02-System Management
HomeSupportRoutersSR6600-M SeriesDiagnose & MaintainAlarms ReferencesH3C SR6608-M Router Alarm Reference-R9141-6W10002-System Management
03-HH3C-ENTITY-EXT-MIB
03-HH3C-ENTITY-EXT-MIB 328.59 KB
HH3C-ENTITY-EXT-MIB
About this MIB
Use this MIB to obtain entity extended information for better management and monitoring of the device.
Products supporting this MIB must first support the ENTITY-MIB MIB.
The following tables show the relationship between the entity extended properties and device entities. Implementation varies by product.
Entity
hh3cEntityExtAdminStatus (R/W)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
No
port
Yes
stack
No
other
No
unknown
No
Entity
hh3cEntityExtOperStatus (R)
chassis
No
backplane
No
container
No
power Supply
Yes
fan
Yes
sensor
No
module
Yes
port
Yes
stack
No
other
No
unknown
No
Entity
hh3cEntityExtStandbyStatus (R)
chassis
No
backplane
No
container
No
powerSupply
No
fan
Yes
sensor
No
module
Yes
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtAlarmLight (R)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
No
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtCpuUsage (R)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
Yes (Only support the Module Level1)
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtCpuUsageThreshold (R/W)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtMemUsage (R)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtMemUsageThreshold(R/W)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtMemSize (R)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtUpTime (R)
chassis
Yes
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
No
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtTemperature (R)
chassis
No
backplane
No
container
No
powerSupply
Yes
fan
Yes
sensor
Yes
module
Yes
port
No
stack
No
other
Yes
unknown
No
Entity
hh3cEntityExtTemperatureThreshold(R/W)
chassis
No
backplane
No
container
No
powerSupply
Yes
fan
Yes
sensor
Yes
module
Yes
port
No
stack
No
other
Yes
unknown
No
Entity
hh3cEntityExtVoltage(R)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
No
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtVoltageLowThreshold(R/W)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
No
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtVoltageHighThreshold(R/W)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
No
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtCriticalTemperatureThreshold(R/W)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
Yes
module
No
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtMacAddress (R)
chassis
Yes
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
No
port
No
stack
Yes
other
No
unknown
No
Entity
hh3cEntityExtErrorStatus (R)
chassis
No
backplane
Yes
container
Yes
powerSupply
Yes
fan
Yes
sensor
Yes
module
No
port
Yes
stack
No
other
Yes
unknown
Yes
Entity
hh3cEntityExtManuSerialNum (R)
chassis
Yes
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
Yes
port
No
cpu
No
Entity
hh3cEntityExtManuBuildInfo (R)
chassis
Yes
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
Yes
port
No
cpu
No
Entity
hh3cEntityExtMacAddressCount (R)
chassis
Yes
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
Yes
port
Yes
cpu
No
Entity
hh3cEntityExtManuBOM (R)
Chassis
Yes
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
Yes
port
No
cpu
No
Entity
(R/W: Read/Write)
POWERSUPPLY
FAN
CHASSIS
CONTAINER
MODULE
PORT
CPU
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
hh3cEntityExtTemperatureThreshold (R/W)
hh3cEntityExtVoltage (R)
hh3cEntityExtVoltageLowThreshold (R/W)
hh3cEntityExtVoltageHighThreshold (R/W)
Yes
·     Yes indicates that the extended property is supported.
·     If the read operation returns no such name/instance, the object is not supported in the current entity instance.
MIB file name
hh3c-entity-ext.mib
Notifications
hh3cEntityExtTemperatureThresholdNotification
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.6.2.0.1
Temperature of an entity exceeded the threshold.
Error
Major
1.3.6.1.4.1.25506.2.6.2.0.22 (hh3cEntityExtTemperatureNormal)
ON
Notification triggers
This notification is generated when the temperature of an entity exceeds the upper limit.
System impact
Too high temperature affects normal operation of the system.
Status control
This notification cannot be disabled.
Objects
OID (object)
Index nodes
Value range
1.3.6.1.4.1.25506.2.6.1.1.1.1.1 (hh3cEntityExtPhysicalIndex)
Entity index.
Integer32
Standard MIB values.
1.3.6.1.4.1.25506.2.6.1.1.1.1.12 (hh3cEntityExtTemperature)
Temperature of the entity.
Integer32
1.3.6.1.4.1.25506.2.6.1.1.1.1.13 (hh3cEntityExtTemperatureThreshold)
Temperature threshold for the entity.
Integer32
1.3.6.1.4.1.25506.2.6.1.1.1.1.2 (hh3cEntityExtAdminStatus)
Administrative status of the entity.
