11-Segment Routing Command Reference
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesCommand ReferencesH3C SR8800-X Routers Command Reference-R8530Pxx-6W10111-Segment Routing Command Reference
01-SR-MPLS commands
01-SR-MPLS commands 604.97 KB
SR-MPLS commands· 1
bfd detect-multiplier 1
bfd enable· 1
bfd min-echo-receive-interval 3
bfd min-receive-interval 3
bfd min-transmit-interval 4
display bgp egress-engineering ipv4· 5
display bgp egress-engineering peer-set 8
display bgp segment-routing label-range· 9
display bgp segment-routing prefix-sid-map· 10
display isis segment-routing adjacency· 11
display isis segment-routing global-block· 12
display isis segment-routing prefix-sid-map· 13
display isis segment-routing routing-table· 16
display mpls static-sr-mpls· 18
display mpls static-sr-mpls prefix· 19
display mpls te tunnel lsp-down-info· 21
display mpls te tunnel lsp-event switch· 22
display ospf segment-routing adjacency· 24
display ospf segment-routing global-block· 25
display ospf segment-routing prefix-sid-map· 26
display ospf segment-routing routing-table· 28
display segment-routing label-block· 30
display segment-routing mapping-server prefix-sid-map· 31
egress-engineering label delete-delay· 33
egress-engineering link-delay· 34
egress-engineering link-loss· 35
egress-engineering metric-bandwidth advertisement enable· 36
egress-engineering metric-bandwidth suppression· 37
egress-engineering metric-delay advertisement enable· 37
egress-engineering metric-delay suppression· 38
egress-engineering metric-link-loss advertisement enable· 39
egress-engineering metric-link-loss suppression· 40
egress-engineering peer-set 42
fast-reroute microloop-avoidance enable· 43
fast-reroute microloop-avoidance rib-update-delay· 44
fast-reroute ti-lfa· 45
global-block· 47
isis adjacency-sid· 47
isis fast-reroute ti-lfa disable· 49
isis prefix-sid· 50
local-block· 51
mapping-server prefix-sid-map· 52
mpls te path-selection adjacency-sid· 53
mpls te static-sr-mpls· 54
ospf adjacency-sid· 55
ospf fast-reroute ti-lfa disable· 56
ospf prefix-sid· 57
peer egress-engineering· 58
peer peer-set 59
sbfd detect-multiplier 60
sbfd enable· 61
sbfd min-receive-interval 62
sbfd min-transmit-interval 63
segment-routing· 64
segment-routing adjacency enable· 64
segment-routing adjacency-sid delete-delay· 65
segment-routing global-block· 66
segment-routing label-advertise· 67
segment-routing lsp-trigger 68
segment-routing mapping-server advertise-local 69
segment-routing mapping-server receive· 69
segment-routing microloop-avoidance enable· 70
segment-routing microloop-avoidance rib-update-delay· 71
segment-routing microloop-avoidance strict-sid-only· 73
segment-routing mpls· 73
segment-routing prefix-sid-map· 74
segment-routing sr-prefer 75
static-sr-mpls adjacency· 76
static-sr-mpls lsp· 77
static-sr-mpls prefix· 78
tunnel-bfd detect-multiplier 79
tunnel-bfd enable· 80
tunnel-bfd min-echo-receive-interval 81
tunnel-bfd min-receive-interval 82
tunnel-bfd min-transmit-interval 82
SR-MPLS commands
Use bfd detect-multiplier to set the BFD detection time multiplier for SRLSPs.
Use undo bfd detect-multiplier to restore the default.
bfd detect-multiplier value
The BFD detection time multiplier is not set for SRLSPs. The BFD detection time multiplier set by the bfd multi-hop detect-multiplier command applies.
Segment Routing view
value: Specifies a detection time multiplier, which is the maximum number of consecutive BFD packets that can be discarded. The value range for this argument is 3 to 50.
The device sends BFD packets to a peer periodically. If the device does not receive BFD packets from the peer within the actual detection interval, it determines that the session is down. The actual detection interval of the sender is the detection time multiplier of the receiver × the actual sending interval of the receiver.
This command takes effect only on BFD sessions created by the bfd enable command.
# Set the BFD detection time multiplier to 3 for SRLSPs.
[Sysname] segment-routing
[Sysname-segment-routing] bfd detect-multiplier 3
bfd enable
bfd multi-hop detect-multiplier (High Availability Command Reference)
bfd enable
Use bfd enable to enable BFD for SRLSPs.
Use undo bfd enable to restore the default.
bfd enable [ prefix-list prefix-list-name ] [ echo | nil-fec ]
undo bfd enable
BFD for SRLSPs is not enabled.
Segment routing view
prefix-list prefix-list-name: Specifies an IPv4 prefix list by the prefix list name, a case-sensitive string of 1 to 63 characters. The device can create BFD sessions only for the SRLSPs permitted by the specified IPv4 prefix list. If you do not specify an IPv4 prefix list, the device can create BFD sessions for all SRLSPs.
echo: Specifies the BFD echo packet mode. If you do not specify this keyword, the BFD control packet mode is used to verify SRLSP connectivity.
nil-fec: Encapsulates the Nil FEC in MPLS echo request packets when BFD control packet mode is used to detect SRLSPs. In SR to LDP interworking mode, the ingress node (source node) cannot determine whether the LDP LSP is connected to the SRLSP. When the ingress node uses MPLS BFD to detect LSPs, it encapsulates LDP FEC in MPLS echo request packets, which will fail the FEC type verification on the egress node (end-point node). Then, the BFD session will go down. To resolve this issue, specify the nil-fec keyword to enable the ingress node to encapsulate the Nil FEC in MPLS echo request packets. The egress node will not check the FEC type of packets encapsulated with the Nil FEC.
This command enables the device to create a BFD session for each primary SRLSP to verify the connectivity of the primary SRLSP. When a primary SRLSP fails, BFD can quickly detect the failure and switches traffic to the backup SRLSP to reduce packet loss.
Before you execute this command, enable MPLS BFD by using the mpls bfd enable command.
If you execute both the bfd enable command and the mpls bfd command for SRLSPs, the mpls bfd command takes effect on the SRLSPs.
In segment routing view, if you execute the bfd enable command and the sbfd enable command multiple times, the most recent configuration takes effect.
# Enable BFD for SRLSPs.
[Sysname-segment-routing] bfd enable
mpls bfd (for LSP) (MPLS Command Reference)
mpls bfd enable (MPLS Command Reference)
sbfd enable
Use bfd min-echo-receive-interval to set the minimum interval for receiving BFD echo packets for SRLSP BFD.
Use undo bfd min-echo-receive-interval to restore the default.
The minimum interval for receiving BFD echo packets is not set for SRLSP BFD. The interval set by the bfd multi-hop min-echo-receive-interval command applies.
interval: Specifies the minimum interval for receiving BFD echo packets, in milliseconds. The value range is 3 to 10000.
The interval for receiving BFD echo packets is also the interval for sending BFD echo packets. By executing this command, you can control both the receiving interval and sending interval for BFD echo packets.
This command takes effect only on the echo mode BFD sessions created by the bfd enable command.
# Set the minimum BFD echo packet receiving interval for SRLSP BFD to 450 milliseconds.
[Sysname-segment-routing] bfd min-echo-receive-interval 450
bfd enable
bfd multi-hop min-echo-receive-interval (High Availability Command Reference)
Use bfd min-receive-interval to set the minimum BFD packet receiving interval for SRLSP BFD.
Use undo bfd min-receive-interval to restore the default.
The minimum interval for receiving BFD packets is not set for SRLSP BFD. The interval set by the bfd multi-hop min-receive-interval command applies.
interval: Specifies the minimum interval for receiving BFD packets, in milliseconds. The value range is 3 to 10000.
Use this command to prevent the packet sending rate of the peer end from exceeding the packet receiving rate of the local end. If the receiving rate is exceeded, the peer end dynamically adjusts the BFD packet transmitting interval to the minimum receiving interval of the local end.
# Set the minimum BFD packet receiving interval for SRLSP BFD to 550 milliseconds.
[Sysname-segment-routing] bfd min-receive-interval 550
bfd enable
bfd multi-hop min-receive-interval (High Availability Command Reference)
Use bfd min-transmit-interval to set the minimum BFD packet transmitting interval for SRLSP BFD.
Use undo bfd min-transmit-interval to restore the default.
The minimum interval for transmitting BFD packets is not set for SRLSP BFD. The interval set by the bfd multi-hop min-transmit-interval command applies.
interval: Specifies the minimum interval for transmitting BFD packets, in milliseconds. The value range is 3 to 10000.
Use this command to prevent the BFD packet sending rate from exceeding the packet receiving rate of the peer end.
The actual BFD packet transmitting interval on the local end is the greater value between the following values:
·     Minimum interval for transmitting BFD packets on the local end.
·     Minimum interval for receiving BFD packets on the peer end.
# Set the minimum BFD packet transmitting interval for SRLSP BFD to 450 milliseconds.
[Sysname-segment-routing] bfd min-transmit-interval 450
bfd enable
bfd multi-hop min-transmit-interval (High Availability Command Reference)
Use display bgp egress-engineering ipv4 to display BGP-EPE information.
display bgp [ instance instance-name ] egress-engineering ipv4 [ ipv4-address ] [ verbose ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays information about the default BGP instance.
ipv4-address: Specifies the IPv4 address of an existing peer. If you do not specify this argument, the command displays information about all peers and peer groups.
verbose: Displays detailed BGP-EPE information. If you do not specify this keyword, the command displays brief BGP-EPE information.
# Display brief BGP-EPE information.
<Sysname> display bgp egress-engineering ipv4
  PeerSet          : 192.168.1.2
  Local ASNumber             : 1
  Remote ASNumber            : 2
  Local RouterID             : 1.1.1.3
  Remote RouterID            : 1.1.1.4
  OriginNextHop              : 192.168.1.2
  RelyNextHop                : 192.168.1.2
  Interface                  : XGE3/1/1
# Display brief BGP-EPE information for a peer.
<Sysname> display bgp egress-engineering ipv4 192.168.1.5
BGP peering segment type: Node-Adjacency
  PeerNodeAdj                : 192.168.1.5
  Local ASNumber             : 1
  Remote ASNumber            : 2
  Remote RouterID            : 1.1.1.5
  OriginalNextHop            : 192.168.1.5
  RelyNextHop                : 192.168.1.5
  Interface                  : XGE3/1/5
# Display detailed BGP-EPE information for a peer.
<Sysname> display bgp egress-engineering ipv4 1.1.1.1 verbose
BGP peering segment type : Node
  PeerAdj Num                : 2
  PeerNode                   : 1.1.1.1
  Local ASNumber             : 1
  Remote AsNumber            : 2
  Local Interface Address    : 2.2.2.2
  Remote Interface Address   : 1.1.1.1
  OriginalNextHop            : 1.1.1.1
  RelyNextHop                : 100.0.27.7
  RelyNextHop                : 100.0.28.7
  Label                      : 15000
  TunnelPolicy               : abc
BGP peering segment type     : Adjacency
  PeerAdj                    : 100.0.27.7
  Local ASNumber             : 1
  Remote ASNumber            : 2
  Local RouterID             : 1.1.1.1
  Remote RouterID            : 2.2.2.2
  OriginalNextHop            : 100.0.27.7
  Local Interface Address    : 100.0.27.2
  Remote Interface Address   : 100.0.27.7
  Label                      : 24001
  TunnelPolicy               : abc
  TE Administrative group: 0x0
  TE Maximum link bandwidth(kbits/sec): 100000
  TE Maximum reservable link bandwidth(kbits/sec): 9999
  TE Maximum Unreserved bandwidth(kbits/sec): 999 999 999 999 999 999 999 999
  TE Metric: 1
  TE SRLG: 100
  Delay flag: 0, Average delay(us): 100
  Delay range flag: 0, Min delay(us): 100, Max delay(us): 200
  Delay variation(us): 200
  Remaining bandwidth(bytes/sec): 200
  Available bandwidth(bytes/sec): 100
  Utilized bandwidth(bytes/sec): 50
  Link loss flag: 0, Link loss rate: 50.331624%
  PeerAdj                    : 100.0.28.7
  Local ASNumber             : 1
  Remote ASNumber            : 2
  OriginalNextHop            : 100.0.28.7
  Local Interface Address    : 100.0.28.2
  Remote Interface Address   : 100.0.28.7
  Interface                  : XGE3/1/2
  Label                      : 24002
  TunnelPolicy               : abc
  TE Metric: 1
  TE SRLG: 100
Type of the BGP peering segments to the specified peer:
·     Node.
·     Adjacency.
·     Set.
·     Node-Adjacency.
PeerAdj Num
Number of peering adjacencies.
Local ASNumber
Local AS number.
Remote ASNumber
Remote AS number.
Interface on which the neighborship is established.
OriginalNextHop
Original next hop.
RelyNextHop
Recursive next hop.
TE Administrative Group
Administrative group of the link, a link attribute.
Delay flag
Flag that indicates whether the average, minimum, or maximum delay has exceeded 16777215 microseconds.
·     0—The measured average, minimum, or maximum delay of the link is equal to or less than 16777215 microseconds, indicating that the link is stable.
·     1—The measured average, minimum, or maximum delay of the link is greater than 16777215 microseconds.
Remaining/available/utilized bandwidth(bytes/sec)
Remaining bandwidth, available bandwidth, or used bandwidth of the link, in bytes per second.
Link loss flag
Flag that indicates whether the packet loss rate has exceeded 50.331642%.
·     0—The measured packet loss rate of the link is smaller than 50.331642%, indicating that the link is stable.
·     1—The measured packet loss rate of the link is equal to or greater than 50.331642%. The current link performance is poor.
Link loss rate
Packet loss rate in percentage.
Use display bgp egress-engineering peer-set to display BGP-EPE peer set information.
display bgp [ instance instance-name ] egress-engineering peer-set [ peer-set-name ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays BGP-EPE peer set information for the default BGP instance.
peer-set-name: Specifies a BGP-EPE peer set by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a peer set, this command displays information about all BGP-EPE peer sets.
