01-HH3C-DOT11-APMT-MIB | 219.54 KB |
hh3cDot11APMtRadioFailRecoverTrap
hh3cDot11DFSFreeCntBelowThrRecov
hh3cDot11APTrapUserCntExceedThre
hh3cDot11DetcAdjChlIntfAPClear
HH3C-DOT11-APMT-MIB
About this MIB
Use this MIB to obtain AP information.
MIB file name
hh3c-dot11-apmt.mib
Notifications
hh3cDot11APMtCfgErrorTrap
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.2 |
AP configuration error |
Informational |
Warning |
N/A (N/A) |
OFF |
Notification triggers
This notification is generated when an error occurs during AP configuration on the AC.
System impact
Configuration deployment fails.
Status control
ON
CLI: snmp-agent trap enable wlan ap
OFF
CLI: undo snmp-agent trap enable wlan ap
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.75.2.1.1.1.1 (hh3cDot11APID) |
Serial number of the AP |
N/A |
Hh3cDot11ObjectIDType |
OCTET STRING (0..127) |
1.3.6.1.4.1.25506.2.75.2.1.3.1.2 (hh3cDot11RadioID) |
Radio ID |
N/A |
Integer32 |
Integer32(0..2147483647) |
1.3.6.1.4.1.25506.2.75.2.3.1.1 (hh3cDot11APMtTrapCfgErrReason) |
Reason |
N/A |
Hh3cDot11NotifyReasonType |
OCTET STRING(0..255) |
Recommended action
No action is required.
hh3cDot11APMtRadioFailTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.3 |
AP radio down |
Informational |
Warning |
1.3.6.1.4.1.25506.2.75.2.3.0.4 (hh3cDot11APMtRadioFailRecoverTrap) |
OFF |
When the AC receives the update configuration response message, if the configuration update fails, and the reason is the failure to set the channel, failure to set the RD status, failure to set the hardware retrys, failure to set the beacon interval, failure to set the RD operating mode, or failure to set the preamble, it sends this trap.
System impact
Radio is unavailable.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
OCTET STRING(0..127) |
Radio ID |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.75.2.3.1.2 (hh3cDot11APMtTrapRadioFailReason) |
Reason for the down event |
N/A |
INTEGER |
config(1) , hh3cerror(2) , swerror(3) , radar(4) , unknown(8) |
Recommended action
Redeploy the configuration.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.4 |
AP radio up |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is generated when a radio comes up.
System impact
Radio is available.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Radio ID |
N/A |
Integer32 |
N/A |
INTEGER |
Recommended action
hh3cDot11APMtRdoChanlChgTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.5 |
Radio channel change |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the channel of a radio changes.
System impact
No negative impact on services.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Radio ID |
N/A |
Integer32 |
Standard MIB values. |
1.3.6.1.4.1.25506.2.75.2.3.1.5 (hh3cDot11APChannelChgMode) |
Channel type change |
N/A |
Hh3cDot11RFModeType |
manual(1),, auto(2) |
1.3.6.1.4.1.25506.2.75.2.3.1.3 (hh3cDot11APMtTrapOldChannel) |
Previous channel number |
N/A |
Hh3cDot11ChannelScopeType |
Integer32, Standard MIB values. |
1.3.6.1.4.1.25506.2.75.2.3.1.4 (hh3cDot11APMtTrapNewChannel) |
New channel number |
N/A |
1.3.6.1.4.1.25506.2.75.2.3.1.16 (hh3cDot11APMtChanlChgCount) |
Number of changes |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.75.2.3.1.24 (hh3cDot11APMtTrapAPMacAddress) |
Corresponding MAC |
N/A |
MacAddress |
OCTET STRING(6) |
Recommended action
hh3cDot11APMtTimeSynFail
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.6 |
AP clock synchronization failed |
Informational |
Warning |
N/A (N/A) |
OFF |
AC will regularly send clock synchronization requests to all successfully registered APs. If no corresponding response is received, the system will send a "clock synchronization alarm." Only when the AC sends update config to the AP will it carry a timestamp. If the AP response times out, this alarm will be triggered. In other cases, the AP will not respond to this timestamp.
Possible causes include:
If the master AC sends an update config message at master/backup AC switchover, this notification is sent.
When setting echo-interval, the AC will send an update config to the AP, at which point the AP will respond, thus not meeting the alarm sending condition; If the AP is disconnected and then echo-interval is set again, the AP response will inevitably time out, triggering the alarm.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Recommended action
hh3cDot11APMtChlIntfDetected
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.7 |
Channel interference detected |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the AP detects interference.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable wlan rrm command.
