H3C Servers Whitley & Cedar Island Platform BIOS User Guide-6W108
HomeSupportConfigure & DeployUser ManualsH3C Servers Whitley & Cedar Island Platform BIOS User Guide-6W108
01-Text
01-Text 16.71 MB
About the BIOS·· 1
Introduction· 1
Applicable products· 1
Using this document 1
Common BIOS tasks· 3
Entering the BIOS setup utility· 3
Setting the BIOS language· 6
Setting the BIOS setup mode· 7
Displaying processor information· 8
Displaying memory information· 9
Displaying onboard drive information· 10
Configuring NVMe SSD RAID through VROC· 11
Configuring PCIe ports· 18
Configuring PXE for NICs· 22
Configuring TXT (for the R4700/R4900/R6900 G5 server only) 24
Setting HDM network information (except for the B5700 G5) 25
Configuring BIOS passwords· 28
About this task· 28
Restrictions and guidelines· 29
Setting a BIOS password· 30
Deleting a BIOS password· 31
Setting the system date and time· 34
Setting the BIOS boot mode· 35
Setting the server boot order 36
Enabling or disabling iFIST· 38
Logging in to iFIST· 39
Configuring serial port redirection· 40
Restoring BIOS default settings· 41
BIOS menus· 43
Main menu· 43
Advanced menu· 45
Socket Configuration submenu· 48
Platform Configuration submenu· 107
Dynamic Device Configuration submenu· 142
Trusted Computing submenu· 176
ACPI Settings submenu· 181
Serial Port Console Redirection submenu· 181
PCI Subsystem Settings submenu· 188
USB Configuration submenu· 190
CSM Configuration submenu· 191
NVMe Configuration submenu· 193
Network Configuration submenu· 194
Miscellaneous Configuration submenu· 197
Driver Health submenu· 198
Server menu· 199
Security menu· 215
Boot menu· 221
Exit menu· 228
Industry standards· 231
Acronyms and abbreviations· 232
About the BIOS
Introduction
The Basic Input and Output System (BIOS) is a non-volatile firmware stored in the system ROM of a server. It is used to perform hardware initialization during server booting and provide runtime services for the operating systems. As shown in Figure 1, the BIOS interacts between the server hardware and the operating system (OS).
Figure 1 Layered architecture of a server system
Applicable products
This document is applicable to the following products:
·     H3C UniServer B5700 G5
·     H3C UniServer R4300 G5
·     H3C UniServer R4700 G5
·     H3C UniServer R4700LC G5
·     H3C UniServer R4900 G5
·     H3C UniServer R4900LC G5
·     H3C UniServer R5300 G5
·     H3C UniServer R5500 G5 Intel
·     H3C UniServer R5500LC G5
·     H3C UniServer R6900 G5
Using this document
The information in this document is subject to change over time. You can access the H3C website to obtain the most recent version of the BIOS.
The information in this document might differ from your product if it contains custom configuration options or features.
The figures used in this document are for illustration only and might differ from your product.
Options on the BIOS screen vary by product or version and some options might be hidden and only used for internal debugging. To avoid impact on system operation, do not display or edit the hidden options without professional guidance.
Common BIOS tasks
This section provides procedures for the following common BIOS tasks:
·     Entering the BIOS setup utility
·     Setting the BIOS language
·     Setting the BIOS setup mode
·     Displaying processor information
·     Displaying memory information
·     Displaying onboard drive information
·     Configuring NVMe SSD RAID through VROC
·     Configuring PCIe ports
·     Configuring PXE for NICs
·     Configuring TXT (for the R4700/R4900/R6900 G5 server only)
·     Setting HDM network information (except for the B5700 G5)
·     Configuring BIOS passwords
·     Setting the system date and time
·     Setting the BIOS boot mode
·     Setting the server boot order
·     Enabling or disabling iFIST
·     Logging in to iFIST
·     Configuring serial port redirection
·     Restoring BIOS default settings
1.     Connect a keyboard, a mouse, and a monitor to the server or enable the remote console from the HDM Web interface.
For information about enabling the remote console, see H3C Servers HDM User Guide.
2.     Start or restart the server.
CAUTION
CAUTION:
·     During the BIOS startup, the system performs checksum verification on the BIOS firmware to ensure the firmware integrity and security. If the verification fails, the startup process is terminated and the system prompts the verification failure.
·     If uncorrectable errors occur during the memory test phase during the startup, the startup fails and the startup page prompts the errors. In this case, view HDM logs and replace the faulty DIMMs.
3.     Press Del or Esc when the BIOS startup screen opens, as shown in Figure 2.
Figure 2 BIOS setup screen
Table 1 BIOS shortcut keys
Key
Esc/Del
Enter the BIOS setup screen.
F7
Enter the Boot menu.
F10
Enter the iFIST GUI. For more information, see H3C Servers iFIST User Guide.
F12
Enter PXE boot.
4.     Enter the BIOS password if required during boot-up, as shown in Figure 3.
By default, no BIOS passwords are set. For information about BIOS password setup, see "Configuring BIOS passwords."
If you enter an incorrect password for three consecutive times, the server will restart automatically.
If you forget the password, use the system maintenance switch in the server to clear BIOS password settings. For more information about the system maintenance switch, see the user guide for the server.
IMPORTANT
IMPORTANT:
If you use the system maintenance switch to clear BIOS passwords, restore the switch to the default position after you set new password settings. If you fail to do so, the new settings will be cleared.
Figure 3 Entering the power on password
5.     (Optional.) If you have set a BIOS administrator password and a user password, select the role before entering BIOS setup, as shown in Figure 4.
Figure 4 Selecting a role to enter setup
6.     Enter the password of the selected role, as shown in Figure 5.
Figure 5 Entering the BIOS password
7.     On the BIOS setup utility screen that opens, press F1, and then follow the instructions in the dialog box that opens to configure BIOS settings, as shown in Figure 6.
Table 2 shows detailed information about the operation keys.
Figure 6 BIOS setup utility screen
Table 2 Operation keys
Key
Arrows
Select a screen or item.
Enter
Select an item to edit its value or access a submenu.
Change the field value of the selected item.
ESC
Exit the BIOS setup utility or return to the previous screen.
F1
Display the general help window.
F2
Load previous values in the BIOS.
F3
Load default values in the BIOS.
F4
Save the current configuration and exit the BIOS. As a best practice, use the Save Changes And Reset option on the Exit screen.
1.     Enter the BIOS setup utility. For more information, see "Entering the BIOS setup utility."
2.     Select Main > Setup Mode, and press Enter, as shown in Figure 7.
3.     Select a BIOS language mode from the System Language field. The setting takes effect immediately.
Figure 7 Setting the BIOS language
2.     Select Main > Setup Mode, and press Enter, as shown in Figure 8.
3.     Select a BIOS setup mode (Text or Graphic) from the Setup Mode field, and then press Enter.
Figure 8 Setting the BIOS setup mode
4.     Press F4 and then select Ok to save the configuration. The server will restart automatically.
2.     Select Advanced > Socket Configuration, and press Enter.
3.     Select Processor Configuration, and press Enter.
The Processor Configuration submenu that opens displays detailed information about processors, as shown in Figure 9.
For more information about the Processor Configuration submenu, see "Processor Configuration submenu."
Figure 9 Processor Configuration submenu screen
2.     Select Advanced > Socket Configuration > Memory Configuration, and press Enter.
The Memory Configuration submenu that opens displays memory capacity and frequency information, as shown in Figure 10.
3.     Select Memory Topology to enter Memory Topology submenu.
For more information about the Memory Configuration submenu, see "Memory Configuration submenu."
Figure 10 Memory Configuration submenu
Both the PCH SATA Configuration and PCH sSATA Configuration submenus display onboard drive information. The following uses the PCH SATA Configuration submenu for example. For more information about the submenus, see "PCH Configuration submenu."
2.     Select Advanced > Platform Configuration > PCH Configuration > PCH SATA Configuration, and press Enter.
The PCH SATA Configuration submenu that opens displays drive information, as shown in Figure 11.
Figure 11 PCH SATA Configuration submenu
On the Intel® Virtual RAID on CPU (Intel® VROC) menu of the BIOS Setup utility, you can configure virtual RAID of NVMe SSDs. This feature is available only when the Intel Volume Management Device (VMD) is enabled. By default, all VMD ports are disabled on all the servers except the B5700 G5.
Make sure you have installed the Intel NVMe VROC module on the server.
·     If you have installed the standard version of the VROC module, you can create RAID 0, RAID 1, and RAID 10.
·     If you have installed the advanced version of the VROC module, you can create RAID 0, RAID 1, RAID 5, and RAID 10.
·     If you have installed the Intel version of the VROC module, you can create RAID 0, RAID 1, RAID 5, and RAID 10 only for Intel NVMe SSDs.
2.     Select Advance > Socket Configuration > IIO Configuration > Intel VMD technology, as shown in Figure 12.
Figure 12 Intel VMD technology submenu screen
3.     Identify the VMD config options based on the slot number of the NVMe drive, set the corresponding Enable/Disable VMD field to Enabled, and enable the VMD ports, as shown in Figure 13.
Figure 13 VMD Config submenu screen
4.     Press F4 to save the settings and restart the server.
5.     Enter the BIOS setup utility. Select Advanced > Dynamic Device Configuration > Intel(R) virtual RAID on CPU, as shown in Figure 14.
Figure 14 Intel® virtual RAID on CPU submenu screen
6.     Select Create RAID Volume to enter the Create RAID Volume submenu.
7.     Enter the RAID name and select the RAID level. If you want to create a RAID across VMD controllers, set Enable RAID spanned over VMD Controllers to X.
Figure 15 Create RAID Volume submenu screen (1)
8.     Select the disks to be added to the RAID array. X means the disk has been selected.
Figure 16 Create RAID Volume submenu screen (2)
9.     Set the strip size and capacity, and then select Create Volume.
Figure 17 Create RAID Volume submenu screen (3)
10.     Select Yes to complete RAID creation.
Figure 18 Create RAID Volume submenu screen (4)
You can access the Intel® virtual RAID on CPU menu to view the created RAID array in the RAID Volumes field.
Figure 19 Intel® virtual RAID on CPU submenu screen
Perform this task to enable or disable PCIe ports (slots). With a PCIe port disabled, the operating system cannot identify the PCIe device connected to the port. To disable a PCIe device, you can perform this task to disable the corresponding port to avoid frequent PCIe device swapping.
1.     Enter the BIOS Setup utility. For more information, see"Entering the BIOS setup utility".
2.     Select Advanced > Socket Configuration, and then press Enter.
Figure 20 Socket Configuration submenu screen
3.     In the Socket configuration submenu, select IIO Configuration, and then press Enter.
Figure 21 IIO Configuration submenu screen
4.     In the IIO Configuration submenu, select a processor configuration item, and then press Enter.
Figure 22 Socket1 Configuration submenu screen
5.     Select a port, and then press Enter.
For more information about the connected device for a port, access the HDM Web interface.
Figure 23 Slot 3 – Port 1A configuration submenu screen
6.     Select Enabled, Disabled, or Auto from the PCI-E Port field, and then press Enter.
7.     Press F4 and then select Ok to save the configuration and exit the BIOS utility.
The configuration takes effect after the server reboots.
This feature configures the NIC preboot execute environment (PXE) feature to boot the server through the network.
Most server NICs have been installed with the PXE feature. When PXE is enabled, the server can download a startup image from a remote device through the network for OS startup or installation.
If the UEFI mode is used, configure an image file that supports the UEFI mode in PXE server configuration.
2.     Select Advance > Network Configuration, and press Enter, as shown in Figure 24.
Figure 24 Network Configuration submenu screen
3.     In the PCIE NIC Configuration submenu, configure the PXE feature for all ports or a single port, as shown in Figure 25.
¡     To configure PEX for all ports, set PCIE NIC PXE.
¡     To configure PEX for a single port, set NIC Port PXE for the specific port.
Figure 25 PCIE NIC Configuration submenu screen
Trusted Execution Technology (TXT) is a security feature supported by Intel processors for comprehensive data security in virtual computing. Intel TXT is available when TPM 2.0 or TPM 1.2 is used.
Enable the following features:
·     All Intel processor cores.
·     Hyper-Threading [ALL].
·     Intel® VT for Directed I/O (VT-d).
·     TPM (physical TPMs are enabled by default).
1.     Enter the BIOS Setup utility. For more information, see "Entering the BIOS setup utility".
2.     Select Advanced > Processor Configuration, and then press Enter.
Figure 26 Enable Intel(R) TXT item
3.     Select Enabled or Disabled from the Enable Intel(R) TXT field, and then press Enter.
4.     Press F4 and then select Ok to save the configuration and exit the BIOS utility.
Perform this task to configure IP address settings of HDM network ports and the method for obtaining the network information.
The submenus are the same for both HDM dedicated and shared network ports. The following uses the HDM shared network port for example.
Do not disconnect the AC power immediately after you modify and save HDM IPv4 and IPv6 address settings. Otherwise, the IP address setting might fail.
To avoid network storms, make sure the IP address of the HDM shared network port is on a network segment different than the HDM dedicated network port.
To avoid device disconnection, make sure HDM network configurations are correct.
2.     Select Server > HDM Network Configuration, and press Enter.
As shown in Figure 27, in the HDM Network Configuration submenu, both IPv4 configuration and IPv6 configuration are supported. Take IPv4 network configuration as an example.
3.     Select IPv4 Network Configuration.
4.     Select Refresh, press Enter, and then select Yes to refresh HDM network configuration.
Figure 27 HDM Network Configuration submenu
5.     Select Configuration Address source for the HDM shared network port, and press Enter.
Figure 28 HDM Network Configuration submenu
6.     From the Configuration Address source field, select the method for obtaining HDM network information. Options are:
¡     UnspecifiedRetains current configuration.
¡     StaticUses manually specified configuration.
¡     DynamicHdmDhcpUses network information obtained through DHCP.
Figure 29 HDM Network Configuration submenu
7.     Press Enter. If you select Static as the method for obtaining HDM network information, edit the following items and press Enter every time you finish editing:
¡     Station IP address—Enter a static IP address. This item is required.
¡     Subnet mask—Enter a subnet mask for the static IP address. This item is required.
¡     Router IP address—Enter a gateway IP address.
8.     Press F4 and then select Ok to save the configuration.
BIOS passwords include a boot password as well as an administrator password and a user password for BIOS Setup. By default, no passwords are set.
·     A boot password is required each time the server starts up.
·     An administrator password or a user password is required each time you enter the BIOS Setup screen.
If only the administrator password is set, you can enter this password to obtain administrator privileges. The system prompts for the password when you use shortcut keys to enter the BIOS setup utility, iFIST, boot menu, or PXE boot interface.
If only the user password is set, you can enter this password to obtain user privileges. Table 3 shows the menu items that are accessible in the BIOS with the user privileges.
Table 3 BIOS menu items accessible with the user password
Level-1 menu
Submenu items
Security
User Password
Exit
Save Changes and Exit
Discard Changes and Exit
Save Changes and Reset
Discard Changes and Reset
Save Changes
Discard Changes
When you change a BIOS password, make sure the new password is different from the most recent three passwords.
The BIOS passwords must meet the following requirements:
·     A case-sensitive string of 8 to 20 characters. Valid characters are letters, digits, spaces, and special characters in Table 4.
·     Contain a minimum of two character types from uppercase letters, lowercase letters, and digits.
·     Contain a minimum of one space or special character.
Table 4 Special characters
Character name
Symbol
Character name
Symbol
Back quote
Tilde
Exclamation point
At sign
Pound sign
Dollar sign
Percent sign
Caret
Ampersand sign
Asterisk
Left parenthesis
Right parenthesis
Underscore
_
Plus sign
Minus sign
Equal sign
Left bracket
Right bracket
Back slash
Left brace
Right brace
Vertical bar
Semi-colon
Apostrophe
Colon
Quotation marks
Comma
Dot
Forward slash
Left angle bracket
Right angle bracket
Question mark
The procedure is the same for setting the administrator password and the user password. This section uses the administrator password as an example.
To set the administrator password:
2.     Select Security > Administrator Password -Not Installed, and press Enter, as shown in Figure 30.
Figure 30 Setting the administrator password
3.     In the Enter Password dialog box that opens, enter an administrator password, confirm the password, select Ok, and then press Enter, as shown in Figure 31.
Figure 31 Creating the administrator password
The procedure is the same for deleting the administrator password and the user password. This section uses the administrator password as an example.
To delete the administrator password:
2.     Select Security > Administrator Password -Installed, and press Enter, as shown in Figure 32.
Figure 32 Selecting the administrator password
3.     In the Enter Password dialog box that opens, enter the current administrator password, leave the new password fields empty, select Ok, and then press Enter, as shown in Figure 33.
Figure 33 Entering the current administrator password
4.     In the WARNING dialog box that opens, select Ok, and press Enter, as shown in Figure 34.
Figure 34 Confirming the deletion
5.     Press F4 and then select OK to save the configuration.
2.     Select the Main menu.
3.     Set the system date, as shown in Figure 35:
a.     Select System Date.
The system date is in the format of mm/dd/yyyy.
b.     Press → or ← to switch between the month, day, and year fields and then use the following methods to modify the value:
-     Press + or to increase the value by 1.
-     Press or to decrease the value by 1.
c.     To save the configuration, press or ← to select the Set button, and then press Enter.
Figure 35 Setting the system date
4.     Set the system time, as shown in Figure 36:
a.     Select System Time.
The system time uses the 24-hour time system and is in the format of hh:mm:ss.
b.     Press or to switch between the hour, minute, and second fields and then use the following methods to modify the value:
c.     To save the configuration, press or to select the Set button, and then press Enter.
Figure 36 Setting the system time
The server supports two BIOS boot modes: legacy mode and UEFI mode.
By default, the boot mode is UEFI. For operating systems that support only the legacy mode, change the boot mode to legacy.
An operating system can run only in the BIOS boot mode under which the system was installed. For example, operating systems installed in legacy mode cannot start up in UEFI mode, and operating systems installed in UEFI mode cannot start up in legacy mode.
1.     Enter the BIOS setup screen. For more information, see "Entering the BIOS setup utility."
2.     As shown in Figure 37, select Boot > Boot mode select, and press Enter.
3.     From the Boot mode select field, select LEGACY or UEFI, and press Enter.
Figure 37 Setting the BIOS boot mode
Perform this task to change the server boot order.
The default boot order is hard disk > network > CD/DVD > other device as shown in the Fixed Boot Order Priorities list in Figure 38.
If the server has more than one boot devices of the same type, the Fixed Boot Order Priorities list displays only the first boot device. To change the first boot device, enter the corresponding priorities submenu of the boot device, and then set the first boot option. For example, to change the first boot option for hard disks, enter the UEFI Hard Disk Drive BBS Priorities submenu as shown in Figure 194, and then set the first boot option.
2.     As shown in Figure 38, select the Boot menu.
Figure 38 Boot menu
Table 5 Server boot options
Item
Example
Hard Disk
Disk (including virtual drives), SD cards, and USB-HDD.
Network
Network.
CD/DVD
CD-ROM and DVD-ROM (including virtual ones), USB-CD, and USB-DVD.
Other Device
The options include but are not limited to:
·     Boot option for entering the Shell command line interface. This option is available only when EFI Shell Boot is set to Enabled.
·     Other unidentified boot devices.
Disabled
The boot option is disabled.
3.     As shown in Figure 39, select the option to be modified from the Fixed Boot Order Priorities area, and press Enter.
4.     In the dialog box that opens, select a new boot device type, and press Enter.
Figure 39 Changing a boot option submenu screen
5.     Press F4 and then select Ok to save the configuration and exit the menu. The configuration takes effect immediately.
This feature enables or disables iFIST. The integrated Fast Intelligent Scalable Toolkit (iFIST) is a standalone intelligent deployment tool embedded in the server. Users do not need to install it. For more information about the iFIST, see H3C Servers iFIST User Guide.
If iFIST is enabled, after the server is initialized, you can enter the iFIST system from the BIOS. If iFIST is disabled, the iFIST Boot shortcut will not be displayed on the BIOS set utility, and you cannot start iFIST by pressing F10.
2.     Select Boot > iFIST Boot, select Enabled or Disabled, and then press Enter, as shown in Figure 40.
Figure 40 iFIST boot option
3.     Press F4 and then select Ok to save the configuration and exit the BIOS utility.
Logging in to iFIST
Press F10 on the BIOS boot screen to access the iFIST GUI. iFIST login screen opens after iFIST starts up.
If the boot screen does not display the iFIST shortcut, make sure iFIST is enabled. For more information, see "Enabling or disabling iFIST."
Figure 41 BIOS boot screen
Serial port redirection redirects console information to the specified serial port. You can perform this task to enable or disable this feature.
2.     Select Advanced > Serial Port Console Redirection, and then press Enter.
Figure 42 Serial Port Console Redirection subscreen
3.     Select Enabled or Disabled from the Console Redirection field, and then press Enter.
4.     If you enabled this feature, select Console Redirection Settings, press Enter, and configure redirection parameters as needed.
5.     Press F4 and then select Ok to save the configuration and exit the BIOS utility.
You can perform this task to restore BIOS to its default settings if unknown modifications to the BIOS cause system problems.
2.     Press F3 in the BIOS, or select Exit > Restore Defaults and press Enter as shown in Figure 43.
3.     Press F4 and Enter to save the settings. The configuration will take effect after the server reboots.
Figure 43 Restoring the default from the Exit submenu screen
BIOS menus
Main menu
As shown in Figure 44 and Figure 45, the Main menu contains information about the BIOS, memory, system language, and system time and date. For more information about the menu items, see Table 6.
Figure 44 Main menu screen (1)
Figure 45 Main menu screen (2)
Table 6 Items on the Main menu screen
Item
BIOS Information
Project Name
Displays the project name.
N/A
Product Name
Displays the product name.
N/A
BIOS Version
Displays the BIOS version.
N/A
Build Date and Time
Displays the compiling date and time of the BIOS build.