# Display information about all BGP-EPE peer sets.
<Sysname> display bgp egress-engineering peer-set
  BGP egress peering segment peer-set: a
  PeerSet label : 2172
  Members: 0
  BGP egress peering segment peer-set: b
  PeerSet label : 5555
  Members: 1
         BGP PeerNodeAdj : 3.3.3.3
  BGP egress peering segment peer-set: c
  PeerSet label: 65001
  Label        : 65001
  Members: 2
         BGP PeerNode: 1.1.1.1
         BGP PeerAdj : 10.1.1.1
  PeerSet name: d
  PeerSet label: 65002
  Members: 2
         BGP PeerNode: 2.2.2.2
         BGP PeerAdj : 11.1.1.1
Name of a BGP-EPE peer set.
PeerSet label
SID used by the BGP-EPE peer set.
Label
SID assigned to the BGP-EPE peer set.
Members
Number of peers in the BGP-EPE peer set.
BGP PeerNode
Address of the node peer.
BGP PeerAdj
Address of the adjacency peer.
BGP PeerNodeAdj
Address of the node-adjacency peer.
Use display bgp segment-routing label-range to display BGP SR label ranges.
display bgp [ instance instance-name ] segment-routing label-range
# Display BGP SR label ranges.
<Sysname> display bgp segment-routing label-range
 BGP peering segment labels:
    2048-15999
    24001-599999
 Prefix labels:
    16000-24000
Use display bgp segment-routing prefix-sid-map to display BGP SR prefix-SID mappings.
display bgp [ instance instance-name ] segment-routing prefix-sid-map [ ip-address mask-length | verbose ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP SR prefix-SID mappings of the default BGP instance.
ip-address mask-length: Specifies a range of prefixes by an IP address and a mask length. The mask-length argument is in the range of 1 to 32.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# Display the BGP SR prefix-SID mapping for prefix 1.1.1.1/32.
<Sysname> display bgp segment-routing prefix-sid-map 1.1.1.1 32
Prefix              SID index
1.1.1.1/32          10
# Display brief information about BGP SR prefix-SID mappings for all prefixes.
Number of mappings: 2
Prefix              SID index   Range
1.1.1.1/32          10          100
2.2.2.2/32          256         520
# Display detailed information about BGP SR prefix-SID mappings for all prefixes.
<Sysname> display bgp segment-routing prefix-sid-map verbose
Prefix: 1.1.1.1/32
  SID index     : 10
  Range         : 100
  Last prefix   : 1.1.1.100/32
  Last SID index: 109
Prefix: 2.2.2.2/32
  SID index     : 256
  Range         : 520
  Last prefix   : 2.2.4.9/32
  Last SID index: 775
SID index
Start SID index value.
Range
Number of consecutive SIDs assigned.
Use display isis segment-routing adjacency to display IS-IS SR adjacency SID information.
display isis [ process-id ] segment-routing adjacency [  sid sid-value | vpn-instance vpn-instance-name ] *
process-id: Specifies an IS-IS process ID in the range of 1 to 65535. If you do not specify this argument, the command displays SR adjacency SID information about all IS-IS processes.
sid sid-value: Specifies an adjacency SID by its value. The value range is 1024 to 1010152.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
If you do not specify the sid sid-value option, this command displays information about all IS-IS SR adjacency SIDs.
If you do not specify the vpn-instance vpn-instance-name option, this command displays SR adjacency SID information on the public network.
# Display SR adjacency SID information about IS-IS process 1.
<Sysname> display isis 1 segment-routing adjacency
Adjacency SID: 15020     Type: Non-member-port     Request result: Init
  SystemID           Interface         NextHop         State       ProcessID
  0000.0000.0000.00  XGE3/1/1          2.2.2.2         Inactive    1
Adjacency SID
Adjacency SID value.
Type of the adjacency SID assigned to the adjacency link:
·     Member-port—Adjacency SID assigned to a Layer 3 aggregation group member interface.
·     Non-member-port—Adjacency SID assigned to a Layer 3 Ethernet interface that is not an aggregation group member interface.
Request result
Adjacency SID application result:
·     Succeeded—The application succeeded.
·     Conflicting—The adjacency SID is already used.
·     Init—The application is in progress or the adjacency SID allocation feature is not enabled.
·     Out-of-range—The adjacency SID is not the in the range of the SRLB.
SystemID
System ID of the neighbor.
Interface connected to the neighbor.
Nexthop
Next hop of the adjacency SID.
SID status:
·     Active—The SID is effective and is available for use.
·     Inactive—The SID is not effective and is not available for use.
ProcessID
IS-IS process ID.
Use display isis segment-routing global-block to display IS-IS SRGB information.
display isis segment-routing global-block [ level-1 | level-2 ] [ process-id ]
level-1: Specifies Level-1 SRGB.
level-2: Specifies Level-2 SRGB.
process-id: Specifies an IS-IS process ID in the range of 1 to 65535. If you do not specify this argument, the command displays the SRGBs of all IS-IS processes.
If you do not specify the level-1 or level-2 keyword, the command displays information about both the Level-1 SRGB and Level-2 SRGB.
# Display information about the SRGBs for IS-IS process 1.
<Sysname> display isis segment-routing global-block 1
             Segment routing global block information for IS-IS(1)
                          Level-1 SRGB
System ID                          Base                Range
0000.0000.0011                     16666               5557
0000.0000.0012                     18012               4001
Table 5 Command output
System ID
Base
Minimum label value of the SRGB.
Range
Number of labels in the SRGB.
Use display isis segment-routing prefix-sid-map to display IS-IS SR prefix-SID mappings.
display isis segment-routing prefix-sid-map [ active-policy | backup-policy ] [ process-id ] [ verbose ]
active-policy: Displays active prefix-SID mappings.
backup-policy: Displays inactive prefix-SID mappings.
process-id: Specifies an IS-IS process ID in the range of 1 to 65535. If you do not specify this argument, the command displays information about all IS-IS processes.
If you do not specify the active-policy or backup-policy keyword, the command displays information about both active and inactive prefix-SID mappings.
# Display active IS-IS SR prefix-SID mappings.
<Sysname> display isis segment-routing prefix-sid-map active-policy
         ISIS 1 - Active policy
Number of mappings:  5
Prefix               SID index    Range        Flags
2.2.2.2/32           10           10           -
3.3.3.3/32           300          1            -
8.8.8.8/32           600          20           -
11.11.11.11/32       100          10           -
12.12.12.1/32        44           3            -
# Display detailed information about active IS-IS SR prefix-SID mappings.
<Sysname> display isis segment-routing prefix-sid-map active-policy verbose
Prefix 1.1.1.1 32
    Source        :  Local
    Router ID     :  1010.1020.1030
    Level         :  Not set
    SID index     :  100
    Range         :  1
    Last prefix   :  1.1.1.1/32
    Last SID index:  100
    Flags         :  -
Prefix 2.2.2.2 32
    Source        :  Remote
    Router ID     :  1010.1020.1040
    Level         :  L1
    SID index     :  200
    Range         :  1
    Last prefix   :  2.2.2.2/32
    Last SID index:  200
    Flags         :  -
# Display inactive IS-IS SR prefix-SID mappings.
<Sysname> display isis segment-routing prefix-sid-map backup-policy
         ISIS 1 - Backup policy
Number of mappings:  4
2.2.2.2/32           200          30           -
8.8.8.8/32           600          20           -
2.2.2.2/32           10           10           -
# Display all IS-IS SR prefix-SID mappings.
         ISIS 1 – Both active policy and backup policy
Number of mappings:  9
2.2.2.2/32           10           10           -
2.2.2.2/32           10           10           -
2.2.2.2/32           200          30           -
3.3.3.3/32           300          1            -
8.8.8.8/32           600          20           -
8.8.8.8/32           600          20           -
Table 6 Command output
ISIS 1 – Active policy
Active prefix-SID mappings in IS-IS process 1.
ISIS 1 – Backup policy
Inactive prefix-SID mappings in IS-IS process 1.
All prefix-SID mappings in IS-IS process 1.
SID index
Range
Flags
Mapping flags.
The A flag indicates that the peer specified by the prefix is directly connected to the device.
If no flags are set, this field displays a hyphen (-).
Source
Source of the prefix-SID mapping:
·     Local—The mapping is configured on the local device.
·     Remote—The mapping is configured on the remote device.
Router ID
ID of the route advertiser.
Level
Level of the route advertiser:
·     L1—Level-1 IS-IS route.
·     L2—Level-2 IS-IS route.
·     Not set—The route was locally advertised.
Use display isis segment-routing routing-table to display IS-IS SR routing information.
display isis segment-routing routing-table [ vpn-instance vpn-instance-name ] [ ip ip-address { mask-length | mask } ] [ flex-algo flex-algo-id ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify an MPLS L3VPN instance, this command displays IS-IS SR routing information on the public network.
ip ip-address { mask-length | mask }: Specifies a destination IP address. The ip-address represents the network address in dotted decimal notation. The mask argument represents the network address mask. The mask-length argument represents the mask length in the range of 0 to 32. If you do not specify a destination address, this command displays IS-IS SR routing information for all destination addresses.
flex-algo flex-algo-id: Specifies a Flex-Algo by its ID, in the range of 128 to 255. If you do not specify a Flex-Algo, this command displays IS-IS SR routing information calculated by algorithm 0 (SPF algorithm).
# Display IS-IS SR routing information for all destination addresses on the public network.
<Sysname> display isis segment-routing routing-table
                      Segment-routing routing-table information
            Flags          : D-Delete                 C-On change list
            Outlabel flags : E-Explicit-Null          I-Implicit-Null
                             N-Normal
Total number of routes: 1
 Destination: 14.159.100.2/32
 Flags: -/-
 SourceCount: 1
       ProcessID  : 1         Active       : True    InLabel      : 17234
       Pref       : 3         SubProtocolID: 1       Metric       : 0
       Route type : Learnt    OutLabel cnt : 1
         NextHop   : 0.0.0.0         VrfIndex  : 0      Interface    : XGE3/1/1
         OutLabel  : 17234           Selected  : True   OutLabel flag: E
         LDPLabel  : 2173
         BkNextHop : 13.0.0.2        BkVrfIndex: 4      BkInterface  : XGE3/1/2
         BkOutLabel: 16021           BkOutLabel flag: N
         BkLDPLabel: 4294967295
Table 7 Command output
Flags
Flags in the routing entry:
·     D—The routing entry has been deleted.
·     C—The routing entry has changed.
·     Hyphen (-)—The routing entry has no change.
SourceCount
Number of route advertisement sources.
ProcessID
IS-IS process ID.
Active
State of the route source:
·     True—The device is directly connected to the route source and has the outgoing label for the route source.
·     False—The device is not directly connected to the route source and does not have the outgoing label for the route source.
InLabel
Incoming label.
Pref
Route preference.
SubProtocolID
Routing subprotocol ID.
Metric
Metric of the route:
Route type
Type of the route:
·     Direct
·     Learnt
·     Redist (redistributed route)
·     Summary
·     Attached
·     Invalid
OutLabel cnt
Number of outgoing labels.
NextHop
Nexthop address.
VrfIndex
VRF index.
Brief name of the outgoing interface.
OutLabel
Outgoing label.
Selected
Whether the outgoing label for the next hop has been selected:
·     True
·     False
OutLabel flag
Flag of the outgoing label:
·     E—Explicit null label. The upstream neighbor of the SID node must change the SID to the explicit null label before forwarding packets to the SID node.
·     I—Implicit null label. The upstream neighbor of the SID node must change the SID to the implicit null label before forwarding packets to the SID node.
·     N—Normal label.
BkNextHop
Backup next hop address.
BkVrfIndex
Backup VRF index
BkInterface
Brief outgoing interface name.
BkOutLabel
Backup outgoing label.
BkOutLabel flag
Flag of the backup outgoing label:
·     N—Normal label.
BkLDPLabel
Backup LDP label.
Use display mpls static-sr-mpls to display static SRLSP and adjacency segment information.
display mpls static-sr-mpls { lsp [ lsp-name ] | adjacency [ adjacency-path-name ] }
lsp: Displays static SRLSP information.
lsp-name: Specifies a static SRLSP by its name, a case-sensitive string of 1 to 67 characters. If you do not specify this argument, the command displays information about all static SRLSPs.
adjacency: Displays static adjacency segment information.
adjacency-path-name: Specifies a static adjacency segment by its name, a case-sensitive string of 1 to 67 characters. If you do not specify this argument, the command displays information about all static adjacency segments.
# Display information about all static SRLSPs.
<Sysname> display mpls static-sr-mpls lsp lsp1
Type           : LSP
In-Label       : -
Out-Label      : 60,70,80
Out-Interface  : -
Nexthop        : -
State          : Up
Table 8 Command output
Name
Name of the static SRLSP or adjacency segment.
Information type:
·     LSP—Static SRLSP information.
·     Adjacency—Adjacency segment information.
In-Label
Incoming label.
Out-Label
Outgoing label.
Out-Interface
Output interface.
Nexthop
Next hop address.
Status of the static SRLSP or adjacency segment:
·     Down—The static SRLSP or adjacency segment is not available.
·     Up—The static SRLSP or adjacency segment is available.
static-sr-mpls lsp
Use display mpls static-sr-mpls prefix to display static prefix segment information.
display mpls static-sr-mpls prefix [ path lsp-name | destination ip-address [ mask | mask-length ] ]
path lsp-name: Displays static prefix segment information for the specified static SRLSP. The lsp-name argument specifies a static SRLSP by its name, a case-sensitive string of 1 to 67 characters.
destination ip-address: Displays static prefix segment information for the specified destination address. The ip-address argument specifies a destination address.
mask: Specifies the destination address mask.
mask-length: Specifies the mask length, in the range of 0 to 32.
If you do not specify any parameters, this command displays information about all static prefix segments.
# Display information about all static prefix segments.
<Sysname> display mpls static-sr-mpls prefix
Prefix Name    : prefixname
Destination    : 2.2.2.2/32
In-Label       : 1024
Active         : Yes(1)
Out-Interface  : XGE3/1/1
Nexthop        : 10.0.0.2
Out-Label      : 600000
Status         : up
Out-Interface  : XGE3/1/2
Nexthop        : 11.0.0.2
Out-Label      : 600002
Status         : down(No Route)
Out-Interface  : XGE3/1/3
Nexthop        : 12.0.0.2
Out-Label      : 600001
Status         : down(MPLS not enabled)
Table 9 Command output
Prefix Name
Name of the prefix segment.
