08-Connection limit commands | 176.04 KB |
connection-limit log-suppress interval
display connection-limit ipv6-stat-nodes
display connection-limit statistics
display connection-limit stat-nodes
reset connection-limit statistics
connection-limit
Use connection-limit to create a connection limit policy and enter its view, or enter the view of an existing connection limit policy.
Use undo connection-limit to delete a connection limit policy.
connection-limit { ipv6-policy | policy } policy-id
undo connection-limit { ipv6-policy | policy } policy-id
No connection limit policies exist.
ipv6-policy: Specifies an IPv6 connection limit policy.
policy: Specifies an IPv4 connection limit policy.
policy-id: Specifies the ID of a connection limit policy. IPv4 and IPv6 connection limit policies have independent numbering systems. The value range for this argument is 1 to 32.
# Create IPv4 connection limit policy 1 and enter its view.
[Sysname] connection-limit policy 1
[Sysname-connlmt-policy-1]
# Create IPv6 connection limit policy 12 and enter its view.
[Sysname] connection-limit ipv6-policy 12
[Sysname-connlmt-ipv6-policy-12]
connection-limit apply
connection-limit apply global
limit
connection-limit amount
Use connection-limit amount to configure the maximum number of user connections.
Use undo connection-limit amount to restore the default.
connection-limit amount amount
The number of user connections is not limited.
User profile view
amount: Specifies the maximum number of user connections, in the range of 1 to 10000. New connections are not allowed when the maximum number is reached.
If you execute this command multiple times, the most recent configuration takes effect. If the configured maximum number is smaller than the current number of connections, the configuration takes effect after the number of non-aged TCP connections is smaller than the configured maximum number.
When a user profile on the device is deleted, the associated users will be no longer restricted by the settings in the user profile.
# Create a user profile named abc and enter its view.
[Sysname] user-profile abc
# Set the maximum number of user connections to 5.
[Sysname-user-profile-abc] connection-limit amount 5
display user-profile
Use connection-limit apply to apply a connection limit policy to an interface.
Use undo connection-limit apply to remove a connection limit policy from an interface.
connection-limit apply { ipv6-policy | policy } policy-id
undo connection-limit apply { ipv6-policy | policy }
No connection limit policy is applied to an interface.
Interface view
policy-id: Specifies the ID of a connection limit policy. The value range for this argument is 1 to 32.
Only one IPv4 connection limit policy and one IPv6 connection limit policy can be applied to an interface. A new IPv4 or IPv6 connection limit policy overwrites the old one.
# Apply IPv4 connection limit policy 1 to Ten-GigabitEthernet 3/0/1.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] connection-limit apply policy 1
# Apply IPv6 connection limit policy 12 to Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] connection-limit apply ipv6-policy 12
connection-limit
limit
Use connection-limit apply global to apply a connection limit policy globally.
Use undo connection-limit apply global to remove the application.
connection-limit apply global { ipv6-policy | policy } policy-id
undo connection-limit apply global { ipv6-policy | policy }
No connection limit policy is applied globally.
Only one IPv4 connection limit policy and one IPv6 connection limit policy can be applied globally. A new IPv4 or IPv6 connection limit policy overwrites the old one.
# Apply IPv4 connection limit policy 1 globally.
[Sysname] connection-limit apply global policy 1
# Apply IPv6 connection limit policy 12 globally.
[Sysname] connection-limit apply global ipv6-policy 12
connection-limit
limit
Use connection-limit log-suppress interval to set the logging suppression interval.
Use undo connection-limit log-suppress interval to restore the default.
connection-limit log-suppress interval time-value
Connection limit log messages are not suppressed.
time-value: Specifies the logging suppression interval in the range of 1 to 60 seconds.
If a connection limit rule is matched frequently in a short period after the upper limit is reached, the device records a large number of repeated log messages for the rule. This command suppresses the generation of repeated log messages for the same rule in the specified period.
The suppression start time of a log message is the time when it is generated.
If you want to know whether the upper limit is reached during a short interval, set a short interval value to avoid generating a very small number of log messages.
# Set the logging suppression interval to 30 seconds.
[Sysname] connection-limit log-suppress interval 30
connection-limit rate
Use connection-limit rate to configure the maximum connection establishment rate.
Use undo connection-limit rate to restore the default.
connection-limit rate rate
The connection establishment rate is not limited.
User profile view
rate: Specifies the maximum connection establishment rate per second, in the range of 5 to 1000. New connections are not allowed when the maximum rate is reached.
If you execute this command multiple times, the most recent configuration takes effect. After you execute this command, the configuration takes effect immediately.
# Set the maximum connection establishment rate to 100 per second.
[Sysname-user-profile-abc] connection-limit rate 100
description
Use description to configure a description for a connection limit policy.
