VPN ID |
Name of the VPN instance to which the egress interface of the packets belong. |
In VPN ID |
Name of the VPN instance to which the ingress interface of the packets belong. This field is supported only in version 10. |
PAD |
Padding string. |
MPLS label n |
MPLS label position. The value for the argument n is 1 to 10, representing label positions from the stack top to the tenth layer. |
Sampling interval |
Sampling rate. |
VXLAN ID |
VXLAN ID. This field is supported only in version 10. |
App ID |
Application ID. |
Bgp-community |
BGP community string. This field is supported only in version 10. If the NetStream template uses the H3C format, the fields Bgp-community1, Bgp-community2, Bgp-community3, and Bgp-community4 are displayed and each field length is 4 bytes. If the NetStream template uses the RFC 7011-compliant format, the field Bgp-community is displayed and the field length is up to 65535 bytes. To configure the RFC 7011-compliant NetStream template format, use the ip netstream template rfc7011 command. |
VPN instance name |
VPN instance name. If the packets belong to the public network, this field displays N/A. |
SRv6 policy color |
Color for the SRv6 TE policy. This field is supported only by version 9. |
SRv6 policy endpoint |
IPv6 address of the destination node for the SRv6 TE policy. This field is supported only by version 9. |
SRv6 policy name |
Name of the SRv6 TE policy. This field is supported only by version 9. |
Serial number |
Device serial number. This field is supported only by version 9. |
enable
Use enable to enable a NetStream aggregation mode.
Use undo enable to disable a NetStream aggregation mode.
enable
undo enable
No NetStream aggregation mode is enabled.
# Enable NetStream AS aggregation mode.
[Sysname] ip netstream aggregation as
[Sysname-ns-aggregation-as] enable
flow standard-mode enable
Use flow standard-mode enable to switch high-performance mode to standard mode for NetStream sampling.
Use undo flow standard-mode enable to restore the default.
High-performance mode is enabled for NetStream sampling.
To reduce the device load, use this command to release the processor resources that NetStream sampling occupies in high-performance mode.
This command takes effect on both IPv4 and IPv6 NetStream.
# Switch high-performance mode to standard mode for NetStream sampling.
[Sysname] flow standard-mode enable
ip netstream (interface view)
Use ip netstream to enable NetStream on an interface.
Use undo ip netstream to disable NetStream on an interface.
ip netstream { inbound | outbound } [ main ]
undo ip netstream { inbound | outbound }
NetStream is disabled on an interface.
Interface view
inbound: Enables NetStream for incoming traffic.
outbound: Enables NetStream for outgoing traffic.
main: Enables NetStream on the main interface. If you do not specify this keyword, this command enables NetStream on the main interface and its subinterfaces.
Do not enable NetStream on an interface that has been assigned to an MP group or HDLC link bundle.
You can enable both IPv4 and IPv6 NetStream on an interface. If you enable both IPv4 and IPv6 NetStream on an interface, either specify the main keyword or do not specify it for both IPv4 and IPv6 NetStream simultaneously. To change the configuration of main keyword, first disable NetStream. Enable NetStream again after the configuration change.
If you do not specify the main keyword, you cannot enable NetStream on both a main interface and its subinterfaces.
The main keyword is available only for Layer 3 Ethernet interfaces and ATM interfaces on the following cards:
Card category |
Cards |
CEPC |
CEPC-CQ8L, CEPC-CQ16L1, CEPC-DQ2L1-G |
CSPEX |
CSPEX-1802XB, CSPEX-1802X, CSPEX-1812X-E, CSPEX-2304X-G, CSPEX-2304X-LG, CSPEX-2612X-E |
SPE |
RX-SPE200-E |
# Enable NetStream for incoming traffic on Ten-GigabitEthernet 3/1/1.
[Sysname] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] ip netstream inbound
ip netstream (system view)
Use ip netstream to enable NetStream.
Use undo ip netstream to disable NetStream.
ip netstream
undo ip netstream
NetStream is disabled.
After you enable NetStream in system view, NetStream is enabled on all interfaces for both incoming and outgoing traffic. NetStream takes effect after configuring NetStream mirroring.