OFF
CLI: Use the undo snmp-agent trap enable wlan rrm command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.75.2.1.3.1.5 (hh3cDot11Channel) |
Channel |
N/A |
Integer32 |
Recommended action
hh3cDot11APMtIntfAPDetected
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.8 |
AP detected |
Informational |
Warning |
1.3.6.1.4.1.25506.2.75.2.3.0.16 (hh3cDot11APInterfClearTrap) |
OFF |
This notification is generated when the system detects the presence of wireless APs.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Channel |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.75.2.3.1.7 (hh3cDot11APIntfDevMACAddress) |
MAC address |
N/A |
MacAddress |
OCTET STRING(6) |
Recommended action
hh3cDot11APFlashWriteFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.11 |
AP flash write-in failed |
Informational |
Major |
N/A (N/A) |
OFF |
This alarm is generated if the AP fails to write data into the flash.
System impact
Failed to update the AP version.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
1.3.6.1.4.1.25506.2.75.2.3.1.17 (hh3cDot11APMtFormerApVersion) |
Original version number |
N/A |
OCTET STRING |
OCTET STRING |
MAC address of the AP |
N/A |
MacAddress |
OCTET STRING(6) |
Recommended action
Identify whether the issue is caused by insufficient memory or insufficient flash.
hh3cDot11APMtAvailChlTooLow
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.13 |
Low number of available channels |
Informational |
Warning |
1.3.6.1.4.1.25506.2.75.2.3.0.27 (hh3cDot11DFSFreeCntBelowThrRecov) |
OFF |
When an AP performs auto channel selection and all detected channels are in a bad condition, this alarm is generated.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Radio ID |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.75.2.3.1.18 (hh3cDot11APMtAPID) |
AP Identifier |
N/A |
OCTET STRING(1..127) |
MAC address |
N/A |
MacAddress |
OCTET STRING(6) |
Recommended action
hh3cDot11APImgDwldSuccess
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.14 |
AP image downloading succeeded |
Informational |
Warning |
N/A (N/A) |
OFF |
If the versions of AP and AC do not match, the AP will automatically download the version. When the version download is complete, the AC will send this alarm.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.75.2.1.2.1.8 (hh3cDot11CurrAPName) |
AP Name |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.75.2.1.2.1.2 (hh3cDot11CurrAPIPAddress) |
AP IP Address |
N/A |
IpAddress |
1.3.6.1.4.1.25506.2.75.2.1.2.1.11 (hh3cDot11CurrAPSoftwareVersion) |
Current version number of AP |
N/A |
OCTET STRING |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.16 |
Co-channel interference from adjacent APs removed |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the AP no longer detects any co-channel AP or when the signal strength of all co-channel APs is less than hh3cDot11IntfTrapThreshold (default value -60dBm).
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Channel |
N/A |
Integer32 |
As stipulated in the 802.11x protocol |
AP Identifier |
N/A |
1.3.6.1.4.1.25506.2.75.2.3.1.19 (hh3cDot11APMtRadioID) |
Radio ID |
N/A |
Hh3cDot11RadioScopeType |
1.3.6.1.4.1.25506.2.75.2.3.1.21 (hh3cDot11APMtInterfMacAdd) |
MAC address |
N/A |
MacAddress |
OCTET STRING(6) |
1.3.6.1.4.1.25506.2.75.2.3.1.23 (hh3cDot11APMtFirstTrapTime) |
Timestamp. |
N/A |
Timeticks |
Neighbor MAC address |
N/A |
MacAddress |
OCTET STRING(6) |
Recommended action
hh3cDot11APRadioDownTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.23 |
Wireless link terminated |
Informational |
Major |
1.3.6.1.4.1.25506.2.75.2.3.0.24 (hh3cDot11APRadioDownRecovTrap) |
OFF |
When the radio changes from UP to Down, it will trigger this alarm.
Possible reasons for this alarm include:
AP offline when tunnel is down.
When the radio interface is down, for example, radio disable. (Note: When the radio status changes, such as enabling or disabling the radio, and when the CAPWAP tunnel is disconnected, an alarm will be triggered. Removing the last service template for the radio to delete the AP, but not disabling the radio status, will not trigger this alarm.)
When hwSysTrapCollectionPeriod times out, and the time interval since the last trap transmission exceeds hwSysTrapResendPeriod, this alarm will be sent repeatedly.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Radio ID |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.75.2.3.1.12 (hh3cDot11APRadioDownReason) |
N/A |
INTEGER |
phyicalUnusable(1) , configDisable(2) operatinUnusable(3) , apTunnelDown(4) |
N/A |
First occurrence time |
N/A |
TimeTicks |
N/A |
MacAddress |
OCTET STRING (6) |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.24 |
Wireless link recovered |
Informational |
Major |
N/A (N/A) |
OFF |
When the Radio of Ap changes from Down to UP, this alarm will be triggered. After a "wireless link disruption" occurs, if the following conditions happen, the system detects that the air interface can provide wireless service, then sends a "link recovery" alarm:
When the radio interface changes from down to up, for example, radio enable. (Note: This trap is sent when the radio status changes, i.e., enabling a previously disabled radio. However, this alarm is not triggered if the radio is enabled for the first time after the AP comes online.)
