- 16-Security Configuration Guide
- 01-ACL configuration
- 02-Packet filter configuration
- 03-Time range configuration
- 04-User profile configuration
- 05-Password control configuration
- 06-Keychain configuration
- 07-Public key management
- 08-PKI configuration
- 09-IPsec configuration
- 10-IKE configuration
- 11-IKEv2 configuration
- 12-SSH configuration
- 13-SSL configuration
- 14-SSL VPN configuration
- 15-Session management
- 16-Connection limit configuration
- 17-Attack detection and prevention configuration
- 18-IP-based attack prevention configuration
- 19-IP source guard configuration
- 20-ARP attack protection configuration
- 21-ND attack defense configuration
- 22-Protocol packet rate limit configuration
- 23-Security policy configuration
- 24-Object group configuration
- 25-ASPF configuration
| 23-Security policy configuration | 204.89 KB |
Restrictions and guidelines: Security policy configuration
Prerequisites for security policies
Security policy tasks at a glance
Configuring security policy rules
Configuring the action of the default security policy rule
Creating a security policy rule
Configuring filtering criteria for a security policy rule
Specifying the action for a security policy rule
Disabling a security policy rule
Specifying a time range for a security policy rule
Applying a DPI application profile to a security policy rule
Applying an IPS policy to a security policy rule
Setting the session aging time for a security policy rule
Associating a security policy rule with a track entry
Enabling logging for matched packets
Enabling statistics collection for matched packets
Configuring security policy rule groups
Creating a security policy rule group
Specifying a security policy rule group for a security policy rule
Moving a security policy rule group
Renaming a security policy rule group
Verifying and maintaining security policies
Clearing object policy statistics
Displaying the object policy configuration and statistics
Configuring security policies
About security policies
A security policy defines a set of rules for forwarding control and Deep Packet Inspection (DPI). It matches packets against the rules and takes the action stated in the rules on the matched packets.
Security policy rules
A security policy contains one or multiple rules. Each security policy rule is a permit or deny, or DPI statement for identifying traffic based on criteria.
Rule numbering
Each rule is uniquely identified by a name and an ID. When you create a rule, the rule name must be manually configured, and the rule ID can be manually configured or automatically assigned by the system.
Rule match criteria
The rule match criteria include the following types: source IP address, destination IP address, user and user group, application and application group, and service.
Rule and session management
When a security policy is configured, the device generates session entries for permitted packets to record packet information.
You can set session aging times for protocol states, application layer protocols, or rules. The aging time configured for a rule takes precedence over the aging time configured for a protocol state or an application layer protocol. For more information about session management, see "Managing sessions."
Security policy mechanism
As shown in Figure 1, a security policy operates as follows:
1. After receiving a packet, the device matches the packet against the configured security policy rules.
A security policy rule includes various match criterion types. A packet is considered matched if it matches all the criterion types in the rule. Each criterion type includes one or more criteria, and a packet matches a criterion type if it matches any criterion of the type.
¡ If no match is found, the device discards the packet.
¡ If a match is found and the rule action is drop, the device discards the packet.
¡ If a match is found and the rule action is pass, the device goes to the next step.
2. If a DPI application profile or IPS policy is configured for the matched rule, the device uses the specified profile or policy to perform DPI on the packet. If no DPI application profile or IPS policy is specified, the device allows the packet to pass.
Figure 1 Security policy mechanism
Security policy rule grouping
Security policy rule grouping allows users to enable, disable, delete, and move security policy rules in batches. A security policy rule in a security policy rule group takes effect only when both the rule and the group are enabled.
When you configure security policies, follow these restrictions and guidelines:
· Packet filtering, if configured, is performed only on packets that do not match any security policy rule. As a best practice, make sure security policies have stricter filtering criteria than packet filtering, so the unmatched packets can still be filtered by packet filtering.
· Follow the depth-first order during rule creation to create rules with stricter match criteria first because the system matches packets against rules in the order the rules were created.
· Security policy rules specified with an IP address object group that uses a user or user group cannot match packets. To filter packets by user or user group, configure security policy rules specified with user or user group criteria.
Before you configure security policies, perform the following tasks:
· Configure a time range. See time range configuration in Security Configuration Guide.
· Configure IP address object groups and service object groups. See "Configuring object groups."
· Configure applications and application groups. See ARP in DPI Configuration Guide.
· Configure user and user groups. See "Configuring user identification."
· Configure DPI. See DPI Configuration Guide.
· After you upgrade the software from version E10xx, E12xx, or R12xx to R14xx and later versions, you must reconfigure the following security policy features:
¡ The security-policy command and all rules configured in security policy view.
