08-IP-FORWARD-MIB | 104.34 KB |
ipCidrRouteNumber(1.3.6.1.2.1.4.24.3)
inetCidrRouteNumber (1.3.6.1.2.1.4.24.6)
inetCidrRouteDiscards (1.3.6.1.2.1.4.24.8)
ipForwardNumber (1.3.6.1.2.1.4.24.1)
IP-FORWARD-MIB
About this MIB
Use this MIB to configure IP routes for Classless Inter-Domain Routing (CIDR).
MIB file name
rfc4292-ip-forward.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).ip(4).ipForward(24)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipCidrRouteNumber(1.3.6.1.2.1.4.24.3) |
read-only |
Gauge32 |
Standard MIB values. |
Number of current valid ipCidrRouteTable entries. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
inetCidrRouteNumber (1.3.6.1.2.1.4.24.6) |
read-only |
Gauge32 |
Number of current valid inetCidrRouteTable entries. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
inetCidrRouteDiscards (1.3.6.1.2.1.4.24.8) |
read-only |
Counter32 |
Number of invalid entries dropped by inetCidrRouteTable. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipForwardNumber (1.3.6.1.2.1.4.24.1) |
read-only |
Gauge32 |
Number of valid ipForwardTable entries. |
As per the MIB. |
Tabular objects
ipCidrRouteTable
About this table
This table can implement routing table function on an entity. This table is obsolete. To implement routing table function on an entity, use table inetCidrRouteTable.
Support for operations
Create:Supported
Edit/Modify:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are ipCidrRouteDest, ipCidrRouteMask, ipCidrRouteTos, and ipCidrRouteNextHop.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipCidrRouteDest(1.3.6.1.2.1.4.24.4.1.1) |
read-only |
IpAddress |
(0..255) |
Destination IP address of the route. |
As per the MIB. |
ipCidrRouteMask(1.3.6.1.2.1.4.24.4.1.2) |
read-only |
IpAddress |
(0..255) |
Address mask. |
As per the MIB. |
ipCidrRouteTos(1.3.6.1.2.1.4.24.4.1.3) |
read-only |
Integer32 |
ToS field value. |
The value is always 0. |
ipCidrRouteNextHop(1.3.6.1.2.1.4.24.4.1.4) |
read-only |
IpAddress |
(0..255) |
Address of the next hop. |
As per the MIB. |
ipCidrRouteIfIndex(1.3.6.1.2.1.4.24.4.1.5) |
read-create |
Integer32 |
Interface index. |
Read only. |
ipCidrRouteType(1.3.6.1.2.1.4.24.4.1.6) |
read-create |
INTEGER |
Type of the route. |
Read only. |
ipCidrRouteProto(1.3.6.1.2.1.4.24.4.1.7) |
read-only |
INTEGER |
Protocol type. |
As per the MIB. |
ipCidrRouteAge(1.3.6.1.2.1.4.24.4.1.8) |
read-only |
Integer32 |
Time since the route was last updated. |
As per the MIB. |
ipCidrRouteInfo(1.3.6.1.2.1.4.24.4.1.9) |
read-create |
OBJECT IDENTIFIER |
Route information. |
The value is always 0. Read only. |
ipCidrRouteNextHopAS(1.3.6.1.2.1.4.24.4.1.10) |
read-create |
Integer32 |
AS number of the next hop. |
ipCidrRouteMetric1(1.3.6.1.2.1.4.24.4.1.11) |
read-create |
Integer32 |
Primary routing metric of the route. |
Read only. |
ipCidrRouteMetric2(1.3.6.1.2.1.4.24.4.1.12) |
read-create |
Integer32 |
Alternate routing metric of the route. |
The value is always -1. Read only. |
ipCidrRouteMetric3(1.3.6.1.2.1.4.24.4.1.13) |
read-create |
Integer32 |
ipCidrRouteMetric4(1.3.6.1.2.1.4.24.4.1.14) |
read-create |
Integer32 |
ipCidrRouteMetric5(1.3.6.1.2.1.4.24.4.1.15) |
read-create |
Integer32 |
ipCidrRouteStatus(1.3.6.1.2.1.4.24.4.1.16) |
read-create |
INTEGER |
Row status variable, used according to row installation and deletion conventions. |
Read only. |
inetCidrRouteTable
About this table
Use this table to obtain IP version-independent multipath CIDR routes.
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table indexes are inetCidrRouteDestType, inetCidrRouteDest, inetCidrRoutePfxLen, inetCidrRoutePolicy, and inetCidrRouteNextHop.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
inetCidrRouteDestType (1.3.6.1.2.1.4.24.7.1.1) |
not-accessible |
Integer32 |
Destination address family. |
As per the MIB. |
inetCidrRouteDest (1.3.6.1.2.1.4.24.7.1.2) |
not-accessible |
Octets |
(0..255) |
Destination address. |
As per the MIB. |
inetCidrRoutePfxLen (1.3.6.1.2.1.4.24.7.1.3) |
not-accessible |
Gauge32 |
Prefix length of the destination address. |
As per the MIB. |
inetCidrRoutePolicy (1.3.6.1.2.1.4.24.7.1.4) |
not-accessible |
Object Identifier |
General set of route information. |
As per the MIB. |
inetCidrRouteNextHopType (1.3.6.1.2.1.4.24.7.1.5) |
not-accessible |
Integer32 |
Next hop address family. |
As per the MIB. |
inetCidrRouteNextHop (1.3.6.1.2.1.4.24.7.1.6) |
not-accessible |
Octets |
(0..255) |
As per the MIB. |
inetCidrRouteIfIndex (1.3.6.1.2.1.4.24.7.1.7) |
read-create |
Integer32 |
Output interface. |
Read only. |
inetCidrRouteType (1.3.6.1.2.1.4.24.7.1.8) |
read-create |
Integer32 |
Only supports remote, local, and blackhole. Read only. |
inetCidrRouteProto (1.3.6.1.2.1.4.24.7.1.9) |
read-only |
Integer32 |
Routing protocol type. |
Supports local, netmgmt, rip, ospf, is-is, bgp, and other (unspecified). |
inetCidrRouteAge (1.3.6.1.2.1.4.24.7.1.10) |
read-only |
Gauge32 |
Lifetime of the route. |
As per the MIB. |
inetCidrRouteNextHopAS (1.3.6.1.2.1.4.24.7.1.11) |
read-create |
Gauge32 |
inetCidrRouteMetric1 (1.3.6.1.2.1.4.24.7.1.12) |
read-create |
Integer32 |
Routing metric in the protocol. |
Read only. |
inetCidrRouteMetric2 (1.3.6.1.2.1.4.24.7.1.13) |
read-create |
Integer32 |
inetCidrRouteMetric3 (1.3.6.1.2.1.4.24.7.1.14) |
read-create |
Integer32 |
inetCidrRouteMetric4 (1.3.6.1.2.1.4.24.7.1.15) |
read-create |
Integer32 |
inetCidrRouteMetric5 (1.3.6.1.2.1.4.24.7.1.16) |
read-create |
Integer32 |
inetCidrRouteStatus (1.3.6.1.2.1.4.24.7.1.17) |
read-create |
Integer32 |
Row status. |
Read only. |
