- 13-Network Management and Monitoring
- 01-DISMAN-EVENT-MIB
- 02-DISMAN-PING-MIB
- 03-DISMAN-TRACEROUTE-MIB
- 04-HH3C-MIRRORGROUP-MIB
- 05-HH3C-NQA-MIB
- 06-HH3C-NTP-MIB
- 07-HH3C-RMON-EXT2-MIB
- 08-HH3C-SNMP-EXT-MIB
- 09-RMON-MIB
- 10-RMON2-MIB
- 11-SFLOW-MIB
- 12-SNMP-FRAMEWORK-MIB
- 13-SNMP-MPD-MIB
- 14-SNMP-NOTIFICATION-MIB
- 15-SNMP-TARGET-MIB
- 16-SNMP-USER-BASED-SM-MIB
- 17-SNMP-VIEW-BASED-ACM-MIB
- 18-SNMPv2-MIB
11-SFLOW-MIB | 91.75 KB |
sFlowVersion (1.3.6.1.4.1.14706.1.1.1)
sFlowAgentAddressType (1.3.6.1.4.1.14706.1.1.2)
sFlowAgentAddress (1.3.6.1.4.1.14706.1.1.3)
SFLOW-MIB
About this MIB
Use this MIB to configure sFlow, a traffic monitoring technology.
MIB file name
sflow.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).sflow(14706).sFlowMIB(1).sFlowAgent(1)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
sFlowVersion (1.3.6.1.4.1.14706.1.1.1) |
read-only |
SnmpAdminString |
Standard MIB values. |
Version information. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
sFlowAgentAddressType (1.3.6.1.4.1.14706.1.1.2) |
read-only |
InetAddressType |
Agent address type. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
sFlowAgentAddress (1.3.6.1.4.1.14706.1.1.3) |
read-only |
InetAddress |
Agent address. |
As per the MIB. |
Tabular objects
sFlowRcvrTable
About this table
This table configures the sFlow collector information.
Support for operations
Create:Not supported
Edit/Modify:Supported
Delete:Not supported
Read:Supported
Columns
The table index is sFlowRcvrIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
sFlowRcvrIndex (1.3.6.1.4.1.14706.1.1.4.1.1) |
not-accessible |
INTEGER |
Integer32(1..65535) |
Collector index. |
As per the MIB. |
sFlowRcvrOwner (1.3.6.1.4.1.14706.1.1.4.1.2) |
read-write |
OwnerString |
Collector description. |
As per the MIB. |
sFlowRcvrTimeout (1.3.6.1.4.1.14706.1.1.4.1.3) |
read-write |
INTEGER |
Aging time. |
As per the MIB. |
sFlowRcvrMaximumDatagramSize (1.3.6.1.4.1.14706.1.1.4.1.4) |
read-write |
INTEGER |
Integer32(200..3000) |
Maximum number of data bytes that can be sent in a single sample datagram. |
As per the MIB. |
sFlowRcvrAddressType (1.3.6.1.4.1.14706.1.1.4.1.5) |
read-write |
InetAddressType |
Collector address type. |
As per the MIB. |
sFlowRcvrAddress (1.3.6.1.4.1.14706.1.1.4.1.6) |
read-write |
InetAddress |
OCTET STRING (0..255) |
Collector IP address. |
As per the MIB. |
sFlowRcvrPort (1.3.6.1.4.1.14706.1.1.4.1.7) |
read-write |
INTEGER |
UDP port number. |
As per the MIB. |
sFlowRcvrDatagramVersion (1.3.6.1.4.1.14706.1.1.4.1.8) |
read-write |
Integer32 |
Datagram version. |
Supports only V5. |
sFlowFsTable
About this table
This table configures sFlow flow sampling.
Read:Supported
Columns
The table indexes are sFlowFsDataSource and sFlowFsInstance.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
sFlowFsDataSource (1.3.6.1.4.1.14706.1.1.5.1.1) |
not-accessible |
SFlowDataSource |
Data source. |
As per the MIB. |
sFlowFsInstance (1.3.6.1.4.1.14706.1.1.5.1.2) |
not-accessible |
SFlowInstance |
Instance ID. |
As per the MIB. |
sFlowFsReceiver (1.3.6.1.4.1.14706.1.1.5.1.3) |
read- write |
SFlowReceiver |
Receiver. |
As per the MIB. |
sFlowFsPacketSamplingRate (1.3.6.1.4.1.14706.1.1.5.1.4) |
read- write |
INTEGER |
Sampling rate. |
As per the MIB. |
sFlowFsMaximumHeaderSize (1.3.6.1.4.1.14706.1.1.5.1.5) |
read- write |
INTEGER |
Integer32(18..512) |
Maximum number of bytes that should be copied from a sampled packet. |
As per the MIB. |
sFlowCpTable
About this table
This table configures sFlow counter sampling.
Read:Supported
Columns
The table indexes are sFlowCpDataSource and sFlowCpInstance.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
sFlowCpDataSource (1.3.6.1.4.1.14706.1.1.6.1.1) |
not-accessible |
SFlowDataSource |
Data source. |
As per the MIB. |
sFlowCpInstance (1.3.6.1.4.1.14706.1.1.6.1.2) |
not-accessible |
SFlowInstance |
Instance ID. |
As per the MIB. |
sFlowCpReceiver (1.3.6.1.4.1.14706.1.1.6.1.3) |
read- write |
INTEGER |
Sampling collector. |
As per the MIB. |
sFlowCpInterval (1.3.6.1.4.1.14706.1.1.6.1.4) |
read- write |
INTEGER |
Integer32(2..86400) |
Sampling interval. |
As per the MIB. |