N/A
System Uuid
Displays the universally unique identifier (UUID) of the system.
N/A
Access Level
Displays the privileges of the current login role.
N/A
Platform Information
Processor
Displays the CPU ID and stepping.
N/A
PCH
Displays the platform controller hub (PCH) model.
N/A
RC Revision
Displays the RC version.
N/A
Memory Information
Total Memory
Displays the total memory capacity of DRAM in GB.
N/A
Usable Memory
Displays the usable DRAM memory capacity, in GB.
When a specific memory mode, such as memory mirroring, is set, the total memory capacity is different from the actual usable memory capacity. This item displays the actual usable memory capacity.
N/A
Total DCPMM Memory
Displays the total memory capacity of DCPMM in GB.
DCPMM should be used together with DRAM. For information about how to install DCPMM, see the user guide.
N/A
Current Memory Frequency
Displays the current memory frequency.
For information about setting the memory frequency, see "Memory Configuration submenu."
N/A
System Language
Displays the language used in the system.
The BIOS supports English and simplified Chinese.
To switch between the languages, press Enter.
English
Setup Mode
Set the BIOS setup mode.
Options:
·     Text.
·     Graphic.
Graphic
System Date
Displays the system date. You can change the system date as needed.
The system date is in the format of mm/dd/yyyy. To move between the month, day, and year fields, press Enter or Tab. To change the value for the selected field, use the following method:
·     Press + to increase the value by 1.
·     Press - to decrease the value by 1.
N/A
System Time
Displays the system time. You can change the system time as needed.
The system time is in the format of hh:mm:ss in 24-hour format. To move between the hour, minute, and second fields, press Enter or Tab. To change the value for the selected field, use the following method:
N/A
Advanced menu
As shown in Figure 46 and Figure 47, the Advanced menu contains advanced system features and functionalities, which are described in Table 7.
Figure 46 Advanced menu screen (1)
Figure 47 Advanced menu screen (2)
Table 7 Items on the Advanced menu screen
Item
Submenu for configuring the socket.
Submenu for configuring the platform.
Submenu for configuring dynamic device settings.
Trusted Computing
Submenu for configuring trusted computing.
ACPI Settings
Submenu for configuring advanced configuration and power interface (ACPI) settings.
Submenu for configuring serial port console redirection.
Submenu for configuring the PCI subsystem.
USB Configuration
Submenu for configuring USB.
CSM Configuration
Submenu for configuring the compatibility support module (CSM).
NVMe Configuration
Submenu for configuring NVMe.
Submenu for configuring network stacks.
Other configuration.
iSCSI Configuration
Submenu for configuring iSCSI.
This submenu is available only for the B5700, R5300, and R5500 G5.
Intel(R) VROC sSATA Controller
Submenu for configuring Intel(R) VROC sSATA controller.
This submenu is available only when the sSATA mode is set to RAID in the PCH settings.
Intel(R) VROC SATA Controller
Submenu for configuring Intel(R) VROC SATA controller.
This submenu is available only when the SATA mode is set to RAID in the PCH settings.
Intel(R) Virtual RAID on CPU
Submenu for configuring Intel(R) Virtual RAID on CPU (Intel VROC).
This submenu is available only when VMD is enabled.
Driver Health
Submenu for viewing the health state of drivers or controllers.
This submenu is available only in UEFI boot mode.
Figure 48 shows the Socket Configuration menu screen, on which you can configure processors, command reference code, uncore, memory, IIO, and advanced power management settings as described in Table 8.
Figure 48 Socket Configuration submenu screen
Table 8 Items on the Socket Configuration submenu screen
Item
Submenu for configuring processors, as shown in Figure 49, Figure 50, and Figure 51.
The submenu items are described in Table 9.
Common RefCode Configuration
Submenu for configuring the common reference code, as shown in Figure 56.
The submenu items are described in Table 12.
Uncore Configuration
Submenu for configuring Uncore parameters, as shown in Figure 57.
The submenu items are described in Table 13.
Submenu for configuring memory parameters, as shown in Figure 60 and Figure 61.
The submenu items are described in Table 16.
IIO Configuration
Submenu for configuring Integrated I/O module (IIO) parameters, as shown in Figure 69.
The submenu items are described in Table 22.
Advanced Power Management Configuration
Submenu for configuring advanced power management parameters, as shown in Figure 78.
The submenu items are described in Table 29.
Figure 49, Figure 50, and Figure 51 show the Processor Configuration submenu screen, on which you can configure features such as hyper-threading and hardware prefetcher for processors.
Figure 49 Processor Configuration submenu screen (1)
Figure 50 Processor Configuration submenu screen (2)
Figure 51 Processor Configuration submenu screen (3)
Figure 52 Processor Configuration submenu screen (4)
Figure 53 Processor Configuration submenu screen (5)
Table 9 Items on the Processor Configuration submenu screen
Item
Per-Socket Configuration
Access the submenu for per-socket configuration, as shown in Figure 54.
The submenu items are described in Table 10.
N/A
Processor BSP Revision
Displays the processor revision.
N/A
Processor Socket
Displays the sequence number of the processor socket.
N/A
Processor ID
Displays the processor ID.
N/A
Processor Frequency
Displays the processor frequency.
N/A
Processor Max Frequency
Displays the maximum frequency allowed for each processor.
N/A
Processor Min Frequency
Displays the minimum frequency allowed for each processor.
N/A
Processor TDP
Displays the thermal design power (TDP) of the processor.
N/A
Microcode Revision
Displays the microcode revision.
N/A
L1 Cache RAM (Per Core)
Displays the capacity of the level-1 processor cache.
N/A
L2 Cache RAM  (Per Core)
Displays the capacity of the level-2 processor cache.
N/A
L3 Cache RAM  (Per Package)
Displays the capacity of the level-3 processor cache.
N/A
Processor X Version
Displays the version of CPU X. This field displays not present if the CPU is absent.
This item is unavailable if the processer does not support hyper-threading.
Select Enabled or Disabled to enable or disable hyper-threading for the processors.
Hyper-threading allows a single processor to handle thread-level parallelism by enabling each physical processor core to function as two logical processor cores. This improves processor operating efficiency by enabling the processors to be compatible with multi-threaded OSs and software and reducing processor idle time.
Enabled
Check CPU BIST Result
Select Enabled or Disabled to enable or disable CPU built-in-self test (BIST).
Enabled
Hardware Prefetcher
Select Enabled or Disabled to enable or disable hardware prefetcher.
If hardware prefetcher is enabled, the processor prefetches instructions or data from memory to L2 cache before processing the instructions or data. This feature helps improve system performance by reducing memory access time and eliminating potential bottlenecks.
Enabled
L2 RFO Prefetch Disable
Select Enabled or Disabled to enable or disable L2 read for ownership (RFO) prefetch.
RFO is the process of reading cache rows from memory into the cache before they are written to memory.
Disabled
Adjacent Cache Prefetch
Select Enabled or Disabled to enable or disable adjacent cache prefetcher.
Adjacent cache prefetcher is also referred to as mid-level cache (MLC) prefetcher. This feature provides system optimization for applications that require high-frequency SAM. You can disable this feature when a large amount of RAM is needed.
Enabled
DCU Streamer Prefetcher
Select Enabled or Disabled to enable or disable data cache unit (DCU) stream prefetcher.
If the DCU stream prefetcher is enabled, the processor improves data processing and system performance by prefetching the stream and sending it to the L1 cache.
Enabled
DCU IP Prefetcher
Select Enabled or Disabled to enable or disable DCU IP prefetcher.
If the DCU IP prefetcher is enabled, the processor prefetches IP addresses to improve network connectivity and system performance.
Enabled
LLC Prefetch
Select Enabled or Disabled to enable or disable the L3 or last level cache (LLC) prefetcher.
·     R6900 G5: Disabled
·     Other servers: Enabled
Extended APIC
Select Enabled or Disabled to enable or disable the extended APIC mode. If the total number of processor cores exceeds 256, enable this mode as a best practice for the operating system to better support the processor multi-core feature.
Disabled
Enable Intel(R) TXT
Select Enabled or Disabled to enable or disable the support for the Intel trusted execution technology (TXT).
Intel TXT provides comprehensive data security protection in a virtualized computing environment.
To avoid potential security problems, set the debug mode to Disabled before enabling Intel TXT.
Before enabling this feature, make sure you have finished the prerequisites described in Configuring TXT (for the R4700/R4900/R6900 G5 server only).
Disabled
VMX
This item is configurable only when Enable Intel(R) TXT is set to Disabled.
Select Enabled or Disabled to enable or disable Intel virtual machine extensions (VMX).
VMX improves server hardware resource usage by allowing the virtualization layer or OS that supports VMX to use Intel hardware virtualization capabilities.
For virtualization layers or OSs that do not support VMX, this feature does not take effect even if it is enabled.
Enabled
Enable SMX
This item is unconfigurable when Enable Intel(R) TXT is set to Enabled.
Select Enabled or Disabled to enable or disable the safer mode extensions (SMX).
Disabled
PKG CST CONFIG CONTROL MSR Lock
Select Enabled or Disabled to enable or disable package C-state configuration control MSR lock.
Enabled
AES-NI
Select Enabled or Disabled to enable or disable the support for Intel Advanced Encryption Standard New Instructions (AES-NI).
AES-NI can promote the encryption and decryption speed for applications.
Enabled
Total Memory Encryption (TME)
Select Enabled or Disabled to enable or disable total memory encryption.
This feature ensures that all memory accessed by processors are encrypted, protecting the system memory from hardware physical attacks.
Disabled
Total Memory Encryption Multi-Tenant (TME-MT)
This item is configurable only when Total Memory Encryption (TME) is set to Enabled.
Select Enabled or Disabled to enable or disable multi-tenant total memory encryption.
Disabled
Max TME-MT Keys
This item is available only when Total Memory Encryption (TME) is set to Enabled.
Displays the maximum number of TME-MT keys.
N/A
SGX Factory Reset
Select Enabled or Disabled to enable or disable SGX factory reset.
Disabled
SW Guard Extensions(SGX)
Select Enabled or Disabled to enable or disable SW Guard Extensions (SGX). This feature provides hardware-based memory encryption that can isolate specific application program codes and data in memory.
This item is configuration only when the following requirements are met:
·     DDR4 memory: All white memory slots are populated with DIMMs.
·     UMA-Based Clustering is set to Disable (All2All).
·     Numa is set to Enabled.
·     ADDDC Sparing is set to Disabled.
Disabled
SGX Package Info In-Band Access
Select Enabled or Disabled to enable or disable SGX package info in-band access.
Disabled
PRMRR Size
This item is configurable only when SW Guard Extensions(SGX) is set to Enabled.
Set the size of the Processor Reserved Memory Range Register. Options include:
·     2G.
·     4G.
·     8G.
·     16G.
2G
SGX QoS
Select Enabled or Disabled to enable or disable SGX QoS.
Disabled
Select Owner EPOCH input type
This item is configurable only when SW Guard Extensions (SGX) is set to Enabled.
Select the owner EPOCH input type. Options include:
·     Manual User Defined Owner EPOCHs.
·     Change to New Random Owner EPOCHs.
Software Guard Extensions Epoch 0
Set the software guard extensions EPOCH value for SGX field 0. The value must be a hexadecimal number.
If Select Owner EPOCH input type is set to Change to New Random Owner EPOCHs, this field displays a random value.
N/A
Software Guard Extensions Epoch 1
Set the software guard extensions EPOCH value for SGX field 1. The value must be a hexadecimal number.
N/A
SGXLEPUBKEYHASHx Write Enable
Select Enabled or Disabled to enable or disable SGXLEPUBKEYHASHx write.
Disabled
SGXLEPUBKEYHASH0
This item is configurable only when SGXLEPUBKEYHASHx Write Enable is set to Enabled.
Set the 0th to 7th bytes for SGX to start SGX Launch Enclave Public Key Hash.
0
SGXLEPUBKEYHASH1
Set the 8th to 15th bytes for SGX to start SGX Launch Enclave Public Key Hash.
0
SGXLEPUBKEYHASH2
Set the 16th to 23rd bytes for SGX to start SGX Launch Enclave Public Key Hash.
0
SGXLEPUBKEYHASH3
Set the 24th to 31st bytes for SGX to start SGX Launch Enclave Public Key Hash.
0
Enable/Disable SGX Auto MP Registration Agent
Select Enabled or Disabled to enable or disable SGX auto MP registration agent for registration with the platform.
Enabled
Limit CPU PA to 46 bits
Select whether to limit a CPU physical address to 46 bits:
·     Enabled.
·     Disabled.
For the R5300 G5 and R5500 G5, the default is Disabled.
Enabled
Per-Socket Configuration submenu
Figure 54 shows the Per-Socket Configuration submenu screen. The submenu items are described in Table 10. For more information about processor configurations supported by a specific server, see the user guide for the server.
Figure 54 Per-Socket Configuration submenu screen
Table 10 Items on the Per-Socket Configuration submenu screen
Item
CPU Socket N Configuration
Submenu for configuring processor N, as shown in Figure 55. N represents the processor number. The screen displays only present processors.
The submenu items are described in Table 11.
CPU Socket Configuration submenu
Figure 55 shows the CPU Socket Configuration submenu screen. The submenu items are described in Table 11.
This section uses CPU socket 1 as an example.
Figure 55 CPU Socket 1 Configuration submenu screen
Table 11 Items on the CPU Socket 1 Configuration submenu screen
Item
Available Core Bitmap / Number
Displays the available core bitmap and core quantity.
N/A
Active Core Bitmap / Number
Displays the active core bitmap and core quantity.
Available core quantity = Active core quantity + Disabled core quantity
N/A
Core Disable Number
Select the number of the cores to be disabled. The configuration takes effect after the server starts.
To enable all cores of the processor, set the value to 0.
You can set the Core Disable Number to a number equal to or less than the available core quantity.
For example, if 18 cores are available and 4 cores are disabled, only 14 cores are active.
Generally, the more cores you enable, the better the computing performance. Please be cautious when you disable cores.
0
Common RefCode Configuration submenu
CAUTION
CAUTION:
Be careful to modify the MMCFG Base, MMIO High Base, and MMIO High Granularity Size values. To modify the values, make sure the modification is made based on the requirements of PCIe devices applied. For more information, see the PCIe device configuration guide.
Figure 56 shows the Common RefCode Configuration submenu screen, on which you can configure memory mapped I/O (MMIO) above 4 GB and non-uniform memory access (NUMA) settings as described in Table 12.
Figure 56 Common RefCode Configuration submenu screen
Table 12 Items on the Common RefCode Configuration submenu screen
Item
MMCFG Base
This item is not supported by the R6900 G5. Non-professionals are not recommended to modify this configuration, which may cause a shortage of MMIO resources, resulting in the failure of BIOS to start up.
Set the MMCFG base.
Options include:
·     1G.
·     1.5G.
·     1.75G.
·     2G.
·     2.25G.
·     3G.
·     Auto.
Auto.
MMIO High Base
Set the MMIO high base address for PCIe modules over 4G.
Options include:
·     56T.
·     40T.
·     32T.
·     24T.
·     16T.
·     12T.
·     4T.
·     2T.
·     1T.
·     512G.
CAUTION CAUTION:
The upper limit of the MMIO high base address is 64T. If the sum size of MMIO high base and size allocated to each stack exceeds 64T, the system hangs at startup. For the B5700, R4300, R4700, R4900, R5300, and R5500 G5, make sure that the sum of MMIO high base and MMIO high granularity size multiplied by 10 is less than 64T.
·     For the R5300 and R5500 G5: 32T.
·     For the other servers: 56T.
Set the MMIO high granularity size, which represents the MMIO size allocated to each stack. Make sure the value is adjusted based on the requirements of installed PCIe devices on MMIO high base address over 4G and do not change it arbitrarily. If a large number of PCIe devices, especially GPUs, are installed, you can increase the MMIO high granularity size to increase the MMIO high base space, so as to ensure the correct allocation of MMIO high base resources to PCIe devices.
Options include:
·     1G.
·     4G.
·     16G.
·     64G.
·     256G.
·     1024G.
·     4096G.
CAUTION CAUTION:
·     For the R5300 and R5500 G5: 4096G.
·     For the other servers: 64G.
Isoc Mode
Select whether to enable the Isoc mode.
Options:
·     Enabled.
·     Disabled.
·     Auto.
Auto
Numa
Select Enabled or Disabled to enable or disable non-uniform memory access (NUMA).
Under NUMA, a processor can access its own local memory faster than non-local memory.
Enabled
Select the UMA-based clustering (UBC) mode. Options include:
·     Hemisphere (2-clusters)—Enable the UBC mode (also known as Hemisphere (HEMI). This mode allows affinity to exist between memory address and LLC slices to minimize distance memory address and cached LLC. This mode is available only when memory modules are populated in a symmetrical way and SNC is disabled.
·     Disable (All2All)Disable the UBC mode.
Uncore Configuration submenu
Figure 57 shows the Uncore Configuration submenu screen, on which you can configure Uncore settings as described in Table 13.
Figure 57 Uncore Configuration submenu screen
Table 13 Items on the Uncore Configuration submenu screen
Item
Uncore General Configuration
Submenu for configuring the Uncore General Settings.
Uncore General Configuration submenu
Figure 58 shows the Uncore General Configuration submenu screen, on which you can configure Uncore settings as described in Table 14.
Figure 58 Uncore General Configuration submenu screen
Table 14 Items on the Uncore General Configuration submenu screen
Item
Uncore Status
Displays the Uncore status.
N/A
Link Frequency Select
Select the UPI link frequency.
Options:
·     9.6GT/s.
·     10.4GT/s.
·     11.2GT/s.
·     Auto.
Auto
KTI Prefetch
This item is available only for the R6900 G5.
Select whether to enable KTI prefetch. KTI prefetch enables memory read operations on DDR bus to be carried out earlier.
Options:
·     Auto.
·     Enabled.
·     Disabled.
Auto
SNC(Sub NUMA)
Select whether to enable sub NUMA clustering (SNC). SNC can shorten the delay between the LLC and the memory.
For the servers except for the B5700, R4300, R4700, R4900, R5300, and R5500 G5, options:
·     Enabled.
·     Disabled.
For the B5700, R4300, R4700, R4900, R5300, and R5500 G5, options:
·     Enable SNC2 (2-clusters)To enable SNC, make sure the value of the MMCFG Base is an integer, for example, 1, 2, or 3 G.
·     Disabled.
Disabled
XPT Prefetch
Select whether to enable XPT prefetch.
Options:
·     Auto.
·     Enabled.
·     Disabled.
Auto
Stale AtoS
Select whether to enable the change from state A to S.
There are three states of cache directory: I stands for invalid; A stands for snooping all; S stands for shared. State AtoS enables the other rows to enter S state when the system reads from a row in A state and the other rows respond no match. This shortens latency of repeated cache reading without affecting writing and saves bandwidth. As a best practice, enable this feature if there are a lot of reading tasks across the sockets.
Options:
·     Auto.
·     Enabled.
·     Disabled.
Auto
LLC dead line alloc
Select whether to enable LLC dead line allocation. In the processor cache scheme, mid-level cache (MLC) evictions are filled into the last level cache (LLC). If a line is evicted from the MLC to the LLC, the processor can flag the evicted MLC lines as "dead." This means that the lines are not likely to be read again. This option allows deadlines to be dropped and never fill the LLC if the option is disabled.
Options:
·     Auto.
·     EnabledFills free LLC space with dead rows.
·     DisabledDiscards dead rows to save LLC space.
Enabled
Uncore Status submenu
Figure 59 shows the Uncore Status submenu screen, on which you can view the Uncore status as described in Table 15.
Figure 59 Uncore Status submenu screen
Table 15 Items on the Uncore Status submenu screen
Item
Number of CPU
Displays the number of CPUs.
Number of IIO
Displays the number of IIOs.
Current UPI Link Speed
Displays the link speed of the current UPI.
Current UPI Link Frequency
Displays the link frequency of the current UPI.
Global MMIO Low Base / Limit
Displays the low base/limit of the global MMIO.
Global MMIO High Base / Limit
Displays the high base/limit of the global MMIO.
Pci-e Configuration Base / Size
Displays the base/size of the UPI PCIe configuration.
Figure 60 and Figure 61 show the Memory Configuration submenu screen, on which you can configure memory settings such as the memory speed and memory RAS features as described in Table 16.
Figure 60 Memory Configuration submenu screen (1)
Figure 61 Memory Configuration submenu screen (2)
Table 16 Items on the Memory Configuration submenu screen
Item
Enforce POR
Select whether to enforce POR restrictions on DDR4 frequency selection to improve memory reliability.
Options:
·     Enforce POR.
·     Disabled.
As a best practice, do not disable this feature.
Enforce POR
Enforce Population POR
Specify how to enforce memory population rule.
Options:
·     Disable Enforcement.
·     Enforce Supported PopulationsFills supported memory, including validated memory and non-validated memory.
·     Enforce Validated Populations—Only fills validated memory.
Memory Frequency
Select the maximum memory frequency, in MT/s.
Options:
·     Auto.
·     2400.
·     2666.
·     2933.
·     3200.
Auto
Attempt Fast Boot
Select whether to enable fast boot attempt.
Options:
·     Enabled—Enables fast boot. If skipping part of memory reference code (MRC) can speed up the warm boot process, the system skips this part of MRC.
·     Disabled—Disables fast boot.
Enabled
Attempt Fast Cold Boot
Select whether to enable fast cold boot attempt.
Options:
·     Enabled—Enables fast cold boot. If skipping part of MRC can speed up the cold boot process, the system skips this part of MRC.
·     Disabled—Disables fast cold boot.
Enabled
RMT On Cold Fast Boot
Select whether to enable rank margin tool (RMT) during cold fast boot.
Options:
·     Enabled.
·     Disabled.
Disabled
Rank Margin Tool
Select whether to turn on the Rank Margin Tool to test memory timing and voltage signals.
Options:
·     EnabledRuns the Rank Margin Tool after memory training.
·     Disabled—Disables the Rank Margin Tool.