¡ The disable or undo disable command.
¡ The action command.
To configure security policies, perform the following tasks:
1. Configuring security policy rules
a. Configuring the action of the default security policy rule
b. Creating a security policy rule
c. Configuring filtering criteria for a security policy rule
d. Specifying the action for a security policy rule
e. Disabling a security policy rule
f. (Optional.) Specifying a time range for a security policy rule
g. (Optional.) Applying a DPI application profile to a security policy rule
h. (Optional.) Applying an IPS policy to a security policy rule
i. (Optional.) Setting the session aging time for a security policy rule
j. (Optional.) Associating a security policy rule with a track entry
k. (Optional.) Enabling logging for matched packets
l. (Optional.) Enabling statistics collection for matched packets
2. (Optional.) Manage security policies
a. Changing the rule match order
3. (Optional.) Configuring security policy rule groups
a. Creating a security policy rule group
b. Specifying a security policy rule group for a security policy rule
c. Moving a security policy rule group
d. Renaming a security policy rule group
When a packet does not match any security policy rules, the action for the default rule is taken on the packet.
1. Enter system view.
2. Enter security policy view.
security-policy
3. Configure the action of the default security policy rule.
default rule action { drop | pass }
By default, the action for the default security policy rule is drop.
4. Enable statistics collection for the default security policy rule.
default rule counting enable
By default, the device does not collect statistics about packets matching the default security policy rule.
5. Enable logging for the default security policy rule.
default rule logging enable
By default, logging is disabled for packets matching the default security policy rule.
security-policy
3. (Optional.) Configure a description for the policy.
By default, a security policy does not have a description.
4. Create a security policy rule.
rule { rule-id | [ rule-id ] name rule-name }
5. (Optional.) Configure a description for the rule.
By default, a security policy rule does not have a description.
A rule matches all packets if no criteria are specified for the rule.
If a specified object group has no objects, the rule cannot match any packets.
Packets exchanged between the Management and Local security zones are allowed to pass by default and can only match local-to-management or management-to-local security policy rules. To discard packets between the Management and Local security zones, configure local-to-management and management-to-local rules and specify the rule actions as drop.
security-policy
3. Enter security policy rule view.
4. Configure source filtering criteria:
¡ Specify a source address object group as a filtering criterion.
source-address { host { ip-address | ipv6-address } | subnet { ip-address { mask-length | mask } | ipv6-address prefix-length | ipv6-address / prefix-length } | range { ip-address1 ip-address2 | ipv6-address1 ipv6-address2 } | object-group-ip address-object-group-name | object-group-ipv6 address-object-group-name | object-group-mac mac-object-group-name }
By default, no source address object group is specified as a filtering criterion.
5. Configure destination filtering criteria:
¡ Specify a destination address object group as a filtering criterion.
destination-address { host { ip-address | ipv6-address} | subnet { ip-address { mask-length | mask }| ipv6-address prefix-length | ipv6-address / prefix-length } | range { ip-address1 ip-address2 | ipv6-address1 ipv6-address2 } | object-group-ip address-object-group-name | object-group-ipv6 address-object-group-name }
By default, no destination address object group is specified as a filtering criterion.
6. Specify a service object group as a filtering criterion.
service object-group object-group-name
By default, no service object group is specified as a filtering criterion.
7. Specify an application or application group as a filtering criterion.
application { name application-name | group app-group-name }
By default, no application or application group is specified as a filtering criterion.
8. Specify a user or user group as a filtering criterion.
user { name username | group user-group-name } [ domain domain-name ]
By default, no user or user group is specified as a filtering criterion.
security-policy
4. Specify the action for the security policy rule.
By default, the action for a security policy rule is not specified.
security-policy
4. Disable the security policy rule.
disable
By default, the security policy rule is enabled.
security-policy
4. Specify a time range during which the security policy rule is in effect.
time-range time-range-name
By default, a security policy rule is in effect at any time.
This feature enables the device to perform DPI on packets matching the specified rule. For more information about DPI, see DPI Configuration Guide.
This feature takes effect only when the rule action is pass.
Under the same rule, you can specify an IPS policy or a DPI application profile, but cannot specify the policy and profile at the same time.
security-policy
4. Specify the rule action as pass.
action pass
By default, the action for a security policy rule is drop.
5. Apply a DPI application profile to the rule.
profile app-profile-name
By default, no DPI application profile is applied to a rule.
This feature enables the device to use an IPS policy to filter packets matching the specified security policy rule. For more information about IPS, see DPI Configuration Guide.
security-policy
action pass
5. Apply an IPS policy to the rule.
ips-policy policy-name
By default, no IPS policy is applied to a rule.
