10-WLAN
HomeSupportDiagnose & MaintainAlarms ReferencesH3C Wireless Products Alarm Reference(R54xx)-6W10010-WLAN
06-HH3C-WLAN-FLEXAPP-CFG-MIB
06-HH3C-WLAN-FLEXAPP-CFG-MIB 115.10 KB
About this MIB
Use this MIB to manage IoT service and wireless location settings.
IoT service settingsIoT module and BLE location settings, and notifications triggered by the access, removal, and type mismatch of an IoT module.
Wireless location settingsAeroScout location, CUPID location, and RF fingerprinting settings, and shared wireless location settings.
MIB file name
hh3c-wlan-flexapp-cfg.mib
Notifications
hh3cWlanModuleInsertTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.75.19.3.0.1
An IoT module is inserted.
Informational
Warning
N/A (N/A)
OFF
Notification triggers
This notification is generated when an IoT module comes online.
System impact
No negative impact on services.
Status control
ON
CLI: Use the snmp-agent trap enable wlan location-aware command.
OFF
CLI: Use the undo snmp-agent trap enable wlan location-aware command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.75.19.3.1.1 (hh3cWlanTrapAPMacAddress)
MAC address of the AP.
N/A
MacAddress
OCTET STRING (6)
1.3.6.1.4.1.25506.2.75.19.3.1.2 (hh3cWlanTrapModuleID)
ID of the inserted module.
N/A
Integer32
Integer32(1..255)
1.3.6.1.4.1.25506.2.75.19.3.1.4 (hh3cWlanTrapModulePhyType)
Physical type of the IoT module.
N/A
INTEGER
None(0), h3c(1), iot(2)
1.3.6.1.4.1.25506.2.75.19.3.1.5 (hh3cWlanTrapModuleModel)
IoT module model.
N/A
OCTET STRING
OCTET STRING (0..32)
1.3.6.1.4.1.25506.2.75.19.3.1.6 (hh3cWlanTrapModuleHwVersion)
Hardware version number of the IoT module.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.75.19.3.1.7 (hh3cWlanTrapModuleSwVersion)
Software version number of the IoT module.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.75.19.3.1.8 (hh3cWlanTrapModuleSequenceId)
Hardware serial number of the IoT module.
N/A
OCTET STRING
Recommended action
No action is required.
hh3cWlanModuleRomveTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.19.3.0.2
An IoT module is moved.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when an IoT module is removed.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
MacAddress
OCTET STRING (6)
N/A
Integer32
Integer32(1..255)
N/A
INTEGER
IoT module model.
N/A
OCTET STRING
N/A
OCTET STRING
N/A
OCTET STRING
N/A
OCTET STRING
Recommended action
hh3cWlanModuleMissMatch
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.19.3.0.3
The physical type of an IoT module does not match the configured type.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when the physical type and configured type of an IoT module are inconsistent.
System impact
The IoT module cannot operate correctly.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
MacAddress
OCTET STRING (6)
N/A
Integer32
Integer32(1..255)
1.3.6.1.4.1.25506.2.75.19.3.1.3 (hh3cWlanTrapModuleCfgType)
Configured type of the IoT module.
N/A
INTEGER
none(0), h3c(1), iot(2)
N/A
INTEGER
IoT module model.
N/A
OCTET STRING
Recommended action
Verify that the configured type of the IoT module matches its physical type.