Disabled
Enable ADR
Select whether to enable asynchronous DIMM self-refresh (ADR) check.
Options:
·     Enabled.
·     Disabled.
Enabled
2x Refresh Enable
Select whether to enable two times of memory refresh.
Options:
·     Auto.
·     Enabled.
·     Disabled.
Auto
Memory Topology
Access the submenu that displays memory information, as shown in Figure 62.
The submenu items are described in Table 17.
N/A
Memory Map
Access the submenu for configuring memory mapping and interleaving, as shown in.
You can enable memory interleaving to improve memory read and write performance.
The submenu items are described in Table 18.
N/A
Memory RAS Configuration
Access the submenu for configuring memory reliability, availability, and serviceability (RAS) settings, as shown in Figure 65 and Figure 66.
The submenu items are described in Table 20.
N/A
PMem Configuration
This item is available only when Barlow Pass (BPS) memory modules are present.
Access the submenu for configuring persistent memory (PMem).
N/A
Figure 62 shows the Memory Topology submenu screen. The submenu items are described in Table 17.
Figure 62 Memory Topology submenu screen
Table 17 Items on the Memory Topology submenu screen
Item
DIMM Status: Enabled CPU1_CH1_D0: 3200MT/s Micron DRx4 32GB RDIMM
Display the DIMM status, location, and other information. For example, DIMM Status: Enabled CPU1_CH1_D0: 3200MT/s Micron DRx4 32GB RDIMM, where:
·     DIMM Status: EnabledDIMM status, which is enabled.
·     CPU1_CH1_D0—DIMM location, which is DIMM slot 0 of channel 1 for CPU1.
·     3200MT/s—DIMM frequency.
·     Micron—DIMM vendor.
·     DRx4—DR stands for the number of ranks. x4 indicates the bit width of a DIMM chip.
·     32GBCapacity of the DIMM.
·     RDIMMType of the DIMM.
Memory Map submenu
Figure 63 shows the Memory Map submenu screen for the B5700, R4300, R4700, R4900, R5300, and R5500 G5. The submenu items are described in Table 18.
Figure 63 Memory Map submenu screen (for the B5700, R4300, R4700, R4900, R5300, and R5500 G5)
Table 18 Items on the Memory Map submenu screen (for the B5700, R4300, R4700, R4900, R5300, and R5500 G5)
Item
Volatile Memory Mode
Set the volatile memory mode for PMem.
Options:
·     2LM—Sets the 2 Level Memory (2LM) mode. In this mode, 2LM facilitates DDR4 memory as cache and PMem can operate in volatile memory mode. To configure Memory Mode (MM) for PMem, you must also configure settings on the PMem configuration subscreen.
·     1LMSets the 1 Level Memory (1LM) mode. In this mode, DDR4 memory acts as ordinary memory and PMem can operate in App Direct (AD) mode.
1LM
AppDirect cache
Select Enabled or Disabled to enable or disable caching for the memory region.
This item is available only when the volatile memory mode is 2LM.
Disabled
Figure 64 shows the Memory Map submenu screen for the R6900 G5. The submenu items are described in Table 19.
Figure 64 Memory Map submenu screen (for the R6900 G5)
Table 19 Items on the Memory Map submenu screen (for the R6900 G5)
Item
eADR Support
Select whether to enable the eADR capability in the platform.
Options:
·     Enabled.
·     Disabled.
·     Auto.
Do not enable eADR and ADR at the same time.
Disabled
CPU Cache Flush Mode
Select the processor cache flush execution mode.
Options:
·     Parallel.
·     Serial.
Parallel
Memory RAS Configuration submenu
Figure 65 and Figure 66 show the Memory RAS Configuration submenu screen. The submenu items are described in Table 20.
Figure 65 Memory RAS Configuration submenu screen (1)
Figure 66 Memory RAS Configuration submenu screen (2)
Table 20 Items on the Memory RAS Configuration submenu screen
Item
New SDDC Mode
This item is not available for the R6900 G5.
Select Enabled or Disabled to enable or disable SDDC mode.
Enabled
Mirror Mode
This item is unconfigurable when UEFI ARM Mirror or ADDDC Sparing is set to Enabled.
Specify a mirror mode.
Options:
·     Disabled—Disables mirror mode.
·     Full Mirror ModeSets all 1LM memory to operate in mirror mode, which reduces the available memory capacity by half.
·     Partial Mirror Mode—Enables partial mirror mode. In this mode, you can set the memory size of the mirror.
·     Due to hardware limitations, a segment of address space must be equally divided among the socket, IMC, Channel and rank. Therefore, when all the DIMMs are present, the memory capacity displayed in the POST screen and BIOS Setup utility is greater than half of the total memory capacity in the full mirror mode.
·     Enabling any type of mirror mode will disable XPT prefetch.
Disabled
Partial Mirror x Size(GB)
This item is available only when the Mirror Mode is set to Partial Mirror Mode.
Set the size of the partial mirror.
N/A
Mirror TAD0
This item is unconfigurable when Mirror Mode is set to Full Mirror Mode or ADDDC Sparing is set to Enabled.
Select Enabled or Disabled to enable or disable the mirror target address decoder (TAD0) mode.
If Enabled is selected, the memory saved for MMIO will be used for mirroring.
Disabled
UEFI ARM Mirror
This item is unconfigurable when Mirror Mode is not disabled or ADDDC Sparing is set to Enabled.
Select Enabled or Disabled to enable or disable UEFI ARM mirror mode.
Disabled
ARM Mirror percentage
Set the ARM mirror percentage. For example, 12.75% can be written as 1275.
N/A
Correctable Error Threshold
Set the correctable error threshold in decimal notation.
Value range: 0 to 32767.
Value 0 indicates that no correctable error threshold is set.
8192
Leaky bucket low bit
This item is configurable only when Memory Rank Sparing is set to Enabled.
Set the leaky bucket low bit in the range of 0 to 0x3F in hexadecimal notation.
0x10
Leaky bucket high bit
Set the leaky bucket high bit in the range of 0 to 0x29 in hexadecimal notation.
0x11
ADDDC Sparing
This item is unconfigurable when Mirror Mode is set to Partial Mirror Mode or Full Mirror Mode.
Select Enabled or Disabled to enable or disable adaptive double device data correction (ADDDC) sparing.
ADDDC sparing can correct data errors on two memory chips and is available only for x4 memory.
After modification, you must perform a cold reboot for the new ADDDC Sparing setting to take effect.
For the change to take effect, perform cold reboot.
Enabled
Plus One
Select Enabled or Disabled to enable or disable the SDDC.
Disabled
Enable ADDDC Error Injection
This item is available only when ADDDC Sparing is set to Enabled.
Select Enabled or Disabled to enable or disable ADDDC error injection.
Enabled
Column Correction Disable
Select Enabled or Disabled to disable or enable column correction.
Disabled
Set PMem Die Sparing
Select Enabled or Disabled to enable or disable the PMem Die sparing.
Enabled
ECC Mode Switch
Select Enabled or Disabled to enable or disable remote memory controller mode to switch from A to B.
Enabled
Patrol Scrub
This item enables or disables patrol scrubbing.
·     Enabled—Enables patrol scrubbing.
·     Disabled—Disables patrol scrubbing.
·     Enable at End of POST—Enables patrol scrubbing after POST.
Patrol scrubbing allows a processor to automatically search for and correct correctable memory errors at regular intervals.
Enable at End of
POST
Patrol Scrub Interval
Set the patrol scrub interval in hours. This item is available only when Patrol Scrub is set to Enabled.
An interval of 0 indicates auto patrol scrubbing.
24
PMem Configuration submenu
Figure 67 and Figure 68 show the PMem Configuration submenu screen. The submenu items are described in Table 21.
Figure 67 PMem Configuration submenu screen (1)
Figure 68 PMem Configuration submenu screen (2)
Table 21 Items on the PMem Configuration submenu screen
Item
PMem Factory Reset/Clear
Select Enabled or Disabled to enable or disable PMem factory reset/clear.
Options:
·     Enabled—Enables PMem factory reset/clear. The average power budget setting will override the default average power budget.
·     Disabled—Disables PMem factory reset/clear.
Disabled
200 Series PMem Average Power Limit(in mW)
Set the 200 series PMem average power limit in mW. The value starts from 10000 mW and must be a multiple of 250 mW.
The average power limit range varies by the capacity of NVDIMM. If the capacity is 128G, the power limit range is 10 W to 15 W. If the capacity is 256 or 512 GB, the power limit range is 12 W to 18 W.
If you set a value out of the range, the system corrects the value automatically.
15000
200 Series PMem Turbo/Memory Bandwidth Boost(MBB) Average Power Time Constant(in mSec)
Set the 200 series PMem average power time constant in mSec as the base time window for measuring the average power. The value is in the range of 10000 ms to 120000 ms and increases in a step size of 1000 ms.
15000
200 Series PMem Turbo/Memory Bandwidth Boost(MBB) Feature
Select Enabled or Disabled to enable or disable 200 series PMemTurbo/memory bandwidth boost (MBB).
Enabled
200 Series PMem Turbo/Memory Bandwidth Boost Feature(MBB) Power Limit(in mW)
Set 200 series PMem memory bandwidth boost (MBB) power limit, in mW.
18000
Publish ARS capability
Select Enabled or Disabled to enable or disable the publishing of address range scrubbing (ARS).
If Enabled is selected, ARS allows the system software to check memory errors, so as to avoid access that may lead to uncorrectable memory errors in advance, and allows memory errors to be counted.
Enabled
PMem FastGo Configuration
Select PMem FastGo configuration profiles.
Options:
·     Auto.
·     Enabled FastGo optimization.
·     Disabled FastGo optimization.
Auto
PMem QoS
Set PMem Quality of Service (QoS) to prevent DDR4 BW drop in case of DDRT BW concurrency.
Options:
·     PMem QoS Disabled.
·     Profile 1 – Optimized for 8 PMem modules per socket.
·     Profile 2 – Optimized for 4/2/1 PMem modules per socket.
PMem Qos Disabled
Snoopy mode for 2LM
Enable the snoopy mode for 2LM to avoid direct updates to far-memory from non-NUMA optimized workloads.
Options:
·     Enabled.
·     Disabled.
Disabled
PMem Performance Setting
Options:
·     BW Optimized.
·     Balanced Profile.
BW Optimized
Snoopy mode for AD
Enable the snoopy mode for AD to avoid direct updates to PMem memory from non-NUMA optimized workloads.
Options:
·     Enabled.
·     Disabled.
Disabled
Figure 69 shows the IIO Configuration submenu screens, on which you can configure the peripheral component interconnect express (PCIe) slots, including their link speed and maximum payload size, as described in Table 22.
Figure 69 IIO Configuration submenu screen
Figure 70 IIO Configuration submenu screen (R6900 G5)
Table 22 Items on the IIO Configuration submenu screen
Item
SocketN Configuration
This item is available only when the processor is present.
Display the IIO configuration of processor N.
N/A
Intel VT for Directed I/O (VT-d)
Displays the configuration menu for Intel® VT.
N/A
Displays the configuration menu for Intel®VMD.
N/A
Enhanced NVMe Hotplug Support
Set the enhanced NVMe hot plug support policy.
Options:
·     OS-Aware Hotplug.
·     OS-Aware & Surprise Hotplug.
OS-Aware Hotplug
IIO-PCIE Express Global Options
PCIe Hot Plug
Select whether to enable or disable PCIe hot plug.
Options:
·     Enabled—Enables global PCIe hot plug.
·     Disabled—Disables global PCIe hot plug.
·     Auto—Sets PCIe hot plug automatically. This option is available only for the R6900 G5.
·     Manual—Sets PCIe hot plug manually. This option is available only for the R6900 G5.
Enabled
PCI-E ASPM Support (Global)
Select whether to enable PCIe ASPM globally.
Options:
·     Disabled—Disables PCIe ASPM globally.
·     Per-Port—Controls PCIe ASPM per port.
·     L1 Only—Supports PCIe ASPM only on L1.
Disabled
PCIe 10-bit Tag Support
Select whether to enable PCIe 10-bit tag support. The 10-bit tag allows Requester to increase the number of its unprocessed Non-Posted Requests (NPR) from 256 to 768, thus avoiding tag availability as a bottleneck. Options:
·     AutoKeeps the hardware default settings.
·     DisabledDisables global PCIe 10-bit tag support.
This option is available only for the B5700/R4300/R4700/R4900/R5300/R5500 G5.
Auto
PCIe 10-bit Tag Enable
Select whether to enable PCIe 10-bit tag support. The 10-bit tag allows Requester to increase the number of its unprocessed NPRs from 256 to 768, thus avoiding tag availability as a bottleneck. Options:
Enabled
The Socket Configuration submenu displays link parameters and status for PCIe ports, and provides options for managing each PCIe port, such as port enabling, link speed selection, and hot swapping enabling.
The Socket Configuration submenu screen varies by server model and PCIe riser card model. The following uses Socket 1 Configuration for example.
Figure 71 shows the Socket 1 Configuration submenu screen. The submenu items are described in Table 23.
Figure 71 Socket 1 Configuration submenu screen
Table 23 Items on the Socket 1 Configuration submenu screen
Item
Port 0/DMI
Displays the configuration menu for Port 0/DMI.
DMI is the interface between the CPU and the PCH.
N/A
Slot 3 - Port 1A
Displays the configuration menu for Port 1A.
Slot 3 indicates the slot ID of the device connected to the PCIe slot.
N/A
The following takes Slot 3 – Port 1A for example.
Figure 72 and Figure 73 show the Port Configuration submenu screen. The submenu items are described in Table 24.
Figure 72 Port Configuration submenu screen (1)
Figure 73 Port Configuration submenu screen (2)
Table 24 Items on the Port Configuration submenu screen
Item
PCI-E Port
This item is available only for non-DMI PCIe ports.
Select whether to enable the PCIe port.
Options:
·     Auto.
·     Enabled.
·     Disabled.
Auto
Hot Plug Capable
Select whether to enable hot plug.
Options:
·     Auto.
·     Enabled.
·     Disabled.
·     Other servers: Auto
Surprise Hot Plug Capable
Select Enabled or Disabled to enable or disable surprise hot plug.
Disabled
PCI-E Port Link Disable
Select whether to enable the PCIe port link.
·     Enabled—Enables the PCIe port link.
·     Disabled—Disables the PCIe port link and link training. The PCIe configuration space is still active.
Disabled
Link Speed
Select a link speed for the PCIe port.
Options:
·     Auto.
·     Gen 1 (2.5 GT/s).
·     Gen 2 (5.0 GT/s).
·     Gen 3 (8.0 GT/s).
·     Gen 4 (16.0 GT/s)—Supported only by IceLake processors.
Auto
Override Max Link Width
Select a maximum link width to be covered.
Options:
·     Auto.
·     x1.
·     x2.
·     x4.
·     x8.
·     x16.
Auto
PCI-E Port Link Status
Displays the PCIe port link status.
N/A
PCI-E Port Link Max
Displays the maximum bandwidth of the PCIe port link.
N/A
PCI-E Port Link Speed
Displays the PCIe port link speed.
N/A
·     Force EnableForcedly enables PCIe 10-bit tag support for the device.
This option is not available for the R6900 G5.
Auto
PCI-E Port Max Payload Size
Set the maximum payload size of the PCIe port.
Options:
·     Auto—Sets the maximum payload size to 256B by default.
·     128B—Sets the maximum payload size to 128B. The configuration might affect the performance of NVMe drives. You can set the maximum payload size of a PCIe port to 128B if NVMe drive hot swapping causes the system to reboot.
·     256B—Sets the maximum payload size to 256B.
Auto
PCI-E ASPM Support
Select whether to enable support for PCIe active-state power management (ASPM). If the PCIe device is not in use, ASPM controls the power status at both ends of the PCIe link to save power.
Options:
·     AutoCPU auto.
·     L1 Only—Only L1 is supported.
·     Disabled—Disables PCIe ASPM.
L1 Only
PM ACPI Mode
Select Enabled or Disabled to enable or disable PM ACPI mode.
Disabled
Intel VT for Directed I/O (VT-d) submenu
Figure 74 shows the Intel VT for Directed I/O (VT-d) submenu screen for the R6900 G5. The submenu items are described in Table 25.
Figure 74 Intel VT for Directed I/O (VT-d) submenu screen (for the R6900 G5)
Table 25 Items on the Intel® VT for Directed I/O (VT-d) submenu screen (for the R6900 G5)
Item
Select Enabled or Disabled to enable or disable Intel virtualization technology for directed I/O (VT-d).
With this feature enabled, management programs and OSs that support this feature can provide directed I/O with hardware support offered by the Intel virtualization technology. You can enable this feature even if such management programs and OSs are not used.
Intel VT-d enhances system security and reliability, and improves the performance of I/O devices in a virtualized environment.
Enabled
Interrupt Remapping
Select whether to enable interrupt remapping.
Options:
·     Auto.
·     Enabled.
·     Disabled.
Auto
Posted Interrupt
Select Enabled or Disabled to enable or disable posted interrupt.
Enabled
ATS
Select Enabled or Disabled to enable or disable non-Isoch VT-d engine address translation services (ATS).
Enabled
Coherency Support(Non-Isoch)
Select Enabled or Disabled to enable or disable support for non-Isoch coherency.
With this feature enabled, management programs and operating systems that support this option can utilize hardware features that provide asynchronous consistency support for directed I/O using Intel Virtualization Technology. This feature does not take effect on management programs and operating systems that do not support this feature.
Enabled
Figure 75 shows the Intel VT for Directed I/O (VT-d) submenu screen for the B5700, R4300, R4700, R4900, R5300, and R5500 G5. The submenu items are described in Table 26.
Figure 75 Intel VT for Directed I/O (VT-d) submenu screen (for the B5700, R4300, R4700, R4900, R5300, and R5500 G5)
Table 26 Items on the Intel VT for Directed I/O (VT-d) submenu screen (for the B5700, R4300, R4700, R4900, R5300, and R5500 G5)
Item
Enabled
Interrupt Remapping
Options:
·     Auto.
·     Enabled.
·     Disabled.
Auto
X2APIC Opt Out
Select Enabled or Disabled to enable or disable X2APIC opt out for VT-d.
Disabled
Figure 76 shows the Intel VMD technology submenu screen. The submenu items are described in Table 27.
Figure 76 Intel VMD technology submenu screen
Table 27 Items on the Intel VMD technology submenu screen
Item
Intel VMD for Volume Management Device on Socket n
Displays VMD configuration submenu for the volume management device on a processor.
This item is available only when a processor is in position.
The configurable parameters on the Intel VMD for Volume Management Device on Socket submenu are the same for different processors. The following takes Socket 1 for example, as shown in Figure 77. The submenu items are described in Table 28.
Figure 77 Intel VMD for Volume Management Device on Socket 1 submenu screen
Table 28 Items on the Intel VMD for Volume Management Device on Socket submenu screen
Item
VMD Config for PCH/IOU n
Indicates that the following VMD settings are for PCH or IOU port N.
NA
Enable/Disable VMD
Select Enabled or Disabled to enable or disable the VMD feature on the PCH or IOU port. VMD is available only in UEFI mode.
Options:
·     Disabled.
·     EnabledThe following fields will be displayed only when VMD is enabled.
·     B5700 G5: Enabled for the VMD Config for IOU 4 submenu for CPU 2
·     Other servers: Disabled
VMD port nA/B/C/D – Slot x
Select Enabled or Disabled to enable or disable the VMD on the port. The slot ID indicates the slot of the device connected to the port, which is decided by the riser card and the NVMe backplane.
Disabled
Hot Plug Capable
Select Enabled or Disabled to enable or disable hot plug on the port.
Disabled
CfgBar Size
Sets the size of the configured BAR, in bits. The value range of 20 to 27.
25
VMD for Direct Assign
Select Enabled or Disabled to enable or disable VMD resource direct assignment. Once enabled, this feature directly allocates VMD domains to VMs, bypassing the virtualization management program entirely, to reduce storage latency and increase bandwidth.
Options:
·     Disabled.
·     Enabled.
This option is available only for the R4900/R5300/R5500 G5.
Disabled
Advanced Power Management Configuration submenu
Figure 78 shows the Advanced Power Management Configuration submenu screen, on which you can configure advanced power management parameters, including P state control and C state control for processors and power management policy.
Figure 78 Advanced Power Management Configuration submenu screen
Table 29 Items on the Advanced Power Management Configuration submenu screen
Item
Workload Profile Configuration
Select the workload profile. Tthis menu does not support modifications through out-of-band IPMI/Redfish, nor does it support modifications through in-band SCE tools. For more information about configuration profiles, see H3C Servers Whitley & Cedar Island Platform Scenario-Based BIOS Configuration Guide.
Static Turbo
Configure the static turbo feature. Options include the following:
·     DisableDisable the static turbo feature. This is the default value.
·     ManualEnable the static turbo feature and allow the user to select a frequency.
·     AutoEnable the static turbo feature and use the MaxCore maximum turbo frequency.
If you enable this feature, the processor frequency will be set to a value between the base frequency and the maximum turbo frequency for all cores. In a Windows Server or CentOS 7 operating system, this feature is configurable only when the high performance mode is enabled.
CPU Frequency Select
Specify a CPU frequency. This parameter is displayed when you select Manual or Auto for the Static Turbo parameter.
·     When you select Manual for the Static Turbo parameter, you can specify a frequency in the range of the base clock to the MaxCore maximum turbo frequency. The default value is 40, and the unit is 100 MHz. If you specify a frequency smaller than the base clock, the base clock is used. If you specify a frequency larger than the supported MaxCore maximum turbo frequency, the MaxCore maximum turbo frequency is used.
·     When you select Auto for the Static Turbo parameter, this parameter is not configurable and displays the MaxCore maximum turbo frequency of the current CPU model.
CPU P State Control
Submenu for configuring CPU P-state control options, as shown in Figure 79 and Figure 80.
On the submenu, you can select whether to enable Enhanced Intel SpeedStep Technology (EIST) and turbo mode as described in Table 30.
