- 13-Network Management and Monitoring
- 01-DISMAN-EVENT-MIB
- 02-DISMAN-PING-MIB
- 03-DISMAN-TRACEROUTE-MIB
- 04-HH3C-MIRRORGROUP-MIB
- 05-HH3C-NQA-MIB
- 06-HH3C-NTP-MIB
- 07-HH3C-RMON-EXT2-MIB
- 08-HH3C-SNMP-EXT-MIB
- 09-RMON-MIB
- 10-RMON2-MIB
- 11-SFLOW-MIB
- 12-SNMP-FRAMEWORK-MIB
- 13-SNMP-MPD-MIB
- 14-SNMP-NOTIFICATION-MIB
- 15-SNMP-TARGET-MIB
- 16-SNMP-USER-BASED-SM-MIB
- 17-SNMP-VIEW-BASED-ACM-MIB
- 18-SNMPv2-MIB
14-SNMP-NOTIFICATION-MIB | 88.69 KB |
About this MIB
Use this MIB to remotely configure the parameters used by an SNMP entity for generation of notifications.
MIB file name
rfc3413-snmp-notification.mib
Root object
iso(1).org(3).dod(6).internet(1).snmpV2(6).snmpModules(3).snmpNotificationMIB(13)
Tabular objects
snmpNotifyTable
About this table
Use this table to select the management targets to receive notifications and the type of notifications to send to each selected management target.
Support for operations
Create:Supported
Edit/Modify:Supported
Delete:Supported
Read:Supported
Columns
The table index is snmpNotifyName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpNotifyName (1.3.6.1.6.3.13.1.1.1.1) |
not-accessible |
SnmpAdminString |
OCTET STRING (1..32) |
Locally arbitrary but unique identifier of an snmpNotifyEntry. |
As per the MIB. |
snmpNotifyTag (1.3.6.1.6.3.13.1.1.1.2) |
read-create |
SnmpTagValue |
OCTET STRING (0..255) |
A single tag value used to select entries in the snmpTargetAddrTable. Any entry in the snmpTargetAddrTable that contains a tag value equal to the value of an instance of this object is selected. If the object value is zero length, no entries are selected. |
As per the MIB. |
snmpNotifyType (1.3.6.1.6.3.13.1.1.1.3) |
read-create |
INTEGER |
trap(1), inform(2) |
Type of notification to be generated for entries in the snmpTargetAddrTable selected by the corresponding instance of snmpNotifyTag. This value is only used for generation of notifications, and is ignored when snmpTargetAddrTable is used for other purposes. If the value of this object is trap(1), any messages generated for selected rows will contain unconfirmed-class PDUs. If the value of this object is inform(2), any messages generated for selected rows will contain confirmed-class PDUs. |
As per the MIB. |
snmpNotifyStorageType (1.3.6.1.6.3.13.1.1.1.4) |
read-create |
StorageType |
other(1), volatile(2), nonVolatile(3), permanent(4), readOnly(5) |
Storage type for this conceptual row. Conceptual rows with a value of permanent(4) are denied write-access to any columnar objects in the row. |
As per the MIB. |
snmpNotifyRowStatus (1.3.6.1.6.3.13.1.1.1.5) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
As per the MIB. |
snmpNotifyFilterProfileTable
About this table
This table associates a notification filter profile with a particular set of target parameters.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table index is IMPLIED snmpTargetParamsName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpNotifyFilterProfileName (1.3.6.1.6.3.13.1.2.1.1) |
read-create |
SnmpAdminString |
Name of the filter profile to be used for generation of notifications using the corresponding entry in the snmpTargetAddrTable. |
As per the MIB. |
snmpNotifyFilterProfileStorType (1.3.6.1.6.3.13.1.2.1.2) |
read-create |
StorageType |
As per the MIB. |
snmpNotifyFilterProfileRowStatus (1.3.6.1.6.3.13.1.2.1.3) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
snmpNotifyFilterTable
About this table
This table determines whether specific management targets will receive specific notifications. When a notification is generated, it must be compared with the filters associated with each management target configured to receive notifications, to determine whether it is sent to these management targets.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are snmpNotifyFilterProfileName and IMPLIED snmpNotifyFilterSubtree.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
snmpNotifyFilterSubtree (1.3.6.1.6.3.13.1.3.1.1) |
not-accessible |
OBJECT IDENTIFIER |
Standard MIB values |
MIB subtree, which is combined with the corresponding instance of snmpNotifyFilterMask, defines a family of subtrees that are included in or excluded from the filter profile. |
As per the MIB. |
snmpNotifyFilterMask (1.3.6.1.6.3.13.1.3.1.2) |
read-create |
OCTET STRING |
OCTET STRING (0..16) |
Bit mask, which in combination with the corresponding instance of snmpNotifyFilterSubtree, defines a family of subtrees that are included in or excluded from the filter profile. Each bit of this bit mask corresponds to a sub-identifier of snmpNotifyFilterSubtree, with the most significant bit of the i-th octet of this octet string value corresponding to the (8*i–7)-th sub-identifier, and the least significant bit of the i-th octet of this octet string corresponding to the (8*i)-th sub-identifier, where i is in the range of 1 through 16. Each bit of this bit mask specifies whether or not the corresponding sub-identifiers must match when determining if an object identifier matches this family of filter subtrees. A 1 indicates that an exact match must occur. A 0 indicates wild card, which means that any sub-identifier value matches. Therefore, the object identifier X of an object instance is contained in a family of filter subtrees if, for each sub-identifier of the value of snmpNotifyFilterSubtree, either the i-th bit of snmpNotifyFilterMask is 0, or the i-th sub-identifier of X is equal to the i-th sub-identifier of the value of snmpNotifyFilterSubtree. If the value of this bit mask is M bits long and there are more than M sub-identifiers in the corresponding instance of snmpNotifyFilterSubtree, the bit mask is extended with 1s to be the required length. If the value of this object is a zero-length string, this extension rule results in a mask of all-1s being used (no wild card), and the family of filter subtrees is the one subtree uniquely identified by the corresponding instance of snmpNotifyFilterSubtree. |
As per the MIB. |
snmpNotifyFilterType (1.3.6.1.6.3.13.1.3.1.3) |
read-create |
INTEGER |
included(1), excluded(2) |
Whether the family of filter subtrees defined by this entry are included in or excluded from a filter. |
As per the MIB. |
snmpNotifyFilterStorageType (1.3.6.1.6.3.13.1.3.1.4) |
read-create |
StorageType |
As per the MIB. |
snmpNotifyFilterRowStatus (1.3.6.1.6.3.13.1.3.1.5) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