Destination
Destination IP address of the prefix segment.
In-Label
Incoming label of the prefix segment.
Active
Status of the prefix segment:
·     Yes(count)—The prefix segment is active. The value of count represents the number of egresses in up status.
·     No—The prefix segment is inactive.
Out-Interface
Outgoing interface of the prefix segment.
Nexthop
Next hop of the prefix segment.
Out-Label
Outgoing label of the prefix segment.
Status
Status of the egress:
·     down—The egress is inactive. The cause is displayed in brackets. Possible causes include:
¡     No Route—The device does not have a route to reach the destination IP address through the outgoing interface.
¡     MPLS not enabled—MPLS is disabled on the outgoing interface.
¡     No main route—The device does not have the main route to reach the destination IP address through the outgoing interface.
¡     Static SRLSP not supported—The outgoing interface cannot be a tunnel interface that uses a static SRLSP.
·     up—The egress is active.
·     duplicate—An egress conflict has occurred because the output interface is already used by another prefix segment.
Use display mpls te tunnel lsp-down-info to display information about the most recent five SRLSP down events for MPLS TE tunnels.
display mpls te tunnel lsp-down-info [ tunnel number ]
tunnel number: Specifies an existing MPLS TE tunnel by the tunnel interface number. If you do not specify an MPLS TE tunnel, this command displays information about the most recent five SRLSP down events for all MPLS TE tunnels.
# Display information about the most recent five SRLSP down events for all MPLS TE tunnels.
<Sysname> display mpls te tunnel lsp-down-info
Tunnel ID           : 1
Down Event Number   : 1
  LSP ID: 100        LSP Type: Backup
  Tunnel Signaling  : Segment Routing
  Down Time         : 2020-3-14 14:30:29.734
  Down Info         : No out segment
  Status After Down : Tunnel went down
Down Event Number   : 2
  LSP ID: 100        LSP Type: Main
  Down Time         : 2020-3-14 14:30:28.621
  Down Info         : Configuration changed
    Detailed Info   : mpls te bandwidth
Table 10 Command output
Down Event Number: number
Reverse ordinal number of the SRLSP down event.
Events are displayed from the most recent to the oldest. The most recent event is displayed as number 1.
LSP ID
LSP ID
LSP Type
LSP type:
·     Main—Primary LSP.
·     Backup—Backup LSP.
Tunnel Signaling
Tunnel signaling protocol. The value is Segment Routing.
Down Time
Time when the SRLSP went down.
Down Info
Reason why the SRLSP went down:
·     No out segment.
·     IGP calculated path failed.
·     SRLG check failed.
·     Configuration changed.
·     PCE state recover.
Detailed Info
More detailed information about the down event.
This field is displayed only when the Down Info value is Configuration changed to provide the key configuration commands that caused the SRLSP down event.
Status After Down
Tunnel status after the SRLSP went down:
·     Tunnel went down.
·     Main LSP MBB succeeded.
·     Main LSP failed, switched to backup LSP.
·     Backup LSP failed, hot-standby disabled.
·     Backup LSP MBB succeeded.
·     Backup LSP is same as main LSP.
Use display mpls te tunnel lsp-event switch to display information about the most recent five SRLSP path switching events for MPLS TE tunnels.
display mpls te tunnel lsp-event switch [ tunnel number ]
tunnel number: Specifies an existing MPLS TE tunnel by the tunnel interface number. If you do not specify an MPLS TE tunnel, this command displays the most recent five SRLSP switching events for all MPLS TE tunnels.
# Display information about the most recent five SRLSP path switching events for all MPLS TE tunnels.
<Sysname> display mpls te tunnel lsp-event switch
Tunnel ID           : 1
Tunnel Signaling    : Static
Switch Event Number : 1
  Switch Type       : Backup LSP inused
  Switch Reason     : Main LSP down
  Switch Time       : 2021-8-14 14:30:29.734
  Path Detail       :
    Old path        : [15001](10.0.0.1/10.0.0.2) - [16041](4.4.4.4)
    New path        : [16030](3.3.3.3) - [16041](4.4.4.4)
Table 11 Command output
Tunnel Signaling
Tunnel signaling protocol. The value is Static or Segment Routing.
Switch Event Number: number
Reverse ordinal number of the SRLSP path switching event.
Switch Type
Path switching type:
·     Backup LSP inused—Traffic has been switched to the backup path because the primary path failed.
·     Main LSP recovered—Traffic has been switched back to the primary path because the primary path recovered.
·     Main LSP make-before-break—Primary path MBB caused by configuration change or other reasons.
·     Backup LSP make-before-break—Backup path MBB caused by configuration change or other reasons.
Switch Reason
Reason why a path switching occurs:
·     Main LSP down.
·     Main LSP up.
·     Main LSP BFD down.
·     Main LSP BFD up.
·     Main LSP BFD deleted.
·     PCE updated.
·     PCE state recovered.
·     Topology recalculated.
Switch Time
Time when the SRLSP switched its path.
Path Detail
Detailed information of the path.
Old path
Path before switching, which is displayed as a stack of labels from top to bottom and the next hop address.
New path
Path after switching, which is displayed as a stack of labels from top to bottom and the next hop address.
Use display ospf segment-routing adjacency to display OSPF SR adjacency SID information.
display ospf [ process-id ] segment-routing adjacency [ sid sid-value ] [ vpn-instance vpn-instance-name ]
process-id: Specifies an OSPF process ID in the range of 1 to 65535. If you do not specify this argument, the command displays SR adjacency SID information about all OSPF processes.
sid sid-value: Specifies an adjacency SID in the range of 1024 to 1010152. If you do not specify an adjacency SID, this command displays information about all OSPF SR adjacency SIDs.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify an MPLS L3VPN instance, this command displays SR adjacency SID information on the public network.
# Display SR adjacency SID information about OSPF process 1.
<Sysname> display ospf 1 segment-routing adjacency
Adjacency SID: 15040     Type: Non-member-port Request result: Init
  NbrID              Interface         NextHop         State     ProcessID
  2.2.2.2            XGE3/1/1          10.1.1.1        Inactive  1
Table 12 Command output
Adjacency SID
Request result
NbrID
ID of the neighbor.
NextHop
SID status:
ProcessID
OSPF process ID.
Use display ospf segment-routing global-block to display OSPF SRGB information.
display ospf [ process-id ] [ area area-id ] segment-routing global-block
process-id: Specifies an OSPF process ID in the range of 1 to 65535. If you do not specify this argument, the command displays the SRGBs of all OSPF processes.
area area-id: Specifies an area by its ID. The area ID can be a value in dotted decimal notation or a decimal value in the range of 0 to 4294967295. If you specify a decimal value, the system automatically transforms it to a value in dotted decimal notation. If you do not specify this option, the command displays the SRGBs of all areas.
# Display the SRGBs of all OSPF processes.
<Sysname> display ospf segment-routing global-block
             Segment Routing Global Block
                     Area: 0.0.0.0
 Router ID       Min SID         Max SID         Total
 1.1.1.1         16000           24000           8001
 2.2.2.2         18000           18999           1000
 3.3.3.3         16000           24000           8001
 4.4.4.4         17000           17999           1000
 5.5.5.5         16000           16999           1000
Table 13 Command output
Router ID
Router ID of the device or the neighbor.
Min SID
Max SID
Maximum label value of the SRGB.
Total
Use display ospf segment-routing prefix-sid-map to display OSPF SR prefix-SID mappings.
display ospf segment-routing prefix-sid-map [ active-policy | backup-policy ] [ process-id ] [ verbose ]
process-id: Specifies an OSPF process ID in the range of 1 to 65535. If you do not specify this argument, the command displays information about all OSPF processes.
# Display active OSPF SR prefix-SID mappings.
<Sysname> display ospf segment-routing prefix-sid-map active-policy
              OSPF 1 - Active policy
Flags:  IA - Inter-Area, L – Local, R - Remote
1.1.1.11/32          10           10           L/-
1.1.1.22/32          20           20           R/-
# Display detailed information about active OSPF SR prefix-SID mappings.
<Sysname> display ospf segment-routing prefix-sid-map active-policy verbose
Prefix 1.1.1.11
    Source        : Local
    Router ID     : 10.1.1.1
    Area ID       : Not set
    LS ID         : Not set
    SID index     : 10
    Range         : 10
    Last prefix   : 1.1.1.20
    Last SID index: 19
    Flags         : -
Prefix 1.1.1.22
    Source        : Remote
    Router ID     : 10.2.1.1
    Area ID       : 0.0.0.1
    LS ID         : 7.0.0.0
    SID index     : 20
    Range         : 20
    Last prefix   : 1.1.1.41
    Last SID index: 39
    Flags         : -
# Display inactive OSPF SR prefix-SID mappings.
<Sysname> display ospf segment-routing prefix-sid-map backup-policy
              OSPF 1 - Backup policy
Number of mappings: 1
1.1.1.33/32          30           30           R/IA
# Display all OSPF SR prefix-SID mappings.
   OSPF 1 - Both active policy and backup policy
Number of mappings: 3
Table 14 Command output
OSPF 1 – Active policy
Active prefix-SID mappings in OSPF process 1.
OSPF 1 – Backup policy
Inactive prefix-SID mappings in OSPF process 1.
OSPF 1 – Both active policy and backup policy
All prefix-SID mappings in OSPF process 1.
SID index
Range
Flags
Mapping flags:
·     IA—The prefix was from another area.
·     L—The mapping is a local mapping.
·     R—The mapping is a remote mapping.
Source
Router ID
Area ID
Area ID. If the mapping is a local mapping, this field displays Not set.
LS ID
Link state ID. If the mapping is a local mapping, this field displays Not set.
Use display ospf segment-routing routing-table to display OSPF SR routing information.
display ospf segment-routing routing-table [ vpn-instance vpn-instance-name ] [ ip ip-address { mask-length | mask } ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify an MPLS L3VPN instance, this command displays OSPF SR routing information on the public network.
ip ip-address { mask-length | mask }: Specifies a destination IP address. The ip-address represents the network address in dotted decimal notation. The mask argument represents the network address mask. The mask-length argument represents the mask length in the range of 0 to 32. If you do not specify a destination address, this command displays OSPF SR routing information for all destination addresses.
# Display OSPF SR routing information for all destination addresses on the public network.
<Sysname> display ospf segment-routing routing-table
                             N-Normal                 P-SR label prefer
 Destination: 1.1.1.1/32
 Flags: -/-/-
 SrouceCount: 1
     ProcessID  : 1         Active       : True    InLabel      : 18555
     Pref       : 10        SubProtocolID: 1       Metric       : 1
     Route type : Stub      OutLabel cnt : 1
         NextHop  : 12.0.0.2         VrfIndex    : 1           Interface     : XGE3/1/1
         OutLabel : 17555            Selected    : True        OutLabel flag : I
         LDPLabel : 4294967295
         BkNextHop : 13.0.0.2        BkVrfIndex  : 4           BkInterface   : XGE3/1/2
Table 15 Command output
Flags
SourceCount
ProcessID
OSPF process ID.
Active
InLabel
Incoming label.
Pref
Route preference.
SubProtocolID
Metric
Route type
Type of the route:
·     Transit
·     Stub
·     Inter
·     Type1
·     Type2
OutLabel cnt
NextHop
Nexthop address.
VrfIndex
VRF index.
OutLabel
Outgoing label.
Selected
·     True
·     False
OutLabel flag
·     N—Normal label.
·     P—SR label preferred.
LDPLabel
LDP label.
BkNextHop
BkVrfIndex
Backup VRF index
BkInterface
BkOutLabel
BkOutLabel flag
·     N—Normal label.
BkLDPLabel
Backup LDP outgoing label.
Use display segment-routing label-block to display SR label block information.
display segment-routing label-block [ protocol { isis | ospf } ]
protocol: Specifies a protocol. If you do not specify this keyword, the command displays SR label block information about all protocols.
isis: Displays IS-IS SR label block information.
ospf: Displays OSPF SR label block information.
# Display SR label block information about all protocols.
<Sysname> display segment-routing label-block
Default label block:
  SRLB: 15000-15999
  SRGB: 16000-55999
Configurate label block:
  SRLB: 200000-210000
  SRGB: 16000-17000
Type      Protocol    Process-ID   Label range     State
SRLB      Global      -            200000-210000   Active
SRGB      Global      -            16000-17000     Active
Table 16 Command output
Label block type, SRGB or SRLB.
Protocol
Protocol to which the label block belongs:
·     ISIS—A IS-IS process.
·     OSPF—An OSPF process.
·     Global—The label block is the global SRGB or SRLB, which is configured in segment routing view..
Process-ID
ID of the protocol process that owns the label block. If label block is the global SRGB or SRLB, this field displays a hyphen (-).
Whether the label block is available for use:
·     Active—The label block is available for use.
·     Inactive—The label block is not available for use.
Use display segment-routing mapping-server prefix-sid-map to display prefix-SID mappings.
display segment-routing mapping-server prefix-sid-map [ ip-address mask-length | verbose ]
ip-address: Specifies an IPv4 address prefix in dotted decimal notation.
mask-length: Specifies the mask length, in the range of 1 to 32.
verbose: Displays detailed information about all configured prefix-SID mappings.
If you do not specify any parameters, this command displays brief information about all configured prefix-SID mappings.
# Display the prefix-SID mapping for prefix 1.1.1.1.
<Sysname> display segment-routing mapping-server prefix-sid-map 1.1.1.1 32
                    SRMS mappings
Prefix              SID index       Flags
1.1.1.1/32          10              A
# Display all configured prefix-SID mappings.
                    SRMS mappings
1.1.1.1/32          10          100         A
2.2.2.2/32          256         520         -
# Display detailed information about all configured prefix-SID mappings.
<Sysname> display segment-routing mapping-server prefix-sid-map verbose
                    SRMS mappings
Prefix 1.1.1.1/32
  SID index     :  10
  Range         :  100
  Last prefix   :  1.1.1.100/24
  Last SID index:  109
  Flags         :  A
Prefix 2.2.2.2/32
  SID index     :  256
  Range         :  520
  Last prefix   :  2.2.4.9/24
  Last SID index:  775
  Flags         :  -
Table 17 Command output
SID index
Range
Flags
Mapping flags.
Last Prefix
Final prefix.
Last SID index
SID assigned to the final prefix.