Hh3cAdminState
notSupported(1), locked(2), shuttingDown(3), unlocked(4)}
1.3.6.1.4.1.25506.2.6.1.1.1.1.5 (hh3cEntityExtAlarmLight)
Alarm status of the entity.
Hh3cAlarmStatus
BITS {, notSupported(0), underRepair(1), critical(2), major(3), minor(4), alarmOutstanding(5), warning(6), indeterminate(7), }
Recommended action
1.     Verify that the temperature of the environment is normal. Execute the display environment command to obtain temperature information, including the current temperature and the temperature thresholds.
2.     Identify the reason causing the temperature to exceed the upper limit.
3.     Resolve the issue to make sure the temperature drops back to the normal range.
4.     If the issue persists, contact H3C Support.
hh3cEntityExtCpuUsageThresholdNotfication
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.4
CPU usage of an entity exceeded the threshold.
Error
Major
1.3.6.1.4.1.25506.2.6.2.0.25 (hh3cEntityExtCpuUsageThresholdRecover)
ON
This notification is generated when the CPU usage of an entity exceeds the threshold. The notification is sent every 60 seconds till the alarm is cleared.
System impact
The service processing capacity of the system will be reduced.
Status control
Objects
OID (object name)
Index nodes
Value range
Entity index.
Integer32
1.3.6.1.4.1.25506.2.6.1.1.1.1.6 (hh3cEntityExtCpuUsage)
CPU usage of this entity.
Integer32
0..100
1.3.6.1.4.1.25506.2.6.1.1.1.1.7 (hh3cEntityExtCpuUsageThreshold)
CPU usage threshold for the entity.
Integer32
0..100
Hh3cAdminState
Hh3cAlarmStatus
1.3.6.1.4.1.25506.2.6.1.1.1.1.31 (hh3cEntityExtCpuUsageRecoverThreshold)
CPU usage recovery threshold for the entity.
Integer32
0..100
1.3.6.1.4.1.25506.2.6.2.1.4 (hh3cEntityExtFirstTrapTime)
Timestamp at which the notification is sent for the first time.
N/A
TimeTicks
Recommended action
·     If the alarm is automatically cleared, no action is required.
·     If the alarm cannot be automatically cleared, contact H3C Support.
hh3cEntityExtMemUsageThresholdNotification
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.5
Memory usage of an entity exceeded the threshold
Error
Major
1.3.6.1.4.1.25506.2.6.2.0.26 (hh3cEntityExtMemUsageThresholdRecover)
ON
This notification is generated when the total memory size is less than 4 GB and the memory usage of an entity exceeds hh3cEntityExtMemUsageThreshold (memory usage threshold). The notification is sent every 60 seconds till the alarm is cleared.
If the total memory size is equal to or greater than 4 GB, an hh3cEntityExtMemUsageThresholdOverTrap notification is generated when the memory usage exceeds hh3cEntityExtMemUsageThreshold.
System impact
The available memory size is reduced, and the service processing capacity of the system might be affected.
Status control
Objects
OID (object name)
Index nodes
Value range
Entity index.
Integer32
1.3.6.1.4.1.25506.2.6.1.1.1.1.8 (hh3cEntityExtMemUsage)
Integer32
0..100
1.3.6.1.4.1.25506.2.6.1.1.1.1.9 (hh3cEntityExtMemUsageThreshold)
Integer32
0..100
1.3.6.1.4.1.25506.2.6.1.1.1.1.10 (hh3cEntityExtMemSize)
Memory size of the entity.
Unsigned32
Hh3cAdminState
Hh3cAlarmStatus
N/A
TimeTicks
Recommended action
1.     Delete unused services to reduce memory consumption.
2.     If the alarm is automatically cleared, no action is required. If the alarm cannot be automatically cleared, contact H3C Support.
hh3cEntityExtCriticalTemperatureThresholdNotification
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.8
Temperature of an entity exceeded the critical high-temperature threshold.
Error
Critical
ON
This notification is generated when the temperature of an entity exceeded the critical high-temperature threshold. The notification is sent every 80 seconds till the alarm is cleared.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Entity index.
Integer32
Integer32
1.3.6.1.4.1.25506.2.6.1.1.1.1.17 (hh3cEntityExtCriticalTemperatureThreshold)
Critical high-temperature threshold for the entity.
Integer32
Hh3cAdminState
Hh3cAlarmStatus
Recommended action
2.     Identify the reason causing the temperature to exceed the critical high-temperature threshold.
3.     Resolve the issue to make sure the temperature drops back to the normal.
hh3cEntityInsert
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.12
Entity inserted.
