12-UDP-MIB | 76.98 KB |
UDP-MIB
About this MIB
This MIB is defined by RFC 4113. Use this MIB to obtain the UDP endpoint information and UDP packet statistics.
MIB file name
rfc4113-udp.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).udp(7)
Scalar objects
udpInDatagrams (1.3.6.1.2.1.7.1)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
udpInDatagrams (1.3.6.1.2.1.7.1) |
read- only |
Counter32 |
Standard MIB values. |
Total number of UDP datagrams delivered to applications. |
As per the MIB. |
udpNoPorts (1.3.6.1.2.1.7.2)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
udpNoPorts (1.3.6.1.2.1.7.2) |
read-only |
Counter32 |
Total number of received UDP datagrams for which no application exist at the destination port. |
As per the MIB. |
udpInErrors (1.3.6.1.2.1.7.3)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
udpInErrors (1.3.6.1.2.1.7.3) |
read-only |
Counter32 |
Number of received UDP datagrams that cannot be delivered for reasons other than the lack of an application at the destination port. |
As per the MIB. |
udpOutDatagrams (1.3.6.1.2.1.7.4)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
udpOutDatagrams (1.3.6.1.2.1.7.4) |
read-only |
Counter32 |
Total number of UDP datagrams sent from this end. |
As per the MIB. |
Tabular objects
udpTable
About this table
Use this table to obtain IPv4 UDP listener information.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table indexes are udpLocalAddress and udpLocalPort.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
udpLocalAddress (1.3.6.1.2.1.7.5.1.1) |
read-only |
IpAddress |
Local IP address for the UDP listener. The value 0.0.0.0 indicates that the UDP listener can accept datagrams for any interface. |
As per the MIB. |
udpLocalPort (1.3.6.1.2.1.7.5.1.2) |
read-only |
Integer32 |
Integer32 (0..65535) |
Local port number for the UDP listener. |
As per the MIB. |