Hardware PM State Control
Submenu for configuring hardware P-state control options, as shown in Figure 81.
The submenu items are described in Table 31.
CPU C State Control
Submenu for configuring CPU C-state control options, as shown in Figure 82.
On the submenu, you can control the power consumption of CPUs in idle state as described in Table 32.
Package C State Control
Submenu for configuring package C state control options, as shown in Figure 83.
On the submenu, you can set the C2 to C3 state transition timer as described in Table 33.
CPU Thermal Management
Submenu for configuring CPU thermal management options, as shown in Figure 84.
The submenu items are described in Table 34.
CPU Advanced PM Tuning
Submenu for configuring CPU advanced power management tuning, as shown in Figure 86.
The submenu items are described in Table 36.
Memory Power & Thermal Configuration
Submenu for configuring memory power and thermal, as shown in Figure 88.
The submenu items are described in Table 38.
CPU P State Control submenu
Figure 79 and Figure 80 show the CPU P State Control submenu screen. The submenu items are described in Table 30.
Figure 79 CPU P State Control submenu screen (1)
Figure 80 CPU P State Control submenu screen (2)
Table 30 Items on the CPU P State Control submenu screen
Item
EIST (P-States)
Select Enabled or Disabled to enable or disable Enhanced Intel SpeedStep Technology (EIST).
EIST allows the system to automatically adjust its performance states (P-States) to reduce power consumption and heat dissipation by lowering processor voltage and core frequency.
Enabled
Dynamic SST-PP
Availability of this item depends on the processor model.
Select Enabled or Disabled to enable or disable dynamic Speed Select Technology-Performance Profile (SST-PP).
Dynamic SST-PP allows dynamic configuration of processors.
Disabled
Intel SST-PP
This item is available only when Dynamic SST-PP is set to Disabled.
Configure static SST-PP.
Options:
·     Base.
·     Config 3.
·     Config 4.
Base
Activate SST-BF
Select Enabled or Disabled to enable or disable Speed Select Technology- Base Frequency (SST-BF).
SST-BF improves the base frequency of cores for high-priority workloads and reducing the base frequency of cores for low-priority workloads, which improves the overall performance.
Disabled
Configure SST-BF
Select whether to enable the BIOS to configure SST-BF settings.
Options:
·     EnabledEnables the BIOS to configure SST-BF high priority cores.
·     Disabled.
Enabled
Config TDP Lock
Select Enabled or Disabled to enable or disable Thermal Design Power (TDP) lock for the processor.
Enabled
EIST PSD Function
Set the method for EIST to automatically adjust processor voltage and core frequency to reduce power consumption and help heat dissipation.
Options:
·     HW_ALL—Specifies all the hardware.
·     SW_ALL—Specifies all the software.
HW_ALL
Boot performance mode
Set the boot performance state for BIOS before the OS takes over.
Options:
·     Max Performance.
·     Max Efficient.
·     Set by Intel Node Manager.
Max Performance
Energy Efficient Turbo
Select Enabled or Disabled to enable or disable energy efficient Turbo mode.
Enabled
Turbo Mode
Select Enabled or Disabled to enable or disable the Turbo mode.
Enabled
CPU Flex Ratio Override
Select Enabled or Disabled to enable or disable setting processor flex ratio.
Disabled
CPU Core Flex Ratio
This item is configurable only when CPU Flex Ratio Override is set to Enabled.
Set the processor core ratio multiplier, in the range of 0 to 100, to limit the maximum operating frequency of a processor. For example, if the multiplier is 32, the maximum operating frequency is 3200 MHz.
If Turbo is disabled, the maximum operating frequency of a processor will not exceed the limit.
23
Hardware PM State Control submenu
Figure 81 shows the Hardware PM State Control submenu screen. The submenu items are described in Table 31.
Figure 81 Hardware PM State Control submenu screen
Table 31 Items on the Hardware PM State Control submenu screen
Item
Hardware P-States
Set the mode for selecting the hardware P-states.
Options:
·     DisabledDisables the hardware P-state feature.
·     Native ModeAllows direct register access from the OS for CPU configuration. Both the legacy ACPI table (_pct\pss\ppc) and new ACPI specification (_CPC V2) are supported.
·     Out of Band ModeAllows only out-of-band management by using BMC. In this mode, you cannot access the hardware P-state register from the OS.
·     Native Mode with No Legacy SupportThis mode is the same as the native mode except for support of the new ACPI specification (_CPC V2).
Native Mode
EPP Enable
This item is unconfigurable when Hardware P-States is set to Disabled.
Select Enabled or Disabled to enable or disable ENERGY_PERFORMANCE_PREFERENCE (EPP).
If this feature is disabled, the system uses ENEGY_PERF_BIAS (EPB).
Enabled
EPP profile
Set the EPP mode.
Options:
·     PerformanceProvides maximum system performance at the expense of energy efficiency.
·     Balanced PerformanceProvides optimum performance with good energy efficiency.
·     Balanced PowerProvides optimum power efficiency with good performance.
·     PowerProvides maximum power efficiency (maximum power saving) at the expense of system performance.
CPU C State Control submenu
Figure 82 shows the CPU C State Control submenu screen. The submenu items are described in Table 32.
Figure 82 CPU C State Control submenu screen
Table 32 Items on the CPU C State Control submenu screen
Item
Enable Monitor MWAIT
Select Enabled or Disabled to enable or disable Monitor/Mwait instructions.
Enabling Monitor/Mwait instructions optimizes processor instruction execution.
To disable CPU C state, you must also disable Monitor MWAIT for some operating systems.
If Enhanced vMotion Compatibility (EVC) errors occur during VM adding to a cluster or VM service migration, enable this feature.
Enabled
CPU C1 auto demotion
Select whether to enable processors to automatically demote to C1.
Options:
·     EnabledEnables processors to automatically demote to C1.
·     DisabledDisables processors from automatically demoting to C1.
Disabled
CPU C1 auto undemotion
Select whether to enable processors to automatically undemote from C1.
Options:
·     EnabledEnables processors to automatically undemote from C1.
·     Disabled—Disables processors from automatically undemoting from C1.
Enabled
CPU C6 Report
Select whether to enable the BIOS to report the C6 state to the operating system.
Options:
·     Enabled—Enables the BIOS to report the C6 state to the operating system.
·     Disabled—Disables the BIOS from reporting the C6 state to the operating system.
·     Auto—Enables the BIOS to report the C6 state to the operating system by default.
Disabled
Enhanced Halt State (C1E)
Select Enabled or Disabled to enable or disable the C1E feature.
C1E feature enables a processor to operate at the minimum performance state in idle time to reduce power consumption.
The C1E configuration takes effect after the server restarts.
Disabled
OS ACPI Cx
Select the ACPI to which the system reports C3/C6.
Options:
·     ACPI C2.
·     ACPI C3.
ACPI C2
Package C State Control submenu
Figure 83 shows the Package C State Control submenu screen. The submenu items are described in Table 33.
Figure 83 Package C State Control submenu screen
Table 33 Items on the Package C State Control submenu screen
Item
Package C State
Select the package C state limit.
Options:
·     C0/C1 state.
·     C2 state.
·     C6 (non Retention)state.
·     C6 (Retention) state.
·     No Limit.
·     Auto.
C0/C1 state
Dynamic L1
Select Enabled or Disabled to enable or disable the dynamic L1.
Enabled
C2C3TT
Set the C2 status to C3 status event counter, in µs.
Setting the value to 0 enables the BIOS to set the counter automatically.
0
PKG C-state Lat. Neg.
Select Enabled or Disabled to enable or disable the package C-state latency negotiation feature.
CPU Thermal Management submenu
Figure 84 shows the CPU Thermal Management submenu screen. The submenu items are described in Table 34.
Figure 84 CPU Thermal Management submenu screen
Table 34 Items on the CPU Thermal Management submenu screen
Item
CPU T State Control
CPU T-state control submenu, as shown in Figure 85.
The submenu items are described in Table 35.
N/A
Thermal Monitor
Select Enabled or Disabled to enable or disable processor temperature monitoring.
Enabled
CPU T State Control submenu
Figure 85 shows the CPU T State Control submenu screen. The submenu items are described in Table 35.
Figure 85 CPU T State Control submenu screen
Table 35 Items on the CPU T State Control submenu screen
Item
Software Controlled T-State
Select Enabled or Disabled to enable or disable software controlled T-state.
Disabled
T-State Throttle Level
This item is available only when Software Controlled T-State is set to Enabled.
Select the T-state throttle level.
Options:
·     DisabledDisables T-state throttling.
·     6.25%.
·     12.5%.
·     18.75%.
·     25.0%.
·     31.25%.
·     37.5%.
·     43.75%.
·     50.0%.
·     56.25%.
·     62.5%.
·     68.75%.
·     75.0%.
·     81.25%.
·     87.5%.
·     93.75%.
Disabled
CPU Advanced PM Tuning submenu
Figure 86 shows the CPU Advanced PM Tuning submenu screen. The submenu items are described in Table 36.
Figure 86 CPU Advanced PM Tuning submenu screen
Table 36 Items on the CPU Advanced PM Tuning submenu screen
Item
Uncore Freq Scaling
Select whether to enable uncore frequency scaling.
Options include:
·     DisabledDisables uncore frequency scaling. When this feature is disabled, you can set the uncore frequency.
·     EnabledEnables uncore frequency scaling. This feature allocates power resources across cores and uncores to maximize the server performance without wasting power.
Disabled
Current Uncore Ratio Range
Set the current uncore ratio range.
This item is available only when Uncore Freq Scaling is set to Disabled.
N/A
Uncore Freq
Set the uncore frequency.
127
Uncore Freq RAPL
Select whether to enable the uncore frequency run-time average power limit (RAPL).
Options include:
·     Disabled.
·     Enabled.
Enabled
Energy Perf BIAS
Energy and performance bias configuration submenu, on which you can configure the energy and performance policy for the system, as shown in Figure 87.
The submenu items are described in Table 37.
Energy Perf BIAS submenu
Figure 87 shows the Energy Perf BIAS submenu screen. The submenu items are described in Table 37.
Figure 87 Energy Perf BIAS submenu screen
Table 37 Items on the Energy Perf BIAS submenu screen
Item
Power Performance Tuning
This item is inaccessible when Hardware P-States is set to Out of Band Mode.
Select the method to control energy and performance bias tuning.
Options:
·     OS Controls EPBThis option is not available when Hardware P-States is set to Out of Band Mode or Native Mode with No Legacy Support.
·     BIOS Controls EPB.
·     PECI Controls EPBThis option is not available for the R6900 G5. For other servers, this option is the default when Hardware P-States is set to Out of Band Mode.
BIOS Controls EPB
PECI PCS EPB
This item is unconfigurable when Hardware P-States is set to Out of Band Mode or Power Performance Tuning is set to BIOS Controls EPB.
Select whether to authorize PECI with the control over EPB.
Options:
·     OS controls EPB—Enables the operating system to control EPB.
·     PECI controls EPB using PCS—Enables PECI to control EPB by using packet config space (PCS).
OS controls EPB
ENERGY_PERF_BIAS_CFG Mode
This item is available only when Energy Performance Tuning is set to BIOS Controls EPB.
Select an energy and performance bias option. The setting for this option overrides the energy and performance bias configured by the operating system.
Options:
·     PerformanceProvides maximum system performance (maximum cooling) at the expense of energy efficiency.
Performance
Workload Configuration
Select the workload option.
Options:
·     BalancedBalances the performance.
·     I/O sensitive—Keeps I/O sensitive.
Balanced
Memory Power & Thermal Configuration submenu
Figure 88 shows the Memory Power & Thermal Configuration submenu screen for the R6900 G5. The submenu items are described in Table 38.
Figure 88 Memory Power & Thermal Configuration submenu screen ( for the R6900 G5)
Table 38 Items on the Memory Power & Thermal Configuration submenu screen ( for the R6900 G5)
Item
Memory Thermal
Configure memory thermal settings.
N/A
MEMHOT Throttling Mode
Configure the MEMHOT I/O settings.
Options:
·     Disabled—Disables the MEMHOT I/O mode.
·     Output-Only—Enables the output mode only.
·     Input-Only—Enables the input mode only.
·     Input and Output Enabled—Enables both the output mode and input mode.
Disabled
Memory Power Saving Advanced Options
Set the advanced memory power saving settings.
N/A
Figure 89 shows the Memory Power & Thermal Configuration submenu screen for the B5700, R4300, R4700, R4900, R5300, and R5500 G5. The submenu items are described in Table 39.
Figure 89 Memory Power & Thermal Configuration submenu screen (for the B5700, R4300, R4700, R4900, R5300, and R5500 G5)
Table 39 Items on the Memory Power & Thermal Configuration submenu screen (for the B5700, R4300, R4700, R4900, R5300, and R5500 G5)
Item
Memory Thermal
N/A
Configure the MEMHOT I/O mode.
Options:
·     EnabledEnables the MEMHOT I/O mode.
Enabled
MemHot Input Pin
Select Enabled or Disabled to enable or disable the MEMHOT input pin.
Enabled
MemHot Output Pin
Select Enabled or Disabled to enable or disable the MEMHOT output pin.
Enabled
MEMHOT Output Throttling Mode Options
Set the MEMHOT output throttling mode option.
Options:
·     DisabledDisables the MEMHOT output throttling mode.
·     Enabled only tempiEnables the MEMHOT output throttling mode only for high bit fields.
·     Enabled only tempi & midEnables the MEMHOT output throttling mode only for high and middle bit fields.
·     Enabled only tempi, mid and lowEnables the MEMHOT output throttling mode for high, middle, and low bit fields
Enabled only tempi
N/A
Figure 90 shows the Memory Thermal submenu screen. The submenu items are described in Table 40.
Figure 90 Memory Thermal submenu screen
Table 40 Items on the Memory Thermal submenu screen
Item
Throttling Mode
Set the throttling mode.
Options:
·     Disabled—Disables the throttling mode.
·     OLTT—Enables OLTT to allow MRC to set a temperature threshold for thermal throttling.
·     CLTTEnables CLTT to allow thermal throttling based on the memory TSOD temperature.
·     CLTT with PECIEnables CLTT with PECI for thermal throttling.
CLTT
OFF PKG MEM TO MEMTRIP
Select whether to add the offpkg memtrip to the MEMtrip tree.
Options:
·     DisabledIgnores the offpkg memtrip.
·     EnabledAdds the offpkg memtrip to the memtrip tree.
Disabled
Figure 91 shows the Memory Power Saving Advanced Options submenu screen. The submenu items are described in Table 41.
Figure 91 Memory Power Saving Advanced Options submenu screen
Table 41 Items on the Memory Power Saving Advanced Options submenu screen
Item
CKE Throttling
Set the Clock Enable (CKE) throttling mode. If CKE is disabled, the internal DDR clock is disabled and DDR power consumption decreases.
Options:
·     AutoEnables the CPU to set the CKE throttling mode automatically.
·     Manual—Sets the throttling mode manually.
Auto
CKE Feature
This item is available only when CKE Throttling is set to Manual.
Submenu for configuring the CKE feature.
N/A
Figure 92 shows the CKE Feature submenu screen. The submenu items are described in Table 42.
Figure 92 CKE Feature submenu screen
Table 42 Items on the CKE Feature submenu screen
Item
CKE Idle Timer
Displays the CKE idle timer, in ns.
As a best practice, set a value larger than 20.
20ns
APD
Select Enabled or Disabled to enable or disable active power down (APD). With APD enabled, the system retains pages opened in DDR, which minimizes power saving performance.
Disabled
PPD
Select Enabled or Disabled to enable or disable pre-charged power-down (PPD).
This mode is entered if all banks in DDR are pre-charged when de-asserting CKE. Power-saving in this mode is intermediate.
Enabled
Platform Configuration submenu
As shown in Figure 93, the Platform Configuration menu contains the submenus described in Table 43.
Figure 93 Platform Configuration menu screen
Table 43 Items on the Platform Configuration menu screen
Item
PCH Configuration
Submenu for configuring the platform controller hub (PCH).
Miscellaneous Configuration
Submenu for configuring miscellaneous settings, including video display device and debug mode settings.
Server ME Configuration
Submenu for configuring the server management engine (ME).
Runtime Error Logging
Submenu for configuring runtime error logging.
PCH Configuration submenu
Figure 94 shows the PCH Configuration submenu screen, on which you can configure PCH settings as described in Table 44.
Figure 94 PCH Configuration submenu screen
Table 44 Items on the PCH Configuration submenu screen
Item
PCH SATA Configuration
Submenu for configuring PCH SATA settings, as shown in Figure 95, and Figure 96.
The submenu menu items are described in Table 45.
This submenu is not available for the B5700 G5.
PCH sSATA Configuration
Submenu for configuring PCH sSATA settings, as shown in Figure 97 and Figure 98.
The submenu menu items are described in Table 46 and Table 47.
Chipset USB Configuration
Submenu for configuring USB, as shown in Figure 99.
The submenu menu items are described in Table 48.
PCH SATA Configuration submenu
Figure 95 and Figure 96 show the PCH SATA Configuration submenu screen. The submenu items are described in Table 45.
Figure 95 PCH SATA Configuration submenu screen (1)
Figure 96 PCH SATA Configuration submenu screen (2)
Table 45 Items on the PCH SATA Configuration submenu screen
Item
SATA Controller
Select Enabled or Disabled to enable or disable the SATA controller.
Enabled
Configure SATA As
Select the operating mode of the SATA controller.
Options:
·     AHCI—Uses the AHCI mode, which allows the drives attached to the SATA ports to be used as SATA disks. This mode supports hot swapping of drives. To use this mode, a SATA driver must be installed.
·     RAID—Uses the RAID mode, which allows creation of a logical drive from multiple independent physical drives. To configure the embedded RSTe RAID controller, select this option.
AHCI
SATA Test Mode
Select Enabled or Disabled to enable or disable SATA test mode.
Disabled
SATA Port N
Displays the name and slot number of the drive connected to logic PCH SATA port N. If no drive is connected, Not Installed is displayed. The number of SATA ports varies by server model. Usually there are 0 to 7 ports.
N/A
Port N
Select Enabled or Disabled to enable or disable the drive connected to SATA port N.
Enabled
PCH sSATA Configuration submenu
Figure 97 and Figure 98 show the PCH sSATA Configuration submenu screen. The submenu items are described in Table 46.
Figure 97 PCH sSATA Configuration submenu screen (1)
Figure 98 PCH sSATA Configuration submenu screen (2)
Table 46 Items on the PCH sSATA Configuration submenu screen
Item
sSATA Controller
Select Enabled or Disabled to enable or disable the sSATA controller.
Enabled
Configure sSATA As
Select the operating mode of the drive controller.
Options:
AHCI
sSATA Test Mode
Select Enabled or Disabled to enable or disable sSATA test mode.
Disabled
sSATA Port N
Displays the name and the slot number of the drive connected to logic PCH sSATA port N. If no drive is connected, Not Installed is displayed.
The number of sSATA ports varies by server model. For more information, see Table 47.
N/A
Port N
Select Enabled or Disabled to enable or disable the drive connected to sSATA port N.
Enabled
Table 47 sSATA output ports available for each server model
Server model
sSATA output ports
R4300 G5
Ports 0 through 5
R4700 G5
Ports 0 through 5
R4900 G5
Ports 0 through 5
R5300 G5
Ports 0 to 1
R5500 G5 Intel
Ports 0 to 1
R6900 G5
Ports 0 to 1
B5700 G5
Ports 0 through 3
Chipset USB Configuration submenu
Figure 99 shows the Chipset USB Configuration submenu screen. The submenu items are described in Table 48.
The number of USB ports and installation locations for USB ports are different for each server model. The Chipset USB Configuration submenu screen varies by server model.
Figure 99 Chipset USB Configuration submenu screen
Table 48 Items on the Chipset USB Configuration submenu screen
Parameter
USB Per-Connector Disable
Enable or disable independent control of individual USB connectors on the system board. If the USB port is disabled, a USB device inserted into this port cannot be detected by the BIOS or the operating system.
Options:
·     Enabled—You can control USB connectors on a per-connector basis.
·     Disabled—You cannot control USB connectors on a per-connector basis.
Disabled
One key to enable USB All-Connectors
Enable all USB connectors.
This item is available only when USB Per-Connector Disable is set to Enabled.
N/A
One key to disable USB All-Connectors
Disable all USB connectors.
N/A
Miscellaneous Configuration submenu
Figure 100 shows the Miscellaneous Configuration submenu screen, on which you can configure features described in Table 49.
Figure 100 Miscellaneous Configuration submenu screen
Table 49 Items on the Miscellaneous Configuration submenu screen
Item
Active Video
Select a monitor to display videos.
Options:
·     Auto—Enables the server to automatically select a monitor to display videos.
·     Onboard Device—Uses the monitor connected to the onboard VGA connector to display videos.
·     PCIe Device—Uses the monitor connected to the GPU module in the PCIe slot to display videos.
In legacy boot mode, the server cannot display the BIOS menus on the monitor connected to the GPU module or VGA connector if the Onboard Device or PCIe Device option is selected, respectively.
Onboard Device
Server ME Configuration submenu
Figure 101 and Figure 102 show the Server ME Configuration submenu screen, on which you can view server management engine information described in Table 50.
Figure 101 Server ME Configuration submenu screen (1)
Figure 102 Server ME Configuration submenu screen (2)
Table 50 Items on the Server ME Configuration submenu screen
Item
Oper. Firmware Version
Displays the active firmware version.
N/A
Backup Firmware Version
Displays the backup firmware version.
N/A
Recovery Firmware Version
Displays the recovery firmware version.
N/A
ME Firmware Status #1
Displays ME firmware status #1.
N/A
ME Firmware Status #2
Displays ME firmware status #2.
N/A
Current State
Displays the current ME state.
N/A
Error Code
Displays the error code.
N/A
Recovery Cause
Displays the reason for recovery.
N/A
PTT Support
Displays support for the Platform Trusted Technology (PTT).
N/A
Suppress PTT Commands
Displays the suppressed PTT commands.