# Enable NetStream.
Use ip netstream aggregation to specify a NetStream aggregation mode and enter its view.
Use undo ip netstream aggregation to remove the configuration for a NetStream aggregation mode.
ip netstream aggregation { as | bgp-community | destination-prefix | prefix | prefix-port | protocol-port | source-prefix | tos-as | tos-bgp-nexthop | tos-destination-prefix | tos-prefix | tos-protocol-port | tos-source-prefix }
undo ip netstream aggregation { as | bgp-community | destination-prefix | prefix | prefix-port | protocol-port | source-prefix | tos-as | tos-bgp-nexthop | tos-destination-prefix | tos-prefix | tos-protocol-port | tos-source-prefix }
No NetStream aggregation mode is specified.
as: Specifies the AS aggregation mode. It aggregates flows by source AS number, destination AS number, inbound interface index, and outbound interface index.
bgp-community: Specifies the BGP community aggregation mode. It aggregates flows by inbound interface index, outbound interface index, and BGP community.
destination-prefix: Specifies the destination-prefix aggregation mode. It aggregates flows by destination AS number, destination address mask length, destination prefix, and outbound interface index.
prefix: Specifies the source and destination prefix aggregation mode. It aggregates flows by the following criteria:
· Source AS number.
· Destination AS number.
· Source address mask length.
· Destination address mask length.
· Source prefix.
· Destination prefix.
· Inbound interface index.
· Outbound interface index.
prefix-port: Specifies the prefix-port aggregation mode. It aggregates flows by the following criteria:
· Source prefix.
· ToS.
· Protocol number.
· Source port.
· Destination port.
protocol-port: Specifies the protocol-port aggregation mode. It aggregates flows by protocol number, source port, and destination port.
source-prefix: Specifies the source-prefix aggregation mode. It aggregates flows by source AS number, source address mask length, source prefix, and inbound interface index.
tos-as: Specifies the ToS-AS aggregation mode. It aggregates flows by ToS, source AS number, destination AS number, inbound interface index, and outbound interface index.
tos-bgp-nexthop: Specifies the ToS-BGP nexthop aggregation mode. It aggregates flows by ToS, BGP next hop address, and outbound interface index. ToS-BGP next hop aggregation is supported by a version 9 template.
tos-destination-prefix: Specifies the ToS-destination-prefix aggregation mode. It aggregates flows by ToS, destination AS number, destination address mask length, destination prefix, and outbound interface index.
tos-prefix: Specifies the ToS-prefix aggregation mode. It aggregates flows by the following criteria:
· ToS.
· Source AS number.
· Source prefix.
tos-protocol-port: Specifies the ToS-protocol-port aggregation mode. It aggregates flows by ToS, protocol number, source port, destination port, inbound interface index, and outbound interface index.
tos-source-prefix: Specifies the ToS-source-prefix aggregation mode. It aggregates flows by ToS, source AS number, source prefix, source address mask length, and inbound interface index.
In NetStream aggregation mode view, you can perform the following tasks:
· Enable or disable the specified NetStream aggregation mode.
· Configure source interface, destination IP address, and destination port for the NetStream data export.
A flow matching multiple aggregation modes is counted as multiple aggregate flows.
# Set the NetStream aggregation mode to AS, and enter NetStream AS aggregation mode view.
enable
ip netstream export source
ip netstream aging
Use ip netstream aging command to enable periodical aging and TCP FIN- and RST-triggered aging.
Use undo ip netstream aging to disable periodical aging and TCP FIN- and RST-triggered aging.
ip netstream aging
Periodical aging and TCP FIN- and RST-triggered aging are enabled.
# Disable periodical aging and TCP FIN- and RST-triggered aging.
[Sysname] undo ip netstream aging
Use ip netstream cache archive enable to enable archiving of cached NetStream entries.
Use undo ip netstream cache archive enable to disable archiving of cached NetStream entries.
Archiving of cached NetStream entries is disabled.
This command enables local archiving of NetStream entries when they are exported to NetStream servers.
This feature is applicable when a small number of NetStream entries exist and no log server exists. If the device generates a large number of NetStream entries, do not enable this feature. Otherwise, the device performance will be affected.
