12-Security Command Reference
HomeSupportRoutersCR16000-M SeriesReference GuidesCommand ReferencesH3C CR16000-M Routers Command Reference-R8530Pxx-6W10112-Security Command Reference
16-uRPF commands
16-uRPF commands 96.06 KB
IPv4 uRPF commands
display ip urpf
Use display ip urpf to display uRPF configuration.
display ip urpf interface interface-type interface-number [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays uRPF configuration for all cards.
# Display uRPF configuration on the specified interface.
<Sysname> display ip urpf interface ten-gigabitethernet 3/0/1
uRPF configuration information of interface Ten-GigabitEthernet3/0/1(failed):
   Check type: loose
   Allow default route
   Suppress drop ACL: 2000
Information about interface-specific uRPF configuration.
(failed)
The system failed to deliver the uRPF configuration to the forwarding chip because of insufficient chip resources.
This field is not displayed if the delivery is successful.
Check type
uRPF check mode: loose or strict.
Allow default route
Using the default route is allowed.
Suppress drop ACL
ACL used for drop suppression.
display ip urpf discard statistics
Use display ip urpf discard statistics to display uRPF packet drop statistics.
display ip urpf discard statistics [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays uRPF packet drop statistics for all cards.
# Display uRPF packet drop statistics for the card on slot 10.
<Sysname> display ip urpf discard statistics slot 10
Slot No.  Discard-packets
3         1177917154
Slot No.
Slot number of the card.
Discard-packets
Number of dropped uRPF packets.
This field displays Not support if the card does not support uRPF packet drop statistics.
ip urpf
Use ip urpf to enable uRPF.
Use undo ip urpf to disable uRPF.
ip urpf { loose [ allow-default-route ] [ acl acl-number ] | strict [ allow-default-route ] [ acl acl-number ] }
undo ip urpf
uRPF is disabled.
Interface view
loose: Enables loose uRPF check. To pass loose uRPF check, the source address of a packet must match the destination address of a FIB entry.
strict: Enables strict uRPF check. To pass strict uRPF check, the source address and receiving interface of a packet must match the destination address and output interface of a FIB entry.
allow-default-route: Allows using the default route for uRPF check.
acl acl-number: Specifies an ACL by its number.
·     For a basic ACL, the value range is 2000 to 2999.
·     For an advanced ACL, the value range is 3000 to 3999.
uRPF can be deployed on a PE connected to a CE or an ISP, or on a CE.
Configure strict uRPF check for traffic that uses symmetric path and configure loose uRPF check for traffic that uses asymmetric path. A symmetric path exists for a session if the PE uses the same interface to receive upstream traffic and send downstream traffic. The path is asymmetric if the PE uses different interfaces to receive upstream traffic and send downstream traffic.
·     Typically, symmetric path applies to traffic that goes through an ISP's PE interface connected to the CE. You can configure strict uRPF check on the PE interface.
·     Asymmetric path might exist for traffic that goes through a PE interface connected to another ISP. In this case, configure loose uRPF check on the PE interface.
Typically, you do not need to configure the allow-default-route keyword on a PE device, because it has no default route pointing to a CE. If you enable uRPF on a CE interface and the CE interface has a default route pointing to the PE, specify the allow-default-route keyword.
You can use an ACL to match specific packets, so they are forwarded even if they fail to pass uRPF check.
If the specified ACL does not exist or does not contain rules, the ACL cannot match any packets.
If the vpn-instance keyword is specified in an ACL rule, the rule applies only to VPN packets. If the vpn-instance keyword is not specified in an ACL rule, the rule applies to both public and private network packets.
# Configure loose uRPF check on interface Ten-GigabitEthernet 3/0/1.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] ip urpf loose
display ip urpf
ip urpf strict
Use ip urpf strict to enable strict uRPF check for PPPoE users on a VT interface.
Use undo ip urpf strict to disable strict uRPF check for PPPoE users on a VT interface.
ip urpf strict [ subnet-check ]
undo ip urpf strict [ subnet-check ]
Strict uRPF check is enabled for all PPPoE users except leased users.
VT interface view
subnet-check: Enables strict uRPF check for all PPPoE users including leased users on the VT interface. If you do not specify this keyword, this command does not apply to PPPoE leased users on the VT interface.
If you do not specify the subnet-check keyword, strict uRPF checks traffic of all PPPoE users except leased users for packet validity based on source IP address.
If you specify the subnet-check keyword, strict uRPF checks traffic of allPPPoE users including leased users for packet validity. The packet validity check is based on the Framed-Route or Framed-IP-Netmask RADIUS attribute.
# Enable strict uRPF check for all PPPoE users except leased users on Virtual-Template 100.
[Sysname] interface virtual-template 100
[Sysname-Virtual-Template100] ip urpf strict
reset ip urpf discard statistics
Use reset ip urpf discard statistics to clear uRPF packet drop statistics.
reset ip urpf discard statistics [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears uRPF packet drop statistics for all cards.