N/A
Altitude
Set the altitude at which the server is located, a hexadecimal value in meters. The default is 8000 meters (or 26246.72 ft).
8000
Enable MCTP Proxy
Select Enabled or Disabled to enable or disable MCTP proxy.
Enabled
Runtime Error Logging submenu
Figure 103 and Figure 104 show the Runtime Error Logging submenu screen, on which you can configure the runtime error logging as described in Table 51.
Figure 103 Runtime Error Logging submenu screen (1)
Figure 104 Runtime Error Logging submenu screen (2)
Table 51 Items on the Runtime Error Logging submenu screen
Item
System Errors
This item controls system error logging, which enables the server to correct system errors automatically and report uncorrectable errors to HDM and the operating system.
Select Enabled or Disabled to enable or disable system error logging.
Enabled
S/W Error Injection Support
This item is available only when System Errors is set to Enabled.
Software error injection tests system performance by injecting software errors.
To test system performance, select Enabled.
Disabled
RAS Log Level
Display the RAS log level.
Options:
·     None.
·     MIN (BASIC_FLOW).
·     MID (BASIC_FLOW, FUNC_FLOW).
·     MAX (BASIC_FLOW, FUNC_FLOW, REG).
MIN (BASIC_FLOW)
System Memory Poison
Select Enabled or Disabled to enable or disable system memory poison.
To report event logs to HDM when uncorrectable memory errors are injected, you must set both System Memory Poison and Viral Status to Disabled.
Enabled
Viral Status
Select Enabled or Disabled to enable or disable detection of memory-resident viruses.
Disabled
Clear Viral Status
This item is unavailable when Viral Status or System Errors is set to Disabled.
Select Enabled or Disabled to enable or disable the clear viral status feature.
Disabled
Cloak Devhide registers from being accessible from OS
Select Enabled or Disabled to enable or disable access to the Cloak Devhide register from OS.
Disabled
System Cloaking
System cloaking enables the operating system and software to block corrected errors and uncorrected no action required (UCNA) errors.
Select Enabled or Disabled to enable or disable system cloaking.
Enabled
UboxToPcuMca Enabling
This item is not configurable.
Select Enabled or Disabled to enable or disable the server to report Ubox errors to Machine Check Architecture (MCA).
Enabled
FatalErrDebugHalt
This item is available only when System Errors is set to Enabled, and this feature is applicable only to McBank fatal error debugging.
Select Enabled or Disabled to enable or disable halting fatal error debugging. Enable this feature only in conjunction with Intel® Technology Provider (ITP) because a thread will halt in fatal error flow.
Disabled
Mca Bank Warm Boot Clear Errors
Select Enabled or Disabled to set whether to clear error information during MCA hot reboot.
Enabled
Shutdown Suppression
Set the shutdown suppression and log MCA IERR support.
Options:
·     DisabledDisables shutdown suppression.
·     Shutdown Suppression and Log MCA IERREnables shutdown suppression and logs MCA IERR errors.
·     Shutdown Log MCA IERRDisables shutdown suppression and logs MCA IERR errors.
Shutdown Sippression and Log MCA IERR
eMCA Settings
Access the submenu for configuring the Enhanced Machine Check Architecture (eMCA), as shown in Figure 105 and Figure 106.
The submenu items are described in Table 52.
N/A
Whea Settings
Access the submenu for configuring the Windows Hardware Error Architecture (WHEA), as shown in Figure 107.
The submenu items are described in Table 53.
N/A
Error Injection Settings
Access the submenu for configuring error injection settings, as shown in Figure 108.
The submenu items are described in Table 54.
N/A
UPI Error Enabling
This item is configurable only when the processors support the Advanced RAS feature.
Access the submenu for configuring UltraPath Interconnect (UPI) error reporting, as shown in Figure 109.
The submenu items are described in Table 55.
N/A
Memory Error Enabling
Access the submenu for configuring memory error reporting, as shown in Figure 110 and Figure 111.
The submenu items are described in Table 56.
N/A
IIO Error Enabling
Access the submenu for configuring Integrated I/O module (IIO) error reporting, as shown in Figure 112, Figure 113, Figure 114, and Figure 115.
The submenu items are described in Table 57.
N/A
PCIe Error Enabling
Access the submenu for configuring PCIe error reporting, as shown in Figure 116, Figure 117, and Figure 118.
The submenu items are described in Table 58.
N/A
Error Control Setting
Access the submenu for configuring error control settings, as shown in Table 58Figure 119.
The submenu items are described in Table 59.
This submenu is not available for the R6900 G5.
N/A
eMCA Settings submenu
Figure 105 and Figure 106 show the eMCA Settings submenu screen. The submenu items are described in Table 52.
Figure 105 eMCA Settings submenu screen (1)
Figure 106 eMCA Settings submenu screen (2)
Table 52 Items on the eMCA Settings submenu screen
Item
EMCA Logging Support
Select Enabled or Disabled to enable or disable eMCA logging.
eMCA logging provides MAC error reports for the server.
Enabled
LMCE Support
Select Enabled or Disabled to enable or disable local machine check exceptions (LMCE) support.
This feature enables the system to report uncorrectable errors of the Software Recoverable Action Required (SRAR) type only to affected logical processors.
Enabled
Ignore OS EMCA Opt-in
This item is available only when EMCA Logging Support is set to Enabled.
Select Enabled or Disabled to enable or disable the ignore OS EMCA opt-in feature.
Disabled
EMCA CMCI-SMI Morphing
When EMCA CMCI-SMI morphing is enabled:
·     An SMI is triggered each time a correctable error occurs.
·     If the number of correctable errors on the MCBank exceeds the upper limit, an SMI is triggered but a Corrected Machine Check Interrupt (CMCI) is not.
Options:
·     EMCA gen 2 CSMI—Enables EMCA CMCI-SMI morphing in EMCA gen 2 CSMI mode.
·     Disabled—Disables EMCA CMCI-SMI morphing.
EMCA gen 2 CSMI
EMCA CMCI-SMI Threshold
Set the CMCI-SMI threshold for eMCA reported correctable errors.
2000
CSMI Dynamic Disable
Set the CSMI dynamic settings.
Options:
·     EnabledEnables the system to disable CSMI when the number of errors reaches the threshold.
·     DisabledForbids the system from disabling CSMI. With this feature disabled, CSMI is always enabled.
Enabled
EMCA MCE-SMI Enable
Options:
·     EMCA gen 2 – MSMI—Enables EMCA MCE-SMI in EMCA gen 2 MSMI mode.
·     Disabled—Disables EMCA MCE-SMI.
EMCA gen 2 – MSMI
Corrected Error eLog
Select Enabled or Disabled to enable or disable eMCA correctable error logging.
Enabled
Memory Error eLog
Select Enabled or Disabled to enable or disable eMCA memory error logging.
Enabled
Processor Error eLog
Select Enabled or Disabled to enable or disable eMCA processor error logging.
Enabled
Ubox Error Mask
Select Enabled or Disabled to enable or disable SMI used for Ubox error trigger.
Disabled
Whea Settings submenu
Figure 107 shows the Whea Settings submenu screen. The submenu items are described in Table 53.
Figure 107 Whea Settings submenu screen
Table 53 Items on the Whea Settings submenu screen
Item
WHEA Support
Select Enabled or Disabled to enable or disable WHEA.
WHEA provides hardware error reports for the server.
Enabled
Whea Log Memory Error
Select Enabled or Disabled to enable or disable WHEA memory error logging.
Enabled
Whea Log Processor Error
Select Enabled or Disabled to enable or disable WHEA processor error logging.
Enabled
Whea Log PCI Error
Select Enabled or Disabled to enable or disable WHEA PCI error logging.
Enabled
Error Injection Settings submenu
Figure 108 shows the Error Injection Settings submenu screen. The submenu items are described in Table 54.
Figure 108 Error Injection Settings submenu screen
Table 54 Items on the Error Injection Settings submenu screen
Item
Mca Bank Error Injection Support
Select Enabled or Disabled to enable or disable MCA bank error injection.
If MCA bank error injection is enabled, the write function of the register into which errors are injected is enabled.
Disabled
PMem Error Injection
Select Enabled or Disabled to enable or disable the PMem error injection.
Disabled
WHEA Error Injection Support
Select Enabled or Disabled to enable or disable WHEA error injection.
Disabled
WHEA Error Injection 5.0 Extension
This item is available only when WHEA Error Injection Support is set to Enabled.
Select Enabled or Disabled to enable or disable support for WHEA error injection 5.0 extension.
Enabled
Whea PCIE Error Injection Support
Select Enabled or Disabled to enable or disable WHEA PCIe error injection.
Disabled
Whea PCIe Error Injection Action Table
Select Enabled or Disabled to enable or disable WHEA PCIe error injection action table.
Disabled
SGX Memory Error Inject Support
Select Enabled or Disabled to enable or disable SGX memory error injection.
Disabled
UPI Error Enabling submenu
Figure 109 shows the UPI Error Enabling submenu screen. The submenu items are described in Table 55.
Figure 109 UPI Error Enabling submenu screen
Table 55 Items on the UPI Error Enabling submenu screen
Item
SMI UPI Lane Failover
Select Enabled or Disabled to enable or disable triggering an SMI upon a UPI lane failover.
Disabled
Memory Error Enabling submenu
Figure 110 and Figure 111 show the Memory Error Enabling submenu screen. The submenu items are described in Table 56.
Figure 110 Memory Error Enabling submenu screen (1)
Figure 111 Memory Error Enabling submenu screen (2)
Table 56 Items on the Memory Error Enabling submenu screen
Item
Memory Error
Select Enabled or Disabled to enable or disable memory error reporting.
Enabled
Memory Corrected Error
This item is available only when Memory Corrected Error is set to Enabled.
Select Enabled or Disabled to enable or disable correctable memory error reporting.
Enabled
Spare Interrupt
Select the type of the spare interrupt to generate upon detection of a memory error.
Options:
·     Disabled—Disables spare interrupt generation.
·     SMI—Generates an SMI interrupt.
·     Error Pin—Generates an error pin interrupt.
·     CMCI—Generates a CMCI interrupt.
SMI
Memory CE Storm Threshold
Set the memory correctable error storm threshold.
Options:
·     Disabled.
·     120.
·     60.
·     240.
·     1200.
Disabled
Memory CE Accumulation Threshold
Set the memory correctable error accumulation threshold.
Options:
·     Disabled.
·     1200.
·     1.
·     500.
·     1000.
·     2000.
·     5000.
·     10000.
Disabled
PMem CTLR Errors
Select Enabled or Disabled to enable or disable NVMCTLR error logging and reporting.
Enabled
PMem CTLR Low Priority Error Signaling
Set NVMCTLR low priority error signaling.
Options:
·     Disabled—Disables reporting of NVMCTLR low priority errors.
·     SMI—Uses SMI interrupts to send NVMCTLR low priority error signals.
·     ERRO# Pin—Uses ERRO# Pin to send NVMCTLR low priority error signals.
SMI
PMem CTLR High Priority Error Signaling
Set NVMCTLR high priority error signaling configuration.
Options:
·     Disabled—Disables reporting of NVMCTLR high priority errors.
·     SMI—Uses SMI interrupts to send NVMCTLR high priority error signals.
·     ERRO# Pin—Uses ERRO# Pin to send NVMCTLR high priority error signals.
SMI
Set PMem Address Range Scrub
Select Enabled or Disabled to enable or disable NGN DIMM physical address range scrubbing.
Disabled
Set PMem Host Alert Policy for Patrol Scrub
This item is configurable only when the processors support the Advanced RAS feature. This item is available only when Memory Corrected Error is set to Enabled.
Select Enabled or Disabled to enable or disable the patrol scrubbing error alert policy. With the policy enabled, the system triggers DDRT interrupts based on uncorrectable errors detected by NGN patrol scrubbing.
Enabled
Enable Reporting SPA to OS
Select Enabled or Disabled to enable or disable system physical address (SPA) reporting to the operating system.
If the reporting is enabled, the MCE recovery threshold is disabled.
Enabled
PMem UNC Poison
Select whether to enable the poison mode for PMem.
Options:
·     EnabledWhen an uncorrectable error is detected in an PMem, the memory marks the abnormal data as poison and then continues to transmit the data.
·     DisabledWhen an uncorrectable error is detected in a PMem, the memory directly reports the error.
Enabled
Set PMem Host Alert Policy for DPA Error
Set the PMem memory DIMM physical address (DPA) error system alarm policy.
Options:
·     Poison—Poison mode.
·     Viral—Virus mode.
Poison
IIO Error Enabling submenu
Figure 112, Figure 113, Figure 114, and Figure 115 show the IIO Error Enabling submenu screen. The submenu items are described in Table 57.
Figure 112 IIO Error Enabling submenu screen (1)
Figure 113 IIO Error Enabling submenu screen (2)
Figure 114 IIO Error Enabling submenu screen (3)
Figure 115 IIO Error Enabling submenu screen (4)
Table 57 Items on the IIO Error Enable submenu screen
Item
IIO/PCH Global Error Support
Select Enabled or Disabled to enable or disable IIO/PCH global error reporting.
Enabled
Os Native AER Support
Select Enabled or Disabled to enable or disable the AER feature on the OS.
Disabled
IIO MCA Support
Select Enabled or Disabled to enable or disable IIO MCA support.
Disabled
Clear PCC for IIO Non-Fatal Error
This item is available only when IIO MCA Support is set to Enabled.
Select Enabled or Disabled to set whether to clear the PCC register if an IIO non-fatal error occurs.
Disabled
IIO Error Pin0 Enable
This item is available only when IIO MCA Support is set to Disabled.
Select Enabled or Disabled to enable or disable IIO Error Pin programming.
Disabled
IIO OOB Mode
Select Enabled or Disabled to set whether to generate system events when ERROR Pin is enabled.
Enabled
IIO Error Registers Clear
Select Enabled or Disabled to enable or disable clearing IIO error registers.
Enabled
IIO eDPC Support
Set the IIO eDPC support.
Options:
·     DisabledDisables IIO eDPC support.
·     On Fatal ErrorEnables IIO eDPC support when a fatal error occurs.
·     On Fatal and Non-Fatal ErrorsEnables IIO eDPC support when a fatal or non-fatal error occurs.
Disabled
IIO eDPC Interrupt
This item is configurable only when IIO eDPC Support is not set to Disabled.
Select Enabled or Disabled to enable or disable IIO eDPC interrupt.
Enabled
IIO eDPC ERR_COR Message
Select Enabled or Disabled to enable or disable the use of IIO eDPC error COR messages.
Enabled
IIO LER Support
This item is available only for the R6900 G5.
Select Enabled or Disabled to enable or disable IIO live error recovery.
Disabled
IIO Coherent Interface Error
Select Enabled or Disabled to enable or disable IIO coherent interface error detection.
Enabled
IIO IRP0 protocol parity error
This item is unconfigurable when IIO Coherent Interface Error is set to Disabled.
Select Enabled or Disabled to enable or disable IIO IRP0 protocol parity error detection.
Enabled
IIO IRP0 protocol qt overflow underflow error
Select Enabled or Disabled to enable or disable the IIO coherent interface protocol layer queue table overflow or underflow error reporting.
Enabled
IIO IRP0 protocol rcvd unexprsp
Select Enabled or Disabled to enable or disable error detection on poisoned packets received at the IIO coherent interface protocol layer.
Enabled
IIO IRP0 csr acc 32b unaligned
Select Enabled or Disabled to enable or disable reporting of 32-bit boundary crossing errors for IIO coherent interface CSR access.
Enabled
IIO IRP0 wrcache uncecccs0 error
Select Enabled or Disabled to enable or disable reporting of IIO coherent interface write cache uncorrectable ECC errors.
Enabled
IIO IRP0 wrcache uncecccs1 error
Enabled
IIO IRP0 protocol rcvd poison error
Select Enabled or Disabled to enable or disable reporting of poisoned packet errors received at the IIO coherent interface protocol layer.
Enabled
IIO IRP0 wrcache correcccs0 error
Select Enabled or Disabled to enable or disable reporting of IIO coherent interface write cache correctable ECC errors.
Enabled
IIO IRP0 wrcache correcccs1 error
Enabled
IIO Misc. Error
Select Enabled or Disabled to enable or disable miscellaneous IIO error detection.
Enabled
IIO Vtd Error
Select Enabled or Disabled to enable or disable IIO Vtd error detection.
Enabled
IIO Dma Error
Select Enabled or Disabled to enable or disable IIO DMA error detection.
Enabled
IIO Dmi Error
Select Enabled or Disabled to enable or disable IIO DMI error detection.
Disabled
PCIE Error
Select Enabled or Disabled to enable or disable PCIe error detection.
Enabled
IIO PCIE Additional Corrected error
Select Enabled or Disabled to enable or disable IIO PCIe additional correctable error detection.
Enabled
IIO PCIE Additional Uncorrected error
Select Enabled or Disabled to enable or disable IIO PCIe additional uncorrectable error detection.
Enabled
IIO PCIE Additional Received Completion with UR
Select Enabled or Disabled to enable or disable IIO PCIe additional received completion with UR.
Disabled
IIO PCIe AER Spec Compliant
Select Enabled or Disabled to enable or disable IIO PCIe Advanced Error Reporting (AER) specification compliance checking.
If this feature is enabled, poisoned errors are recorded as fatal errors. If this feature is disabled, poisoned errors are recorded as non-fatal errors.
Disabled
ITC/OTC CA/MA Errors
Select Enabled or Disabled to enable or disable complete abort and master abort errors on ITC and OTC.
Disabled
PSF UR Error
Select Enabled or Disabled to enable or disable unsupported request errors on PSF.
Enabled
PMSB Router Parity Error
Select Enabled or Disabled to enable or disable PMSB router parity errors.
Enabled
PCIe Error Enabling submenu
Figure 116, Figure 117, and Figure 118 show the PCIe Error Enabling submenu screen. The submenu items are described in Table 58.
Figure 116 PCIe Error Enabling submenu screen (1)
Figure 117 PCIe Error Enabling submenu screen (2)
Figure 118 PCIe Error Enabling submenu screen (3)
Table 58 Items on the PCIe Error Enabling submenu screen
Items
Corrected Error
Select Enabled or Disabled to enable or disable PCIe correctable error detection.
Enabled
Uncorrected Error
Select Enabled or Disabled to enable or disable PCIe uncorrectable error detection.
Enabled
Fatal Error Enable
Select Enabled or Disabled to enable or disable PCIe fatal error detection.
Enabled
PCIe Corrected Error Threshold Counter
Select Enabled or Disabled to enable or disable the PCIe correctable error threshold counter.
·     R6900 G5: Disabled
·     Other servers: Enabled
PCIE Correctable Error Threshold
This item is configurable only when PCIe Corrected Error Threshold Counter is set to Enabled.
Set the PCIe correctable error threshold.
·     R6900 G5: 1
·     Other servers: 0x1F40 (8000)
PCIe Corrected Error Limit Check
Select Enabled or Disabled to enable or disable the limit on PCIe correctable errors.
Disabled
This item is configurable only when PCIe Corrected Error Limit Check is set to Enabled.
Set the maximum number of PCIe correctable errors that can be reported.
Value range: 0 to 4294967295.
80
PCIE AER Corrected Errors
Select Enabled or Disabled to enable or disable PCIe AER correctable error detection.
Disabled
PCIE AER NonFatal Error
Select Enabled or Disabled to enable or disable PCIe AER non-fatal error detection.
Enabled
PCIE AER Fatal Error
Select Enabled or Disabled to enable or disable PCIe AER fatal error detection.
Enabled
PCIE AER Advisory Nonfatal Error
Select Enabled or Disabled to enable or disable PCIe AER advisory non-fatal error detection.
Disabled
PCIE ECRC Error
Select Enabled or Disabled to enable or disable PCIe endpoint cyclic redundancy check (ECRC).
Enabled
PCIE Unsupported Request Error
Select Enabled or Disabled to enable or disable PCIe unsupported request error detection.
Disabled
PCIE Surprise Link Down Error
Select Enabled or Disabled to enable or disable PCIe surprise link down error detection.
Disabled
PCIe CE Report
Select Enabled or Disabled to enable or disable reporting PCIe correctable errors to System Event Log (SEL).
Enabled
PCIe CE Storm Threshold
Set the PCIe correctable error storm threshold.
Options:
·     1The server can report only one PCIe correctable error each time.
·     40The server can report a maximum of 40 PCIe correctable errors each time.
1
Assert NMI on SERR
Select Enabled or Disabled to enable or disable the system to generate an NMI interrupt and record the error when a system error (SERR) occurs.
Enabled
Assert NMI on PERR
Select Enabled or Disabled to enable or disable the system to generate an NMI interrupt and record the error when a parity error (PERR) occurs.
Enabled
Leaky Bucket Feature
The following items are not available for the R6900 G5.
Expected BER
Set the expected bit error rate for all speeds.
34359738367
Time Window (Gen1/2)
Set the error burst protection time window for Gen1 and Gen2 speeds. A burst of errors within the window is recorded as one error.
65535
Time Window (Gen3/4)
Set the error burst protection time window for Gen3 and Gen4 speeds. A burst of errors within the window is recorded as one error.
65535
Error Threshold (Gen1/2)
Set the error threshold for Gen1 and Gen2 speeds. An event is triggered when the number of errors exceeds the threshold.
0
Error Threshold (Gen3/4)
Set the error threshold for Gen3 and Gen4 speeds. An event is triggered when the number of errors exceeds the threshold.
16
Gen3/4 Re-Equalization
Select Enabled or Disabled to enable or disable Gen3 and Gen4 re-equalization. This feature applies only when the PCIe devices are operating at Gen2 or Gen4 speeds. When an event is triggered, equalization will re-operate.
Enabled
Gen2 Link Degradation
Select Enabled or Disabled to enable or disable Gen2 link degraddation.
Enabled
Gen3 Link Degradation
Select Enabled or Disabled to enable or disable Gen3 link degraddation.
