05-Layer 2—WAN Access Command Reference
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesCommand ReferencesH3C SR8800-X Routers Command Reference-R8530Pxx-6W10105-Layer 2—WAN Access Command Reference
02-HDLC commands
02-HDLC commands 148.71 KB
HDLC commands
link-protocol hdlc
Use link-protocol hdlc to enable HDLC encapsulation on an interface.
link-protocol hdlc
PPP encapsulation is enabled on an interface.
POS interface view
HDLC can transport the network layer protocols, such as IP and IPv6.
# Enable HDLC encapsulation on Serial 3/1/1:0.
[Sysname] interface serial 3/1/1:0
[Sysname-Serial3/1/1:0] link-protocol hdlc
snmp-agent trap enable hdlc
Use snmp-agent trap enable hdlc to enable SNMP notifications for the HDLC loop detection module.
Use undo snmp-agent trap enable hdlc to disable SNMP notifications for the HDLC loop detection module.
snmp-agent trap enable hdlc [ loopback-detect ]
undo snmp-agent trap enable hdlc [ loopback-detect ]
SNMP notifications are disabled for the HDLC loop detection module.
loopback-detect: Enable SNMP notifications for the HDLC loop detection module.
With SNMP notifications enabled for the HDLC loop detection module, traps will be generated when loops occur or are removed on both ends of an HDLC link. The generated traps are sent to the SNMP module of the device. You can specify how the traps are output through setting the trap output parameters in SNMP. For more information about traps, see SNMP configuration in Network Management and Monitoring Configuration Guide.
Both the snmp-agent trap enable hdlc command and the snmp-agent trap enable hdlc loopback-detect command can enable SNMP notifications for the HDLC loop detection module.
# Enable SNMP notifications for the HDLC loop detection module.
[Sysname] snmp-agent trap enable hdlc loopback-detect
timer-hold
Use timer-hold to set the keepalive interval on an interface.
Use undo timer-hold to restore the default.
timer-hold seconds
undo timer-hold
The keepalive interval is 10 seconds on an interface.
POS interface view
seconds: Specifies the keepalive interval in the range 0 to 32767 seconds.
An HDLC-enabled interface can regularly check link status by sending keepalives to the peer at the keepalive interval at the link layer. A keepalive carries the local sender sequence number and the last received sequence number of the peer.
After sending a keepalive, an interface increments the sender sequence number by 1 in the next keepalive when the following conditions exist:
·     The interface receives a response within the keepalive interval.
·     The response carries the sender sequence number in the sent keepalive.
After sending a keepalive, if the interface does not receive a response within the keepalive interval, it resends the keepalive with an unchanged sequence number. When the keepalive retry limit is reached, the interface considers the link faulty and reports a link layer down event.
Link status check is disabled if you set the keepalive interval to 0.
As a best practice, set the same keepalive interval for the two ends of a link.
If the network has a long delay or is experiencing congestion, you can increase the keepalive interval to prevent the link from being closed.
# Set the keepalive interval to 100 seconds on Serial 3/1/1:0.
[Sysname-Serial3/1/1:0] timer-hold 100
timer-hold retry
timer-hold retry
Use timer-hold retry to set the keepalive retry limit on an interface.
Use undo timer-hold retry to restore the default.
timer-hold retry retries
The keepalive retry limit is 5 on an interface.
POS interface view
Pre-defined user roles
retries: Specifies the keepalive retry limit in the range of 1 to 255.
If the network has a long delay or is experiencing congestion, you can increase the keepalive retry limit to prevent the link from being closed.
# Set the keepalive retry limit to 10 on Serial 3/1/1:0.
[Sysname-Serial3/1/1:0] timer-hold retry 10
timer-hold
HDLC link bundling commands
bandwidth
Use bandwidth to set the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
HDLC link bundle interface view
The expected bandwidth of an interface is available for service modules (for example, affects the link costs in OSPF), and does not affect the actual interface bandwidth. For more information about link costs in OSPF, see Layer 3—IP Routing Configuration Guide.
# Set the expected bandwidth to 1000 kbps for HDLC link bundle interface 1.
[Sysname] interface hdlc-bundle 1
[Sysname-HDLC-bundle1] bandwidth 1000
bundle id
Use bundle id to assign an interface to an HDLC link bundle.
Use undo bundle id to restore the default.
bundle id bundle-id
undo bundle id
An interface is not assigned to any HDLC link bundle.
POS interface view
bundle-id: Specifies an HDLC link bundle by its number. The value range for this argument is 1 to 127.
In the current software version, only POS interfaces can be assigned to an HDLC bundle.
An interface can be the member of only one HDLC link bundle. To move an interface from one HDLC link bundle to another HDLC link bundle, remove the interface from the current HDLC link bundle first.