# Clear uRPF packet drop statistics for the card on slot 10.
IPv6 uRPF commands
display ipv6 urpf
Use display ipv6 urpf to display IPv6 uRPF configuration.
display ipv6 urpf interface interface-type interface-number [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 uRPF configuration for all cards.
# Display IPv6 uRPF configuration on the specified interface.
<Sysname> display ipv6 urpf interface ten-gigabitethernet 3/0/1
IPv6 uRPF configuration information of interface Ten-GigabitEthernet3/0/1(failed):
   Check type: loose
   Allow default route
Information about interface-specific IPv6 uRPF configuration.
(failed)
The system failed to deliver the IPv6 uRPF configuration to the forwarding chip because of insufficient chip resources. This field is not displayed if the delivery is successful.
Check type
IPv6 uRPF check mode: loose or strict.
Allow default route
Suppress drop ACL
IPv6 ACL used for drop suppression.
display ipv6 urpf discard statistics
Use display ipv6 urpf discard statistics to display IPv6 uRPF packet drop statistics.
display ipv6 urpf discard statistics [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 uRPF packet drop statistics for all cards.
# Display IPv6 uRPF packet drop statistics for the card on slot 10.
<Sysname> display ipv6 urpf discard statistics slot 10
3         1177917154
Slot No.
Discard-packets
Number of dropped IPv6 uRPF packets.
This field displays Not support if the card does not support IPv6 uRPF packet drop statistics.
ipv6 urpf
Use ipv6 urpf to enable IPv6 uRPF.
Use undo ipv6 urpf to disable IPv6 uRPF.
ipv6 urpf { loose | strict } [ allow-default-route ] [ acl acl-number ]
undo ipv6 urpf
IPv6 uRPF is disabled.
Interface view
loose: Enables loose IPv6 uRPF check. To pass loose IPv6 uRPF check, the source address of a packet must match the destination address of an IPv6 FIB entry.
strict: Enables strict IPv6 uRPF check. To pass strict IPv6 uRPF check, the source address and receiving interface of a packet must match the destination address and output interface of an IPv6 FIB entry.
allow-default-route: Allows using the default route for IPv6 uRPF check.
acl acl-number: Specifies an IPv6 ACL by its number.
·     For a basic IPv6 ACL, the value range is 2000 to 2999.
·     For an advanced IPv6 ACL, the value range is 3000 to 3999.
IPv6 uRPF can be deployed on a CE or on a PE connected to either a CE or an ISP.
Configure strict IPv6 uRPF check for traffic that uses symmetric path and configure loose IPv6 uRPF check for traffic that uses asymmetric path. A symmetric path exists for a session if the PE uses the same interface to receive upstream traffic and send downstream traffic. The path is asymmetric if the PE uses different interfaces to receive upstream traffic and send downstream traffic.
·     Typically, symmetric path applies to traffic that goes through an ISP's PE interface connected to the CE. You can configure strict IPv6 uRPF check on the PE interface.
·     Asymmetric path might exist for traffic that goes through a PE interface connected to another ISP. In this case, configure loose IPv6 uRPF check on the PE interface.
You can use an ACL to match specific packets, so they are forwarded even if they fail to pass IPv6 uRPF check.
# Configure loose IPv6 uRPF check on interface Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] ipv6 urpf loose
display ipv6 urpf
ipv6 urpf strict
Use ipv6 urpf strict to enable strict IPv6 uRPF check for PPPoE users on a VT interface.
Use undo ipv6 urpf strict to disable strict IPv6 uRPF check for PPPoE users on a VT interface.
ipv6 urpf strict [ subnet-check ]
undo ipv6 urpf strict [ subnet-check ]
Strict IPv6 uRPF check is disabled for all PPPoE users.
VT interface view
subnet-check: Enables strict IPv6 uRPF check for all PPPoE users including leased users on a VT interface. If you do not specify this keyword, this command does not apply to PPPoE leased users on the VT interface.
If you do not specify the subnet-check keyword, strict IPv6 uRPF checks traffic of all PPPoE users except leased users for packet validity based on source IP address.
If you specify the subnet-check keyword, strict IPv6 uRPF checks traffic of all PPPoE users including leased users for packet validity. The packet validity check is based on the Framed-Route or Framed-IP-Netmask RADIUS attribute.
# Enable strict IPv6 uRPF check for all PPPoE users except leased users on Virtual-Template 100.
[Sysname-Virtual-Template100] ipv6 urpf strict
reset ipv6 urpf discard statistics
Use reset ipv6 urpf discard statistics to clear IPv6 uRPF packet drop statistics.
reset ipv6 urpf discard statistics [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears IPv6 uRPF packet drop statistics for all cards.
# Clear IPv6 uRPF packet drop statistics for the card on slot 10.