Enabled
Gen4 Link Degradation
Select Enabled or Disabled to enable or disable Gen4 link degraddation.
Enabled
Error Control Setting submenu
Figure 119 shows the Error Control Setting submenu screen. The submenu items are described in Table 59.
Figure 119 Error Control Setting submenu screen
Table 59 Items on the Error Control Setting submenu screen
Items
Patrol Scrub Error Reporting
Set the patrol scrub error type selection.
Options:
·     Correctable ErrorReports correctable errors.
·     UCNAReports UCNA errors.
Correctable Error
2LM Correctable Error Logging in m2mem
Select Enabled or Disabled to enable or disable 2LM correctable error logging in m2mem.
Enabled
Latch First Corrected Error in KTI
Select Enabled or Disabled to enable or disable latching first correctable error in KTI.
Enabled
Dynamic Device Configuration submenu
As shown in Figure 120, the Dynamic Device Configuration menu contains the submenus described in Table 60. You can configure network adapters, storage controllers, VROC, RSTE, and iSCSI settings from these submenus.
Figure 120 Dynamic Device Configuration submenu
Table 60 Items on the Dynamic Device Configuration menu screen
Item
iSCSI Configuration
Submenu for configuring iSCSI settings. This submenu is available only for the B5700/R5300/R5500 G5.
Intel(R) VROC sSATA Controller
Submenu for configuring Intel(R) VROC sSATA controller.
This submenu is available only when the sSATA mode is set to RAID in the PCH sSATA configuration.
Intel(R) VROC SATA Controller
Submenu for configuring Intel(R) VROC SATA controller.
This submenu is available only when the SATA mode is set to RAID in the PCH SATA configuration.
Intel(R) Virtual RAID on CPU
Submenu for configuring Intel(R) Virtual RAID on CPU (Intel VROC).
This submenu is available only when VMD is enabled.
Slot x: Port n - Mellanox Network Adapter-B08:59:9F:2E:7A:7C(example)
Submenu for configuring network adapters.
Slot 158: INTEL SSDPE2KX010T8-BTLJ742400SU1P0FGN(example)
Submenu for configuring NVMe devices. For more information, see "NVMe Configuration submenu."
The logical slot number of NVMe devices varies by server model. For more information, see the HDM screen.
iSCSI Configuration submenu (for the B5700, R5300, and R5500 G5)
Figure 121 shows the iSCSI Configuration submenu screen, on which you can configure iSCSI settings as described in Table 61.
Figure 121 iSCSI Configuration submenu screen
Table 61 Items on the iSCSI Configuration submenu screen
Item
Attempt Priority
Set the attempt priority.
Options:
·     Host AttemptSet the host with the highest priority.
·     Redfish AttemptSet Redfish with the highest priority.
Host Attempt
Host iSCSI Configuration
Submenu for configuring host iSCSI settings.
N/A
Figure 122 shows the Host iSCSI Configuration submenu screen. The submenu items are described in Table 62.
Figure 122 Host iSCSI Configuration
Table 62 Items on the Host iSCSI Configuration submenu screen
Item
iSCSI Initiator Name
Set the name of the iSCSI initiator. The name is a string of 4 to 223 characters.
The name must be in the IQN format of iqn.YYYY-MM.Domain name:Device name.
·     YYYY—Year.
·     MM—Month.
·     Domain name—Domain name in the reversed order.
·     Device name.
For example, iqn.2003-02.emu.com:test123.
Add an Attempt
Add an iSCSI attempt.
Delete Attempts
Delete an iSCSI attempt.
Change Attempt Order
Change the order of the attempts.
Add an Attempt submenu
Figure 123 shows the Add an Attempt submenu screen, on which all existing attempts are displayed. Each attempt is identified by the MAC address of an iSCSI Ethernet adapter port. The submenu items for each port are the same.
Figure 123 Add an Attempt submenu screen
Figure 124 shows the submenu for configuring an attempt. The submenu items are described in Table 63.
Figure 124 Attempt Configuration submenu screen
Table 63 Items on the Attempt Configuration submenu screen
Item
iSCSI Attempt Name
Set the name of the iSCSI attempt. The name is a case-sensitive string of 1 to 12 characters.
N/A
iSCSI Mode
Set the iSCSI mode.
Options:
·     Disabled—Disables iSCSI.
·     Enabled—Enables iSCSI.
·     Enabled for MPIO—Enables MPIO iSCSI.
Disabled
Internet Protocol
Select the Internet protocol.
Options:
·     IP4—Enables IPv4.
·     IP6—Enables IPv6.
·     Autoconfigure—Configures the Internet protocol automatically. IPv4 takes precedence over IPv6.
IP4
Connection Retry Count
Set the maximum number of connection retries.
Value range: 0 to 16.
A value of 0 indicates no connection retries.
N/A
Connection Establishing Timeout
Set the connection timeout time, in milliseconds.
1000
OUT-format ISID
Displays the ID of the iSCSI initiator.
N/A
Configure ISID
Configure the ID of the iSCSI initiator.
The last six bits in the MAC address of the Ethernet adapter port.
Enable DHCP
Select Enabled or Disabled to enable or disable DHCP.
Disabled
Initiator IP Address
Set the IP address of the iSCSI initiator.
N/A
Initiator Subnet Mask
Set the subnet mask of the iSCSI initiator.
N/A
Gateway
Set the gateway IP address.
N/A
Target Name
Set the name of the iSCSI target.
N/A
Target Address
N/A
Target Port
Set the port number of the iSCSI target.
3260
Boot LUN
Set the LUN of the iSCSI target, in hexadecimal notation.
N/A
Authentication Type
Select the authentication type.
Options:
·     None.
·     CHAP.
None
CHAP Type
Select the CHAP authentication type.
Options:
·     Mutual—The iSCSI target and iSCSI initiator authenticate each other.
·     One way—Only the iSCSI target authenticates the iSCSI initiator.
Mutual
CHAP Name
Set the name for CHAP authentication.
N/A
CHAP Secret
Set the password for CHAP authentication.
N/A
CHAP Status
Displays the status of CHAP authentication.
N/A
Reverse CHAP Name
Set the name for reverse CHAP authentication.
N/A
Reverse CHAP Secret
Set the password for reverse CHAP authentication.
N/A
Reverse CHAP Status
Displays the status of reverse CHAP authentication.
N/A
Save Changes
Save the changes.
N/A
Back to Previous Page
Return to the previous submenu.
N/A
Delete Attempts submenu
Figure 125 shows the Delete Attempts submenu screen. The items are described in Table 64.
Figure 125 Delete Attempts submenu screen
Table 64 Items on the Delete Attempts submenu screen
Item
Attempt x
Select the target attempts to delete.
Commit Changes and Exit
Commit the changes and return to the iSCSI Configuration submenu.
Discard Changes and Exit
Discard the changes and return to the iSCSI Configuration submenu.
Change Attempt Order submenu
Figure 126 shows the Change Attempt Order submenu screen. The items are described in Table 65.
Figure 126 Change Attempt Order submenu screen
Table 65 Items on the Change Attempt Order submenu screen
Item
Change the order of existing attempts.
Select an attempt and press + or key to change its order.
Intel(R) VROC SATA/sSATA Controller submenu
The submenus of Intel(R) VROC sSATA controller and Intel(R) VROC SATA controller are available only when the RAID mode is used in the PCH settings.
The submenu screens of Intel(R) VROC sSATA controller and Intel(R) VROC SATA controller are the same. The following uses the submenu screen of Intel(R) VROC SATA controller for example.
Figure 127 shows the Intel(R) VROC SATA Controller submenu screen. The submenu items are described in Table 66.
Figure 127 Intel(R) VROC SATA Controller submenu screen
Table 66 Items on the Intel(R) VROC SATA controller submenu screen
Item
Create RAID Volume
Open the submenu for creating a RAID volume.
This option is available only when more than two SATA or sSATA drives are connected to the port managed by the SATA or sSATA controller.
RAID Volumes
Displays the list of the created RAID volumes.
Volume0,RAID0(Stripe),424.77GB,Normal
Displays summary information about managed RAID volumes, including their volume name, RAID level, capacity, and state, for example, Volume0, RAID0 (Stripe), 424.77GB, Normal.
Non-RAID Physical Disks
Displays the list of the physical drives that have not been used to build RAID volumes.
Port 0,INTEL SSDSC2BB480G7 SN:PHDV702001YJ480BGN,447.14GB
Displays the information about non-RAID physical drives, including port number, physical drive name, serial number, and size.
Create RAID Volume submenu
Figure 128 and Figure 129 show the Create RAID Volume submenu screen. The submenu items are described in Table 67.
Figure 128 Create RAID Volume submenu screen (1)
Figure 129 Create RAID Volume submenu screen (2)
Table 67 Items on the Create RAID Volume submenu screen
Item
Create RAID volume
Name
Enter the name of the RAID volume.
Make sure the name does not contain backslashes (\) or spaces.
To avoid operation errors, make sure the name does not contain tildes (~), exclamation points (!), at signs (@), pound signs (#), forward slashes (/), or parentheses (()) as a best practice.
N/A
RAID Level
Select a RAID level.
Options:
·     RAID0(Stripe).
·     RAID1(Mirror).
·     RAID5(Parity)This option is available only when a minimum of three drives are present.
·     RAID10(RAID0+1)This option is available only when a minimum of four drives are present.
RAID0(Stripe)
Select Disks
All available drives, for example:
Select drives over which you want to create the RAID volume.
The selected drive is represented by the symbol X.
No drives are selected.
Stripe Size
Set the stripe size of the RAID volume.
N/A
Capacity(GB)
Displays the total capacity of the RAID volume, in GB.
N/A
Create Volume
Create a RAID volume.
To view information about the configured RAID volumes, select All Intel VMD Controllers.
N/A
Figure 130 Create Volume confirmation submenu screen
RAID VOLUME INFO submenu
Figure 131 and Figure 132 show the RAID VOLUME INFO submenu screen. The submenu items are described in Table 68.
Figure 131 RAID VOLUME INFO submenu screen (1)
Figure 132 RAID VOLUME INFO submenu screen (2)
Table 68 Items on the RAID VOLUME INFO submenu screen
Item
Volume Actions
Delete
CAUTION CAUTION:
All data in the member drives of the volume are permanently deleted when the volume is deleted. As a best practice to avoid data loss, back up the data before you delete a volume.
To delete the RAID volume, select this item, and then select Yes to confirm the deletion, as shown in Figure 133.
Name
Displays the name of the RAID volume.
RAID Level
Displays the RAID level.
Strip Size
Displays the stripe size of the RAID volume.
Size
Displays the capacity of the RAID volume.
Status
Displays the state of the RAID volume.
Bootable
Displays whether the RAID volume is bootable.
Block Size
Displays the block size of the RAID volume, in bytes.
RAID Member Disks
Member drives of the RAID, for example, Port 0, SAMSUNG MZ7LM240HMHQ-00005 SN:S2WNXR_J802073,223.57GB
To manage a member drive or view its detailed information, select that drive and the RAID member drive management submenu opens.
Delete Confirm submenu
Figure 133 shows the Delete Confirm submenu screen. The submenu items are described in Table 69.
Figure 133 Delete Confirm submenu screen
Table 69 Items on the Delete Confirm submenu screen
Item
Delete the RAID volume. After deletion, all data on this volume will be lost.
Yes
Select Yes and press Enter to delete this volume.
No
Select No and press Enter to cancel the deletion of this volume.
PHYSICAL DISK INFO submenu
Figure 134 and Figure 135 show the PHYSICAL DISK INFO submenu screen. The submenu items are described in Table 70.
Figure 134 PHYSICAL DISK INFO submenu screen (1)
Figure 135 PHYSICAL DISK INFO submenu screen (2)
Table 70 Items on the PHYSICAL DISK INFO submenu screen
Item
Disk Actions
Reset to non-RAID
CAUTION CAUTION:
This action deletes all data on the drive. As a best practice to avoid data loss, back up the data before you perform this action.
To remove the drive from the RAID array, select this item, and then select Yes to confirm the deletion, as shown in Figure 136.
Locate LED
Turn on or turn off the locate LED.
Port
Displays the port number of the drive.
Controller
Displays the drive controller information, which is SATA in this example.
Model Number
Displays the model number of the drive.
Serial Number
Displays the serial number of the drive.
Size
Displays the capacity of the drive.
Status
Displays whether the drive is a RAID member.
Block Size
Displays the block size of the drive, in bytes.
Reset to non-RAID submenu
Figure 136 shows the Reset to non-RAID submenu screen. The submenu items are described in Table 71.
Figure 136 Reset to non-RAID submenu screen
Table 71 Items on the Reset to non-RAID submenu screen
Item
Reset the RAID volume. After resetting, all data on this volume will be deleted.
Yes
Select Yes and press Enter to reset this volume.
No
Non-RAID Physical Disk submenu
Figure 137 and Figure 138 show the Non-RAID Physical Disk submenu screen for a non-RAID physical drive. On the screen, you can view information about the drive and set the drive as a spare or journaling drive, as described in Table 72.
Figure 137 Non-RAID Physical Disk submenu screen (1)
Figure 138 Non-RAID Physical Disk submenu screen (2)
Table 72 Items on the Non-RAID Physical Disk submenu screen
Item
Disk Actions
Mark as Spare
CAUTION CAUTION:
Setting a drive as a spare drive deletes all data on that drive. As a best practice to avoid data loss, back up the data before you perform this action.
To specify the drive as a spare drive, select this item, and then select Yes to confirm the action, as shown in Figure 139.
A spare drive cannot be used to build a RAID volume.
Mark as Journaling Drive
CAUTION CAUTION:
Setting a drive as a journaling drive deletes all data on that drive. As a best practice to avoid data loss, back up the data before you perform this action.
To specify the drive as a journaling drive, select this item, and then select Yes to confirm the action, as shown in Table 73Figure 140.
A journaling drive cannot be used to build a RAID volume.
Locate LED
Port
Controller
Displays drive controller information, which is SATA in this example.
Model Number
Serial Number
Size
Status
Block Size
Mark as Spare submenu
Figure 139 shows the Mark as Spare submenu screen. The submenu items are described in Table 73.
Figure 139 Mark as Spare submenu screen
Table 73 Items on the Mark as Spare submenu screen
Item
Yes
CAUTION CAUTION:
To specify the drive as a spare drive, select this item, and then select Yes to confirm the action.
No
Select No and press Enter to cancel the marking of a disk as a spare drive.
Mark as Journaling Drive submenu
Figure 140 shows the Mark as Journaling Drive submenu screen. The submenu items are described in Table 74.
Figure 140 Mark as Journaling Drive submenu screen
Table 74 Items on the Mark as Journaling Drive submenu screen
Item
Yes
CAUTION CAUTION:
To specify the drive as a journaling drive, select this item, and then select Yes to confirm the action.
No
Select No and press Enter to cancel the marking of a disk as a journaling drive.
Intel(R) Virtual RAID on CPU submenu
Intel® Virtual RAID on CPU (Intel VROC) is a RAID solution specifically designed for NVMe-based SSDs. Figure 141 displays the Intel(R) Virtual RAID on CPU submenu. The menu items are described in Table 75.
The Intel® Virtual RAID on CPU submenu screen displays NVMe drive information only when VMD is enabled. If the VMD is disabled, NVMe drive information is displayed on the Advanced or NVMe Configuration screen, depending on whether NVMe drives contain OptionRom. For more information, see "Dynamic Device Configuration submenu" or "NVMe Configuration submenu."
Figure 141 Intel(R) virtual RAID on CPU submenu screen
Table 75 Items on the Intel(R) Virtual RAID on CPU submenu screen
Item
RAID Volumes
Displays all the created RAID volumes.
Volume0, RAID0(Stripe),796.44GB,Normal
Displays information about the created RAID volumes.
Volume0: RAID name.
RAID0: RAID level.
796.44GB(Size): This size of the RAID.
Normal: The status of the RAID.
Displays physical drives that have not been used to create RAID volumes.
Figure 142 and Figure 143 show the Create RAID Volume submenu screen.
The menu items are described in Table 76.
Figure 142 Create RAID Volume submenu screen (1)
Figure 143 Create RAID Volume submenu screen (2)
Table 76 Items on the Create RAID Volume submenu screen
Item
Create RAID Volume
Name
Specify the name of the RAID.
Volume0: The name of the RAID to be created.
N/A
RAID Level
Specify the RAID level.
Options:
·     RAID0(Stripe).
·     RAID1(Mirror).
·     RAID5(Parity).
·     RAID10(RAID0+1).
RAID0
Enable RAID spanned over VMD Controllers
Enable RAID spanned over VMD controllers.
When this item is selected, you can choose the drives controlled by VMD0 and VMD1 controllers to create a RAID.
N/A
Select Disks
N/A
INTEL SSDPE7KX020T7 SN:PHLF7330003S2P0LGN 1863.02GB Port 1:0,Slot 105,CPU0,VMD0,BDF 08:00.0
Strip Size
N/A
Capacity(GB)
Specify the capacity of the RAID volume, in GB.
N/A
Create Volume
Select to create a RAID volume.
Then, the confirm submenu screen opens as shown in Figure 144.
N/A
Figure 144 Create Volume Confirm submenu screen
Created RAID VOLUME INFO submenu
Figure 145 and Figure 146 show the Created RAID Volume information submenu screen.
The menu items are described in Table 77.
Figure 145 Created RAID VOLUME INFO submenu screen (1)
Figure 146 Created RAID VOLUME INFO submenu screen (2)
Table 77 Items on the Created RAID VOLUME INFO submenu screen
Item
Delete
Select Delete and press Enter to delete a created RAID volume.
Name
RAID Level
Displays the level of the RAID.
Strip Size
Displays the size of the RAID strip.
Size
Displays the size of the RAID, in GB or TB.
Status
Displays the status of the RAID.
Bootable
Indicates whether the volume can be used for system boot.
Block Size
Displays the size of a block, in bytes.
RAID Member Disks
Displays the member disks of the RAID volume.
Delete submenu
Figure 147 shows the Delete submenu screen.
The menu items are described in Table 78.
Figure 147 Delete submenu screen
Table 78 Items on the Delete submenu screen
Item
Yes
No
RAID Member Disks submenu
Figure 148 and Figure 149 show the RAID Member Disks submenu screen. The screen is similar for all RAID member disks.
The menu items are described in Table 79.
Figure 148 RAID Member Disks submenu screen (1)
Figure 149 RAID Member Disks submenu screen (2)
Table 79 Items on the RAID Member Disks submenu screen
Item
Disk Actions
Reset to non-RAID
CAUTION CAUTION:
To remove the drive from the RAID array, select this item, and then select Yes to confirm the deletion, as shown in Figure 150.
Locate LED
Controller
Displays controller information, which is Volume Management Device Controller in this example.
Model Number
Serial Number
Size
Status
Block Size
Root Port Number
Displays the root port number of the drive.
Root Port Offset
Displays the root port offset of the drive.
Slot Number
Displays the slot number of the drive.
Socket Number
Displays the slot number of the processor for the drive.
VMD Controller Number
Displays controller information.
PCI Bus:Device.Function
Displays the Bus:Dev.Func of the drive.
VMD Bus:Device.Function
Displays the Bus:Dev.Func of VMD controller of the drive.
Figure 150 shows the Reset to non-RAID screen. The submenu items are described in Table 80.
Figure 150 Reset to non-RAID submenu screen
Table 80 Items on the Reset to non-RAID submenu screen
Item
Yes
No
Figure 151 and Figure 152 shows the Non-RAID Physical Disk submenu screen for a non-RAID physical drive. The submenu items are described in Table 81.
Figure 151 Non-RAID Physical Disk submenu screen (1)
Figure 152 Non-RAID Physical Disk submenu screen (2)
Table 81 Items on the Non-RAID Physical Disk submenu screen
Item
Disk Actions
Mark as Spare
CAUTION CAUTION:
To specify the drive as a spare drive, select this item, and then select Yes to confirm the action, as shown in Figure 153.
Locate LED
Controller
Model Number
Serial Number
Size
Status
Block Size
Displays the block size of the drive.
Root Port Number
Root Port Offset
Slot Number
Socket Number
Displays the Bus:Dev.Func of the VMD controller of the drive.
Figure 153 shows the Mark as Spare submenu screen. The submenu items are described in Table 82.
Figure 153 Mark as Spare submenu screen
Table 82 Items on the Mark as Spare submenu screen
Item
Disk Actions
Yes
CAUTION CAUTION:
To specify the drive as a spare drive, select Yes to confirm the action, as shown in Table 81Figure 153.
No
Select No and press Enter to cancel this action.
Trusted Computing submenu
The server might contain a trusted platform module (TPM) or a trusted cryptography module (TCM).
Figure 154 shows the Trusted Computing submenu screen. The submenu items are described in Table 83.
Figure 154 Trusted Computing submenu screen
Table 83 Items on the Trusted Computing submenu screen
Items
Security Device Support
Select Enabled or Disabled to enable or disable security device support.
Enabled
TPM security device submenu
Figure 155 and Figure 156 show the TPM2.0 submenu screen. The submenu items are described in Table 84.
Figure 155 TPM2.0 submenu screen (1)
Figure 156 TPM2.0 submenu screen (2)
Table 84 Items on TPM2.0 submenu screen
Item
Firmware Version
Displays the firmware version.
N/A
Vendor
Displays the name of the vendor.
N/A
Select Enabled or Disabled to enable or disable BIOS support for security devices.
Enabled
Active PCR banks
Displays the active platform configuration register (PCR) banks.
N/A
Available PCR Banks
Displays the available PCR banks.
N/A
SHA-1 PCR Bank
Select Enabled or Disabled to enable or disable the SHA-1 PCR bank.
Enabled
SHA256 PCR Bank
Select Enabled or Disabled to enable or disable the SHA256 PCR bank.
Enabled
SHA384 PCR Bank
Select Enabled or Disabled to enable or disable the SHA384 PCR bank.
Disabled
SM3_256 PCR Bank
Select Enabled or Disabled to enable or disable the SM3_256 PCR bank.