# Enable archiving of cached NetStream entries.
[Sysname] ip netstream cache archive enable
Use ip netstream export host to specify a destination host for NetStream aggregation data export in a NetStream aggregation mode view.
Use undo ip netstream export host to remove the specified destination host or all destination hosts that are configured in a NetStream aggregation mode view.
ip netstream export host { ipv4-address | ipv6-address } udp-port [ vpn-instance vpn-instance-name ] [ dscp dscp-value ]
undo ip netstream export host [ { ipv4-address | ipv6-address } [ vpn-instance vpn-instance-name ] ]
No destination host is specified in a NetStream aggregation mode view.
ipv4-address: Specifies the destination IPv4 address.
ipv6-address: Specifies the destination IPv6 address.
udp-port: Specifies the destination UDP port number in the range of 0 to 65535.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the destination host belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the destination is on the public network, do not specify this option.
dscp dscp-value: Specifies the DSCP value in export traffic statistics, in the range of 0 to 63. If you do not specify this option, the DSCP value in export traffic statistic is 0.
If an aggregation mode is not enabled, the display ip netstream export command cannot display the destination host configuration for the mode.
If no destination host is specified in a NetStream aggregation mode view, the destination host in system view applies. If destination hosts are specified in a NetStream aggregation mode view and system view, the destination hosts in the aggregation mode view take effect.
You can specify the same destination IP address and UDP port in different NetStream aggregation mode views. Each NetStream aggregation mode view supports a maximum of four destination hosts. The device supports exporting NetStream data to multiple destination hosts for backup. Each destination host is identified by the combination of IP address, UDP port number, and network identifier (VPN instance or public network).
· Destination hosts on different VPN instances can use the same IP address and UDP port number.
· Within the same VPN instance or on the public network, each destination host must use a unique IP address. If you specify a destination host with the same IP address but different UDP port numbers, the most recent configuration takes effect.
NetStream aggregation data is exported to all destination hosts in the related NetStream aggregation mode view.
# In AS aggregation mode view, specify 172.16.105.48 as the IP address of the destination host and UDP port 5000 as the export destination port number, and set the DSCP value in export traffic statistics to 1.
[Sysname-ns-aggregation-as] ip netstream export host 172.16.105.48 5000 dscp 1
Use ip netstream export host to specify a destination host for NetStream data export in system view.
Use undo ip netstream export host to remove the specified destination host or all destination hosts that are specified in system view.
In standalone mode:
ip netstream export host { ipv4-address | ipv6-address } udp-port [ vpn-instance vpn-instance-name ] [ dscp dscp-value ] [ slot slot-number [ cpu cpu-number ] ]
undo ip netstream export host [ { ipv4-address | ipv6-address } [ vpn-instance vpn-instance-name ] ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
ip netstream export host { ipv4-address | ipv6-address } udp-port [ vpn-instance vpn-instance-name ] [ dscp dscp-value ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo ip netstream export host [ { ipv4-address | ipv6-address } [ vpn-instance vpn-instance-name ] ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
No destination host is specified for NetStream data export in system view.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command applies to all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command applies to all cards. (In IRF mode.)
The system supports general and slot-specific destination hosts, and they can share the same IP address and port number. If both types of destination hosts are specified for one slot, the device prefers the slot-specific destination hosts for exporting NetStream data of that card. If no slot-specific destination host is specified for that slot, the device uses the general destination hosts for exporting NetStream data of the card.
You can specify a maximum of four destination hosts in system view. The device supports exporting NetStream traditional data to multiple destination hosts for backup. Each destination host is identified by the combination of the IP address, UDP port number, and network identifier (VPN instance or public network).
In system view, the device supports a maximum of four destination hosts for each slot.
# In system view, specify 172.16.105.48 as the IP address of the destination host and UDP port 5000 as the destination port number, and set the DSCP value in export traffic statistics to 1.
[Sysname] ip netstream export host 172.16.105.48 5000 dscp 1
ip netstream export rate
Use ip netstream export rate to limit the NetStream data export rate.
Use undo ip netstream export rate to restore the default.
ip netstream export rate rate
The export rate of NetStream data is not limited.
rate: Specifies the export rate in the range of 1 to 1000.