Use egress-engineering label delete-delay to configure a deletion delay for dynamic SIDs.
Use undo egress-engineering label delete-delay to restore the default.
egress-engineering label delete-delay time-value
The dynamic SID deletion delay time is 1800 seconds.
BGP instance view
time-value: Specifies the deletion delay time, in the range of 0 to 3600 seconds. A value of 0 means no delay and the device deletes the SRv6 SIDs allocated by BGP immediately after the BGP session is down.
Application scenarios
To make sure BGP allocates the same SRv6 SID before and after a BGP session down-up event, use this command to set a proper dynamic SID deletion delay.
Operating mechanism
With this feature configured, the device does not delete the BGP-allocated SRv6 SID when the BGP session is down before the delay timer expires.
·     If the BGP session becomes up before the delay timer expires, the original SRv6 SID is used.
·     If the BGP session is down after the delay timer expires, the BGP-allocated SRv6 SID is deleted.
If an active/standby MPU switchover occurs before the delay timer expires, the device does not delete the dynamically allocated SRv6 SIDs when the neighbors are disconnected and deletes them until after the timer expires.
If you delete the BGP configuration actively, the device immediately deletes the SRv6 SIDs dynamically allocated by BGP without a delay.
# Configure the dynamic SID deletion delay time as 120 seconds.
[Sysname] bgp 100
[Sysname-bgp-default] egress-engineering label delete-delay 120
Use egress-engineering link-delay to configure the link delay information to be reported by BGP to the controller.
Use undo egress-engineering link-delay to restore the default.
egress-engineering link-delay { average average-delay-value | min min-delay-value max max-delay-value | variation variation-value } * interface interface-type interface-number
undo egress-engineering link-delay { average | min | variation } * interface interface-type interface-number
No link delay information is configured.
BGP instance view
average average-delay-value: Specifies the average delay time of the interface, in the range of 1 to 16777215, in microseconds. The average delay is the average value of all delays for the IP data packets sent from the local interface to the BGP neighbor. If you do not specify this option, BGP uses the average delay advertised by the interface.
min min-delay-value max max-delay-value: Specifies the minimum and maximum delay time of the interface, in the range of 1 to 16777215, in microseconds. The minimum and maximum delays are the minimum and maximum delays among all delays for the IP data packets sent from the local interface to the BGP neighbor. If you do not specify this option, BGP uses the minimum and maximum delays advertised by the interface.
variation variation-value: Specifies the delay variation of the interface, in the range of 1 to 16777215, in microseconds. The delay variation refers to the difference between average delays. If you do not specify this option, BGP uses the delay variation advertised by the interface.
interface interface-type interface-number: Specifies the interface to be configured with the delay information. Only physical interfaces are supported.
BGP can obtain delay information of interfaces in the following methods:
·     Static configuration—Use this command to configure the interface delay information for BGP.
·     Dynamic obtaining—Use the test-session bind interface command to bind a TWAMP-light test session to an interface. TWAMP-light sends the collected delay information to the bound interface, which then reports the delay information to BGP.
If BGP obtains delay information in both methods, it uses the statically configured delay information.
If you execute this command multiple times for the same interface, the most recent configuration for each delay parameter takes effect.
The minimum delay value must be smaller than the maximum delay value.
# Configure the average delay, minimum delay, maximum delay, and delay variation of interface Ten-GigabitEthernet 3/1/1 as 100, 10, 1000, and 20 microseconds, respectively.
[Sysname] bgp 100
[Sysname-bgp-default] egress-engineering link-delay average 100 min 10 max 1000 variation 20 interface ten-gigabitethernet 3/1/1
test-session bind interface (Network Management and Monitoring Command Reference)
Use egress-engineering link-loss to configure the packet loss rate for a BGP-EPE interface.
Use undo egress-engineering link-loss to restore the default.
egress-engineering link-loss loss-value interface interface-type interface-number
undo egress-engineering link-loss interface interface-type interface-number
No packet loss rate is configured for a BGP-EPE interface.
BGP instance view
loss-value: Specifies the packet loss rate of the interface, in the range of 0 to 16777214, in a unit of 0.000003%.
interface interface-type interface-number: Specifies the interface to be configured with the packet loss rate. Only physical interfaces are supported.
BGP can obtain packet loss information of BGP-EPE interfaces in the following methods:
·     Static configuration—Use this command to configure the packet loss rate for a BGP-EPE interface.
·     Dynamic obtaining—Use the test-session bind interface command to bind a TWAMP-light test session to an interface. TWAMP-light sends the collected packet loss rate to the bound interface, which then reports the packet loss rate to BGP. For more information about TWAMP-light, see NQA TWAMP-light configuration in Network Management and Monitoring Configuration Guide.
If BGP obtains packet loss information in both methods, it uses the statically configured packet loss rate.
If you execute this command multiple times for the same interface, the most recent configuration takes effect.
# Configure the packet loss rate of interface Ten-GigabitEthernet 3/1/1 as 1000*0.000003%.
[Sysname] bgp 100
[Sysname-bgp-default] egress-engineering link-loss 1000 interface ten-gigabitethernet 3/1/1
Use egress-engineering metric-bandwidth advertisement enable to enable bandwidth advertisement.
Use undo egress-engineering metric-bandwidth advertisement enable to disable bandwidth advertisement.
Bandwidth advertisement is disabled.
BGP instance view
In scenarios where BGP-LS reports link states to a controller for path computation, configure this feature on BGP-EPE devices to enable BGP to collect and propagate intra-AS link bandwidth information and report the information to the controller through BGP-LS. The controller then uses the bandwidth information to compute paths to ensure that the optimal path has the most bandwidth.
# Enable bandwidth advertisement for a BGP instance.
[Sysname] bgp 100
[Sysname-bgp-default] egress-engineering metric-bandwidth advertisement enable
Use egress-engineering metric-bandwidth suppression to enable bandwidth advertisement suppression for BGP and set the suppression parameters.
Use undo egress-engineering metric-bandwidth suppression to disable bandwidth advertisement suppression for BGP.
egress-engineering metric-bandwidth suppression timer time-value
Bandwidth advertisement suppression of BGP is enabled, and the bandwidth advertisement suppression timer is 120 seconds.
BGP instance view
timer time-value: Sets the bandwidth advertisement suppression timer, in the range of 0 to 600 seconds. A value of 0 means to disable bandwidth advertisement suppression.
When bandwidth changes frequently, BGP will frequently process, advertise, and report the bandwidth information, occupying too many device resources. To resolve this issue, you can enable the bandwidth advertisement suppression feature.
After this feature is enabled, interfaces report bandwidth information to BGP at intervals of the bandwidth advertisement suppression time. BGP advertises and reports bandwidth information at intervals of the bandwidth advertisement suppression time. It cannot advertise or report bandwidth information before the suppression timer expires.
This command takes effect only after the egress-engineering metric-bandwidth advertisement enable command is enabled.
# Enable bandwidth advertisement suppression and set the suppression timer to 100 seconds.
[Sysname] bgp 100
[Sysname-bgp-default] egress-engineering metric-bandwidth suppression timer 100
Use egress-engineering metric-delay advertisement enable to enable delay advertisement for BGP.
Use undo egress-engineering metric-delay advertisement enable to disable delay advertisement for BGP.
Delay advertisement is disabled.
BGP instance view
In scenarios where BGP-LS reports link states to a controller for path computation, configure this feature on BGP-EPE devices to enable BGP to collect and propagate intra-AS link delay information and report the information to the controller through BGP-LS. The controller then uses the delay information to compute paths to ensure that the optimal path has the least delay.
# Enable delay advertisement in a BGP instance.
[Sysname] bgp 100
[Sysname-bgp-default] egress-engineering metric-delay advertisement enable
Use egress-engineering metric-delay suppression to enable delay advertisement suppression for BGP and set the suppression parameters.
Use undo egress-engineering metric-delay suppression to disable delay advertisement suppression for BGP.
egress-engineering metric-delay suppression timer time-value percent-threshold percent-value absolute-threshold absolute-value
Delay advertisement suppression is enabled, and the suppression timer is 120 seconds, the delay change percentage threshold is 10%, and the delay change absolute value threshold is 1000 microseconds.
BGP instance view
timer time-value: Specifies the delay advertisement suppression timer, in the range of 0 to 600 seconds. A value of 0 means to disable delay advertisement suppression.
percent-threshold percent-value: Specifies the delay change percentage threshold, in the range of 0 to 100. A value of 0 means not to concern the delay change percentage during suppression.
absolute-threshold absolute-value: Specifies the delay change absolute value threshold, in the range of 0 to 10000. A value of 0 means not to concern the delay change absolute value during suppression.
When delay changes frequently, BGP will frequently process, advertise, and report the delay information, occupying too many device resources. To resolve this issue, you can enable the delay advertisement suppression feature.
Delay advertisement suppression operates as follows:
1.     After this feature is enabled, interfaces report delay information to BGP at intervals of the delay advertisement suppression time.
2.     BGP advertises and reports delay information at intervals of the delay advertisement suppression time. It cannot advertise or report delay information before the suppression timer expires except in the following cases:
¡     If the percentage of the change between two consecutive delays reported by an interface reaches or exceeds the threshold set by percent-value, BGP advertises and reports the delay information regardless of whether the suppression timer has expired or not.
¡     If the absolute value of change between two consecutive delays reported by an interface reaches or exceeds the threshold set by absolute-value, BGP advertises and reports the delay information regardless of whether the suppression timer has expired or not.
This command takes effect only after the egress-engineering metric-delay advertisement enable command is enabled.
If a suppression parameter is set to 0, the corresponding suppression function is disabled. If all the suppression parameters are set to 0, the entire delay advertisement suppression feature is disabled.
# Enable delay advertisement suppression for BGP, set the suppression timer to 100 seconds, the delay change percentage threshold to 50%, and delay change absolute value threshold to 200 microseconds.
[Sysname] bgp 100
[Sysname-bgp-default] egress-engineering metric-delay suppression timer 100 percent-threshold 50 absolute-threshold 200
Use egress-engineering metric-link-loss advertisement enable to enable packet loss rate advertisement for BGP-EPE.
Use undo egress-engineering metric-link-loss advertisement enable to disable packet loss rate advertisement for BGP-EPE.
Packet loss rate advertisement is disabled for BGP-EPE.
BGP instance view
·     Static configuration—Use the egress-engineering link-loss command to configure the packet loss rate for a BGP-EPE interface.
In scenarios where BGP-LS reports link states to a controller for path computation, configure the packet loss rate advertisement feature on BGP-EPE devices. Then, BGP can collect packet loss information locally and from the BGP-EPE neighbors and report the information to the controller through BGP-LS. The controller then uses the packet loss information to compute paths to ensure that the optimal path has the smallest packet loss rate.
NQA can collect packet loss rate statistics only from physical interfaces. As a best practice, use directly connected physical interfaces to establish BGP-EPE neighbor relationships to avoid packet loss rate collection failure.
# Enable packet loss rate advertisement in a BGP instance.
[Sysname] bgp 100
[Sysname-bgp-default] egress-engineering metric-link-loss advertisement enable
egress-engineering link-delay advertisement enable
Use egress-engineering metric-link-loss suppression to enable packet loss rate advertisement suppression for BGP-EPE and set the suppression parameters.
Use undo egress-engineering metric-link-loss suppression to disable packet loss rate advertisement suppression for BGP-EPE.
egress-engineering metric-link-loss suppression timer time-value percent-threshold percent-value absolute-threshold absolute-value
Packet loss rate advertisement suppression is enabled. The suppression timer is 120 seconds. The percentage threshold of the packet loss rate change is 10%. The absolute value threshold of the packet loss rate change is 0.01%.
BGP instance view
timer time-value: Specifies the packet loss rate advertisement suppression timer, in the range of 0 to 600 seconds. A value of 0 means to disable packet loss rate advertisement suppression.
percent-threshold percent-value: Specifies the packet loss rate change percentage threshold, in the range of 0 to 100. A value of 0 means not to concern the packet loss rate change percentage during suppression. The packet loss rate change percentage = the absolute value of the difference between two consecutive packet loss rates / previous packet loss rate.
absolute-threshold absolute-value: Specifies the packet loss rate change absolute value threshold, in the range of 0 to 10000, in a unit of 0.00001%. A value of 0 means not to concern the packet loss rate change absolute value during suppression. The packet loss rate change absolute value is the absolute value of the difference between two consecutive packet loss rates.
When packet loss rate changes frequently, BGP will frequently process, advertise, and report the packet loss rate information, occupying too many device resources. To resolve this issue, you can enable the packet loss rate advertisement suppression feature.
Packet loss rate advertisement suppression operates as follows:
1.     After this feature is enabled, interfaces report packet loss rate information to BGP at intervals of the packet loss rate advertisement suppression time.
2.     BGP advertises and reports packet loss rate information at intervals of the packet loss rate advertisement suppression time. It cannot advertise or report packet loss rate information before the suppression timer expires except in the following cases:
¡     If the percentage of the change between two consecutive packet loss rates reported by an interface reaches or exceeds the threshold set by percent-value, BGP advertises and reports the packet loss rate information regardless of whether the suppression timer has expired or not.
¡     If the absolute value of the change between two consecutive packet loss rates reported by an interface reaches or exceeds the threshold set by absolute-value, BGP advertises and reports the packet loss rate information regardless of whether the suppression timer has expired or not.
This command takes effect only after the egress-engineering metric-link-loss advertisement enable command is enabled.
If a suppression parameter is set to 0, the corresponding suppression function is disabled. If all the suppression parameters are set to 0, the entire packet loss rate advertisement suppression feature is disabled.
If you execute both the egress-engineering metric-link-loss suppression command and the egress-engineering metric-delay suppression command, NQA uses the smaller value of the suppression timers set by the two commands as the time interval for advertising packet loss rate and delay information.
As a best practice, set the packet loss rate advertisement suppression timer greater than or equal to the NQA TWAMP-light packet loss rate test interval. For more information about TWAMP-light, see NQA TWAMP-light configuration in Network Management and Monitoring Configuration Guide.
# Enable packet loss rate advertisement suppression for BGP-EPE, set the suppression timer to 300 seconds, the percentage threshold of the packet loss rate change to 20%, and the absolute value threshold of the packet loss rate change to 0.02%.