A connection limit policy does not have a description.
IPv4 connection limit policy view
IPv6 connection limit policy view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as CenterToA for IPv4 connection limit policy 1.
[Sysname-connlmt-policy-1] description CenterToA
Use display connection-limit to display information about connection limit policies.
display connection-limit { ipv6-policy | policy } { policy-id | all }
policy-id: Specifies a connection limit policy by its ID. The value range for this argument is 1 to 32.
all: Specifies all connection limit policies.
# Display information about all IPv4 connection limit policies.
<Sysname> display connection-limit policy all
3 policies in total:
Policy Rule Stat Type HiThres LoThres ACL
1 2 Dst-Port 800 70 3010
3 Src-Dst 100 90 3000
10 Src-Dst-Port 50 45 3003
11 Src 200 200 3004
200 -- 500000 498000 2002
28 4 Port 1500 1400 3100
5 Dst 3000 280 3101
21 Src-Dst 200 180 3102
25 Src-Port 50 35 3200
Description list:
Policy Description
1 IPv4Description1
28 Description for IPv4 28
# Display information about IPv4 connection limit policy 1.
<Sysname> display connection-limit policy 1
IPv4 connection limit policy 1 has been applied 5 times, and has 5 limit rules.
Description: IPv4Description1
Limit rule list:
1 2 Dst-Port 800 700 3010
11 Src 200 200 3004
Application list:
Ten-GigabitEthernet3/0/2
Vlan-interface1
Tunnel0
Global
# Display information about all IPv6 connection limit policies.
<Sysname> display connection-limit ipv6-policy all
2 policies in total:
3 1 Src-Dst 1000 800 3010
2 Dst 500 450 3001
4 2 Src-Dst-Port 800 700 3010
3 Src 100 90 3020
200 -- 100000 89000 2005
Description list:
Policy Description
3 IPv6Description3
4 Description for IPv6 4
# Display information about IPv6 connection limit policy 3.
<Sysname> display connection-limit ipv6-policy 3
IPv6 connection limit policy 3 has been applied 3 times, and has 2 limit rules.
Description: IPv6Description3
Limit rule list:
2 Dst 500 450 3001
Application list:
Vlan-interface1
Tunnel0
Limit rule list |
Connection limit policy information. |
Policy |
Number of the connection limit policy. |
Rule |
Number of the connection limit rule. |
Stat Type |
Statistics types: · Src-Dst-Port—Limits connections by source IP, destination IP, and service combination. · Src-Dst—Limits connections by source IP address and destination IP address combination. · Src-Port—Limits connections by source IP and service combination. · Dst-Port—Limits connections by destination IP and service combination. · Src—Limits connections by source IP address. · Dst—Limits connections by destination IP address. · Port—Limits connections by service. · Dslite—Limits connections by B4 device of a DS-Lite tunnel. This value is not supported in the current software version. · --—Limits connections not by a specific IP address or service. All connections that match the ACL used by the rule are limited. |
HiThres |
Upper limit of the connections. |
LoThres |
Lower limit of the connections. |
ACL |
Number or name of the ACL used by the rule. |
Application list |
Application list of the connection limit policy, including interface name and Global. Global indicates that the connection limit policy is applied globally. |
Connection limit policy description. |
Description list |
List of connection limit policy descriptions. |
connection-limit
limit
Use display connection-limit ipv6-stat-nodes to display statistics about IPv6 connections that match connection limit rules globally or on an interface.
display connection-limit ipv6-stat-nodes { global | interface interface-type interface-number } [ slot slot-number ] [ destination destination-ip | service-port port-number | source source-ip ] * [ count ]
global: Displays statistics about IPv6 connections that match connection limit rules globally.
slot slot-number: Specifies a card by its slot number. This option is available only when you specify the global keyword or specify a virtual interface, such as a VLAN interface or tunnel interface.
destination destination-ip: Specifies a destination by its IP address.
service-port port-number: Specifies a service port by its port number.
source source-ip: Specifies a source by its IP address.
count: Displays only the number of limit rule-based statistics sets. Detailed information about the specified IPv6 connections is not displayed. If you do not specify this keyword, the command displays detailed information about the specified IPv6 connections that match connection limit rules.
The statistics for this command include the following information:
· Connection information, including the source/destination IP address, service port, and transport layer protocol of connections.
· Matching connection limit rules.
· Number of current connections.
· Whether or not new connections can be created.
To further filter the output statistics, specify the following options in the command:
· source source-ip.
· destination destination-ip.
· service-port port-number.
For example, if you specify the source source-ip and destination destination-ip combination, this command displays statistics about IPv6 connections that match connection limit rules by source IP address and destination IP address.
If you specify none of the source source-ip, destination destination-ip, and service-port port-number options, this command displays statistics about all IPv6 connections that match connection limit rules.