This command sets the maximum number of NetStream packets that can be exported per second. Packets that cannot be exported due to the export rate limit are buffered for later export. When the buffer is full, the system will temporarily invalidate the rate limit and export packets as fast as possible until the buffer has available free space.
# Allow a maximum of 10 packets to be exported per second.
[Sysname] ip netstream export rate 10
Use ip netstream export source to specify the source interface for data packets sent to NetStream servers. Use undo ip netstream export source to restore the default.
ip netstream export source interface interface-type interface-number
The packets take the IP address of the output interface as the source IP address.
interface-type interface-number: Specifies a source interface by its type and number.
The IP address of the specified source interface is used as the source IP address for packets sent to NetStream servers.
You can configure different source interfaces in different NetStream aggregation mode views.
If no source interface is configured in a NetStream aggregation mode view, the source interface in system view applies.
# In system view, specify Ten-GigabitEthernet 3/1/1 as the source interface for NetStream traditional data packets.
[Sysname] ip netstream export source interface ten-gigabitethernet 3/1/1
# In AS aggregation mode view, specify Ten-GigabitEthernet 3/1/2 as the source interface for NetStream aggregation data packets.
[Sysname-ns-aggregation-as] ip netstream export source interface ten-gigabitethernet 3/1/2
Use ip netstream export template refresh-rate to set the refresh rate for the NetStream version 9 or version 10 template.
Use undo ip netstream export template refresh-rate to restore the default.
ip netstream export template refresh-rate { packet packets | time minutes }
undo ip netstream export template refresh-rate { packet | time }
The packet count-based refresh rate is 20 packets, and the time-based refresh interval is 30 minutes.
packet packets: Specifies the number of packets that are sent before the template is sent. The value range is 1 to 600.
time minutes: Specifies the interval at which the template is sent, in the range of 1 to 3600 minutes.
Version 9 and version 10 are template-based and support user-defined formats. A NetStream device must send the version 9 or version 10 template to NetStream servers regularly, because the servers do not permanently save templates.
The refresh rate can be packet count-based or time-based. If both settings are configured, the template is sent when either of the conditions is met.
# Configure the device to send the NetStream version 9 or version 10 template to NetStream servers every 100 packets.
[Sysname] ip netstream export template refresh-rate packet 100
ip netstream export version
Use ip netstream export version 5 to export NetStream data in the version 5 format and configure AS export attribute.
Use ip netstream export version 9 to export NetStream data in the version 9 format and configure the AS export attribute, BGP next hop, and serial number export attribute.
Use ip netstream export version 10 to export NetStream data in the version 10 format and configure the AS export attribute, BGP next hop, and serial number export attribute.
Use undo ip netstream export version to restore the default.
ip netstream export version 5 { origin-as | peer-as }
ip netstream export version { 9 | 10 } { origin-as | peer-as } [ bgp-nexthop ] [ serial-number ]
NetStream data export uses the version 9 format.
The peer AS numbers are recorded.
The BGP next hop and serial number information is not recorded.
origin-as: Records the original AS numbers for the flow source and destination.
peer-as: Records the peer AS numbers for the flow source and destination.
bgp-nexthop: Records the BGP next hop information.
serial-number: Records the device serial number.
A NetStream entry records the source IP address and destination IP address, and two AS numbers for each IP address. You can choose to configure which AS numbers are to be exported as the source AS and destination AS.
Only the version 9 and version 10 formats support recoding BGP next hop and serial number information.
Only one version format can take effect on the device. If you execute this command multiple times, the most recent configuration takes effect.
If the version 5 format is used, the NetStream aggregation data export uses the version 8 format.
If the version 9 format is used, the NetStream aggregation data export uses the version 9 format.
If the version 10 format is used, the NetStream aggregation data export uses the version 10 format.
# Configure the device to export NetStream data in version 5 format and to specify the NetStream data to include the source AS and destination AS.
[Sysname] ip netstream export version 5 origin-as
# Configure the device to export NetStream data in version 9 format, specify the NetStream data to include the source AS and destination AS, and record the BGP next hop and serial number.