[Sysname] bgp 100
[Sysname-bgp-default] egress-engineering metric-link-loss suppression timer 300 percent-threshold 20 absolute-threshold 2000
Use egress-engineering peer-set to create a BGP-EPE peer set.
Use undo egress-engineering peer-set to delete a BGP-EPE peer set.
egress-engineering peer-set peer-set-name [ label label-value ]
undo egress-engineering peer-set peer-set-name
No BGP-EPE peer sets exist.
BGP instance view
peer-set-name: Specifies a BGP-EPE peer set name, a case-sensitive string of 1 to 63 characters.
label label-value: Specifies a SID for the BGP EPE peer set. The value range for the label-value argument is 16 to 1010152. If you do not specify a SID, this command dynamically assigns a SID for the BGP EPE peer set.
BGP-EPE assigns BGP peering SIDs to segments across ASs. The device sends BGP peering SIDs to the controller through BGP-LS extensions. The controller orchestrates IGP SIDs and BGP peering SIDs for inter-AS forwarding over optimal paths.
You can add multiple BGP peers into a BGP-EPE peer set and assign a PeerSet SID to the set. A PeerSet SID corresponds to multiple outgoing interfaces.
Before assigning BGP-EPE SIDs, execute the display mpls label command to display the usage status of the labels that you want to assign as BGP-EPE SIDs. Make sure the labels are in Idle state. A label that is not in Idle state is being used by another protocol. If you assign it to a peer or peer group as a BGP-EPE SID, the BGP-EPE SID is not available even if the status of the label changes to Idle later. To use the BGP-EPE SID, you must remove the BGP-EPE SID assignment and assign the BGP-EPE SID again.
# Create a BGP-EPE peer set named bgpepe, and assign SID 5555 to the set.
[Sysname] bgp 100
[Sysname-bgp-default] egress-engineering peer-set bgpepe label 5555
display mpls label
peer egress-engineering
peer peer-set
fast-reroute microloop-avoidance enable
Use fast-reroute microloop-avoidance enable to enable FRR microloop avoidance.
Use undo fast-reroute microloop-avoidance enable to disable FRR microloop avoidance.
In IS-IS IPv4 unicast address family view:
fast-reroute microloop-avoidance enable [ level-1 | level-2 ]
undo fast-reroute microloop-avoidance enable [ level-1 | level-2 ]
In OSPF view:
FRR microloop avoidance is disabled.
OSPF view
level-1: Specifies FRR microloop avoidance for IS-IS Level-1.
level-2: Specifies FRR microloop avoidance for IS-IS Level-2.
Use this command only on the source node.
On a network configured with TI-LFA FRR, if a node or link fails, traffic will be switched to the backup path calculated by TI-LFA. However, if a device along the backup path has not finished route convergence, traffic might be looped between the device and the source node. The source node is the node prior to the node or link that failed. The loop will exist until the device finishes route convergence.
To resolve this issue, configure microloop avoidance on the source node enabled with TI-LFA FRR. Then, when a node or link on the optimal path fails, traffic will be switched to the backup path calculated by TI-LFA. The source node starts a delay timer for other devices to finish route convergence. After the delay timer expires, the source node installs the converged path to the FIB and switches traffic from the TI-LFA-calculated backup path to the converged path.
If you configure both FRR microloop avoidance and SR microloop avoidance, both timers are started and FRR microloop avoidance takes effect.
·     The value of the delay timer of FRR microloop avoidance is greater than or equal to the value of the delay timer of SR microloop avoidance, the device switches to the converged path immediately after the delay timer of the latter expires.
·     The value of the delay timer of FRR microloop avoidance is smaller than or equal to the value of the delay timer of SR microloop avoidance, the device switches to the converged path after the delay timer of the former expires.
If you do not specify the level-1 or level-2 keyword, the command enables or disables FRR microloop avoidance on all IS-IS levels.
# Enable FRR microloop avoidance for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] address-family ipv4
[Sysname-isis-1-ipv4] fast-reroute microloop-avoidance enable
# Enable FRR microloop avoidance for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute microloop-avoidance enable
fast-reroute microloop-avoidance rib-update-delay
segment-routing microloop-avoidance enable
Use fast-reroute microloop-avoidance rib-update-delay to set the FRR microloop avoidance RIB-update-delay time.
Use undo fast-reroute microloop-avoidance rib-update-delay to restore the default.
fast-reroute microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
undo fast-reroute microloop-avoidance rib-update-delay [ level-1 | level-2 ]
In OSPF view:
The FRR microloop avoidance RIB-update-delay time is 5000 ms.
OSPF view
delay-time: Specifies the FRR microloop avoidance RIB-update-delay time in milliseconds. The value range is 1 to 60000.
level-1: Specifies the FRR microloop avoidance RIB-update-delay time for IS-IS Level-1.
level-2: Specifies the FRR microloop avoidance RIB-update-delay time for IS-IS Level-2.
If you do not specify the level-1 or level-2 keyword, the command sets the FRR microloop avoidance RIB-update-delay time for all IS-IS levels.
# Set the FRR microloop avoidance RIB-update-delay time to 6000 ms for Level-1 of IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] fast-reroute microloop-avoidance rib-update-delay 6000 level-1
# Set the FRR microloop avoidance RIB-update-delay time to 6000 ms for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute microloop-avoidance rib-update-delay 6000
fast-reroute ti-lfa
Use fast-reroute ti-lfa to enable Topology-Independent Loop-Free Alternate Fast Re-Route (TI-LFA FRR).
Use fast-reroute ti-lfa to disable TI-LFA FRR.
fast-reroute ti-lfa [ per-prefix ] [ route-policy route-policy-name | host ] [ level-1 | level-2 ]
undo fast-reroute ti-lfa [ level-1 | level-2 ]
In OSPF view:
TI-LFA FRR is disabled.
OSPF view
level-1: Specifies TI-LFA FRR for IS-IS Level-1.
level-2: Specifies TI-LFA FRR for IS-IS Level-2.
per-prefix: Calculates backup information for each advertising source of a route. Specify this keyword only if routes are advertised by multiple sources. If you do not specify this keyword, the device calculates backup information for each route.
route-policy route-policy-name: Enables TI-LFA FRR for prefixes identified by the routing policy. The route-policy-name argument specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
host: Enables TI-LFA for host routes.
TI-LFA FRR provides link and node protection for SR tunnels. When a link or node fails, TI-LFA FRR switches the traffic to the backup path to ensure continuous data forwarding.
Before configuring TI-LFA FRR, you must execute the following commands in IS-IS IPv4 unicast address family view or OSPF view:
·     segment-routing mpls
·     fast-reroute lfa
TI-LFA FRR takes effect only after you enable LFA FRR.
TI-LFA FRR operates in a level only after you enable LFA FRR for the level.
If you do not specify the level-1 or level-2 keyword, the command enables or disables TI-LFA FRR for all IS-IS levels.
If you do not specify the route-policy route-policy-name option or the host keyword, the device calculates backup information for all routes.
# Enable TI-LFA FRR for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] fast-reroute ti-lfa
# Enable TI-LFA FRR for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute ti-lfa
fast-reroute (Layer 3IP Routing Command Reference)
route-policy (Layer 3IP Routing Command Reference)
global-block
Use global-block to configure the global MPLS SRGB.
Use undo global-block to restore the default.
global-block minimum-value maximum-value
undo global-block
The global MPLS SRGB is from 16000 to 24000.
Segment routing view
minimum-value: Specifies the minimum label value, in the range of 1024 to 1010151.
maximum-value: Specifies the maximum label value, in the range of 1025 to 1010152.
The global MPLS SRGB is used for prefix segments and BGP prefix SIDs. If no MPLS SRGB is configured for a protocol process, the process uses the global MPLS SRGB.
If you have configured prefix SIDs when you configure the global MPLS SRGB, the global MPLS SRGB must contain the configured prefix SIDs.
Before executing this command, use the display mpls label command to display MPLS label usage information. Make sure that all labels in the specified SRGB range are idle. If a label in the range is not idle, the SRGB cannot be configured.
# Configure the global MPLS SRGB to be from 200000 to 220000.
[Sysname] segment-routing
[Sysname-segment-routing] global-block 200000 220000
isis adjacency-sid
Use isis adjacency-sid to assign an IS-IS adjacency SID to an IS-IS adjacency.
Use undo isis adjacency-sid to reclaim an IS-IS adjacency SID.
isis adjacency-sid { absolute absolute-value | index index-value } [ nexthop nexthop-address ]
undo isis adjacency-sid { absolute absolute-value | index index-value } [ nexthop nexthop-address ]
An IS-IS adjacency does not have an adjacency SID.
Interface view
absolute absolute-value: Specifies an absolute value as the adjacency SID. The value range for the absolute-value argument is 1024 to 1010152.
index index-value: Specifies an adjacency SID index value in the range of 0 to 1009128.
nexthop nexthop-address: Specifies a next hop by its IP address. If the network type of the interface is broadcast, you must specify this option. If the network type of the interface is P2P, you cannot specify this option.
After you enable IS-IS adjacency SID allocation, the device randomly allocates adjacency SIDs to the links to its IS-IS neighbors. If the link to an IS-IS neighbor flaps, the adjacency SID of the link keeps changing. For a link to always use the same adjacency SID, use this command to assign a specific adjacency SID to the link.
You can assign adjacency SIDs by using absolute values or index values. If you use index values, the adjacency SID of a link is the base value of the SRLB plus the index value for the link.
Before assigning adjacency SIDs, execute the display mpls label command to display the usage status of the labels that you want to assign as adjacency SIDs. Make sure the labels are in Idle state. A label that is not in Idle state is being used by another protocol. If you assign it to a link as an adjacency SID, the adjacency SID is not available even if the status of the label changes to Idle later. To use the adjacency SID, you must remove the adjacency SID assignment and assign the adjacency SID again.
Before executing the isis adjacency-sid command on an interface, you must complete the following tasks:
·     Enable IS-IS on the interface.
·     Execute the segment-routing mpls and segment-routing adjacency enable commands.
You can assign the same adjacency SID on multiple interfaces.
If you execute the isis adjacency-sid command multiple times on an interface of the P2P network type, the most recent configuration takes effect.
If you execute the isis adjacency-sid command multiple times on an interface of the broadcast network type, the effective configuration varies depending on how you specify the next hop address:
·     If you specify a different next hop address each time, all configurations take effect.
·     If you specify the same next hop address each time, the most recent configuration takes effect.
To change the network type of an interface, execute the isis circuit-type p2p command before executing the isis adjacency-sid command on the interface. To change the network type of an interface after assigning an adjacency SID to the interface, you must remove the assignment first.
# Set the absolute value of the adjacency SID to 20000 on interface Ten-GigabitEthernet 3/1/1. Specify 1.1.1.1 as the next hop.
[Sysname] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] isis enable 1
[Sysname-Ten-GigabitEthernet3/1/1] isis adjacency-sid absolute 20000 nexthop 1.1.1.1
display mpls label (MPLS Command Reference)
isis circuit-type p2p (Layer 3IP Routing Command Reference)
isis enable (Layer 3IP Routing Command Reference)
isis fast-reroute ti-lfa disable
Use isis fast-reroute ti-lfa disable to disable an IS-IS interface from participating in TI-LFA calculation.
Use undo isis fast-reroute ti-lfa disable to enable an IS-IS interface to participate in TI-LFA calculation.
isis fast-reroute ti-lfa disable [ level-1 | level-2 ]
undo isis fast-reroute ti-lfa disable [ level-1 | level-2 ]
An IS-IS interface participates in TI-LFA calculation.
Interface view
level-1: Specifies TI-LFA calculation on IS-IS Level-1.
level-2: Specifies TI-LFA calculation on IS-IS Level-2.
Disable the output interface to the primary next hop from participating in TI-LFA calculation.
If you do not specify the level-1 or level-2 keyword, the command disables or enables the interface to participate in TI-LFA calculation in any level.
# Disable interface Ten-GigabitEthernet 3/1/1 from participating in TI-LFA calculation.
[Sysname-Ten-GigabitEthernet3/1/1] isis fast-reroute ti-lfa disable
fast-reroute ti-lfa
isis prefix-sid
Use isis prefix-sid to configure an IS-IS prefix SID.
Use undo isis prefix-sid to restore the default.
isis [ process-id process-id ] prefix-sid [ algorithm algorithm-id ] { absolute absolute-value | index index-value } [ n-flag-clear | { explicit-null  | no-php } ] *
undo isis [ process-id process-id ] prefix-sid [ algorithm algorithm-id ]
No IS-IS prefix SID is configured.
Loopback interface view
process-id process-id: Specifies an IS-IS process by its process ID in the range of 1 to 65535. To configure an IS-IS prefix SID for a traditional IS-IS process, do not specify this option.
algorithm algorithm-id: Specifies a Flex-Algo for the prefix SID. The algorithm-id argument represents the Flex-Algo ID, in the range of 128 to 255. If you do not specify a Flex-Algo, IS-IS uses the SPF algorithm to calculate the shortest path to the prefix SID.
absolute absolute-value: Specifies an absolute value as the prefix SID. The value range for the absolute-value argument is 1024 to 1010152.
index index-value: Specifies an index value as the adjacency SID. The value range for the index-value argument is 0 to 1009128.
n-flag-clear: Sets the Node-SID flag bit of the prefix SID to 0 to use the prefix SID for a group of SR nodes. If you do not specify this keyword, the flag bit is 1 and the prefix SID is used for a single SR node.
explicit-null: Sets the Explicit-null flag bit of the prefix SID to 1. This setting requires that the upstream neighbor uses an explicit null label to replace the prefix SID. If you do not specify this keyword, the flag bit is 0 and the upstream neighbor continues to forward the packet based on the prefix SID. For more information about the explicit null label, see MPLS basics configuration in MPLS Configuration Guide.
no-php: Sets the P-flag bit of the prefix SID to 1 so the penultimate hop does not pop out the SID. If you do not specify this keyword, the P-flag bit is 0 and the penultimate hop pops out the SID.
An absolute value used as the prefix SID takes effect only if it is in the SRGB of the node.
If you specify an index value, the sum of the index value and the SRGB base value is used as the prefix SID. The prefix SID takes effect only if it is in the SRGB of the node.
To use a prefix SID for a group of SR nodes in anycast scenarios, specify the n-flag-clear keyword to set the Node-SID flag bit of the prefix SID to 0.
