02-System Management
HomeSupportRoutersSR6600-M SeriesDiagnose & MaintainAlarms ReferencesH3C SR6608-M Router Alarm Reference-R9141-6W10002-System Management
02-HH3C-COMMON-SYSTEM-MIB
02-HH3C-COMMON-SYSTEM-MIB 60.97 KB
About this MIB
Use this MIB to perform basic operations on the device. For example, access this MIB to reboot the device, obtain basic system information such as reboot mode and system operating mode, and send poweroff alarms. This MIB also contains notifications about device operation changes.
MIB file name
hh3c-common-system.mib
Notifications
hh3cRebootSendTrap
Basic information
OID (object name)
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.6.8.3
The device is to reboot
Informational
Major
N/A
ON
Notification triggers
This notification is generated two seconds before the reboot command is used to reboot the device.
System impact
The system will stop providing services and restart.
Status control
This alarm cannot be disabled.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.145.2.3.1.1 (hh3cLicenseFeatureName)
Name of a licensed feature.
hh3cLicensePhysicalIndex
SnmpAdminString
OCTET STRING (SIZE (1..31))
1.3.6.1.4.1.25506.2.145.2.3.1.2 (hh3cLicenseFeatureState)
Licensing state of the feature.
INTEGER
notLicensed(1), trialLicense(2), formalLicense(3)
1.3.6.1.4.1.25506.2.145.3.1.1 (hh3cLicenseBindValidityPeriodRemaining)
Remaining days before the license expires.
N/A
Unsigned32
Standard MIB values.
Recommended action
No action is required.
hh3cSysColdStartTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.6.8.4
A cold boot was performed
Informational
Warning
N/A
ON
This notification is generated when a cold boot is performed on the device.
System impact
No negative impact on the system.
Status control
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.6.11.10 (hh3cSysFirstTrapTime)
Time when the alarm occurred.
N/A
TimeTicks
Recommended action
hh3cSysWarmStartTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.6.8.5
A warm boot was performed
Informational
Warning
N/A
ON
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
TimeTicks
Recommended action
hh3cSysDyingGaspTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.6.8.7
Poweroff alarm
Informational
Critical
N/A
ON
This alarm occurs when the device is powered off.
System impact
The system will be powered off and stop providing services.
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
TimeTicks
Recommended action
Verify that the power cord is connected correctly.