Deleting or modifying an IPv6 connection limit policy will not delete the effective IPv6 connection limit rule-based statistics sets. An IPv6 connection limit rule-based statistics set will be automatically deleted after all the IPv6 connections for the set are disconnected.
# Display the number of global limit rule-based statistics sets that match the source IP address 2::1.
<Sysname> display connection-limit ipv6-stat-nodes global source 2::1 count
Current limit statistic nodes count is 16.
# Display statistics about IPv6 connections that match the global connection limit rule on the specified slot.
<Sysname> display connection-limit ipv6-stat-nodes global slot 1
Slot 1:
Src IP address : Any
VPN instance : --
Dst IP address : Any
VPN instance : --
DS-Lite tunnel peer : --
Service : icmp/0
Limit rule ID : 22(ACL: 3666)
Sessions threshold Hi/Lo: 3500/3000
Sessions count : 3100
New session flag : Permit
# Display the number of global limit rule-based statistics sets on the specified slot.
<Sysname> display connection-limit ipv6-stat-nodes global slot 1 count
Slot 1:
Current limit statistic nodes count is 0.
Src IP address |
Source IP address. |
Dst IP address |
Destination IP address. |
VPN instance |
MPLS L3VPN instance to which the IP address belongs. Two hyphens (--) indicates that the IP address is on the public network. |
DS-Lite tunnel peer |
This field is not supported in the current software version. ID of the DS-Lite tunnel. Two hyphens (--) indicates that the connection does not belong to a DS-Lite tunnel. |
Service |
Protocol name and service port number. For an unwell-known protocol, this field displays unknown(xx).The cross signs (xx) indicates the protocol number. For the ICMP protocol, the protocol number is the decimal digits that are converted from the hexadecimal contents of the type and code fields. |
Limit rule ID |
ID of the matched rule. The ACL number of the rule is enclosed in parentheses. |
Sessions threshold Hi/Lo |
Upper and lower connection limits. |
Sessions count |
Number of current connections. |
New session flag |
Whether or not new connections can be created: · Permit—New connections can be created. · Deny—New connections cannot be created. NOTE: When the number of connections reaches the upper limit, this field displays Permit although new connections are not allowed. This field displays Deny only when the number of connections exceeds the upper limit. |
limit
Use display connection-limit statistics to display the global, interface-based, or user-based connection limit statistics.
display connection-limit statistics { global | interface interface-type interface-number | user-id user-id } [ slot slot-number ]
global: Displays the global connection limit statistics.
user-id user-id: Specifies an online user by its hexadecimal ID in the range of 1 to 7fffff. For more information about user IDs, see UCM in BRAS Services Command Reference.
# Display the global connection limit statistics on the specified slot.
<Sysname> display connection-limit statistics global slot 1
Connection limit statistics (Global, slot 1):
Dropped IPv4 packets: 74213
Dropped IPv6 packets: 58174
# Display the connection limit statistics for user ID 1 on the specified slot.
<Sysname> display connection-limit statistics user-id 1 slot 1
Connection limit statistics (User ID: 1, slot 1):
Total uplink connections: 100
Total downlink connections: 200
Dropped IPv4 packet |
Number of IPv4 packets that are dropped because the upper connection limit is exceeded for the IPv4 connection limit policy that is configured globally or on an interface. |
Dropped IPv6 packet |
Number of IPv6 packets that are dropped because the upper connection limit is exceeded for the IPv6 connection limit policy that is configured globally or on an interface. |
Total uplink connections |
Total number of uplink connections established. |
Total downlink connections |
Total number of downlink connections established. |
connection-limit
limit
Use display connection-limit stat-nodes to display statistics about IPv4 connections that match connection limit rules globally or on an interface.
display connection-limit stat-nodes { global | interface interface-type interface-number } [ slot slot-number ] [ destination destination-ip | service-port port-number | source source-ip ] * [ count ]
global: Displays statistics about IPv4 connections that match connection limit rules globally.
count: Displays only the number of limit rule-based statistics sets. Detailed information about the specified IPv4 connections is not displayed. If you do not specify this keyword, the command displays detailed information about the specified IPv4 connections that match connection limit rules.
· source source-ip.
For example, if you specify the source source-ip and destination destination-ip combination, this command displays statistics about IPv4 connections that match connection limit rules by source IP address and destination IP address.
If you do not specify any of the source source-ip, destination destination-ip, and service-port port-number options, this command displays statistics about all IPv4 connections that match connection limit rules.
Deleting or modifying an IPv4 connection limit policy will not delete the effective IPv6 connection limit rule-based statistics sets. An IPv4 connection limit rule-based statistics set will be automatically deleted after all the IPv6 connections for the set are disconnected.
