06-Layer 3—IP Services Command Reference
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesCommand ReferencesH3C SR8800-X Routers Command Reference-R8530Pxx-6W10106-Layer 3—IP Services Command Reference
13-GRE commands
13-GRE commands 49.68 KB
GRE commands
gre key
Use gre key to configure a key for a GRE tunnel interface.
Use undo gre key to restore the default.
gre key key
undo gre key
No key is configured for a GRE tunnel interface.
Tunnel interface view
key: Specifies the key for the GRE tunnel interface, in the range of 0 to 4294967295.
You can configure a GRE key to check for the validity of packets received on a GRE tunnel interface.
When a GRE key is configured, the sender puts the GRE key into each sent packet. The receiver compares the GRE key in the received packet with its own GRE key. If the two keys are the same, the receiver accepts the packet. If the two keys are different, the receiver drops the packet.
Both ends of a GRE tunnel must have the same key or no key.
This command is available only for the following cards:
Card category
Cards
CEPC
NP5 cards-CEPC
CSPEX
NP5 cards-CSPEX
SPE
NP5 cards-SPE
# Configure the GRE key as 123 for the GRE tunnel interface Tunnel 2.
[Sysname] interface tunnel 2 mode gre
[Sysname-Tunnel2] gre key 123
keepalive
Use keepalive to enable GRE keepalive, set the keepalive interval and the keepalive number, and configure the keepalive mode.
Use undo keepalive to disable GRE keepalive.
keepalive [ interval [ times ] | reply-check-only ]*
undo keepalive
GRE keepalive is disabled.
interval: Specifies the keepalive interval, in the range of 1 to 32767 seconds. The default value is 10.
times: Specifies the keepalive number, in the range of 1 to 255. The default value is 3.
reply-check-only: Enables the reply-check-only keepalive mode. In this mode, the device places the tunnel interface state to up only when it receives a keepalive acknowledgment packet replied from the peer. The reply-check-only mode is disabled by default. If you do not specify this keyword, the device places the tunnel interface state to up when it receives a keepalive packet initiated or replied from the peer.
Card category
Cards
CEPC
NP5 cards-CEPC, NPS400 cards-CEPC
CSPC
FPGA cards-CSPC
CSPEX
NP5 cards-CSPEX, NPS400 cards-CSPEX, FPGA cards-CSPEX
SPE
NP5 cards-SPE, NPS400 cards-SPE
SPEX
FPGA cards-SPEX
This command enables the tunnel interface to send keepalive packets at the specified interval. If the device receives no response from the peer within the timeout time, it shuts down the local tunnel interface. The device brings the local tunnel interface up if it receives a keepalive acknowledgment packet from the peer. The timeout time is the result of multiplying the keepalive interval by the keepalive number.
Enable the reply-check-only mode in scenarios where the local device can receive keepalive packets from the peer but cannot send keepalive packets, such as remote-to-local one-way communication of a tunnel. In such a scenario, the peer shuts down the tunnel interface because it cannot receive keepalive packets from the local device. The local device, however, brings up the tunnel interface mistakenly when it receives a keepalive probe packet initiatively sent from the peer. After the reply-check-only mode is enabled, the local device brings up the tunnel interface only when it receives a keepalive probe reply from the peer. It keeps the tunnel interface down when it receives keepalive probe packets from the peer, so as to avoid setting wrong tunnel interface state.
The device always acknowledges the keepalive packets it receives whether or not GRE keepalive is enabled.
# Enable GRE keepalive, set the keepalive interval to 20 seconds, and set the keepalive number to 5.
[Sysname-Tunnel2] keepalive 20 5