Perform this task to specify the aging time for stable sessions and persistent sessions. The configuration takes effect only on sessions established afterwards.
The configured aging time for persistent sessions is effective only on TCP sessions in ESTABLISHED state.
The priorities of the session aging times configured by using the session persistent aging-time, session aging-time, and session persistent acl commands are in descending order.
security-policy
4. Set the session aging time.
session aging-time time-value
By default, the session aging time is not configured.
5. Set the aging time for persistent sessions.
session persistent aging-time time-value
By default, the aging time for persistent sessions is not configured.
Perform this task to enable the collaboration between the track module and a security policy rule. The collaboration operates as follows:
· If a rule is associated with the Negative state of a track entry, the device:
¡ Sets the rule state to Active if the track entry is in Negative state.
¡ Sets the rule state to Inactive if the track entry is in Positive state.
· If a rule is associated with the Positive state of a track entry, the device:
¡ Sets the rule state to Active if the track entry is in Positive state.
¡ Sets the rule state to Inactive if the track entry is in Negative state.
security-policy
4. Associate the rule with a track entry.
track { negative | positive } track-entry-number
By default, no track entry is associated with a rule.
This feature enables the device to log matching packets and send the log to the information center for processing. The log destinations and output rules are determined by the information center settings. For more information about the information center, see System Management Configuration Guide.
security-policy
4. Enable logging for matched packets.
logging enable
By default, logging for matched packets is disabled.
5. (Optional.) Enable real-time sending for security policy log messages.
security-policy log real-time-sending enable
By default, real-time sending is disabled for security policy log messages.
Perform this task to enable the device to collect statistics about matched packets. The collected statistics can be viewed by executing the display security-policy statistics command.
When inter-VLAN bridge forwarding is configured, this feature collects statistics only about packets discarded by security policies and DPI. Statistics about permitted packets are not collected. For more information about inter-VLAN bridge forwarding, see Layer 2 forwarding in Network Connectivity Configuration Guide..
security-policy
4. Enable statistics collection for matched packets.
counting enable
By default, the device does not collect statistics about matched packets.
The device matches packets against security policy rules in the order the rules were created. You can change the rule match order by changing the position of a security policy rule in the rule list.
security-policy
3. Move a security policy rule.
¡ Move a security policy rule by rule ID.
move rule rule-id before insert-rule-id
¡ Move a security policy rule by rule name.
move rule name rule-name1 { { after | before } name rule-name2 | bottom | down | top | up }
Perform this task to create a security policy rule group and add security policy rules to the group.
To add a list of security policy rules, make sure the end rule is listed behind the start rule and the specified rules do not belong to any other security policy rule group.
A security policy rule group can contain only IPv4 rules or IPv6 rules.
2. Enter IPv4 or IPv6 security policy view.
security-policy
3. Create a security policy rule group and add security policy rules to the group.
group name group-name [ from rule-name1 to rule-name2 ] [ description description-text ] [ disable | enable ]
security-policy
4. Specify a security policy rule group for the security policy rule.
parent-group group-name
Perform this task to move a security policy rule group to change the match order of security policy rules.
If you specify a target security policy rule that belongs to a security policy rule group, follow these restrictions and guidelines:
· If the target rule is neither the start nor end rule of the group, you cannot move a security policy rule group to the place before or after the rule.
· If the target rule is the start rule of the group, you can only move a security policy rule group to the place before the rule.
· If the target rule is the end rule of the group, you can only move a security policy rule group to the place after the rule.
You can move a security policy rule group before or after a security policy rule or group of the same type (IPv4 or IPv6).
security-policy
3. Move a security policy rule group.
group move group-name1 { after | before } { group group-name2 | rule rule-name }
security-policy
3. Rename a security policy rule group.
group rename old-name new-name
To clear object policy statistics, execute the following command in user view:
reset security-policy statistics [ rule rule-name ]
· Display security policy configuration.
display security-policy [ verbose | rule name rule-name ]
· Display configuration information of the security policy with the specified quintuple.
display security-policy match-criteria { source-zone { name source-zone-name | any } | destination-zone { name destination-zone-name | any } | source-address { ip-address | ipv6-address | any } | destination-address { ip-address | ipv6-address | any } | protocol { protocol-number [ [ source-port source-port | destination-port destination-port ] * | icmp-type icmp-type-number icmp-code icmp-code-number | icmpv6-type icmpv6-type-number icmpv6-code icmpv6-code-number ] | any } } * [ verbose ]
· Display security policy statistics.
display security-policy statistics [ rule rule-name ]