You must enable HDLC encapsulation on an interface to be assigned to an HDLC link bundle.
You cannot assign interfaces to a nonexistent HDLC link bundle as members.
 On the same interface, you cannot use the bundle id command together with the ip netstream command, the ipv6 netstream command, or both. Once you have executed the ip netstream command, the ipv6 netstream command, or both on an interface, you cannot execute the bundle id command on that interface. To use the bundle id command on the interface, first disable all NetStream features on the interface by using the undo ip netstream and undo ipv6 netstream commands. Then, you can execute the bundle id command on the interface.
# Assign Pos 3/1/1 to HDLC link bundle 1.
[Sysname] interface pos 3/1/1
[Sysname-Pos3/1/1] bundle id 1
bundle max-active links
Use bundle max-active links to set the maximum number of Selected interfaces allowed in an HDLC link bundle.
Use undo bundle max-active links to restore the default.
bundle max-active links number
The maximum number of Selected interfaces allowed in an HDLC link bundle is 8.
number: Specifies the maximum number of Selected interfaces allowed in an HDLC link bundle. The value range for this argument is 1 to 8.
The value specified by using this command cannot be smaller than the value specified by using the bundle min-active links command.
Use the bundle max-active links command together with the bundle member-priority command to make sure both ends of a link always have the same Selected status. The communication fails when one end is Selected but the other end is Unselected.
# Set the maximum number of Selected interfaces allowed in HDLC link bundle 1 to 8.
[Sysname-HDLC-bundle1] bundle max-active links 8
Use bundle member-priority to set the bundling priority value for an HDLC-enabled interface.
Use undo bundle member-priority to restore the default.
bundle member-priority priority
The bundling priority value of an HDLC-enabled interface is 32768.
POS interface view
priority: Specifies the bundling priority value of an HDLC-enabled interface. The value range for this argument is 1 to 65535. A higher priority value means a lower bundling priority.
# Set the bundling priority value to 1 for HDLC-enabled interface Pos 3/1/1.
[Sysname-Pos3/1/1] bundle member-priority 1
bundle min-active bandwidth
Use bundle min-active bandwidth to set the minimum bandwidth required for bringing up an HDLC link bundle interface.
Use undo bundle min-active bandwidth to restore the default.
bundle min-active bandwidth bandwidth
The minimum bandwidth required for bringing up an HDLC link bundle is not set.
bandwidth: Specifies the minimum bandwidth (in kbps) required for bringing up an HDLC link bundle interface. The value range for this argument is 64 to 1342177280.
# Set the minimum bandwidth required for bringing up HDLC link bundle 1 to 1000 kbps.
[Sysname-HDLC-bundle1] bundle min-active bandwidth 1000
Use bundle min-active links to set the minimum number of Selected interfaces required for bringing up an HDLC link bundle interface.
Use undo bundle min-active links to restore the default.
bundle min-active links number
The minimum number of Selected interfaces required for bringing up an HDLC link bundle is not set.
number: Specifies the minimum number of Selected interfaces required for bringing up an HDLC link bundle interface. The value range for this argument is 1 to 8.
The value specified by using this command cannot be greater than the value specified by using the bundle max-active links command.
# Set the minimum number of Selected interfaces required for bringing up HDLC link bundle 1 to 5.
[Sysname-HDLC-bundle1] bundle min-active links 5
default
Use default to restore the default settings for an HDLC link bundle interface.
default
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for HDLC link bundle interface 1.
[Sysname-HDLC-bundle1] default
description
The description of an interface is the interface name followed by the Interface string, for example, Hdlc-bundle1 Interface.
text: Specifies an interface description, a case-sensitive string of 1 to 255 characters.
# Set the description of HDLC link bundle interface 1 to HDLC-bundle interface.
[Sysname-HDLC-bundle1] description HDLC-bundle interface
display bundle hdlc-bundle
Use display bundle hdlc-bundle to display information about an HDLC link bundle.
display bundle hdlc-bundle [ bundle-id ]
bundle-id: Specifies an HDLC link bundle by its number. If this argument is not specified, this command displays information for all HDLC link bundles.
The HDLC link bundle information displayed includes information about all member interfaces.
# Display information about HDLC link bundle 1.
<Sysname> display bundle hdlc-bundle 1
Bundle: HDLC-bundle1
  max-active links: 2, min-active links: 2, min-active bandwidth: 1000000 kbps
  Selected members: 2, Total bandwidth: 1244160 kbps
  Member              State               Bandwidth(kbps)     Priority
  Pos3/1/1            Selected            622080              1
  Pos3/1/2            Selected            622080              2
  Pos3/1/3            Ready               622080              65535
Bundle
Name of the HDLC link bundle.
max-active links
Maximum number of Selected interfaces allowed in the HDLC link bundle interface. This field will not be displayed if you have not set the limit.
min-active links
Minimum number of Selected interfaces required for bringing up the HDLC link bundle interface. This field will not be displayed if you have not set the limit.
