06-HH3C-NAT-MIB | 151.76 KB |
hh3cNATBandwidthRatio (1.3.6.1.4.1.25506.2.18.2.15.1.1)
hh3cNATChassis (1.3.6.1.4.1.25506.2.18.2.15.1.2)
hh3cNATSlot (1.3.6.1.4.1.25506.2.18.2.15.1.3)
hh3cNATCpu (1.3.6.1.4.1.25506.2.18.2.15.1.4)
hh3cInstAddrTrapInstName (1.3.6.1.4.1.25506.2.18.2.18.1.1)
hh3cInstAddrTrapGrpIndex (1.3.6.1.4.1.25506.2.18.2.18.1.2)
hh3cInstAddrTrapInstIndex (1.3.6.1.4.1.25506.2.18.2.18.1.3)
hh3cInstAddrTrapUsgThreshold (1.3.6.1.4.1.25506.2.18.2.18.1.4)
hh3cNatTrapIPPoolName (1.3.6.1.4.1.25506.2.18.2.20.1.1)
hh3cNatTrapIPPoolAddrUsage (1.3.6.1.4.1.25506.2.18.2.20.1.2)
hh3cNatTrapIPPoolMemStartIP (1.3.6.1.4.1.25506.2.18.2.20.1.3)
hh3cNatTrapIPPoolMemIPMask (1.3.6.1.4.1.25506.2.18.2.20.1.4)
hh3cNatTrapIPPoolFailReason (1.3.6.1.4.1.25506.2.18.2.20.1.5)
hh3cNatTrapAddrGrpIndex (1.3.6.1.4.1.25506.2.18.2.21.1.1)
hh3cNatTrapAddrGrpChassis (1.3.6.1.4.1.25506.2.18.2.21.1.10)
hh3cNatTrapAddrGrpSlot (1.3.6.1.4.1.25506.2.18.2.21.1.11)
hh3cNatTrapAddrGrpCpu (1.3.6.1.4.1.25506.2.18.2.21.1.12)
hh3cNatTrapUserIPType (1.3.6.1.4.1.25506.2.18.2.21.1.2)
hh3cNatTrapUserIP (1.3.6.1.4.1.25506.2.18.2.21.1.3)
hh3cNatTrapUserID (1.3.6.1.4.1.25506.2.18.2.21.1.4)
hh3cNatTrapAddrGrpMemberIP (1.3.6.1.4.1.25506.2.18.2.21.1.5)
hh3cNatTrapMemberIPPortNums (1.3.6.1.4.1.25506.2.18.2.21.1.6)
HH3C-NAT-MIB
About this MIB
Use this MIB to obtain NAT information.
MIB file name
hh3c-nat.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cNat(18)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNATBandwidthRatio (1.3.6.1.4.1.25506.2.18.2.15.1.1) |
accessible-for-notify |
Unsigned32 |
Standard MIB values. |
Bandwidth usage threshold. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNATChassis (1.3.6.1.4.1.25506.2.18.2.15.1.2) |
Unsigned32 |
(0..65534) |
Chassis number. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNATSlot (1.3.6.1.4.1.25506.2.18.2.15.1.3) |
Unsigned32 |
(0..65534) |
Slot number. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNATCpu (1.3.6.1.4.1.25506.2.18.2.15.1.4) |
Unsigned32 |
(0..7) |
CPU number. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cInstAddrTrapInstName (1.3.6.1.4.1.25506.2.18.2.18.1.1) |
DisplayString |
(1..32) |
Global NAT instance name. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cInstAddrTrapGrpIndex (1.3.6.1.4.1.25506.2.18.2.18.1.2) |
Unsigned32 |
(1..65536) |
Index of the address group. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cInstAddrTrapInstIndex (1.3.6.1.4.1.25506.2.18.2.18.1.3) |
Unsigned32 |
(1..127) |
Index of the global NAT instance. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cInstAddrTrapUsgThreshold (1.3.6.1.4.1.25506.2.18.2.18.1.4) |
Unsigned32 |
(0..100) |
Resource usage threshold for the NAT address group. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNatTrapIPPoolName (1.3.6.1.4.1.25506.2.18.2.20.1.1) |
OCTET STRING |
SIZE (1..32) |
NAT address pool name. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNatTrapIPPoolAddrUsage (1.3.6.1.4.1.25506.2.18.2.20.1.2) |
Unsigned32 |
(1..100) |
IP usage of the NAT address pool. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNatTrapIPPoolMemStartIP (1.3.6.1.4.1.25506.2.18.2.20.1.3) |
IpAddress |
Start address of the address range. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNatTrapIPPoolMemIPMask (1.3.6.1.4.1.25506.2.18.2.20.1.4) |
OCTET STRING |
SIZE(0..32) |
Mask for the address range. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNatTrapIPPoolFailReason (1.3.6.1.4.1.25506.2.18.2.20.1.5) |
OCTET STRING |
SIZE (1..127) |
Reason why the address range fails to be added. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNatTrapAddrGrpIndex (1.3.6.1.4.1.25506.2.18.2.21.1.1) |
INTEGER32 |
(1..65536) |
Address group index. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNatTrapAddrGrpChassis (1.3.6.1.4.1.25506.2.18.2.21.1.10) |
INTEGER32 |
(0..65534) |
Chassis number. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNatTrapAddrGrpSlot (1.3.6.1.4.1.25506.2.18.2.21.1.11) |
INTEGER32 |
(0..65534) |