To configure an IS-IS prefix SID, you must enable an IS-IS process on the loopback interface.
If you execute this command on an interface multiple times, the most recent configuration takes effect.
# Set the IS-IS prefix SID index value to 20 on loopback interface 1.
[Sysname] interface loopback 1
[Sysname-LoopBack1] isis enable 1
[Sysname-LoopBack1] isis prefix-sid index 20
local-block
Use local-block to configure the SRLB.
Use undo local-block to restore the default.
local-block minimum-value maximum-value [ ignore-conflict ]
undo local-block
The SRLB is from 15000 to 15999.
ignore-conflict: Ignores the conflicts between the SRLB and allocated adjacency SIDs. With this keyword specified, this command can be executed but does not take effect if an allocated adjacency SID is not within the configured SRLB range. Without this keyword specified, this command cannot be executed if an allocated adjacency SID is not within the configured SRLB range.
CAUTION
CAUTION:
With the ignore-conflict keyword specified, this command can be executed but does not take effect if an allocated SR-MPLS adjacency SID is not within the configured SRLB range. To make the configured SRLB take effect, you must restart the device. Meanwhile, you must also change the allocated SID to be within the SRLB. Otherwise, the SRLSP using that SID cannot forward packets normally.
The segment routing local block (SRLB) is the range of local labels dedicated for SR-MPLS adjacency SIDs.
The device has a default reserved SRLB, which can neither be edited or deleted nor be used by other protocols. If you do not configure this command, the device allocates SR-MPLS adjacency SIDs from the reserved SRLB. In addition to the reserved SRLB, you can also use this command to allocate an additional label range as the SRLB to the device. The device will allocate SR-MPLS adjacency SIDs from the configured SRLB.
If adjacency SIDs have been allocated from the reserved or configured SRLB, do not change the minimum label value in the SRLB when you configure this command. If you change the minimum label value, adjacency SIDs generated by using index values will be affected.
When you use this command to change the configured SRLB, follow these restrictions and guidelines:
·     If you reduce the configured SRLB range, make sure the labels to be released in the SRLB are not in inuse state. You must first release the labels.
·     If you expand the configured SRLB range, make sure the labels to be added in the SRLB are not in inuse or alloc state. You must first release the labels.
# Configure the SRLB to be from 200000 to 220000.
[Sysname-segment-routing] local-block 200000 220000
display mpls label
display mpls summary (MPLS Command Reference)
Use mapping-server prefix-sid-map to configure a prefix-SID mapping.
Use undo mapping-server prefix-sid-map to delete a prefix-SID mapping.
mapping-server prefix-sid-map ip-address mask-length start-value [ range range-value ] [ attached ]
undo mapping-server prefix-sid-map ip-address mask-length
No prefix-SID mappings exist.
ip-address: Specifies an IPv4 address prefix to be mapped or specifies the start IP prefix for a range of prefix-SID mappings, in dotted decimal notation.
start-value: Specifies the index value of the SID to be mapped to the specified prefix, or specifies the index value of the start SID for a range of prefix-SID mappings. The value range for this argument is 0 to 1009127.
range range-value: Specifies the number of prefix-SID mappings, in the range of 1 to 1009128.
attached: Specifies that the specified prefixes represent local networks.
The specified prefixes must not belong to any existing prefix-SID mappings.
Before you configure prefix-SID mappings in bulk, plan the number of mappings. Make sure there are enough mappings to use.
If you specify a value greater than 65535 for the range-value argument, the prefix-SID mappings cannot be advertised through IS-IS or OSPF.
# Map prefix 1.1.1.1/32 to SID index value 100.
[Sysname-segment-routing] mapping-server prefix-sid-map 1.1.1.1 32 100
# Configure two prefix-SID mappings, starting from prefix 10.1.1.1/32 and SID index value 200.
[Sysname-segment-routing] mapping-server prefix-sid-map 10.1.1.1 32 200 range 2
In the first mapping, the prefix is 10.1.1.1/32 and the SID is 200. In the second mapping, the prefix is 10.1.1.2/32 and the SID is 201.
mpls te path-selection adjacency-sid
Use mpls te path-selection adjacency-sid to configure a tunnel interface to perform CSPF calculation strictly based on adjacency SID information when establishing an SRLSP for an MPLS TE tunnel.
Use undo mpls te path-selection adjacency-sid to restore the default.
A tunnel interface does not perform CSPF calculation strictly based on adjacency SID information when establishing an SRLSP for an MPLS TE tunnel.
Tunnel interface view
This command takes effect only on an MPLS TE tunnel established by using SR.
Before executing this command, you must enable SR-MPLS and SR-MPLS adjacency SID allocation on each node that the TE tunnel might traverse.
If an MPLS TE tunnel is already established when you execute this command, the tunnel interface calculates a new SRLSP based on adjacency SID information.
·     If the new SRLSP is successfully established, the tunnel interface removes the old SRLSP and uses the new SRLSP to establish a new MPLS TE tunnel.
·     If the new SRLSP fails to be established, the tunnel interface continues to use the old SRLSP.
# Configure a tunnel interface to perform CSPF calculation strictly based on adjacency SID information when establishing an SRLSP for an MPLS TE tunnel.
[Sysname] interface tunnel 1 mode mpls-te
[Sysname-Tunnel1] mpls te path-selection adjacency-sid
mpls te static-sr-mpls
Use mpls te static-sr-mpls to bind a static SRLSP to an MPLS TE tunnel interface.
Use undo mpls te static-sr-mpls to unbind a static SRLSP from an MPLS TE tunnel interface.
mpls te static-sr-mpls lsp-name [ backup ]
undo mpls te static-sr-mpls lsp-name
An MPLS TE tunnel interface does not use any static SRLSPs.
lsp-name: Specifies a static SRLSP by its name, a case-sensitive string of 1 to 67 characters. The specified static SRLSP must be already created by using the static-sr-mpls lsp command.
backup: Specifies the backup static SRLSP. If you do not specify this keyword, this command specifies the main static SRLSP.
Execute this command only on the ingress node of a static SRLSP.
This command takes effect only if you have configured the mpls te signaling static command in tunnel interface view.
You can specify the backup keyword to bind a backup static SRLSP only if both the main and backup SRLSPs are established by using the adjacency segment method.
If you execute both the mpls te static-sr-mpls and mpls te static-cr-lsp commands on the device, only the mpls te static-cr-lsp command takes effect. For the mpls te static-sr-mpls command to take effect, execute the undo mpls te static-cr-lsp command.
# Bind static SRLSP static-sr-3 to MPLS TE tunnel interface 0.
[Sysname] interface tunnel 0 mode mpls-te
[Sysname-Tunnel0] mpls te static-sr-mpls static-sr-3
display mpls te tunnel-interface (MPLS Command Reference)
mpls te signaling (MPLS Command Reference)
mpls te static-cr-lsp (MPLS Command Reference)
static-sr-mpls lsp
ospf adjacency-sid
Use ospf adjacency-sid to assign an OSPF adjacency SID to an OSPF adjacency.
Use undo ospf adjacency-sid to reclaim an OSPF adjacency SID.
ospf adjacency-sid { absolute absolute-value | index index-value } [ nexthop nexthop-address ]
undo ospf adjacency-sid { absolute absolute-value | index index-value } [ nexthop nexthop-address ]
An OSPF adjacency does not have an adjacency SID.
Interface view
index index-value: Specifies an adjacency SID index value as the adjacency SID. The value range for the index-value argument is 0 to 1009128.
nexthop nexthop-address: Specifies a next hop by its IP address. If the network type of the interface is not P2P, you must specify this option. If the network type of the interface is P2P, you cannot specify this option.
After you enable OSPF adjacency SID allocation, the device randomly allocates adjacency SIDs to the links to its OSPF neighbors. If the link to an OSPF neighbor flaps, the adjacency SID of the link keeps changing. For a link to always use the same adjacency SID, use this command to assign a specific adjacency SID to the link.
The ospf adjacency-sid command takes effect only after you execute the segment-routing mpls and segment-routing adjacency enable commands.
If you execute the ospf adjacency-sid command multiple times on an interface of the P2P network type, the most recent configuration takes effect.
If you execute the ospf adjacency-sid command multiple times on an interface of the broadcast network type, the effective configuration varies depending on how you specify the next hop address:
To change the network type of an interface, execute the ospf network-type command.
# Set the absolute value of the adjacency ID to 20000 on interface Ten-GigabitEthernet 3/1/1. Specify 1.1.1.1 as the next hop.
[Sysname-Ten-GigabitEthernet3/1/1] ospf adjacency-sid absolute 20000 nexthop 1.1.1.1
ospf network-type (Layer 3IP Routing Command Reference)
ospf fast-reroute ti-lfa disable
Use ospf fast-reroute ti-lfa disable to disable an OSPF interface from participating in TI-LFA calculation.
Use undo ospf fast-reroute ti-lfa disable to enable an OSPF interface to participate in TI-LFA calculation.
An OSPF interface participates in TI-LFA calculation.
Interface view
On the source node, the route's output interface to the primary next hop might not be on the backup path calculated by TI-LFA. Disable TI-LFA on the interface to prevent it from participating in TI-LFA calculation.
[Sysname-Ten-GigabitEthernet3/1/1] ospf fast-reroute ti-lfa disable
fast-reroute ti-lfa (OSPF view)
ospf prefix-sid
Use ospf prefix-sid to configure an OSPF prefix SID.
Use undo ospf prefix-sid to restore the default.
ospf process-id prefix-sid { absolute absolute-value | index index-value } [ n-flag-clear | { explicit-null | no-php } ] *
undo ospf process-id prefix-sid
No OSPF prefix SID is configured.
index index-value: Specifies an index value as the prefix SID. The value range for the index-value argument is 0 to 1009128.
The configured OSPF prefix SID takes effect only if the OSPF process enabled on the loopback interface is the same as the OSPF process associated with the prefix SID.
# Set the OSPF prefix SID index value to 20 on loopback interface 1.
[Sysname-LoopBack1] ospf 1 prefix-sid index 20
Use peer egress-engineering to enable BGP-EPE for a peer or peer group and assign a label (SID) to the peer or peer group.
Use undo peer egress-engineering to restore the default for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } egress-engineering [ adjacency | node-adjacency | set ] [ label label-value | route-policy policy-name ]
undo peer { group-name | ipv4-address [ mask-length ] } egress-engineering
BGP-EPE is disabled.
BGP instance view
group-name: Specifies an existing peer group by its name, a case-sensitive string of 1 to 47 characters.
ipv4-address: Specifies the IPv4 address of an existing peer.
mask-length: Specifies the mask length, in the range of 0 to 32. This argument and the ipv4-address argument together specify a subnet. If you specify this argument, the command applies to dynamic peers on the specified subnet.
adjacency: Assigns a PeerAdj SID.
node-adjacency: Assigns both a PeerNode SID and a PeerAdj SID.
set: Assigns a PeerSet SID.
label label-value: Specifies the SID value, in the range of 16 to 1010152.
route-policy route-policy-name: Specifies a routing policy to a assign a SID. The route-policy-name argument represents the routing policy name, a case-sensitive string of 1 to 63 characters.
If you do not specify the adjacency, node-adjacency, or set keyword, the device assigns a PeerNode SID.
If you enable BGP-EPE without specifying an SID (by using the label or route-policy option), the device randomly assigns an SID to the specified peer or peer group.
When you use BGP-EPE to apply a routing policy to a peer or peer group, follow these restrictions and guidelines:
·     You can use the apply label-value command to set an SID value and cannot use the apply label-index command to set a label index value.
·     You cannot apply a routing policy to assign the same label to multiple BGP peers or peer groups when you assign a PeerNode SID, PeerAdj SID, or PeerNode-Adj SID to the BGP peers or peer groups.
·     You can apply a routing policy to assign the same label to multiple BGP peers or peer groups only when you assign a PeerSet SID to the BGP peers or peer groups.
·     You can use if-match interface as a filtering condition only when you assign a PeerAdj SID to a BGP peer or peer group.
·     If you apply a routing policy to a peer group, BGP-EPE assigns a SID to only one of the peers in the peer group.
If you use the label keyword to assign a static SID to a peer group, BGP-EPE assigns a SID to only one of the peers in the peer group.
If the specified peer group contains two or more peers, you cannot assign other types but the set type of SID by using the following methods:
·     Assign a SID by using the label label-value option.
·     Specify a routing policy to assign a SID by using the route-policy route-policy-name option.
# Enable BGP-EPE for peer 1.1.1.1 and assign a PeerNode SID to the peer.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 egress-engineering
display bgp egress-engineering ipv4
peer peer-set
Use peer peer-set to add a peer or peer group to a BGP-EPE peer set.
Use undo peer peer-set to remove a peer or peer group from its BGP-EPE peer set.
peer { group-name | ipv4-address [ mask-length ] } peer-set peer-set-name
undo peer { group-name | ipv4-address [ mask-length ] } peer-set
A peer or peer group does not belong to a BGP-EPE peer set.
BGP instance view
ipv4-address: Specifies an existing peer by its IPv4 address.
mask-length: Specifies a mask length in the range of 0 to 32. The IPv4 address and the mask length together specify a network segment. This command applies to the dynamic peers in the specified network segment.
peer-set-name: Specifies the name of the BGP-EPE peer set to which the specified BGP peers will be added. The peer set name is a case-sensitive string of 1 to 63 characters.
Before you execute this command, make sure BGP-EPE is enabled.
If a peer or peer group is assigned a PeerSet SID (by using the peer egress-engineering set command), the peer or peer group cannot be added to a BGP-EPE peer set, and vice versa.
# Add peer 10.1.1.1 to BGP-EPE peer set abc.
[Sysname] bgp 100
[Sysname-bgp-default] peer 10.1.1.1 peer-set abc
sbfd detect-multiplier
Use sbfd detect-multiplier to set the SBFD detection time multiplier for SRLSPs.
Use undo sbfd detect-multiplier to restore the default.
sbfd detect-multiplier value
The SBFD detection time multiplier is not set for SRLSPs. The BFD detection time multiplier set by the bfd multi-hop detect-multiplier command applies.
value: Specifies a detection time multiplier, which is the maximum number of consecutive SBFD packets that can be discarded. The value range for this argument is 3 to 50.