Minimum bandwidth required for bringing up the HDLC link bundle interface. This field will not be displayed if you have not set the limit.
Selected members
Current number of Selected interfaces.
Total bandwidth
Total actual bandwidth of all the Selected interfaces in the HDLC link bundle.
Member
Name of a member interface.
State of a member interface:
·     Selected—On an interface card, only information about Selected interfaces is displayed.
·     Ready.
·     Negotiated.
·     Initial.
Bandwidth(kbps)
Actual bandwidth (in kbps) of a member interface.
Priority
Bundling priority of a member interface.
display interface hdlc-bundle
Use display interface hdlc-bundle to display information about an HDLC link bundle interface.
display interface [ hdlc-bundle [ bundle-id ] ] [ brief [ description | down ] ]
hdlc-bundle [ bundle-id ]: Specifies an HDLC link bundle interface by its number. If you do not specify the hdlc-bundle keyword, this command displays information about all interfaces. If you specify the hdlc-bundle keyword without any HDLC link bundle interface number, this command displays information about all HDLC link bundle interfaces.
brief: Displays brief interface information. If you do not specify this keyword, this command displays detailed interface information.
down: Displays information about interfaces in DOWN state and the link down causes. If you do not specify this keyword, the command displays information about interfaces in all states.
# Display detailed information about HDLC link bundle interface 1.
<Sysname> display interface hdlc-bundle 1
HDLC-bundle1
Interface index: 17935
Current state: UP
Line protocol state: UP
Description: HDLC-bundle1 Interface
Bandwidth: 128kbps
Maximum Transmit Unit: 1500
Hold timer: 10 seconds, retry times: 5
Internet address: 1.1.1.2/24 (primary)
Link layer protocol: HDLC
Physical: HDLC-BUNDLE, baudrate: 128000 bps
Input: 32 packets, 1842 bytes, 0 drops
Output: 27 packets, 1512 bytes, 0 drops
# Display brief information about HDLC link bundle interface 1.
<Sysname> display interface hdlc-bundle 1 brief
Protocol: (s) - spoofing
HDLC-B1              UP   UP(s)    1.1.1.2
# Display information about all HDLC link bundle interfaces in down state and the link down reasons.
<Sysname> display interface hdlc-bundle brief down
HDLC-B2              ADM  Administratively
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer.
Description of the interface.
Bandwidth
Expected bandwidth of the interface.
MTU on the interface.
Hold timer
Keepalive transmission interval of the interface.
This field is ineffective for an HDLC link bundle interface because an HDLC link bundle interface does not transmit keepalives.
Retry times
Maximum number of keepalive retransmission attempts. A link is removed after the maximum number of retransmission attempts is reached.
The interface is not assigned an IP address and cannot process IP packets.
Primary IP address of the interface.
Link layer protocol
Link layer protocol encapsulation on the HDLC link bundle interface.
Physical
Physical type of the HDLC link bundle interface.
Baudrate
Baudrate of the HDLC link bundle interface.
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup.
Average rate of input packets in the last 300 seconds, in Bps, bps, and pps.
Average rate of output packets in the last 300 seconds, in Bps, bps, and pps.
Incoming traffic size in packets and bytes and the number of dropped incoming packets on the interface.
Outgoing traffic size in packets and bytes and the number of dropped outgoing packets on the interface.
Brief information about Layer 3 interfaces.
Abbreviated interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Cause
Cause for the physical link state of an interface to be DOWN.
Administratively indicates that the interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
Use interface hdlc-bundle to create an HDLC link bundle interface and enter its view, or enter the view of an existing HDLC link bundle interface.
Use undo interface hdlc-bundle to delete an HDLC link bundle interface.
interface hdlc-bundle bundle-id
undo interface hdlc-bundle bundle-id
No HDLC link bundle interface exists.
bundle-id: Specifies an HDLC link bundle interface by its number. The value range for this argument is 1 to 127.
# Create HDLC link bundle interface 1 and enter its view.
mtu
Use mtu to set the MTU size for an HDLC link bundle interface.
mtu size
undo mtu
The MTU size of an HDLC link bundle interface is 1500 bytes.
size: Specifies the MTU in bytes for an HDLC link bundle interface. The value range for this argument is 46 to 9100 bytes.
The MTU size of an interface affects IP packet fragmentation and reassembly on the interface.
To make the MTU configuration take effect on an interface, you must re-enable the interface by using the shutdown command and the undo shutdown command.