Slot number. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNatTrapAddrGrpCpu (1.3.6.1.4.1.25506.2.18.2.21.1.12) |
INTEGER32 |
(0..7) |
CPU number. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNatTrapUserIPType (1.3.6.1.4.1.25506.2.18.2.21.1.2) |
InetAddressType |
ipv4(1) ipv6(2) |
Type of the user private IP address. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNatTrapUserIP (1.3.6.1.4.1.25506.2.18.2.21.1.3) |
InetAddress |
OCTET STRING (0..255) |
User private IP address. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNatTrapUserID (1.3.6.1.4.1.25506.2.18.2.21.1.4) |
INTEGER32 |
User ID. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNatTrapAddrGrpMemberIP (1.3.6.1.4.1.25506.2.18.2.21.1.5) |
IpAddress |
Public IP address. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNatTrapMemberIPPortNums (1.3.6.1.4.1.25506.2.18.2.21.1.6) |
INTEGER32 |
(1..65536) |
Port count. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
INTEGER32 |
(0..65534) |
Chassis number. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
INTEGER32 |
(0..65534) |
Slot number. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
INTEGER32 |
(0..7) |
CPU number. |
As per the MIB. |
Tabular objects
hh3cNATStatVer2Table
About this table
This table obtains NAT statistics of version 2.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table indexes are hh3cNATStatChassis, hh3cNATStatSlot, and hh3cNATStatCPUID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNATStatChassis (1.3.6.1.4.1.25506.2.18.2.13.1.1) |
not-accessible |
Unsigned32 |
0..65534 |
Chassis number. |
As per the MIB. |
hh3cNATStatSlot (1.3.6.1.4.1.25506.2.18.2.13.1.2) |
not-accessible |
Unsigned32 |
0..65534 |
Slot number. |
As per the MIB. |
hh3cNATStatCPUID (1.3.6.1.4.1.25506.2.18.2.13.1.3) |
not-accessible |
Unsigned32 |
0..7 |
CPU number. |
As per the MIB. |
hh3cNATTotalNATSessionCount (1.3.6.1.4.1.25506.2.18.2.13.1.4) |
read-only |
Unsigned32 |
Total number of NAT sessions. |
As per the MIB. |
hh3cNATEimTableCount (1.3.6.1.4.1.25506.2.18.2.13.1.5) |
read-only |
Unsigned32 |
Number of EIM entries. |
As per the MIB. |
hh3cNATInboundNoPATTableCount (1.3.6.1.4.1.25506.2.18.2.13.1.6) |
read-only |
Unsigned32 |
NO-PAT entries generated for the inbound NAT translation. |
As per the MIB. |
hh3cNATOutboundNoPATTableCount (1.3.6.1.4.1.25506.2.18.2.13.1.7) |
read-only |
Unsigned32 |
NO-PAT entries generated for the outbound NAT translation. |
As per the MIB. |
hh3cNATMaxDynamicPortblock (1.3.6.1.4.1.25506.2.18.2.13.1.8) |
read-only |
Unsigned32 |
Number of NAT444 dynamic port blocks. |
As per the MIB. |
hh3cNATMaxStaticPortblock (1.3.6.1.4.1.25506.2.18.2.13.1.9) |
read-only |
Unsigned32 |
Number of NAT444 static port blocks. |
As per the MIB. |
hh3cNATActiveDynamicPortblock (1.3.6.1.4.1.25506.2.18.2.13.1.10) |
read-only |
Unsigned32 |
Number of active NAT444 dynamic port blocks. |
As per the MIB. |
hh3cNATActiveStaticPortblock (1.3.6.1.4.1.25506.2.18.2.13.1.11) |
read-only |
Unsigned32 |
Number of active NAT444 static port blocks. |
As per the MIB. |
hh3cNatIPPoolGroupTable
About this table
Use this table to obtain NAT address group resources usage in a NAT instance.
Read:Supported
Columns
The table index is hh3cNatIPPoolName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNatIPPoolName (1.3.6.1.4.1.25506.2.18.2.19.1.1) |
not-accessible |
Unsigned32 |
OCTET STRING |
Name of the NAT address pool. |
As per the MIB. |
hh3cNatIPPoolAddrUsage (1.3.6.1.4.1.25506.2.18.2.19.1.2) |
read-only |
IpAddress |
Unsigned32 |
NAT address pool usage. |
As per the MIB. |
hh3cNatIPPoolTotalCount (1.3.6.1.4.1.25506.2.18.2.19.1.3) |
read-only |
Unsigned32 |
Unsigned32 |
Total number of IP addresses in the NAT address pool. |
As per the MIB. |
hh3cNatIPPoolUsedCount (1.3.6.1.4.1.25506.2.18.2.19.1.4) |
read-only |
Unsigned32 |
Unsigned32 |
Number of used IP addresses in the NAT address pool. |
As per the MIB. |
hh3cNatIPPoolUnusedCount (1.3.6.1.4.1.25506.2.18.2.19.1.5) |
read-only |
OCTET STRING |
Unsigned32 |
Number of unused IP addresses in the NAT address pool. |
As per the MIB. |