System impact
The radio is not available.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Radio ID |
N/A |
Integer32 |
N/A |
INTEGER |
N/A |
N/A |
TimeTicks |
N/A |
MacAddress |
OCTET STRING (6) |
Recommended action
hh3cDot11APStaFullTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.25 |
Client quantity upper limit reached |
Informational |
Warning |
1.3.6.1.4.1.25506.2.75.2.3.0.26 (hh3cDot11APStaFullRecoverTrap) |
OFF |
When the number of clients is about to exceed the maximum value allowed by the AP, this alarm will be triggered.
System impact
Status control
ON
CLI: snmp-agent trap enable wlan client
OFF
CLI: undo snmp-agent trap enable wlan client
Object
OID (object name) |
Index |
Type |
Value range |
APID |
N/A |
1.3.6.1.4.1.25506.2.75.2.3.1.11 (hh3cDot11StaLimitNumber) |
Maximum number of clients on the AP. |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.75.2.3.1.10 (hh3cDot11StaFullReason) |
Reasons for the number of clients reaching the upper limit |
N/A |
INTEGER |
ap(1), bss(2), radio(3), radioConcur(4), radiopolicy(5), ac(6), acConcur(7), aid(8) |
First alarm time |
N/A |
TimeTicks |
MAC address of the AP. |
N/A |
MacAddress |
OCTET STRING (6) |
Recommended action
Check the configuration or add more APs.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.26 |
Upper limit-reaching alarm removed for associated client quantity |
Informational |
Warning |
N/A (N/A) |
OFF |
The number of clients dropped below the maximum allowed number. .
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
APID |
N/A |
N/A |
Integer32 |
Reason |
N/A |
INTEGER |
First alarm time |
N/A |
TimeTicks |
N/A |
MacAddress |
OCTET STRING (6) |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.27 |
Alarm removed for low number of available channels |
Informational |
Warning |
N/A (N/A) |
OFF |
If the available channel condition recovers, this alarm will be generated.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Radio ID |
N/A |
Integer32 |
AP Identifier |
N/A |
MAC address |
N/A |
MacAddress |
OCTET STRING(6) |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.32 |
Number of associated clients exceeded the upper limit |
Informational |
Warning |
N/A (N/A) |
OFF |
When the number of terminals on an AP exceeds the set threshold (hh3cDot11APUserThreshold), the system will generate this alarm.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
APID |
N/A |
1.3.6.1.4.1.25506.2.75.2.3.1.14 (hh3cDot11APTrapUserCnt) |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.75.2.3.1.15 (hh3cDot11APTrapUserThreshold) |
Threshold for online users of AP |
N/A |
Integer32 |
Recommended action
hh3cDot11APMtDetectedIntfAP
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.33 |
Co-channel interference from adjacent APs |
Informational |
Warning |
OFF |
When the AP detects that the signal strength of the neighboring AP on the same channel is greater than hh3cDot11IntfTrapThreshold (default value is -60dbm), this alarm is generated.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
AP Identifier |
N/A |
RADIO |
N/A |
1.3.6.1.4.1.25506.2.75.2.3.1.20 (hh3cDot11APMtChannel) |
Channel |
N/A |
Integer32 |
MAC address |
N/A |
MacAddress |
OCTET STRING(6) |
Timestamp. |
N/A |
Timeticks |
N/A |
MacAddress |
OCTET STRING(6) |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.36 |
Adjacent-channel interference from adjacent APs |
Informational |
Warning |
1.3.6.1.4.1.25506.2.75.2.3.0.37 (hh3cDot11DetcAdjChlIntfAPClear) |
OFF |
The AP detects that there are adjacent frequency channels AP and the signal strength of the adjacent AP is greater than hh3cDot11AdjIntfTrapThreshold (default value is -60dbm), then this alarm is generated.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
AP ID |
N/A |
Radio ID |
N/A |
Channel |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.75.2.3.1.22 (hh3cDot11APMtAdjChannel) |
Neighbor channel |
N/A |
Integer32 |
MAC address |
N/A |
MacAddress |
OCTET STRING(6) |
Timestamp. |
N/A |
Timeticks |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.2.3.0.37 |
Neighbor AP co-channel interference cleared |
Informational |
Warning |
N/A (N/A) |
OFF |
When the AP no longer detects any AP on the same channel or when the signal strength of all APs on the same channel is less than hh3cDot11IntfTrapThreshold (default value is -60dbm), this alarm is generated.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
AP Identifier |
N/A |
Radio ID |
N/A |
Channel |
N/A |
Integer32 |
Neighbor channel |
N/A |
Integer32 |
MAC address |
N/A |
MacAddress |
OCTET STRING(6) |
Timestamp. |
N/A |
Timeticks |
Recommended action