The MTU size of an HDLC link bundle interface cannot exceed the MTU size of any its member interface. For example, if the member interfaces are on MIC subcards (the effective MTU range is 46 to 4980) and PIC-PS2G4L subcards (the effective MTU range is 46 to 2000) in the cards in Table 3, the MTU size of the HDLC link bundle interface cannot exceed 2000. For the effective MTU ranges on different cards, see POS interface commands in Interface Command Reference.
The device uses 1280 bytes as the MTU when an interface on the cards in Table 3 acts as the incoming interface for the traffic and the MTU of the outgoing interface for the traffic is less than 1280 bytes. As a best practice, set the MTU of the outgoing interface to larger than 1280 bytes when the device has the cards in Table 3.
Table 3 Card information
Card category
Cards
CSPC
CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E
CSPEX
CSPEX-1104-E
SPEX
SPEX-1204
# Set the MTU size of HDLC link bundle interface 1 to 1430 bytes.
[Sysname-HDLC-bundle1] mtu 1430
reset counters interface hdlc-bundle
Use reset counters interface hdlc-bundle to clear the statistics of an HDLC link bundle interface.
reset counters interface [ hdlc-bundle [ bundle-id ] ]
hdlc-bundle [ bundle-id ]: Specifies an HDLC link bundle interface by its number. The value range for this argument is 1 to 127.If you do not specify hdlc-bundle, this command clears the statistics of all interfaces. If you specify hdlc-bundle but not bundle-id, this command clears the statistics of all HDLC link bundle interfaces. If you specify both hdlc-bundle and bundle-id, this command clears the statistics of the specified HDLC link bundle interface.
Before collecting traffic statistics within a period of time on an interface, you must clear the existing statistics.
# Clear the statistics of HDLC link bundle interface 1.
<Sysname> reset counters interface hdlc-bundle 1
shutdown
Use shutdown to shut down an HDLC link bundle interface.
Use undo shutdown to bring up an HDLC link bundle interface.
shutdown
An HDLC link bundle interface is up.
Using this command to shut down an HDLC link bundle interface will invalidate the HDLC functions based on the current HDLC link bundle interface. As a best practice, make sure you know the impact on the network before using this command.
# Shut down HDLC link bundle interface 1.
[Sysname-HDLC-bundle1] shutdown
system-hash-mode
Use system-hash-mode to configure the hash calculation mode for cards.
Use undo system-hash-mode to restore the default.
system-hash-mode { lbid | mac }
This command is available only for the SR8804-X routers, SR8808-X routers (one fan tray), SR8808-X routers (two fan trays), and SR8812-X routers.
On the SR8804-X routers, SR8808-X routers (one fan tray), SR8808-X routers (two fan trays), and SR8812-X routers, the hashes of cards are calculated based on MAC addresses in sent packets on SPEX-1204 and the hashes are the LBIDs on the other cards.
lbid: Uses the LBIDs as the hashes of cards. The LBIDs have been calculated by the uplink devices through hashing.
mac: Calculates the hashes for cards based on the MAC addresses in sent packets.
CAUTION
CAUTION:
To change the hash calculation mode, make sure no service traffic exists on cards. If service traffic exists on cards, service traffic will be interrupted when you change the hash calculation mode.
To assign interfaces on different cards to the same HDLC link bundle, first make sure the hash calculation mode is the same on these cards.
After this command is executed, the configured hash calculation mode takes effect on the following cards, and the default hash calculation mode is used on the other cards.
Card category
Cards
CSPC
CEPC
CEPC-XP4LX, CEPC-XP24LX, CEPC-XP48RX, CEPC-CP4RX, CEPC-CP4RX-L
CSPEX
CSPEX-1104-E, CSPEX-1304X, CSPEX-1404X, CSPEX-1502X, CSPEX-1504X, CSPEX-1602X
Among these cards, follow these restrictions and guidelines for CSPEX-1104-E, CSPEX-1304X, CSPEX-1404X, and CSPEX-1504X cards:
·     When the load balance IDs (LBIDs) are used as the hashes, interfaces on the preceding cards can be assigned to the same HDLC link bundle as interfaces on a CSPEX-2304X-G or CSPEX-2304X-LG card.
·     When the hashes of cards are calculated based on MAC addresses in sent packets, interfaces on the preceding cards card can be assigned to the same HDLC link bundle as interfaces on an SPEX-1204.
# Calculate the hashes for cards based on the MAC addresses in sent packets.
[Sysname] system-hash-mode mac
Changing the hash calculation mode might cause service anomaly in the HDLC link bundle or aggregation group.
Are you sure you want to continue? [Y/N]:y
The preceding information shows that the configuration might cause service anomaly for the HDLC link bundling or aggregation group module.