Warning
N/A
ON
This notification is generated when an entity is inserted into the device.
System impact
No impact on services.
Status control
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.47.1.1.1.1.2 (entPhysicalDescr)
Description of the entity.
entPhysicalIndex
SnmpAdminString
OCTET STRING (SIZE (0..255))
Hh3cAdminState
1.3.6.1.4.1.25506.2.6.1.1.1.1.3 (hh3cEntityExtOperStatus)
Operation status of the entity.
Hh3cOperState
notSupported(1), disabled(2), enabled(3), dangerous(4)
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
hh3cEntityRemove
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.13
Entity removed.
Error
Minor
1.3.6.1.4.1.25506.2.6.2.0.12 (hh3cEntityInsert)
ON
This notification is generated when an entity is removed from the device.
System impact
Depends on the removed entity.
Status control
Objects
OID (object name)
Index nodes
Value range
entPhysicalIndex
SnmpAdminString
Hh3cAdminState
Operation status for the entity.
Hh3cOperState
Recommended action
1.     If the entity was removed from the device, no action is required.
2.     If the entity was not removed, verify that the entity is installed correctly.
3.     If the issue persists, contact H3C Support.
hh3cEntityExtFaultAlarmOn
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.16
Error occurrence on the entity.
Error
Major
1.3.6.1.4.1.25506.2.6.2.0.17 (hh3cEntityExtFaultAlarmOff)
ON
This notification is generate when an error occurs on the entity.
System impact
Depends on the faulty entity.
Status control
Objects
OID (object name)
Index nodes
Value range
Entity index.
Integer32
1.3.6.1.2.1.47.1.1.1.1.7 (entPhysicalName)
Entity name.
entPhysicalIndex
SnmpAdminString
1.3.6.1.4.1.25506.2.6.1.1.1.1.19 (hh3cEntityExtErrorStatus)
Alarm status for the entity.
INTEGER
notSupported(1), normal(2), postFailure(3), entityAbsent(4), poeError(11), stackError(21), stackPortBlocked(22), stackPortFailed(23), sfpRecvError(31), sfpSendError(32), sfpBothError(33), sfpRecvExceedUpperLimit(34), sfpRecvBelowLowerLimit(35), sfpSendExceedUpperLimit(36), sfpSendBelowLowerLimit(37), fanError(41), psuError(51), rpsError(61), moduleFaulty(71), sensorError(81), hardwareFaulty(91)
Hh3cAdminState
Hh3cAlarmStatus
Recommended action
1.     Verify that the entity is installed correctly.
2.     If the issue persists, contact H3C Support.
Basic information
OID
Event
Severity
Default status
Error clearance from an entity.
Warning
N/A
ON
This notification is generated when an entity recovers from the faulty state.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Entity index.
Integer32
Entity name.
entPhysicalIndex
SnmpAdminString
Error status of the entity.
INTEGER
Hh3cAdminState
Hh3cAlarmStatus
Recommended action
hh3cEntityExtTemperatureLower
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.20
Temperature of an entity dropped below the low-temperature threshold.
Error
Major
ON
This notification is generated when the temperature of an entity decreases below the low-temperature threshold.
System impact
A low temperature affects normal operation of the system.
Status control
Objects
OID (object name)
Index nodes
Value range
Entity index.
Integer32
Entity name.
entPhysicalIndex
SnmpAdminString
Integer32
1.3.6.1.4.1.25506.2.6.1.1.1.1.21 (hh3cEntityExtLowerTemperatureThreshold)
Low-temperature threshold for the entity.
Integer32
Hh3cAdminState
Recommended action
2.     Identify the reason causing the temperature to drop below the lower limit.
3.     Resolve the issue to make sure the temperature increases to the normal range.
hh3cEntityExtTemperatureTooUp
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.21
Temperature of an entity exceeded the shutdown temperature threshold
Error
Critical
ON
This notification is generated when the temperature of an entity exceeds the shutdown temperature threshold. The notification is sent every 80 seconds till the alarm is cleared.
System impact
Too high temperature causes the system to shut down right now or anytime.
Status control
Objects
OID (object name)
Index nodes
Value range
Entity index.
Integer32
Entity name.
entPhysicalIndex
SnmpAdminString
Integer32
1.3.6.1.4.1.25506.2.6.1.1.1.1.22 (hh3cEntityExtShutdownTemperatureThreshold)
Shutdown temperature threshold for the entity.
Integer32
Hh3cAdminState
Recommended action
2.     Identify the reason causing the temperature to exceed the shutdown temperature threshold.
Basic information
OID
Event
Severity
Default status
Temperature of an entity returned to the normal range.