Disabled
TPM State
Select Enabled or Disabled to enable or disable TPM.
Enabled
Pending Operation
Select the TPM operation to be performed during the next boot process.
Options:
·     None.
·     TPM Clear—Clears the values of TPM measurements.
None
Platform Hierarchy
This item is inaccessible.
Select Enabled or Disabled to enable or disable platform hierarchy.
Enabled
Storage Hierarchy
Select Enabled or Disabled to enable or disable storage hierarchy.
Enabled
Endorsement Hierarchy
Select Enabled or Disabled to enable or disable endorsement hierarchy.
Enabled
TPM 2.0 UEFI Spec Version
Select the supported Trusted Computing Group (TCG) specification version.
Options:
·     TCG_1_2—Supports Windows 8 and Windows 10.
·     TCG_2—Supports TCG 2 protocols, TCG 2 event formats, and Windows 10 or higher.
TCG_2
Physical Presence Spec Version
Select the Physical Presence Interface (PPI) specification version to be reported to the OS.
Options:
·     1.2.
·     1.3Some HCK tests might not support this version.
1.3
TPM 2.0 InterfaceType
Displays the TPM 2.0 interface type. This item is inaccessible.
N/A
PH Randomization
Select Enabled or Disabled to enable or disable platform hierarchy randomization.
This feature is used only for tests at the development phase.
Enabled
Trusted Computing submenu (TCM 1.0 module installed)
Figure 157 shows a Trusted Computing submenu screen when a TCM 1.0 module is installed. The submenu items are described in Table 85.
Figure 157 Trusted Computing submenu screen (TCM 1.0 module installed)
Table 85 Items on the Trusted Computing submenu screen when a TCM 1.0 module is installed
Item
Configuration
Enabled
TCM State
Select Enabled or Disabled to enable or disable TCM.
Enabled
Pending Operation
Select the TCM operation to be performed during the next boot process.
Options:
·     None.
·     TCM ClearClears the values of TCM measurements.
None
Current Status Information
TCM Enabled Status
Displays whether TCM is enabled or disabled.
N/A
TCM Active Status
Displays whether TCM is activated or deactivated.
N/A
TCM Owner Status
Displays the TCM ownership state. Options are Owned and Unowned.
N/A
ACPI Settings submenu
The ACPI Settings submenu contains the ACPI options for you to configure OS-directed configuration and power management of the server as shown in Figure 158. The submenu items are described in Table 86.
Figure 158  ACPI Settings submenu screen
Table 86 Items on the ACPI Settings submenu screen
Item
Enable ACPI Auto Configuration
Select Enabled or Disabled to enable or disable ACPI auto configuration.
ACPI auto configuration allows the operating system to control and allocate power to the server hardware.
Disabled
Enable Hibernation
This item is configurable only when Enable ACPI Auto Configuration is set to Disabled. The configuration does not take effect on some OSs.
Select Enabled or Disabled to enable or disable system hibernation.
Enabled
Serial Port Console Redirection submenu
Figure 159 shows the Serial Port Console Redirection submenu screen, on which you can configure console redirection settings as described in Table 87.
Figure 159  Serial Port Console Redirection submenu screen
Table 87 Items on the Serial Port Console Redirection submenu screen
Item
COM0
Console Redirection
Select Enabled or Disabled to enable or disable console redirection on CMO0.
If the feature is enabled, the data on a specific physical console or a virtual console will be redirected to the specified system console.
Enabled
Console Redirection Settings
This item is available only when Console Redirection is set to Enabled on CMO0.
Configure console redirection settings.
N/A
Legacy Console Redirection
Legacy Console Redirection Settings
N/A
Serial Port for Out-of-Band Management/Windows Emergency Management Services (EMS)
Console Redirection EMS
Select Enabled or Disabled to enable or disable console redirection for Windows emergency management services (EMS).
Disabled
This item is available only when Console Redirection EMS is set to Enabled for Windows EMS.
N/A
Console Redirection Settings submenu (COM0)
Figure 160 and Figure 161 show a Console Redirection Settings submenu screen for serial port COM0. The submenu items are described in Table 88.
Figure 160  Console Redirection Settings submenu screen (COM0)(1)
Figure 161 Console Redirection Settings submenu screen (COM0)(2)
Table 88 Items on the Console Redirection Settings submenu screen (COM0)
Item
Terminal Type
Select the type of the terminal used for console redirection.
Options:
·     VT100—Uses a supported VT100 video terminal with the ASCII character set.
·     VT100+—Uses a supported VT100-plus video terminal and its character set. VT100+ supports colors and function keys.
·     VT-UTF8Uses a video terminal with the UTF-8 character set.
·     ANSIUses the ANSI character set, which is an extended ASCII character set.
VT100+
Bits Per Second
Set the baud rate of the serial port in bits per second.
Options:
·     9600.
·     19200.
·     38400.
·     57600.
·     115200.
This baud rate setting must match the setting on the remote terminal.
As a best practice, set a low speed on a long or noisy serial line.
115200
Data Bits
Set the number of bits used to represent one character of data.
Options:
·     7.
·     8.
8
Parity
Set the parity bit to be sent with the data bits for transmission error detection.
Options:
·     NoneDisables the transmission error detection feature.
·     Even—Sets the parity bit so that the number of ones in the data set is an even number.
·     Odd—Sets the parity bit so that the number of ones in the data set is an odd number.
·     Mark—Always sets the parity bit to 1. A parity bit value of 0 indicates that an error has occurred.
·     Space—Always sets the parity bit to 0. A non-zero parity bit indicates that an error has occurred.
None
Stop Bits
Set the number of stop bits used to indicate the end of a serial data packet.
Options:
·     1.
·     2.
Two stop bits might be required for communications with a low-speed device.
1
Flow Control
Select a flow control method to prevent data loss from buffer overflow.
Options:
·     NoneNo flow control is used.
·     Hardware RTS/CTSFlow control that uses the ready to send/clear to send (RTS/CTS) signal. When you select this option, make sure it is supported on the serial port.
If you enable hardware RTS/CTS on a serial port that does not support hardware flow control (such as a port that uses a USB-to-serial cable), or on a serial port with no cable connected, the following issues might occur:
·     Failure to load the option ROM of embedded and external PCIe modules.
·     Screen blackout.
·     Cursor flickering.
None
VT-UTF8 Combo Key Support
Select Enabled or Disabled to enable or disable VT-UTF8 combination key support for ANSI/VT100 terminals.
Enabled
Recorder Mode
Select Enabled or Disabled to enable or disable the recorder mode, which is used to capture terminal text data.
Disabled
Resolution 100×31
Select Enabled or Disabled to enable or disable enhanced terminal resolution (100 × 31).
Enabled
Putty KeyPad
Select a mode to change the action of the function keys and keypad in PuTTY.
Options:
·     VT100.
·     LINUX.
·     XTERMR6.
·     SCO.
·     ESCN.
·     VT400.
VT100
Console Redirection Settings (Legacy) submenu
Figure 162 shows the Console Redirection Settings submenu screen. The submenu items are described in Table 89.
Figure 162 Console Redirection Settings (Legacy) submenu screen
Table 89 Items on the Console Redirection Settings (Legacy)  submenu screen
Item
Redirection COM Port
Select the CMO port for the OS and Option ROM redirection in Legacy mode.
The only option is CMO0.
N/A
Resolution
Set the redirection solution.
Options:
·     80x24.
·     80x25.
80x24
Redirect After POST
Select whether to enable or disable redirection after POST.
Options:
·     Always Enable—Always enables redirection after POST.
·     BootLoader—Disables redirection after the OS is booted in Legacy mode.
Always Enable
Console Redirection Settings (EMS port) submenu
Figure 163 shows a Console Redirection Settings (EMS port) submenu screen. The submenu items are described in Table 90.
Figure 163 Console Redirection Settings (EMS port) submenu screen
Table 90 Items on the Console Redirection Settings (EMS port) submenu screen
Item
Out-of-Band Management Port
Indicate the EMS port.
This port allows Microsoft Windows EMS to remotely access the Window OS to collect fault information.
N/A
Terminal Type EMS
Options:
VT100+
Bits Per Second EMS
Set the data transfer rate of the serial port in bits per second.
Options:
·     9600.
·     19200.
·     57600.
·     115200.
This data transfer rate setting must match the setting on the remote terminal.
115200
Flow Control EMS
Options:
·     Software Xon/Xoff—Flow control that uses the XON (transmit ON) and XOFF (transmit OFF) control characters. When the data transfer rate exceeds 1200 bits per second, the receiver sends an XOFF to have the sender stop transmission. The sender will resume the transmission only when it receives an XON from the receiver.
None
Data Bits EMS
N/A
Parity EMS
Options:
None
Stop Bits EMS
N/A
PCI Subsystem Settings submenu
Figure 164 shows the PCI Subsystem Settings submenu screen, on which you can configure PCI subsystem settings as described Table 91.
Figure 164 PCI Subsystem Settings submenu screen
Table 91 Items on the PCI Subsystem Settings submenu screen
Item
PCI Bus Driver Version
Displays the PCI bus driver version.
N/A
PCI Devices Common Settings
Above 4G Decoding
Select Enabled or Disabled to enable or disable decoding of 64-bit PCIe modules in a 4 GB or greater address space.
As a best practice, enable this option if the PCIe module has a 4 GB or higher-capacity VRAM. For example, disabling this option can cause an M60 or K80 GPU to get stuck in the EarlyPOST 100% phase, preventing you from accessing the BIOS setup menu or the OS.
Enabled
SR-IOV Support
Select Enabled or Disabled to enable or disable support for PCIe single-root I/O virtualization (SR-IOV). SR-IOV virtualizes one physical PCIe module into multiple virtual PCIe modules, each of which can be bound to a virtual machine, thus allowing multiple accesses to the physical PCIe module.
With SR-IOV support enabled, the BIOS allocates I/O resources if a PCIe module supports SR-IOV. With SR-IOV support disabled, the OS allocates I/O resources if a PCIe module supports SR-IOV.
Enabled
Figure 165 shows the USB Configuration submenu screen, on which you can view connected USB devices and configure USB settings as described in Table 92.
Figure 165  USB Configuration submenu screen
Table 92 Items on the USB Configuration submenu screen
Item
USB Module Version
Displays the USB module version.
N/A
USB Controllers
Displays the detected USB controllers.
The system supports eXtensible Host Controller (XHCI) controllers that support USB 3.0.
N/A
USB Devices
Displays the numbers of connected USB devices, including drives, keyboards, mouses, and hubs.
The server has one embedded USB hub in addition to the connected USB hubs.
N/A
Legacy USB Support
Select whether to enable support for legacy USB devices.
Options:
·     Enabled—Legacy USB support is always enabled.
·     Disabled—USB devices are available only for UEFI applications.
·     Auto—The system automatically disables legacy USB support if no USB devices are connected.
Enabled
XHCI Hand-off
Select Enabled or Disabled to enable or disable the XHCI hand-off feature. This feature provides a solution for the operating system that does not support XHCI.
Enabled
USB Mass Storage Driver Support
Select Enabled or Disabled to enable or disable the support for USB mass storage drivers.
This field displays USB information depending on USB storage devices installed.
Enabled
CSM Configuration submenu
The configuration support module (CSM) provides UEFI compatibility with OSs that do not support UEFI boot mode.
Figure 166 shows the CSM Configuration submenu screen, on which you can configure CMS settings as described in Table 93.
Figure 166 CSM Configuration submenu screen
Table 93 Items on the CSM Configuration submenu screen
Item
CSM Support
Select Enabled or Disabled to enable or disable support for UEFI-incapable operating systems.
You must enable CSM support in legacy boot mode.
Enabled
CSM16 Module Version
Displays the version of the CSM 16 module.
N/A
Option ROM Execution
Displays ROM execution settings.
N/A
Option ROM Policy
Select the option ROM policy.
Options:
·     Auto—Enables the UEFI boot mode for UEFI option ROMs and legacy boot mode for legacy option ROMs.
·     Custom—Customizes a policy matching with the BIOS boot mode. As a best practice, uses the auto mode to prevent some option ROMs from failing to execute due to incorrect settings.
Auto
Network
Select the option ROM load method for network adapters.
This option is available when the option ROM policy is in custom mode.
Options:
·     UEFI—Loads the option ROM for network adapters in UEFI boot mode.
·     Legacy—Loads the option ROM for network adapters in legacy boot mode.
·     In UEFI boot mode: UEFI.
·     In legacy boot mode: Legacy.
Storage
Select the option ROM load method for storage devices.
Options:
·     UEFI—Loads the option ROM for storage devices in UEFI boot mode.
·     Legacy—Loads the option ROM for storage devices in legacy boot mode.
Video
Select the option ROM load method for video devices.
Options:
·     UEFI—Loads the option ROM for video cards in UEFI boot mode.
·     Legacy—Loads the option ROM for video cards in legacy boot mode.
Other PCI devices
Select the option ROM load method for other PCI devices such as input devices.
Options:
·     UEFI—Loads the option ROM for other PCI devices in UEFI boot mode.
·     Legacy—Loads the option ROM for other PCI devices in legacy boot mode.
Figure 167 shows the NVMe Configuration submenu screen, on which all installed NVMe devices without option ROM are displayed. You can select an NVMe device to view its information as shown in Table 94.
Figure 167 NVMe Configuration submenu screen
Table 94 Items on the NVMe Configuration submenu screen
Item
Slot 251: INTEL SSDPEKKW128G7
Open the submenu for the selected NVMe device.
Figure 168 shows the NVMe Device Information submenu screen, on which you can view the device settings as described in Table 95.
Figure 168 NVMe Device Information submenu screen
Table 95 Items on the NVMe Device Information submenu screen
Item
Seg:Bus:Dev:Func
Displays the Seg:Bus:Dev:Func of the NVMe device.
Model Number
Displays the model number of the NVMe device.
Total Size
Displays the total size of the NVMe device.
Vendor ID
Displays the vendor ID of the NVMe device.
Device ID
Displays the device ID of the NVMe device.
Namespace
Displays the namespace of the NVMe device.
Network Configuration submenu
Figure 169 shows the Network Configuration submenu screen, on which all Ethernet adapters are displayed. The submenu items are described in Table 96.
Preboot Execute Environment (PXE) enables a server to load the operating system through the network interface. This feature allows the system to start up independently from local storage devices (such as drives) and locally installed operating systems.
Figure 169 Network Configuration submenu screen
Table 96 Items on the Network Configuration submenu screen
Item
IPv4 PXE Support
Select Enabled or Disabled to enable or disable loading the OS over an IPv4 network.
If Disabled is selected, the IPv4 PXE boot option will not be created.
Enabled
IPv6 PXE Support
This item is not available in Legacy mode.
Select Enabled or Disabled to enable or disable loading the OS over an IPv6 network.
If Disabled is selected, the IPv6 PXE boot option will not be created.
Disabled
IPSEC Certificate
Select Enabled or Disabled to enable or disable Internet Key Exchange (IPsec) certificate for Internet Key Exchange (IKE).
Disabled
PXE Boot Wait Time
Set the wait time to press ESC key to abort the PXE boot.
Value range: 0 to 5, in seconds.
0
Media Detect Count
Set the maximum number of media presence detections.
Value range: 1 to 50.
1
PXE Retry Count
Set the maximum number of PXE retries.
Value range: 0 to 50.
A value of 0 indicates that the number of PXE retries is not limited.
1
Onboard NIC Support
This item is available only the servers that support onboard NICs.
Submenu for configuring onboard NIC ports, as shown in .
PCIE NIC Configuration
Submenu for configuring PCIe NIC port settings, as shown in Figure 171.
The submenu items are described in Table 98.
N/A
Onboard NIC Support submenu
Figure 170 shows the Onboard NIC Support submenu screen, on which you can configure features described in Table 97.
Figure 170 Onboard NIC Support submenu screen
Table 97 Items on the Onboard NIC Support submenu screen
Item
Onboard NIC Support
Select Enabled or Disabled to enable or disable the onboard NIC.
If you select Disabled, the onboard NIC is not available in the BIOS or OS.
Enabled
Protx Support
Select Enabled or Disabled to enable or disable a specific onboard NIC port.
Enabled
Onboard Portx PXE
Select Enabled or Disabled to enable or disable PXE on a specific onboard NIC port.
Enabled
PCIE NIC Configuration submenu
Figure 171 shows the PCIE NIC Configuration submenu screen, on which you can configure features described in Table 98.
Figure 171 PCIE NIC Configuration submenu screen
Table 98 Items on the PCIE NIC Configuration submenu screen
Item
PCIE NIC PXE
Select Enabled or Disabled to enable or disable PCIe NIC PXE. This feature is supported both in the Legacy mode and the UEFI mode.
Enabled
NICx: Slot x
Displays the relations between the NIC ID and the slot ID. The following lists the PXE settings of each port on the NIC.
N/A
NICm Portn PXE
Select Enabled or Disabled to enable or disable PXE on a specific NIC port. If this NIC port does not exist, this setting does not take effect.
Enabled
Miscellaneous Configuration submenu
Figure 172 shows the Miscellaneous Configuration submenu screen, on which you can configure features described in Table 99.
Figure 172 Miscellaneous Configuration submenu screen
Table 99 Items on the Miscellaneous Configuration submenu screen
Item
Debug Mode
Select Enabled or Disabled to enable or disable the server to output BIOS console log messages.
Disabled
Summary Debug Mode
Select Enabled or Disabled to enable or disable summary debug mode.
Disabled
Init CE report
Select Enabled or Disabled to enable or disable the report of correctable errors at the initialization stage.
Disabled
NVRAM Checksum Support
Select Enabled or Disabled to enable or disable NVRAM checksum. If Enabled is selected, each NVRAM data will be checked.
Disabled
Firmware Integrity Check Support
Select Enabled or Disabled to enable or disable firmware integrity check.
If Enabled is selected, the server will take 10 more seconds to complete POST.
Enabled
Driver Health submenu
Figure 173 shows the Driver Health submenu screen, on which you can view the health state of a driver or controller. The submenu items are described in Table 100.
Figure 173 Driver Health submenu screen
Table 100 Items on the Driver Health submenu screen
Item
Intel(R) PRO/1000 8.3.04 PCI-E
Displays the health state of a driver or a controller.
Options:
·     Healthy—Normal.
·     Failed—Abnormal.
If the state is Failed, press Enter and follow the instructions to repair the driver or controller. The repair method varies by driver or controller.
Server menu
Figure 174 and Figure 175 show the Server menu. From the menu, you can access the firmware information menu, and configure server management features such as the FRB-2 timer, OS watchdog timer, firmware information, HDM network configuration, and HDM user settings.
The menu items are described in Table 101.
Figure 174 Server menu (1)
Figure 175 Server menu (2)
Table 101 Items on the Server menu screen
Item
FRB-2 Timer
Select Enabled or Disabled to enable or disable the FRB-2 timer.
Enabled
FRB-2 Timer timeout
This item is available only when FRB-2 Timer is set to Enabled.
Set the timeout for the FRB-2 timer in the range of 1 to 30 minutes.
15 minutes
FRB-2 Timer Policy
Select the action to take when the FRB-2 timer expires.
Options:
·     Do NothingNo action is taken.
·     Reset—Reboots the system.
·     Power Down—Removes the main power from the system.
·     Power CyclePower cycles the system.
Power Cycle
OS Watchdog Timer
Select Enabled or Disabled to enable or disable the OS watchdog timer.
The OS watchdog timer starts when the OS begins to run and restarts the operating system if the system gets stuck. This helps restore the system in case of system crush.
Disabled
OS Wtd Timer Timeout
This item is configurable only when OS Watchdog Timer is set to Enabled.
Set the timeout for the OS watchdog timer in the range of 5 to 30 minutes.
10 minutes
OS Wtd Timer Policy
Select the action to take when the OS watchdog timer expires.
Options:
·     Do Nothing—No action is taken.
·     Reset—Reboot the system.
·     Power Cycle—Power cycles the system.
Reset
AC Restore Settings
This item is not available for the B5700 G5.
Select the state to which the system is restored when the system AC power is restored.
Options:
·     Always Power On—The system always returns to the power-on state.
·     Always Remain Off—The system always returns to the power-off state.
·     Restore Last Power State—The system returns to the power state when AC power was lost.
The default state also depends on HDM settings.
Serial Number
Set the serial number for the server. It is 2-20 characters in length. The format must meet the HDM requirements.
N/A
Asset Tag
Set the asses tag for the server. It is 0-48 characters in length. The format must meet the HDM requirements.
N/A
Load HDM Default
To restore the factory default settings for HDM, select this item, and then press Enter. It takes one minute to restore the factory default HDM settings. After the restoration finishes, the server restarts automatically.
CAUTION CAUTION:
Do not configure HDM-related items before the server restarts.
N/A
View FRU information
Access the submenu for viewing FRU information, as shown in Figure 176 and Figure 177.
The submenu items are described in Table 102.
N/A
Firmware Information
Access the submenu that displays the firmware information, as shown in Figure 178.
The submenu items are described in Table 103.
N/A
HDM Network Configuration
Access the network configuration submenu for HDM access, as shown in Figure 179.
The submenu items are described in Table 104.
N/A
HDM User Settings
Access the submenu for managing HDM user accounts, as shown in Figure 185.
The submenu items are described in Table 108.
N/A
HDM Warm Reset
Select to enable HDM warm reset. To perform the HDM warm reset, press Enter and select Yes in the prompt page.
N/A
View FRU information submenu
Figure 176 and Figure 177 show the View FRU information menu screen, on which you can view FRU information. The menu items are described in Table 102.
Figure 176 View FRU information menu screen (1)
Figure 177 View FRU information menu screen (2)
Table 102 Items on the View FRU information menu screen
Item
System Manufacturer
Displays the manufacturer of the system.
System Product Name
Displays the name of the system product.
System Version
Displays the version of the system.
System Serial Number
Displays the serial number of the system.
Board Manufacturer
Displays the manufacturer of the system board.
Board Product Name
Displays the product name of the system board.
Board Version
Displays the version of the system board.