The device sends SBFD packets to a peer periodically. If the device does not receive SBFD packets from the peer within the actual detection interval, it determines that the session is down. The actual detection interval of the sender is the detection time multiplier of the receiver × the actual sending interval of the receiver.
This command takes effect only on SBFD sessions created by the sbfd enable command.
# Set the SBFD detection time multiplier to 3 for SRLSPs.
[Sysname-segment-routing] sbfd enable
[Sysname-segment-routing] sbfd detect-multiplier 3
bfd multi-hop detect-multiplier (High Availability Command Reference)
sbfd enable
sbfd enable
Use sbfd enable to enable SBFD for SRLSPs.
Use undo sbfd enable to restore the default.
sbfd enable [ prefix-list prefix-list-name ]
undo sbfd enable
SBFD for SRLSPs is not enabled.
prefix-list prefix-list-name: Specifies an IPv4 prefix list by the prefix list name, a case-sensitive string of 1 to 63 characters. The device can create SBFD sessions only for the SRLSPs permitted by the specified IPv4 prefix list. If you do not specify an IPv4 prefix list, the device can create SBFD sessions for all SRLSPs.
This command enables the device to create an SBFD session for each primary SRLSP to verify the connectivity of the primary SRLSP. When a primary SRLSP fails, SBFD can quickly detect the failure and switches traffic to the backup SRLSP to reduce packet loss.
Before you execute this command, enable MPLS BFD by using the mpls bfd enable command.
After you execute this command, the local end uses the destination address of an SRLSP as the remote discriminator to establish an SBFD session for the SRLSP. Make sure you specify the local discriminator of the SBFD session on the remote end as the SRLSP's destination address by using the sbfd local-discriminator command.
If you execute both the sbfd enable command and the mpls sbfd command for SRLSPs, the mpls sbfd command takes effect on the SRLSPs.
In segment routing view, if you execute the bfd enable command and the sbfd enable command multiple times, the most recent configuration takes effect.
# Enable SBFD for SRLSPs.
bfd enable
mpls bfd enable (MPLS Command Reference)
mpls sbfd (for LSP) (MPLS Command Reference)
sbfd local-discriminator (MPLS Command Reference)
sbfd min-receive-interval
Use sbfd min-receive-interval to set the minimum interval for receiving SBFD packets for SRLSP SBFD.
Use undo sbfd min-receive-interval to restore the default.
sbfd min-receive-interval interval
The minimum interval for receiving SBFD packets is not set for SRLSP SBFD. The interval set by the bfd multi-hop min-receive-interval command applies.
interval: Specifies the minimum interval for receiving SBFD packets, in milliseconds. The value range is 3 to 10000.
Use this command to prevent the packet sending rate of the peer end from exceeding the packet receiving rate of the local end. If the receiving rate is exceeded, the peer end dynamically adjusts the BFD packet transmitting interval to the minimum receiving interval of the local end.
# Set the minimum SBFD packet receiving interval for SRLSP SBFD to 450 milliseconds.
[Sysname-segment-routing] sbfd min-receive-interval 450
bfd multi-hop min-receive-interval (High Availability Command Reference)
sbfd enable
sbfd min-transmit-interval
Use sbfd min-transmit-interval to set the minimum interval for transmitting SBFD packets for SRLSP SBFD.
Use undo sbfd min-transmit-interval to restore the default.
sbfd min-transmit-interval interval
The minimum interval for transmitting SBFD packets is not set for SRLSP SBFD. The interval set by the bfd multi-hop min-transmit-interval command applies.
interval: Specifies the minimum interval for transmitting SBFD packets, in milliseconds. The value range is 3 to 10000.
Use this command to prevent the SBFD packet sending rate from exceeding the packet receiving rate of the peer end.
The actual SBFD packet transmitting interval on the local end is the greater value between the following values:
·     Minimum interval for transmitting SBFD packets on the local end.
·     Minimum interval for receiving SBFD packets on the peer end.
# Set the minimum SBFD packet transmitting interval for SRLSP SBFD to 450 milliseconds.
[Sysname-segment-routing] sbfd min-transmit-interval 450
bfd multi-hop min-transmit-interval (High Availability Command Reference)
sbfd enable
segment-routing
Use segment-routing to enable segment routing and enter segment routing view.
Use undo segment-routing to disable segment routing.
segment-routing
Segment routing is disabled.
To configure the Segment Routing Mapping Server (SRMS) features, you must execute this command on the SRMS. The SRMS is an entity that advertises prefix-SID mappings in an IGP. By deploying an SRMS, you can allocate SIDs to devices that do not support SR-MPLS, allowing for SR-MPLS and LDP interworking.
# Enable segment routing and enter segment routing view.
Use segment-routing adjacency enable to enable SR-MPLS adjacency SID allocation.
Use undo segment-routing adjacency enable to disable SR-MPLS adjacency SID allocation.
SR-MPLS adjacency SID allocation is disabled.
OSPF view
For this command to take effect, you must enable SR-MPLS.
# Enable SR-MPLS adjacency SID allocation for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] segment-routing adjacency enable
[Sysname] isis 1
# Enable SR-MPLS adjacency SID allocation for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing adjacency enable
[Sysname] ospf 1
segment-routing adjacency-sid delete-delay
Use segment-routing adjacency-sid delete-delay to enable dynamic adjacency SID deletion delay and set the delay timer.
Use undo segment-routing adjacency-sid delete-delay to restore the default.
segment-routing adjacency-sid delete-delay [ time-value ]
Dynamic adjacency SID deletion delay is enabled. The delay timer is 1800 seconds.
IS-IS IPv4 address family view
OSPF view
time-value: Sets the dynamic adjacency SID deletion delay timer in seconds, in the range of 1 to 2592000. The default value is 1800 value is 1800. A value of 0 disables dynamic adjacency SID deletion.
Packet loss occurs between OSPF or IS-IS neighbors if the neighbors frequently delete and request dynamically allocated adjacency SIDs for the links between them because of neighbor flapping. To resolve this issue, set a delay timer for deleting dynamically allocated adjacency SIDs when the neighbors are disconnected. If the neighbors are still disconnected when the delay timer expires, the device deletes the dynamically allocated adjacency SIDs.
# Enable dynamic adjacency SID deletion delay and set the delay timer to 360 seconds.
[Sysname] isis 1
[Sysname-isis-1-ipv4] segment-routing adjacency-sid delete-delay 360
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing adjacency-sid delete-delay 360
segment-routing global-block
Use segment-routing global-block to configure the MPLS SRGB.
Use undo segment-routing global-block to restore the default.
segment-routing global-block minimum-value maximum-value
The MPLS SRGB is from 16000 to 24000.
IS-IS view
OSPF view
The global MPLS SRGB is used for static prefix segments and BGP prefix SIDs. If no MPLS SRGB is configured for a protocol process, the process uses the global MPLS SRGB.
If you have configured prefix SIDs when you configure the SRGB, the SRGB must contain the configured prefix SIDs.
In the following situations, the configured SRGB takes effect after a device reboot:
·     The SRGB contains a label that is already used by another protocol. For example, the SRGB contains a label that is already used by LDP.
·     The SRGB overlaps with the label range of another protocol. For example, the SRGB for OSPF process 1 overlaps with the SRGB for IS-IS process 1.
# Configure the MPLS SRGB to be from 17000 to 22000 for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] segment-routing global-block 17000 22000
# Configure the MPLS SRGB to be from 17000 to 22000 for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing global-block 17000 22000
global-block
segment-routing label-advertise
Use segment-routing label-advertise to specify the type of label for the device to advertise to the penultimate hop when the device acts as the egress in an SR-MPLS network.
Use undo segment-routing label-advertise to restore the default.
segment-routing label-advertise { explicit-null | non-null }
As egress, the device advertises an implicit null label of 3 to the penultimate hop.
BGP IPv4 unicast address family view
BGP IPv4 labeled unicast address family view
explicit-null: Advertises an explicit null label of 0 to the penultimate hop.
non-null: Advertises a non-null label to the penultimate hop.
As a best practice, configure the egress node to advertise an implicit null label to the penultimate hop if the penultimate hop supports PHP.
If you want to simplify packet forwarding on egress but keep labels to determine QoS policies, configure the egress node to advertise an explicit null label to the penultimate hop.
Use non-null labels only in particular scenarios. For example, when OAM is configured on the egress node, the egress node can get the OAM function entity status only through non-null labels. In this case, the egress node assigns an SID to the penultimate hop based on the prefix SID information in the BGP IPv4 unicast route.
If you change the type of label for the device to advertise to the penultimate hop, the device will close all SRLSPs established based on BGP IPv4 unicast routes. Then, the device will re-establish SRLSPs, using the new label type.
Before executing the command, you must execute the segment-routing mpls command to enable SR-MPLS.
# Configure the device to advertise an explicit null label to the penultimate hop.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4] segment-routing label-advertise explicit-null
segment-routing lsp-trigger
Use segment-routing lsp-trigger to configure the SRLSP establishment triggering policy.
Use undo segment-routing lsp-trigger to restore the default.
segment-routing lsp-trigger { host | none | prefix-list prefix-name }
The device allows all FECs to trigger SRLSP establishment.
OSPF view
host: Allows host FECs to trigger SRLSP establishment.
none: Allows no FECs to trigger SRLSP establishment.
prefix-list prefix-name: Allows FECs permitted by a prefix list to trigger SRLSP establishment. The prefix-name argument is a case-sensitive string of 1 to 63 characters.
To save system resources, you can configure the SRLSP establishment triggering policy to allow only certain FECs to trigger SRLSP establishment.
# Configure the SRLSP establishment triggering policy to allow only host FECs to trigger SRLSP establishment.
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing lsp-trigger host
segment-routing mapping-server advertise-local
Use segment-routing mapping-server advertise-local to enable advertisement of locally configured prefix-SID mappings.
Use undo segment-routing mapping-server advertise-local to disable advertisement of locally configured prefix-SID mappings.
Advertisement is disabled for locally configured prefix-SID mappings.
OSPF view
In an SR to LDP interworking scenario, you must execute this command on the SRMS so the device advertises locally configured prefix-SID mappings to neighbors.
# Enable IS-IS to advertise locally configured prefix-SID mappings for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] segment-routing mapping-server advertise-local
# Enable OSPF to advertise locally configured prefix-SID mappings for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing mapping-server advertise-local
segment-routing mapping-server receive
Use segment-routing mapping-server receive to enable reception of prefix-SID mappings.
Use undo segment-routing mapping-server receive to disable reception of prefix-SID mappings.
Reception of prefix-SID mappings is enabled.
OSPF view
In an SR to LDP interworking scenario, you must execute this command on the SRMCs so they can identify the prefix-SID mappings advertised by the SRMS.
# Disable reception of prefix-SID mappings for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] undo segment-routing mapping-server receive
# Disable reception of prefix-SID mappings for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] undo segment-routing mapping-server receive
mapping-server prefix-sid-map advertise-local
Use segment-routing microloop-avoidance enable to enable SR microloop avoidance.
Use undo segment-routing microloop-avoidance enable to disable SR microloop avoidance.
segment-routing microloop-avoidance enable [ level-1 | level-2 ]
undo segment-routing microloop-avoidance enable [ level-1 | level-2 ]
In OSPF view:
SR microloop avoidance is disabled.
OSPF view
level-1: Specifies SR microloop avoidance for IS-IS Level-1.
level-2: Specifies SR microloop avoidance for IS-IS Level-2.
After a network failure occurs or recovers, route convergence occurs on relevant network devices. Because of non-simultaneous convergence on network devices, microloops might be formed. After you configure SR microloop avoidance, the devices will forward traffic along the specified path before route convergence is finished on all the relevant network devices. Because the forwarding path is independent of route convergence, microloops are avoided.
The specific process is as follows:
·     After a network failure occurs, the device installs the calculated forwarding path to the FIB and switches to the forwarding path after a delay time. During the delay time, the device still uses the TI-LFA FRR backup path.
·     After a network failure recovers, the device calculates an active path and a backup path with a SID. During the delay time, the device still uses the backup path.
If you do not specify the level-1 or level-2 keyword, the segment-routing microloop-avoidance enable command enables or disables SR microloop avoidance on all IS-IS levels.
# Enable SR microloop avoidance for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] segment-routing microloop-avoidance enable
# Enable SR microloop avoidance for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing microloop-avoidance enable
segment-routing microloop-avoidance rib-update-delay
Use segment-routing microloop-avoidance rib-update-delay to set the SR microloop avoidance RIB-update-delay time.
Use undo segment-routing microloop-avoidance rib-update-delay to restore the default.
segment-routing microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
undo segment-routing microloop-avoidance rib-update-delay [ level-1 | level-2 ]
In OSPF view:
The SR microloop avoidance RIB-update-delay time is 5000 ms.
OSPF view
delay-time: Specifies the SR microloop avoidance RIB-update-delay time in milliseconds. The value range is 1 to 60000.
level-1: Specifies the SR microloop avoidance RIB-update-delay time for IS-IS Level-1.
level-2: Specifies the SR microloop avoidance RIB-update-delay time for IS-IS Level-2.
To leave sufficient time for IGP to finish route convergence, specify a proper value for the SR microloop avoidance RIB-update-delay timer. Before the timer expires, failure relevant devices will forward traffic along the specified path. After the timer expires, traffic will traverse the usual path.
If you do not specify the level-1 or level-2 keyword, this command sets the SR microloop avoidance RIB-update-delay time for all IS-IS levels.
# Set the SR microloop avoidance RIB-update-delay time to 6000 ms for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] segment-routing microloop-avoidance rib-update-delay 6000
# Set the SR microloop avoidance RIB-update-delay time to 6000 ms for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing microloop-avoidance rib-update-delay 6000
segment-routing microloop-avoidance strict-sid-only
Use segment-routing microloop-avoidance strict-sid-only to configure SR microloop avoidance to encapsulate only strict SIDs in the SID list.
Use undo segment-routing microloop-avoidance strict-sid-only to restore the default.
The strict-SID-only feature is not configured for SR microloop avoidance.
By default, SR microloop avoidance first calculates the prefix SID to the P node, and then calculates the adjacency SIDs from the P node to the destination node, and then encapsulates the list of prefix and adjacency SIDs into the packet.
