03-HH3C-DOT11-RRM-MIB | 57.37 KB |
HH3C-DOT11-RRM-MIB
About this MIB
Use this MIB to manage wireless resources.
MIB file name
hh3c-dot11-rrm.mib
Notifications
hh3cDot11RRMIntrfLimit
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.75.8.3.1.0.1 |
Air interface interference crossing threshold alarm. |
Informational |
Warning |
N/A (N/A) |
Off |
Notification triggers
This notification is triggered when the air interface detects that channel interference exceeds the specified threshold.
System impact
None.
Status control
ON
CLI: Use the snmp-agent trap enable wlan rrm command.
OFF
CLI: Use the undo snmp-agent trap enable wlan rrm command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.75.8.2.1.1.8 (hh3cDot11RRMChlRptIntrf) |
Channel interference. |
N/A |
Integer32 |
Integer32, (0..100) |
Recommended action
1.No action is required.
hh3cDot11RRMPERLimit
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.8.3.1.0.2 |
Error packet crossing threshold alarm |
Informational |
Warning |
N/A (N/A) |
Off |
This notification is triggered when the air interface detects that the proportion of received error packets exceeds the specified threshold.
System impact
No impact on services.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.75.8.2.1.1.9 (hh3cDot11RRMChlRptPER) |
Error packet ratio |
N/A |
Integer32 |
Recommended action
hh3cDot11RRMPowerChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.8.3.2.0.1 |
Power change notification |
Informational |
Warning |
N/A (N/A) |
Off |
This notification is triggered when the transmission power of a radio changes.
System impact
No negative impact on the system.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.75.8.2.1.1.1 (hh3cDot11RRMRadioIndex) |
RADIO ID |
N/A |
Integer32 |
Integer32, (1..4) |
1.3.6.1.4.1.25506.2.75.8.3.3.1 (hh3cDot11NewPower) |
New power value. |
N/A |
Integer32 |
Integer32, (1..100) |
1.3.6.1.4.1.25506.2.75.8.3.3.2 (hh3cDot11OldPower) |
Old power value. |
N/A. |
Integer32 |
Recommended action