Board Serial Number
Displays the serial number of the system board.
Chassis Manufacturer
Displays the manufacturer of the chassis.
Chassis Product Number
Displays the product name of the chassis.
Chassis Serial Number
Displays the serial number of the system product.
System Uuid
Displays the UUID of the system.
Firmware Information submenu
Figure 178 shows the Firmware Information submenu screen, on which you can view firmware information. The menu items are described in Table 103.
Figure 178 Firmware Information submenu screen
Table 103 Items on the Firmware Information submenu screen
Item
BIOS Information
BIOS Vendor
Displays the BIOS vendor.
Compliancy
Displays the BIOS compliance standard.
Project Name
Displays the project name.
BIOS Version
Displays the BIOS version.
Build Date and Time
Displays the BIOS build date and time.
HDM Information
HDM Self Test Status
Displays the HDM self test status.
HDM Device ID
Displays the HDM device ID.
HDM Device Revision
Displays the HDM device revision.
HDM Firmware Revision
Displays the HDM firmware revision.
IPMI Version
Display the IPMI version.
HDM Network Configuration submenu
Figure 179 shows the HDM Network Configuration submenu screen, on which you can view HDM network configuration information. The submenu items are described in Table 104.
Figure 179 HDM Network Configuration submenu screen
Table 104 Items on the HDM Network Configuration submenu screen
Item
Sharelink Configuration
This submenu is not available for the B5700 G5.
Access the submenu for configuring the HDM sharelink.
IPv4 Network Configuration
Access the submenu for configuring the IPv4 network.
IPv6 Network Configuration
Access the submenu for configuring the IPv6 network.
Sharelink Configuration submenu
Figure 180 shows the Sharelink Configuration submenu screen, on which you can view Sharelink configuration information. The submenu items are described in Table 105.
Figure 180 Sharelink Configuration submenu screen
Table 105 Items on the Sharelink Configuration submenu screen
Item
NCSI Network Setting
Select HDM NCSI network port.
This item is available when an NCSI-capable network adapter is installed on the server.
You can select any network port of the present NCSI-capable network adapter.
IPv4 Network Configuration submenu
The HDM shared network port and the HDM dedicated network port have the same parameters. The IP addresses of these ports cannot be in the same segment. The following takes the HDM dedicated network port for example.
Figure 181 and Figure 182 show the IPv4 Network Configuration submenu screen, on which you can view IPv4 network configuration information. The menu items are described in Table 106.
Figure 181 IPv4 Network Configuration submenu screen (1)
Figure 182 IPv4 Network Configuration submenu screen (2)
Table 106 Items on the IPv4 Network Configuration submenu screen
Item
Refresh
Refresh the HDM network configuration information.
Press Enter to refresh configuration before making any changes.
N/A
HDM Net Mode
Displays the HDM network mode dynamically.
Options:
·     Normal Mode—In this mode, the HDM can be accessed through the HDM shared network port or the HDM dedicated network port.
·     Active/standby Mode—In this mode, the HDM dedicated port is used as the first choice to access the HDM.
·     Bonding Mode—In this mode, the HDM shared network port and the HDM dedicated network port are used as one logical network port.
N/A
Dedicated VLAN Setting
Select Enabled or Disabled to enable or disable VLAN on the HDM dedicated network port.
Disabled
Dedicated VLAN id
This item is available only when Dedicated VLAN Setting is set to Enabled.
Configures the VLAN ID, in the range of 2 to 4094.
2
Dedicated VLAN priority
Specify the priority of a dedicated VLAN, in the range of 0 to 7. The larger the number, the higher the priority.
When traffic congestion occurs, frames with the highest priority will be sent first.
0
Shared VLAN Settings
Select Enabled or Disabled to enable or disable VLAN on the HDM shared network port.
Disabled
Shared VLAN id
This item is available only when Shared VLAN Setting is set to Enabled.
2
Shared VLAN priority
Specify the priority of a shared VLAN, in the range of 0 to 7. The larger the number, the higher the priority.
0
HDM Dedicated/Shared Network Port
The B5700 G5 displays only HDM dedicated network port information.
Configuration Address source
Configure the HDM network status parameters.
Options:
·     Unspecified—Retains the current configuration.
·     StaticUses manually specified configuration.
·     DynamicHdmDhcpUses network information obtained through DHCP.
Unspecified
Current Configuration Address source
Displays the current address source.
N/A
Station IP Address
This item is available only when Configuration Address source is set to Static.
The configured HDM static IPv4 address takes effect only after both the Station IP Address and Subnet Mask are configured.
Specify the station IP address for the port.
192.168.1.2
Subnet Mask
This item must be specified before you set the HDM static IPv4 address.
Specify the subnet mask.
255.255.0.0
Station MAC Address
Displays the MAC address of the port.
N/A
Router IP Address
Specify the gateway IP address.
N/A
Router MAC Address
Displays the gateway MAC address.
N/A
IPv6 Network Configuration submenu
Figure 183 and Figure 184 show the IPv6 Network Configuration submenu screen, on which you can view IPv4 network configuration information. The menu items are described in Table 107.
Figure 183 IPv6 Network Configuration submenu screen (1)
Figure 184 IPv6 Network Configuration submenu screen (2)
Table 107 Items on the IPv6 Network Configuration submenu screen
Item
Refresh
Refresh HDM network configuration information.
N/A
HDM Net Mode
Options:
N/A
Options:
Unspecified
N/A
Station IP Address
The configured HDM static IPv6 address takes effect only after both the Station IPv6 Address and Prefix Length are configured.
Specify the IPv6 address for the port.
N/A
Prefix Length
This item must be specified before you set the HDM static IPv6 address.
Specify the prefix length, in the range of 0 to 127. 0 indicates that no prefix length is specified.
0
IPv6 Router IP Address
The IPv6 gateway IPv6 address and the port IPv6 address must be in the same segment.
Specify the IPv6 gateway IP address.
N/A
IPv6 address status
Displays the status of the IPv6 address.
Options:
·     Actived.
·     Disabled.
·     Pending.
·     Failed.
·     Deprecated.
·     Invalid.
·     Reserved.
N/A
IPv6 DHCP Algorithm
Displays the IPv6 DHCP algorithm.
N/A
HDM User Settings submenu
Figure 185 shows the HDM User Settings menu screen, on which you can configure HDM users. The menu items are described in Table 108.
Figure 185 HDM User Settings submenu screen
Table 108 Items on the HDM User Settings submenu screen
Item
User ID
Displays the current HDM user ID.
User information is configurable only when the user ID is 2 (Admin).
N/A
User Name
Press Enter to modify the HDM username.
A username is a case-sensitive string of 1 to 16 characters and supports only letters, digits, and underscores (_).
The name of the login user cannot be modified.
N/A
User Password
Set the HDM user password.
The password must follow these HDM password complexity check rules:
·     When password complexity check is enabled:
¡     The password must be a case-sensitive string of 8 to 20 characters and can contain only letters, digits, spaces, and special characters: `~!@#$%^&*()_+-=[]\{}|;':",./<>?
¡     It must contain at least two kinds of characters: uppercase letters, lowercase letters or numbers.
¡     It must contain at least one space or special character.
¡     It cannot be the same as the username or the reverse order of the username.
·     When password complexity check is disabled, the password must be a case-sensitive string of 2 to 20 characters and can contain only letters, digits, spaces, and the following special characters: `~!@#$%^&*()_+-=[]\{}|;':",./<>?
By default, password complexity check is enabled.
For more information about how to enable or disable password complexity check, see HDM online help.
N/A
Load HDM User Configuration
Restore the default HDM user configuration. If the default HDM user is online, this feature is not available.
N/A
Security menu
Figure 186 shows the Security menu, on which you can configure security features such as setting the BIOS administrator and user passwords.
The menu items are described in Table 109.
Figure 186 Security menu screen
Table 109 Items on the Security menu screen
Item
Password Description
Displays the password description.
Administrator Password
Set the administrator password. For more information about restrictions for setting the administrator password, see "Restrictions and guidelines."
User Password
Set the user password. For more information about restrictions for setting the user password, see "Restrictions and guidelines."
Power On Password
Set the power-on password. For more information about restrictions for setting the power-on password, see "Restrictions and guidelines."
HDD Security Configuration
Displays hard disk drives that support security configuration, for example, P2:TS256GMTS800.
To configure security settings for a hard disk drive, select the disk drive and press Enter. The screen that opens is as shown in Figure 187, and the submenu items are described in Table 110.
Secure Boot Menu
This item is available only in UEFI boot mode.
Access the submenu for configuring secure boot, as shown in Table 110Figure 188.
The submenu items are described in Table 111.
Figure 187 shows the HDD Security Configuration submenu. The menu items are described in Table 110.
Figure 187 HDD Security Configuration submenu screen
Table 110 Items on the HDD Security Configuration submenu screen
Item
Security Supported
Displays whether the hard disk drive supports security configuration.
Security Enabled
Displays whether an HDD user password has been set.
If an HDD user password has been set, you must provide the password to unlock the hard disk drive before using it.
Security Locked
Displays whether the hard disk drive is locked.
If the hard disk drive is locked, enter the user password to unlock it.
Security Frozen
Displays the security frozen status. You cannot format a drive in frozen state.
HDD User Pwd Status
Displays whether an HDD user password is set.
Set User Password
Set an HDD user password, 1 to 32 characters in length.
If an HDD user password is set or removed, the setting on the BIOS will not affect the password.
If this item is inaccessible or hidden, you can power cycle the server for this item to become accessible.
Figure 188 shows the Secure Boot submenu screen. The submenu items are described in Table 111.
Secure boot is available only in UEFI mode. With this feature enabled, key authentication is required when you load any operating system or hardware driver program. This prevents intrusion of malware. The servers come with a secure boot key and you can import keys as needed. Secure boot does not require any hardware (for example, Trusted Platform Module).
Figure 188 Secure Boot submenu screen
Table 111 Items on the Secure Boot menu screen
Item
System Mode
Displays the system mode.
N/A
Secure Boot
Select Enabled or Disabled to enable or display secure boot.
With this feature enabled, key authentication is required to load any operating system or hardware driver.
Disabled
Secure Boot Mode
Select a secure boot mode.
Options:
·     StandardUses the preset secure boot key and certificate. In standard boot mode, you can select whether to install the factory default secure boot key, as shown in Figure 189.
·     CustomIn custom boot mode, you can change the image execution policy and manage secure boot keys.
Custom
Restore Factory Keys
Restore the factory default secure boot keys.
N/A
Reset To Setup Mode
Reset the system mode to setup mode.
N/A
Key Management
Access the submenu for key management, as shown in Figure 190 and Figure 191.
The submenu items are described in Table 112.
N/A
Figure 189 Installing the factory default secure boot key
Figure 190 and Figure 191 show the Key Management submenu. The submenu items are described in Table 112.
Figure 190 Key Management submenu screen (1)
Figure 191 Key Management submenu screen (2)
Table 112 Items on the Key Management submenu screen
Item
Vendor Keys
Displays whether the vendor keys have been modified.
Options:
·     ValidThe vendor keys have not been modified and are valid.
·     ModifiedThe vendor keys have been modified or deleted.
N/A
Factory Key Provision
Select Enabled or Disabled to enable or disable provisioning the factory default keys when the system is in setup mode.
Disabled
Access the submenu for restoring factory default keys.
This operation forces the system to enter user mode and installs factory default secure boot keys.
N/A
Reset To Setup Mode
Access the submenu for resetting the system mode to setup mode.
N/A
Export Secure Boot Variables
Access the submenu for exporting all secure boot variables.
N/A
Enroll Efi Image
Access the submenu for enrolling the EFI image.
This operation enables secure boot for the image and enrolls a SHA256 hash of the PE image in the Authorized Signature Database (DB).
N/A
Device Guard Ready
Indicates the server is ready for device guard.
N/A
Remove ‘UEFI CA’ from DB
Access the submenu for removing UEFI CA from DB.
N/A
Restore DB defaults
Access the submenu for restoring all DB variables to factory defaults.
N/A
Platform Key(PK)
Access the submenu for managing the platform key.
Option is Update.
N/A
Key Exchange Keys
Access the submenu for managing key exchange keys.
Options:
·     Update.
·     Append.
N/A
Authorized Signatures
Access the submenu for configuring authorized signatures.
Options:
·     Update.
·     Append.
N/A
Forbidden Signatures
Access the submenu for managing forbidden signatures.
Options:
·     Update.
·     Append.
N/A
Authorized TimeStamps
Access the submenu for managing authorized timestamps.
Options:
·     Update.
·     Append.
N/A
OsRecovery Signatures
Access the submenu for configuring operating system recovery signatures.
Options:
·     Update.
·     Append.
N/A
Boot menu
Figure 192 and Figure 193 show the Boot menu, on which you can configure boot settings such as the boot type and boot sequence.
The menu items are described in Table 113.
Figure 192 Boot menu screen (1)
Figure 193 Boot menu screen (2)
Table 113 Items on the Boot menu screen
Item
Bootup NumLock State
Select On or Off to turn on or turn off the NumLock key on the numeric keypad of the keyboard at system boot.
On
Quiet Boot
Select On or Off to enable or disable quiet boot mode.
Options:
·     DisabledEnables the boot screen to display POST information during boot process.
·     Enabled—Enables the boot screen to display the product logo instead of POST information during boot process.
Disabled
Hide Logo
Select Enabled or Disabled to display or hide the logo on the boot screen.
Disabled
Early VGA Mode
Displays in the early VGA mode.
Options:
·     Detail—Displays detail information, including logo, version, HDM IP address, progress, and alarm information.
·     SimpleDisplays simple information, including logo, version, and HDM IP address.
·     LogoOnly—Display the logo only.
Detail
iFIST Boot
Select Enabled or Disabled to enable or disable iFIST boot.
If iFIST boot is disabled, the iFist item is not displayed on the BIOS startup screen as shown in Figure 2, and pressing F10 cannot boot iFIST.
Enabled
USB Boot
Select Enabled or Disabled to enable or disable USB boot.
Enabled
Boot mode select
Select a boot mode.
Options:
·     LEGACY.
·     UEFI.
UEFI
EFI Shell Boot
Select Enabled or Disabled to enable or disable shell boot.
Disabled
Fixed Boot Order Priorities
Displays the prioritized list of bootable devices from which the system can boot.
In legacy mode, a drive is displayed in the list only if it has the highest boot priority (BBS priority) among all the drives of the same type. To display a drive in this list, enter the BBS priorities submenu for the drive type, and then set this drive as the first boot option.
N/A
Boot Option #1
Set the first boot option.
To disable the first boot option, select Disabled for this item.
N/A
Boot Option #2
Set the second boot option.
To disable the second boot option, select Disabled for this item.
N/A
Boot Option #3
Set the third boot option.
To disable the third boot option, select Disabled for this item.
N/A
Boot Option #4
Set the fourth boot option.
To disable the fourth boot option, select Disabled for this item.
N/A
UEFI Hard Disk Drive BBS Priorities
Access the submenu for configuring the boot priorities of hard disk drive, USB-HDD, SD card, and virtual hard disk drive, as shown in Figure 194.
The submenu items are described in Table 114.
N/A
This item is available only in legacy boot mode.
Access the submenu for configuring the boot priorities of hard disk drive, USB-HDD, SD card, and virtual hard disk drive.
N/A
UEFI CDROM/DVD Drive BBS Priorities
This item is available only in UEFI boot mode and when one or more CD- or DVD-ROM drives are connected.
Access the submenu for configuring the boot priorities of connected CD- or DVD-ROM drives, as shown in Figure 195.
The submenu items are described in Table 115.
N/A
This item is available only in legacy boot mode and when one or more CD- or DVD-ROM drives are connected.
Access the submenu for configuring the boot priorities of connected CD- or DVD-ROM drives.
N/A
UEFI Network Drive BBS Priorities
Access the submenu for configuring the boot priorities of available network drives, as shown in Figure 196.
The submenu items are described in Table 116.
N/A
Access the submenu for configuring the boot priorities of available network drives.
N/A
UEFI Other Drive BBS Priorities
Set the boot device priority sequence from the available UEFI other drives.
The options include but are not limited to:
·     Embedded UEFI shell. This option is available only when EFI Shell Boot is set to Enabled.
·     Other unidentified boot devices.
Access the submenu for configuring the boot priorities of other devices, as shown in Figure 197.
The submenu items are described in Table 117.
N/A
Figure 194 UEFI Hard Disk Drive BBS Priorities submenu screen
Table 114 Items on the UEFI Hard Disk Drive BBS Priorities submenu screen
Item
Boot Option #1
Select a hard disk as the first boot option. To disable this boot option, select Disabled.
The number of available options varies by server configuration.
Figure 195 UEFI CDROM/DVD Drive BBS Priorities screen menu
Table 115 Items on the UEFI CDROM/DVD Drive BBS Priorities submenu screen
Item
Boot Option #1
Select a CD- or DVD-ROM drive as the first boot option. To disable this boot option, select Disabled.
Figure 196 UEFI Network Drive BBS Priorities submenu screen
Table 116 Items on the UEFI Network Drive BBS Priorities submenu screen
Item
Boot Option #1
Select a PXE boot device as the first boot option. To disable this boot option, select Disabled.
Boot Option #2
Select a PXE boot device as the second boot option. To disable this boot option, select Disabled.
Figure 197 UEFI Other Drive BBS Priorities submenu screen
Table 117 Items on the UEFI Other Drive BBS Priorities submenu screen
Item
Boot Option #1
Select the other type of boot devices as the first boot option. To disable this boot option, select Disabled.
Exit menu
Figure 198 shows the Exit menu, on which you can modify BIOS parameter settings and exit the BIOS.
The menu items are described in Table 118.
Figure 198 Exit menu screen
Table 118 Items on the Exit menu screen
Item
Save Options
Save Changes and Exit
Exit with changes saved.
Exit without saving changes.
Save Changes and Reset
Restart the server with changes saved. (Recommended)
Discard Changes and Reset
Restart the server without saving changes.
Save Changes
Save changes without exiting the BIOS.
Discard Changes
Discard changes without exiting the BIOS.
Default Options
Restore Defaults
Restore the factory-default settings.
The following information is not restored:
·     System date and time on the Main screen.
·     Items except for FRB-2 Timer on the Server screen.
·     Password-related items on Security screen.
Boot Override
Select a boot device option and press Enter to boot from that device. This field displays all available boot options.
This setting is a one-time setting that takes effect only at the next boot. Subsequent boots will use the boot order configured on the Boot menu screen.
UEFI: PXE IPv4 Embedded: Port x – Intel(R) I350 Gigabit Network Connection
Select this item as a boot option for one-time boot override.
This item is available when port X of the network adapter is connected to an IPv4 PXE server.
IBA 40G Slot 3D00 v1066
This item is available only in Legacy boot mode.
Industry standards
Table 119 shows the industry standards followed by the BIOS.
Table 119 Industry standards
Industry standard
Full name
Version
URL address
UEFI
Unified Extensible Firmware Interface (UEFI) Specification
2.8
https://uefi.org/
ACPI
Advanced Configuration and Power Interface (ACPI) Specification
6.2
https://uefi.org/
SMBIOS
System Management BIOS (SMBIOS) Specification
3.3
https://www.dmtf.org/
Redfish
Redfish Specification
1.8
PCI
PCI Local Bus Specification
3.0
https://pcisig.com/specifications/
PCI Firmware
PCI Firmware Specification
3.2
PCIE
PCI Express® Base Specification
5.0
DDR
DDR4 SDRAM Specification
DDR4
https://www.jedec.org/
Acronyms and abbreviations
Term
Definition
A
ACPI
ADR
Asynchronous Dram Refresh
AHCI
Advanced Host Controller Interface
ATS
Address Translation Services
B
BIOS
Basic Input Output System
C
CFG
Configure
CSM
Compatibility Support Module
D
DCU
Drive Control Unit
DMA
Direct Memory Access
DMI
Direct Media Interface
DRAM
Dynamic Random Access Memory
DCPMM
Intel® OptaneTM DC PMEM module
E
ECC
Error Checking and Correcting
EFI
EIST
Enhanced Intel SpeedStep Technology
EMS
EMCA
Enhanced Machine Check Architecture
G
GPU
Graphics Processing Unit
H
HBA
Host Bus Adapter
HDM
Hardware Device Management
I
IDE
Integrated Drive Electronics
IIO
Integrated I/O Module
IMC
Integrated Memory Controller
IRQ
Interrupt Request
iSCSI
Internet Small Computer System Interface
L
LLC
Last Level Cache
LLDP
Link Layer Discovery Protocol
LUN
Logical Unit Number
M
MAC
Media Access Control
MCTP
Management Component Transport Protocol
ME
Management Engine
MMIO
Memory mapping I/O
MRC
Memory Reference Code
N
NIC
Network Interface Controller
NMI
Non-Maskable Interrupt
NUMA
Non Uniform Memory Access
O
OS
Operating System
P
PCH
Platform Controller Hub
PCI
Peripheral Component Interface
PCIe
Peripheral Component Interconnect Express
PCU
Power Controller Unit
PECI
Platform Environment Control Interface
PMem
Persistent memory
PK
Platform Key
POR
Plan Of Record
POST
Power On Self Test
PXE
R
RAID
Redundant Arrays of Independent Disks
RAPL
Running Average Power Limit
RAS
Reliability, Availability, Serviceability
RFO
Read For Ownership
ROM
Read-Only Memory
RTS/CTS
Request To Send/Clear To Send
S
SAS
Serial Attached SCSI
SATA
Serial Advanced Technology Attachment
SCSI
SEL
System Event Log
SMI
System Management Interrupt
SR-IOV
Single-Root I/O Virtualization
SMBIOS
T
TCM
Trusted Cryptography Module
TDP
Thermal Design Power
TPM
TXT
Trusted Execution Technologies
U
UEFI
UID
Unit Identification
UPI
Ultra Path Interconnect
V
VT-d
Intel Virtualization Technology For Directed I/O
VMD
VGA
Video Graphics Array
X
XHCI
eXtensible Host Controller Interface