Warning
N/A
ON
This notification is generated when the temperature of an entity returns to the normal range.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Entity index.
Integer32
Entity name.
entPhysicalIndex
SnmpAdminString
Integer32
Integer32
Integer32
Hh3cAdminState
Recommended action
Basic information
OID
Event
Severity
Default status
CPU usage of an entity restored to the normal range.
Warning
N/A
ON
This notification is generated when the CPU usage of an entity restores to the normal range.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Entity index.
Integer32
CPU usage of the entity.
Integer32
0..100
Integer32
0..100
Hh3cAdminState
Hh3cAlarmStatus
Integer32
0..100
N/A
TimeTicks
Recommended action
Basic information
OID
Event
Severity
Default status
Memory usage of an entity restored to the normal range.
Warning
N/A
ON
This notification is generated when the memory usage of an entity restores to the normal range.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Entity index.
Integer32
Memory usage of the entity.
Integer32
0..100
Memory usage threshold for the entity.
Integer32
0..100
Unsigned32
Hh3cAdminState
Hh3cAlarmStatus
N/A
TimeTicks
Recommended action
hh3cEntityExtVoltageNormal
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.37
Voltage of an entity restored to the normal range
Warning
N/A
ON
This notification is generated when the voltage of an entity restores to the normal range.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Entity index.
Integer32
1.3.6.1.4.1.25506.2.6.1.5.1.1.1 (hh3cEntityExtCurrentVoltage)
Voltage of the entity.
Integer32
1.3.6.1.4.1.25506.2.6.1.5.1.1.2 (hh3cEntityExtNominalVoltage)
Rated voltage of the entity.
Integer32
1.3.6.1.4.1.25506.2.6.1.5.1.1.4 (hh3cEntityExtVoltageMajorLowThreshold)
Low-voltage threshold for the entity.
Integer32
1.3.6.1.4.1.25506.2.6.1.5.1.1.6 (hh3cEntityExtVoltageMajorHighThreshold)
High-voltage threshold for the entity.
Integer32
Recommended action
hh3cEntityExtVoltageLower
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.38
Voltage of an entity dropped below the low-voltage threshold
Error
Major
1.3.6.1.4.1.25506.2.6.2.0.37 (hh3cEntityExtVoltageNormal)
ON
This notification is generated when the voltage of an entity drops below the low-voltage threshold.
System impact
The service processing capacity of the system might be affected.
Status control
Objects
OID (object name)
Index nodes
Value range
Entity index.
Integer32
Integer32
Integer32
Integer32
Recommended action
1.     Verify that the power system of the device is normal.
hh3cEntityExtVoltageTooLow
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.39
Voltage of the threshold dropped below critical low-voltage threshold
Error
Critical
ON
This notification is generated when the voltage of the entity drops below the critical low-voltage threshold. The notification is sent every 80 seconds till the alarm is cleared.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Entity index.
Integer32
Integer32
Integer32
1.3.6.1.4.1.25506.2.6.1.5.1.1.5 (hh3cEntityExtVoltageFatalLowThreshold)
Critical low-voltage threshold for the entity.
Integer32
Recommended action
hh3cEntityExtVoltageHigher
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.40
Voltage of an entity exceeded the high-voltage threshold
Error
Major
ON
This notification is generated when the voltage of an entity increases above the high-voltage threshold.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Entity index.
Integer32
Integer32
Integer32
Integer32
Recommended action
hh3cEntityExtVoltageTooHigh
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.41
Voltage of an entity exceeded the critical high-voltage threshold
Error
Critical
ON
This notification is generated when the voltage of an entity increases over the critical high-voltage threshold. The notification is sent every 80 seconds till the alarm is cleared.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Entity index.
Integer32
Integer32
Integer32
1.3.6.1.4.1.25506.2.6.1.5.1.1.7 (hh3cEntityExtVoltageFatalHighThreshold)
Critical high-voltage threshold for the entity.
Integer32
Recommended action
h3cEntityExtSFPPhony
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.11
A counterfeit transceiver module was detected.
Error
Major
N/A
ON
This notification is generated when a counterfeit transceiver module is detected.
System impact
Use of a counterfeit transceiver module might result in communication failure.
Status control
Objects
OID (object name)
Index nodes
Value range
Entity index.
Integer32
Entity name.
entPhysicalIndex
SnmpAdminString
Hh3cAdminState
Hh3cAlarmStatus
Recommended action
To resolve this issue, replace the counterfeit transceiver module with one from H3C.