[Sysname] ip netstream export version 9 origin-as bgp-nexthop serial-number
ip netstream hardware enable
Use ip netstream hardware enable to enable hardware-based NetStream.
Use undo ip netstream hardware enable to disable hardware-based NetStream.
Hardware-based NetStream is disabled.
If you enable hardware-based NetStream, the device releases the CPU resources occupied by NetStream to reduce the load on the device, and NetStream can collect larger amount of traffic statistics.
Hardware-based NetStream takes effect on both IPv4 NetStream and IPv6 NetStream.
# Enable hardware-based NetStream.
[Sysname] ip netstream hardware enable
Are you sure you want to enable hardware NetStream? [Y/N]: Y
# Disable hardware-based NetStream.
[Sysname] undo ip netstream hardware enable
Are you sure you want to disable hardware NetStream? [Y/N]: Y
ip netstream max-entry
Use ip netstream max-entry to set the upper limit for NetStream entries or specify the processing method when the upper limit is reached.
Use undo ip netstream max-entry to restore the default.
ip netstream max-entry { max-entries | aging | disable-caching }
A maximum of 2048000 NetStream entries can be cached. The system will age out the oldest entries when the number of cached entries reaches the upper limit.
max-entries: Specifies the upper limit for NetStream entries that the cache can accommodate.The value range is 1024 to 2048000.
aging: Ages out the oldest entries when the upper limit is reached.
disable-caching: Disables creation of a new entry when the upper limit is reached.
The max-entries argument takes effect on each card.
If you execute the ip netstream max-entry max-entries command multiple times, the most recent configuration takes effect.
If you execute the ip netstream max-entry { aging | disable-caching } command multiple times, the most recent configuration takes effect.
After you execute this command, it is deployed to all cards. The command does not take effect on the cards enabled with hardware-based NetStream.
# Set the upper limit to 5000 for NetStream entries.
[Sysname] ip netstream max-entry 5000
# Disable creation of a new entry when the upper limit is reached.
[Sysname] ip netstream max-entry disable-caching
# Configure the device to age out the oldest entries when the upper limit is reached.
[Sysname] ip netstream max-entry aging
ip netstream mpls
Use ip netstream mpls to enable MPLS packet statistics collection.
Use undo ip netstream mpls to disable MPLS packet statistics collection.
ip netstream mpls [ label-positions label-position1 [ label-position2 [ label-position3 ] ] ] [ no-ip-fields ]
MPLS packet statistics collection is disabled.
label-positions: Specifies position of the labels to be counted.
label-position1: Specifies the position of the first label in the label stack, in the range of 1 to 10, representing the position from the stack top to the tenth layer.
label-position2: Specifies the position of the second label in the label stack, in the range of 1 to 10 except for specified labels, representing the position from the stack top to the tenth layer.
label-position3: Specifies the position of the third label in the label stack, in the range of 1 to 10 except for specified labels, representing the position from the stack top to the tenth layer.
no-ip-fields: Excludes IP addresses in MPLS packets during NetStream statistics collection.
This command enables statistics collection of MPLS packets for both IPv4 and IPv6 NetStream.
If you do not specify any keywords or options, the top label and IP fields are counted.
If multiple labels are to be counted, the label positions specified cannot be the same and have no order. After counting, the collected MPLS information of the label positions is arranged in ascending order.
# Enable NetStream for MPLS packets with top label counted but without IP fields.
[Sysname] ip netstream mpls no-ip-fields
ip netstream sampler
Use ip netstream sampler to configure the NetStream sampling rate..
Use undo ip netstream sampler to restore the default.
ip netstream { inbound | outbound } sampler sampler-name
undo ip netstream { inbound | outbound } sampler
NetStream sampler 1 is used.
Interface view
inbound: Enables NetStream sampling in the inbound direction.
outbound: Enables NetStream sampling in the outbound direction.
sampler sampler-name: Specifies a sampler by its name. The name is a case-insensitive string of 1 to 31 characters.