# Display the number of global limit rule-based statistics sets.
<Sysname> display connection-limit stat-nodes global count
Current limit statistic nodes count is 5.
# Display statistics about IPv4 connections that match the global connection limit rule on the specified slot.
<Sysname> display connection-limit stat-nodes global slot 1
Slot 1:
VPN instance : Vpn1
Dst IP address : 202.113.16.117
VPN instance : Vpn2
Service : icmp/0
Limit rule ID : 7(ACL: 3102)
Sessions threshold Hi/Lo: 4000/3800
Sessions count : 1001
# Display the number of global limit rule-based statistics sets that match the source IP address 1.1.1.1 for the specified slot.
<Sysname> display connection-limit stat-nodes global slot 1 source 1.1.1.1 count
Slot 1:
Src IP address |
Dst IP address |
VPN instance |
Service |
Protocol name and service port number. For an unwell-known protocol, this field displays unknown(xx). The cross signs (xx) represents the protocol number. For the ICMP protocol, the protocol number is the decimal digits that are converted from the hexadecimal contents of the type and code fields. |
Sessions count |
New session flag |
limit
limit
Use limit to configure a connection limit rule.
Use undo limit to delete a connection limit rule.
In IPv4 connection limit policy view:
limit limit-id acl { acl-number | name acl-name } [ per-destination | per-service | per-source ] * amount max-amount min-amount
undo limit limit-id
In IPv6 connection limit policy view:
limit limit-id acl ipv6 { acl-number | name acl-name } [ per-destination | per-service | per-source ] * amount max-amount min-amount
undo limit limit-id
No connection limit rules exist.
limit-id: Specifies a connection limit rule by its ID. The value range for this argument is 1 to 256..
acl: Specifies the ACL that matches the user range. Only the user connections that match the ACL are limited.
ipv6: Specifies an IPv6 ACL. If you do not specify this keyword, an IPv4 ACL is used.
acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
name acl-name: Specifies an ACL by its name. The acl-name argument is a case-insensitive string of 1 to 63 characters. It must start with an English letter. To avoid confusion, it cannot be all.
per-destination: Limits connections by destination IP address.
per-service: Limits connections by service depending on transport layer protocol and service port.
per-source: Limits connections by source IP address.
amount: Specifies the upper and lower connection limits.
max-amount: Specifies the upper connection limit in the range of 1 to 4294967295. When user connections in a range or of a type exceed the upper connection limit, new connections cannot be created.
min-amount: Specifies the lower connection limit in the range of 1 to 4294967295. The lower connection limit cannot be greater than the upper connection limit. New connections cannot be created until the connection number goes below the lower connection limit.
Each connection limit policy can define multiple rules, and each rule must specify the used ACL, rule type, and upper/lower connection limit. In one rule, you can specify one or multiple of the keywords per-destination, per-source, and per-service. For example, if the per-destination and per-source combination is specified, connections are limited by the source IP address and destination IP address. Connections with the same source IP address and destination IP address are the same type.
When you configure a connection limit rule, follow these guidelines:
· Different rules in the same connection limit policy must use different ACLs.
· If you specify none of the per-destination, per-source, and per-service keywords, all connections that match the specified ACL are limited by the specified value.
· When the connections established on a device are matched against a connection limit policy, the limit rules in the policy are matched in ascending order of rule ID.
· When the specified ACL changes, the connections that have been established are limited by the new connection limit policy.
# Configure connection limit rule 1 for IPv4 connection limit policy 1:
1. Configure ACL 3000.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule permit ip source 192.168.0.0 0.0.0.255
2. Limit connections that match ACL 3000 by the source and destination IP addresses, with the upper limit 2000 and lower limit 1800.
[Sysname-connlmt-policy-1] limit 1 acl 3000 per-destination per-source amount 2000 1800
3. Verify that when the connection number exceeds 2000, new connections cannot be established until the connection number goes below 1800. (Details not shown.)
# Configure connection limit rule 2 for IPv6 connection limit policy 12:
1. Configure ACL 2001.
[Sysname] acl ipv6 basic 2001
[Sysname-acl-ipv6-basic-2001] rule permit source 2:1::/96
2. Limit connections that match ACL 2001 by the source and destination IP addresses, with the upper limit 200 and lower limit 100.
[Sysname-connlmt-ipv6-policy-12] limit 2 acl ipv6 2001 per-destination amount 200 100
3. Verify that when the connection number exceeds 200, new connections cannot be established until the connection number goes below 100. (Details not shown.)
connection-limit
Use reset connection-limit statistics to clear the connection limit statistics globally or on an interface.
reset connection-limit statistics { global | interface interface-type interface-number } [ slot slot-number ]
global: Clears the global connection limit statistics.
# Clear the global connection limit statistics on the specified slot.
<Sysname> reset connection-limit statistics global slot 1