If multi-point failure exists and the forwarding path is frequently switched, there might be a microloop on the path to the P node identified by the prefix SID. To avoid the microloop, you can strictly constrain the path to the P node. This command strictly constrains the path to the P node by calculating an adjacency SID to reach the P node. Then, the SID list encapsulated into the packet consists of the adjacency SID to the P node and adjacency SIDs from the P node to the destination node.
# Configure SR microloop avoidance in IS-IS process 1 to encapsulate strict SIDs in the SID list.
[Sysname] isis 1
[Sysname-isis-1-ipv4] segment-routing microloop-avoidance strict-sid-only
Use segment-routing mpls to enable SR-MPLS.
Use undo segment-routing mpls to disable SR-MPLS.
SR-MPLS is disabled.
OSPF view
For SR-MPLS to take effect, perform the following tasks before configuring the IGP to support SR-MPLS:
·     If the IGP is IS-IS, set the cost style to wide, compatible, or wide-compatible. For more information about the cost style, see IS-IS configuration in Layer 3IP Routing Configuration Guide.
·     If the IGP is OSPF, enable opaque LSA reception and advertisement capability. For more information about the capability, see OSPF configuration in Layer 3IP Routing Configuration Guide.
# Enable SR-MPLS in IS-IS IPv4 unicast address family view of IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] cost-style wide
[Sysname-isis-1-ipv4] segment-routing mpls
# Enable SR-MPLS for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing mpls
# Enable SR-MPLS for the BGP IPv4 unicast address family.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] segment-routing mpls
cost-style (Layer 3IP Routing Command Reference)
opaque-capability enable (Layer 3IP Routing Command Reference)
segment-routing prefix-sid-map
Use segment-routing prefix-sid-map to enable prefix-SID mappings.
Use undo segment-routing prefix-sid-map to disable prefix-SID mappings.
Prefix-SID mappings are disabled.
After you execute this command on the SRMCs, the device will assign SIDs to prefixes based on prefix-SID mappings when it receives BGP IPv4 unicast routes or BGP IPv4 labeled unicast routes from neighbors. The prefix-SID mappings  are configured by using the mapping-server prefix-sid-map command.
If a BGP route contains an SID but there is a prefix-SID mapping for the prefix, the device assigns the SID in the mapping to the prefix.
Before executing this command, execute the segment-routing mpls command to enable SR-MPLS.
# Enable prefix-SID mappings in BGP IPv4 unicast address family view.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] segment-routing prefix-sid-map
segment-routing sr-prefer
Use segment-routing sr-prefer to configure the device to prefer SRLSPs in traffic forwarding.
Use undo segment-routing sr-prefer to restore the default.
segment-routing sr-prefer [ prefix-list prefix-list-name ]
The device prefers LDP LSPs in traffic forwarding.
OSPF view
prefix-list prefix-list-name: Specifies an IP address prefix list by its name, a case-sensitive string of 1 to 63 characters. The device preferentially uses SRLSPs to forward traffic destined for addresses on the prefix list, and preferentially uses LDP LSPs to forward traffic destined for other addresses. If you do not specify an IP address prefix list, the device preferentially uses SRLSPs to forward all traffic.
This command determines whether the device prefers SRLSPs or LDP LSPs when both SRLSPs and LDP LSPs are available for traffic forwarding.
This command takes effect only when SR-MPLS is enabled and the SRLSPs use prefix SIDs.
# Configure the device to preferentially use SRLSPs established by OSPF to forward all traffic.
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing sr-prefer
# Configure the device to preferentially use SRLSPs established by OSPF to forward traffic that is identified by prefix list 8.
[Sysname] ip prefix-list 8 permit 4.4.4.4 32
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing sr-prefer prefix-list 8
ip prefix-list (Layer 3IP Routing Command Reference)
static-sr-mpls adjacency
Use static-sr-mpls adjacency to configure an adjacency segment for static SR-MPLS.
Use undo static-sr-mpls adjacency to delete an adjacency segment.
static-sr-mpls adjacency adjacency-path-name in-label label-value { nexthop ip-address | outgoing-interface interface-type interface-number }
undo static-sr-mpls adjacency adjacency-path-name
No adjacency segments exist.
adjacency-path-name: Specifies the adjacency segment name, a case-sensitive string of 1 to 67 characters.
in-label label-value: Specifies the incoming label, in the range of 16 to 1010152.
nexthop ip-address: Specifies the next hop address.
outgoing-interface interface-type interface-number: Specifies an output interface by its type and number. The output interface must be a P2P interface.
Execute this command on all nodes of a static SRLSP.
If you specify the next hop address, make sure the following requirements are met:
·     The device has a route to reach the next hop address.
·     MPLS is enabled on the output interface of the route.
If you specify an output interface, make sure the following requirements are met:
·     The interface is up.
·     The interface can receive direct routes.
·     MPLS is enabled on the interface.
The incoming label specified by this command must be different than existing static LSPs, static PWs, and static CRLSPs. If not, the configured adjacency segment is unavailable. The adjacency segment cannot become available even if you change the incoming label of the static LSP, static PW, or static CRLSP. To resolve this problem, you must delete the existing adjacency segment and configure a new one with a different incoming label.
# Configure an adjacency segment named adj1. Set the incoming label to 100 and the next hop address to 12.2.1.2.
[Sysname] static-sr-mpls adjacency adj1 in-label 100 nexthop 12.2.1.2
display static-sr-mpls
static-sr-mpls lsp
static-sr-mpls lsp
Use static-sr-mpls lsp to configure a static SRLSP.
Use undo static-sr-mpls lsp to delete a static SRLSP.
static-sr-mpls lsp lsp-name out-label out-label-value&<1-14>
undo static-sr-mpls lsp lsp-name
No static SRLSPs exist.
lsp-name: Specifies the static SRLSP name, a case-sensitive string of 1 to 67 characters.
out-label out-label-value&<1-14>: Specifies a space-separated list of up to 14 outgoing labels, corresponding to the labels from top to bottom in the label stack. The value range for the out-label-value argument is 0, 3, and 16 to 1048575.
The outgoing labels represent an ordered list of labels allocated for the adjacencies or nodes that a static SRLSP traverses. The top label is the label that the ingress node allocates for the adjacency or destination prefix.
# Configure a static SRLSP named lsp1. Specify outgoing labels 100 and 200 for the SRLSP.
[Sysname] static-sr-mpls lsp lsp1 out-label 100 200
static-sr-mpls prefix
Use static-sr-mpls prefix to configure a prefix segment for static SR-MPLS.
Use undo static-sr-mpls prefix to delete a prefix segment.
static-sr-mpls prefix prefix-path-name destination ip-address { mask | mask-length } in-label in-label-value [ { nexthop ip-address | outgoing-interface interface-type interface-number } out-label out-label-value ]
undo static-sr-mpls prefix prefix-path-name [ destination ip-address { mask | mask-length } in-label in-label-value [ nexthop ip-address | outgoing-interface interface-type interface-number ] ]
No prefix segments exist.
prefix-path-name: Specifies the prefix segment name, a case-sensitive string of 1 to 67 characters.
destination ip-address: Specifies the destination IP address.
mask: Specifies the mask.
in-label label-value: Specifies the incoming label, in the range of 16000 to 24000.
out-label out-label-value: Specifies the outgoing label, in the range of 0, 3, and 16 to 1048575.
A prefix segment must use the next hop or output interface of the optimal route (non-BGP route) to the destination address of the prefix segment. You can configure multiple prefix segments to the destination address for load sharing if the optimal route has more than one next hops or output interfaces. To avoid configuration failure, make sure all prefix segments use the same prefix segment name, and incoming label.
If you specify only the prefix-path-name argument, the undo static-sr-mpls prefix command deletes all prefix segments with the specified name. If you specify all parameters, only the prefix segment that matches the specified name, destination IP address, and next hop or output interface is deleted.
# Configure a prefix segment named prefix1. Set the destination IP address, incoming label, outgoing label, and next hop to 2.2.2.2, 16000, 16001, and 10.0.0.2, respectively.
[Sysname] static-sr-mpls prefix prefix1 destination 2.2.2.2 32 in-label 16000 nexthop 10.0.0.2 out-label 16001
display mpls static-sr-mpls prefix
tunnel-bfd detect-multiplier
Use tunnel-bfd detect-multiplier to set the tunnel BFD detection time multiplier for SRLSPs.
Use undo tunnel-bfd detect-multiplier to restore the default.
tunnel-bfd detect-multiplier value
The tunnel BFD detection time multiplier is not set for SRLSPs and the setting for the bfd multi-hop detect-multiplier command applies.
value: Specifies a detection time multiplier, which is the maximum number of consecutive BFD packets that can be discarded. The value range for this argument is 3 to 50.
The device sends BFD packets periodically to a peer. If the device does not receive BFD packets from the peer within the detection time, it determines that the BFD session with the peer has gone down.
The actual detection time is the detection time multiplier of the receiver multiplied by the actual BFD packet transmitting interval of the receiver.
This command takes effect only on the BFD sessions created by the tunnel-bfd enable command.
# Set the BFD detection time multiplier to 3.
[Sysname-segment-routing] tunnel-bfd detect-multiplier 3
tunnel-bfd enable
tunnel-bfd enable
Use tunnel-bfd enable to enable tunnel BFD for all SRLSPs.
Use undo tunnel-bfd enable to restore the default.
tunnel-bfd enable [ prefix-list prefix-list-name ] [ echo | nil-fec ]
Tunnel BFD is not enabled to verify the connectivity of SRLSPs.
prefix-list prefix-list-name: Specifies an IPv4 prefix list by the prefix list name, a case-sensitive string of 1 to 63 characters. The device can create tunnel BFD sessions only for the SRLSPs permitted by the specified IPv4 prefix list. If you do not specify an IPv4 prefix list, the device can create tunnel BFD sessions for all SRLSPs.
echo: Specifies the BFD echo packet mode. If you do not specify this keyword, the BFD control packet mode is used to verify SRLSP connectivity.
nil-fec: Encapsulates the Nil FEC in MPLS echo request packets when BFD control packet mode is used to detect SRLSPs. In LDP to SR interworking mode, the ingress node (source node) cannot determine whether the LDP LSP is connected to the SRLSP. When the ingress node uses MPLS BFD to detect LSPs, it encapsulates LDP FEC in MPLS echo request packets, which will fail the FEC type verification on the egress node (end-point node). Then, the BFD session will go down. To resolve this issue, specify the nil-fec keyword to enable the ingress node to encapsulate the Nil FEC in MPLS echo request packets. The egress node will not check the FEC type of packets encapsulated with the Nil FEC.
This command establishes tunnel BFD sessions to verify the connectivity of all SRLSPs.
A tunnel BFD session is a BFD session established for the primary and backup SRLSPs of a specific FEC (destination IP/mask). The BFD session is up as long as an SRLSP is available for the FEC. If both the primary and backup SRLSPs for the FEC are faulty, the BFD session goes down. BFD then quickly triggers a protection measure (such as MPLS L3VPN FRR) to switch traffic to other forwarding paths to reduce traffic loss.
If you configure both the mpls tunnel-bfd command for an SRLSP and the tunnel-bfd enable command for all SRLSPs, the mpls tunnel-bfd command takes effect for that SRLSP.
# Enable tunnel BFD to verify the connectivity of all SRLSPs.
[Sysname-segment-routing] tunnel-bfd enable
mpls tunnel-bfd (for LSP) (MPLS Command Reference)
tunnel-bfd min-echo-receive-interval
Use tunnel-bfd min-echo-receive-interval to set the minimum interval for receiving BFD echo packets for SRLSP tunnel BFD.
Use undo tunnel-bfd min-echo-receive-interval to restore the default.
tunnel-bfd min-echo-receive-interval interval
The minimum interval for receiving BFD echo packets is not set for SRLSP tunnel BFD. The interval set by the bfd multi-hop min-echo-receive-interval command applies.
interval: Specifies the minimum interval for receiving BFD echo packets, in milliseconds. The value range is 3 to 10000.
The interval for receiving BFD echo packets is also the interval for sending BFD echo packets. By executing this command, you can control both the receiving interval and sending interval for BFD echo packets.
This command takes effect only on the echo mode BFD sessions created by the tunnel-bfd enable command.
# Set the minimum BFD echo packet receiving interval for SRLSP tunnel BFD to 450 milliseconds.
[Sysname-segment-routing] tunnel-bfd min-echo-receive-interval 450
bfd multi-hop min-echo-receive-interval (High Availability Command Reference)
tunnel-bfd enable
tunnel-bfd min-receive-interval
Use tunnel-bfd min-receive-interval to set the minimum BFD packet receiving interval for SRLSP tunnel BFD.
Use undo tunnel-bfd min-receive-interval to restore the default.
tunnel-bfd min-receive-interval interval
The minimum interval for receiving BFD packets is not set for SRLSP tunnel BFD. The setting for the bfd multi-hop min-receive-interval command applies.
interval: Specifies the minimum interval for receiving BFD packets, in milliseconds. The value range is 3 to 10000.
The actual BFD packet transmitting interval on the peer end is the greater value between the following values:
·     Minimum interval for transmitting BFD packets on the peer end.
·     Minimum interval for receiving BFD packets on the local end.
# Set the minimum BFD packet receiving interval to 30 milliseconds for SRLSP tunnel BFD.
[Sysname-segment-routing] tunnel-bfd min-receive-interval 30
tunnel-bfd enable
tunnel-bfd min-transmit-interval
Use tunnel-bfd min-transmit-interval to set the minimum BFD packet transmitting interval for SRLSP tunnel BFD.
Use undo tunnel-bfd min-transmit-interval to restore the default.
tunnel-bfd min-transmit-interval interval
The minimum interval for transmitting BFD packets is not set for tunnel BFD. The setting for the bfd multi-hop min-transmit-interval command applies.
interval: Specifies the minimum interval for transmitting BFD packets, in milliseconds. The value range is 3 to 10000.
Use this command to prevent the BFD packet sending rate from exceeding the packet receiving rate of the peer end.
The actual BFD packet transmitting interval on the local end is the greater value between the following values:
·     Minimum interval for transmitting BFD packets on the local end.
·     Minimum interval for receiving BFD packets on the peer end.
# Set the minimum BFD packet transmitting interval to 30 milliseconds for SRLSP tunnel BFD.
[Sysname-segment-routing] tunnel-bfd min-transmit-interval 30
tunnel-bfd enable