By default, NetStream collects all data of target flows. If the flow traffic is heavy, NetStream is resource-consuming and can cause high CPU usage, which impacts the device forwarding performance. NetStream sampling is helpful to decrease the NetStream traffic volume. If the collected statistics can basically reflect the network status, you can enable this feature and set a proper sampling rate. The higher the sampling rate, the less impact on device performance.
# Use sampler abc for inbound NetStream sampling on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] ip netstream inbound sampler abc
Use ip netstream outbound sampler srv6-policy to configure the NetStream sampling rate for an SRv6 TE policy..
Use undo ip netstream outbound sampler srv6-policy to restore the default.
ip netstream outbound sampler sampler-name srv6-policy end-point ipv6 ipv6-address color color-value
undo ip netstream outbound sampler sampler-name srv6-policy end-point ipv6 ipv6-address color color-value
NetStream sampler 1 is used for an SRv6 TE policy.
end-point ipv6 ipv6-address: Specifies the IPv6 address of the destination node for an SRv6 TE policy.
color color-value: Specifies the color for an SRv6 TE policy, in the range of 0 to 4294967295.
Configure the NetStream sampling rateon the ingress node for an SRv6 TE policy to enable NetStream to sample the outgoing traffic forwarded based on that SRv6 TE policy. For more information about SRv6 TE policies, see Segment Routing Configuration Guide.
# Enable NetStream sampling by using sampler abc for the SRv6 TE policy whose destination node is at 1000::1 and color is 10.
[Sysname] ip netstream outbound sampler abc srv6-policy endpoint ipv6 1000::1 color 10
Use ip netstream outbound srv6-policy to enable NetStream for an SRv6 TE policy.
Use undo ip netstream outbound srv6-policy to disable NetStream for an SRv6 TE policy.
ip netstream outbound srv6-policy end-point ipv6 ipv6-address color color-value
undo ip netstream outbound srv6-policy end-point ipv6 ipv6-address color color-value
NetStream is disabled for an SRv6 TE policy.
Execute this command on the ingress node for an SRv6 TE policy to enable NetStream to collect statistics about the outgoing traffic forwarded based on that SRv6 TE policy. For more information about SRv6 TE policies, see Segment Routing Configuration Guide.
Global NetStream configuration does not take effect on NetStream based on an SRv6 TE policy.
# Enable NetStream for the SRv6 TE policy whose destination node is at 1000::1 and color is 10.
[Sysname] ip netstream outbound srv6-policy endpoint ipv6 1000::1 color 10
Use ip netstream template rfc7011 to configure the RFC 7011-compliant NetStream template format.
Use undo ip netstream template rfc7011 to restore the default.
The NetStream template uses the H3C-defined template format.
This command enables NetStream to use the template format defined by the RFC 7011 for data export. Make sure the NetStream template format on the device is consistent with that on the server.
This command applies to both IPv4 and IPv6 NetStream templates.
# Configure the RFC 7011-compliant NetStream template format.
[Sysname] ip netstream template rfc7011
ip netstream timeout active
Use ip netstream timeout active to set the aging timer for active flows.
Use undo ip netstream timeout active to restore the default.
ip netstream timeout active minutes
The aging timer is 30 minutes for active flows.
minutes: Sets the aging timer for active flows, in the range of 1 to 60 minutes.
A flow is considered active if packets for the NetStream entry arrive before the timer set by this command expires.
# Set the aging timer to 60 minutes for active flows.
[Sysname] ip netstream timeout active 60
ip netstream timeout inactive
Use ip netstream timeout inactive to set the aging timer for inactive flows.
Use undo ip netstream timeout inactive to restore the default.
ip netstream timeout inactive seconds
The aging timer is 30 seconds for inactive flows.
seconds: Sets the aging timer for inactive flows, in the range of 10 to 600 seconds.
A flow is considered inactive if no packet for the NetStream entry arrives before the timer set by this command expires.
# Set the aging timer to 60 seconds for inactive flows.
[Sysname] ip netstream timeout inactive 60
Use reset ip netstream statistics to age out all flows in the cache and export NetStream data.
It takes the system several minutes to execute the command. During this period, the system does not collect NetStream data.
# Age out and export all NetStream data.
<Sysname> reset ip netstream statistics
This process may take a few minutes.
Netstream statistic function is disabled during this process.
